Run to Failure Maintenance: Definition, Strategy and How to implement it
Run to failure (RTF) maintenance is a planned corrective strategy focusing on intervention only after a failure has occurred. Find out when it's useful to implement and its benefits.
Planning and executing asset maintenance are crucial in various industrial sectors, from manufacturing productions to critical infrastructure. Managing and maintaining facilities, buildings, infrastructure, or any other asset can be a lengthy and complicated task. Fortunately, specific facility management software assists us in managing assets regardless of the type of maintenance we choose to adopt for them.
In this article, we delve into a type of failure maintenance: run to failure maintenance. Run to failure maintenance distinguishes itself as a planned corrective strategy that focuses on intervening only after a failure has occurred. While this strategy may seem counterintuitive, it can have useful applications in various contexts. Let’s explore it further in this article.
- What Is Run to Failure Maintenance?
- Comparing Run-to-Failure with Modern Maintenance Strategies
- What is an example of run to failure maintenance?
- When and why is it useful to implement a run to failure maintenance strategy?
- How to implement run to failure maintenance in your maintenance plan?
- What are the advantages and disadvantages of run to failure maintenance?
- FAQ- Run to failure
Run to failure maintenance, indicated by the acronym RTF, is a planned corrective maintenance strategy that acts by intervening on already occurred failures. Such a maintenance approach utilizes resources throughout their useful life, replacing or repairing them only when they fail and/or stop functioning, thus minimizing total maintenance costs.
Implementing this maintenance strategy requires some considerations, such as:
- Understanding intervention and repair/replacement procedures.
- Having equipment and spare parts readily available.
- Having maintenance personnel in place.
It’s crucial for these considerations to be made before the failure occurs to minimize intervention times and prevent further damage, disruptions, or deferred maintenance strategies.
The landscape of asset management, particularly in plant and equipment maintenance, encompasses diverse maintenance strategies, each offering unique characteristics and trade-offs. The “Run to Failure” (RTF) approach stands as one distinct methodology among a spectrum of maintenance philosophies, ranging from traditional reactive methods to sophisticated preventive and predictive strategies.
This analysis explores the critical distinctions between these maintenance approaches, focusing on three key dimensions: operational context suitability, cost-risk optimization, and planning requirements. Understanding these differences is essential for organizations to implement the most effective maintenance strategy aligned with their operational objectives.
Run to Failure vs. Reactive Maintenance
Run to failure maintenance and reactive maintenance are both forms of breakdown maintenance, differing in the planning of maintenance intervention and the criticality of the failure. Specifically:
- Run to failure is a planned corrective strategy designed to minimize total maintenance costs. It involves planning corrective actions to be taken after the failure. This type of maintenance is feasible on non-critical assets that do not impact an organization’s productivity or safety.
- Reactive maintenance is an unplanned maintenance strategy executed when an asset fails suddenly, causing downtime, and must be repaired to avoid affecting productivity or safety.
Run to Failure vs. Preventive Maintenance
Preventive maintenance is a strategy involving regular and planned interventions on an asset to prevent failures. These interventions occur based on a predetermined time schedule or specific performance criteria.
On the other hand, run to failure maintenance intervenes only after a failure has occurred, replacing or repairing the failed component. The main distinctions are:
- Temporal approach: Preventive maintenance is based on a predetermined time schedule or performance criteria, while RTF does not involve preventive interventions.
- Costs and resources: Preventive maintenance requires allocating resources and time for planned interventions, while RTF minimizes costs and resources used until a failure occurs.
- Risk management: Preventive maintenance aims to reduce the risk of failure through preventive interventions, while RTF accepts the risk of sudden failures in exchange for lower maintenance costs.
Run to Failure vs Predictive Maintenance
Predictive maintenance relies on data analysis and continuous monitoring of asset conditions to anticipate the optimal time for maintenance. This strategy utilizes indicators such as vibrations, temperatures, or other signals to identify early signs of failure and intervene before actual failure occurs.
The main differences are:
- Timing of intervention: Predictive maintenance intervenes before an actual failure occurs, while RTF maintenance only intervenes after the failure has already occurred;
- Utilization of data: Predictive maintenance is based on data analysis to predict failures, whereas RTF does not require predictive data analysis;
- Costs and resources: Predictive maintenance may require investments in monitoring technologies and data analysis, while RTF may be more economical in terms of implementation costs.
An example of run to failure maintenance involves replacing parts of an asset whose failure, and therefore discontinuity in operation, does not cause further damage to the rest of the resource or inconvenience to users.
For instance, replacing a light bulb can easily fall under a run to failure maintenance plan. This is because when a light bulb stops working:
- Other bulbs in the room will still provide illumination;
- Having a spare supply of light bulbs is easy and does not require excessive investment;
- The brief period of non-operation does not pose risks to user safety.
It’s important to note that there isn’t always a single maintenance strategy suitable for a particular asset, but multiple maintenance types can be combined based on the resource. It is likely, therefore, that run to failure maintenance will be applied within the maintenance plan to those resources or parts thereof whose non-operation does not pose safety risks and can be repaired afterward, maximizing the resource itself and thus saving on total intervention costs.
Run to failure workflow
Run to failure maintenance is useful when applying another type of maintenance is more expensive than replacing the resource itself. The earlier example of the light bulb is relevant: it is more cost-effective, both economically and logically in terms of intervention, to deal with a blown bulb than to preemptively replace it while it’s still functional.
If the failure has a minimal impact on the overall performance of the asset, a run to failure approach is preferable to preventive maintenance.
In general, run to failure maintenance is suitable for:
- resources with a short useful life that can simply be replaced at the end of their lifecycle;
- assets that are inherently disposable by nature;
- durable assets, and/or parts thereof, associated with a low risk of failure;
- non-critical assets whose failure does not affect the use of the rest of the asset;
- resources where applying another type of maintenance is complicated.
To successfully implement this type of maintenance, some precautions will suffice, including:
- a good inventory and availability of spare parts to quickly remedy the failure through total or partial replacement of the part;
- prepared and available personnel to intervene quickly to avoid further damage,
- maintenance planning through the support of specific facility management software that help plan activities, manage work orders, and tickets in an integrated manner to optimize resource utilization and reduce interference.
This particular type of maintenance should only be applied after a thorough risk assessment associated with the failure of various parts of the asset, in order to avoid more serious damage. Despite this, when applicable, “run to failure” maintenance has some advantages to consider:
- minimum planning: by acting after a failure has occurred, it is not necessary to schedule interventions beforehand but will only intervene afterwards in relation to the damage;
- low initial costs: no investment in predictive or preventive tools or technologies;
- easy to implement: implementing interventions after a failure, having parts and personnel available, is easy and intuitive;
- low maintenance costs: using resources until the end of their life cycle can reduce downtime and avoid intervening on still functioning parts; however, this only applies to assets that are quick and easy to replace and especially to parts of the assets considered “non-critical”.
- optimization of component use: the asset is utilized until the end of its useful life cycle;
- ideal for non-critical assets: RTF is suitable for low-cost or easily replaceable components, whose failure does not compromise safety or productivity.
Advantages of Run to Failure maintenance
It is important to note, however, that this type of maintenance strategy can entail some disadvantages, including:
- risk of sudden failures: RTF maintenance can involve the risk of sudden failures, which could affect productivity or safety;
- high indirect costs: if applied to critical assets, machine downtime can lead to severe economic losses;
- safety risks: in the event of failures in important components, the risks to personnel safety are potentially greater;
- spare parts inventory management: by not acting preventively, one must be ready to intervene should a failure occur, which requires immediate availability of spare parts to reduce downtime;
- increased stress for technical teams: maintenance occurs in emergencies, and thus, often under pressure;
- possible increase in downtime: failure interventions could cause unplanned downtime, affecting operational productivity.
The future of “run to failure” maintenance may see greater integration of advanced technologies, such as the Internet of Things (IoT) and artificial intelligence, to optimize failure interventions. However, RTF will continue to be a relevant strategy in contexts where maintenance costs must be kept low and the risk of sudden failures is acceptable.
In our comprehensive exploration of maintenance strategies, we have consistently highlighted the critical nature of maintenance as a pivotal phase in an asset’s lifecycle. Despite the diverse maintenance approaches that can be tailored to specific asset characteristics, the complexity of effective maintenance management necessitates sophisticated technological support.
To optimize maintenance efficiency and strategic planning, we strongly recommend leveraging advanced facility management software. Such solutions provide comprehensive tools for planning, executing, and tracking maintenance activities, ultimately driving significant reductions in both operational times and associated costs.
FAQ- Run to failure
What is Run to Failure maintenance?
Run to Failure (RTF) maintenance is a corrective and planned maintenance strategy that consists of intervening only after a component or equipment has failed.
With this approach:
- a resource is used until the end of its useful life, without performing preventive or predictive interventions;
- repair or replacement occurs only when the component stops functioning.
Why is the Run to Failure program considered cost-effective?
The “Run to Failure” (RTF) maintenance program is considered cost-effective because it utilizes resources until the end of their life cycle, avoiding intervention on still functioning parts. However, it is particularly useful when applied to non-critical and easily replaceable components that do not compromise productivity and worker safety.
When is Run to Failure maintenance used?
Run to Failure (RTF) maintenance is used in specific contexts where allowing a component to fail before intervening is more convenient and safe than applying preventive or predictive strategies. Such contexts include:
- non-critical assets whose failure does not significantly impact productivity or safety;
- low-cost and easily replaceable components;
- cases where the cost of preventive maintenance exceeds that of post-failure replacement;
- situations where there is immediate availability of spare parts and personnel for quick interventions.
What are some examples of Run to Failure maintenance?
Concrete examples of Run to Failure (RTF) maintenance, that is, situations where a component is intentionally allowed to fail before intervening, can include:
- light bulbs: not replaced until they burn out;
- non-essential auxiliary pumps or motors: which do not cause plant downtime;
- fuses: designed to break in case of overload, replaced only after they have blown;
- disposable filters (e.g., HVAC): not constantly monitored, but replaced after blockage or performance drop;
- warehouse mobile devices: such as labelers or secondary handhelds;
- cooling fans for non-critical equipment: not continuously monitored and intervened upon only when they stop working.
What are the advantages of Run to Failure maintenance?
Among the advantages of Run to Failure are: minimal planning, reduced initial costs, ease of implementation, optimization of component use, low maintenance costs, ideal for non-critical assets.
What are the disadvantages of Run to Failure maintenance?
The disadvantages of Run to Failure include: risk of sudden failures, high indirect costs, safety risks, spare parts inventory management, increased stress for technical teams, possible increase in downtime.
