Office design, the practical guide_software-BIM-architecture-Edificius
Office design: types, standards, functional layouts and interior design. A complete guide to optimal office space planning, together with practical examples, DWGs and a 3D model to download
A comfortable and well designed office is the "ideal" place where to work, because the employee's well-being increases production quality and quantity. Furthermore, offices are environments where people spend most of their day. Therefore, designing an office is an important topic to address.
In addition to the specific standards, it is important to consider other design aspects, such as ergometry and workstations arrangement.
In this article we will provide an overview about how to design a smart workplace focusing on the following aspects:
  • reference standards
  • types of offices
  • spaces arrangement
  • working environment comfort
  • equipments
  • electric power systems.
In addition, we’ll be taking a look at different types of office spaces by developing an open space office project, and produce the relating DWG drawings and the 3D model that you can download for free.
Download and try Edificius, the architectural BIM design software
Download the 3D BIM model (.edf file) of the office project
Office design, international standard examples
Safety standards and a series of provisions to protect workers’ health are envisaged at international level and must be taken into account when planning an office.
An organizational approach, premises, furnishings, technical equipment and the configuration of work stations should be functional according to the activities carried out and are key for the employees’ well-being. Standards promote sustainability in a workplace and their importance is evident
Let's see some examples of rules and/or standards to follow.
  • ISO
ISO, The International Organization for Standardization, has developed some international standards, including:
The terms of both standards have been applied through various national annexes.
  • European Union
Each EU country has implemented the following directives concerning the improvement of health and safety in a workplace:
References in this regard are issued for US designers by the following organizations:
Some workplaces in Canada fall under the federal legislation, regulated by:
However, the majority of workplaces are regulated by local regulations.
  • Brazil
Safety in a workplace in Brazil is regulated by:
Different regulations for a workplaces design are present in Mexico, but the two main ones are:
How to design an office: types of offices
It is fundamental to establish, already during the planning phase, which activities will be carried out within the premises and which are the requirements for a correct workstations configuration.
come progettare un ufficio_aerial-render_software-BIM-architecture-Edificius
We can distinguish different types of office space:
  • cellular office layout – the floor plan is divided up into smaller or individual spaces, suitable for individual work and which do not require information exchange. This can be done by creating various separate rooms or cubicles by means of half-height dividing partitions within the larger floor plan.
  • open plan office – is a term for any floor plan which makes use of large, open and undivided space for multiple workstations. It is an option suitable for large groups of employees, whose work is largely divided and based on routine activities requiring low concentration levels.
  • activity-based office – spaces are designed to create opportunities for a variety of workplace activities. It involves different types of meetings and interactive situations. Employees will change their workstation during the day according to the type of task that they need to complete.
  • team enclosures – team offices allow members of the same team to work together without losing concentration and getting distracted by people not in their immediate team. This is ideal for creative teams where brainstorming and discussion are a large part of the day routine.
How to design an office: space arrangements
A workplace must be well designed keeping in mind its final use and avoiding lack of movement for employees.
Office design, the practical guide_functional-layout_software-BIM-architecture-Edificius
Office environment dimensions
Generally, when designing an office, the following minimum dimensions need to be considered for each environment:
  • net height 2,70 m
  • surface 9 m²
  • surface per employee at least 5 m²
Office design, the practical guide_B-B-section_software-BIM-architecture-Edificius
Service areas
Service areas are those that do not involve continues presence of people (such as corridors, warehouses and archives, changing rooms, toilets, possible shower rooms, etc).
Changing rooms and toilet areas cannot be in direct contact with the work environments, so a passageway must be provided.
Service areas can be:
  • obtained from aboveground, basement or semi-basement rooms;
  • ventilated both naturally or through ventilation systems.
Office design, the practical guide_render-detail-open-plan_software-BIM-architecture-Edificius
Accessory and support environments
Accessory or support areas includes:
  • health facilities (medication rooms, clinics);
  • refectories or company canteens;
  • living and resting areas.
Accessory and support environments must be provided with the same ventilation and lighting characteristics that are intended for the other work spaces, even through plant installations when necessary.
Office design, the practical guide_office-render_software-BIM-architecture-Edificius
Mezzanines used for office purposes
Typically, a stud and track partitioning system will be used to build the required room above or below the mezzanine floor. There are a certain number of aspects to consider when designing an office mezzanine floor. From building contol consideration, through to power and lighting requirements. In addition, when designing a mezzanine floor it is important that the correct loadings and deflection are calculated.
Office design, the practical guide_A-A-section_software-BIM-architecture-Edificius
Workplace comfort
When designing an office, the comfort of the environment and of the workers, as already mentioned, is of fundamental importance. Other aspects that must be taken into account are:
Lighting
Lighting design in a workplace is perhaps one of the most difficult aspects to manage, because it is connected to production capacity and it should also guarantee that psycho-physical conditions are best preserved, thus making the working environment a more comfortable and safe place.
Office environments ventilation
Ventilation in the office is an aspect that should not be underestimated, since microclimate conditions (including air speed, humidity and temperature) are very important to ensure the well-being of those who work there.
Many regulations worldwide state that, workplaces need to be adequately ventilated in the proper manner by which clean air is drawn from an external source outside of the workplace and circulated throughout the building. Whether by natural or mechanical means, it should dilute and remove humid air and provide sufficient air movement to give a feeling of freshness without causing a draught.
Office design, the practical guide_C-C-section_software-BIM-architecture-Edificius
Noise
One of the elements that contribute to workers’ well-being is the control of acoustic requirements of the working environment.
When designing an office, in order to have good acoustic comfort, and always considering the type of activities that will be carried out, it is advisable to provide offices with closed compartments rather than areas with side wall partitions and false ceiling.
Office design, the practical guide_render-meeting-room_software-BIM-architecture-Edificius
Office design, the practical guide_render-open-space_software-BIM-architecture-Edificius
Project DWGs of an office open space
In this section you'll have the opportunity to download the project drawings (floor plans and sections) in DWG and the 3D BIM model for free.
Download and try Edificius, the 3D architectural BIM design software
Download the 3D BIM model (.edf file ) of an office project
Download the project DWG drawings
