{"name":"BibLus","description":"Blog von Know-how und Software f\u00fcr Architektur, Engineering und Konstruktion","url":"https:\/\/biblus.accasoftware.com\/de","home":"https:\/\/biblus.accasoftware.com\/de","gmt_offset":1,"timezone_string":"Europe\/Rome","page_for_posts":0,"page_on_front":661,"show_on_front":"page","namespaces":["oembed\/1.0","akismet\/v1","contact-form-7\/v1","real-custom-post-order\/v1","real-utils\/v1","siteground-settings\/v1","siteground-optimizer\/v1","uap\/v2","automator\/v1","yoast\/v1","biblus\/v1","regenerate-thumbnails\/v1","wp\/v2","wp-site-health\/v1","wp-block-editor\/v1","wp-abilities\/v1"],"authentication":{"application-passwords":{"endpoints":{"authorization":"https:\/\/biblus.accasoftware.com\/de\/wp-admin\/authorize-application.php"}}},"routes":{"\/":{"namespace":"","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/"}]}},"\/batch\/v1":{"namespace":"","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"validation":{"type":"string","enum":["require-all-validate","normal"],"default":"normal","required":false},"requests":{"type":"array","maxItems":25,"items":{"type":"object","properties":{"method":{"type":"string","enum":["POST","PUT","PATCH","DELETE"],"default":"POST"},"path":{"type":"string","required":true},"body":{"type":"object","properties":[],"additionalProperties":true},"headers":{"type":"object","properties":[],"additionalProperties":{"type":["string","array"],"items":{"type":"string"}}}}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/batch\/v1"}]}},"\/oembed\/1.0":{"namespace":"oembed\/1.0","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"oembed\/1.0","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/oembed\/1.0"}]}},"\/oembed\/1.0\/embed":{"namespace":"oembed\/1.0","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"description":"Die URL der Ressource, f\u00fcr die oEmbed-Daten abgerufen werden sollen.","type":"string","format":"uri","required":true},"format":{"default":"json","required":false},"maxwidth":{"default":600,"required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/oembed\/1.0\/embed"}]}},"\/oembed\/1.0\/proxy":{"namespace":"oembed\/1.0","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"description":"Die URL der Ressource, f\u00fcr die oEmbed-Daten abgerufen werden sollen.","type":"string","format":"uri","required":true},"format":{"description":"Das zu verwendende oEmbed-Format.","type":"string","default":"json","enum":["json","xml"],"required":false},"maxwidth":{"description":"Die maximale Breite des eingebundenen Frames in Pixel.","type":"integer","default":600,"required":false},"maxheight":{"description":"Die maximale H\u00f6he des eingebundenen Frames in Pixel.","type":"integer","required":false},"discover":{"description":"Ob eine oEmbed-Discovery-Anfrage f\u00fcr nicht autorisierte Anbieter durchgef\u00fchrt werden soll.","type":"boolean","default":true,"required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/oembed\/1.0\/proxy"}]}},"\/akismet\/v1":{"namespace":"akismet\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"akismet\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/akismet\/v1"}]}},"\/akismet\/v1\/key":{"namespace":"akismet\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":{"key":{"type":"string","description":"Ein 12-stelliger Akismet-API-Schl\u00fcssel. Erh\u00e4ltlich unter akismet.com\/account","required":true}}},{"methods":["DELETE"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/akismet\/v1\/key"}]}},"\/akismet\/v1\/settings":{"namespace":"akismet\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":{"akismet_strictness":{"type":"boolean","description":"Wenn \u201etrue\u201c, wird Akismet den schlimmsten Spam automatisch l\u00f6schen, anstatt ihn in den Spam-Ordner zu verschieben.","required":false},"akismet_show_user_comments_approved":{"type":"boolean","description":"Wenn \u201etrue\u201c, wird die Anzahl der freigegebenen Kommentare neben jedem Kommentarautor in der Kommentarliste angezeigt.","required":false},"akismet_enable_mcp_access":{"type":"boolean","description":"Wenn \u201etrue\u201c, wird MCP-Clients Zugriff auf die Daten und Funktionen von Akismet gew\u00e4hrt.","required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/akismet\/v1\/settings"}]}},"\/akismet\/v1\/stats":{"namespace":"akismet\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"interval":{"type":"string","description":"Der Zeitraum, f\u00fcr den Statistiken abgerufen werden. Optionen: 60-days, 6-months, all","default":"all","required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/akismet\/v1\/stats"}]}},"\/akismet\/v1\/stats\/(?P<interval>[\\w+])":{"namespace":"akismet\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"interval":{"description":"Der Zeitraum, f\u00fcr den Statistiken abgerufen werden. Optionen: 60-days, 6-months, all","type":"string","required":false}}}]},"\/akismet\/v1\/alert":{"namespace":"akismet\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"key":{"type":"string","description":"Ein 12-stelliger Akismet-API-Schl\u00fcssel. Erh\u00e4ltlich unter akismet.com\/account","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"key":{"type":"string","description":"Ein 12-stelliger Akismet-API-Schl\u00fcssel. Erh\u00e4ltlich unter akismet.com\/account","required":false}}},{"methods":["DELETE"],"args":{"key":{"type":"string","description":"Ein 12-stelliger Akismet-API-Schl\u00fcssel. Erh\u00e4ltlich unter akismet.com\/account","required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/akismet\/v1\/alert"}]}},"\/akismet\/v1\/webhook":{"namespace":"akismet\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/akismet\/v1\/webhook"}]}},"\/contact-form-7\/v1":{"namespace":"contact-form-7\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"contact-form-7\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/contact-form-7\/v1"}]}},"\/contact-form-7\/v1\/contact-forms":{"namespace":"contact-form-7\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/contact-form-7\/v1\/contact-forms"}]}},"\/contact-form-7\/v1\/contact-forms\/(?P<id>\\d+)":{"namespace":"contact-form-7\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/contact-form-7\/v1\/contact-forms\/(?P<id>\\d+)\/feedback":{"namespace":"contact-form-7\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}]},"\/contact-form-7\/v1\/contact-forms\/(?P<id>\\d+)\/feedback\/schema":{"namespace":"contact-form-7\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/contact-form-7\/v1\/contact-forms\/(?P<id>\\d+)\/refill":{"namespace":"contact-form-7\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/real-custom-post-order\/v1":{"namespace":"real-custom-post-order\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"real-custom-post-order\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/real-custom-post-order\/v1"}]}},"\/real-custom-post-order\/v1\/plugin":{"namespace":"real-custom-post-order\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/real-custom-post-order\/v1\/plugin"}]}},"\/real-utils\/v1":{"namespace":"real-utils\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"real-utils\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/real-utils\/v1"}]}},"\/real-utils\/v1\/feedback\/(?P<slug>[a-zA-Z0-9_-]+)":{"namespace":"real-utils\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"reason":{"type":"string","required":true},"note":{"type":"string","required":true},"email":{"type":"string","required":false}}}]},"\/real-utils\/v1\/cross\/(?P<slug>[a-zA-Z0-9_-]+)\/(?P<action>[a-zA-Z0-9_-]+)\/dismiss":{"namespace":"real-utils\/v1","methods":["DELETE"],"endpoints":[{"methods":["DELETE"],"args":{"force":{"type":"boolean","default":false,"required":false}}}]},"\/real-utils\/v1\/rating\/(?P<slug>[a-zA-Z0-9_-]+)\/dismiss":{"namespace":"real-utils\/v1","methods":["DELETE"],"endpoints":[{"methods":["DELETE"],"args":{"force":{"type":"boolean","default":false,"required":false}}}]},"\/siteground-settings\/v1":{"namespace":"siteground-settings\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"siteground-settings\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/siteground-settings\/v1"}]}},"\/siteground-settings\/v1\/update-settings":{"namespace":"siteground-settings\/v1","methods":["PUT"],"endpoints":[{"methods":["PUT"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/siteground-settings\/v1\/update-settings"}]}},"\/siteground-optimizer\/v1":{"namespace":"siteground-optimizer\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"siteground-optimizer\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/siteground-optimizer\/v1"}]}},"\/siteground-optimizer\/v1\/webp-support":{"namespace":"siteground-optimizer\/v1","methods":["PUT","GET"],"endpoints":[{"methods":["PUT"],"args":[]},{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/siteground-optimizer\/v1\/webp-support"}]}},"\/siteground-optimizer\/v1\/reset-webp-conversion":{"namespace":"siteground-optimizer\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/siteground-optimizer\/v1\/reset-webp-conversion"}]}},"\/siteground-optimizer\/v1\/fetch-options":{"namespace":"siteground-optimizer\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/siteground-optimizer\/v1\/fetch-options"}]}},"\/siteground-optimizer\/v1\/enable-option":{"namespace":"siteground-optimizer\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/siteground-optimizer\/v1\/enable-option"}]}},"\/siteground-optimizer\/v1\/disable-option":{"namespace":"siteground-optimizer\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/siteground-optimizer\/v1\/disable-option"}]}},"\/siteground-optimizer\/v1\/combine-css":{"namespace":"siteground-optimizer\/v1","methods":["PUT"],"endpoints":[{"methods":["PUT"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/siteground-optimizer\/v1\/combine-css"}]}},"\/siteground-optimizer\/v1\/preload-combined-css":{"namespace":"siteground-optimizer\/v1","methods":["PUT"],"endpoints":[{"methods":["PUT"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/siteground-optimizer\/v1\/preload-combined-css"}]}},"\/siteground-optimizer\/v1\/fetch-options\/(?P<page_id>[^\/]+)":{"namespace":"siteground-optimizer\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"page_id":{"required":false}}}]},"\/siteground-optimizer\/v1\/purge-rest-cache":{"namespace":"siteground-optimizer\/v1","methods":["PUT"],"endpoints":[{"methods":["PUT"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/siteground-optimizer\/v1\/purge-rest-cache"}]}},"\/siteground-optimizer\/v1\/logged-in-cache":{"namespace":"siteground-optimizer\/v1","methods":["PUT"],"endpoints":[{"methods":["PUT"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/siteground-optimizer\/v1\/logged-in-cache"}]}},"\/siteground-optimizer\/v1\/enable-gzip-compression":{"namespace":"siteground-optimizer\/v1","methods":["PUT"],"endpoints":[{"methods":["PUT"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/siteground-optimizer\/v1\/enable-gzip-compression"}]}},"\/siteground-optimizer\/v1\/enable-browser-caching":{"namespace":"siteground-optimizer\/v1","methods":["PUT"],"endpoints":[{"methods":["PUT"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/siteground-optimizer\/v1\/enable-browser-caching"}]}},"\/siteground-optimizer\/v1\/optimize-css":{"namespace":"siteground-optimizer\/v1","methods":["PUT"],"endpoints":[{"methods":["PUT"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/siteground-optimizer\/v1\/optimize-css"}]}},"\/siteground-optimizer\/v1\/optimize-javascript":{"namespace":"siteground-optimizer\/v1","methods":["PUT"],"endpoints":[{"methods":["PUT"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/siteground-optimizer\/v1\/optimize-javascript"}]}},"\/siteground-optimizer\/v1\/combine-javascript":{"namespace":"siteground-optimizer\/v1","methods":["PUT"],"endpoints":[{"methods":["PUT"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/siteground-optimizer\/v1\/combine-javascript"}]}},"\/siteground-optimizer\/v1\/optimize-javascript-async":{"namespace":"siteground-optimizer\/v1","methods":["PUT"],"endpoints":[{"methods":["PUT"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/siteground-optimizer\/v1\/optimize-javascript-async"}]}},"\/siteground-optimizer\/v1\/optimize-html":{"namespace":"siteground-optimizer\/v1","methods":["PUT"],"endpoints":[{"methods":["PUT"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/siteground-optimizer\/v1\/optimize-html"}]}},"\/siteground-optimizer\/v1\/optimize-web-fonts":{"namespace":"siteground-optimizer\/v1","methods":["PUT"],"endpoints":[{"methods":["PUT"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/siteground-optimizer\/v1\/optimize-web-fonts"}]}},"\/siteground-optimizer\/v1\/remove-query-strings":{"namespace":"siteground-optimizer\/v1","methods":["PUT"],"endpoints":[{"methods":["PUT"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/siteground-optimizer\/v1\/remove-query-strings"}]}},"\/siteground-optimizer\/v1\/disable-emojis":{"namespace":"siteground-optimizer\/v1","methods":["PUT"],"endpoints":[{"methods":["PUT"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/siteground-optimizer\/v1\/disable-emojis"}]}},"\/siteground-optimizer\/v1\/lazyload-images":{"namespace":"siteground-optimizer\/v1","methods":["PUT"],"endpoints":[{"methods":["PUT"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/siteground-optimizer\/v1\/lazyload-images"}]}},"\/siteground-optimizer\/v1\/backup-media":{"namespace":"siteground-optimizer\/v1","methods":["PUT"],"endpoints":[{"methods":["PUT"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/siteground-optimizer\/v1\/backup-media"}]}},"\/siteground-optimizer\/v1\/enable-cache":{"namespace":"siteground-optimizer\/v1","methods":["PUT"],"endpoints":[{"methods":["PUT"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/siteground-optimizer\/v1\/enable-cache"}]}},"\/siteground-optimizer\/v1\/memcached":{"namespace":"siteground-optimizer\/v1","methods":["PUT"],"endpoints":[{"methods":["PUT"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/siteground-optimizer\/v1\/memcached"}]}},"\/siteground-optimizer\/v1\/autoflush-cache":{"namespace":"siteground-optimizer\/v1","methods":["PUT"],"endpoints":[{"methods":["PUT"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/siteground-optimizer\/v1\/autoflush-cache"}]}},"\/siteground-optimizer\/v1\/purge-cache":{"namespace":"siteground-optimizer\/v1","methods":["PUT"],"endpoints":[{"methods":["PUT"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/siteground-optimizer\/v1\/purge-cache"}]}},"\/siteground-optimizer\/v1\/user-agent-header":{"namespace":"siteground-optimizer\/v1","methods":["PUT"],"endpoints":[{"methods":["PUT"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/siteground-optimizer\/v1\/user-agent-header"}]}},"\/siteground-optimizer\/v1\/test-url-cache":{"namespace":"siteground-optimizer\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/siteground-optimizer\/v1\/test-url-cache"}]}},"\/siteground-optimizer\/v1\/enable-memcache":{"namespace":"siteground-optimizer\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/siteground-optimizer\/v1\/enable-memcache"}]}},"\/siteground-optimizer\/v1\/disable-memcache":{"namespace":"siteground-optimizer\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/siteground-optimizer\/v1\/disable-memcache"}]}},"\/siteground-optimizer\/v1\/file-caching":{"namespace":"siteground-optimizer\/v1","methods":["PUT"],"endpoints":[{"methods":["PUT"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/siteground-optimizer\/v1\/file-caching"}]}},"\/siteground-optimizer\/v1\/file-caching-settings":{"namespace":"siteground-optimizer\/v1","methods":["PUT"],"endpoints":[{"methods":["PUT"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/siteground-optimizer\/v1\/file-caching-settings"}]}},"\/siteground-optimizer\/v1\/enable-multisite-optimization":{"namespace":"siteground-optimizer\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/siteground-optimizer\/v1\/enable-multisite-optimization"}]}},"\/siteground-optimizer\/v1\/disable-multisite-optimization":{"namespace":"siteground-optimizer\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/siteground-optimizer\/v1\/disable-multisite-optimization"}]}},"\/siteground-optimizer\/v1\/run-analysis":{"namespace":"siteground-optimizer\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/siteground-optimizer\/v1\/run-analysis"}]}},"\/siteground-optimizer\/v1\/exclude\/(?P<type>[^\/]+)":{"namespace":"siteground-optimizer\/v1","methods":["PUT","PUT","PUT","PUT","PUT","PUT","PUT","PUT","PUT","PUT","PUT","PUT"],"endpoints":[{"methods":["PUT"],"args":{"type":{"required":false}}},{"methods":["PUT"],"args":{"type":{"required":false}}},{"methods":["PUT"],"args":{"type":{"required":false}}},{"methods":["PUT"],"args":{"type":{"required":false}}},{"methods":["PUT"],"args":{"type":{"required":false}}},{"methods":["PUT"],"args":{"type":{"required":false}}},{"methods":["PUT"],"args":{"type":{"required":false}}},{"methods":["PUT"],"args":{"type":{"required":false}}},{"methods":["PUT"],"args":{"type":{"required":false}}},{"methods":["PUT"],"args":{"type":{"required":false}}},{"methods":["PUT"],"args":{"type":{"required":false}}},{"methods":["PUT"],"args":{"type":{"required":false}}}]},"\/siteground-optimizer\/v1\/feature-popup\/(?P<type>[^\/]+)":{"namespace":"siteground-optimizer\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"type":{"required":false},"page_id":{"required":false}}}]},"\/siteground-optimizer\/v1\/performance-report":{"namespace":"siteground-optimizer\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/siteground-optimizer\/v1\/performance-report"}]}},"\/siteground-optimizer\/v1\/perf-notification-email":{"namespace":"siteground-optimizer\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/siteground-optimizer\/v1\/perf-notification-email"}]}},"\/siteground-optimizer\/v1\/optimize-images":{"namespace":"siteground-optimizer\/v1","methods":["PUT","GET"],"endpoints":[{"methods":["PUT"],"args":[]},{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/siteground-optimizer\/v1\/optimize-images"}]}},"\/siteground-optimizer\/v1\/reset-images-optimization":{"namespace":"siteground-optimizer\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/siteground-optimizer\/v1\/reset-images-optimization"}]}},"\/siteground-optimizer\/v1\/preview-image(?:\/(?P<id>\\d+))?":{"namespace":"siteground-optimizer\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[{"required":false}]}]},"\/siteground-optimizer\/v1\/image-resize":{"namespace":"siteground-optimizer\/v1","methods":["PUT"],"endpoints":[{"methods":["PUT"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/siteground-optimizer\/v1\/image-resize"}]}},"\/siteground-optimizer\/v1\/ssl":{"namespace":"siteground-optimizer\/v1","methods":["PUT"],"endpoints":[{"methods":["PUT"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/siteground-optimizer\/v1\/ssl"}]}},"\/siteground-optimizer\/v1\/fix-insecure-content":{"namespace":"siteground-optimizer\/v1","methods":["PUT"],"endpoints":[{"methods":["PUT"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/siteground-optimizer\/v1\/fix-insecure-content"}]}},"\/siteground-optimizer\/v1\/database-optimization":{"namespace":"siteground-optimizer\/v1","methods":["PUT"],"endpoints":[{"methods":["PUT"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/siteground-optimizer\/v1\/database-optimization"}]}},"\/siteground-optimizer\/v1\/heartbeat\/(?P<location>[^\/]+)":{"namespace":"siteground-optimizer\/v1","methods":["PUT"],"endpoints":[{"methods":["PUT"],"args":{"location":{"required":false}}}]},"\/siteground-optimizer\/v1\/notifications":{"namespace":"siteground-optimizer\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/siteground-optimizer\/v1\/notifications"}]}},"\/siteground-optimizer\/v1\/hardening":{"namespace":"siteground-optimizer\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/siteground-optimizer\/v1\/hardening"}]}},"\/siteground-optimizer\/v1\/e-book":{"namespace":"siteground-optimizer\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/siteground-optimizer\/v1\/e-book"}]}},"\/siteground-optimizer\/v1\/rate":{"namespace":"siteground-optimizer\/v1","methods":["PUT","GET"],"endpoints":[{"methods":["PUT"],"args":[]},{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/siteground-optimizer\/v1\/rate"}]}},"\/uap\/v2":{"namespace":"uap\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"uap\/v2","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/uap\/v2"}]}},"\/uap\/v2\/loop\/process\/(?P<action>\\w+)":{"namespace":"uap\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"process_id":{"required":true}}}]},"\/uap\/v2\/loop\/(?P<recipe_id>\\d+)":{"namespace":"uap\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}]},"\/uap\/v2\/mcp\/chat\/refresh":{"namespace":"uap\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"page_url":{"type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/uap\/v2\/mcp\/chat\/refresh"}]}},"\/uap\/v2\/mcp\/chat\/launcher\/(?P<recipe_id>\\d+)":{"namespace":"uap\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"recipe_id":{"type":"integer","required":true}}}]},"\/automator\/v1":{"namespace":"automator\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"automator\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/automator\/v1"}]}},"\/automator\/v1\/agent-context":{"namespace":"automator\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/automator\/v1\/agent-context"}]}},"\/automator\/v1\/mcp":{"namespace":"automator\/v1","methods":["POST","GET","DELETE"],"endpoints":[{"methods":["POST"],"args":{"jsonrpc":{"type":"string","enum":["2.0"],"required":true},"method":{"type":"string","required":false},"id":{"type":["string","number"],"required":false}}},{"methods":["GET"],"args":[]},{"methods":["DELETE"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/automator\/v1\/mcp"}]}},"\/automator\/v1\/mcp\/dropdown":{"namespace":"automator\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"entity_type":{"type":"string","description":"The entity type: \"action\" or \"trigger\".","required":true},"entity_code":{"type":"string","description":"The action\/trigger code (e.g., SLACKSENDMESSAGE).","required":true},"field_option_code":{"type":"string","description":"The field option code (e.g., SLACKCHANNEL).","required":true},"field_parent_option_code":{"type":"string","description":"Parent field option code for cascading dropdowns (e.g., ASANA_WORKSPACE).","required":false},"field_parent_option_value":{"type":"string","description":"Parent option value for cascading dropdowns.","required":false},"parent_values":{"type":"string","description":"JSON object of multiple parent field values for multi-level cascading (e.g., {\"GSSPREADSHEET\":\"abc123\",\"GSWORKSHEET\":\"xyz789\"}).","required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/automator\/v1\/mcp\/dropdown"}]}},"\/uap\/v2\/recipe\/(?P<recipe_id>\\d+)\/item\/(?P<item_type>[a-zA-Z0-9_-]+)\/(?P<operation>[a-zA-Z0-9_-]+)":{"namespace":"uap\/v2","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"recipe_id":{"required":false},"item_type":{"required":false},"operation":{"required":false}}}]},"\/uap\/v2\/recipe\/(?P<recipe_id>\\d+)\/block\/(?P<block_type>[a-zA-Z0-9_-]+)\/(?P<operation>[a-zA-Z0-9_-]+)":{"namespace":"uap\/v2","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"recipe_id":{"required":false},"block_type":{"required":false},"operation":{"required":false}}}]},"\/uap\/v2\/integrations\/get":{"namespace":"uap\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/uap\/v2\/integrations\/get"}]}},"\/uap\/v2\/integrations\/get\/(?P<scope>[a-zA-Z0-9_-]+)":{"namespace":"uap\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"scope":{"type":"string","required":true}}}]},"\/uap\/v2\/integrations\/collections\/get":{"namespace":"uap\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/uap\/v2\/integrations\/collections\/get"}]}},"\/uap\/v2\/blocks\/get":{"namespace":"uap\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/uap\/v2\/blocks\/get"}]}},"\/uap\/v2\/remote-data\/(?P<id>[a-zA-Z0-9_-]+)\/(?P<data>[a-zA-Z0-9_-]+)":{"namespace":"uap\/v2","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"id":{"type":"string","required":true},"data":{"type":"string","required":true},"recipe_id":{"type":"integer","required":false},"item_id":{"type":["integer","string"],"required":false},"parent_id":{"type":"integer","required":false},"group_id":{"type":"string","required":false},"field_id":{"type":"string","required":false},"triggered_by":{"type":"string","required":false},"values":{"type":"object","required":false},"context":{"type":"string","required":false},"q":{"type":"string","required":false}}}]},"\/uap\/v2\/async_action":{"namespace":"uap\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/uap\/v2\/async_action"}]}},"\/uap\/v2\/log-event":{"namespace":"uap\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/uap\/v2\/log-event"}]}},"\/automator\/v1\/email\/test":{"namespace":"automator\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/automator\/v1\/email\/test"}]}},"\/automator\/v1\/user\/(?P<id>\\d+)":{"namespace":"automator\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/automator\/v1\/log\/recipe_id\/(?P<recipe_id>\\d+)\/run_number\/(?P<run_number>\\d+)\/recipe_log_id\/(?P<recipe_log_id>\\d+)":{"namespace":"automator\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/automator\/v1\/log\/loop-runs\/(?P<recipe_id>\\d+)\/(?P<run_number>\\d+)\/(?P<recipe_log_id>\\d+)\/(?P<action_id>\\d+)":{"namespace":"automator\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/automator\/v1\/license\/summary":{"namespace":"automator\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/automator\/v1\/license\/summary"}]}},"\/automator\/v1\/addons\/get-list\/(?P<list_code>\\w+)":{"namespace":"automator\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/automator\/v1\/replay\/(?P<recipe_log_id>\\d+)":{"namespace":"automator\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}]},"\/automator\/v1\/addons\/plugin-manager\/(?P<action>\\w+)\/(?P<addon_id>\\d+)":{"namespace":"automator\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}]},"\/uap\/v2\/integration-settings\/(?P<integration_id>[a-zA-Z0-9_-]+)":{"namespace":"uap\/v2","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"integration_id":{"required":true},"action":{"required":true},"data":{"type":"object","required":false}}}]},"\/yoast\/v1":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"yoast\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/yoast\/v1"}]}},"\/yoast\/v1\/file_size":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"type":"string","description":"The url to retrieve","required":true}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/yoast\/v1\/file_size"}]}},"\/yoast\/v1\/statistics":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/yoast\/v1\/statistics"}]}},"\/yoast\/v1\/ai_generator\/callback":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"access_jwt":{"type":"string","description":"The access JWT.","required":true},"refresh_jwt":{"type":"string","description":"The JWT to be used when the access JWT needs to be refreshed.","required":true},"code_challenge":{"type":"string","description":"The SHA266 of the verification code used to check the authenticity of a callback call.","required":true},"user_id":{"type":"integer","description":"The id of the user associated to the code verifier.","required":true}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/yoast\/v1\/ai_generator\/callback"}]}},"\/yoast\/v1\/ai_generator\/refresh_callback":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"access_jwt":{"type":"string","description":"The access JWT.","required":true},"refresh_jwt":{"type":"string","description":"The JWT to be used when the access JWT needs to be refreshed.","required":true},"code_challenge":{"type":"string","description":"The SHA266 of the verification code used to check the authenticity of a callback call.","required":true},"user_id":{"type":"integer","description":"The id of the user associated to the code verifier.","required":true}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/yoast\/v1\/ai_generator\/refresh_callback"}]}},"\/yoast\/v1\/ai_generator\/consent":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"consent":{"type":"boolean","description":"Whether the consent to use AI-based services has been given by the user.","required":true}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/yoast\/v1\/ai_generator\/consent"}]}},"\/yoast\/v1\/ai_content_planner\/banner_permanent_dismissal":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"is_dismissed":{"type":"bool","required":true}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/yoast\/v1\/ai_content_planner\/banner_permanent_dismissal"}]}},"\/yoast\/v1\/ai_content_planner\/get_outline":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"post_type":{"type":"string","description":"The post type to get a content outline for.","required":true},"language":{"type":"string","description":"The language the content is written in.","required":true},"editor":{"type":"string","enum":["classic","elementor","gutenberg"],"description":"The current editor.","required":true},"title":{"type":"string","description":"The title of the chosen content suggestion.","required":true},"intent":{"type":"string","description":"The intent of the chosen content suggestion.","required":true},"explanation":{"type":"string","description":"The explanation of the chosen content suggestion.","required":true},"keyphrase":{"type":"string","description":"The keyphrase of the chosen content suggestion.","required":true},"meta_description":{"type":"string","description":"The meta description of the chosen content suggestion.","required":true},"category":{"type":"object","properties":{"name":{"type":"string","required":true},"id":{"type":"integer","required":true}},"description":"The category of the chosen content suggestion. Use name \"\" and id -1 to indicate no category.","required":true},"recent_content":{"type":"array","maxItems":100,"items":{"type":"object","properties":{"title":{"type":"string","required":true,"maxLength":500},"description":{"type":"string","required":true,"maxLength":1000}},"additionalProperties":false},"description":"The recent content returned by the get_suggestions response.","required":true}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/yoast\/v1\/ai_content_planner\/get_outline"}]}},"\/yoast\/v1\/ai_content_planner\/get_suggestions":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"post_type":{"type":"string","description":"The post type to get content suggestions for.","required":true},"language":{"type":"string","description":"The language the content is written in.","required":true},"editor":{"type":"string","enum":["classic","elementor","gutenberg"],"description":"The current editor.","required":true}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/yoast\/v1\/ai_content_planner\/get_suggestions"}]}},"\/yoast\/v1\/ai\/free_sparks":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/yoast\/v1\/ai\/free_sparks"}]}},"\/yoast\/v1\/ai_generator\/bust_subscription_cache":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/yoast\/v1\/ai_generator\/bust_subscription_cache"}]}},"\/yoast\/v1\/ai_generator\/get_suggestions":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"type":{"type":"string","enum":["seo-title","meta-description","product-seo-title","product-meta-description","product-taxonomy-seo-title","product-taxonomy-meta-description","taxonomy-seo-title","taxonomy-meta-description"],"description":"The type of suggestion requested.","required":true},"prompt_content":{"type":"string","description":"The content needed by the prompt to ask for suggestions.","required":true},"focus_keyphrase":{"type":"string","description":"The focus keyphrase associated to the post.","required":true},"language":{"type":"string","description":"The language the post is written in.","required":true},"platform":{"type":"string","enum":["Google","Facebook","Twitter"],"description":"The platform the post is intended for.","required":true},"editor":{"type":"string","enum":["classic","elementor","gutenberg"],"description":"The current editor.","required":true}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/yoast\/v1\/ai_generator\/get_suggestions"}]}},"\/yoast\/v1\/ai_generator\/get_usage":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"is_woo_product_entity":{"type":"boolean","default":false,"required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/yoast\/v1\/ai_generator\/get_usage"}]}},"\/yoast\/v1\/bulk_editor\/posts_content":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"ids":{"type":"array","minItems":1,"maxItems":20,"items":{"type":"integer","minimum":1},"description":"The IDs of the posts to return the content of. Accepts a comma separated list.","required":true}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/yoast\/v1\/bulk_editor\/posts_content"}]}},"\/yoast\/v1\/bulk_editor\/posts":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"content_type":{"type":"string","description":"The content type to fetch posts for.","required":true},"per_page":{"type":"integer","default":20,"minimum":1,"maximum":100,"description":"The number of posts to fetch.","required":false},"page":{"type":"integer","default":1,"minimum":1,"description":"The page of posts to fetch.","required":false},"search":{"type":"string","default":"","description":"The term to search posts by.","required":false},"status":{"type":"array","default":["publish","draft","pending","future"],"items":{"type":"string","enum":["publish","draft","pending","future"]},"description":"The post statuses to include.","required":false},"needs_improvement":{"type":"array","default":[],"items":{"type":"string","enum":["seo_title","meta_description","social_title","social_description"]},"description":"The fields to filter posts by; a field matches when it is empty, or (for search fields, while SEO analysis is enabled and the content type shows Yoast's controls and assessments) when its score needs improvement.","required":false},"include":{"type":"array","default":[],"maxItems":100,"items":{"type":"integer","minimum":1},"description":"Limits the posts to these post IDs, e.g. a selection carried over from the posts overview.","required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/yoast\/v1\/bulk_editor\/posts"}]}},"\/yoast\/v1\/bulk_editor\/update_scores":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"items":{"type":"array","description":"The per-post score updates to apply.","required":true}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/yoast\/v1\/bulk_editor\/update_scores"}]}},"\/yoast\/v1\/bulk_editor\/update_search":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"items":{"type":"array","description":"The per-post updates to apply.","required":true}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/yoast\/v1\/bulk_editor\/update_search"}]}},"\/yoast\/v1\/bulk_editor\/update_social":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"items":{"type":"array","description":"The per-post updates to apply.","required":true}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/yoast\/v1\/bulk_editor\/update_social"}]}},"\/yoast\/v1\/new-content-type-visibility\/dismiss-post-type":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"postTypeName":{"required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/yoast\/v1\/new-content-type-visibility\/dismiss-post-type"}]}},"\/yoast\/v1\/new-content-type-visibility\/dismiss-taxonomy":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"taxonomyName":{"required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/yoast\/v1\/new-content-type-visibility\/dismiss-taxonomy"}]}},"\/yoast\/v1\/site_kit_configuration_permanent_dismissal":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"is_dismissed":{"type":"bool","required":true}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/yoast\/v1\/site_kit_configuration_permanent_dismissal"}]}},"\/yoast\/v1\/readability_scores":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"contentType":{"type":"string","required":true},"taxonomy":{"type":"string","default":"","required":false},"term":{"type":"integer","default":null,"required":false},"troubleshooting":{"type":"bool","default":null,"required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/yoast\/v1\/readability_scores"}]}},"\/yoast\/v1\/seo_scores":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"contentType":{"type":"string","required":true},"taxonomy":{"type":"string","default":"","required":false},"term":{"type":"integer","default":null,"required":false},"troubleshooting":{"type":"bool","default":null,"required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/yoast\/v1\/seo_scores"}]}},"\/yoast\/v1\/setup_steps_tracking":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"setup_widget_loaded":{"type":"string","enum":["yes","no"],"required":false},"first_interaction_stage":{"type":"string","enum":["install","activate","setup","grantConsent","successfullyConnected"],"required":false},"last_interaction_stage":{"type":"string","enum":["install","activate","setup","grantConsent","successfullyConnected"],"required":false},"setup_widget_temporarily_dismissed":{"type":"string","enum":["yes","no"],"required":false},"setup_widget_permanently_dismissed":{"type":"string","enum":["yes","no"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/yoast\/v1\/setup_steps_tracking"}]}},"\/yoast\/v1\/introductions\/(?P<introduction_id>[\\w-]+)\/seen":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"introduction_id":{"type":"string","required":true},"is_seen":{"type":"bool","default":true,"required":false}}}]},"\/yoast\/v1\/wistia_embed_permission":{"namespace":"yoast\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":{"value":{"type":"bool","default":true,"required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/yoast\/v1\/wistia_embed_permission"}]}},"\/yoast\/v1\/available_posts":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"search":{"type":"string","default":"","required":false},"postType":{"type":"string","default":"page","required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/yoast\/v1\/available_posts"}]}},"\/yoast\/v1\/myyoast\/status":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/yoast\/v1\/myyoast\/status"}]}},"\/yoast\/v1\/myyoast\/refresh-status":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/yoast\/v1\/myyoast\/refresh-status"}]}},"\/yoast\/v1\/myyoast\/register":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/yoast\/v1\/myyoast\/register"}]}},"\/yoast\/v1\/myyoast\/registration":{"namespace":"yoast\/v1","methods":["PUT","DELETE"],"endpoints":[{"methods":["PUT"],"args":[]},{"methods":["DELETE"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/yoast\/v1\/myyoast\/registration"}]}},"\/yoast\/v1\/myyoast\/authorize":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"return_url":{"type":"string","description":"URL to send the browser back to once the flow completes. Validated against the site host; an invalid or off-site URL is ignored.","required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/yoast\/v1\/myyoast\/authorize"}]}},"\/yoast\/v1\/alerts\/dismiss":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"key":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/yoast\/v1\/alerts\/dismiss"}]}},"\/yoast\/v1\/configuration\/site_representation":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"company_or_person":{"type":"string","enum":["company","person"],"required":true},"company_name":{"type":"string","required":false},"company_logo":{"type":"string","required":false},"company_logo_id":{"type":"integer","required":false},"person_logo":{"type":"string","required":false},"person_logo_id":{"type":"integer","required":false},"company_or_person_user_id":{"type":"integer","required":false},"description":{"type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/yoast\/v1\/configuration\/site_representation"}]}},"\/yoast\/v1\/configuration\/social_profiles":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"facebook_site":{"type":"string","required":false},"twitter_site":{"type":"string","required":false},"other_social_urls":{"type":"array","required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/yoast\/v1\/configuration\/social_profiles"}]}},"\/yoast\/v1\/configuration\/check_capability":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"user_id":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/yoast\/v1\/configuration\/check_capability"}]}},"\/yoast\/v1\/configuration\/enable_tracking":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"tracking":{"type":"boolean","required":true}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/yoast\/v1\/configuration\/enable_tracking"}]}},"\/yoast\/v1\/configuration\/save_configuration_state":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"finishedSteps":{"type":"array","required":true}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/yoast\/v1\/configuration\/save_configuration_state"}]}},"\/yoast\/v1\/configuration\/get_configuration_state":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/yoast\/v1\/configuration\/get_configuration_state"}]}},"\/yoast\/v1\/import\/(?P<plugin>[\\w-]+)\/(?P<type>[\\w-]+)":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}]},"\/yoast\/v1\/get_head":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/yoast\/v1\/get_head"}]}},"\/yoast\/v1\/indexing\/posts":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/yoast\/v1\/indexing\/posts"}]}},"\/yoast\/v1\/indexing\/terms":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/yoast\/v1\/indexing\/terms"}]}},"\/yoast\/v1\/indexing\/post-type-archives":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/yoast\/v1\/indexing\/post-type-archives"}]}},"\/yoast\/v1\/indexing\/general":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/yoast\/v1\/indexing\/general"}]}},"\/yoast\/v1\/indexing\/prepare":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/yoast\/v1\/indexing\/prepare"}]}},"\/yoast\/v1\/indexing\/indexables-complete":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/yoast\/v1\/indexing\/indexables-complete"}]}},"\/yoast\/v1\/indexing\/complete":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/yoast\/v1\/indexing\/complete"}]}},"\/yoast\/v1\/link-indexing\/posts":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/yoast\/v1\/link-indexing\/posts"}]}},"\/yoast\/v1\/link-indexing\/terms":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/yoast\/v1\/link-indexing\/terms"}]}},"\/yoast\/v1\/integrations\/set_active":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"active":{"type":"boolean","required":true},"integration":{"type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/yoast\/v1\/integrations\/set_active"}]}},"\/yoast\/v1\/meta\/search":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/yoast\/v1\/meta\/search"}]}},"\/yoast\/v1\/semrush\/authenticate":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"code":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/yoast\/v1\/semrush\/authenticate"}]}},"\/yoast\/v1\/semrush\/country_code":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"country_code":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/yoast\/v1\/semrush\/country_code"}]}},"\/yoast\/v1\/semrush\/related_keyphrases":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"keyphrase":{"required":true},"country_code":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/yoast\/v1\/semrush\/related_keyphrases"}]}},"\/yoast\/v1\/workouts":{"namespace":"yoast\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":{"cornerstone":{"required":true},"orphaned":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/yoast\/v1\/workouts"}]}},"\/yoast\/v1\/complete_task":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"options":{"type":"object","properties":{"task":{"type":"string","required":true,"sanitize_callback":"sanitize_text_field"}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/yoast\/v1\/complete_task"}]}},"\/yoast\/v1\/get_tasks":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"options":{"type":"object","properties":{"filter":{"type":"string","required":false,"sanitize_callback":"sanitize_text_field"},"limit":{"type":"int","required":false,"sanitize_callback":"absint"}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/yoast\/v1\/get_tasks"}]}},"\/yoast\/v1\/action_tracking":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"action":{"type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/yoast\/v1\/action_tracking"}]}},"\/yoast\/v1\/ai\/bulk_suggestions":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"subjects":{"type":"array","minItems":1,"maxItems":20,"description":"The subjects to fetch suggestions for.","items":{"type":"object","required":["id","type","content"],"properties":{"id":{"type":"integer","minimum":1,"description":"The post ID."},"type":{"type":"string","enum":["seo-title","meta-description"],"description":"The type of suggestion requested."},"content":{"type":"string","maxLength":20000,"description":"The prompt content the suggestion should be based on, collected client-side by the analysis engine."},"content_length":{"type":"integer","minimum":0,"description":"The visible-text length of the post, measured client-side. Omitted when it could not be measured, in which case the content length is not judged."},"platform":{"type":"string","enum":["Google","Facebook","Twitter"],"description":"The platform the suggestion is intended for."}}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/yoast\/v1\/ai\/bulk_suggestions"}]}},"\/yoast\/v1\/ai\/optimize":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"assessment":{"type":"string","enum":["seo-keyphrase-introduction","seo-keyphrase-density","seo-keyphrase-distribution","seo-keyphrase-subheadings","read-sentence-length","read-paragraph-length"],"description":"The assessment.","required":true},"language":{"type":"string","description":"The language the post is written in.","required":true},"prompt_content":{"type":"string","description":"The content needed by the prompt to ask for suggestions.","required":true},"focus_keyphrase":{"type":"string","description":"The focus keyphrase associated to the post.","required":false},"synonyms":{"type":"string","description":"The synonyms for the focus keyphrase.","required":false},"editor":{"type":"string","enum":["Classic","Gutenberg"],"description":"The editor type, either Classic or Gutenberg.","required":true}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/yoast\/v1\/ai\/optimize"}]}},"\/yoast\/v1\/ai\/summarize":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"language":{"type":"string","description":"The language the post is written in.","required":true},"prompt_content":{"type":"string","description":"The content needed by the prompt to ask for a summary.","required":true},"focus_keyphrase":{"type":"string","description":"The focus keyphrase associated to the post.","required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/yoast\/v1\/ai\/summarize"}]}},"\/yoast\/v1\/link_suggestions":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"prominent_words":{"type":"object","description":"Stems of prominent words and their term frequencies we want link suggestions based on","required":true},"object_id":{"type":"integer","description":"The object id of the current indexable.","required":true},"object_type":{"type":"string","description":"The object type of the current indexable.","required":true},"limit":{"default":5,"type":"integer","description":"The maximum number of link suggestions to retrieve","required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/yoast\/v1\/link_suggestions"}]}},"\/yoast\/v1\/prominent_words\/get_content":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/yoast\/v1\/prominent_words\/get_content"}]}},"\/yoast\/v1\/prominent_words\/complete":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/yoast\/v1\/prominent_words\/complete"}]}},"\/yoast\/v1\/prominent_words\/save":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"data":{"type":"array","items":{"type":"object","properties":{"object_id":{"type":"number","required":true},"prominent_words":{"type":"object","required":false}}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/yoast\/v1\/prominent_words\/save"}]}},"\/yoast\/v1\/workouts\/noindex":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"object_id":{"type":"integer","required":true},"object_type":{"type":"string","required":true},"object_sub_type":{"type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/yoast\/v1\/workouts\/noindex"}]}},"\/yoast\/v1\/workouts\/remove_redirect":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"object_id":{"type":"integer","required":true},"object_type":{"type":"string","required":true},"object_sub_type":{"type":"string","required":true},"permalink":{"type":"string","required":true},"redirect_url":{"type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/yoast\/v1\/workouts\/remove_redirect"}]}},"\/yoast\/v1\/workouts\/link_suggestions":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"indexableId":{"type":"integer","required":true}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/yoast\/v1\/workouts\/link_suggestions"}]}},"\/yoast\/v1\/workouts\/last_updated":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"postId":{"type":"integer","required":true}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/yoast\/v1\/workouts\/last_updated"}]}},"\/yoast\/v1\/workouts\/cornerstone_data":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/yoast\/v1\/workouts\/cornerstone_data"}]}},"\/yoast\/v1\/workouts\/enable_cornerstone":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"object_id":{"type":"integer","required":true},"object_type":{"type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/yoast\/v1\/workouts\/enable_cornerstone"}]}},"\/uap\/v2\/actions_conditions_update":{"namespace":"uap\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/uap\/v2\/actions_conditions_update"}]}},"\/uap\/v2\/actions_conditions_fields":{"namespace":"uap\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/uap\/v2\/actions_conditions_fields"}]}},"\/uap\/v2\/actions_order_and_conditions":{"namespace":"uap\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/uap\/v2\/actions_order_and_conditions"}]}},"\/yoast\/v1\/redirects":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"origin":{"type":"string","description":"The origin to redirect","required":true},"target":{"type":"string","description":"The redirect target","required":false},"type":{"type":"integer","description":"The redirect type","required":true},"ignore_warning":{"type":"boolean","description":"Whether to ignore warnings","default":false,"required":false},"format":{"description":"Das Format der zu erstellenden Umleitung.","type":"string","enum":["plain","regex"],"default":"plain","required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/yoast\/v1\/redirects"}]}},"\/yoast\/v1\/redirects\/delete":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"origin":{"type":"string","description":"The origin to redirect","required":true},"target":{"type":"string","description":"The redirect target","required":false},"type":{"type":"string","description":"The redirect format","required":false},"ignore_warning":{"type":"boolean","description":"Whether to ignore warnings","default":false,"required":false},"format":{"description":"Das Format der zu erstellenden Umleitung.","type":"string","enum":["plain","regex"],"default":"plain","required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/yoast\/v1\/redirects\/delete"}]}},"\/yoast\/v1\/redirects\/list":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"format":{"description":"Das Format der abzurufenden Umleitungen.","type":"string","enum":["plain","regex"],"default":"plain","required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/yoast\/v1\/redirects\/list"}]}},"\/yoast\/v1\/redirects\/update":{"namespace":"yoast\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"old_origin":{"type":"string","description":"The origin to redirect (old)","required":true},"old_target":{"type":"string","description":"The redirect target (old)","required":false},"old_type":{"type":"integer","description":"The redirect type (old)","required":true},"new_origin":{"type":"string","description":"The origin to redirect (new)","required":true},"new_target":{"type":"string","description":"The redirect target (new)","required":false},"new_type":{"type":"integer","description":"The redirect type (new)","required":true},"ignore_warning":{"type":"boolean","description":"Whether to ignore warnings","default":false,"required":false},"format":{"description":"Das Format der abzurufenden Umleitungen.","type":"string","enum":["plain","regex"],"default":"plain","required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/yoast\/v1\/redirects\/update"}]}},"\/yoast\/v1\/redirects\/settings":{"namespace":"yoast\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":{"disable_php_redirect":{"description":"Ob PHP-basierte Weiterleitungen deaktiviert und stattdessen .htaccess verwendet werden soll.","type":"string","enum":["on","off"],"required":true},"separate_file":{"description":"Ob Umleitungen in eine separate Datei anstelle von .htaccess geschrieben werden sollen.","type":"string","enum":["on","off"],"required":true}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/yoast\/v1\/redirects\/settings"}]}},"\/yoast\/v1\/redirects\/undo-for-object":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"obj_id":{"type":"int","description":"The id of the post or term","required":true},"obj_type":{"type":"string","description":"The object type: post or term","required":true}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/yoast\/v1\/redirects\/undo-for-object"}]}},"\/biblus\/v1":{"namespace":"biblus\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"biblus\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/biblus\/v1"}]}},"\/biblus\/v1\/latest-posts":{"namespace":"biblus\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"tags":{"type":"string","description":"Slug di uno o pi\u00f9 tag (post_tag) separati da virgola. Vengono restituiti i post con almeno uno dei tag indicati.","required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/biblus\/v1\/latest-posts"}]}},"\/uap\/v2\/run-now\/start\/(?P<recipe_id>\\d+)":{"namespace":"uap\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"recipe_id":{"required":true}}}]},"\/real-custom-post-order\/v1\/move":{"namespace":"real-custom-post-order\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"type":{"type":"string","enum":["post"],"required":true},"sequence":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/real-custom-post-order\/v1\/move"}]}},"\/real-custom-post-order\/v1\/post\/firstTimePointer":{"namespace":"real-custom-post-order\/v1","methods":["DELETE"],"endpoints":[{"methods":["DELETE"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/real-custom-post-order\/v1\/post\/firstTimePointer"}]}},"\/regenerate-thumbnails\/v1":{"namespace":"regenerate-thumbnails\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"regenerate-thumbnails\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/regenerate-thumbnails\/v1"}]}},"\/regenerate-thumbnails\/v1\/regenerate\/(?P<id>[\\d]+)":{"namespace":"regenerate-thumbnails\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET","POST","PUT","PATCH","DELETE"],"args":{"only_regenerate_missing_thumbnails":{"description":"Ob nur fehlende Vorschaubilder regeneriert werden sollen. Damit geht es schneller.","type":"boolean","default":true,"required":false},"delete_unregistered_thumbnail_files":{"description":"Ob alle alten, jetzt nicht mehr zugewiesene Vorschaubilder gel\u00f6scht werden sollen.","type":"boolean","default":false,"required":false},"update_usages_in_posts":{"description":"Ob die Bilder-Schlagw\u00f6rter in allen Beitr\u00e4gen, die diesen Anhang verwenden, aktualisiert werden sollen.","type":"boolean","default":true,"required":false},"update_usages_in_posts_post_type":{"description":"Der Typ von Beitr\u00e4gen, die aktualisiert werden sollen. Standard sind alle \u00f6ffentlichen Beitragstypen.","type":"array","default":[],"required":false},"update_usages_in_posts_post_ids":{"description":"Bestimmte Beitrag-IDs, die aktualisiert werden sollen, statt aller Beitr\u00e4ge, die diese Anlage verwenden.","type":"array","default":[],"required":false},"update_usages_in_posts_posts_per_loop":{"description":"Beitr\u00e4ge, die pro Durchlauf verarbeitet werden sollen. Damit soll die Nutzung von Arbeitsspeicher kontrolliert werden und wahrscheinlich brauchst du diesen Wert nicht anzupassen.","type":"integer","default":10,"required":false}}}]},"\/regenerate-thumbnails\/v1\/attachmentinfo\/(?P<id>[\\d]+)":{"namespace":"regenerate-thumbnails\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/regenerate-thumbnails\/v1\/featuredimages":{"namespace":"regenerate-thumbnails\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/regenerate-thumbnails\/v1\/featuredimages"}]}},"\/uap\/v2\/get_recipe":{"namespace":"uap\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/uap\/v2\/get_recipe"}]}},"\/uap\/v2\/create":{"namespace":"uap\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/uap\/v2\/create"}]}},"\/uap\/v2\/add":{"namespace":"uap\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/uap\/v2\/add"}]}},"\/uap\/v2\/delete":{"namespace":"uap\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/uap\/v2\/delete"}]}},"\/uap\/v2\/update":{"namespace":"uap\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/uap\/v2\/update"}]}},"\/uap\/v2\/get_options":{"namespace":"uap\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/uap\/v2\/get_options"}]}},"\/uap\/v2\/change_post_status":{"namespace":"uap\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/uap\/v2\/change_post_status"}]}},"\/uap\/v2\/change_post_recipe_type":{"namespace":"uap\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/uap\/v2\/change_post_recipe_type"}]}},"\/uap\/v2\/set_walkthrough_progress":{"namespace":"uap\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/uap\/v2\/set_walkthrough_progress"}]}},"\/uap\/v2\/change_post_title":{"namespace":"uap\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/uap\/v2\/change_post_title"}]}},"\/uap\/v2\/change_recipe_notes":{"namespace":"uap\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/uap\/v2\/change_recipe_notes"}]}},"\/uap\/v2\/recipe_completions_allowed":{"namespace":"uap\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/uap\/v2\/recipe_completions_allowed"}]}},"\/uap\/v2\/recipe_max_completions_allowed":{"namespace":"uap\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/uap\/v2\/recipe_max_completions_allowed"}]}},"\/uap\/v2\/set_recipe_terms":{"namespace":"uap\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/uap\/v2\/set_recipe_terms"}]}},"\/uap\/v2\/user-selector":{"namespace":"uap\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/uap\/v2\/user-selector"}]}},"\/uap\/v2\/trigger-options":{"namespace":"uap\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/uap\/v2\/trigger-options"}]}},"\/uap\/v2\/schedule_action":{"namespace":"uap\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/uap\/v2\/schedule_action"}]}},"\/uap\/v2\/remove_schedule":{"namespace":"uap\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/uap\/v2\/remove_schedule"}]}},"\/uap\/v2\/set_recipe_requires_user":{"namespace":"uap\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/uap\/v2\/set_recipe_requires_user"}]}},"\/uap\/v2\/actions_order":{"namespace":"uap\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/uap\/v2\/actions_order"}]}},"\/uap\/v2\/set_any_or_all_trigger_option":{"namespace":"uap\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/uap\/v2\/set_any_or_all_trigger_option"}]}},"\/uap\/v2\/duplicate_action":{"namespace":"uap\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/uap\/v2\/duplicate_action"}]}},"\/uap\/v2\/resend_api_request":{"namespace":"uap\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/uap\/v2\/resend_api_request"}]}},"\/uap\/v2\/triggers_change_logic":{"namespace":"uap\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/uap\/v2\/triggers_change_logic"}]}},"\/uap\/v2\/recipe_update_setting":{"namespace":"uap\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/uap\/v2\/recipe_update_setting"}]}},"\/wp\/v2":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp\/v2","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/wp\/v2"}]}},"\/wp\/v2\/posts":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"author":{"description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, die bestimmten Autoren zugewiesen sind.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Sicherstellen, dass der Ergebnissatz Beitr\u00e4ge ausschlie\u00dft, die bestimmten Autoren zugewiesen sind.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Wie die Sucheingabe interpretiert wird.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sammlung nach Beitragsattribut sortieren.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array mit den zu durchsuchenden Spaltennamen.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Ergebnissatz auf Beitr\u00e4ge mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, denen ein oder mehrere Status zugewiesen sind.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","flamingo-spam","avvia_traduzione","crea_task_resolver","any"],"type":"string"},"required":false},"tax_relation":{"description":"Abfrage-Ergebnis auf Basis der Beziehung zwischen mehreren Taxonomien einschr\u00e4nken.","type":"string","enum":["AND","OR"],"required":false},"categories":{"description":"Ergebnissatz auf Elemente beschr\u00e4nken, denen bestimmte Begriffe in der Taxonomie categories zugewiesen sind.","type":["object","array"],"oneOf":[{"title":"Begriffs-ID-Liste","description":"Begriffe mit den gelisteten IDs vergleichen.","type":"array","items":{"type":"integer"}},{"title":"Taxonomie-Abfrage nach Begriffs-ID","description":"F\u00fchre eine erweiterte Begriffsabfrage durch.","type":"object","properties":{"terms":{"description":"Begriff-IDs.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Ob untergeordnete Begriffe in Begriffe, welche die Ergebnismenge begrenzen, mit einbezogen werden sollen.","type":"boolean","default":false},"operator":{"description":"Ob Elemente allen oder beliebigen festgelegten Begriffen zugewiesen sein m\u00fcssen.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"categories_exclude":{"description":"Ergebnissatz auf Elemente beschr\u00e4nken, au\u00dfer auf solche, denen bestimmte Begriffe in der Taxonomie categories zugewiesen sind.","type":["object","array"],"oneOf":[{"title":"Begriffs-ID-Liste","description":"Begriffe mit den gelisteten IDs vergleichen.","type":"array","items":{"type":"integer"}},{"title":"Taxonomie-Abfrage nach Begriffs-ID","description":"F\u00fchre eine erweiterte Begriffsabfrage durch.","type":"object","properties":{"terms":{"description":"Begriff-IDs.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Ob untergeordnete Begriffe in Begriffe, welche die Ergebnismenge begrenzen, mit einbezogen werden sollen.","type":"boolean","default":false}},"additionalProperties":false}],"required":false},"tags":{"description":"Ergebnissatz auf Elemente beschr\u00e4nken, denen bestimmte Begriffe in der Taxonomie tags zugewiesen sind.","type":["object","array"],"oneOf":[{"title":"Begriffs-ID-Liste","description":"Begriffe mit den gelisteten IDs vergleichen.","type":"array","items":{"type":"integer"}},{"title":"Taxonomie-Abfrage nach Begriffs-ID","description":"F\u00fchre eine erweiterte Begriffsabfrage durch.","type":"object","properties":{"terms":{"description":"Begriff-IDs.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Ob Elemente allen oder beliebigen festgelegten Begriffen zugewiesen sein m\u00fcssen.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"tags_exclude":{"description":"Ergebnissatz auf Elemente beschr\u00e4nken, au\u00dfer auf solche, denen bestimmte Begriffe in der Taxonomie tags zugewiesen sind.","type":["object","array"],"oneOf":[{"title":"Begriffs-ID-Liste","description":"Begriffe mit den gelisteten IDs vergleichen.","type":"array","items":{"type":"integer"}},{"title":"Taxonomie-Abfrage nach Begriffs-ID","description":"F\u00fchre eine erweiterte Begriffsabfrage durch.","type":"object","properties":{"terms":{"description":"Begriff-IDs.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"sticky":{"description":"Den Ergebnissatz auf Elemente begrenzen, die oben gehalten werden.","type":"boolean","required":false},"ignore_sticky":{"description":"Ob oben gehaltene Beitr\u00e4ge ignoriert werden sollen oder nicht.","type":"boolean","default":true,"required":false},"format":{"description":"Den Ergebnissatz auf Elemente begrenzen, denen ein oder mehrere bestimmte Formate zugeordnet sind.","type":"array","uniqueItems":true,"items":{"enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","avvia_traduzione","crea_task_resolver"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Beitrags.","type":"integer","required":false},"excerpt":{"description":"Der Textauszug f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Textauszug f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Textauszug f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Ob der Textauszug durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"Die ID des hervorgehobenen Mediums f\u00fcr den Beitrag.","type":"integer","required":false},"comment_status":{"description":"Ob Kommentare f\u00fcr den Beitrag ge\u00f6ffnet sind oder nicht.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Ob der Beitrag gepingt werden kann oder nicht.","type":"string","enum":["open","closed"],"required":false},"format":{"description":"Das Format f\u00fcr den Beitrag.","type":"string","enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"_yoast_wpseo_focuskw":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_title":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_metadesc":{"type":"string","title":"","description":"","default":""},"_data_scadenza_evento":{"type":"string","title":"","description":"","default":""},"_evento_nome":{"type":"string","title":"","description":"","default":""},"_evento_data":{"type":"string","title":"","description":"","default":""},"_evento_luogo":{"type":"string","title":"","description":"","default":""},"_evento_cta":{"type":"string","title":"","description":"","default":""},"keyword_en":{"type":"string","title":"","description":"","default":""},"keyword_es":{"type":"string","title":"","description":"","default":""},"keyword_fr":{"type":"string","title":"","description":"","default":""},"keyword_de":{"type":"string","title":"","description":"","default":""},"keyword_ptb":{"type":"string","title":"","description":"","default":""},"_note_content":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"sticky":{"description":"Ob der Beitrag als oben gehalten behandelt werden soll oder nicht.","type":"boolean","required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false},"categories":{"description":"Die Begriffe, die dem Beitrag in der Taxonomie category zugewiesen sind.","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"Die Begriffe, die dem Beitrag in der Taxonomie post_tag zugewiesen sind.","type":"array","items":{"type":"integer"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/wp\/v2\/posts"}]}},"\/wp\/v2\/posts\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"Setzt die Standardl\u00e4nge des Textauszugs au\u00dfer Kraft.","type":"integer","required":false},"password":{"description":"Das Passwort f\u00fcr den Beitrag, falls dieser passwortgesch\u00fctzt ist.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","avvia_traduzione","crea_task_resolver"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Beitrags.","type":"integer","required":false},"excerpt":{"description":"Der Textauszug f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Textauszug f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Textauszug f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Ob der Textauszug durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"Die ID des hervorgehobenen Mediums f\u00fcr den Beitrag.","type":"integer","required":false},"comment_status":{"description":"Ob Kommentare f\u00fcr den Beitrag ge\u00f6ffnet sind oder nicht.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Ob der Beitrag gepingt werden kann oder nicht.","type":"string","enum":["open","closed"],"required":false},"format":{"description":"Das Format f\u00fcr den Beitrag.","type":"string","enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"_yoast_wpseo_focuskw":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_title":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_metadesc":{"type":"string","title":"","description":"","default":""},"_data_scadenza_evento":{"type":"string","title":"","description":"","default":""},"_evento_nome":{"type":"string","title":"","description":"","default":""},"_evento_data":{"type":"string","title":"","description":"","default":""},"_evento_luogo":{"type":"string","title":"","description":"","default":""},"_evento_cta":{"type":"string","title":"","description":"","default":""},"keyword_en":{"type":"string","title":"","description":"","default":""},"keyword_es":{"type":"string","title":"","description":"","default":""},"keyword_fr":{"type":"string","title":"","description":"","default":""},"keyword_de":{"type":"string","title":"","description":"","default":""},"keyword_ptb":{"type":"string","title":"","description":"","default":""},"_note_content":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"sticky":{"description":"Ob der Beitrag als oben gehalten behandelt werden soll oder nicht.","type":"boolean","required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false},"categories":{"description":"Die Begriffe, die dem Beitrag in der Taxonomie category zugewiesen sind.","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"Die Begriffe, die dem Beitrag in der Taxonomie post_tag zugewiesen sind.","type":"array","items":{"type":"integer"},"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ob der Papierkorb umgangen und die L\u00f6schung erzwungen werden soll.","required":false}}}]},"\/wp\/v2\/posts\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Revision.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Die Sammlung nach Objektattribut sortieren.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/posts\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Revision.","type":"integer","required":false},"id":{"description":"Eindeutige Kennung f\u00fcr die Revision.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Revision.","type":"integer","required":false},"id":{"description":"Eindeutige Kennung f\u00fcr die Revision.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Setzen auf true erforderlich, denn Revisionen k\u00f6nnen nicht in den Papierkorb gelegt werden.","required":false}}}]},"\/wp\/v2\/posts\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","avvia_traduzione","crea_task_resolver"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Beitrags.","type":"integer","required":false},"excerpt":{"description":"Der Textauszug f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Textauszug f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Textauszug f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Ob der Textauszug durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"Die ID des hervorgehobenen Mediums f\u00fcr den Beitrag.","type":"integer","required":false},"comment_status":{"description":"Ob Kommentare f\u00fcr den Beitrag ge\u00f6ffnet sind oder nicht.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Ob der Beitrag gepingt werden kann oder nicht.","type":"string","enum":["open","closed"],"required":false},"format":{"description":"Das Format f\u00fcr den Beitrag.","type":"string","enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"_yoast_wpseo_focuskw":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_title":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_metadesc":{"type":"string","title":"","description":"","default":""},"_data_scadenza_evento":{"type":"string","title":"","description":"","default":""},"_evento_nome":{"type":"string","title":"","description":"","default":""},"_evento_data":{"type":"string","title":"","description":"","default":""},"_evento_luogo":{"type":"string","title":"","description":"","default":""},"_evento_cta":{"type":"string","title":"","description":"","default":""},"keyword_en":{"type":"string","title":"","description":"","default":""},"keyword_es":{"type":"string","title":"","description":"","default":""},"keyword_fr":{"type":"string","title":"","description":"","default":""},"keyword_de":{"type":"string","title":"","description":"","default":""},"keyword_ptb":{"type":"string","title":"","description":"","default":""},"_note_content":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"sticky":{"description":"Ob der Beitrag als oben gehalten behandelt werden soll oder nicht.","type":"boolean","required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false},"categories":{"description":"Die Begriffe, die dem Beitrag in der Taxonomie category zugewiesen sind.","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"Die Begriffe, die dem Beitrag in der Taxonomie post_tag zugewiesen sind.","type":"array","items":{"type":"integer"},"required":false}}}]},"\/wp\/v2\/posts\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"id":{"description":"Die ID f\u00fcr die automatische Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/pages":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"author":{"description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, die bestimmten Autoren zugewiesen sind.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Sicherstellen, dass der Ergebnissatz Beitr\u00e4ge ausschlie\u00dft, die bestimmten Autoren zugewiesen sind.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"menu_order":{"description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, die einen bestimmten menu_order-Wert haben.","type":"integer","required":false},"search_semantics":{"description":"Wie die Sucheingabe interpretiert wird.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sammlung nach Beitragsattribut sortieren.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"parent":{"description":"Den Ergebnissatz auf alle Elemente bestimmter \u00fcbergeordneter IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Den Ergebnissatz auf alle Elemente begrenzen, au\u00dfer denen mit einer bestimmten \u00fcbergeordneten ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_columns":{"default":[],"description":"Array mit den zu durchsuchenden Spaltennamen.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Ergebnissatz auf Beitr\u00e4ge mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, denen ein oder mehrere Status zugewiesen sind.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","flamingo-spam","avvia_traduzione","crea_task_resolver","any"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","avvia_traduzione","crea_task_resolver"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"parent":{"description":"Die ID f\u00fcr den \u00fcbergeordneten Beitrag.","type":"integer","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Beitrags.","type":"integer","required":false},"excerpt":{"description":"Der Textauszug f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Textauszug f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Textauszug f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Ob der Textauszug durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"Die ID des hervorgehobenen Mediums f\u00fcr den Beitrag.","type":"integer","required":false},"comment_status":{"description":"Ob Kommentare f\u00fcr den Beitrag ge\u00f6ffnet sind oder nicht.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Ob der Beitrag gepingt werden kann oder nicht.","type":"string","enum":["open","closed"],"required":false},"menu_order":{"description":"Die Reihenfolge des Beitrags in Bezug auf andere Beitr\u00e4ge.","type":"integer","required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"_yoast_wpseo_focuskw":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_metadesc":{"type":"string","title":"","description":"","default":""},"_data_scadenza_evento":{"type":"string","title":"","description":"","default":""},"_evento_nome":{"type":"string","title":"","description":"","default":""},"_evento_data":{"type":"string","title":"","description":"","default":""},"_evento_luogo":{"type":"string","title":"","description":"","default":""},"_evento_cta":{"type":"string","title":"","description":"","default":""},"keyword_en":{"type":"string","title":"","description":"","default":""},"keyword_es":{"type":"string","title":"","description":"","default":""},"keyword_fr":{"type":"string","title":"","description":"","default":""},"keyword_de":{"type":"string","title":"","description":"","default":""},"keyword_ptb":{"type":"string","title":"","description":"","default":""},"_note_content":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/wp\/v2\/pages"}]}},"\/wp\/v2\/pages\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"Setzt die Standardl\u00e4nge des Textauszugs au\u00dfer Kraft.","type":"integer","required":false},"password":{"description":"Das Passwort f\u00fcr den Beitrag, falls dieser passwortgesch\u00fctzt ist.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","avvia_traduzione","crea_task_resolver"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"parent":{"description":"Die ID f\u00fcr den \u00fcbergeordneten Beitrag.","type":"integer","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Beitrags.","type":"integer","required":false},"excerpt":{"description":"Der Textauszug f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Textauszug f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Textauszug f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Ob der Textauszug durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"Die ID des hervorgehobenen Mediums f\u00fcr den Beitrag.","type":"integer","required":false},"comment_status":{"description":"Ob Kommentare f\u00fcr den Beitrag ge\u00f6ffnet sind oder nicht.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Ob der Beitrag gepingt werden kann oder nicht.","type":"string","enum":["open","closed"],"required":false},"menu_order":{"description":"Die Reihenfolge des Beitrags in Bezug auf andere Beitr\u00e4ge.","type":"integer","required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"_yoast_wpseo_focuskw":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_metadesc":{"type":"string","title":"","description":"","default":""},"_data_scadenza_evento":{"type":"string","title":"","description":"","default":""},"_evento_nome":{"type":"string","title":"","description":"","default":""},"_evento_data":{"type":"string","title":"","description":"","default":""},"_evento_luogo":{"type":"string","title":"","description":"","default":""},"_evento_cta":{"type":"string","title":"","description":"","default":""},"keyword_en":{"type":"string","title":"","description":"","default":""},"keyword_es":{"type":"string","title":"","description":"","default":""},"keyword_fr":{"type":"string","title":"","description":"","default":""},"keyword_de":{"type":"string","title":"","description":"","default":""},"keyword_ptb":{"type":"string","title":"","description":"","default":""},"_note_content":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ob der Papierkorb umgangen und die L\u00f6schung erzwungen werden soll.","required":false}}}]},"\/wp\/v2\/pages\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Revision.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Die Sammlung nach Objektattribut sortieren.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/pages\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Revision.","type":"integer","required":false},"id":{"description":"Eindeutige Kennung f\u00fcr die Revision.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Revision.","type":"integer","required":false},"id":{"description":"Eindeutige Kennung f\u00fcr die Revision.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Setzen auf true erforderlich, denn Revisionen k\u00f6nnen nicht in den Papierkorb gelegt werden.","required":false}}}]},"\/wp\/v2\/pages\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"Die ID f\u00fcr den \u00fcbergeordneten Beitrag.","type":"integer","required":false},"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","avvia_traduzione","crea_task_resolver"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Beitrags.","type":"integer","required":false},"excerpt":{"description":"Der Textauszug f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Textauszug f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Textauszug f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Ob der Textauszug durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"Die ID des hervorgehobenen Mediums f\u00fcr den Beitrag.","type":"integer","required":false},"comment_status":{"description":"Ob Kommentare f\u00fcr den Beitrag ge\u00f6ffnet sind oder nicht.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Ob der Beitrag gepingt werden kann oder nicht.","type":"string","enum":["open","closed"],"required":false},"menu_order":{"description":"Die Reihenfolge des Beitrags in Bezug auf andere Beitr\u00e4ge.","type":"integer","required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"_yoast_wpseo_focuskw":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_metadesc":{"type":"string","title":"","description":"","default":""},"_data_scadenza_evento":{"type":"string","title":"","description":"","default":""},"_evento_nome":{"type":"string","title":"","description":"","default":""},"_evento_data":{"type":"string","title":"","description":"","default":""},"_evento_luogo":{"type":"string","title":"","description":"","default":""},"_evento_cta":{"type":"string","title":"","description":"","default":""},"keyword_en":{"type":"string","title":"","description":"","default":""},"keyword_es":{"type":"string","title":"","description":"","default":""},"keyword_fr":{"type":"string","title":"","description":"","default":""},"keyword_de":{"type":"string","title":"","description":"","default":""},"keyword_ptb":{"type":"string","title":"","description":"","default":""},"_note_content":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false}}}]},"\/wp\/v2\/pages\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"id":{"description":"Die ID f\u00fcr die automatische Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/media":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"author":{"description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, die bestimmten Autoren zugewiesen sind.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Sicherstellen, dass der Ergebnissatz Beitr\u00e4ge ausschlie\u00dft, die bestimmten Autoren zugewiesen sind.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Wie die Sucheingabe interpretiert wird.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sammlung nach Beitragsattribut sortieren.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"parent":{"description":"Den Ergebnissatz auf alle Elemente bestimmter \u00fcbergeordneter IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Den Ergebnissatz auf alle Elemente begrenzen, au\u00dfer denen mit einer bestimmten \u00fcbergeordneten ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_columns":{"default":[],"description":"Array mit den zu durchsuchenden Spaltennamen.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Ergebnissatz auf Beitr\u00e4ge mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"inherit","description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, denen ein oder mehrere Status zugewiesen sind.","type":"array","items":{"enum":["inherit","private","trash"],"type":"string"},"required":false},"media_type":{"default":null,"description":"Den Ergebnissatz auf Anh\u00e4nge eines bestimmten Medientyps oder bestimmter Medientypen begrenzen.","type":"array","items":{"type":"string","enum":["image","video","audio","application","text"]},"required":false},"mime_type":{"default":null,"description":"Den Ergebnissatz auf Anh\u00e4nge eines bestimmten MIME-Typs oder bestimmter MIME-Typen begrenzen.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"args":{"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","avvia_traduzione","crea_task_resolver"],"required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Beitrags.","type":"integer","required":false},"featured_media":{"description":"Die ID des hervorgehobenen Mediums f\u00fcr den Beitrag.","type":"integer","required":false},"comment_status":{"description":"Ob Kommentare f\u00fcr den Beitrag ge\u00f6ffnet sind oder nicht.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Ob der Beitrag gepingt werden kann oder nicht.","type":"string","enum":["open","closed"],"required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"_yoast_wpseo_focuskw":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_metadesc":{"type":"string","title":"","description":"","default":""},"_data_scadenza_evento":{"type":"string","title":"","description":"","default":""},"_evento_nome":{"type":"string","title":"","description":"","default":""},"_evento_data":{"type":"string","title":"","description":"","default":""},"_evento_luogo":{"type":"string","title":"","description":"","default":""},"_evento_cta":{"type":"string","title":"","description":"","default":""},"keyword_en":{"type":"string","title":"","description":"","default":""},"keyword_es":{"type":"string","title":"","description":"","default":""},"keyword_fr":{"type":"string","title":"","description":"","default":""},"keyword_de":{"type":"string","title":"","description":"","default":""},"keyword_ptb":{"type":"string","title":"","description":"","default":""},"_note_content":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false},"alt_text":{"description":"Alternativtext, der angezeigt wird, wenn der Anhang nicht angezeigt wird.","type":"string","required":false},"caption":{"description":"Die Beschriftung des Anhangs.","type":"object","properties":{"raw":{"description":"Die Beschriftung f\u00fcr den Anhang, wie sie in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"Die f\u00fcr die Anzeige umgewandelte HTML-Beschriftung des Anhangs.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Die Beschreibung des Anhangs.","type":"object","properties":{"raw":{"description":"Beschreibung f\u00fcr den Anhang, wie sie in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Beschreibung f\u00fcr den Anhang, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"post":{"description":"Die ID des Beitrags, dem der Anhang zugeordnet ist.","type":"integer","required":false},"generate_sub_sizes":{"type":"boolean","default":true,"description":"Ob Bilduntergr\u00f6\u00dfen erzeugt werden sollen.","required":false},"convert_format":{"type":"boolean","default":true,"description":"Ob Bildformate konvertiert werden sollen.","required":false},"url":{"type":"string","format":"uri","description":"Die URL eines externen Bildes, das in die Mediathek \u00fcbertragen werden soll, anstatt eine Datei hochzuladen.","required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/wp\/v2\/media"}]}},"\/wp\/v2\/media\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","avvia_traduzione","crea_task_resolver"],"required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Beitrags.","type":"integer","required":false},"featured_media":{"description":"Die ID des hervorgehobenen Mediums f\u00fcr den Beitrag.","type":"integer","required":false},"comment_status":{"description":"Ob Kommentare f\u00fcr den Beitrag ge\u00f6ffnet sind oder nicht.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Ob der Beitrag gepingt werden kann oder nicht.","type":"string","enum":["open","closed"],"required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"_yoast_wpseo_focuskw":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_metadesc":{"type":"string","title":"","description":"","default":""},"_data_scadenza_evento":{"type":"string","title":"","description":"","default":""},"_evento_nome":{"type":"string","title":"","description":"","default":""},"_evento_data":{"type":"string","title":"","description":"","default":""},"_evento_luogo":{"type":"string","title":"","description":"","default":""},"_evento_cta":{"type":"string","title":"","description":"","default":""},"keyword_en":{"type":"string","title":"","description":"","default":""},"keyword_es":{"type":"string","title":"","description":"","default":""},"keyword_fr":{"type":"string","title":"","description":"","default":""},"keyword_de":{"type":"string","title":"","description":"","default":""},"keyword_ptb":{"type":"string","title":"","description":"","default":""},"_note_content":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false},"alt_text":{"description":"Alternativtext, der angezeigt wird, wenn der Anhang nicht angezeigt wird.","type":"string","required":false},"caption":{"description":"Die Beschriftung des Anhangs.","type":"object","properties":{"raw":{"description":"Die Beschriftung f\u00fcr den Anhang, wie sie in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"Die f\u00fcr die Anzeige umgewandelte HTML-Beschriftung des Anhangs.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Die Beschreibung des Anhangs.","type":"object","properties":{"raw":{"description":"Beschreibung f\u00fcr den Anhang, wie sie in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Beschreibung f\u00fcr den Anhang, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"post":{"description":"Die ID des Beitrags, dem der Anhang zugeordnet ist.","type":"integer","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ob der Papierkorb umgangen und die L\u00f6schung erzwungen werden soll.","required":false}}}]},"\/wp\/v2\/media\/(?P<id>[\\d]+)\/post-process":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Anhang.","type":"integer","required":false},"action":{"type":"string","enum":["create-image-subsizes"],"required":true}}}]},"\/wp\/v2\/media\/(?P<id>[\\d]+)\/edit":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"src":{"description":"URL zur bearbeiteten Bilddatei.","type":"string","format":"uri","required":true},"modifiers":{"description":"Array an Bildbearbeitungen.","type":"array","minItems":1,"items":{"description":"Bildbearbeitung.","type":"object","required":["type","args"],"oneOf":[{"title":"Spiegeln","properties":{"type":{"description":"Die Art der Spiegelung.","type":"string","enum":["flip"]},"args":{"description":"Die Spiegelungs-Argumente.","type":"object","required":["flip"],"properties":{"flip":{"description":"Die Richtung der Spiegelung.","type":"object","required":["horizontal","vertical"],"properties":{"horizontal":{"description":"Ob in horizontaler Richtung gespiegelt werden soll.","type":"boolean"},"vertical":{"description":"Ob in vertikaler Richtung gespiegelt werden soll.","type":"boolean"}}}}}}},{"title":"Rotation","properties":{"type":{"description":"Rotations-Typ.","type":"string","enum":["rotate"]},"args":{"description":"Rotations-Argumente.","type":"object","required":["angle"],"properties":{"angle":{"description":"Winkel in Grad f\u00fcr die Rotation im Uhrzeigersinn.","type":"number"}}}}},{"title":"Zuschneiden","properties":{"type":{"description":"Typ des Zuschnitts.","type":"string","enum":["crop"]},"args":{"description":"Zuschnitt-Argumente.","type":"object","required":["left","top","width","height"],"properties":{"left":{"description":"Horizontale Position von links, an der der Zuschnitt beginnen soll, in Prozent der Bildbreite.","type":"number"},"top":{"description":"Vertikale Position von oben, an der der Zuschnitt beginnen soll, in Prozent der Bildh\u00f6he.","type":"number"},"width":{"description":"Die Breite des Zuschnitts in Prozent der Bildbreite.","type":"number"},"height":{"description":"Die H\u00f6he des Zuschnitts in Prozent der Bildh\u00f6he.","type":"number"}}}}}]},"required":false},"rotation":{"description":"Der Bereich in Grad, um den das Bild im Uhrzeigersinn gedreht werden soll. VERALTET: Stattdessen `modifiers` benutzen.","type":"integer","minimum":0,"exclusiveMinimum":true,"maximum":360,"exclusiveMaximum":true,"required":false},"x":{"description":"Die x-Position des Bildes in Prozent, an der das Zuschneiden des Bildes beginnen soll. VERALTET: Stattdessen `modifiers` benutzen.","type":"number","minimum":0,"maximum":100,"required":false},"y":{"description":"Die y-Position des Bildes in Prozent, an der das Zuschneiden des Bildes beginnen soll. VERALTET: Stattdessen `modifiers` benutzen.","type":"number","minimum":0,"maximum":100,"required":false},"width":{"description":"Die Breite des Bildes in Prozent, auf die das Bild zugeschnitten werden soll. VERALTET: Stattdessen `modifiers` benutzen.","type":"number","minimum":0,"maximum":100,"required":false},"height":{"description":"Die H\u00f6he des Bildes in Prozent, auf die das Bild zugeschnitten werden soll. VERALTET: Stattdessen `modifiers` benutzen.","type":"number","minimum":0,"maximum":100,"required":false},"caption":{"description":"Die Beschriftung des Anhangs.","type":"object","properties":{"raw":{"description":"Die Beschriftung f\u00fcr den Anhang, wie sie in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"Die f\u00fcr die Anzeige umgewandelte HTML-Beschriftung des Anhangs.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Die Beschreibung des Anhangs.","type":"object","properties":{"raw":{"description":"Beschreibung f\u00fcr den Anhang, wie sie in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Beschreibung f\u00fcr den Anhang, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"post":{"description":"Die ID des Beitrags, dem der Anhang zugeordnet ist.","type":"integer","required":false},"alt_text":{"description":"Alternativtext, der angezeigt wird, wenn der Anhang nicht angezeigt wird.","type":"string","required":false}}}]},"\/wp\/v2\/media\/(?P<id>[\\d]+)\/sideload":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Anhang.","type":"integer","required":false},"image_size":{"description":"Die Bildgr\u00f6\u00dfe. Sie kann ein einzelner Gr\u00f6\u00dfenname oder ein Array mit Gr\u00f6\u00dfennamen sein, um dieselbe Datei unter mehreren Gr\u00f6\u00dfen zu registrieren.","type":["string","array"],"items":{"type":"string","minLength":1},"minItems":1,"minLength":1,"required":true},"convert_format":{"type":"boolean","default":true,"description":"Ob Bildformate konvertiert werden sollen.","required":false}}}]},"\/wp\/v2\/media\/(?P<id>[\\d]+)\/finalize":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Anhang.","type":"integer","required":false},"sub_sizes":{"description":"Ein Array mit Metadaten von Untergr\u00f6\u00dfen, extrahiert aus \u00dcbertragungsantworten.","type":"array","default":[],"maxItems":100,"items":{"type":"object","properties":{"image_size":{"description":"Gr\u00f6\u00dfenname oder ein Array aus Gr\u00f6\u00dfennamen, wenn eine einzelne Datei unter mehreren Gr\u00f6\u00dfen mit identischen Ma\u00dfen registriert ist.","type":["string","array"],"items":{"type":"string","minLength":1},"minItems":1,"minLength":1,"required":true},"width":{"type":"integer","minimum":1},"height":{"type":"integer","minimum":1},"file":{"type":"string","minLength":1},"mime_type":{"type":"string","pattern":"^image\/.*"},"filesize":{"type":"integer","minimum":1},"original_image":{"type":"string","minLength":1}}},"required":false}}}]},"\/wp\/v2\/menu-items":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":100,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Wie die Sucheingabe interpretiert wird.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Die Sammlung nach Objektattribut sortieren.","type":"string","default":"menu_order","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"search_columns":{"default":[],"description":"Array mit den zu durchsuchenden Spaltennamen.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Ergebnissatz auf Beitr\u00e4ge mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, denen ein oder mehrere Status zugewiesen sind.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","flamingo-spam","avvia_traduzione","crea_task_resolver","any"],"type":"string"},"required":false},"tax_relation":{"description":"Abfrage-Ergebnis auf Basis der Beziehung zwischen mehreren Taxonomien einschr\u00e4nken.","type":"string","enum":["AND","OR"],"required":false},"menus":{"description":"Ergebnissatz auf Elemente beschr\u00e4nken, denen bestimmte Begriffe in der Taxonomie menus zugewiesen sind.","type":["object","array"],"oneOf":[{"title":"Begriffs-ID-Liste","description":"Begriffe mit den gelisteten IDs vergleichen.","type":"array","items":{"type":"integer"}},{"title":"Taxonomie-Abfrage nach Begriffs-ID","description":"F\u00fchre eine erweiterte Begriffsabfrage durch.","type":"object","properties":{"terms":{"description":"Begriff-IDs.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Ob Elemente allen oder beliebigen festgelegten Begriffen zugewiesen sein m\u00fcssen.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"menus_exclude":{"description":"Ergebnissatz auf Elemente beschr\u00e4nken, au\u00dfer auf solche, denen bestimmte Begriffe in der Taxonomie menus zugewiesen sind.","type":["object","array"],"oneOf":[{"title":"Begriffs-ID-Liste","description":"Begriffe mit den gelisteten IDs vergleichen.","type":"array","items":{"type":"integer"}},{"title":"Taxonomie-Abfrage nach Begriffs-ID","description":"F\u00fchre eine erweiterte Begriffsabfrage durch.","type":"object","properties":{"terms":{"description":"Begriff-IDs.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"menu_order":{"description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, die einen bestimmten menu_order-Wert haben.","type":"integer","required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"title":{"description":"Der Titel f\u00fcr das Objekt.","type":["string","object"],"properties":{"raw":{"description":"Titel f\u00fcr das Objekt, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr das Objekt, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"type":{"default":"custom","description":"Die urspr\u00fcnglich repr\u00e4sentierte Objektfamilie, z.\u00a0B. \u201epost_type\u201c oder \u201etaxonomy\u201c.","type":"string","enum":["taxonomy","post_type","post_type_archive","custom"],"required":false},"status":{"default":"publish","description":"Ein benannter Status f\u00fcr das Objekt.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","avvia_traduzione","crea_task_resolver"],"required":false},"parent":{"default":0,"description":"Die ID des \u00fcbergeordneten Objekts.","type":"integer","minimum":0,"required":false},"attr_title":{"description":"Text f\u00fcr das Titelattribut des Linkelements dieses Men\u00fceintrags.","type":"string","required":false},"classes":{"description":"Klassennamen f\u00fcr das Linkelement dieses Men\u00fceintrags.","type":"array","items":{"type":"string"},"required":false},"description":{"description":"Die Beschreibung dieses Men\u00fceintrags.","type":"string","required":false},"menu_order":{"default":1,"description":"Die DB-ID des nav_menu_item, das gegebenenfalls der \u00fcbergeordnete Men\u00fceintrag dieses Elements ist; andernfalls 0.","type":"integer","minimum":1,"required":false},"object":{"description":"Der urspr\u00fcnglich repr\u00e4sentierte Objekttyp, z.\u00a0B. \u201ecategory\u201c, \u201epost\u201c oder \u201eattachment\u201c.","type":"string","required":false},"object_id":{"default":0,"description":"Die Datenbank-ID des urspr\u00fcnglichen Objekts, das dieser Men\u00fceintrag repr\u00e4sentiert, zum Beispiel die ID f\u00fcr Beitr\u00e4ge oder die term_id f\u00fcr Kategorien.","type":"integer","minimum":0,"required":false},"target":{"description":"Das Zielattribut des Linkelements f\u00fcr diesen Men\u00fceintrag.","type":"string","enum":["_blank",""],"required":false},"url":{"description":"Die URL, auf die dieser Men\u00fceintrag zeigt.","type":"string","format":"uri","required":false},"xfn":{"description":"Die XFN-Beziehung, die durch den Link dieses Men\u00fceintrags beschrieben wird.","type":"array","items":{"type":"string"},"required":false},"menus":{"description":"Die Begriffe, die dem Objekt in der Taxonomie nav_menu zugewiesen sind.","type":"integer","required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"_yoast_wpseo_focuskw":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_metadesc":{"type":"string","title":"","description":"","default":""},"_data_scadenza_evento":{"type":"string","title":"","description":"","default":""},"_evento_nome":{"type":"string","title":"","description":"","default":""},"_evento_data":{"type":"string","title":"","description":"","default":""},"_evento_luogo":{"type":"string","title":"","description":"","default":""},"_evento_cta":{"type":"string","title":"","description":"","default":""},"keyword_en":{"type":"string","title":"","description":"","default":""},"keyword_es":{"type":"string","title":"","description":"","default":""},"keyword_fr":{"type":"string","title":"","description":"","default":""},"keyword_de":{"type":"string","title":"","description":"","default":""},"keyword_ptb":{"type":"string","title":"","description":"","default":""},"_note_content":{"type":"string","title":"","description":"","default":""}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/wp\/v2\/menu-items"}]}},"\/wp\/v2\/menu-items\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"title":{"description":"Der Titel f\u00fcr das Objekt.","type":["string","object"],"properties":{"raw":{"description":"Titel f\u00fcr das Objekt, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr das Objekt, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"type":{"description":"Die urspr\u00fcnglich repr\u00e4sentierte Objektfamilie, z.\u00a0B. \u201epost_type\u201c oder \u201etaxonomy\u201c.","type":"string","enum":["taxonomy","post_type","post_type_archive","custom"],"required":false},"status":{"description":"Ein benannter Status f\u00fcr das Objekt.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","avvia_traduzione","crea_task_resolver"],"required":false},"parent":{"description":"Die ID des \u00fcbergeordneten Objekts.","type":"integer","minimum":0,"required":false},"attr_title":{"description":"Text f\u00fcr das Titelattribut des Linkelements dieses Men\u00fceintrags.","type":"string","required":false},"classes":{"description":"Klassennamen f\u00fcr das Linkelement dieses Men\u00fceintrags.","type":"array","items":{"type":"string"},"required":false},"description":{"description":"Die Beschreibung dieses Men\u00fceintrags.","type":"string","required":false},"menu_order":{"description":"Die DB-ID des nav_menu_item, das gegebenenfalls der \u00fcbergeordnete Men\u00fceintrag dieses Elements ist; andernfalls 0.","type":"integer","minimum":1,"required":false},"object":{"description":"Der urspr\u00fcnglich repr\u00e4sentierte Objekttyp, z.\u00a0B. \u201ecategory\u201c, \u201epost\u201c oder \u201eattachment\u201c.","type":"string","required":false},"object_id":{"description":"Die Datenbank-ID des urspr\u00fcnglichen Objekts, das dieser Men\u00fceintrag repr\u00e4sentiert, zum Beispiel die ID f\u00fcr Beitr\u00e4ge oder die term_id f\u00fcr Kategorien.","type":"integer","minimum":0,"required":false},"target":{"description":"Das Zielattribut des Linkelements f\u00fcr diesen Men\u00fceintrag.","type":"string","enum":["_blank",""],"required":false},"url":{"description":"Die URL, auf die dieser Men\u00fceintrag zeigt.","type":"string","format":"uri","required":false},"xfn":{"description":"Die XFN-Beziehung, die durch den Link dieses Men\u00fceintrags beschrieben wird.","type":"array","items":{"type":"string"},"required":false},"menus":{"description":"Die Begriffe, die dem Objekt in der Taxonomie nav_menu zugewiesen sind.","type":"integer","required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"_yoast_wpseo_focuskw":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_metadesc":{"type":"string","title":"","description":"","default":""},"_data_scadenza_evento":{"type":"string","title":"","description":"","default":""},"_evento_nome":{"type":"string","title":"","description":"","default":""},"_evento_data":{"type":"string","title":"","description":"","default":""},"_evento_luogo":{"type":"string","title":"","description":"","default":""},"_evento_cta":{"type":"string","title":"","description":"","default":""},"keyword_en":{"type":"string","title":"","description":"","default":""},"keyword_es":{"type":"string","title":"","description":"","default":""},"keyword_fr":{"type":"string","title":"","description":"","default":""},"keyword_de":{"type":"string","title":"","description":"","default":""},"keyword_ptb":{"type":"string","title":"","description":"","default":""},"_note_content":{"type":"string","title":"","description":"","default":""}},"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ob der Papierkorb umgangen und die L\u00f6schung erzwungen werden soll.","required":false}}}]},"\/wp\/v2\/menu-items\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"Die ID des \u00fcbergeordneten Objekts.","type":"integer","minimum":0,"required":false},"title":{"description":"Der Titel f\u00fcr das Objekt.","type":["string","object"],"properties":{"raw":{"description":"Titel f\u00fcr das Objekt, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr das Objekt, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"type":{"description":"Die urspr\u00fcnglich repr\u00e4sentierte Objektfamilie, z.\u00a0B. \u201epost_type\u201c oder \u201etaxonomy\u201c.","type":"string","enum":["taxonomy","post_type","post_type_archive","custom"],"required":false},"status":{"description":"Ein benannter Status f\u00fcr das Objekt.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","avvia_traduzione","crea_task_resolver"],"required":false},"attr_title":{"description":"Text f\u00fcr das Titelattribut des Linkelements dieses Men\u00fceintrags.","type":"string","required":false},"classes":{"description":"Klassennamen f\u00fcr das Linkelement dieses Men\u00fceintrags.","type":"array","items":{"type":"string"},"required":false},"description":{"description":"Die Beschreibung dieses Men\u00fceintrags.","type":"string","required":false},"menu_order":{"description":"Die DB-ID des nav_menu_item, das gegebenenfalls der \u00fcbergeordnete Men\u00fceintrag dieses Elements ist; andernfalls 0.","type":"integer","minimum":1,"required":false},"object":{"description":"Der urspr\u00fcnglich repr\u00e4sentierte Objekttyp, z.\u00a0B. \u201ecategory\u201c, \u201epost\u201c oder \u201eattachment\u201c.","type":"string","required":false},"object_id":{"description":"Die Datenbank-ID des urspr\u00fcnglichen Objekts, das dieser Men\u00fceintrag repr\u00e4sentiert, zum Beispiel die ID f\u00fcr Beitr\u00e4ge oder die term_id f\u00fcr Kategorien.","type":"integer","minimum":0,"required":false},"target":{"description":"Das Zielattribut des Linkelements f\u00fcr diesen Men\u00fceintrag.","type":"string","enum":["_blank",""],"required":false},"url":{"description":"Die URL, auf die dieser Men\u00fceintrag zeigt.","type":"string","format":"uri","required":false},"xfn":{"description":"Die XFN-Beziehung, die durch den Link dieses Men\u00fceintrags beschrieben wird.","type":"array","items":{"type":"string"},"required":false},"menus":{"description":"Die Begriffe, die dem Objekt in der Taxonomie nav_menu zugewiesen sind.","type":"integer","required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"_yoast_wpseo_focuskw":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_metadesc":{"type":"string","title":"","description":"","default":""},"_data_scadenza_evento":{"type":"string","title":"","description":"","default":""},"_evento_nome":{"type":"string","title":"","description":"","default":""},"_evento_data":{"type":"string","title":"","description":"","default":""},"_evento_luogo":{"type":"string","title":"","description":"","default":""},"_evento_cta":{"type":"string","title":"","description":"","default":""},"keyword_en":{"type":"string","title":"","description":"","default":""},"keyword_es":{"type":"string","title":"","description":"","default":""},"keyword_fr":{"type":"string","title":"","description":"","default":""},"keyword_de":{"type":"string","title":"","description":"","default":""},"keyword_ptb":{"type":"string","title":"","description":"","default":""},"_note_content":{"type":"string","title":"","description":"","default":""}},"required":false}}}]},"\/wp\/v2\/menu-items\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"id":{"description":"Die ID f\u00fcr die automatische Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/blocks":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Wie die Sucheingabe interpretiert wird.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sammlung nach Beitragsattribut sortieren.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array mit den zu durchsuchenden Spaltennamen.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Ergebnissatz auf Beitr\u00e4ge mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, denen ein oder mehrere Status zugewiesen sind.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","flamingo-spam","avvia_traduzione","crea_task_resolver","any"],"type":"string"},"required":false},"tax_relation":{"description":"Abfrage-Ergebnis auf Basis der Beziehung zwischen mehreren Taxonomien einschr\u00e4nken.","type":"string","enum":["AND","OR"],"required":false},"wp_pattern_category":{"description":"Ergebnissatz auf Elemente beschr\u00e4nken, denen bestimmte Begriffe in der Taxonomie wp_pattern_category zugewiesen sind.","type":["object","array"],"oneOf":[{"title":"Begriffs-ID-Liste","description":"Begriffe mit den gelisteten IDs vergleichen.","type":"array","items":{"type":"integer"}},{"title":"Taxonomie-Abfrage nach Begriffs-ID","description":"F\u00fchre eine erweiterte Begriffsabfrage durch.","type":"object","properties":{"terms":{"description":"Begriff-IDs.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Ob Elemente allen oder beliebigen festgelegten Begriffen zugewiesen sein m\u00fcssen.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"wp_pattern_category_exclude":{"description":"Ergebnissatz auf Elemente beschr\u00e4nken, au\u00dfer auf solche, denen bestimmte Begriffe in der Taxonomie wp_pattern_category zugewiesen sind.","type":["object","array"],"oneOf":[{"title":"Begriffs-ID-Liste","description":"Begriffe mit den gelisteten IDs vergleichen.","type":"array","items":{"type":"integer"}},{"title":"Taxonomie-Abfrage nach Begriffs-ID","description":"F\u00fchre eine erweiterte Begriffsabfrage durch.","type":"object","properties":{"terms":{"description":"Begriff-IDs.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","avvia_traduzione","crea_task_resolver"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit"]}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit"]},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"Der Textauszug f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Textauszug f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Textauszug f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Ob der Textauszug durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"_yoast_wpseo_focuskw":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_metadesc":{"type":"string","title":"","description":"","default":""},"_data_scadenza_evento":{"type":"string","title":"","description":"","default":""},"_evento_nome":{"type":"string","title":"","description":"","default":""},"_evento_data":{"type":"string","title":"","description":"","default":""},"_evento_luogo":{"type":"string","title":"","description":"","default":""},"_evento_cta":{"type":"string","title":"","description":"","default":""},"keyword_en":{"type":"string","title":"","description":"","default":""},"keyword_es":{"type":"string","title":"","description":"","default":""},"keyword_fr":{"type":"string","title":"","description":"","default":""},"keyword_de":{"type":"string","title":"","description":"","default":""},"keyword_ptb":{"type":"string","title":"","description":"","default":""},"_note_content":{"type":"string","title":"","description":"","default":""},"wp_pattern_sync_status":{"type":"string","title":"","description":"","default":"","enum":["partial","unsynced"]},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false},"wp_pattern_category":{"description":"Die Begriffe, die dem Beitrag in der Taxonomie wp_pattern_category zugewiesen sind.","type":"array","items":{"type":"integer"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/wp\/v2\/blocks"}]}},"\/wp\/v2\/blocks\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"Setzt die Standardl\u00e4nge des Textauszugs au\u00dfer Kraft.","type":"integer","required":false},"password":{"description":"Das Passwort f\u00fcr den Beitrag, falls dieser passwortgesch\u00fctzt ist.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","avvia_traduzione","crea_task_resolver"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit"]}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit"]},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"Der Textauszug f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Textauszug f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Textauszug f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Ob der Textauszug durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"_yoast_wpseo_focuskw":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_metadesc":{"type":"string","title":"","description":"","default":""},"_data_scadenza_evento":{"type":"string","title":"","description":"","default":""},"_evento_nome":{"type":"string","title":"","description":"","default":""},"_evento_data":{"type":"string","title":"","description":"","default":""},"_evento_luogo":{"type":"string","title":"","description":"","default":""},"_evento_cta":{"type":"string","title":"","description":"","default":""},"keyword_en":{"type":"string","title":"","description":"","default":""},"keyword_es":{"type":"string","title":"","description":"","default":""},"keyword_fr":{"type":"string","title":"","description":"","default":""},"keyword_de":{"type":"string","title":"","description":"","default":""},"keyword_ptb":{"type":"string","title":"","description":"","default":""},"_note_content":{"type":"string","title":"","description":"","default":""},"wp_pattern_sync_status":{"type":"string","title":"","description":"","default":"","enum":["partial","unsynced"]},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false},"wp_pattern_category":{"description":"Die Begriffe, die dem Beitrag in der Taxonomie wp_pattern_category zugewiesen sind.","type":"array","items":{"type":"integer"},"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ob der Papierkorb umgangen und die L\u00f6schung erzwungen werden soll.","required":false}}}]},"\/wp\/v2\/blocks\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Revision.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Die Sammlung nach Objektattribut sortieren.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/blocks\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Revision.","type":"integer","required":false},"id":{"description":"Eindeutige Kennung f\u00fcr die Revision.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Revision.","type":"integer","required":false},"id":{"description":"Eindeutige Kennung f\u00fcr die Revision.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Setzen auf true erforderlich, denn Revisionen k\u00f6nnen nicht in den Papierkorb gelegt werden.","required":false}}}]},"\/wp\/v2\/blocks\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","avvia_traduzione","crea_task_resolver"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit"]}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit"]},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"Der Textauszug f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Textauszug f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Textauszug f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Ob der Textauszug durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"_yoast_wpseo_focuskw":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_metadesc":{"type":"string","title":"","description":"","default":""},"_data_scadenza_evento":{"type":"string","title":"","description":"","default":""},"_evento_nome":{"type":"string","title":"","description":"","default":""},"_evento_data":{"type":"string","title":"","description":"","default":""},"_evento_luogo":{"type":"string","title":"","description":"","default":""},"_evento_cta":{"type":"string","title":"","description":"","default":""},"keyword_en":{"type":"string","title":"","description":"","default":""},"keyword_es":{"type":"string","title":"","description":"","default":""},"keyword_fr":{"type":"string","title":"","description":"","default":""},"keyword_de":{"type":"string","title":"","description":"","default":""},"keyword_ptb":{"type":"string","title":"","description":"","default":""},"_note_content":{"type":"string","title":"","description":"","default":""},"wp_pattern_sync_status":{"type":"string","title":"","description":"","default":"","enum":["partial","unsynced"]},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false},"wp_pattern_category":{"description":"Die Begriffe, die dem Beitrag in der Taxonomie wp_pattern_category zugewiesen sind.","type":"array","items":{"type":"integer"},"required":false}}}]},"\/wp\/v2\/blocks\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"id":{"description":"Die ID f\u00fcr die automatische Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/templates\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID eines Templates","type":"string","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Die Sammlung nach Objektattribut sortieren.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/templates\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID eines Templates","type":"string","required":false},"id":{"description":"Eindeutige Kennung f\u00fcr die Revision.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"Die ID eines Templates","type":"string","required":false},"id":{"description":"Eindeutige Kennung f\u00fcr die Revision.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Setzen auf true erforderlich, denn Revisionen k\u00f6nnen nicht in den Papierkorb gelegt werden.","required":false}}}]},"\/wp\/v2\/templates\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Die ID eines Templates","type":"string","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"id":{"description":"Die ID eines Templates","type":"string","required":false},"slug":{"description":"Eindeutige Titelform, die das Template identifiziert.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"Theme-Kennung f\u00fcr das Template.","type":"string","required":false},"type":{"description":"Typ des Templates.","type":"string","required":false},"content":{"description":"Inhalt des Templates.","type":["object","string"],"properties":{"raw":{"description":"Der Inhalt f\u00fcr das Template, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit"]},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Template verwendet wird.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"Titel des Templates.","type":["object","string"],"properties":{"raw":{"description":"Der Titel f\u00fcr das Template, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"Der HTML-Titel f\u00fcr das Template, der f\u00fcr die Anzeige transformiert wurde.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Beschreibung des Templates.","type":"string","required":false},"status":{"description":"Status des Templates.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","avvia_traduzione","crea_task_resolver"],"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Templates.","type":"integer","required":false}}}]},"\/wp\/v2\/templates\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID eines Templates","type":"string","required":false},"id":{"description":"Die ID f\u00fcr die automatische Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/templates":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wp_id":{"description":"Auf die angegebene Beitrags-ID begrenzen.","type":"integer","required":false},"area":{"description":"Auf den angegebenen Bereich des Template-Teils begrenzen.","type":"string","required":false},"post_type":{"description":"Inhaltstyp f\u00fcr die Templates.","type":"string","required":false}}},{"methods":["POST"],"args":{"slug":{"description":"Eindeutige Titelform, die das Template identifiziert.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":true},"theme":{"description":"Theme-Kennung f\u00fcr das Template.","type":"string","required":false},"type":{"description":"Typ des Templates.","type":"string","required":false},"content":{"default":"","description":"Inhalt des Templates.","type":["object","string"],"properties":{"raw":{"description":"Der Inhalt f\u00fcr das Template, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit"]},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Template verwendet wird.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"default":"","description":"Titel des Templates.","type":["object","string"],"properties":{"raw":{"description":"Der Titel f\u00fcr das Template, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"Der HTML-Titel f\u00fcr das Template, der f\u00fcr die Anzeige transformiert wurde.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"default":"","description":"Beschreibung des Templates.","type":"string","required":false},"status":{"default":"publish","description":"Status des Templates.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","avvia_traduzione","crea_task_resolver"],"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Templates.","type":"integer","required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/wp\/v2\/templates"}]}},"\/wp\/v2\/templates\/lookup":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"Die Titelform des Templates, f\u00fcr die das Fallback abgerufen werden soll","type":"string","required":true},"is_custom":{"description":"Gibt an, ob ein Template individuell oder Teil der Template-Hierarchie ist","type":"boolean","required":false},"template_prefix":{"description":"Das Template-Pr\u00e4fix f\u00fcr das erstellte Template. Dies wird verwendet, um den Haupt-Template-Typ zu extrahieren, z.\u00a0B. in `taxonomy-books` wird die `taxonomy` extrahiert","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/wp\/v2\/templates\/lookup"}]}},"\/wp\/v2\/templates\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Die ID eines Templates","type":"string","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Die ID eines Templates","type":"string","required":false},"slug":{"description":"Eindeutige Titelform, die das Template identifiziert.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"Theme-Kennung f\u00fcr das Template.","type":"string","required":false},"type":{"description":"Typ des Templates.","type":"string","required":false},"content":{"description":"Inhalt des Templates.","type":["object","string"],"properties":{"raw":{"description":"Der Inhalt f\u00fcr das Template, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit"]},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Template verwendet wird.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"Titel des Templates.","type":["object","string"],"properties":{"raw":{"description":"Der Titel f\u00fcr das Template, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"Der HTML-Titel f\u00fcr das Template, der f\u00fcr die Anzeige transformiert wurde.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Beschreibung des Templates.","type":"string","required":false},"status":{"description":"Status des Templates.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","avvia_traduzione","crea_task_resolver"],"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Templates.","type":"integer","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Die ID eines Templates","type":"string","required":false},"force":{"type":"boolean","default":false,"description":"Ob der Papierkorb umgangen und die L\u00f6schung erzwungen werden soll.","required":false}}}]},"\/wp\/v2\/template-parts\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID eines Templates","type":"string","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Die Sammlung nach Objektattribut sortieren.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/template-parts\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID eines Templates","type":"string","required":false},"id":{"description":"Eindeutige Kennung f\u00fcr die Revision.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"Die ID eines Templates","type":"string","required":false},"id":{"description":"Eindeutige Kennung f\u00fcr die Revision.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Setzen auf true erforderlich, denn Revisionen k\u00f6nnen nicht in den Papierkorb gelegt werden.","required":false}}}]},"\/wp\/v2\/template-parts\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Die ID eines Templates","type":"string","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"id":{"description":"Die ID eines Templates","type":"string","required":false},"slug":{"description":"Eindeutige Titelform, die das Template identifiziert.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"Theme-Kennung f\u00fcr das Template.","type":"string","required":false},"type":{"description":"Typ des Templates.","type":"string","required":false},"content":{"description":"Inhalt des Templates.","type":["object","string"],"properties":{"raw":{"description":"Der Inhalt f\u00fcr das Template, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit"]},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Template verwendet wird.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"Titel des Templates.","type":["object","string"],"properties":{"raw":{"description":"Der Titel f\u00fcr das Template, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"Der HTML-Titel f\u00fcr das Template, der f\u00fcr die Anzeige transformiert wurde.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Beschreibung des Templates.","type":"string","required":false},"status":{"description":"Status des Templates.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","avvia_traduzione","crea_task_resolver"],"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Templates.","type":"integer","required":false},"area":{"description":"Wo das Template-Teil verwendet werden soll (Header, Footer etc.)","type":"string","required":false}}}]},"\/wp\/v2\/template-parts\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID eines Templates","type":"string","required":false},"id":{"description":"Die ID f\u00fcr die automatische Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/template-parts":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wp_id":{"description":"Auf die angegebene Beitrags-ID begrenzen.","type":"integer","required":false},"area":{"description":"Auf den angegebenen Bereich des Template-Teils begrenzen.","type":"string","required":false},"post_type":{"description":"Inhaltstyp f\u00fcr die Templates.","type":"string","required":false}}},{"methods":["POST"],"args":{"slug":{"description":"Eindeutige Titelform, die das Template identifiziert.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":true},"theme":{"description":"Theme-Kennung f\u00fcr das Template.","type":"string","required":false},"type":{"description":"Typ des Templates.","type":"string","required":false},"content":{"default":"","description":"Inhalt des Templates.","type":["object","string"],"properties":{"raw":{"description":"Der Inhalt f\u00fcr das Template, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit"]},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Template verwendet wird.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"default":"","description":"Titel des Templates.","type":["object","string"],"properties":{"raw":{"description":"Der Titel f\u00fcr das Template, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"Der HTML-Titel f\u00fcr das Template, der f\u00fcr die Anzeige transformiert wurde.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"default":"","description":"Beschreibung des Templates.","type":"string","required":false},"status":{"default":"publish","description":"Status des Templates.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","avvia_traduzione","crea_task_resolver"],"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Templates.","type":"integer","required":false},"area":{"description":"Wo das Template-Teil verwendet werden soll (Header, Footer etc.)","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/wp\/v2\/template-parts"}]}},"\/wp\/v2\/template-parts\/lookup":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"Die Titelform des Templates, f\u00fcr die das Fallback abgerufen werden soll","type":"string","required":true},"is_custom":{"description":"Gibt an, ob ein Template individuell oder Teil der Template-Hierarchie ist","type":"boolean","required":false},"template_prefix":{"description":"Das Template-Pr\u00e4fix f\u00fcr das erstellte Template. Dies wird verwendet, um den Haupt-Template-Typ zu extrahieren, z.\u00a0B. in `taxonomy-books` wird die `taxonomy` extrahiert","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/wp\/v2\/template-parts\/lookup"}]}},"\/wp\/v2\/template-parts\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Die ID eines Templates","type":"string","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Die ID eines Templates","type":"string","required":false},"slug":{"description":"Eindeutige Titelform, die das Template identifiziert.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"Theme-Kennung f\u00fcr das Template.","type":"string","required":false},"type":{"description":"Typ des Templates.","type":"string","required":false},"content":{"description":"Inhalt des Templates.","type":["object","string"],"properties":{"raw":{"description":"Der Inhalt f\u00fcr das Template, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit"]},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Template verwendet wird.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"Titel des Templates.","type":["object","string"],"properties":{"raw":{"description":"Der Titel f\u00fcr das Template, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"Der HTML-Titel f\u00fcr das Template, der f\u00fcr die Anzeige transformiert wurde.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Beschreibung des Templates.","type":"string","required":false},"status":{"description":"Status des Templates.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","avvia_traduzione","crea_task_resolver"],"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Templates.","type":"integer","required":false},"area":{"description":"Wo das Template-Teil verwendet werden soll (Header, Footer etc.)","type":"string","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Die ID eines Templates","type":"string","required":false},"force":{"type":"boolean","default":false,"description":"Ob der Papierkorb umgangen und die L\u00f6schung erzwungen werden soll.","required":false}}}]},"\/wp\/v2\/global-styles\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Revision.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","minimum":1,"maximum":100,"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false}}}]},"\/wp\/v2\/global-styles\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Revision der globalen Stile.","type":"integer","required":false},"id":{"description":"Eindeutige Kennung der Revision f\u00fcr globale Stile.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/global-styles\/themes\/(?P<stylesheet>[\\\/\\s%\\w\\.\\(\\)\\[\\]\\@_\\-]+)\/variations":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":false},"args":{"stylesheet":{"description":"Die Theme-Kennung","type":"string","required":false}}}]},"\/wp\/v2\/global-styles\/themes\/(?P<stylesheet>[^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":false},"args":{"stylesheet":{"description":"Die Theme-Kennung","type":"string","required":false}}}]},"\/wp\/v2\/global-styles\/(?P<id>[\\\/\\d+]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":false},"args":{"id":{"description":"Die ID der globalen Stile-Konfiguration.","type":"integer","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":false},"args":{"styles":{"description":"Globale Stile.","type":["object"],"required":false},"settings":{"description":"Globale Einstellungen.","type":["object"],"required":false},"title":{"description":"Der Titel der globalen Stilvariante.","type":["object","string"],"properties":{"raw":{"description":"Der Titel der globalen Stilvariante, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false}}}]},"\/wp\/v2\/navigation":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Wie die Sucheingabe interpretiert wird.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sammlung nach Beitragsattribut sortieren.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array mit den zu durchsuchenden Spaltennamen.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Ergebnissatz auf Beitr\u00e4ge mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, denen ein oder mehrere Status zugewiesen sind.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","flamingo-spam","avvia_traduzione","crea_task_resolver","any"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","avvia_traduzione","crea_task_resolver"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit","embed"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit","embed"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit","embed"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/wp\/v2\/navigation"}]}},"\/wp\/v2\/navigation\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"Das Passwort f\u00fcr den Beitrag, falls dieser passwortgesch\u00fctzt ist.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","avvia_traduzione","crea_task_resolver"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit","embed"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit","embed"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit","embed"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ob der Papierkorb umgangen und die L\u00f6schung erzwungen werden soll.","required":false}}}]},"\/wp\/v2\/navigation\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Revision.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Die Sammlung nach Objektattribut sortieren.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/navigation\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Revision.","type":"integer","required":false},"id":{"description":"Eindeutige Kennung f\u00fcr die Revision.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Revision.","type":"integer","required":false},"id":{"description":"Eindeutige Kennung f\u00fcr die Revision.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Setzen auf true erforderlich, denn Revisionen k\u00f6nnen nicht in den Papierkorb gelegt werden.","required":false}}}]},"\/wp\/v2\/navigation\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","avvia_traduzione","crea_task_resolver"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit","embed"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit","embed"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit","embed"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false}}}]},"\/wp\/v2\/navigation\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"id":{"description":"Die ID f\u00fcr die automatische Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/font-families":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Wie die Sucheingabe interpretiert wird.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sammlung nach Beitragsattribut sortieren.","type":"string","default":"id","enum":["id","include"],"required":false},"slug":{"description":"Ergebnissatz auf Beitr\u00e4ge mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"args":{"theme_json_version":{"description":"Die Version des theme.json-Schemas, das f\u00fcr Typografie-Einstellungen verwendet wird.","type":"integer","default":3,"minimum":2,"maximum":3,"required":false},"font_family_settings":{"description":"Schriftfamilien-Deklaration im theme.json-Format, als Zeichenfolge kodiert.","type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/wp\/v2\/font-families"}]}},"\/wp\/v2\/font-families\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"theme_json_version":{"description":"Die Version des theme.json-Schemas, das f\u00fcr Typografie-Einstellungen verwendet wird.","type":"integer","default":3,"minimum":2,"maximum":3,"required":false},"font_family_settings":{"description":"Schriftfamilien-Deklaration im theme.json-Format, als Zeichenfolge kodiert.","type":"string","required":true}}},{"methods":["DELETE"],"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ob der Papierkorb umgangen und die L\u00f6schung erzwungen werden soll.","required":false}}}]},"\/wp\/v2\/font-families\/(?P<font_family_id>[\\d]+)\/font-faces":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"font_family_id":{"description":"Die ID der \u00fcbergeordneten Schriftfamilie des Schriftschnitts.","type":"integer","required":true},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Wie die Sucheingabe interpretiert wird.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sammlung nach Beitragsattribut sortieren.","type":"string","default":"id","enum":["id","include"],"required":false}}},{"methods":["POST"],"args":{"font_family_id":{"description":"Die ID der \u00fcbergeordneten Schriftfamilie des Schriftschnitts.","type":"integer","required":true},"theme_json_version":{"description":"Die Version des theme.json-Schemas, das f\u00fcr Typografie-Einstellungen verwendet wird.","type":"integer","default":3,"minimum":2,"maximum":3,"required":false},"font_face_settings":{"description":"Schriftschnitt-Deklaration im theme.json-Format, als Zeichenfolge kodiert.","type":"string","required":true}}}]},"\/wp\/v2\/font-families\/(?P<font_family_id>[\\d]+)\/font-faces\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"font_family_id":{"description":"Die ID der \u00fcbergeordneten Schriftfamilie des Schriftschnitts.","type":"integer","required":true},"id":{"description":"Eindeutige Kennung f\u00fcr den Schriftschnitt.","type":"integer","required":true},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"font_family_id":{"description":"Die ID der \u00fcbergeordneten Schriftfamilie des Schriftschnitts.","type":"integer","required":true},"id":{"description":"Eindeutige Kennung f\u00fcr den Schriftschnitt.","type":"integer","required":true},"force":{"type":"boolean","default":false,"description":"Ob der Papierkorb umgangen und die L\u00f6schung erzwungen werden soll.","required":false}}}]},"\/wp\/v2\/portfolio":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"author":{"description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, die bestimmten Autoren zugewiesen sind.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Sicherstellen, dass der Ergebnissatz Beitr\u00e4ge ausschlie\u00dft, die bestimmten Autoren zugewiesen sind.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Wie die Sucheingabe interpretiert wird.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sammlung nach Beitragsattribut sortieren.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array mit den zu durchsuchenden Spaltennamen.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Ergebnissatz auf Beitr\u00e4ge mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, denen ein oder mehrere Status zugewiesen sind.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","flamingo-spam","avvia_traduzione","crea_task_resolver","any"],"type":"string"},"required":false},"tax_relation":{"description":"Abfrage-Ergebnis auf Basis der Beziehung zwischen mehreren Taxonomien einschr\u00e4nken.","type":"string","enum":["AND","OR"],"required":false},"tags":{"description":"Ergebnissatz auf Elemente beschr\u00e4nken, denen bestimmte Begriffe in der Taxonomie tags zugewiesen sind.","type":["object","array"],"oneOf":[{"title":"Begriffs-ID-Liste","description":"Begriffe mit den gelisteten IDs vergleichen.","type":"array","items":{"type":"integer"}},{"title":"Taxonomie-Abfrage nach Begriffs-ID","description":"F\u00fchre eine erweiterte Begriffsabfrage durch.","type":"object","properties":{"terms":{"description":"Begriff-IDs.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Ob Elemente allen oder beliebigen festgelegten Begriffen zugewiesen sein m\u00fcssen.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"tags_exclude":{"description":"Ergebnissatz auf Elemente beschr\u00e4nken, au\u00dfer auf solche, denen bestimmte Begriffe in der Taxonomie tags zugewiesen sind.","type":["object","array"],"oneOf":[{"title":"Begriffs-ID-Liste","description":"Begriffe mit den gelisteten IDs vergleichen.","type":"array","items":{"type":"integer"}},{"title":"Taxonomie-Abfrage nach Begriffs-ID","description":"F\u00fchre eine erweiterte Begriffsabfrage durch.","type":"object","properties":{"terms":{"description":"Begriff-IDs.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"portfolio_entries":{"description":"Ergebnissatz auf Elemente beschr\u00e4nken, denen bestimmte Begriffe in der Taxonomie portfolio_entries zugewiesen sind.","type":["object","array"],"oneOf":[{"title":"Begriffs-ID-Liste","description":"Begriffe mit den gelisteten IDs vergleichen.","type":"array","items":{"type":"integer"}},{"title":"Taxonomie-Abfrage nach Begriffs-ID","description":"F\u00fchre eine erweiterte Begriffsabfrage durch.","type":"object","properties":{"terms":{"description":"Begriff-IDs.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Ob untergeordnete Begriffe in Begriffe, welche die Ergebnismenge begrenzen, mit einbezogen werden sollen.","type":"boolean","default":false},"operator":{"description":"Ob Elemente allen oder beliebigen festgelegten Begriffen zugewiesen sein m\u00fcssen.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"portfolio_entries_exclude":{"description":"Ergebnissatz auf Elemente beschr\u00e4nken, au\u00dfer auf solche, denen bestimmte Begriffe in der Taxonomie portfolio_entries zugewiesen sind.","type":["object","array"],"oneOf":[{"title":"Begriffs-ID-Liste","description":"Begriffe mit den gelisteten IDs vergleichen.","type":"array","items":{"type":"integer"}},{"title":"Taxonomie-Abfrage nach Begriffs-ID","description":"F\u00fchre eine erweiterte Begriffsabfrage durch.","type":"object","properties":{"terms":{"description":"Begriff-IDs.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Ob untergeordnete Begriffe in Begriffe, welche die Ergebnismenge begrenzen, mit einbezogen werden sollen.","type":"boolean","default":false}},"additionalProperties":false}],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","avvia_traduzione","crea_task_resolver"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Beitrags.","type":"integer","required":false},"excerpt":{"description":"Der Textauszug f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Textauszug f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Textauszug f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Ob der Textauszug durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"Die ID des hervorgehobenen Mediums f\u00fcr den Beitrag.","type":"integer","required":false},"comment_status":{"description":"Ob Kommentare f\u00fcr den Beitrag ge\u00f6ffnet sind oder nicht.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Ob der Beitrag gepingt werden kann oder nicht.","type":"string","enum":["open","closed"],"required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"_yoast_wpseo_focuskw":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_metadesc":{"type":"string","title":"","description":"","default":""},"_data_scadenza_evento":{"type":"string","title":"","description":"","default":""},"_evento_nome":{"type":"string","title":"","description":"","default":""},"_evento_data":{"type":"string","title":"","description":"","default":""},"_evento_luogo":{"type":"string","title":"","description":"","default":""},"_evento_cta":{"type":"string","title":"","description":"","default":""},"keyword_en":{"type":"string","title":"","description":"","default":""},"keyword_es":{"type":"string","title":"","description":"","default":""},"keyword_fr":{"type":"string","title":"","description":"","default":""},"keyword_de":{"type":"string","title":"","description":"","default":""},"keyword_ptb":{"type":"string","title":"","description":"","default":""},"_note_content":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false},"tags":{"description":"Die Begriffe, die dem Beitrag in der Taxonomie post_tag zugewiesen sind.","type":"array","items":{"type":"integer"},"required":false},"portfolio_entries":{"description":"Die Begriffe, die dem Beitrag in der Taxonomie portfolio_entries zugewiesen sind.","type":"array","items":{"type":"integer"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/wp\/v2\/portfolio"}]}},"\/wp\/v2\/portfolio\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"Setzt die Standardl\u00e4nge des Textauszugs au\u00dfer Kraft.","type":"integer","required":false},"password":{"description":"Das Passwort f\u00fcr den Beitrag, falls dieser passwortgesch\u00fctzt ist.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","avvia_traduzione","crea_task_resolver"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Beitrags.","type":"integer","required":false},"excerpt":{"description":"Der Textauszug f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Textauszug f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Textauszug f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Ob der Textauszug durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"Die ID des hervorgehobenen Mediums f\u00fcr den Beitrag.","type":"integer","required":false},"comment_status":{"description":"Ob Kommentare f\u00fcr den Beitrag ge\u00f6ffnet sind oder nicht.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Ob der Beitrag gepingt werden kann oder nicht.","type":"string","enum":["open","closed"],"required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"_yoast_wpseo_focuskw":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_metadesc":{"type":"string","title":"","description":"","default":""},"_data_scadenza_evento":{"type":"string","title":"","description":"","default":""},"_evento_nome":{"type":"string","title":"","description":"","default":""},"_evento_data":{"type":"string","title":"","description":"","default":""},"_evento_luogo":{"type":"string","title":"","description":"","default":""},"_evento_cta":{"type":"string","title":"","description":"","default":""},"keyword_en":{"type":"string","title":"","description":"","default":""},"keyword_es":{"type":"string","title":"","description":"","default":""},"keyword_fr":{"type":"string","title":"","description":"","default":""},"keyword_de":{"type":"string","title":"","description":"","default":""},"keyword_ptb":{"type":"string","title":"","description":"","default":""},"_note_content":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false},"tags":{"description":"Die Begriffe, die dem Beitrag in der Taxonomie post_tag zugewiesen sind.","type":"array","items":{"type":"integer"},"required":false},"portfolio_entries":{"description":"Die Begriffe, die dem Beitrag in der Taxonomie portfolio_entries zugewiesen sind.","type":"array","items":{"type":"integer"},"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ob der Papierkorb umgangen und die L\u00f6schung erzwungen werden soll.","required":false}}}]},"\/wp\/v2\/portfolio\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Revision.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Die Sammlung nach Objektattribut sortieren.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/portfolio\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Revision.","type":"integer","required":false},"id":{"description":"Eindeutige Kennung f\u00fcr die Revision.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Revision.","type":"integer","required":false},"id":{"description":"Eindeutige Kennung f\u00fcr die Revision.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Setzen auf true erforderlich, denn Revisionen k\u00f6nnen nicht in den Papierkorb gelegt werden.","required":false}}}]},"\/wp\/v2\/portfolio\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","avvia_traduzione","crea_task_resolver"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Beitrags.","type":"integer","required":false},"excerpt":{"description":"Der Textauszug f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Textauszug f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Textauszug f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Ob der Textauszug durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"Die ID des hervorgehobenen Mediums f\u00fcr den Beitrag.","type":"integer","required":false},"comment_status":{"description":"Ob Kommentare f\u00fcr den Beitrag ge\u00f6ffnet sind oder nicht.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Ob der Beitrag gepingt werden kann oder nicht.","type":"string","enum":["open","closed"],"required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"_yoast_wpseo_focuskw":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_metadesc":{"type":"string","title":"","description":"","default":""},"_data_scadenza_evento":{"type":"string","title":"","description":"","default":""},"_evento_nome":{"type":"string","title":"","description":"","default":""},"_evento_data":{"type":"string","title":"","description":"","default":""},"_evento_luogo":{"type":"string","title":"","description":"","default":""},"_evento_cta":{"type":"string","title":"","description":"","default":""},"keyword_en":{"type":"string","title":"","description":"","default":""},"keyword_es":{"type":"string","title":"","description":"","default":""},"keyword_fr":{"type":"string","title":"","description":"","default":""},"keyword_de":{"type":"string","title":"","description":"","default":""},"keyword_ptb":{"type":"string","title":"","description":"","default":""},"_note_content":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false},"tags":{"description":"Die Begriffe, die dem Beitrag in der Taxonomie post_tag zugewiesen sind.","type":"array","items":{"type":"integer"},"required":false},"portfolio_entries":{"description":"Die Begriffe, die dem Beitrag in der Taxonomie portfolio_entries zugewiesen sind.","type":"array","items":{"type":"integer"},"required":false}}}]},"\/wp\/v2\/portfolio\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"id":{"description":"Die ID f\u00fcr die automatische Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/types":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/wp\/v2\/types"}]}},"\/wp\/v2\/types\/(?P<type>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"type":{"description":"Eine alphanumerische Kennung f\u00fcr den Inhaltstyp.","type":"string","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/statuses":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/wp\/v2\/statuses"}]}},"\/wp\/v2\/statuses\/(?P<status>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"status":{"description":"Eine alphanumerische Kennung f\u00fcr den Status.","type":"string","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/taxonomies":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"type":{"description":"Ergebnisse auf Taxonomien begrenzen, die einem bestimmten Inhaltstyp zugeordnet sind.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/wp\/v2\/taxonomies"}]}},"\/wp\/v2\/taxonomies\/(?P<taxonomy>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"taxonomy":{"description":"Eine alphanumerische Kennung f\u00fcr die Taxonomie.","type":"string","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/categories":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sammlung nach Begriffsattribut sortieren.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Ob Begriffe ausgeblendet werden sollen, die keinen Beitr\u00e4gen zugewiesen sind.","type":"boolean","default":false,"required":false},"parent":{"description":"Den Ergebnissatz auf Begriffe begrenzen, die einem bestimmten \u00fcbergeordneten Objekt zugewiesen sind.","type":"integer","required":false},"post":{"description":"Ergebnissatz auf Begriffe begrenzen, die einem bestimmten Beitrag zugewiesen sind.","type":"integer","default":null,"required":false},"slug":{"description":"Ergebnissatz auf Begriffe mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"HTML-Beschreibung des Begriffs.","type":"string","required":false},"name":{"description":"HTML-Titel f\u00fcr den Begriff.","type":"string","required":true},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Begriff, die eindeutig f\u00fcr ihren Typ ist.","type":"string","required":false},"parent":{"description":"Die ID des \u00fcbergeordneten Begriffs.","type":"integer","required":false},"meta":{"description":"Metafelder.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/wp\/v2\/categories"}]}},"\/wp\/v2\/categories\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Begriff.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Begriff.","type":"integer","required":false},"description":{"description":"HTML-Beschreibung des Begriffs.","type":"string","required":false},"name":{"description":"HTML-Titel f\u00fcr den Begriff.","type":"string","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Begriff, die eindeutig f\u00fcr ihren Typ ist.","type":"string","required":false},"parent":{"description":"Die ID des \u00fcbergeordneten Begriffs.","type":"integer","required":false},"meta":{"description":"Metafelder.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Begriff.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Setzen auf true erforderlich, denn Begriffe k\u00f6nnen nicht in den Papierkorb gelegt werden.","required":false}}}]},"\/wp\/v2\/tags":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sammlung nach Begriffsattribut sortieren.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Ob Begriffe ausgeblendet werden sollen, die keinen Beitr\u00e4gen zugewiesen sind.","type":"boolean","default":false,"required":false},"post":{"description":"Ergebnissatz auf Begriffe begrenzen, die einem bestimmten Beitrag zugewiesen sind.","type":"integer","default":null,"required":false},"slug":{"description":"Ergebnissatz auf Begriffe mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"HTML-Beschreibung des Begriffs.","type":"string","required":false},"name":{"description":"HTML-Titel f\u00fcr den Begriff.","type":"string","required":true},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Begriff, die eindeutig f\u00fcr ihren Typ ist.","type":"string","required":false},"meta":{"description":"Metafelder.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/wp\/v2\/tags"}]}},"\/wp\/v2\/tags\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Begriff.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Begriff.","type":"integer","required":false},"description":{"description":"HTML-Beschreibung des Begriffs.","type":"string","required":false},"name":{"description":"HTML-Titel f\u00fcr den Begriff.","type":"string","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Begriff, die eindeutig f\u00fcr ihren Typ ist.","type":"string","required":false},"meta":{"description":"Metafelder.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Begriff.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Setzen auf true erforderlich, denn Begriffe k\u00f6nnen nicht in den Papierkorb gelegt werden.","required":false}}}]},"\/wp\/v2\/menus":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sammlung nach Begriffsattribut sortieren.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Ob Begriffe ausgeblendet werden sollen, die keinen Beitr\u00e4gen zugewiesen sind.","type":"boolean","default":false,"required":false},"post":{"description":"Ergebnissatz auf Begriffe begrenzen, die einem bestimmten Beitrag zugewiesen sind.","type":"integer","default":null,"required":false},"slug":{"description":"Ergebnissatz auf Begriffe mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"HTML-Beschreibung des Begriffs.","type":"string","required":false},"name":{"description":"HTML-Titel f\u00fcr den Begriff.","type":"string","required":true},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Begriff, die eindeutig f\u00fcr ihren Typ ist.","type":"string","required":false},"meta":{"description":"Metafelder.","type":"object","properties":[],"required":false},"locations":{"description":"Die dem Men\u00fc zugeordneten Positionen.","type":"array","items":{"type":"string"},"required":false},"auto_add":{"description":"Ob Seiten der obersten Ebene automatisch zu diesem Men\u00fc hinzugef\u00fcgt werden sollen.","type":"boolean","required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/wp\/v2\/menus"}]}},"\/wp\/v2\/menus\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Begriff.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Begriff.","type":"integer","required":false},"description":{"description":"HTML-Beschreibung des Begriffs.","type":"string","required":false},"name":{"description":"HTML-Titel f\u00fcr den Begriff.","type":"string","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Begriff, die eindeutig f\u00fcr ihren Typ ist.","type":"string","required":false},"meta":{"description":"Metafelder.","type":"object","properties":[],"required":false},"locations":{"description":"Die dem Men\u00fc zugeordneten Positionen.","type":"array","items":{"type":"string"},"required":false},"auto_add":{"description":"Ob Seiten der obersten Ebene automatisch zu diesem Men\u00fc hinzugef\u00fcgt werden sollen.","type":"boolean","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Begriff.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Setzen auf true erforderlich, denn Begriffe k\u00f6nnen nicht in den Papierkorb gelegt werden.","required":false}}}]},"\/wp\/v2\/wp_pattern_category":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sammlung nach Begriffsattribut sortieren.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Ob Begriffe ausgeblendet werden sollen, die keinen Beitr\u00e4gen zugewiesen sind.","type":"boolean","default":false,"required":false},"post":{"description":"Ergebnissatz auf Begriffe begrenzen, die einem bestimmten Beitrag zugewiesen sind.","type":"integer","default":null,"required":false},"slug":{"description":"Ergebnissatz auf Begriffe mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"HTML-Beschreibung des Begriffs.","type":"string","required":false},"name":{"description":"HTML-Titel f\u00fcr den Begriff.","type":"string","required":true},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Begriff, die eindeutig f\u00fcr ihren Typ ist.","type":"string","required":false},"meta":{"description":"Metafelder.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/wp\/v2\/wp_pattern_category"}]}},"\/wp\/v2\/wp_pattern_category\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Begriff.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Begriff.","type":"integer","required":false},"description":{"description":"HTML-Beschreibung des Begriffs.","type":"string","required":false},"name":{"description":"HTML-Titel f\u00fcr den Begriff.","type":"string","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Begriff, die eindeutig f\u00fcr ihren Typ ist.","type":"string","required":false},"meta":{"description":"Metafelder.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Begriff.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Setzen auf true erforderlich, denn Begriffe k\u00f6nnen nicht in den Papierkorb gelegt werden.","required":false}}}]},"\/wp\/v2\/portfolio_entries":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sammlung nach Begriffsattribut sortieren.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Ob Begriffe ausgeblendet werden sollen, die keinen Beitr\u00e4gen zugewiesen sind.","type":"boolean","default":false,"required":false},"parent":{"description":"Den Ergebnissatz auf Begriffe begrenzen, die einem bestimmten \u00fcbergeordneten Objekt zugewiesen sind.","type":"integer","required":false},"post":{"description":"Ergebnissatz auf Begriffe begrenzen, die einem bestimmten Beitrag zugewiesen sind.","type":"integer","default":null,"required":false},"slug":{"description":"Ergebnissatz auf Begriffe mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"HTML-Beschreibung des Begriffs.","type":"string","required":false},"name":{"description":"HTML-Titel f\u00fcr den Begriff.","type":"string","required":true},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Begriff, die eindeutig f\u00fcr ihren Typ ist.","type":"string","required":false},"parent":{"description":"Die ID des \u00fcbergeordneten Begriffs.","type":"integer","required":false},"meta":{"description":"Metafelder.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/wp\/v2\/portfolio_entries"}]}},"\/wp\/v2\/portfolio_entries\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Begriff.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Begriff.","type":"integer","required":false},"description":{"description":"HTML-Beschreibung des Begriffs.","type":"string","required":false},"name":{"description":"HTML-Titel f\u00fcr den Begriff.","type":"string","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Begriff, die eindeutig f\u00fcr ihren Typ ist.","type":"string","required":false},"parent":{"description":"Die ID des \u00fcbergeordneten Begriffs.","type":"integer","required":false},"meta":{"description":"Metafelder.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Begriff.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Setzen auf true erforderlich, denn Begriffe k\u00f6nnen nicht in den Papierkorb gelegt werden.","required":false}}}]},"\/wp\/v2\/users":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"default":"asc","description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","enum":["asc","desc"],"type":"string","required":false},"orderby":{"default":"name","description":"Sammlung nach Benutzerattribut sortieren.","enum":["id","include","name","registered_date","slug","include_slugs","email","url"],"type":"string","required":false},"slug":{"description":"Ergebnissatz auf Benutzer mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"},"required":false},"roles":{"description":"Ergebnissatz auf Benutzer begrenzen, die mindestens einer bestimmten Rolle entsprechen. Akzeptiert eine CSV-Liste oder eine einzelne Rolle.","type":"array","items":{"type":"string"},"required":false},"capabilities":{"description":"Den Ergebnissatz auf Benutzer begrenzen, die mindestens eine bestimmte angegebene Berechtigung haben. Akzeptiert werden eine CSV-Liste oder eine einzelne Berechtigung.","type":"array","items":{"type":"string"},"required":false},"who":{"description":"Ergebnissatz auf Benutzer begrenzen, die als Autoren gelten.","type":"string","enum":["authors"],"required":false},"has_published_posts":{"description":"Den Ergebnissatz auf Benutzer begrenzen, die Beitr\u00e4ge ver\u00f6ffentlicht haben.","type":["boolean","array"],"items":{"type":"string","enum":{"post":"post","page":"page","attachment":"attachment","nav_menu_item":"nav_menu_item","wp_block":"wp_block","wp_template":"wp_template","wp_template_part":"wp_template_part","wp_global_styles":"wp_global_styles","wp_navigation":"wp_navigation","wp_font_family":"wp_font_family","wp_font_face":"wp_font_face","portfolio":"portfolio"}},"required":false},"search_columns":{"default":[],"description":"Array mit den zu durchsuchenden Spaltennamen.","type":"array","items":{"enum":["email","name","id","username","slug"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"username":{"description":"Anmeldename f\u00fcr den Benutzer.","type":"string","required":true},"name":{"description":"Der Anzeigename f\u00fcr den Benutzer.","type":"string","required":false},"first_name":{"description":"Vorname f\u00fcr den Benutzer.","type":"string","required":false},"last_name":{"description":"Nachname f\u00fcr den Benutzer.","type":"string","required":false},"email":{"description":"Die E-Mail-Adresse f\u00fcr den Benutzer.","type":"string","format":"email","required":true},"url":{"description":"Die URL des Benutzers.","type":"string","format":"uri","required":false},"description":{"description":"Die Beschreibung des Benutzers.","type":"string","required":false},"locale":{"description":"Sprachumgebung f\u00fcr den Benutzer.","type":"string","enum":["","en_US","de_DE","en_GB","es_ES","fr_FR","it_IT","pt_BR"],"required":false},"nickname":{"description":"Der Spitzname f\u00fcr den Benutzer.","type":"string","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Benutzer.","type":"string","required":false},"roles":{"description":"Rollen, die dem Benutzer zugewiesen sind.","type":"array","items":{"type":"string"},"required":false},"password":{"description":"Passwort f\u00fcr den Benutzer (nie enthalten).","type":"string","required":true},"meta":{"description":"Metafelder.","type":"object","properties":{"persisted_preferences":{"type":"object","title":"","description":"","default":[],"context":["edit"],"properties":{"_modified":{"description":"Das Datum und die Uhrzeit der Aktualisierung der Einstellungen.","type":"string","format":"date-time","readonly":false}},"additionalProperties":true}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/wp\/v2\/users"}]}},"\/wp\/v2\/users\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Benutzer.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Benutzer.","type":"integer","required":false},"username":{"description":"Anmeldename f\u00fcr den Benutzer.","type":"string","required":false},"name":{"description":"Der Anzeigename f\u00fcr den Benutzer.","type":"string","required":false},"first_name":{"description":"Vorname f\u00fcr den Benutzer.","type":"string","required":false},"last_name":{"description":"Nachname f\u00fcr den Benutzer.","type":"string","required":false},"email":{"description":"Die E-Mail-Adresse f\u00fcr den Benutzer.","type":"string","format":"email","required":false},"url":{"description":"Die URL des Benutzers.","type":"string","format":"uri","required":false},"description":{"description":"Die Beschreibung des Benutzers.","type":"string","required":false},"locale":{"description":"Sprachumgebung f\u00fcr den Benutzer.","type":"string","enum":["","en_US","de_DE","en_GB","es_ES","fr_FR","it_IT","pt_BR"],"required":false},"nickname":{"description":"Der Spitzname f\u00fcr den Benutzer.","type":"string","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Benutzer.","type":"string","required":false},"roles":{"description":"Rollen, die dem Benutzer zugewiesen sind.","type":"array","items":{"type":"string"},"required":false},"password":{"description":"Passwort f\u00fcr den Benutzer (nie enthalten).","type":"string","required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"persisted_preferences":{"type":"object","title":"","description":"","default":[],"context":["edit"],"properties":{"_modified":{"description":"Das Datum und die Uhrzeit der Aktualisierung der Einstellungen.","type":"string","format":"date-time","readonly":false}},"additionalProperties":true}},"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Benutzer.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Setzen auf true erforderlich, denn Benutzer k\u00f6nnen nicht in den Papierkorb gelegt werden.","required":false},"reassign":{"type":"integer","description":"Die Beitr\u00e4ge und Links des gel\u00f6schten Benutzers dieser Benutzer-ID neu zuweisen.","required":true}}}]},"\/wp\/v2\/users\/me":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"username":{"description":"Anmeldename f\u00fcr den Benutzer.","type":"string","required":false},"name":{"description":"Der Anzeigename f\u00fcr den Benutzer.","type":"string","required":false},"first_name":{"description":"Vorname f\u00fcr den Benutzer.","type":"string","required":false},"last_name":{"description":"Nachname f\u00fcr den Benutzer.","type":"string","required":false},"email":{"description":"Die E-Mail-Adresse f\u00fcr den Benutzer.","type":"string","format":"email","required":false},"url":{"description":"Die URL des Benutzers.","type":"string","format":"uri","required":false},"description":{"description":"Die Beschreibung des Benutzers.","type":"string","required":false},"locale":{"description":"Sprachumgebung f\u00fcr den Benutzer.","type":"string","enum":["","en_US","de_DE","en_GB","es_ES","fr_FR","it_IT","pt_BR"],"required":false},"nickname":{"description":"Der Spitzname f\u00fcr den Benutzer.","type":"string","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Benutzer.","type":"string","required":false},"roles":{"description":"Rollen, die dem Benutzer zugewiesen sind.","type":"array","items":{"type":"string"},"required":false},"password":{"description":"Passwort f\u00fcr den Benutzer (nie enthalten).","type":"string","required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"persisted_preferences":{"type":"object","title":"","description":"","default":[],"context":["edit"],"properties":{"_modified":{"description":"Das Datum und die Uhrzeit der Aktualisierung der Einstellungen.","type":"string","format":"date-time","readonly":false}},"additionalProperties":true}},"required":false}}},{"methods":["DELETE"],"args":{"force":{"type":"boolean","default":false,"description":"Setzen auf true erforderlich, denn Benutzer k\u00f6nnen nicht in den Papierkorb gelegt werden.","required":false},"reassign":{"type":"integer","description":"Die Beitr\u00e4ge und Links des gel\u00f6schten Benutzers dieser Benutzer-ID neu zuweisen.","required":true}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/wp\/v2\/users\/me"}]}},"\/wp\/v2\/users\/(?P<user_id>(?:[\\d]+|me))\/application-passwords":{"namespace":"wp\/v2","methods":["GET","POST","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"app_id":{"description":"Eine UUID, die von der Anwendung bereitgestellt wird, um sie eindeutig zu identifizieren. Es wird empfohlen, eine UUID\u00a0v5 mit dem URL- oder DNS-Namensraum zu verwenden.","type":"string","oneOf":[{"type":"string","format":"uuid"},{"type":"string","enum":[""]}],"required":false},"name":{"description":"Der Name des Anwendungspassworts.","type":"string","minLength":1,"pattern":".*\\S.*","required":true}}},{"methods":["DELETE"],"args":[]}]},"\/wp\/v2\/users\/(?P<user_id>(?:[\\d]+|me))\/application-passwords\/introspect":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/users\/(?P<user_id>(?:[\\d]+|me))\/application-passwords\/(?P<uuid>[\\w\\-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"app_id":{"description":"Eine UUID, die von der Anwendung bereitgestellt wird, um sie eindeutig zu identifizieren. Es wird empfohlen, eine UUID\u00a0v5 mit dem URL- oder DNS-Namensraum zu verwenden.","type":"string","oneOf":[{"type":"string","format":"uuid"},{"type":"string","enum":[""]}],"required":false},"name":{"description":"Der Name des Anwendungspassworts.","type":"string","minLength":1,"pattern":".*\\S.*","required":false}}},{"methods":["DELETE"],"args":[]}]},"\/wp\/v2\/comments":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"after":{"description":"Antwort auf Kommentare einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"author":{"description":"Ergebnissatz auf Kommentare begrenzen, denen bestimmte Benutzer-IDs zugewiesen sind. Erfordert eine Autorisierung.","type":"array","items":{"type":"integer"},"required":false},"author_exclude":{"description":"Sicherstellen, dass der Ergebnissatz Kommentare ausschlie\u00dft, die bestimmten Benutzer-IDs zugewiesen sind. Erfordert eine Autorisierung.","type":"array","items":{"type":"integer"},"required":false},"author_email":{"default":null,"description":"Den Ergebnissatz auf den einer speziellen E-Mail-Adresse eines Autors begrenzen. Erfordert eine Autorisierung.","format":"email","type":"string","required":false},"before":{"description":"Antwort auf Kommentare einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sammlung nach Kommentarattribut sortieren.","type":"string","default":"date_gmt","enum":["date","date_gmt","id","include","post","parent","type"],"required":false},"parent":{"default":[],"description":"Den Ergebnissatz auf Kommentare bestimmter \u00fcbergeordneter IDs begrenzen.","type":"array","items":{"type":"integer"},"required":false},"parent_exclude":{"default":[],"description":"Sicherstellen, dass der Ergebnissatz bestimmte \u00fcbergeordnete IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"required":false},"post":{"default":[],"description":"Ergebnissatz auf Kommentare begrenzen, die bestimmten Beitrags-IDs zugewiesen sind.","type":"array","items":{"type":"integer"},"required":false},"status":{"default":"approve","description":"Ergebnissatz auf Kommentare begrenzen, denen ein bestimmter Status zugewiesen ist. Erfordert eine Autorisierung.","type":"string","required":false},"type":{"default":"comment","description":"Ergebnissatz auf Kommentare begrenzen, denen ein bestimmter Typ zugewiesen ist. Erfordert eine Autorisierung.","type":"string","required":false},"password":{"description":"Das Passwort f\u00fcr den Beitrag, falls dieser passwortgesch\u00fctzt ist.","type":"string","required":false}}},{"methods":["POST"],"args":{"author":{"description":"Die ID des Benutzerobjekts, falls der Autor ein Benutzer war.","type":"integer","required":false},"author_email":{"description":"E-Mail-Adresse f\u00fcr den Autor des Kommentars.","type":"string","format":"email","required":false},"author_ip":{"description":"IP-Adresse f\u00fcr den Autor des Kommentars.","type":"string","format":"ip","required":false},"author_name":{"description":"Der Anzeigename f\u00fcr den Kommentarautor.","type":"string","required":false},"author_url":{"description":"URL f\u00fcr den Autor des Kommentars.","type":"string","format":"uri","required":false},"author_user_agent":{"description":"User Agent f\u00fcr den Autor des Kommentars.","type":"string","required":false},"content":{"description":"Der Inhalt f\u00fcr den Kommentar.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Kommentar, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Kommentar, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"date":{"description":"Datum, an dem der Kommentar ver\u00f6ffentlicht wurde, in der Zeitzone der Website.","type":"string","format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Kommentar ver\u00f6ffentlicht wurde.","type":"string","format":"date-time","required":false},"parent":{"default":0,"description":"Die ID f\u00fcr den \u00fcbergeordneten Kommentar.","type":"integer","required":false},"post":{"default":0,"description":"Die ID des zugeordneten Beitragsobjekts.","type":"integer","required":false},"status":{"description":"Status des Kommentars.","type":"string","required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"_wp_note_status":{"type":"string","title":"","description":"Status der Anmerkung","default":"","enum":["resolved","reopen"]}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/wp\/v2\/comments"}]}},"\/wp\/v2\/comments\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Kommentar.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"Das Passwort f\u00fcr den \u00fcbergeordneten Beitrag des Kommentars (wenn der Beitrag passwortgesch\u00fctzt ist).","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Kommentar.","type":"integer","required":false},"author":{"description":"Die ID des Benutzerobjekts, falls der Autor ein Benutzer war.","type":"integer","required":false},"author_email":{"description":"E-Mail-Adresse f\u00fcr den Autor des Kommentars.","type":"string","format":"email","required":false},"author_ip":{"description":"IP-Adresse f\u00fcr den Autor des Kommentars.","type":"string","format":"ip","required":false},"author_name":{"description":"Der Anzeigename f\u00fcr den Kommentarautor.","type":"string","required":false},"author_url":{"description":"URL f\u00fcr den Autor des Kommentars.","type":"string","format":"uri","required":false},"author_user_agent":{"description":"User Agent f\u00fcr den Autor des Kommentars.","type":"string","required":false},"content":{"description":"Der Inhalt f\u00fcr den Kommentar.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Kommentar, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Kommentar, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"date":{"description":"Datum, an dem der Kommentar ver\u00f6ffentlicht wurde, in der Zeitzone der Website.","type":"string","format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Kommentar ver\u00f6ffentlicht wurde.","type":"string","format":"date-time","required":false},"parent":{"description":"Die ID f\u00fcr den \u00fcbergeordneten Kommentar.","type":"integer","required":false},"post":{"description":"Die ID des zugeordneten Beitragsobjekts.","type":"integer","required":false},"status":{"description":"Status des Kommentars.","type":"string","required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"_wp_note_status":{"type":"string","title":"","description":"Status der Anmerkung","default":"","enum":["resolved","reopen"]}},"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Kommentar.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ob der Papierkorb umgangen und die L\u00f6schung erzwungen werden soll.","required":false},"password":{"description":"Das Passwort f\u00fcr den \u00fcbergeordneten Beitrag des Kommentars (wenn der Beitrag passwortgesch\u00fctzt ist).","type":"string","required":false}}}]},"\/wp\/v2\/search":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"type":{"default":"post","description":"Ergebnisse auf Elemente eines Objekt-Typs beschr\u00e4nken.","type":"string","enum":["post","term","post-format"],"required":false},"subtype":{"default":"any","description":"Ergebnisse auf einen oder mehrere Objekt-Subtypen einschr\u00e4nken.","type":"array","items":{"enum":["post","page","portfolio","category","post_tag","portfolio_entries","any"],"type":"string"},"required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/wp\/v2\/search"}]}},"\/wp\/v2\/block-renderer\/(?P<name>[a-z0-9-]+\/[a-z0-9-]+)":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET","POST"],"args":{"name":{"description":"Eindeutiger registrierter Name f\u00fcr den Block.","type":"string","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["edit"],"default":"view","required":false},"attributes":{"description":"Attribute f\u00fcr den Block.","type":"object","default":[],"required":false},"post_id":{"description":"Die ID des Beitragskontextes.","type":"integer","required":false}}}]},"\/wp\/v2\/block-types":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"namespace":{"description":"Block-Namensraum.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/wp\/v2\/block-types"}]}},"\/wp\/v2\/block-types\/(?P<namespace>[a-zA-Z0-9_-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"namespace":{"description":"Block-Namensraum.","type":"string","required":false}}}]},"\/wp\/v2\/block-types\/(?P<namespace>[a-zA-Z0-9_-]+)\/(?P<name>[a-zA-Z0-9_-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"name":{"description":"Blockname.","type":"string","required":false},"namespace":{"description":"Block-Namensraum.","type":"string","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/settings":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":{"wordpress_api_key":{"title":"API-Schl\u00fcssel f\u00fcr Akismet Anti-Spam","description":"Der API-Schl\u00fcssel f\u00fcr den Konnektor Akismet Anti-Spam.","type":"string","required":false},"title":{"title":"Titel","description":"Website-Titel.","type":"string","required":false},"description":{"title":"Untertitel","description":"Website-Untertitel.","type":"string","required":false},"timezone":{"title":"","description":"Eine Stadt in deiner Zeitzone.","type":"string","required":false},"date_format":{"title":"","description":"Ein Datumsformat f\u00fcr alle datumsbasierten Zeichenfolgen.","type":"string","required":false},"time_format":{"title":"","description":"Ein Zeitformat f\u00fcr alle zeitbasierten Zeichenfolgen.","type":"string","required":false},"start_of_week":{"title":"","description":"Die Zahl eines Wochentages, mit dem die Woche beginnen sollte.","type":"integer","required":false},"language":{"title":"","description":"Der WordPress-Lokalisierungscode.","type":"string","required":false},"use_smilies":{"title":"","description":"Emoticons wie :-) und :-P als Grafiken anzeigen.","type":"boolean","required":false},"default_category":{"title":"","description":"Standard-Beitragskategorie.","type":"integer","required":false},"default_post_format":{"title":"","description":"Standard-Beitragsformat.","type":"string","required":false},"posts_per_page":{"title":"Maximale Beitragsanzahl pro Seite","description":"Maximal angezeigte Beitr\u00e4ge.","type":"integer","required":false},"show_on_front":{"title":"Vorne anzeigen","description":"Was auf der Homepage angezeigt werden soll","type":"string","required":false},"page_on_front":{"title":"Titelseite","description":"Die ID der Seite, die auf der Homepage angezeigt werden soll","type":"integer","required":false},"page_for_posts":{"title":"","description":"Die ID der Seite, auf der die neuesten Beitr\u00e4ge angezeigt werden sollen","type":"integer","required":false},"default_ping_status":{"title":"","description":"Link-Benachrichtigungen von anderen Blogs (Pingbacks und Trackbacks) zu neuen Beitr\u00e4gen erlauben.","type":"string","enum":["open","closed"],"required":false},"default_comment_status":{"title":"Kommentare bei neuen Beitr\u00e4gen erlauben","description":"Erlaubt Personen, neue Beitr\u00e4ge zu kommentieren.","type":"string","enum":["open","closed"],"required":false},"site_logo":{"title":"Logo","description":"Website-Logo.","type":"integer","required":false},"site_icon":{"title":"Icon","description":"Website-Icon.","type":"integer","required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/wp\/v2\/settings"}]}},"\/wp\/v2\/themes":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"status":{"description":"Ergebnissatz auf Themes begrenzen, die einem oder mehreren Status zugewiesen sind.","type":"array","items":{"enum":["active","inactive"],"type":"string"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/wp\/v2\/themes"}]}},"\/wp\/v2\/themes\/(?P<stylesheet>[^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"stylesheet":{"description":"Das Stylesheet des Themes. Dieses identifiziert das Theme eindeutig.","type":"string","required":false}}}]},"\/wp\/v2\/plugins":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"status":{"description":"Beschr\u00e4nkt die Ergebnisse auf Plugins mit dem angegebenen Status.","type":"array","items":{"type":"string","enum":["inactive","active","network-active"]},"required":false}}},{"methods":["POST"],"args":{"slug":{"type":"string","description":"Titelform im WordPress.org-Plugin-Verzeichnis.","pattern":"[\\w\\-]+","required":true},"status":{"description":"Der Aktivierungsstatus des Plugins.","type":"string","enum":["inactive","active","network-active"],"default":"inactive","required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/wp\/v2\/plugins"}]}},"\/wp\/v2\/plugins\/(?P<plugin>[^.\\\/]+(?:\\\/[^.\\\/]+)?)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"plugin":{"type":"string","pattern":"[^.\\\/]+(?:\\\/[^.\\\/]+)?","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"plugin":{"type":"string","pattern":"[^.\\\/]+(?:\\\/[^.\\\/]+)?","required":false},"status":{"description":"Der Aktivierungsstatus des Plugins.","type":"string","enum":["inactive","active","network-active"],"required":false}}},{"methods":["DELETE"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"plugin":{"type":"string","pattern":"[^.\\\/]+(?:\\\/[^.\\\/]+)?","required":false}}}]},"\/wp\/v2\/sidebars":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/wp\/v2\/sidebars"}]}},"\/wp\/v2\/sidebars\/(?P<id>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Die ID einer registrierten Seitenleiste","type":"string","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"widgets":{"description":"Verschachtelte Widgets.","type":"array","items":{"type":["object","string"]},"required":false}}}]},"\/wp\/v2\/widget-types":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/wp\/v2\/widget-types"}]}},"\/wp\/v2\/widget-types\/(?P<id>[a-zA-Z0-9_-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Die Widget-Typ-ID.","type":"string","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/widget-types\/(?P<id>[a-zA-Z0-9_-]+)\/encode":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"Die Widget-Typ-ID.","type":"string","required":true},"instance":{"description":"Aktuelle Instanz-Einstellungen des Widgets.","type":"object","required":false},"form_data":{"description":"Serialisierte Widget-Formulardaten zur Kodierung in Instanz-Einstellungen.","type":"string","required":false}}}]},"\/wp\/v2\/widget-types\/(?P<id>[a-zA-Z0-9_-]+)\/render":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"Die Widget-Typ-ID.","type":"string","required":true},"instance":{"description":"Aktuelle Instanz-Einstellungen des Widgets.","type":"object","required":false}}}]},"\/wp\/v2\/widgets":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"sidebar":{"description":"Die Seitenleiste, f\u00fcr die Widgets zur\u00fcckgegeben werden sollen.","type":"string","required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr das Widget.","type":"string","required":false},"id_base":{"description":"Typ des Widgets. Entspricht der ID im Endpunkt widget-types.","type":"string","required":false},"sidebar":{"default":"wp_inactive_widgets","description":"Die Seitenleiste, zu der das Widget geh\u00f6rt.","type":"string","required":true},"instance":{"description":"Instanz-Einstellungen des Widgets, falls unterst\u00fctzt.","type":"object","properties":{"encoded":{"description":"Base64-kodierte Darstellung der Instanz-Einstellungen.","type":"string","context":["edit"]},"hash":{"description":"Kryptographischer Hash der Instanz-Einstellungen.","type":"string","context":["edit"]},"raw":{"description":"Nicht kodierte Instanz-Einstellungen, falls unterst\u00fctzt.","type":"object","context":["edit"]}},"required":false},"form_data":{"description":"URL-kodierte Formulardaten aus dem Widget-Adminformular. Werden verwendet, um ein Widget zu aktualisieren, das keine Instanz unterst\u00fctzt. Nur Schreibzugriff.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/wp\/v2\/widgets"}]}},"\/wp\/v2\/widgets\/(?P<id>[\\w\\-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr das Widget.","type":"string","required":false},"id_base":{"description":"Typ des Widgets. Entspricht der ID im Endpunkt widget-types.","type":"string","required":false},"sidebar":{"description":"Die Seitenleiste, zu der das Widget geh\u00f6rt.","type":"string","required":false},"instance":{"description":"Instanz-Einstellungen des Widgets, falls unterst\u00fctzt.","type":"object","properties":{"encoded":{"description":"Base64-kodierte Darstellung der Instanz-Einstellungen.","type":"string","context":["edit"]},"hash":{"description":"Kryptographischer Hash der Instanz-Einstellungen.","type":"string","context":["edit"]},"raw":{"description":"Nicht kodierte Instanz-Einstellungen, falls unterst\u00fctzt.","type":"object","context":["edit"]}},"required":false},"form_data":{"description":"URL-kodierte Formulardaten aus dem Widget-Adminformular. Werden verwendet, um ein Widget zu aktualisieren, das keine Instanz unterst\u00fctzt. Nur Schreibzugriff.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"force":{"description":"Ob das Entfernen des Widgets erzwungen werden soll oder ob es in die inaktive Seitenleiste verschoben werden soll.","type":"boolean","required":false}}}]},"\/wp\/v2\/block-directory\/search":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"term":{"description":"Ergebnissatz auf Bl\u00f6cke beschr\u00e4nken, die mit dem Suchbegriff \u00fcbereinstimmen.","type":"string","minLength":1,"required":true}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/wp\/v2\/block-directory\/search"}]}},"\/wp\/v2\/pattern-directory\/patterns":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":100,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","minLength":1,"required":false},"category":{"description":"Ergebnisse auf die beschr\u00e4nken, die mit einer Kategorie-ID \u00fcbereinstimmen.","type":"integer","minimum":1,"required":false},"keyword":{"description":"Ergebnisse auf die beschr\u00e4nken, die mit einer Stichwort-ID \u00fcbereinstimmen.","type":"integer","minimum":1,"required":false},"slug":{"description":"Ergebnisse auf die beschr\u00e4nken, die mit einer Vorlage (Titelform) \u00fcbereinstimmen.","type":"array","required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sammlung nach Beitragsattribut sortieren.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","favorite_count"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/wp\/v2\/pattern-directory\/patterns"}]}},"\/wp\/v2\/block-patterns\/patterns":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/wp\/v2\/block-patterns\/patterns"}]}},"\/wp\/v2\/block-patterns\/categories":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/wp\/v2\/block-patterns\/categories"}]}},"\/wp-site-health\/v1":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp-site-health\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/wp-site-health\/v1"}]}},"\/wp-site-health\/v1\/tests\/background-updates":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/wp-site-health\/v1\/tests\/background-updates"}]}},"\/wp-site-health\/v1\/tests\/loopback-requests":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/wp-site-health\/v1\/tests\/loopback-requests"}]}},"\/wp-site-health\/v1\/tests\/https-status":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/wp-site-health\/v1\/tests\/https-status"}]}},"\/wp-site-health\/v1\/tests\/dotorg-communication":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/wp-site-health\/v1\/tests\/dotorg-communication"}]}},"\/wp-site-health\/v1\/tests\/authorization-header":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/wp-site-health\/v1\/tests\/authorization-header"}]}},"\/wp-site-health\/v1\/directory-sizes":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/wp-site-health\/v1\/directory-sizes"}]}},"\/wp-site-health\/v1\/tests\/page-cache":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/wp-site-health\/v1\/tests\/page-cache"}]}},"\/wp-block-editor\/v1":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp-block-editor\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/wp-block-editor\/v1"}]}},"\/wp-block-editor\/v1\/url-details":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"description":"Zu verarbeitende URL.","type":"string","format":"uri","required":true}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/wp-block-editor\/v1\/url-details"}]}},"\/wp\/v2\/menu-locations":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/wp\/v2\/menu-locations"}]}},"\/wp\/v2\/menu-locations\/(?P<location>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"location":{"description":"Eine alphanumerische Kennung f\u00fcr die Men\u00fcposition.","type":"string","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp-block-editor\/v1\/export":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/wp-block-editor\/v1\/export"}]}},"\/wp-block-editor\/v1\/navigation-fallback":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/wp-block-editor\/v1\/navigation-fallback"}]}},"\/wp\/v2\/font-collections":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/wp\/v2\/font-collections"}]}},"\/wp\/v2\/font-collections\/(?P<slug>[\\\/\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp-abilities\/v1":{"namespace":"wp-abilities\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp-abilities\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/wp-abilities\/v1"}]}},"\/wp-abilities\/v1\/categories":{"namespace":"wp-abilities\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":50,"minimum":1,"maximum":100,"required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/wp-abilities\/v1\/categories"}]}},"\/wp-abilities\/v1\/categories\/(?P<slug>[a-z0-9]+(?:-[a-z0-9]+)*)":{"namespace":"wp-abilities\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"Eine eindeutige Kennung f\u00fcr die F\u00e4higkeitskategorie.","type":"string","pattern":"^[a-z0-9]+(?:-[a-z0-9]+)*$","required":false}}}]},"\/wp-abilities\/v1\/abilities\/(?P<name>[a-zA-Z0-9\\-\\\/]+?)\/run":{"namespace":"wp-abilities\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET","POST","PUT","PATCH","DELETE"],"args":{"name":{"description":"Eindeutige Kennung f\u00fcr die F\u00e4higkeit.","type":"string","pattern":"^[a-zA-Z0-9\\-\\\/]+$","required":false},"input":{"description":"Eingabeparameter f\u00fcr die Ausf\u00fchrung der F\u00e4higkeit.","type":["integer","number","boolean","string","array","object","null"],"default":null,"required":false}}}]},"\/wp-abilities\/v1\/abilities":{"namespace":"wp-abilities\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":50,"minimum":1,"maximum":100,"required":false},"category":{"description":"Die Ergebnisse auf F\u00e4higkeiten einer bestimmten F\u00e4higkeitskategorie begrenzen.","type":"string","required":false},"namespace":{"description":"Ergebnisse auf F\u00e4higkeiten in einem bestimmten Namensraum beschr\u00e4nken.","type":"string","required":false},"meta":{"description":"Ergebnisse auf F\u00e4higkeiten beschr\u00e4nken, die allen angegebenen Meta-Feldern entsprechen.","type":"object","properties":{"annotations":{"description":"Ergebnisse auf F\u00e4higkeiten beschr\u00e4nken, die den angegebenen verhaltensbezogenen Anmerkungen entsprechen.","type":"object","properties":{"readonly":{"description":"Ob die F\u00e4higkeit ihre Umgebung nicht ver\u00e4ndert.","type":["boolean","null"]},"destructive":{"description":"Ob die F\u00e4higkeit destruktive \u00c4nderungen an ihrer Umgebung durchf\u00fchren kann.","type":["boolean","null"]},"idempotent":{"description":"Ob wiederholte Aufrufe mit denselben Argumenten keine zus\u00e4tzliche Auswirkung haben.","type":["boolean","null"]}},"additionalProperties":true}},"additionalProperties":true,"required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/wp-abilities\/v1\/abilities"}]}},"\/wp-abilities\/v1\/abilities\/(?P<name>[a-zA-Z0-9\\-\\\/]+)":{"namespace":"wp-abilities\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"name":{"description":"Eindeutige Kennung f\u00fcr die F\u00e4higkeit.","type":"string","pattern":"^[a-zA-Z0-9\\-\\\/]+$","required":false}}}]},"\/wp\/v2\/icons":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"collection":{"description":"Ergebnisse auf Icons beschr\u00e4nken, die zur angegebenen Sammlungs-Titelform geh\u00f6ren.","type":"string","pattern":"^[a-z0-9]([a-z0-9_-]*[a-z0-9])?$","required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/wp\/v2\/icons"}]}},"\/wp\/v2\/icons\/(?P<collection>[a-z0-9](?:[a-z0-9_-]*[a-z0-9])?)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"collection":{"description":"Ergebnisse auf Icons beschr\u00e4nken, die zur angegebenen Sammlungs-Titelform geh\u00f6ren.","type":"string","pattern":"^[a-z0-9]([a-z0-9_-]*[a-z0-9])?$","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false}}}]},"\/wp\/v2\/icons\/(?P<name>[a-z0-9](?:[a-z0-9_-]*[a-z0-9])?\/[a-z0-9](?:[a-z0-9_-]*[a-z0-9])?)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"name":{"description":"Der Icon-Name.","type":"string","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/icon-collections":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/wp\/v2\/icon-collections"}]}},"\/wp\/v2\/icon-collections\/(?P<slug>[a-z0-9](?:[a-z0-9_-]*[a-z0-9])?)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"Die Titelform der Icon-Sammlung.","type":"string","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/view-config":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"kind":{"description":"Entit\u00e4tsart.","type":"string","required":true},"name":{"description":"Entit\u00e4tsname.","type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/wp\/v2\/view-config"}]}}},"site_logo":0,"site_icon":30793,"site_icon_url":"https:\/\/biblus.accasoftware.com\/de\/wp-content\/uploads\/sites\/6\/2023\/12\/favicon_biblus.webp","_links":{"help":[{"href":"https:\/\/developer.wordpress.org\/rest-api\/"}],"wp:featuredmedia":[{"embeddable":true,"type":"site_icon","href":"https:\/\/biblus.accasoftware.com\/de\/wp-json\/wp\/v2\/media\/30793"}],"curies":[{"name":"wp","href":"https:\/\/api.w.org\/{rel}","templated":true}]}}
