Open plan kitchen and living useful tips and examples
Open plan kitchen and living room: useful tips and examples
How to design an open plan kitchen and living room: in this article free 3D BIM models and a video to show you the steps for a successful space planning
Open plan kitchen and living room is a popular design choice for modern homes where barriers, such as walls and doors, are eliminated and distinct functional areas are integrated into a single shared space.
The open plan kitchen and living room describes a scenario where:
• existing interior spaces are reconfigured by merging two rooms that were originally conceived as separate
• a single kitchen-living room environment is designed from scratch.
In this focus we’ll see how to design an open plan providing pros and cons and some useful tips to correctly map out home spaces in full compliance with building regulations. You will also have the opportunity to download the 3D file and DWG CAD resources of a project example that we have created together with brief summary slides.
Open plan kitchen and living room rendering
Open plan design | Rendering produced with Edificius
Open plan kitchen and living room layouts and types
Depending on your needs and the spaces available, it is possible to design an open plan with kitchen and living room that is:
  • fully integrated
  • partially integrated.
In case of pre-existing environments, to obtain an open plan with fully integrated kitchen and living room (diagram 1 – 3) it is necessary to verify that it is possible to completely demolish the partitions separating the two environments. In case of frame structures, the actual position of columns should be assessed so as to organize the space, thus avoiding any interference with existing structural elements. Hence, reviewing the building’s structural layout will avoid to come across unexpected events that could compromise the quality and functionality of the spaces to be designed during demolition works.
In case of a structure with load-bearing walls, openings must be designed in sufficiently large rooms to obtain the perception of a single space. Once the feasibility of the intervention has been established, it will be possible to proceed with the project design phase.
Open floor plan kitchen and living room
Designing an open plan – Scheme 1 | Fully integrated kitchen and living room
The great challenge when designing a functional open plan kitchen and living room is to obtain a large but non-dispersive environment that preserves stylistic coherence. If the environment is very large, it is better to avoid false ceiling installation that further lower the inter-floor height, making the environment not proportioned.
Knocking through between an existing kitchen and living room to generate a single environment requires selecting furniture that adapts to different functions. For example, using kitchen islands or peninsulas can result very handy making an efficient use of space. In addition, they can work as equipped cooking surfaces or be suitable for dining, but also a division element between the cooking area and the dining / living area, or serve as a bar counter for breakfast or for aperitifs with friends.
Generally speaking, when separating areas, it is advisable not to use furniture that is too high but rather to opt for lighter and more creative solutions. In some cases, in fact, it is also sufficient to just add carpets, low-level furniture and false ceiling.
Open floor plan living
Design an open plan – Scheme 2 | Partially integrated kitchen and living room
If you prefer to have two adjoining rooms that still maintain some privacy, or if you are facing structural constraints that cannot be overcome, it would be more appropriate to design an open plan with a partially integrated kitchen and living room.
In this case, flexible design solutions can be pursued to guarantee more privacy, when needed. The kitchen and the living area can, for example, be separated by retractable sliding doors or by movable walls. The space thus obtained will be multi-functional and adaptable to any type of situation.
This instance is shown in diagram 2. The kitchen and living room are separated by a low wall that works as a supporting element both to the kitchen and the sofa in the relaxation area. The two functions are contiguous and connected but retain a certain visual privacy, developing along two opposite perspective directions. Specifically, furnishings are positioned along the back (kitchen and sofa), so that those using them at the same time, look at opposite sides of the room, avoiding mutual visual interference.
Design an open space – Scheme 3 | Fully integrated kitchen and living room
Scheme 3 represents the case of an open space project with fully integrated functions. The environment is a single space and the characteristics of the different areas are determined by furnishing elements. The wall, which is equipped with shelves and tv furniture, defines the areas space and connects them perfectly.
Designing an open plan: pros and cons
A multi-functional open plan kitchen and living room allows for many household activities and cretaes a family friendly environment. Now people want the kitchen to be an active part of their home, and open concept kitchen are by far a very popular choice today.
Pros of an open plan kitchen and living room, that can be managed during planning phase, are:
  • brighter environments
  • space optimization
  • more usable and functional spaces
  • greater sharing and interaction between users
  • more flexible, dynamic and modern spaces.
Open floor plan kitchen and living room, rendering made with Edificius
Open plan living | Interior space rendering
Cons of an open plan kitchen and living room are:
  • lack of privacy
  • less vertical partitions to place furniture
  • interference between different domestic activities
  • spread of noises, smell and fumes from the kitchen throughout the living area.
Finding creative solutions that can enhance quality and reduce cons will be a major challenge for the designer.
5  fundamental rules to design an open plan kitchen and living room
Summarizing, here is a list of some good design rules to consider when designing an open plan:
  • prefer multi-functional furnishings that adapt to a practical kitchen and are consistent with the style chosen
  • create a fluid space characterized by movable elements (doors or walls)
  • differentiate the various areas of the open plan (reading area, relaxation area, dining room, kitchen, etc.) with false ceilings, low-level furniture or carpets
  • in the event of renovation, verify the position of existing structural elements (columns, beams, load-bearing walls, etc.) to avoid unexpected interference during works.
A pratical example
The case study below is a practical example that can guide you when designing an open plan. Let’s suppose we have a space with a rectangular floor plan and access on the long side, located in a central position.
How to design an open plan dining
Open plan design | Floor plan
Since the entrance naturally divides the space into two areas, we have a kitchen on the right and the living area on the opposite side. The kitchen is located on the longer side of the floor plan and has a parallel multifunctional island. The L-shaped island has a wooden top that can be used for dining.
How tod esign an open plan dining, cross section made with Edificius
Open plan design | cross section
Along the kitchen opposite wall, there is a wall equipped with built-in wardrobes that offer wide room for storing food, small appliances and dishes. The wardrobes also develop towards the living area, creating continuity between the kitchen area and the living area. A resin fireplace with cement effect, a white leather sofa and a large glass dining table are the main elements of the living area. The large full-height windows give a modern touch to the whole environment.
Download the project 3D BIM model (.edf file)
Slides
Video
