IFC objects OmniClass classification
IFC objects classification: how to classify IFC model entities with the OmniClass system
Do you need to classify the entities of an IFC project or to read a classification associated with the entities present in an IFC file? This post is all about OmniClass classification system.
We’ll be taking a closer look at what OmniClass classification is, what it is used for and how to use it in order to classify and add information to the entities of an IFC model. We’ll also provide you an example in IFC format that will allow you to classify objects with the aid of usBIM.viewer+ (the freeware to easily manage IFC files).
OmniClass logo
What is the OmniClass classification system?
OmniClass is a system adopted in North America (according to ISO 12006-2 international standard) and used for the organizing and retrieving of information throughout the full facility life cycle, from conception to demolition. The system adapts to all levels of detail of a work: be it industrial, commercial or residential, from materials to construction systems.
OmniClass consists of 15 tables, each of which deals with different construction information.
Each table can be used individually or in combination with others to classify more complex information, while the system can always be updated with the addition of new elements.
The tables organization draws its definitions from ISO 12006-2:
  • tables 11 to 22 describe construction results
  • tables 23-33-34-35 and partly 36 and 42 classify information on construction resources
  • tables 31 and 32 organize the construction processes and phases throughout the construction life cycle.
The chart below shows some examples to better understand how to classify an entity with the OmniClass system.
Table cod.
Number cod.
DescriptionExample
Table 1111-00 00 00Entities of the construction system (classified by function)Private residences, hotels, congress centres, bus stations, motorways, etc.
Table 1212-00 00 00Entities of the construction system (classified by shape)Apartment houses, skyscrapers, bridges, landing platforms, etc.
Table 1313-00 00 00Spaces (classified by function)Bedrooms, offices, gyms, motorways, etc.
Table 1414-00 00 00Spaces (classified by shape)Courtyards, patios, recesses, interspaces, etc.
Table 2121-00 00 00Elements (including designed elements)Exterior walls, stairs, roof, furniture, etc.
Table 2222-00 00 00Activity resultsMetal carpentry, concrete casting, ceramic coating, lighting system, plumbing pipes, railroad tracks, etc
Table 2323-00 00 00ProductsConcrete, bricks, mortar, windows, boilers, manholes, etc.
Table 3131-00 00 00PhasesDefining the project concept, preparing documents to obtain a building permit, the construction phase, disposing of construction waste, etc.
Table 3232-00 00 00ServicesPlanning, the offer, construction estimating, site surveying, etc.
Table 3333-00 00 00DisciplinesArchitecture, construction company, structural engineering, administration, etc.
Table 3434-00 00 00Organizational rolesSite engineer, designer, plant designer, BIM manager, real estate agent, process manager, etc.
Table 3535-00 00 00ToolsScaffolding, work tools, design and calculation software, construction site fencing, vehicles, formwork, etc.
Table 3636-00 00 00InformationsProject files, building regulations, property titles, maintenance and management manuals, site journal, etc.
Table 4133-00 00 00MaterialsSteel, wood, concrete, plastic, etc.
Table 4949-00 00 00PropertiesColour, area, length, transmittance values, fire resistance, etc.
Each information is classified and detected by a six-digit identification code which refers to the table.
The first two digits indicate the reference table while the subsequent pairs of numbers identify the typology for each level.
For example, a foundation wall is identified by the code 21-01 10 10 10, corresponding to:
  • table 21 – Elements
  • level 1 – Substructures
  • level 2 – Foundations
  • level 3 – Standard foundations
  • level 4 – Foundation wall.
In this way, by reading the code and the classification system adopted, it is possible to uniquely identify an entity and retrieve more information about it.
Implementation of the OmniClass classification system in usBIM.viewer +
How to classify IFC entities with usBIM.viewer +
We’ll now show you how to classify any entity (e.g. roof, wall, window, etc.) of an IFC model. You can try yourself to classify the elements of the IFC example using the freeware usBIM.viewer+.
Here are the steps to follow to classify IFC entities, according to the OmniClass classification system:
  • download and install usBIM.viewer+ for free
  • click File>Open and select the IFC to upload (you can use the example that we’ve prepared for you or any other IFC file)
  • click Edit IFC>Edit to model the file
  • select (either manually or with the help of selection groups) the objects to classify
  • in the Select Classification section on the toolbar click on Edit
  • in the pop-up dialog, select the type of classification, in our case OmniClass, and the subcategories to associate with the selected entity
  • once the operation is complete, click on Confirm.
This is how you can classify an entity or group of entities according to the OmniClass system.
Below the steps of the process for classifying an element according to the OmniClass standard.
How to set the OmniClass classification with usBIM.viewer +
For further testing you can download the IFC file for free and view a project classified according to the OmniClass system.
To verify the entity classification in an IFC file you can use again usBIM.viewer+.
Follow these simple steps:
  • open the file with usBIM.viewer+
  • select an entity (for example a door, a wall, a slab, etc.)
  • read the information relating to the classification on the Properties toolbox on the right-hand side:
    • IfcClassificationReference will report the code;
    • IfcClassification will specify the information relating to the type of classification system adopted (in this case OmniClass).
OmniClass classification of a project entities with usBIM.viewer+
Remember that with usBIM.viewer+ you can classify objects according to the main classification systems:
  • MasterFormat
  • NatSpec
  • NBS Create
  • OmniClass
  • UniClass (versione 2)
  • UniClass 2015
  • UniFormat.
Omniclass classification system
Classification systems available in usBIM.viewer +
usbim-viewer
usbim-viewer
