PID Potential Induced Degradation: Photovoltaic Degradation
PID photovoltaic is a potential degradation phenomenon of photovoltaic modules caused by the difference in voltage. Discover the causes and how to prevent it
PID photovoltaic (potential induced degradation) is an electrical phenomenon that causes a loss of power in photovoltaic modules. This phenomenon manifests itself over the course of several months or even years: in fact, it is often overlooked at the beginning of the plant’s life, while it becomes more burdensome in the later stages of operation, especially because it is not always easy to trace the causes.
The effects of PID can be reversible and irreversible. These performance degradation effects on the module and system can result in significant changes to the plant’s business plan. In particular, cases of PID have been reported that led to a power reduction of up to 70% in less than a year.
It is, therefore, essential to constantly monitor the photovoltaic system in order to identify the first signs of performance degradation present in the system. To this end, in order to obtain economic analyses regarding the actual profitability of the plant, you can use the photovoltaic software.
Let us analyze in detail what causes PID photovoltaic, its effects, and the strategies to identify and prevent it.
photovoltaic system efficiency – Solarius PV software
- What is potential induced degradation (PID) in photovoltaic panels?
- Types of PID: reversible and irreversible
- Main Causes of PID in Photovoltaic Modules
- How does PID affect the performance and lifespan of photovoltaic modules?
- PID in different photovoltaic technologies
- How to test for potential induced degradation (PID)?
- How to prevent photovoltaic PID effect
- Monitoring PID and maintaining plant efficiency
- FAQ- Photovoltaic PID
Potential induced degradation, known by the acronym PID (Potential Induced Degradation), is a phenomenon that can affect photovoltaic modules when they are subjected to significant differences in electric potential relative to the ground or the support structure of the system. This phenomenon leads to a reduction in the photovoltaic effect, resulting in a decrease in the power of photovoltaic cells. Advanced systems with bifacial photovoltaic panels can be particularly sensitive to PID due to their dual-sided structure, which requires careful design and monitoring.
PID occurs when a high difference in electric potential develops between the cell, which constitutes the active semiconductor material, and other parts of the module, such as the glass, support, or aluminum frame. This condition is typical of photovoltaic systems connected in high-voltage strings.
The potential difference generates a leakage current within the module, which facilitates the migration of ions. Negative ions tend to disperse towards the aluminum frame, while positive ions, particularly sodium ions present in the glass, migrate towards the surface of the cell. The accumulation of these ions alters the electrical properties of the cell, compromising the proper functioning of the photovoltaic effect and causing power losses.
The degradation is progressive over time and can manifest even in the first few months of the system’s operation, especially in unfavorable environmental conditions, such as high humidity and high temperatures.
The phenomenon of PID can affect the various types of photovoltaic panels and is not related to an isolated manufacturing defect, but to the overall behavior of the photovoltaic system, which involves modules, inverters, grounding schemes, and operating conditions. For this reason, it represents a significant issue both at the design stage of the system and during operation and maintenance.
Potential induced degradation can manifest in different forms depending on the intensity of the phenomenon, the duration of exposure, and the construction characteristics of the photovoltaic module. Based on the effects produced on the cells and the possibility of recovering performance, PID is generally distinguished into reversible and irreversible.
Reversible PID (polarization)
This is the less severe form of potential induced degradation. The performance loss is mainly due to the temporary accumulation of charges or ions on the surface of the cells and the presence of leakage currents through the encapsulation material, the frame, and the front glass.
This type of PID is particularly evident in the modules positioned at the bottom of the photovoltaic strings, i.e., those closest to the negative pole, where power loss can reach up to 70% in a few years.
If the cause of the phenomenon is removed, for example by reducing the potential difference or intervening on the system configuration, the module can recover all or part of the original power. Reversible PID is more frequent in the initial operating phases of the system and is often counterable with appropriate technical solutions.
Irreversible PID (electrocorrosion of the TCO layer)
This form of PID results in a deeper and permanent degradation of photovoltaic cells. Ionic migration and leakage currents cause structural or chemical damage, particularly to the TCO (Transparent Conductive Oxide) layer, which stably compromises the electrical properties of the cell.
The phenomenon manifests especially when the frame comes into contact with moisture, triggering an electrochemical reaction that causes corrosion of the materials. In these cases, even if the cause of PID is eliminated, the performance of the module cannot be restored, making panel replacement or a significant reduction in performance expectations over time necessary.
To limit or prevent irreversible PID, one can intervene on the choice of frame materials or use inverters with galvanic separation, reducing the potential differences responsible for the phenomenon.
The causes that lead to the onset of potential induced degradation (PID) in photovoltaic modules are numerous and depend both on the constructive characteristics of the module and the electrical operating conditions of the system. In particular, the main factors influencing PID are:
- quality of photovoltaic cells: lower quality cells are more sensitive to deterioration phenomena and therefore more prone to the development of PID over time;
- type of photovoltaic module: the choice of encapsulation materials and the front glass affects the ease with which ions can move within the module. Materials with poor insulating properties favor the formation of leakage currents;
- dielectric properties of the glass: the dielectric characteristics of the glass used in photovoltaic modules affect the resistivity of the encapsulant and the magnitude of leakage currents, significantly contributing to the onset of the PID effect;
- electric potential to which the module is subjected: the presence of high potential differences, particularly a negative voltage between the cells of the module and the frame connected to ground, represents one of the most critical factors in the development of PID. This condition is typical of systems with high voltage photovoltaic strings;
- configuration of the photovoltaic system: the arrangement of modules in strings, the grounding system, and the type of installed inverter influence the potential to which the modules are subjected. An inadequate configuration can increase the risk of PID and anticipate its appearance even in recently completed systems;
- environmental factors: the environmental conditions in which the system operates, such as high humidity and high temperatures, can reduce the resistivity of insulating materials and promote leakage currents, accelerating the mechanisms responsible for PID.
Environmental Factors Influencing PID in Photovoltaic Panels
Among the listed causes, environmental factors play a particularly relevant role in the development of potential induced degradation (PID). High humidity levels facilitate the migration of ions within the module, while high temperatures increase the conductivity of materials, making the formation of leakage currents more likely.
Systems installed in humid, coastal environments or characterized by particularly severe climatic conditions are therefore more exposed to the risk of PID. Temperature fluctuations can also contribute to degradation, as they stress the module materials over time and alter their insulating properties.
The combination of unfavorable environmental factors and suboptimal design choices can anticipate the onset of PID and amplify its effects, reducing the useful life of photovoltaic modules and the overall performance of the system.
Causes of PID in photovoltaic modules
Potential induced degradation directly impacts the electrical performance of photovoltaic modules and the duration over time of the system. The phenomenon compromises the cells’ ability to convert solar radiation into electrical energy, causing a progressive reduction in production.
The main effects of PID on module performance include:
- reduction in power output, leading to a decline in overall energy production;
- decrease in output voltage and current, altering the I-V curve, which describes the relationship between current and voltage of the module;
- worsening of module efficiency, initially contained but increasing over time if the phenomenon is not countered;
- significant power losses in severe cases, potentially compromising the profitability of the system.
In addition to the immediate effects on performance, PID also affects the lifespan of photovoltaic modules:
- accelerates the aging of the cells and materials of the panel;
- can cause permanent damage in the case of irreversible PID;
- increases the risk of extraordinary maintenance interventions or of module replacements.
Finally, since PID does not uniformly affect all panels in a string, it can generate operational imbalances between the modules, further reducing the overall efficiency of the system.
Potential induced degradation can manifest differently depending on the photovoltaic technology used. The characteristics of the materials, cell structure, and production processes influence both the likelihood of PID occurrence and the ways in which the phenomenon develops over time.
PID in crystalline silicon photovoltaic cells
In crystalline silicon photovoltaic modules, PID is generally associated with the migration of ions, particularly sodium ions coming from the glass, towards the cell surface. This process alters the internal electric field of the cell and reduces the ability to collect charges generated by solar radiation.
The phenomenon occurs more frequently in modules subjected to high voltages relative to ground, such as those positioned at the ends of strings. Power losses can become significant over time and, if left uncontrolled, can evolve from reversible forms to irreversible forms of degradation.
PID in thin-film photovoltaic cells
In thin-film modules, such as amorphous silicon panels, PID often takes on different characteristics compared to crystalline silicon. In these technologies, degradation is more commonly related to electrocorrosion phenomena of the transparent conductive layers, such as TCO (Transparent Conductive Oxide), caused by leakage currents and interaction with moisture.
The deterioration of conductive layers results in a reduction of electrical conductivity and a worsening of the module’s performance. In many cases, PID in thin-film modules is less reversible and can lead to permanent degradation, especially under unfavorable environmental conditions and suboptimal system design.
To identify the presence of potential induced degradation, it is essential to perform targeted diagnostic tests that can highlight the electrical and structural alterations in photovoltaic modules. PID is not always immediately visible to the naked eye and may initially manifest only as a reduction in the system’s performance.
The most commonly used testing techniques allow for the analysis of the electrical behavior of the modules and the identification of any anomalies related to leakage currents or ionic migration phenomena. Among the most effective methods are I-V curve analysis and electroluminescence tests.
PID detection through I-V curve analysis
The I-V (current-voltage) curve analysis allows for evaluating the electrical behavior of photovoltaic modules by measuring the relationship between the generated current and the voltage at the module terminals. By comparing the measured curve with the reference curve provided by the manufacturer, it is possible to identify anomalies related to the presence of PID.
In the case of potential induced degradation, the I-V curve typically shows a reduction in voltage, current, or maximum power, leading to a consequent worsening of the module efficiency. This type of analysis also allows for evaluating the electrical insulation state of the panels, providing useful indications about their overall health.
Thus, measuring the I-V curves makes it possible to identify energy losses, diagnose PID-related problems early, and plan timely interventions, which are essential for maintaining high system performance over time.
Electroluminescence testing for PID detection
Electroluminescence testing is an advanced diagnostic technique that allows for analyzing the state of photovoltaic cells by observing their light emission levels. In operational contexts, the analysis can also be performed outdoors, allowing simultaneous visualization of entire strings of modules.
By applying an electrical voltage to the panels in low light conditions, the cells emit a weak light radiation that is detected using dedicated acquisition systems such as infrared cameras. Differences in emission levels allow for identifying anomalies, damaged areas, or areas affected by PID.
The presence of potential induced degradation typically manifests as dark or irregular areas, indicating cells compromised by ionic migration or leakage currents. This method allows for precise localization of the affected modules and serves as an effective tool for distinguishing PID from other defects in photovoltaic panels.
Preventing potential induced degradation represents a fundamental aspect in the design, implementation, and management of photovoltaic systems. Since PID is linked to the overall behavior of the system, its risk can be reduced through a combination of correct design choices, suitable components, and ongoing monitoring activities.
Best practices to reduce the risk of PID in photovoltaic systems
Implementing best practices from the early design phases and throughout the operation of the system significantly contributes to limiting the onset of PID. In particular, the following measures are effective:
- use of high-quality materials, such as photovoltaic cells and encapsulation materials with good dielectric properties, capable of reducing leakage currents;
- careful design of the system, taking into account the site’s environmental conditions, operating voltages, and string connection schemes;
- constant monitoring of performance, useful for promptly identifying performance drops linked to PID;
- regular cleaning of the panels, helping to limit the accumulation of moisture and contaminants on the module surfaces;
- periodic verification of electrical connections, to prevent current leaks and anomalies that can promote degradation;
- implementation of a BIM construction site, supported by an integrated digital model of the system, allowing for planning and coordinating the arrangement of the modules, optimizing the electrical layout, identifying potential criticalities, and scheduling maintenance interventions.
These activities, when integrated into a proper management plan for the system, significantly reduce the likelihood of the development of PID over time.
Choice of inverters and materials to avoid PID
A key role in the prevention of PID is played by the choice of inverters and system materials. The use of inverters specifically designed to mitigate potential induced degradation allows limiting potential differences between the modules and the plant’s ground.
In particular, inverters with galvanic isolation or with functions for managing the potential of the modules can reduce leakage currents responsible for the phenomenon. The choice of materials for the frame, glass, and encapsulant also significantly affects the module’s resistance to PID.
Therefore, a proper selection of components, combined with adequate electrical design, represents one of the most effective strategies to prevent the PID effect and ensure high long-term performance.
Continuous monitoring of the photovoltaic system is a fundamental aspect for early detection of degradation induced by potential and limiting its effects on performance. Since PID can develop gradually and is not always immediately visible, constant monitoring allows for intervention before power losses become significant.
Through performance monitoring systems, it is possible to detect abnormal variations in energy production, compare the performance of different strings, and identify modules that exhibit non-compliant behaviors. Integrating production data with periodic measurements, such as I-V curve analysis or electroluminescence tests, allows confirmation of the presence of PID and assessment of its evolution over time.
Effective monitoring also facilitates scheduling maintenance interventions, reduces the risk of irreversible degradation, and helps preserve the overall efficiency of the system. This way, it is possible to ensure greater operational reliability, extend the useful life of photovoltaic modules, and maintain the expected performance from the system over time.
In the design, verification, and management phases of photovoltaic systems, it is important to be supported by photovoltaic software, capable of analyzing the electrical behavior of the system, assessing the performance of strings, and identifying potential criticalities, such as the risk of potential induced degradation. Using this professional design and simulation solution allows improving system reliability from the earliest stages and effectively supports monitoring and maintenance activities. Trust this tool and optimize the performance and profitability of your photovoltaic system right away.
What is photovoltaic PID?
Photovoltaic PID, standing for Potential Induced Degradation, is an electrical phenomenon that causes a progressive loss of power in photovoltaic modules, reducing the performance of the system over time.
Does PID affect all photovoltaic modules equally?
No, PID does not uniformly affect all modules in a string. Some panels, particularly those at the ends of the string and closer to the negative pole, may experience more significant degradation than others.
What is the difference between reversible PID and irreversible PID?
Reversible PID involves a temporary performance loss that can be recovered by eliminating the cause of the phenomenon, such as reducing the potential difference. Irreversible PID, on the other hand, causes permanent damage to the cells or materials of the module, making it impossible to restore the original performance.
How much power can PID reduce in severe cases?
In critical cases, PID can cause power reductions of up to 70%, with significant impacts on energy production and the profitability of the photovoltaic system.
What are the main causes of PID in photovoltaic modules?
The main causes of PID include the quality of the cells, the encapsulation and glass materials, high potential differences between cells and the frame, the electrical configuration of the system, and environmental conditions such as high humidity and high temperatures.
How does the environment affect the risk of PID?
Environments characterized by high humidity, high temperatures, or significant temperature fluctuations favor ionic migration and leakage currents, increasing the likelihood of the onset and acceleration of PID.
Does PID affect the useful life of photovoltaic modules?
Yes, PID accelerates the aging of the modules and, in irreversible cases, can cause permanent damage that reduces the useful life of the panels and increases the need for maintenance or replacement.
Does PID manifest the same way across all photovoltaic technologies?
No, PID manifests differently depending on the technology. In crystalline silicon modules, it is often related to the migration of ions from the glass, while in thin-film modules, it is more frequently associated with electro-corrosion phenomena of the transparent conductive layers.
How can the presence of PID in a photovoltaic system be identified?
The presence of PID can be identified through specific diagnostic tests, such as I-V curve analysis and electroluminescence tests, which allow the detection of electrical anomalies and damaged cells.
Why is continuous monitoring important for PID?
Continuous monitoring allows for early detection of abnormal variations in system performance, enabling intervention before degradation becomes irreversible and compromises the system’s profitability.
Is it possible to prevent PID in photovoltaic systems?
Yes, the risk of PID can be reduced through proper system design, the selection of suitable inverters, degradation-resistant materials, and continuous monitoring of performance over time.
