Solar Assisted Heat Pump: Operation and Advantages
A heat pump combined with solar thermal is an efficient system for heating, cooling, and producing hot water. Discover how it works and its features
A heat pump can be combined with both a solar thermal system and a photovoltaic system. Both technologies represent today the most efficient plant solutions in terms of efficiency and exploitation of renewable energy sources.
While the photovoltaic system generates electrical energy for self-consumption that can be used to activate the heat pump, the solar thermal system provides thermal energy, contributing to the production of hot water and integrating the heating system. The heat pump, combined with photovoltaic and solar thermal systems, is therefore a highly efficient and sustainable system for heating, cooling, and producing domestic hot water (DHW).
Heat pump and solar thermal: features
The heat pump combined with solar thermal consists of a heat pump and a solar thermal system.
The heat pump is a machine capable of transferring heat from a lower temperature environment to a higher temperature one. The operating principle of a heat pump in heating is similar to that of a refrigerator, with the difference that while the refrigerator extracts heat from its interior to keep it cool and releases it into the environment, the heat pump extracts heat from the environment to heat the interior of a house and/or produce the hot water needed for daily use.
A solar thermal system, on the other hand, is a system that uses solar energy to produce thermal energy: energy that can be used both for DHW production and for heating buildings.
The integration between the two systems is particularly effective. In particular, during the winter months, the solar system can reduce the loads on the heat pump, and during the summer months, it can take care of producing domestic hot water, allowing the heat pump to focus exclusively on cooling the environments, ensuring high energy savings.
Heat pump and solar thermal: operation
The operation of this system presents two possible alternatives, depending on the chosen technological solution. In particular, the combination with solar thermal is aimed at using solar energy for the production of domestic hot water and/or to increase the machine’s performance. It can be implemented in two ways: with a direct system or with an indirect system.
In the first case, the solar panel circuit is directly connected to the heat pump. In this configuration, the heat transfer fluid circulating in the solar collector is the same one that reaches the compressor: the solar collector effectively takes on the role of the evaporator. By harnessing solar energy, it is possible to reduce the electricity consumption of the compressor, used to compress the process fluid in order to increase its temperature, consequently reducing consumption.
Direct System
In indirect systems, on the other hand, the two circuits are separate. In these cases, the operation is based on the heat exchange between the fluid heated in the solar panel and the heat pump fluid.
In this configuration, the heat exchanger acts as the evaporator, as in the previous case the heat pump will require less electrical energy to heat the fluid, instead exploiting the heat transferred by the solar system.
Indirect System
Solar assisted heat pumps can also be integrated with a photovoltaic system that uses solar energy to generate electricity. This energy can be used to power the heat pump, reducing the dependence on electricity supplied by third parties.
A photovoltaic system collects solar energy through photovoltaic solar panels, transforming it into readily usable electrical energy. This energy can directly power household appliances or be stored for future use. On the other hand, heat pumps are highly efficient systems that transfer heat from a low-temperature source to a higher-temperature source, using electricity for heating or cooling indoor spaces.
The integration of heat pumps and photovoltaic systems with storage systems allows for optimizing the self-consumption of solar energy. During sunlight hours, photovoltaic panels generate electricity, part of which will be used instantly. Excess energy is stored in storage batteries for nighttime use or on days with reduced solar radiation. This approach minimizes the draw of energy from the traditional electrical grid, increasing the system’s efficiency and reducing overall energy costs.
What are the advantages of combining a heat pump with solar thermal energy?
Integrating a heat pump with a solar thermal system is a beneficial choice that significantly reduces energy costs and environmental impact, thanks to the optimized use of renewable energies.
The main advantages are:
- reduction of cycle inversions: cycle inversion can cause interruptions in the cooling function, energy inefficiencies, and stress on the heat pump’s compressor. By integrating a solar thermal system for domestic hot water, these issues are reduced, improving overall efficiency and extending the heat pump’s lifespan;
- benefits of solar thermal energy: the solar thermal system, especially with vacuum tube collectors, covers a significant portion of the domestic hot water demand, reducing energy consumption and improving the building’s energy performance;
- combined efficiency: with proper sizing, the combined use of solar thermal energy and heat pumps significantly increases the overall energy efficiency of the building, reducing environmental impact and ensuring maximum long-term energy savings;
- sustainable investment: although installing a heat pump with solar thermal energy may require a significant initial investment, its durability and improved efficiency make it an environmentally friendly and economically advantageous choice in the long run.
