Grid Connected PV System
What is a grid connected pv system? How does it work? How is it designed? Discover all in this in-depth article
Installing a photovoltaic system is the best way to produce clean energy and save on electricity bills. A grid-connected system is the most suitable choice when seeking stable supply and the ability to feed excess electricity generated back to the national grid.
How to design a grid connected pv system?
If you’re planning a grid connected pv system, or any other photovoltaic system, and want to ensure optimal performance and precise calculation, placement, and sizing, using specific solar design software can be helpful. Let’s explore in detail the various types of photovoltaic systems, their key features, and the tools to avoid evaluation errors.
What Does Grid Connected PV System Mean?
A grid-connected photovoltaic system, or a photovoltaic system connected to the grid, is a solar energy generation system connected to the national or local electrical grid. This type of system harnesses solar energy to generate electricity through photovoltaic panels and then transmits the produced energy, entirely or partially, directly to the electrical grid, converted into alternating current.
To further enhance your understanding, be sure to explore Types of photovoltaic systems: characteristics and advantages.
Main components in a grid-connected solar system
Grid-connected systems include:
- photovoltaic modules: monocrystalline or polycrystalline, with specific characteristics;
- string inverters, microinverters, or central inverters: DC/AC conversion, integrated MPPT, grid support functions;
- DC/AC electrical panels: protections against overcurrents, overvoltages, and isolation;
- monitoring system: gateway, irradiance sensors, module temperature;
- mounting structures: aerated, ballasted, or integrated into the roof;
- certified wiring and connectors: class II, UV resistant, and according to regulations;
- network interface devices: anti-islanding protections and disconnect devices.
How It Works
The grid-connected photovoltaic system comprises a photovoltaic array dedicated to harvesting solar energy, divided into several strings of photovoltaic modules arranged in parallel.
Optimally orienting the photovoltaic panels is crucial to benefit from sunlight exposure. The best exposure is between south, southeast/west, east, but specific location factors such as nearby trees or buildings casting shadows on panels, mountainous terrain, etc., need consideration.
The distinctive component of a grid connected system is the inverter, necessary to convert the energy generated by the photovoltaic array – direct current (DC) – into electrical energy for the grid in the form of alternating current (AC). It’s essential to highlight that, being “connected to the grid,” the system requires connection cables resistant to high temperatures and UV rays.
All these parts contribute to the system’s operation and the production of energy subsequently fed into the national grid.
3D modeling of a photovoltaic system with Solarius-PV
Types of Photovoltaic Systems
There are various types of photovoltaic systems that differ in their electricity usage:
- Stand-Alone Photovoltaic Systems (stand-alone or off-grid): These systems are not connected to the distribution electrical grid, so the generated energy is entirely used to meet the needs of the individual building on or near which they are installed. Stand-alone photovoltaic systems are optimal for ensuring energy production even in remote areas not served by the distribution grid;
- Grid-Connected Photovoltaic Systems: In this context, the system is connected to the electrical grid. The generated energy is drawn from the grid distribution network, while conversely, it is supplied to the grid operator during times when the system isn’t generating energy. The electrical energy produced and fed into the grid constitutes a credit for the user;
- Hybrid Photovoltaic Systems: These systems are connected to the electrical grid, but the presence of a storage system allows the use of stored solar energy to entirely meet the user’s needs. If the stored energy is also consumed, the building will reconnect to the grid through a power control unit.
Based on the panel positioning, there are photovoltaic systems:
- On roofs;
- On facades or sunbreakers (brise soleil) of new or existing buildings;
- On the ground (photovoltaic parks with panels also of the “sunflower” type);
- On a flat terrace;
- On a photovoltaic canopy (parking).
Installation of a photovoltaic system on a roof
Stand-alone and Grid-Connected Photovoltaic Systems: Differences
The main differences between a grid-connected and a stand-alone photovoltaic system concern the connection to the electrical grid, energy management, and energy independence. Here’s an overview of the disparities:
- Grid Connection
- Grid-connected: This type of system is linked to the national or local electrical grid. The generated energy can be used locally and/or fed into the grid. Additionally, when the system doesn’t produce sufficient energy, drawing electricity from the grid is possible.
- Stand-alone: In a stand-alone system, the produced energy is directly used to power local loads or stored in storage batteries for use when sunlight is unavailable (nighttime, cloudy days, etc.). There’s no connection to an external electrical grid.
- Energy Management
- Grid-connected: In a grid-connected system, excess energy can be injected into the grid, and the owner may receive credits or compensations for this energy. Accessing energy from the grid is possible when the system doesn’t produce enough.
- Stand-alone: In a stand-alone system, energy must be managed locally. Energy storage systems, such as batteries, are often present to ensure continuous supply when sunlight is unavailable.
- Energy Reliability
- Grid-connected: Grid-tied systems offer higher reliability as they can draw energy from the grid when solar production is insufficient.
- Stand-alone: Stand-alone systems entirely rely on solar production and the batteries’ capacity to store energy. Their reliability is tied to weather conditions and the size of the storage system.
- Applications and Usage
- Grid-connected: Commonly used in urban and suburban areas, grid-connected systems are suitable for those aiming to contribute to renewable energy, benefit from net metering tariffs, and have a reliable energy supply.
- Stand-alone: Stand-alone systems are ideal in remote locations without access to the electrical grid. They’re often used in applications such as weather stations, water pump systems, or off-grid houses.
In summary, the primary distinction between the two types of systems is their connection to the electrical grid, resulting in differences in energy management and reliability.
Designing a Photovoltaic System
Designing a photovoltaic system requires meticulous planning and consideration of various factors, including:
- Site Analysis
Geographical Position: Evaluate the site’s position to determine solar exposure and the available solar irradiance.
Shading: Identify any obstacles like trees or buildings that could cause shading on the photovoltaic arrays. - System Sizing
Energetic Load Calculation: Estimate the building or device’s daily energy consumption connected to the system.
System Sizing: Determine the system’s size based on the required power and anticipated solar irradiance. - Component Selection
Photovoltaic Panels: Choose panels with suitable efficiency and capacity.
Inverters: Select an inverter matching the photovoltaic panel’s power. Options include centralized inverters or string inverters based on the project.
Support Structures: Assess mounting options like fixed frames, solar tracking systems, or building-integrated structures for the panels. - System Design
Array Configuration: Determine the optimal orientation and tilt to maximize solar irradiance.
Element Distribution: Plan the positioning of panels, inverters, and cables based on site characteristics. - Financial Evaluation
Financial Analysis: Assess return on investment (ROI) and tax benefits.
Costs: Calculate initial and operational costs of the entire system.
All these aspects can be significantly simplified and managed using a guided procedure, thanks to a photovoltaic software.
In this video, we’ll be showing a practical example to guide you through the process.
How grid-connected photovoltaic systems integrate into building design
The integration of grid-connected photovoltaic systems into building design requires a multidisciplinary approach involving architecture, electrical engineering, structural engineering, and plant engineering. From the early concept stages, PV must be considered an integral part of the project, not just an additional component: this means evaluating available surfaces, favorable orientations, aesthetic and landscape constraints, as well as the energy needs of the building.
Integration can occur in two main ways: BAPV (Building-Applied PV), where modules are installed on existing surfaces such as roofs and facades, and BIPV (Building-Integrated PV), where photovoltaic modules replace traditional building elements while also performing architectural functions such as solar shading, parapets, facade cladding, or roof components.
From an electrical perspective, a grid-connected system must be designed to ensure safety, efficiency, and regulatory compliance: this involves proper string configuration, the selection of suitable inverters, the sizing of interface panels, and adherence to national grid connection standards. Architecturally, the design must consider the visual integration of the modules, accessibility for maintenance, shadows generated by building elements, and additional loads on the structure. The use of energy simulation software and BIM tools allows for the integration of photovoltaics into the digital model of the building, checking for interferences, assessing productivity in relation to irradiation, and optimizing the layout based on real data.
A grid-connected PV system, if correctly integrated, contributes to achieving contemporary energy standards — such as NZEB, LEED certifications, or local protocols — improving the building’s performance both in terms of energy consumption and lifecycle. Attention to the preparation of spaces for inverters, conduits, monitoring systems, and future integrations (such as batteries or electric vehicles) makes the building more flexible and ready to adapt to future technological developments. In summary, the integration of grid-connected photovoltaic systems is not just a matter of plant engineering, but a comprehensive design process that harmonizes form, function, and energy performance, contributing to the construction of more sustainable and intelligent buildings.
Best practices for the orientation and tilt of photovoltaic modules
Best practices for the orientation and tilt of photovoltaic modules aim to maximize irradiation on the panel plane and thus energy production, taking into account geometric, environmental, and technical variables.
In general, in the northern hemisphere, the ideal orientation is towards South, with a tolerance of ±15–30° which results in minimal losses; wider deviations towards East or West reduce annual production but can be strategic when aiming to optimize self-consumption during specific time slots.
The optimal tilt depends on latitude: in Italy, while higher tilts improve winter production and lower tilts favor summer production, although they reduce the natural self-cleaning of the panels.
Shadows represent one of the main loss factors and require dedicated analysis with professional software and calculation of the minimum distances between rows on flat roofs to avoid internal shading, often in the order of 1.5–2.5 times the height of the module.
Also, the ventilation of the panels is crucial: maintaining a space of 5–12 cm from the support surface reduces operating temperatures and thus losses related to the thermal coefficient. The electrical aspect imposes further considerations, as partial shadows on a single module can compromise the entire string: for this reason, it is good practice to separate different orientations and tilts on different MPPTs and possibly use optimizers or microinverters in particularly heterogeneous contexts.
Tilt also affects structural stresses due to wind and snow, which increase significantly for tilts greater than 35° or less than 10°, which is why a compromise between 10° and 15° is often adopted on flat roofs, also useful for maximizing installation density.
Finally, high reflectance surfaces or bifacial modules may require different tilts to take advantage of the albedo contribution. Overall, an integrated approach that considers orientation, tilt, shadows, ventilation, electrical layout, and structural constraints allows for more efficient, reliable systems that align with the energy and architectural needs of the project.
FAQ
How do you design a grid-connected photovoltaic system?
Designing a grid-connected photovoltaic system requires a thorough site analysis, evaluation of solar exposure, shading risk, and proper sizing of power. It is essential to choose appropriate panels, inverters, and structures, and to reduce errors, it is advisable to use specific software for photovoltaics.
What does grid-connected photovoltaic system mean?
A grid-connected photovoltaic system is a system connected to the national or local electricity grid. The solar energy produced by the panels is converted by the inverter into alternating current and used on-site or fed into the grid when not consumed immediately.
What are the main components of a grid-connected photovoltaic system?
The main components include photovoltaic modules, string inverters or microinverters, DC/AC electrical panels with protections, monitoring systems, mounting structures, certified wiring, and network interface devices such as anti-islanding protections.
How does a grid-connected photovoltaic system work?
The photovoltaic field collects solar energy through modules arranged in strings. The inverter converts direct current into alternating current, and the energy produced is used by the building or fed into the national electricity grid. The optimal orientation of the panels and the absence of shading are essential to maximize production.
What types of photovoltaic systems exist?
There are three main types: stand-alone systems, not connected to the grid and equipped with batteries; grid-connected systems, which feed energy into the grid; hybrid systems, which integrate grid and storage. Panels can be installed on roofs, facades, ground, terraces, or canopies.
What are the differences between stand-alone and grid-connected photovoltaic systems?
Grid-connected systems are connected to the electricity grid and allow excess energy to be fed back, earning credits. They offer greater reliability due to grid support. Stand-alone systems are autonomous, use batteries, and do not have grid support, making them more sensitive to weather and storage capacity.
How do you correctly design a photovoltaic system?
The design involves geographical site analysis, shading verification, consumption calculation, system sizing, component selection, and economic analysis. The use of professional software allows for a reliable and optimized project in a short time.
How are photovoltaic systems integrated into building design?
The integration of photovoltaics requires a multidisciplinary approach that considers structural, aesthetic, energy, and electrical aspects. Systems can be installed as BAPV (Building-Applied) or BIPV (Building-Integrated), contributing to modern energy standards such as NZEB and improving the overall efficiency of the building.
What are the best practices for the orientation and tilt of photovoltaic panels?
The ideal orientation in the northern hemisphere is towards South with a tolerance of ±15–30°. It is essential to avoid shading, ensure ventilation for the panels, separate modules with different tilts on different MPPTs, and consider wind and snow loads, especially on flat roofs.
