How to generate, customize, print and export drawing models with a BIM software for architectural design
One of the great advantages of 3D Architectural design is to be able to obtain drawings and project documentation (area plans, floor plans, cross-sections, elevation views, isometric-views, perspectives, project reports, comparison tables, tables and schedules) automatically.
You can in fact create, personalize, print, and export all of these construction documents with great ease and compose the working drawings in absolute freedom, thanks to simple Drag & Drop operations from the project navigator to the Project layout.
Export all graphical content in the DXF/DWG CAD file formats as well as the project reports in the RTF text file format.
The BIM methodology also provides specific procedures for importing and exporting in the standard IFC format. A very important aspect when having to satisfy the need of exchanging information and model data, regardless of the software used.
All working drawings are automatically composed by the software with the General Data and further detailing can be achieved by adding custom graphics and text elements.
Working drawings are then saved within the project and can always be re-used.
Let’s start off by simply creating the various project views, such as, cross-sections and elevation views of an Edificius project.
After completing the modelling process, adding 2D Graphical objects, available in the online catalogue, we can easily generate the relating project drawing models.
These drawings are automatically generated by simply placing the relating “Drawing Model” object in the various Levels that form the building. Adding a Floor Plan, Cross-section view or Elevation view simply adds a new Drawing Node under the relating section in the Program’s Project Navigator. No need to worry about anything else. Edificius does it all for you allowing you to simply choose between various illustration styles, shadow settings or add construction details for extra professionalism.
Let’s see how.
Floor Plans
Selecting the Floor plan object from the Architectural objects menu
Generating the Project floor plan with Edificius
Cross-sections
Selecting the cross-section object type
Generating cross-sections and Views with Edificius
Elevation views
Selecting the elevation view
Generating the elevation view
Edificius, for extra flexibility, even allows the user to edit the BIM model directly from the cross-section view.
Editing the BIM Model from a Drawing Model view
And modify the illustration styles too.
Editing and customising a Drawing model style in Edificius
To export or print the drawng models, simply select the “Print” button, from the program’s quick access toolbar, to see a print preview, make the necessary adjustments and proceed with printing.
Printing management
Print management
Customising documents and prints in Edificius
Other types of project exports can be used when accessing the Export section of the Edificius Home page
Exporting to DXF and DWG CAD file formats
To compose a project report simply add a new report node in the project navigator.
Composing the Architectural reports
Or view tables and schedules.
Viewing Tables and Schedules
Choose the appropriate title block and compose as many Working Drawings as you need. The wide range of ready-made templates can be easily edited according to the user’s needs.
Selecting a Title Block in Edificius
You can customize as many Working Drawing layout as you like by simply dragging and dropping the individual Drawing Models from the project navigator to the working drawing layout.
Composing working drawings with drag and drop
Example of a working drawing layout with Edificius
Click here to find out more about Edificius and its features. Download the architectural BIM design software.
