Evolution of the BIM methodology: LOD as “Level of Development” and clarifications for its use published by the American Institute of Architects
In a 2008 publication by the AIA (American Institute of Architects) the term “Level of Development” was used for the first time and was proposed internationally as the meaning of the LOD acronym.
Degree of reliability of information in BIM and LOD
The need to quickly understand the degree of reliability of information transmitted by a BIM model was to imagine its classification by using specific indicators and for this purpose, the LOD acronym quickly gained wide dissemination.
Definition of LOD according to AIA
The contribution of the AIA has been valuable in providing the definition of “Development Level” specifying the meaning and scope of the application: following the raised interest, the first paper, published in 2008 was followed by various updates in 2013.
The AIA documents mentioned are:
  • AIA Document E202™ – 2008, Building Information Modeling Protocol Exhibit;
  • AIA Document E203™ – 2013, Building Information Modeling and Digital Data Exhibit;
  • AIA Document G201™ – 2013, Project Digital Data Protocol Form;
  • AIA Document G202™ – 2013, Project Building Information Modeling Protocol Form.
  • Guide, Instructions and Commentary to the 2013 AIA Digital Practice Documents:
  1. AIA Document E203™–2013, Building Information Modeling and Digital Data Exhibit;
  2. AIA Document G201™–2013, Project Digital Data Protocol Form;
  3. AIA Document G202™–2013, Project Building Information Modeling Protocol Form.
The definition of LOD as “Level of Development” and its meaning
Let’s see how AIA has in time expressed the meaning of “level of development”, starting with the definition proposed in 2008:
“The Level of Development” (LOD) describes the level of completeness with which a Model Element is developed”.
This definition soon changed to a second meaning in 2013, which further clarified and strengthened its contents:
“Development Level” (LOD) describes the minimal dimensional, spatial, quantitative, qualitative, and other data included in a Model Element to support the Authorized Uses associated with that specific LOD”.
The intent that obviously derives from such definitions is to give a wider meaning to the “Development Level” expression, including both graphical and non-graphical aspects, to clearly indicate the “completeness with which a Model Element is developed”.
This same orientation also emerges by observing how the descriptions of each of the model “Development Levels” envisaged by AIA are to be broken down into two parts:
  • “Model Element Content Requirements”, where the minimum requirements, especially in terms of representation, are defined, which must be owned by the model element so that it can be said to be developed at a given LOD;
  • Authorized Uses”, where the uses that the model elements must allow for the considered LOD are specified; In other words, performance is prescribed by the degree of accuracy and reliability of the information transmitted by the model element.
Classification of the “Level of Development” proposed by the American Institute of Architects (AIA)
The proposed classification of LODs consists of 5 levels (100 to 500), each of which can be associated to the following meanings:
LOD 100 – Concept;
LOD 200 – Approximate geometry;
LOD 300 – Precise geometry;
LOD 400 – Adapted to realization;
LOD 500 – “as built”.
Each subsequent LOD is based on the previous level and includes all features contained in the previous levels. This allows, at a certain stage of project development, to have different LODs for different elements of the model.
For example, a first sizing of the air conditioning system (LOD “low”) will require a more definitive degree of definition of air conditioning volumes (LOD “high”), such as to allow heat load assessments and calculations.
Click here for more information regarding Edificius, the architectural BIM design software. Download the free trial here.
