what is BIM
What is BIM and what is it for? Everything you need to know
BIM is the acronym for ‘Building Information Modelling ‘. In this article, we’ll find out more about what BIM actually is and how its implementation can improve your design workflow!
The construction sector has been lagging behind other industries when it comes to digital adoption until recently. Today, however, construction is going through a radical transformation thanks to BIM and new technological advances that are majorly impacting its productivity and efficiency.
But what is BIM? What are its benefits to the construction industry?
What is BIM?
BIM stands for ” Building Information Modeling ” or Building Information Model. The NIBS (National Institutes of Building Science) defines BIM as the “digital representation of physical and functional characteristics of an object”.
First of all, it is necessary to clarify that BIM is an operational methodology and not a tool. BIM can be intended as a process for:
  • programming
  • designing
  • operations
  • maintenance
of a building that uses a data-rich, object-oriented and parametric representation of the facility, that is basically a model carrying all the information relating to the building over the course of its entire life cycle. In other words, taking into account design, construction, operations, demolition and dismissal/waste treatment.
BIM life cycle
What is BIM (Building Information Modelling)
Across the industry, BIM can be defined as a collaboration process by different stakeholders at different phases of a building’s lifecycle, in order to add, export, update or edit the information of a BIM model.
For example, the architectural designer defines shapes, geometries of the 3D model; the structural designer defines the structure’s elements (beams, columns, walls, foundations, etc.), etc.
meaning of BIM collaboration
BIM collaboration
BIM is therefore a modern process for construction project management that allows you to produce a virtual building model, or dynamic model, including a series of information on its:
  • geometry
  • materials
  • load-bearing structure
  • thermal properties and energy performance
  • technical installation systems
  • costs
  • health and safety
  • maintenance
  • life cycle
  • demolition
  • dismissal
  • etc.
As a matter of fact, the technology component of BIM helps project stakeholders to visualize what is to be built in a simulated environment to identify any potential design, construction or operational issues through the contribution and interoperability of all the figures involved in the project (architects, engineers, consultant designers, energy analysts, etc).
BIM interoperability
the interoperability concept
In short, BIM is a highly strategic approach which offers the possibility to analyze the architectural object and evaluate its performance already during the design stage.
Here is the answer to the recurring question ‘what is BIM?
BIM is not a software, but it is rather an approach, a methodology that allows you to create a realistic shared information model. Specifically, BIM collects all the information relating to the development, growth and analysis process of multidimensional virtual models which are digitally generated by using specific software.
BIM and design
The specific functions of each discipline are managed by different software. Each professional involved in the BIM project will carry out that specific part of the project with his own BIM authoring software.
Therefore, BIM authoring software can be defined as applications capable of defining the characteristics and properties for a specific design aspect in the 3D virtual model and according to their purpose (architectural, structural, installation systems engineering, infrastructural design).
BIM and architectural design
BIM definitely offers a clear advantage to designers and the potential to bring great efficiency among players.
working drawings in a BIM project
working drawings produced with Edificius
For the professionals (architects, surveyors, engineers) involved in a project, BIM allows for a virtual information model that encompasses all the aspects relating to design to be communicated from the design team to the main contractor. In addition, thanks to BIM, each specific professional can add specific data to the single-shared model and from simple parametric architectural objects (beams, columns, walls, windows, etc.) they can automatically obtain floor plans, elevation and cross-section views.
This means that every variation made to the BIM model corresponds to an automatic and dynamic updating of all related drawings and construction details!
The use of BIM obviously translates into increased productivity, as it completely erases the possibility of making mistakes or having misalignments between the various working drawings and documents.
Various BIM software are integrated with “Real Time Rendering” technology that allows you to obtain photorealistic architectural renderings in real time, just as it is designed with the BIM, without having to waith hours for a render top process.
BIM rendering example
Exterior render produced with Edificius
Thanks to Real Time Rendering you can evaluate your design choices, experiment with new shapes, materials, objects, lights, etc. and instantly verify any kind of design hypothesis.
Rendering/sketch created with con Edificius
BIM and structural calculation
Even in the structural sphere, BIM technology clearly demonstrates the significant benefits that increase productivity.
In this case, the structural designer avoids having to start all over to re-model the structure again. This drastically reduces the possibility of making mistakes.
BIM structural project
structural project created with EdiLus
Thanks to BIM integration with the aspects of structural calculations, adding structural information, such as, (columns, beams, materials, reinforcements, etc.) and perform the relating calculations, is amazingly straight-forward and easy to manage completing the entire process with all the necessary construction documents and drawings.
BIM MEP software
Thanks to the BIM integration with the plant engineering (MEP), it is possible to enrich the 3D model with all the plant engineering elements: ducting, cable paths, junction boxes, electrical switch panels, etc..
In this way it becomes easy to have control over the entire installation project and see if there are possible conflicts with the architectural design or with the structural members.
Obviously, without the use of BIM technology, installation system design remains something confined in itself and it is not possible to have an overview of the building.
BIM MEP project
Installation system produced with Edificius-MEP
BIM and construction estimating
Thanks to the integration with BIM you can get detailed cost estimates of the project in a completely automatic way.
The advantages in this case are also remarkable: the resulting estimates is obtained is dynamic, that is, every variation of the project corresponds to a real-time variation of the cost estimate and therefore, the total project cost. All this, once again, avoids the design team a lot of aggravation and any risks in making mistakes.
BIM and CAD, what are the differences?
BIM is not simply the evolution of CAD. It is a completely new way of looking at the design and construction of a building.
Designers who still use CAD for their building projects draw a significant amount of lines and polylines to represent objects (doors, windows, walls, balconies) to manually generate other relevant construction drawings (floor plans, section, elevation views and isometric cut-away).
This means that many designers probably still don’t understand the obvious advantages offered from the use of BIM technology.
What are the advantages offered by BIM?
Using BIM gives you great benefits that result in:
    • time and cost savings: the designer will no longer have to draw an incredible amount of lines, polylines, and geometric shapes (which take a long time), but simply have dedicated smart objects with their own properties and information (material, cost, thermal capacity, maintenance, etc.)
    • error reduction: floor plans, elevation views, and cross-sections are simply different views of the same object. Any modification to the BIM model affects all the correlated views and representations
    • more simplicity: easily create even complex models. Anyone involved in architectural design can now expand his/her creative skills by proposing ideas and solutions that would never be reached using a traditional CAD application.
Find out more about ACCA software easy-to-use BIM solutions
usbim-platform
usbim-platform
