Discover How to Solve Thermal Bridging Roof Issues
A complete guide to thermal bridges in pitched roofs and flat roofs. What causes it, usual problems, insulation strategies and benefits resulting from proper design.
Designing thermal bridges is crucial in the construction field and requires special attention as it determines the habitability, energy efficiency and occupants’ health. In the specific context of the roof, thermal bridges can lead to heat loss, mold formation and condensation. Significantly impacting the building structure and occupants’ well-being.
This article aims to explore in-depth all aspects related to thermal bridges in pitched roofs and flat roofs. A video will also show you how to easily address the issue with specific thermal bridge calculation software equipped with an integrated FEM solver, wizards for standard cases, and DXF/DWG scheme import.
Graphic of the thermal bridge on the roof and on the intermediate floor
- Causes of Thermal Bridges in Roofs
- Issues Arising from Thermal Bridges in Roofs
- Thermal Bridges Attacking with the Roof Covering
- What are the benefits of roof insulation
- Materials for Eliminating Roof Thermal Bridges
- Strategies for correcting thermal bridges in the renovation of existing roofs
- Common Mistakes in Roof Insulation
- How to Design and Calculate Roof Thermal Bridges Considering Real Conditions
- FAQ – Thermal bridges in roofing and optimization strategies
Fully understanding the underlying causes of thermal bridges in roofs is essential to effectively address the issue. A thermal bridge, defined as a localized area of the building envelope with lower thermal resistance than the remaining portion without thermal bridges, represents the focal point of thermal flow between a building’s internal and external environment.
Various inconsistencies contributing to thermal bridge formation include:
- Geometric inconsistencies in the building envelope
Wall-floor nodes, wall-column nodes and wall-window nodes are critical points where geometric inconsistencies can occur. These areas, if not treated correctly, can become true “breaches” in the building’s thermal barrier; - Building envelope thickness variations
Elements like recesses, technical voids and chimneys can cause variations in the envelope’s thickness. These discontinuities can disrupt thermal insulation coherence, facilitating heat dispersion through these areas; - Material inconsistencies
The presence of different materials or the transition from one material to another can contribute to thermal bridge formation. Material inconsistencies can alter the building envelope’s thermal insulating capacity, creating vulnerable points; - Specific building phenomena
Other building-specific factors, such as the presence of structural bridges or suboptimal design solutions can also contribute to thermal bridges.
We have already mentioned that thermal bridges in the roof can cause significant problems both in terms of living comfort and building’s energy efficiency. Let’s delve into more detail.
Impact on Thermal Loss
Thermal loss resulting from roof’s thermal bridges is responsible for considerable energy losses. This phenomenon compromises the overall building’s thermal insulation efficiency. Affecting occupants’ thermal comfort and increasing energy consumption.
Mold and Condensation
The formation of mold and condensation is a tangible risk associated with thermal bridges in the roof. This phenomenon occurs when areas affected by thermal bridges become colder than the rest of the building, creating an environment conducive to condensing the moisture in the air. This condition, besides compromising the structural integrity of the roof, it poses a threat to occupants’ health.
Thermal bridges in the roof can indeed compromise indoor air quality, increasing the risk of respiratory diseases and allergies.
Mold growth risk assessment
In intermediate floors and connection zones with the roof covering, structural continuity between the horizontal or inclined plane and the vertical one can generate thermal bridges, especially when considering flat roofs. The connection between the wall and the roof covering can be influenced by the roof covering structure itself, with elements such as copings, eaves lines or vertical parapets that can interrupt geometric continuity.
If the wall extends beyond the roof slab, with a parapet or other vertical element, it can interrupt the continuity of the insulation layer. In this case, it is essential to carefully manage the connection between the parapet and the insulation layer, paying attention to dimensions and materials involved.
In the context of a pitched roof, thermal bridge formation requires careful consideration of the different geometry resulting from the connection between the roof’s inclined part and the vertical wall. This aspect is particularly relevant when considering connecting elements such as beams, especially in cases of wooden floors.
Alternatively, the roof covering could adopt a “ventilated roof” configuration, with the upper part facing outward and separated from the lower part by an air layer. Although this configuration promotes proper ventilation, it may introduce critical points in terms of thermal insulation.
Elements such as copings, shelves, or architectural solutions in connections between inclined roofs and walls may protrude beyond the roof covering profile, generating potential interruptions in the insulation layer continuity and becoming sources of thermal dispersion if not designed and executed with care. Therefore, it is crucial to adopt design approaches to ensure insulation layer continuity. Minimizing thermal bridges’ impact and ensuring optimal thermal performance in the entire pitched roof system.
Roof insulation is one of the most effective interventions to improve the energy performance of a building, as the roof is the surface most exposed to thermal losses in winter and overheating in summer.
- Reduction of winter thermal losses
An uninsulated roof can lose up to 30% of the heat produced by the heating systems. Adding a continuous insulating layer helps contain energy losses, keeping the spaces warmer and reducing the need for heating. - Control of summer overheating
In summer, the roof receives maximum solar radiation. An insulated roof limits the transmission of heat indoors, helping to keep the house cooler without excessive reliance on air conditioning. In flat or sloped roofs, the use of materials with high thermal mass (e.g., wood fiber, cellulose fiber) ensures a delay and attenuation of the thermal wave. - Improved living comfort
By eliminating cold or overheated areas, a more uniform temperature is achieved in the spaces. This translates into greater thermal well-being and a reduction in drafts and surface condensation phenomena. - Prevention of mold and condensation
Thermal bridges in roofs often create cold spots prone to condensation. Insulation reduces surface temperature differences, lowering the risk of harmful mold formation for both the structure and the health of the occupants. - Energy and economic savings
A well-insulated roof leads to lower energy consumption for both heating and cooling. In the long term, this results in lower bills and generally quick payback times, especially when combined with tax incentives. - Durability of the building structure
Limiting thermal fluctuations and interstitial condensation phenomena preserves structural elements (beams, floors, waterproofing layers), reducing degradation and extending the useful life of the roof. - Increase in property value
A building with insulated roofing improves its energy class, increasing market attractiveness and compliance with current regulations. - Environmental sustainability
Reducing energy demand means lowering CO₂ emissions related to the operation of the building. Using eco-friendly materials (cellulose, wood fiber, mineral wool) further contributes to environmental sustainability.
Commonly used insulating materials to eliminate thermal bridges include:
- cellulose fiber: biodegradable and ecological, offers heat resistance and waste reduction;
- glass wool: widely used for its excellent insulating properties, fire resistance and ease of installation;
- polyurethane foam: closed-cell insulation that adheres without joints, effective in filling voids;
- expanded polystyrene (EPS): lightweight, durable, moldable, suitable for various roof shapes and waterproof.
Composition of a stratigraphy
Correcting thermal bridges in the renovation of existing roofs requires an integrated approach that combines preliminary analysis, choice of insulation system, and attention to construction details.
Continuous external insulation (warm roof) is the most effective solution, as it eliminates discontinuities and significantly reduces the risks of condensation, with a minimally invasive intervention inside. When the outer surface is not accessible, internal insulation can be opted for using panels applied to the underside of the slab, a simple solution but with reduced thicknesses and a higher risk of condensation formation that requires particular attention to vapor management and ventilation.
In more radical renovations, structural insulating panels (SIPs) can be adopted, which integrate insulation and load-bearing capacity, ensuring high performance but with greater costs and complexity. Other strategies involve the use of localized thermal discontinuity elements, such as high-heel beams or insulating plinths, useful for ensuring continuity of insulation at critical junctions. Monitoring before, during, and after the intervention is essential, using thermography and hygrometric checks, to identify and verify the correction of thermal bridges at sensitive points, such as wall-roof junctions, gutters, and structural connections.
In many cases, the roof renovation can be combined with additional interventions, such as doubling the external insulation or applying cool roof solutions to improve summer performance, keeping in mind that the latter do not directly affect winter thermal bridges.
In summary, correcting thermal bridges in roofing cannot be entrusted to a single technique but must be the result of a targeted strategy that integrates thermal performance, moisture control, technical feasibility, and economic sustainability.
It is important to be aware of common mistakes that can compromise work effectiveness:
- Use of inappropriate materials
The choice of insulating materials is crucial. Opting for cheap or low-quality solutions can reduce the effectiveness of thermal insulation. Consult industry professionals to make the most suitable and functional choice for specific needs; - Ignoring ventilation
Proper ventilation is essential to prevent condensation and mold formation. Ensure you have an adequate system that allows proper air circulation under the roof, crucial for the final result contributing to maintain a healthy environment; - Not paying attention to leaks and cracks
Even the smallest cracks in the roof can compromise the effectiveness of thermal insulation. Conduct a thorough roof inspection, looking for any weak points. Repair them before proceeding with any installation is an essential point for the work’s success; - Ignoring the importance of proper installation
Even with quality materials, improper insulation installation can reduce its effectiveness. Relying on industry professionals for correct implementation is essential.
By carefully following these guidelines and paying attention to avoidable mistakes, it is possible to achieve optimal roof insulation from the inside. Ensuring a comfortable home environment, reducing energy costs and preventing issues related to moisture and mold formation.
In the following video, you can see how thermal bridge calculation software allows you to design structures identical to real conditions obtaining highly professional results thanks to a finite element analysis solver.
Why is it important to properly design thermal bridges in roofs?
Because they directly affect living comfort, the energy efficiency of the building, and the health of the occupants. If neglected, they can cause heat loss, condensation, and mold.
What are the main causes of thermal bridges in roofs?
The most common are geometric inconsistencies in construction junctions (wall-slab, wall-window), variations in the thickness of the envelope (shafts, chimneys), differences in materials, and ineffective design solutions.
What problems do thermal bridges in roofing cause?
They cause significant energy losses, worsen thermal comfort, promote the formation of mold and condensation, with consequences for indoor air quality and health.
What solutions exist to correct thermal bridges in existing roofs?
The most effective are continuous external insulation (warm roof), internal insulation with panels on the underside, the use of structural insulating panels (SIPs), or the insertion of localized thermal breaks. In all cases, it is essential to monitor the hygrothermal behavior during and after the work.
What materials are used to eliminate thermal bridges in roofs?
Among the most common are cellulose fiber, glass wool, polyurethane foam, and expanded polystyrene (EPS), chosen based on insulating performance, fire resistance, ease of installation, and sustainability.
What mistakes should be avoided in roof insulation?
The most common are the use of unsuitable materials, lack of proper ventilation, neglecting joints and cracks, and imprecise installation of the insulation. Avoiding these is essential to ensure the effectiveness and durability of the intervention.
