  • BIM news
  • BIM projects
  • EN
  • Menu Menu
List List Menu
  • BIM and Construction Sites
  • BIM and Building Design
  • BIM in Construction
  • BIM and Estimation
  • BIM and Energy
  • BIM and Safety
  • BIM and MEP
  • BIM and Facility Management
  • BIM and training
  • BIM and GIS
  • BIM and Infrastructure
  • BIM and technical standards
  • IFC and openBIM
  • Digital Twin
Home » BIM and Construction Sites » Critical Path Method: Enhancing Construction Management
The key to successful construction projects lies in efficient process management: a comprehensive guide to the Critical Path Method
Editorial Team / 9 September 2025
Managing complex construction projects demands precise planning and execution strategies. In this context, the Critical Path Method (CPM) emerges as a fundamental tool to ensure the success of construction projects. In this article, we’ll delve into CPM, examining how it can be effectively implemented within the construction sector.
  • What is the Critical Path Method
  • Why is the Critical Path Method essential for planning construction work?
  • Implementing CPM in Construction: An Example
  • Benefits for Construction Industry Professionals
  • Practical examples of CPM in construction
  • How to manage delays and variations in the critical path
  • Tools for Implementing CPM in Workflow
  • FAQ – Critical Path Method (CPM) construction
The Critical Path Method is one of the project management techniques used to plan, schedule, and control the activities involved in a project.
It is a management methodology that is part of the so-called “Pull Planning,” a specific approach to project planning that works “backwards”: it starts from the presumed completion date of the project and works backwards in defining the fundamental phases of the construction process.
The CPM identifies the critical sequence of activities that determines the overall duration of the project.
It involves the identification of all necessary activities to complete a project, determining the sequence in which these activities must be performed, and identifying the critical sequence.
The critical sequence represents the most effective path to achieving the planned objective, and any delay in one of the critical activities will affect the overall duration of the project.
The CPM is an effective tool for managing complex projects and identifying areas that require special attention to avoid overall delays. It is widely used in project management in sectors such as engineering, construction, IT, and other fields where it is necessary to coordinate various activities to achieve a common goal.
Critical Path Method and Kanban view
The Critical Path Method (CPM) is an effective and reliable technique in construction project management because it allows for efficient planning and resource allocation.
By identifying the essential activities and milestones of the project and completing them in the correct order, project managers increase the likelihood of completing projects on time.
It helps keep the project on track, deliver it on time and within budget, and provides visibility on the most important work on site while managing a multitude of activities, dependencies, and people.
The critical path method, if developed properly, helps project managers:
  • identify the most important activities of a project that critically impact its duration;
  • establish an efficient schedule to complete the entire project on time and within budget.
Imagine being involved in constructing a new building and utilizing the Critical Path Method (CPM) to plan project activities. The CPM process involves several steps:
  • Activity identification – listing all project activities and defining dependencies among them;
    • A: Project Approval
    • B: Site Setup
    • C: Foundation
    • D: Main Structure
    • E: Electrical and Plumbing Installations
    • F: Interior Finishing
    • G: Inspections and Testing
    • H: Final Approval
  • Time estimation – determining the duration for each activity. This estimation could be based on historical data, experience, or other time estimation methodologies;
    • A: 2 weeks
    • B: 4 weeks
    • C: 6 weeks
    • D: 8 weeks
    • E: 5 weeks
    • F: 7 weeks
    • G: 3 weeks
    • H: 2 weeks
  • Creating network diagrams – representing activities and their dependencies through a network diagram, called PERT (Program Evaluation and Review Technique) or activity diagram. For instance, Activity C (Foundation) can only start after completing Activity B (Site Setup). To create a diagram correlating times and activities, consider using project management software;
  • Calculating the critical path – identifying the longest path through the network diagram. Activities on this critical path determine the overall project duration (A – B – C – D – E – F – G – H);
  • Resource allocation – determining resources needed for each activity, ensuring that critical path activities take priority to avoid overall delays.
  • Monitoring and control – during project execution, monitor activity progress, focusing on critical path activities. Any delays in these activities will impact the project’s overall duration.
CPM enables identifying critical activities that require careful management to avoid overall delays in building construction. This method provides a clear roadmap for the project, allowing better planning and resource management.
Managing construction projects is often a complex endeavor, requiring precise planning and vigilant supervision. The Critical Path Method (CPM) can be a great solution for industry professionals, offering strategic advantages that can revolutionize their approach to construction projects.
Here’s how CPM can catalyze success.
Detailed Planning for Long-term Success
In the construction realm, precise planning is the key to success. CPM allows detailed breakdown of involved activities, providing a clear view of project phases. This level of detail facilitates managing complex projects, enabling technicians to anticipate and prevent potential obstacles.
Resource Optimization for Maximizing Efficiency
Efficient resource allocation is crucial for construction project success. By identifying the critical path, CPM enables professionals to focus resources where they are most needed. This ensures critical activities receive necessary attention and resources to avoid delays, minimizing waste and maximizing overall project efficiency.
Accurate Completion Time Predictions
Providing realistic completion time estimates is a distinctive strength of CPM. Construction industry technicians can use this method to obtain reliable forecasts of the overall project duration. This not only provides a realistic timeframe but also allows better management of client and stakeholder expectations.
Risk Minimization and Enhanced Control
CPM isn’t just a planning tool but also an effective control and monitoring system. By identifying critical activities, technicians can focus on phases that can significantly impact the project’s duration. This not only helps prevent delays but also enables a swift and targeted response to deviations from the initial plan.
Proven Success in Complex Projects
CPM has demonstrated its effectiveness across a wide array of construction projects, from skyscrapers to infrastructures. Technicians adopting this methodology can benefit from the positive experience of numerous successful projects, gaining confidence in its application.
In conclusion, the Critical Path Method is more than a mere project management methodology; it’s a strategic ally offering tangible advantages for construction industry professionals. Accurate implementation of CPM can radically transform how projects are planned, executed, and completed, paving the way for a new era of efficiency and success in the construction field.
The Critical Path Method can be applied to various types of construction projects, both for new construction and for renovation projects.
Imagine we want to build a new structure to be used as offices; the first step will be to define all the activities into which the project can be broken down:
  1. excavation;
  2. foundation construction;
  3. construction of the load-bearing structure;
  4. construction of the closure elements (walls/windows);
  5. construction of insulation elements;
  6. installation of systems;
  7. construction of finishing elements (painting/flooring, etc.).
  8. furnishing insertion.
Among these activities, it will be possible to identify critical activities such as excavation or pouring of foundations, whose delay will affect the timely success of the entire construction, and a series of non-critical activities, such as finishes, which in case of delays can be executed simultaneously with other remaining activities.
Similarly, the Critical Path Method can be applied to a renovation project. Imagine we need to intervene on a building to renovate the heating, plumbing, and electrical systems.
Among the activities are:
  1. demolition and dismantling of floors and wall coverings;
  2. removal of old systems;
  3. creation of new traces;
  4. laying of pipes/cables and all parts of the systems;
  5. restoration of flooring and finishing elements.
It is easy to understand how a delay in the initial demolition phase for the traces will result in a overall delay of the entire intervention because it will affect the entire execution of the intervention.
The Critical Path Method can optimize project management by identifying the critical path, which is the set of activities that take the longest to complete and therefore, considering dependencies and other variables, most constrain the project.
Identifying the critical path during the design phase, before actually executing the work, does not mean that it remains unchanged!
As the project progresses:
  • on one hand, the actual completion times of activities can be different from those planned;
  • on the other hand, there may be constraints related to resources, which could impact the critical path.
To keep the entire process under control, it is important to constantly update the network diagram including all emerging new information.
In this way, not only can a different critical path from the original be recalculated, but there will also be a more realistic view of the project’s completion date and more information to understand if the project is proceeding according to the established plans.
If it is necessary to shorten the completion times of a particular activity that is delayed, one might consider developing other activities in parallel, always paying attention to the various risks associated with overlap, or investing additional resources to accelerate that activity.
If, on the other hand, not enough resources have been allocated for a particular activity, it will be necessary to completely or partially reschedule it, which will imply a variation in timing.
Since just one miscalculation can cause the entire critical path to change, it is important, to avoid future problems, to analyze delays and understand their causes and the impact of such changes on the initial and final scheduling.
Effectively managing workflows and implementing CPM in daily work activities can benefit from using construction management software. It helps manage work activities smoothly and as scheduled. Choosing a cloud application enables planning activities from anywhere, sharing tasks and deadlines with collaborators, fostering efficient communication, and real-time activity tracking until issue resolution.
BIM issue tracking | Schematic representation of the usBIM.resolver chat
In this short video, we’ll show how to manage construction project issues at every stage and meet deadlines using a cloud-based construction management software.
What is the Critical Path Method (CPM)?
The Critical Path Method is a project management technique used to plan, schedule, and control project activities. It allows for the identification of the sequence of critical activities that determine the overall duration of the project and that, if delayed, directly affect the final deadline.
Why is CPM important in construction projects?
Because it allows for precise planning, efficient resource allocation, identification of fundamental activities, and monitoring of execution times. It is a strategic tool that helps avoid delays and ensures adherence to budget and deadlines.
What are the main advantages of CPM in the construction sector?
  • Detailed project planning
  • Resource optimization
  • Accurate timing forecasts
  • Effective control of critical activities
  • Reduction of risks related to delays or unforeseen events
How is the critical path calculated?
The critical path is calculated by constructing a network diagram (PERT), where activities, durations, and dependencies are represented. All possible sequences are then identified, and the one with the longest overall duration is determined: this is the critical sequence.
Does the critical path remain unchanged during the project?
No. The critical path can change during the course of the project due to delays, unforeseen events, or variations in resources. Therefore, it is essential to continuously update the network diagram to maintain a realistic view of the project.
How to manage delays in one of the critical activities?
It is possible to:
  • overlap compatible activities (fast tracking);
  • allocate more resources to shorten times (crashing);
  • reschedule the activity and update the critical path.
In any case, it is important to analyze the impact of each change on the overall duration.
Is CPM useful in renovation projects as well?
Yes. The method is applicable to both new constructions and renovations. In both cases, it helps identify critical activities, plan dependencies, and anticipate the impact of any delays on overall timing.
usbim-resolver
usbim-resolver
Share this entry
  • Share on Facebook
  • Share on X
  • Share on WhatsApp
  • Share on LinkedIn
  • Share by Mail
Related posts
    20 August 2026
  • Digital construction sites: revolution and innovation in the Construction Industry
  • 7 April 2026
  • 4 tips for using Agile construction
  • 30 October 2025
  • What is a Building Inspection Checklist?
  • 20 October 2025
  • Construction Quality Control Checklist: 5 essential elements
Follow us on
  • Construction Sites
  • Energy
  • Estimation
  • Infrastructure
  • Safety
  • Structural Calculation
  • Technical standards
  • Training
  • BIM news
  • BIM project example
  • Digital Twin
  • IFC and openBIM
Scroll to top
