BIM Detailing: Transforming the Information Model into an Executive Project
Discover BIM Detailing and the role of LOD, LOG and LOI in translating the information model into an executive model
BIM Detailing means embedding construction intelligence into the 3D model, enabling errors to be identified and resolved before they turn into cost overruns or schedule delays. Each digital element is transformed into a precise, unambiguous instruction for industrial production and on-site assembly, bridging the gap between design intent and construction reality.
In this article, we explore how the transition from conceptual modeling to executive detailing (LOD 400) is not merely a technical milestone, but a fundamental prerequisite for industrialized, sustainable, and truly efficient construction processes.
We will examine how increasing regulatory rigor and information requirements are redefining the role of the designer—shifting the construction site from a place of uncertainty to one of controlled, predictable, and high-quality execution.
All of this is made possible through structured collaboration within a Common Data Environment (CDE), which enables effective coordination, information management, and traceability across all stakeholders involved in the design and delivery of a project.
The tools and methodologies for an efficient and scalable BIM
- What is BIM detailing and why is it central to contemporary design
- From the conceptual model to executive detailing: development levels and information
- Tools and methods for efficient and scalable BIM detailing
- Regulations and standards influencing the level of detail
- Practical Guide: how to correctly set up BIM detailing in a project
- FAQ on BIM Detailing
BIM Detailing is the process of geometric and informational refinement that elevates a digital model from a representation of intent (Design Intent) to an operational guide for production and assembly. If architectural modeling defines “what” we are building, detailing establishes “how” each individual component will interact with others on site.
Today it is central because the complexity of modern buildings and stringent contractual timelines no longer allow for improvisation during installation. Without accurate detailing, BIM remains an unfulfilled promise; with it, it becomes the tool to eliminate uncertainty.
Operational meaning of BIM detailing: the bridge between the technical office and the construction site
Operationally, BIM detailing acts as a universal translator. It translates the performance requirements of the architectural and structural project into unique instructions for the workforce and for CNC (Computer Numerical Control) machines.
At this stage, the model is enriched with minute but critical details: bolted connections, reinforcement bars, brackets for MEP systems, gaskets, and assembly tolerances. This flow of information eliminates the subjective interpretations of the worker or site manager, shifting conflict resolution (clash detection) from the physical environment, where mistakes are costly, to the virtual environment, where mistakes are an opportunity for optimization.
Difference between BIM modeling (Design-Intent) and detailing phase (Construction-Ready)
It is essential to distinguish between what is beautiful and what is buildable. The difference mainly lies in the Level of Development (LOD) of the elements:
- Design-Intent (intent modeling) – typical of preliminary and definitive phases (LOD 200-300). Here, the elements represent footprints, theoretical stratifications, and spatial placements. The goal is general coordination and volume calculations;
- Construction-Ready (detailing) – this is the executive and construction phase (LOD 400-500). Here, the wall is no longer a homogeneous parallelepiped, but a collection of metal profiles, cladding panels, insulation with related fastening systems and accessories.
While the intent model says: “There will be a continuous facade here,” the detailing model specifies every anchoring bracket to the slab, every EPDM gasket, and the exact sequence of assembly of the studs.
From 3D to prefabrication: the impact on waste reduction
BIM Detailing is the fundamental prerequisite for DfMA (Design for Manufacturing and Assembly). When the model is detailed to the millimeter, it is possible to send the data directly to prefabrication factories.
This approach generates a massive impact on sustainability and the economy of the project through:
- material optimization – the more detailed calculation of waste (for example, for rebar or CLT wood panels) allows for orders with a greater degree of precision, reducing waste produced on site;
- Just-in-Time logistics – components arrive on site ready to be installed, eliminating the need for on-site processing (cuts, welds), which are inherently less precise and more dangerous;
- reduction of downtime – every prefabricated component based on BIM detailing fits perfectly with adjacent ones, speeding up the installation speed compared to traditional methods.
Preventing errors thanks to BIM Detailing
If BIM Detailing is the process, its “measuring stick” is represented by the maturity levels of the model. It is not just about adding lines or polygons, but about layering technical awareness on every single digital object, transforming a spatial idea into an entity ready for production.
LOD, LOG, and LOI: how expectations change regarding the informational model
In technical language, we often talk about LOD (Level of Development), but for professional detailing, it is essential to split the concept into its two fundamental aspects, as provided by the UNI 11337 standard and the ISO 19650 standards.
On one side, we find LOG (Level of Geometry), which defines geometric accuracy: moving from LOG 300 to 400 means, for example, stopping modeling a beam as a continuous solid and starting to represent the end plates, bolt holes, and actual welds.
On the other side, we develop LOI (Level of Information), which refers to the set of metadata. In the detailing phase, this informational component explodes in complexity: the object no longer simply states “Steel S355,” but is enriched with data about the manufacturer, batch number, surface treatments such as galvanizing, and even the torque values for the bolts. Expectations, therefore, change radically.
When the level of detail is “sufficient” and when it is excessive (Model Weight Management)
One of the most common mistakes in BIM Detailing is over-modeling, that is, the tendency to include every single screw or washer with actual threading in the model, risking making the file unmanageable and saturating hardware resources without adding real value. The golden rule of the experienced BIM Manager suggests modeling only what needs to be actually coordinated, quantified, or manufactured.
In this sense, a detail is considered sufficient when it allows verifying that a flange does not collide with a column, but becomes excessive if it goes as far as representing the internal threading of the bolts. Model Weight Management thus becomes the art of balancing informational richness and software performance, often preferring the use of informational parameters (LOI) for small components instead of unnecessarily burdening the geometric database (LOG). A fluid model is a working tool, while a heavy model is just an obstacle to productivity.
BIM detailing and data reliability: ensuring consistency between quantity take-off and construction site
The significant leap in quality of BIM Detailing is directly reflected in the Quantity Take-Off (QTO). In a traditional project, the quantity take-off is often based on estimates or flat measurements derived from 2D drawings, while with detailing, the take-off becomes a direct and rigorous extraction from the virtual reality. This reliability ensures that quantities are certain, avoiding “forgotten items” that cause variations during the work.
Moreover, the total consistency between the model and the contract documents eliminates the disconnect between the drawing delivered to the carpenter and the materials list in the purchasing office, as both draw from the same Single Source of Truth. This approach makes procurement extremely lean: only what is truly needed is ordered, reducing purchasing errors that, in complex projects, can heavily impact the total budget of the contract.
The Quantity Take-Off associated with BIM Detailing
The scalability of an executive project depends on the ability to manage thousands of components without compromising the stability of the system. It is not just about choosing the most powerful software, but about setting up a workflow that allows for a smooth transition from the detail of a single node to the overall view of the work without informational friction.
BIM families and detail-oriented parametric objects: balancing geometry and data
Creating libraries of parametric objects represents the backbone of detailing. A “detail-oriented” object is not a static block, but an intelligent entity capable of adapting to the context. For example, a family of steel connections must be able to vary the number of bolts or the thickness of plates based on the structural loads entered as parameters. The main challenge lies in balancing: inserting too much geometry weighs down the model, while inserting too little forces laborious manual adjustments during the drawing phase. The solution lies in using Visibility States, which allow for the maximum detail to be shown only in section or shop views, while maintaining a simplified representation in general coordination views.
Managing variants during construction without duplicating the model (Nested Families and Worksharing)
On site, variants are the only constant. Effectively managing them requires a model structure based on Nested Families, where complex components are assemblies of independent sub-components. If the supplier of a support for systems changes, it is sufficient to update the “child” element for the modification to propagate instantly throughout the project. At the same time, Worksharing allows different teams to operate simultaneously on distinct work packages. In an efficient detailing flow, the structural modeler and the connection detailer work on the same database, ensuring that every geometric change is immediately visible to those coordinating the system installations.
Quality control and Clash Detection: distinguishing between geometric (Hard) and assembly (Soft) interferences
BIM detailing elevates Clash Detection to a higher level. It is no longer limited to identifying hard clashes, which are physical interpenetrations between objects (like a pipe passing through a beam), but also analyzes soft clashes. The latter concern assembly tolerances and maintenance spaces: a bolt may not touch other objects in the model, but if there is no physical space to insert the pneumatic screwdriver, the detail fails the site test. A mature detailing process therefore includes the modeling of “clearance volumes” that are invisible but detectable by the software, ensuring that every component is not only correctly positioned but also actually installable by the workforce.
Automated extraction of Shop Drawings from the federated model
The ultimate goal of detailing is to produce the documentation for fabrication. The automated extraction of Shop Drawings transforms the model into the “graphic engine” of the project. Thanks to rigorous view templates and filters based on parameters, it is possible to generate lists of rebar, cutting lists for wood, or shop drawings for metalwork with minimal manual intervention. This process drastically reduces human error: if the detail in the model is correct, the drawing will be consistent. Automation concerns not only geometry but also the coding of elements, which is essential for logistics and tracking pieces from the factory to the exact installation point on site.
BIM detailing does not operate in a legislative vacuum. The accuracy of a model must meet regulatory requirements that ensure transparency, interoperability, and quality of public and private works. Without shared standards, the term “detailing” would remain subjective, creating disputes between clients and designers.
International standards: comparison between AIA approach and BIMForum (LOD 350-400)
At the international level, the most widely used standard is the one developed by the AIA (American Institute of Architects) and refined by the BIMForum. In detailing, the fundamental leap occurs between LOD 350 and LOD 400.
- LOD 350 is the “coordination step”: it includes the necessary parts for the interface between different systems (such as supports or connection plates).
- LOD 400, on the other hand, is the manufacturer’s level: the element contains all the details of reinforcement, welding, and assembly necessary for industrial production.
Understanding this distinction is vital in international projects, where the request for a “LOD 400” implies legal responsibility for the millimeter accuracy of every bolt and prefabricated component.
LOD, LOG and LOI and informative model
The Information Requirement Document (EIR) as a basis for defining the required level of detail
All regulatory theory converges in the Information Requirement Document (EIR – Exchange Information Requirements). This is the document, drawn up by the client, that establishes “who must model what and with what level of detail.” Without a well-structured EIR, there is a risk of producing overly complex models where they are not needed or too simplistic where construction detail is crucial.
An effective EIR defines the Responsibility Matrix (LOD Matrix), specifying that, for example, structural nodes must reach a construction level (LOD E / 400) by a certain date to allow for the order of steel, while internal finishes can remain at a definitive level (LOD C / 300). BIM detailing thus becomes a planned and contracted process, where every modeling effort is aimed at a specific decision-making or productive goal, optimizing design costs and maximizing efficiency on site.
Implementing detailing requires a paradigm shift: we must stop thinking of the model as a drawing and start treating it as a digital assembly line. Here are the key steps to transform theory into a solid and scalable operational flow.
Preliminary project analysis and objective definition
Before starting modeling, it is essential to identify the critical areas that require a high level of detail. Not all elements of a building need an LOD 400: focusing on complex structural nodes, cramped MEP passages, or custom facades allows for resource allocation where the risk of error is highest. This project’s “triage” phase helps establish the necessary level of detail for each discipline, avoiding wasting time on unnecessary modeling for standard or easily manageable components on site.
Creation of a structured Common Data Environment (CDE)
BIM detailing thrives on collaboration. Without an organized Data Sharing Environment (ACDat) according to ISO 19650 standards, the risk of working on outdated model versions is extremely high. An efficient CDE must allow for the smooth linking of federated models: the structural detailer must be able to see in real-time the slopes of drains modeled by the MEP designer to adapt rebar or holes in beams. The fluidity of data is a necessary condition for ensuring that the detail is always consistent and up to date.
Library standardization and automation
Efficiency in detailing is achieved through standardization. It is necessary to create libraries of parametric components that already include assembly tolerances and production data. Instead of modeling every node from scratch, experienced teams use Visual Programming scripts to automate repetitive tasks, such as distributing brackets or inserting standard bolts. Automation drastically reduces model production times and, above all, minimizes human error in the project’s most information-dense phase.
Model review and validation protocols
The final mile of BIM detailing is quality control. Before extracting workshop drawings or material lists, the model must pass a series of rigorous checks. These include verifying the complete absence of “soft” interferences (accessibility and assembly) and the consistency of the necessary informational parameters for quantity take-off. A detail is truly “executive” only when it has received technical approval from all discipline coordinators, ensuring that what is modeled is physically feasible, economically measurable, and temporally planable.
What is BIM detailing and why is it central to contemporary design?
BIM detailing is the process of geometric and informational refinement that elevates a digital model from a representation of intent (Design Intent) to an operational guide for production and assembly. While architectural modeling defines ‘what’ we are building, detailing establishes ‘how’ each individual component will interact with others on site. It is central today because the complexity of modern buildings and stringent contractual timelines no longer allow for improvisation during installation. Without accurate detailing, BIM remains an unfulfilled promise; with it, it becomes a tool to eliminate uncertainty.
What is the operational meaning of BIM detailing?
Operationally, BIM detailing acts as a universal translator. It translates the performance requirements of the architectural and structural project into unique instructions for the workforce and for computer numerical control (CNC) machines. At this stage, the model is enriched with minute yet critical details: bolted connections, reinforcement rebar, bracketing for MEP systems, seals, and assembly tolerances. This flow of information eliminates subjective interpretations by workers or site managers, moving conflict resolution (clash detection) from the physical environment to the virtual environment.
What is the difference between BIM modeling (Design-Intent) and the detailing phase (Construction-Ready)?
The difference lies in the Level of Development (LOD): Design-Intent modeling is typical of preliminary and definitive phases (LOD 200-300), where elements represent theoretical volumes and strata for general coordination. The Construction-Ready phase (detailing) pertains to the execution and construction phase (LOD 400-500), where elements are defined in minute detail, such as metal profiles, fastening systems, and accessories, specifying every anchoring bracket and the exact assembly sequence.
How does BIM detailing impact the reduction of waste and prefabrication?
BIM detailing is a prerequisite for DfMA (Design for Manufacturing and Assembly). It enables material optimization by reducing waste through precise calculations, facilitates Just-in-Time logistics by eliminating hazardous work onsite, and reduces downtime by ensuring that every prefabricated component fits perfectly with others, accelerating installation speed.
What do LOD, LOG, and LOI mean in professional detailing?
According to the UNI 11337 and ISO 19650 standards, LOD is divided into LOG (Level of Geometry) and LOI (Level of Information). LOG defines the geometric accuracy (e.g., moving from a solid beam to a beam with real holes and bolting), while LOI concerns the metadata (e.g., manufacturer data, batch number, surface treatments, and bolt torque values).
What is Model Weight Management and when is a detail excessive?
Model Weight Management is the art of balancing informational richness and software performance. A common mistake is over-modeling, such as modeling the internal threading of bolts, which makes the file unmanageable. A detail is sufficient when it allows for verification of coordination, quantity take-off, or manufacturing without unnecessarily burdening the geometric database.
How does BIM detailing ensure reliability between quantity take-off and site?
Detailing transforms the Quantity Take-Off (QTO) into a rigorous extraction from the virtual reality. This ensures accurate quantities and eliminates the disconnect between the purchasing office and the site, as both draw from the same Single Source of Truth. Only what is genuinely needed is ordered, drastically reducing purchasing errors.
What is the difference between Hard and Soft interferences in Clash Detection?
‘Hard clashes’ are physical penetrations between objects. ‘Soft clashes’ concern assembly tolerances and maintenance spaces: for example, checking if there is enough physical space to insert a pneumatic screwdriver. Mature detailing involves modeling ‘respect volumes’ to ensure actual installability.
What regulations influence the level of detail in BIM?
Internationally, the AIA/BIMForum standard is followed, where the fundamental jump for the manufacturer occurs between LOD 350 and LOD 400.
What is the Information Requirement Document (EIR) and how does it influence detailing?
The EIR (Exchange Information Requirements) is the document drawn up by the client that establishes who must model what and with what detail. It defines the Responsibility Matrix (LOD Matrix), ensuring that every modeling effort is aimed at a specific decision-making or productive goal, optimizing costs and time.
