4D BIM Explained: Key Concepts and Practical Applications
Construction site organization: How 4D BIM enhances Project Scheduling and Execution Planning
Estimating and scheduling project execution times are critical for optimizing resources during the construction phase. As part of project planning, it is standard practice—and in some cases mandatory, such as in public contracts—to prepare work schedules, Gantt charts, PERT diagrams, and similar tools to manage the duration of a construction site or an entire contract.
However, traditional methods often lack the flexibility to dynamically adjust or reorganize project timelines. They also provide limited support for communication between project managers and suppliers, real-time monitoring of work progress, and the management of material orders and deliveries on site.
For clients, designers, and contractors, being able to ‘visualize the construction site’ during the design phase would be invaluable, allowing all activities to be anticipated and planned with respect to time.
BIM, and in particular 4D BIM modeling, addresses these challenges by providing a dynamic, integrated solution that helps reduce delays and inefficiencies on site, enhancing both planning and execution.
Let’s proceed in order and discover what 4D BIM is, what the advantages are for your work, and the best software for temporal project management.
4D BIM model and organization of the construction site activities
- What is 4D BIM?
- 4D BIM Model: how temporal data connects to building elements
- 4D BIM Construction Workflow: from schedule to model simulation
- How contractors use BIM 4D for site planning
- The 5 advantages of 4D BIM
- 4D Modeling Software
- What is the difference between 4D and 5D?
- What does the 6D dimension refer to in BIM?
- Case Study: 4D BIM for the Planning of a Complex Construction Site
- FAQ on 4D BIM
What is 4D BIM?
4D BIM modeling is the process that creates intelligent links between the 3D digital model (which defines the geometry of the work) and the time-related information of the various activities necessary to carry out the project.
The result is a comprehensive informational model that can also be used to create realistic simulations of the construction process over time. The purpose is to identify all the site activities (similar to a traditional schedule), visualize their progress over time, and provide stakeholders the opportunity to identify, analyze, and prevent issues related to the sequential, spatial, and temporal aspects of the construction process of a building project.
Dynamic visualization of a 4D BIM model over time | Edificius (ACCA software)
Thanks to this data, designers can develop accurate programs based on a reliable source of federated information. This makes the process secure, improves the control of detecting conflicts between different activities, limits the occurrence of unpleasant surprises during construction, and the consequent waste of time and resources.
The difference compared to a traditional approach is that we are dealing with a three-dimensional BIM model, visually represented in an extremely realistic way and enhanced with the fourth dimension, which is time information. The realistic simulation of 4D BIM, thinking in images rather than just diagrams and written relationships, enhances the ability to understand information.
The concept of 4D BIM scheduling
Literally, scheduling refers to the planning of work timelines for a project. Talking about 4D BIM means defining the activities to be carried out along with their timelines and dynamically connecting them to the BIM model of the project itself.
Construction planning is an essential aspect of design because it allows for the anticipation and prevention of difficulties even in the preliminary phase, avoiding misunderstandings and wasting time and resources on-site.
Construction planning, compared to traditional methods, allows for the detection of spatio-temporal conflicts and overcoming problems in advance through immediate updates to the schedules, thanks to dynamic and intelligent links with the BIM model.
4D BIM model with Gantt chart
The transition from 3D to 4D is not a simple overlay of a schedule onto a geometric model; it is an ontological fusion. In a BIM 4D workflow, every parametric entity of the model (whether it is a reinforced concrete column, a curtain wall, or an MEP system) ceases to be a static object and becomes a dynamic entity endowed with a temporal coordinate.
Interoperability between geometry and time
The heart of the process lies in the linking between the objects of the model and the activities defined in the WBS (Work Breakdown Structure). This linking usually occurs through three modes:
- direct mapping – each “BIM Object” is associated with one or more activities from the Gantt chart;
- selection set – grouping of objects with common characteristics (e.g., all partitions on the ground floor) linked to a single temporal phase;
- shared parameters – use of specific attributes (Activity ID, start/end date) directly entered into the object’s properties to automate the connection with management software.
The digitalization of the construction site
Inserting the temporal data means being able to visualize the evolution of the current state. We are not only planning the installation of a component but defining its “life cycle” during construction: from procurement at the site, to assembly, until achieving full operability.
This level of detail allows for the identification of so-called space-time interferences (soft clashes). For example, it is possible to foresee whether the storage of materials on the second floor will obstruct the crane movement planned for that specific week, an error that would be invisible in a traditional paper Gantt chart.
The 4D workflow is not a linear process but an iterative cycle that requires perfect synchronization between the technical office and the site manager. The goal is to create a digital twin that not only represents the completed building but simulates the entire assembly process.
The structuring of the WBS and data import
Everything begins with the definition of the Work Breakdown Structure (WBS). In a mature 4D BIM flow, the decomposition of activities must not only follow an accounting or supply logic, but must reflect spatial construction logic.
Through 4D BIM software, it is possible to import existing schedules or create new ones directly linked to the architectural model generated with BIM software for architectural design. At this stage, each activity is defined by duration, precedences, and necessary resources.
Association of objects and timeline
Once the temporal structure is established, the association of the 3D elements proceeds. This is the crucial stage where the “where” meets the “when”.
- phase analysis – the states of the objects are defined (Existing, To Demolish, New Construction);
- synchronization – thanks to BIM technology, if an architectural modification is made in the architectural design software, the 4D model updates dynamically, avoiding the need to manually reconnect each individual element.
Visual simulation (4D Simulation)
The final result of the workflow is the visual simulation. It is not just a simple presentation video, but a powerful tool for critical analysis. The simulation allows for:
- validate the construction sequence – visually verify if the assembly order is physically possible (e.g., avoiding closing a slab before installing large mechanical equipment);
- optimize site logistics – visualize the occupation of spaces by machinery, scaffolding, and storage areas in each specific week of work;
- communication to stakeholders – clearly show the client the expected progress of the work, reducing ambiguities typical of traditional bar charts.
For a construction company, time is literally money. If in the design phase 4D serves to validate choices, in the construction phase it becomes the main tool for Risk Management. Companies use BIM 4D to solve problems before they arise on-site, transforming the construction site from a reactive environment to a proactive one.
Analysis of space-time interferences
Unlike classic 3D clash detection, which identifies static geometric conflicts (e.g., a pipe crossing a beam), with 4D it is possible to identify dynamic conflicts.
Contractors use this technology to understand if two different teams are scheduled to work in the same tight space at the same time, or if the position of a crane will interfere with the installation of a facade planned for that specific week. Identifying these “bottlenecks” digitally avoids extremely costly construction stoppages.
Logistics and storage area optimization
The construction site is an organism that changes shape every day. Contractors leverage the 4D model to:
- plan land use – define where to position cabins, storage, and machinery based on the progress of work;
- manage “Just-in-Time” deliveries – synchronize the arrival of materials (prefabricated, reinforcements, plant components) exactly when the 4D model shows that the space for assembly is ready, reducing clutter and risks of damage in storage;
- simulate traffic flows – study the routes of heavy vehicles within the construction site area to avoid congestion during critical phases, such as large concrete pours.
For more information, I recommend reading the article: “4D GIS: the future of geospatial data with time-based analysis“.
4D BIM can be the catalyst for an essential change in the way projects are designed, managed, and developed in the construction sector.
Here are 5 aspects of 4D BIM that can positively change your way of working:
- Planning and scheduling – AEC sector stakeholders can have a comprehensive overview of the project and its construction from the very beginning of the process. This helps the entire team to prevent errors, identify conflicts, and adapt the plan based on newly added information. Everyone is assured that tools, personnel, and supplies will be on-site at the right time and that all resources will be optimized;
- Real-time updates – BIM 4D provides valuable assistance in minimizing the number and duration of meetings and phone calls to communicate decisions, changes, and updates. Thanks to the visualization of project progress obtained through 4D BIM models, communication becomes much simpler, clearer, and more immediate. This connection between the site and the back-office, along with better communication among various project agents, also minimizes disputes and changes during the work;
- Project monitoring – The animation of various stages of the construction process obtained from the 4D model can be very helpful in keeping track of everything happening on-site. What is achieved is a true video in which the various planned construction activities follow one another in chronological order. This allows for planning the arrival of materials on-site and the resources to be used at the right times, anticipating all events that occur on-site;
- Conflict prevention and resolution – The existence of a shared information model adds transparency and clearly outlines the responsibilities of all parties involved. Any addition or change to the project can be easily traced back to the responsible party. No one can shift their responsibilities to other team members, and the entire process is clear and straightforward for everyone.
- Site safety – The use of a construction animation sequence to monitor the progress of the site has great advantages for safety, both in terms of data security for the project and the risk of accidents on-site. Concentrating all data and information into a single BIM model nearly eliminates the likelihood of data loss or tampering. Finally, concerning site safety, BIM 4D can be a compelling step forward towards a safer construction site, thanks to full control of the project: knowing every single detail about the location of materials, machinery, and workers, the management team can guide its resources accordingly and make the best data-driven decisions.
Now let’s see what the tools that connect the 3D geometric model of a work to 4D time and 5D costs must have in terms of features.
First, let’s specify that BIM 4D modeling tools are software that allows you to associate a series of information related to the timing of the project’s execution and the organization of the construction site with the 3D BIM model. This information is visually represented through animations that reproduce the progression of the various works and the advancement of the phases of the construction site. In practice, it is a true video that shows the construction activities and the development of the work until its complete realization.
Specifically, any BIM 4D modeling software must allow:
- to break down the project into individual activities defining a specific WBS (Work Breakdown Structure, that is, the structured list of all project activities)
- to associate BIM objects with the various activities
- to obtain the Gantt chart
- to simulate in Real-Time the evolution of the project over time and obtain realistic presentations
- to identify and resolve any conflicts (overlapping incompatible works, etc.)
- to federate different 3D BIM models
- to add all objects related to activities that are not directly connected to the work (objects present in a material storage area, etc.)
- to share the 4D model with colleagues
- to export the obtained diagrams in various formats.
If you want to try to estimate the execution times of your project with BIM software, I recommend using a BIM software for project time management. This way, you can build the Gantt chart and realistically simulate the evolution of the 3D model in the various phases of the project.
4D BIM Model | 4D environment – GANTT by Edificius
What tool allows us to connect 3D geometries to 4D time and 5D costs?
To connect 3D geometries to 4D time and 5D costs, it is necessary to use BIM software with which you can:
- model the 3D of the project artifact;
- the scheduled works over time;
- estimate the cost of the works.
The best solution would be to use a single tool to manage all these aspects. For this reason, it is always advisable to work with a BIM software for project time management that allows you to build a single informative model of the project from which to draw all the necessary data and information for the entire life cycle of the work.
How much does BIM software cost?
The cost of BIM software varies greatly depending on the type of subscription and the features it includes. Generally, it ranges from 2,000 to 3,000 euros, but to have a realistic idea of the cost of BIM software, I recommend visiting this page.
In summary, BIM 4D integrates the data of the 3D model with the programming and planning data of the project, generating realistic simulations of the construction activities of the work.
5D BIM, on the other hand, connects all 4D information with the aspects of project costs (the quantities of materials, programs, and other price-related information).
In the application of BIM, the planning of costs and time refers to the methodology of Project Management and particularly to project time management and project cost management.
The BIM expert responsible for preparing the calculation (5D) and managing the timing of the work (4D) has the task of linking all measurements, no longer just to a price list but also to the parametric objects of the BIM model. This operation is carried out thanks to the use of specific BIM software.
Parametric objects (walls, doors, windows, etc.) actually contain a series of information that helps in preparing the calculation (Quantity take off) and in identifying, more appropriately, the most suitable item from the price list, having all project information available.
In this way, the calculation is drafted with extreme simplicity, leveraging automatons that associate to the parametric object to be calculated, the dimensions (automatically derived from the geometry of the object) and the price (usually taken from the reference pricing lists).
In summary, 3D, 4D, and 5D are three interconnected aspects of design: creating the WBS automatically derives the metric calculation (also querying the 3D model to obtain quantities) and the times for each individual operation (also evaluating the price analyses in which the times used for each operation are specified) to then sequence them, respecting the good programming rules.
The 6D dimension in BIM refers to the phase of management and maintenance of the completed works. This phase is generally also known as facility management. Essentially, it is the dimension of BIM that focuses on the existing real estate assets during their entire lifecycle and associates to the 3D model the essential information for maintenance and management of the asset. In this way, the information is shareable and exchangeable among various stakeholders, always implementable over time, and there is no risk of data loss.
To delve into the topic, I propose a case study, an exemplary application of BIM modeling for construction phases, serving the productivity of the company and the safety of workers.
Specifically, the case study involves the renovation of an attic located on the eighth floor of a building in the city’s central area, an intervention characterized by significant logistical and organizational challenges. The project entailed the demolition of the existing roof, the vertical support structures, and the internal elements, followed by the construction of a new apartment of approximately 200 m² using prefabricated wooden structures. From the early stages, it became clear that the architectural model alone was not sufficient to represent all the operational conditions of the site: in addition to the limited availability of space for site management, there were television antennas and third-party telecommunications systems on the roof, elements that had to be documented and integrated into the informational model to avoid interference during project execution.
To develop the BIM model of the construction site, the survey of the existing conditions, the project model, and the context model were used, all in IFC format. The models were federated and subsequently “phased,” that is, divided into the various time phases of the construction process. This organization allowed the visualization of the site at any moment during execution, showing exclusively the elements present in a specific phase. Unlike traditional two-dimensional drawings, the 4D model made it possible to represent intermediate situations as well, such as partial demolition or the progressive completion of a structure, offering a reading much closer to the actual evolution of the site.
One of the most significant aspects of the case study concerns the optimization of logistics. The only available private area for material storage was the floor of the eighth floor, while the use of the condominium courtyard required specific permits. Thanks to the 4D simulation, it was possible to pre-validate the placement of storage areas and the movement of materials in the various project phases. For example, during the installation of the metal framework following the demolition of the ridge beam, the model allowed verification that the available space was sufficient to simultaneously accommodate the bins intended for debris and the new metal beams, ensuring the continuous operation of the crane without downtime or operational interference.
The design of the scaffolding was also supported by the informational model. The areas designated for storing boards and horses were repositioned according to the progress of the work, avoiding conflicts with condominium activities and minimizing material movements. In particular, the horses used in the initial phases were placed in a location that would allow their subsequent reuse for the protection of the new roof, without interfering with the installation of the XLAM panels or other expected tasks.
The 4D BIM proved to be equally effective from a safety perspective. During the installation phase of the XLAM floor, the three-dimensional model immediately highlighted the presence of level differences, height changes, and obstacles that were difficult to interpret through floor plans alone. This visualization allowed for the early identification of operational challenges, such as the inability to use pallet trucks for material handling or the need to raise the existing guardrail before starting the work. The views generated by the model were also used as graphic support for defining operational procedures and for drafting safety documentation intended for the executing companies.
Finally, the connection between the three-dimensional model and the work schedule allowed for the dynamic updating of construction phases, checking the impact of any advanced or postponed activities and controlling the availability of equipment, materials, and operational areas. The model was also employed to associate site equipment with information related to CO₂ emissions, noise produced, and the characteristics of electric charging infrastructures, demonstrating how 4D BIM can support not only temporal planning but also the achievement of safety, profitability, and sustainability objectives throughout the entire construction process.
FAQ on 4D BIM
What is 4D BIM?
4D BIM modeling is the process that creates intelligent links between the digital 3D model (which defines the geometry of the work) and the information related to the execution time of the various activities necessary to carry out the work. More specifically, the UNI 11337-1 standard defines 4D BIM as: ‘the simulation of the work or its elements in relation to time, as well as space.’ The result is a complete informative model that can also be used to create realistic simulations of the work process based on time.
To connect 3D geometries to 4D time and 5D costs, it is necessary to use BIM software with which you can: model the 3D of the project artifact; the scheduled works over time; estimate the cost of the works. The best solution would be to use a single tool to manage all these aspects. For this reason, it is always advisable to work with a BIM software for project time management that allows you to build a single informative model of the project from which to draw all the necessary data and information for the entire life cycle of the work.
The cost of BIM software varies greatly depending on the type of subscription and the features it includes. Generally, it ranges from 2,000 to 3,000 euros.
4D BIM integrates the data of the 3D model with the programming and planning data of the project, generating realistic simulations of the construction activities of the work. 5D BIM, on the other hand, connects all the information 4D with the aspects of project costs (the quantities of materials, programs, and other information related to prices). In summary, 3D, 4D, and 5D are three interconnected aspects of design: creating the WBS automatically derives the metric calculation (also querying the 3D model to obtain quantities) and the times for each individual operation.
