{"name":"BibLus","description":"Blog sobre arquitetura, engenharia e constru\u00e7\u00e3o","url":"https:\/\/biblus.accasoftware.com\/ptb","home":"https:\/\/biblus.accasoftware.com\/ptb","gmt_offset":1,"timezone_string":"Europe\/Rome","page_for_posts":0,"page_on_front":9101,"show_on_front":"page","namespaces":["oembed\/1.0","akismet\/v1","contact-form-7\/v1","real-custom-post-order\/v1","real-utils\/v1","siteground-settings\/v1","siteground-optimizer\/v1","uap\/v2","automator\/v1","yoast\/v1","biblus\/v1","regenerate-thumbnails\/v1","wp\/v2","wp-site-health\/v1","wp-block-editor\/v1","wp-abilities\/v1"],"authentication":{"application-passwords":{"endpoints":{"authorization":"https:\/\/biblus.accasoftware.com\/ptb\/wp-admin\/authorize-application.php"}}},"routes":{"\/":{"namespace":"","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/"}]}},"\/batch\/v1":{"namespace":"","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"validation":{"type":"string","enum":["require-all-validate","normal"],"default":"normal","required":false},"requests":{"type":"array","maxItems":25,"items":{"type":"object","properties":{"method":{"type":"string","enum":["POST","PUT","PATCH","DELETE"],"default":"POST"},"path":{"type":"string","required":true},"body":{"type":"object","properties":[],"additionalProperties":true},"headers":{"type":"object","properties":[],"additionalProperties":{"type":["string","array"],"items":{"type":"string"}}}}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/batch\/v1"}]}},"\/oembed\/1.0":{"namespace":"oembed\/1.0","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"oembed\/1.0","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/oembed\/1.0"}]}},"\/oembed\/1.0\/embed":{"namespace":"oembed\/1.0","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"description":"O URL do recurso de onde devem ser coletados os dados do oEmbed.","type":"string","format":"uri","required":true},"format":{"default":"json","required":false},"maxwidth":{"default":600,"required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/oembed\/1.0\/embed"}]}},"\/oembed\/1.0\/proxy":{"namespace":"oembed\/1.0","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"description":"O URL do recurso de onde devem ser coletados os dados do oEmbed.","type":"string","format":"uri","required":true},"format":{"description":"O formato oEmbed a ser usado.","type":"string","default":"json","enum":["json","xml"],"required":false},"maxwidth":{"description":"A largura m\u00e1xima, em p\u00edxeis, do frame da m\u00eddia incorporada.","type":"integer","default":600,"required":false},"maxheight":{"description":"A altura m\u00e1xima, em p\u00edxeis, do frame da m\u00eddia incorporada.","type":"integer","required":false},"discover":{"description":"Fazer ou n\u00e3o uma requisi\u00e7\u00e3o de descoberta para um servidor oEmbed n\u00e3o pertencente \u00e0 lista de servidores permitidos.","type":"boolean","default":true,"required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/oembed\/1.0\/proxy"}]}},"\/akismet\/v1":{"namespace":"akismet\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"akismet\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/akismet\/v1"}]}},"\/akismet\/v1\/key":{"namespace":"akismet\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":{"key":{"type":"string","description":"Uma chave de API do Akismet de 12 caracteres. Dispon\u00edvel em akismet.com\/account","required":true}}},{"methods":["DELETE"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/akismet\/v1\/key"}]}},"\/akismet\/v1\/settings":{"namespace":"akismet\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":{"akismet_strictness":{"type":"boolean","description":"Se verdadeiro, o Akismet descartar\u00e1 automaticamente os spam mais \u00f3bvios ao inv\u00e9s de envi\u00e1-los para a pasta de spam.","required":false},"akismet_show_user_comments_approved":{"type":"boolean","description":"Se verdadeiro, mostra o n\u00famero de coment\u00e1rios aprovados ao lado de cada autor de coment\u00e1rios na p\u00e1gina de listar coment\u00e1rios.","required":false},"akismet_enable_mcp_access":{"type":"boolean","description":"Se essa op\u00e7\u00e3o for configurada como verdadeira, os clientes MCP poder\u00e3o acessar os dados e a funcionalidade do Akismet.","required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/akismet\/v1\/settings"}]}},"\/akismet\/v1\/stats":{"namespace":"akismet\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"interval":{"type":"string","description":"Per\u00edodo de tempo para retornar estat\u00edsticas. Op\u00e7\u00f5es: 60 dias, 6 meses, Tudo","default":"all","required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/akismet\/v1\/stats"}]}},"\/akismet\/v1\/stats\/(?P<interval>[\\w+])":{"namespace":"akismet\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"interval":{"description":"Per\u00edodo de tempo para retornar estat\u00edsticas. Op\u00e7\u00f5es: 60 dias, 6 meses, Tudo","type":"string","required":false}}}]},"\/akismet\/v1\/alert":{"namespace":"akismet\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"key":{"type":"string","description":"Uma chave de API do Akismet de 12 caracteres. Dispon\u00edvel em akismet.com\/account","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"key":{"type":"string","description":"Uma chave de API do Akismet de 12 caracteres. Dispon\u00edvel em akismet.com\/account","required":false}}},{"methods":["DELETE"],"args":{"key":{"type":"string","description":"Uma chave de API do Akismet de 12 caracteres. Dispon\u00edvel em akismet.com\/account","required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/akismet\/v1\/alert"}]}},"\/akismet\/v1\/webhook":{"namespace":"akismet\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/akismet\/v1\/webhook"}]}},"\/contact-form-7\/v1":{"namespace":"contact-form-7\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"contact-form-7\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/contact-form-7\/v1"}]}},"\/contact-form-7\/v1\/contact-forms":{"namespace":"contact-form-7\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/contact-form-7\/v1\/contact-forms"}]}},"\/contact-form-7\/v1\/contact-forms\/(?P<id>\\d+)":{"namespace":"contact-form-7\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/contact-form-7\/v1\/contact-forms\/(?P<id>\\d+)\/feedback":{"namespace":"contact-form-7\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}]},"\/contact-form-7\/v1\/contact-forms\/(?P<id>\\d+)\/feedback\/schema":{"namespace":"contact-form-7\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/contact-form-7\/v1\/contact-forms\/(?P<id>\\d+)\/refill":{"namespace":"contact-form-7\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/real-custom-post-order\/v1":{"namespace":"real-custom-post-order\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"real-custom-post-order\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/real-custom-post-order\/v1"}]}},"\/real-custom-post-order\/v1\/plugin":{"namespace":"real-custom-post-order\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/real-custom-post-order\/v1\/plugin"}]}},"\/real-utils\/v1":{"namespace":"real-utils\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"real-utils\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/real-utils\/v1"}]}},"\/real-utils\/v1\/feedback\/(?P<slug>[a-zA-Z0-9_-]+)":{"namespace":"real-utils\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"reason":{"type":"string","required":true},"note":{"type":"string","required":true},"email":{"type":"string","required":false}}}]},"\/real-utils\/v1\/cross\/(?P<slug>[a-zA-Z0-9_-]+)\/(?P<action>[a-zA-Z0-9_-]+)\/dismiss":{"namespace":"real-utils\/v1","methods":["DELETE"],"endpoints":[{"methods":["DELETE"],"args":{"force":{"type":"boolean","default":false,"required":false}}}]},"\/real-utils\/v1\/rating\/(?P<slug>[a-zA-Z0-9_-]+)\/dismiss":{"namespace":"real-utils\/v1","methods":["DELETE"],"endpoints":[{"methods":["DELETE"],"args":{"force":{"type":"boolean","default":false,"required":false}}}]},"\/siteground-settings\/v1":{"namespace":"siteground-settings\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"siteground-settings\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/siteground-settings\/v1"}]}},"\/siteground-settings\/v1\/update-settings":{"namespace":"siteground-settings\/v1","methods":["PUT"],"endpoints":[{"methods":["PUT"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/siteground-settings\/v1\/update-settings"}]}},"\/siteground-optimizer\/v1":{"namespace":"siteground-optimizer\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"siteground-optimizer\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/siteground-optimizer\/v1"}]}},"\/siteground-optimizer\/v1\/webp-support":{"namespace":"siteground-optimizer\/v1","methods":["PUT","GET"],"endpoints":[{"methods":["PUT"],"args":[]},{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/siteground-optimizer\/v1\/webp-support"}]}},"\/siteground-optimizer\/v1\/reset-webp-conversion":{"namespace":"siteground-optimizer\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/siteground-optimizer\/v1\/reset-webp-conversion"}]}},"\/siteground-optimizer\/v1\/fetch-options":{"namespace":"siteground-optimizer\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/siteground-optimizer\/v1\/fetch-options"}]}},"\/siteground-optimizer\/v1\/enable-option":{"namespace":"siteground-optimizer\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/siteground-optimizer\/v1\/enable-option"}]}},"\/siteground-optimizer\/v1\/disable-option":{"namespace":"siteground-optimizer\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/siteground-optimizer\/v1\/disable-option"}]}},"\/siteground-optimizer\/v1\/combine-css":{"namespace":"siteground-optimizer\/v1","methods":["PUT"],"endpoints":[{"methods":["PUT"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/siteground-optimizer\/v1\/combine-css"}]}},"\/siteground-optimizer\/v1\/preload-combined-css":{"namespace":"siteground-optimizer\/v1","methods":["PUT"],"endpoints":[{"methods":["PUT"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/siteground-optimizer\/v1\/preload-combined-css"}]}},"\/siteground-optimizer\/v1\/fetch-options\/(?P<page_id>[^\/]+)":{"namespace":"siteground-optimizer\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"page_id":{"required":false}}}]},"\/siteground-optimizer\/v1\/purge-rest-cache":{"namespace":"siteground-optimizer\/v1","methods":["PUT"],"endpoints":[{"methods":["PUT"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/siteground-optimizer\/v1\/purge-rest-cache"}]}},"\/siteground-optimizer\/v1\/logged-in-cache":{"namespace":"siteground-optimizer\/v1","methods":["PUT"],"endpoints":[{"methods":["PUT"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/siteground-optimizer\/v1\/logged-in-cache"}]}},"\/siteground-optimizer\/v1\/enable-gzip-compression":{"namespace":"siteground-optimizer\/v1","methods":["PUT"],"endpoints":[{"methods":["PUT"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/siteground-optimizer\/v1\/enable-gzip-compression"}]}},"\/siteground-optimizer\/v1\/enable-browser-caching":{"namespace":"siteground-optimizer\/v1","methods":["PUT"],"endpoints":[{"methods":["PUT"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/siteground-optimizer\/v1\/enable-browser-caching"}]}},"\/siteground-optimizer\/v1\/optimize-css":{"namespace":"siteground-optimizer\/v1","methods":["PUT"],"endpoints":[{"methods":["PUT"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/siteground-optimizer\/v1\/optimize-css"}]}},"\/siteground-optimizer\/v1\/optimize-javascript":{"namespace":"siteground-optimizer\/v1","methods":["PUT"],"endpoints":[{"methods":["PUT"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/siteground-optimizer\/v1\/optimize-javascript"}]}},"\/siteground-optimizer\/v1\/combine-javascript":{"namespace":"siteground-optimizer\/v1","methods":["PUT"],"endpoints":[{"methods":["PUT"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/siteground-optimizer\/v1\/combine-javascript"}]}},"\/siteground-optimizer\/v1\/optimize-javascript-async":{"namespace":"siteground-optimizer\/v1","methods":["PUT"],"endpoints":[{"methods":["PUT"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/siteground-optimizer\/v1\/optimize-javascript-async"}]}},"\/siteground-optimizer\/v1\/optimize-html":{"namespace":"siteground-optimizer\/v1","methods":["PUT"],"endpoints":[{"methods":["PUT"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/siteground-optimizer\/v1\/optimize-html"}]}},"\/siteground-optimizer\/v1\/optimize-web-fonts":{"namespace":"siteground-optimizer\/v1","methods":["PUT"],"endpoints":[{"methods":["PUT"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/siteground-optimizer\/v1\/optimize-web-fonts"}]}},"\/siteground-optimizer\/v1\/remove-query-strings":{"namespace":"siteground-optimizer\/v1","methods":["PUT"],"endpoints":[{"methods":["PUT"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/siteground-optimizer\/v1\/remove-query-strings"}]}},"\/siteground-optimizer\/v1\/disable-emojis":{"namespace":"siteground-optimizer\/v1","methods":["PUT"],"endpoints":[{"methods":["PUT"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/siteground-optimizer\/v1\/disable-emojis"}]}},"\/siteground-optimizer\/v1\/lazyload-images":{"namespace":"siteground-optimizer\/v1","methods":["PUT"],"endpoints":[{"methods":["PUT"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/siteground-optimizer\/v1\/lazyload-images"}]}},"\/siteground-optimizer\/v1\/backup-media":{"namespace":"siteground-optimizer\/v1","methods":["PUT"],"endpoints":[{"methods":["PUT"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/siteground-optimizer\/v1\/backup-media"}]}},"\/siteground-optimizer\/v1\/enable-cache":{"namespace":"siteground-optimizer\/v1","methods":["PUT"],"endpoints":[{"methods":["PUT"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/siteground-optimizer\/v1\/enable-cache"}]}},"\/siteground-optimizer\/v1\/memcached":{"namespace":"siteground-optimizer\/v1","methods":["PUT"],"endpoints":[{"methods":["PUT"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/siteground-optimizer\/v1\/memcached"}]}},"\/siteground-optimizer\/v1\/autoflush-cache":{"namespace":"siteground-optimizer\/v1","methods":["PUT"],"endpoints":[{"methods":["PUT"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/siteground-optimizer\/v1\/autoflush-cache"}]}},"\/siteground-optimizer\/v1\/purge-cache":{"namespace":"siteground-optimizer\/v1","methods":["PUT"],"endpoints":[{"methods":["PUT"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/siteground-optimizer\/v1\/purge-cache"}]}},"\/siteground-optimizer\/v1\/user-agent-header":{"namespace":"siteground-optimizer\/v1","methods":["PUT"],"endpoints":[{"methods":["PUT"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/siteground-optimizer\/v1\/user-agent-header"}]}},"\/siteground-optimizer\/v1\/test-url-cache":{"namespace":"siteground-optimizer\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/siteground-optimizer\/v1\/test-url-cache"}]}},"\/siteground-optimizer\/v1\/enable-memcache":{"namespace":"siteground-optimizer\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/siteground-optimizer\/v1\/enable-memcache"}]}},"\/siteground-optimizer\/v1\/disable-memcache":{"namespace":"siteground-optimizer\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/siteground-optimizer\/v1\/disable-memcache"}]}},"\/siteground-optimizer\/v1\/file-caching":{"namespace":"siteground-optimizer\/v1","methods":["PUT"],"endpoints":[{"methods":["PUT"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/siteground-optimizer\/v1\/file-caching"}]}},"\/siteground-optimizer\/v1\/file-caching-settings":{"namespace":"siteground-optimizer\/v1","methods":["PUT"],"endpoints":[{"methods":["PUT"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/siteground-optimizer\/v1\/file-caching-settings"}]}},"\/siteground-optimizer\/v1\/enable-multisite-optimization":{"namespace":"siteground-optimizer\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/siteground-optimizer\/v1\/enable-multisite-optimization"}]}},"\/siteground-optimizer\/v1\/disable-multisite-optimization":{"namespace":"siteground-optimizer\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/siteground-optimizer\/v1\/disable-multisite-optimization"}]}},"\/siteground-optimizer\/v1\/run-analysis":{"namespace":"siteground-optimizer\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/siteground-optimizer\/v1\/run-analysis"}]}},"\/siteground-optimizer\/v1\/exclude\/(?P<type>[^\/]+)":{"namespace":"siteground-optimizer\/v1","methods":["PUT","PUT","PUT","PUT","PUT","PUT","PUT","PUT","PUT","PUT","PUT","PUT"],"endpoints":[{"methods":["PUT"],"args":{"type":{"required":false}}},{"methods":["PUT"],"args":{"type":{"required":false}}},{"methods":["PUT"],"args":{"type":{"required":false}}},{"methods":["PUT"],"args":{"type":{"required":false}}},{"methods":["PUT"],"args":{"type":{"required":false}}},{"methods":["PUT"],"args":{"type":{"required":false}}},{"methods":["PUT"],"args":{"type":{"required":false}}},{"methods":["PUT"],"args":{"type":{"required":false}}},{"methods":["PUT"],"args":{"type":{"required":false}}},{"methods":["PUT"],"args":{"type":{"required":false}}},{"methods":["PUT"],"args":{"type":{"required":false}}},{"methods":["PUT"],"args":{"type":{"required":false}}}]},"\/siteground-optimizer\/v1\/feature-popup\/(?P<type>[^\/]+)":{"namespace":"siteground-optimizer\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"type":{"required":false},"page_id":{"required":false}}}]},"\/siteground-optimizer\/v1\/performance-report":{"namespace":"siteground-optimizer\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/siteground-optimizer\/v1\/performance-report"}]}},"\/siteground-optimizer\/v1\/perf-notification-email":{"namespace":"siteground-optimizer\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/siteground-optimizer\/v1\/perf-notification-email"}]}},"\/siteground-optimizer\/v1\/optimize-images":{"namespace":"siteground-optimizer\/v1","methods":["PUT","GET"],"endpoints":[{"methods":["PUT"],"args":[]},{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/siteground-optimizer\/v1\/optimize-images"}]}},"\/siteground-optimizer\/v1\/reset-images-optimization":{"namespace":"siteground-optimizer\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/siteground-optimizer\/v1\/reset-images-optimization"}]}},"\/siteground-optimizer\/v1\/preview-image(?:\/(?P<id>\\d+))?":{"namespace":"siteground-optimizer\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[{"required":false}]}]},"\/siteground-optimizer\/v1\/image-resize":{"namespace":"siteground-optimizer\/v1","methods":["PUT"],"endpoints":[{"methods":["PUT"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/siteground-optimizer\/v1\/image-resize"}]}},"\/siteground-optimizer\/v1\/ssl":{"namespace":"siteground-optimizer\/v1","methods":["PUT"],"endpoints":[{"methods":["PUT"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/siteground-optimizer\/v1\/ssl"}]}},"\/siteground-optimizer\/v1\/fix-insecure-content":{"namespace":"siteground-optimizer\/v1","methods":["PUT"],"endpoints":[{"methods":["PUT"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/siteground-optimizer\/v1\/fix-insecure-content"}]}},"\/siteground-optimizer\/v1\/database-optimization":{"namespace":"siteground-optimizer\/v1","methods":["PUT"],"endpoints":[{"methods":["PUT"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/siteground-optimizer\/v1\/database-optimization"}]}},"\/siteground-optimizer\/v1\/heartbeat\/(?P<location>[^\/]+)":{"namespace":"siteground-optimizer\/v1","methods":["PUT"],"endpoints":[{"methods":["PUT"],"args":{"location":{"required":false}}}]},"\/siteground-optimizer\/v1\/notifications":{"namespace":"siteground-optimizer\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/siteground-optimizer\/v1\/notifications"}]}},"\/siteground-optimizer\/v1\/hardening":{"namespace":"siteground-optimizer\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/siteground-optimizer\/v1\/hardening"}]}},"\/siteground-optimizer\/v1\/e-book":{"namespace":"siteground-optimizer\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/siteground-optimizer\/v1\/e-book"}]}},"\/siteground-optimizer\/v1\/rate":{"namespace":"siteground-optimizer\/v1","methods":["PUT","GET"],"endpoints":[{"methods":["PUT"],"args":[]},{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/siteground-optimizer\/v1\/rate"}]}},"\/uap\/v2":{"namespace":"uap\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"uap\/v2","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/uap\/v2"}]}},"\/uap\/v2\/loop\/process\/(?P<action>\\w+)":{"namespace":"uap\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"process_id":{"required":true}}}]},"\/uap\/v2\/loop\/(?P<recipe_id>\\d+)":{"namespace":"uap\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}]},"\/uap\/v2\/mcp\/chat\/refresh":{"namespace":"uap\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"page_url":{"type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/uap\/v2\/mcp\/chat\/refresh"}]}},"\/uap\/v2\/mcp\/chat\/launcher\/(?P<recipe_id>\\d+)":{"namespace":"uap\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"recipe_id":{"type":"integer","required":true}}}]},"\/automator\/v1":{"namespace":"automator\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"automator\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/automator\/v1"}]}},"\/automator\/v1\/agent-context":{"namespace":"automator\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/automator\/v1\/agent-context"}]}},"\/automator\/v1\/mcp":{"namespace":"automator\/v1","methods":["POST","GET","DELETE"],"endpoints":[{"methods":["POST"],"args":{"jsonrpc":{"type":"string","enum":["2.0"],"required":true},"method":{"type":"string","required":false},"id":{"type":["string","number"],"required":false}}},{"methods":["GET"],"args":[]},{"methods":["DELETE"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/automator\/v1\/mcp"}]}},"\/automator\/v1\/mcp\/dropdown":{"namespace":"automator\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"entity_type":{"type":"string","description":"The entity type: \"action\" or \"trigger\".","required":true},"entity_code":{"type":"string","description":"The action\/trigger code (e.g., SLACKSENDMESSAGE).","required":true},"field_option_code":{"type":"string","description":"The field option code (e.g., SLACKCHANNEL).","required":true},"field_parent_option_code":{"type":"string","description":"Parent field option code for cascading dropdowns (e.g., ASANA_WORKSPACE).","required":false},"field_parent_option_value":{"type":"string","description":"Parent option value for cascading dropdowns.","required":false},"parent_values":{"type":"string","description":"JSON object of multiple parent field values for multi-level cascading (e.g., {\"GSSPREADSHEET\":\"abc123\",\"GSWORKSHEET\":\"xyz789\"}).","required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/automator\/v1\/mcp\/dropdown"}]}},"\/uap\/v2\/recipe\/(?P<recipe_id>\\d+)\/item\/(?P<item_type>[a-zA-Z0-9_-]+)\/(?P<operation>[a-zA-Z0-9_-]+)":{"namespace":"uap\/v2","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"recipe_id":{"required":false},"item_type":{"required":false},"operation":{"required":false}}}]},"\/uap\/v2\/recipe\/(?P<recipe_id>\\d+)\/block\/(?P<block_type>[a-zA-Z0-9_-]+)\/(?P<operation>[a-zA-Z0-9_-]+)":{"namespace":"uap\/v2","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"recipe_id":{"required":false},"block_type":{"required":false},"operation":{"required":false}}}]},"\/uap\/v2\/integrations\/get":{"namespace":"uap\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/uap\/v2\/integrations\/get"}]}},"\/uap\/v2\/integrations\/get\/(?P<scope>[a-zA-Z0-9_-]+)":{"namespace":"uap\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"scope":{"type":"string","required":true}}}]},"\/uap\/v2\/integrations\/collections\/get":{"namespace":"uap\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/uap\/v2\/integrations\/collections\/get"}]}},"\/uap\/v2\/blocks\/get":{"namespace":"uap\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/uap\/v2\/blocks\/get"}]}},"\/uap\/v2\/remote-data\/(?P<id>[a-zA-Z0-9_-]+)\/(?P<data>[a-zA-Z0-9_-]+)":{"namespace":"uap\/v2","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"id":{"type":"string","required":true},"data":{"type":"string","required":true},"recipe_id":{"type":"integer","required":false},"item_id":{"type":["integer","string"],"required":false},"parent_id":{"type":"integer","required":false},"group_id":{"type":"string","required":false},"field_id":{"type":"string","required":false},"triggered_by":{"type":"string","required":false},"values":{"type":"object","required":false},"context":{"type":"string","required":false},"q":{"type":"string","required":false}}}]},"\/uap\/v2\/async_action":{"namespace":"uap\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/uap\/v2\/async_action"}]}},"\/uap\/v2\/log-event":{"namespace":"uap\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/uap\/v2\/log-event"}]}},"\/automator\/v1\/email\/test":{"namespace":"automator\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/automator\/v1\/email\/test"}]}},"\/automator\/v1\/user\/(?P<id>\\d+)":{"namespace":"automator\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/automator\/v1\/log\/recipe_id\/(?P<recipe_id>\\d+)\/run_number\/(?P<run_number>\\d+)\/recipe_log_id\/(?P<recipe_log_id>\\d+)":{"namespace":"automator\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/automator\/v1\/log\/loop-runs\/(?P<recipe_id>\\d+)\/(?P<run_number>\\d+)\/(?P<recipe_log_id>\\d+)\/(?P<action_id>\\d+)":{"namespace":"automator\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/automator\/v1\/license\/summary":{"namespace":"automator\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/automator\/v1\/license\/summary"}]}},"\/automator\/v1\/addons\/get-list\/(?P<list_code>\\w+)":{"namespace":"automator\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/automator\/v1\/replay\/(?P<recipe_log_id>\\d+)":{"namespace":"automator\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}]},"\/automator\/v1\/addons\/plugin-manager\/(?P<action>\\w+)\/(?P<addon_id>\\d+)":{"namespace":"automator\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}]},"\/uap\/v2\/integration-settings\/(?P<integration_id>[a-zA-Z0-9_-]+)":{"namespace":"uap\/v2","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"integration_id":{"required":true},"action":{"required":true},"data":{"type":"object","required":false}}}]},"\/yoast\/v1":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"yoast\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/yoast\/v1"}]}},"\/yoast\/v1\/file_size":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"type":"string","description":"The url to retrieve","required":true}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/yoast\/v1\/file_size"}]}},"\/yoast\/v1\/statistics":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/yoast\/v1\/statistics"}]}},"\/yoast\/v1\/ai_generator\/callback":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"access_jwt":{"type":"string","description":"The access JWT.","required":true},"refresh_jwt":{"type":"string","description":"The JWT to be used when the access JWT needs to be refreshed.","required":true},"code_challenge":{"type":"string","description":"The SHA266 of the verification code used to check the authenticity of a callback call.","required":true},"user_id":{"type":"integer","description":"The id of the user associated to the code verifier.","required":true}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/yoast\/v1\/ai_generator\/callback"}]}},"\/yoast\/v1\/ai_generator\/refresh_callback":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"access_jwt":{"type":"string","description":"The access JWT.","required":true},"refresh_jwt":{"type":"string","description":"The JWT to be used when the access JWT needs to be refreshed.","required":true},"code_challenge":{"type":"string","description":"The SHA266 of the verification code used to check the authenticity of a callback call.","required":true},"user_id":{"type":"integer","description":"The id of the user associated to the code verifier.","required":true}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/yoast\/v1\/ai_generator\/refresh_callback"}]}},"\/yoast\/v1\/ai_generator\/consent":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"consent":{"type":"boolean","description":"Whether the consent to use AI-based services has been given by the user.","required":true}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/yoast\/v1\/ai_generator\/consent"}]}},"\/yoast\/v1\/ai_content_planner\/banner_permanent_dismissal":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"is_dismissed":{"type":"bool","required":true}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/yoast\/v1\/ai_content_planner\/banner_permanent_dismissal"}]}},"\/yoast\/v1\/ai_content_planner\/get_outline":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"post_type":{"type":"string","description":"The post type to get a content outline for.","required":true},"language":{"type":"string","description":"The language the content is written in.","required":true},"editor":{"type":"string","enum":["classic","elementor","gutenberg"],"description":"The current editor.","required":true},"title":{"type":"string","description":"The title of the chosen content suggestion.","required":true},"intent":{"type":"string","description":"The intent of the chosen content suggestion.","required":true},"explanation":{"type":"string","description":"The explanation of the chosen content suggestion.","required":true},"keyphrase":{"type":"string","description":"The keyphrase of the chosen content suggestion.","required":true},"meta_description":{"type":"string","description":"The meta description of the chosen content suggestion.","required":true},"category":{"type":"object","properties":{"name":{"type":"string","required":true},"id":{"type":"integer","required":true}},"description":"The category of the chosen content suggestion. Use name \"\" and id -1 to indicate no category.","required":true},"recent_content":{"type":"array","maxItems":100,"items":{"type":"object","properties":{"title":{"type":"string","required":true,"maxLength":500},"description":{"type":"string","required":true,"maxLength":1000}},"additionalProperties":false},"description":"The recent content returned by the get_suggestions response.","required":true}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/yoast\/v1\/ai_content_planner\/get_outline"}]}},"\/yoast\/v1\/ai_content_planner\/get_suggestions":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"post_type":{"type":"string","description":"The post type to get content suggestions for.","required":true},"language":{"type":"string","description":"The language the content is written in.","required":true},"editor":{"type":"string","enum":["classic","elementor","gutenberg"],"description":"The current editor.","required":true}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/yoast\/v1\/ai_content_planner\/get_suggestions"}]}},"\/yoast\/v1\/ai\/free_sparks":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/yoast\/v1\/ai\/free_sparks"}]}},"\/yoast\/v1\/ai_generator\/bust_subscription_cache":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/yoast\/v1\/ai_generator\/bust_subscription_cache"}]}},"\/yoast\/v1\/ai_generator\/get_suggestions":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"type":{"type":"string","enum":["seo-title","meta-description","product-seo-title","product-meta-description","product-taxonomy-seo-title","product-taxonomy-meta-description","taxonomy-seo-title","taxonomy-meta-description"],"description":"The type of suggestion requested.","required":true},"prompt_content":{"type":"string","description":"The content needed by the prompt to ask for suggestions.","required":true},"focus_keyphrase":{"type":"string","description":"The focus keyphrase associated to the post.","required":true},"language":{"type":"string","description":"The language the post is written in.","required":true},"platform":{"type":"string","enum":["Google","Facebook","Twitter"],"description":"The platform the post is intended for.","required":true},"editor":{"type":"string","enum":["classic","elementor","gutenberg"],"description":"The current editor.","required":true}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/yoast\/v1\/ai_generator\/get_suggestions"}]}},"\/yoast\/v1\/ai_generator\/get_usage":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"is_woo_product_entity":{"type":"boolean","default":false,"required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/yoast\/v1\/ai_generator\/get_usage"}]}},"\/yoast\/v1\/bulk_editor\/posts_content":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"ids":{"type":"array","minItems":1,"maxItems":20,"items":{"type":"integer","minimum":1},"description":"The IDs of the posts to return the content of. Accepts a comma separated list.","required":true}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/yoast\/v1\/bulk_editor\/posts_content"}]}},"\/yoast\/v1\/bulk_editor\/posts":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"content_type":{"type":"string","description":"The content type to fetch posts for.","required":true},"per_page":{"type":"integer","default":20,"minimum":1,"maximum":100,"description":"The number of posts to fetch.","required":false},"page":{"type":"integer","default":1,"minimum":1,"description":"The page of posts to fetch.","required":false},"search":{"type":"string","default":"","description":"The term to search posts by.","required":false},"status":{"type":"array","default":["publish","draft","pending","future"],"items":{"type":"string","enum":["publish","draft","pending","future"]},"description":"The post statuses to include.","required":false},"needs_improvement":{"type":"array","default":[],"items":{"type":"string","enum":["seo_title","meta_description","social_title","social_description"]},"description":"The fields to filter posts by; a field matches when it is empty, or (for search fields, while SEO analysis is enabled and the content type shows Yoast's controls and assessments) when its score needs improvement.","required":false},"include":{"type":"array","default":[],"maxItems":100,"items":{"type":"integer","minimum":1},"description":"Limits the posts to these post IDs, e.g. a selection carried over from the posts overview.","required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/yoast\/v1\/bulk_editor\/posts"}]}},"\/yoast\/v1\/bulk_editor\/update_scores":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"items":{"type":"array","description":"The per-post score updates to apply.","required":true}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/yoast\/v1\/bulk_editor\/update_scores"}]}},"\/yoast\/v1\/bulk_editor\/update_search":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"items":{"type":"array","description":"The per-post updates to apply.","required":true}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/yoast\/v1\/bulk_editor\/update_search"}]}},"\/yoast\/v1\/bulk_editor\/update_social":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"items":{"type":"array","description":"The per-post updates to apply.","required":true}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/yoast\/v1\/bulk_editor\/update_social"}]}},"\/yoast\/v1\/new-content-type-visibility\/dismiss-post-type":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"postTypeName":{"required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/yoast\/v1\/new-content-type-visibility\/dismiss-post-type"}]}},"\/yoast\/v1\/new-content-type-visibility\/dismiss-taxonomy":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"taxonomyName":{"required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/yoast\/v1\/new-content-type-visibility\/dismiss-taxonomy"}]}},"\/yoast\/v1\/site_kit_configuration_permanent_dismissal":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"is_dismissed":{"type":"bool","required":true}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/yoast\/v1\/site_kit_configuration_permanent_dismissal"}]}},"\/yoast\/v1\/readability_scores":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"contentType":{"type":"string","required":true},"taxonomy":{"type":"string","default":"","required":false},"term":{"type":"integer","default":null,"required":false},"troubleshooting":{"type":"bool","default":null,"required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/yoast\/v1\/readability_scores"}]}},"\/yoast\/v1\/seo_scores":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"contentType":{"type":"string","required":true},"taxonomy":{"type":"string","default":"","required":false},"term":{"type":"integer","default":null,"required":false},"troubleshooting":{"type":"bool","default":null,"required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/yoast\/v1\/seo_scores"}]}},"\/yoast\/v1\/setup_steps_tracking":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"setup_widget_loaded":{"type":"string","enum":["yes","no"],"required":false},"first_interaction_stage":{"type":"string","enum":["install","activate","setup","grantConsent","successfullyConnected"],"required":false},"last_interaction_stage":{"type":"string","enum":["install","activate","setup","grantConsent","successfullyConnected"],"required":false},"setup_widget_temporarily_dismissed":{"type":"string","enum":["yes","no"],"required":false},"setup_widget_permanently_dismissed":{"type":"string","enum":["yes","no"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/yoast\/v1\/setup_steps_tracking"}]}},"\/yoast\/v1\/introductions\/(?P<introduction_id>[\\w-]+)\/seen":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"introduction_id":{"type":"string","required":true},"is_seen":{"type":"bool","default":true,"required":false}}}]},"\/yoast\/v1\/wistia_embed_permission":{"namespace":"yoast\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":{"value":{"type":"bool","default":true,"required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/yoast\/v1\/wistia_embed_permission"}]}},"\/yoast\/v1\/available_posts":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"search":{"type":"string","default":"","required":false},"postType":{"type":"string","default":"page","required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/yoast\/v1\/available_posts"}]}},"\/yoast\/v1\/alerts\/dismiss":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"key":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/yoast\/v1\/alerts\/dismiss"}]}},"\/yoast\/v1\/configuration\/site_representation":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"company_or_person":{"type":"string","enum":["company","person"],"required":true},"company_name":{"type":"string","required":false},"company_logo":{"type":"string","required":false},"company_logo_id":{"type":"integer","required":false},"person_logo":{"type":"string","required":false},"person_logo_id":{"type":"integer","required":false},"company_or_person_user_id":{"type":"integer","required":false},"description":{"type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/yoast\/v1\/configuration\/site_representation"}]}},"\/yoast\/v1\/configuration\/social_profiles":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"facebook_site":{"type":"string","required":false},"twitter_site":{"type":"string","required":false},"other_social_urls":{"type":"array","required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/yoast\/v1\/configuration\/social_profiles"}]}},"\/yoast\/v1\/configuration\/check_capability":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"user_id":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/yoast\/v1\/configuration\/check_capability"}]}},"\/yoast\/v1\/configuration\/enable_tracking":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"tracking":{"type":"boolean","required":true}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/yoast\/v1\/configuration\/enable_tracking"}]}},"\/yoast\/v1\/configuration\/save_configuration_state":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"finishedSteps":{"type":"array","required":true}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/yoast\/v1\/configuration\/save_configuration_state"}]}},"\/yoast\/v1\/configuration\/get_configuration_state":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/yoast\/v1\/configuration\/get_configuration_state"}]}},"\/yoast\/v1\/import\/(?P<plugin>[\\w-]+)\/(?P<type>[\\w-]+)":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}]},"\/yoast\/v1\/get_head":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/yoast\/v1\/get_head"}]}},"\/yoast\/v1\/indexing\/posts":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/yoast\/v1\/indexing\/posts"}]}},"\/yoast\/v1\/indexing\/terms":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/yoast\/v1\/indexing\/terms"}]}},"\/yoast\/v1\/indexing\/post-type-archives":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/yoast\/v1\/indexing\/post-type-archives"}]}},"\/yoast\/v1\/indexing\/general":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/yoast\/v1\/indexing\/general"}]}},"\/yoast\/v1\/indexing\/prepare":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/yoast\/v1\/indexing\/prepare"}]}},"\/yoast\/v1\/indexing\/indexables-complete":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/yoast\/v1\/indexing\/indexables-complete"}]}},"\/yoast\/v1\/indexing\/complete":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/yoast\/v1\/indexing\/complete"}]}},"\/yoast\/v1\/link-indexing\/posts":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/yoast\/v1\/link-indexing\/posts"}]}},"\/yoast\/v1\/link-indexing\/terms":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/yoast\/v1\/link-indexing\/terms"}]}},"\/yoast\/v1\/integrations\/set_active":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"active":{"type":"boolean","required":true},"integration":{"type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/yoast\/v1\/integrations\/set_active"}]}},"\/yoast\/v1\/meta\/search":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/yoast\/v1\/meta\/search"}]}},"\/yoast\/v1\/semrush\/authenticate":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"code":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/yoast\/v1\/semrush\/authenticate"}]}},"\/yoast\/v1\/semrush\/country_code":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"country_code":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/yoast\/v1\/semrush\/country_code"}]}},"\/yoast\/v1\/semrush\/related_keyphrases":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"keyphrase":{"required":true},"country_code":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/yoast\/v1\/semrush\/related_keyphrases"}]}},"\/yoast\/v1\/workouts":{"namespace":"yoast\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":{"cornerstone":{"required":true},"orphaned":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/yoast\/v1\/workouts"}]}},"\/yoast\/v1\/complete_task":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"options":{"type":"object","properties":{"task":{"type":"string","required":true,"sanitize_callback":"sanitize_text_field"}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/yoast\/v1\/complete_task"}]}},"\/yoast\/v1\/get_tasks":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"options":{"type":"object","properties":{"filter":{"type":"string","required":false,"sanitize_callback":"sanitize_text_field"},"limit":{"type":"int","required":false,"sanitize_callback":"absint"}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/yoast\/v1\/get_tasks"}]}},"\/yoast\/v1\/action_tracking":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"action":{"type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/yoast\/v1\/action_tracking"}]}},"\/yoast\/v1\/ai\/bulk_suggestions":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"subjects":{"type":"array","minItems":1,"maxItems":20,"description":"The subjects to fetch suggestions for.","items":{"type":"object","required":["id","type","content"],"properties":{"id":{"type":"integer","minimum":1,"description":"The post ID."},"type":{"type":"string","enum":["seo-title","meta-description"],"description":"The type of suggestion requested."},"content":{"type":"string","maxLength":20000,"description":"The prompt content the suggestion should be based on, collected client-side by the analysis engine."},"content_length":{"type":"integer","minimum":0,"description":"The visible-text length of the post, measured client-side. Omitted when it could not be measured, in which case the content length is not judged."},"platform":{"type":"string","enum":["Google","Facebook","Twitter"],"description":"The platform the suggestion is intended for."}}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/yoast\/v1\/ai\/bulk_suggestions"}]}},"\/yoast\/v1\/ai\/optimize":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"assessment":{"type":"string","enum":["seo-keyphrase-introduction","seo-keyphrase-density","seo-keyphrase-distribution","seo-keyphrase-subheadings","read-sentence-length","read-paragraph-length"],"description":"The assessment.","required":true},"language":{"type":"string","description":"The language the post is written in.","required":true},"prompt_content":{"type":"string","description":"The content needed by the prompt to ask for suggestions.","required":true},"focus_keyphrase":{"type":"string","description":"The focus keyphrase associated to the post.","required":false},"synonyms":{"type":"string","description":"The synonyms for the focus keyphrase.","required":false},"editor":{"type":"string","enum":["Classic","Gutenberg"],"description":"The editor type, either Classic or Gutenberg.","required":true}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/yoast\/v1\/ai\/optimize"}]}},"\/yoast\/v1\/ai\/summarize":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"language":{"type":"string","description":"The language the post is written in.","required":true},"prompt_content":{"type":"string","description":"The content needed by the prompt to ask for a summary.","required":true},"focus_keyphrase":{"type":"string","description":"The focus keyphrase associated to the post.","required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/yoast\/v1\/ai\/summarize"}]}},"\/yoast\/v1\/link_suggestions":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"prominent_words":{"type":"object","description":"Stems of prominent words and their term frequencies we want link suggestions based on","required":true},"object_id":{"type":"integer","description":"The object id of the current indexable.","required":true},"object_type":{"type":"string","description":"The object type of the current indexable.","required":true},"limit":{"default":5,"type":"integer","description":"The maximum number of link suggestions to retrieve","required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/yoast\/v1\/link_suggestions"}]}},"\/yoast\/v1\/prominent_words\/get_content":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/yoast\/v1\/prominent_words\/get_content"}]}},"\/yoast\/v1\/prominent_words\/complete":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/yoast\/v1\/prominent_words\/complete"}]}},"\/yoast\/v1\/prominent_words\/save":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"data":{"type":"array","items":{"type":"object","properties":{"object_id":{"type":"number","required":true},"prominent_words":{"type":"object","required":false}}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/yoast\/v1\/prominent_words\/save"}]}},"\/yoast\/v1\/workouts\/noindex":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"object_id":{"type":"integer","required":true},"object_type":{"type":"string","required":true},"object_sub_type":{"type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/yoast\/v1\/workouts\/noindex"}]}},"\/yoast\/v1\/workouts\/remove_redirect":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"object_id":{"type":"integer","required":true},"object_type":{"type":"string","required":true},"object_sub_type":{"type":"string","required":true},"permalink":{"type":"string","required":true},"redirect_url":{"type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/yoast\/v1\/workouts\/remove_redirect"}]}},"\/yoast\/v1\/workouts\/link_suggestions":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"indexableId":{"type":"integer","required":true}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/yoast\/v1\/workouts\/link_suggestions"}]}},"\/yoast\/v1\/workouts\/last_updated":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"postId":{"type":"integer","required":true}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/yoast\/v1\/workouts\/last_updated"}]}},"\/yoast\/v1\/workouts\/cornerstone_data":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/yoast\/v1\/workouts\/cornerstone_data"}]}},"\/yoast\/v1\/workouts\/enable_cornerstone":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"object_id":{"type":"integer","required":true},"object_type":{"type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/yoast\/v1\/workouts\/enable_cornerstone"}]}},"\/uap\/v2\/actions_conditions_update":{"namespace":"uap\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/uap\/v2\/actions_conditions_update"}]}},"\/uap\/v2\/actions_conditions_fields":{"namespace":"uap\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/uap\/v2\/actions_conditions_fields"}]}},"\/uap\/v2\/actions_order_and_conditions":{"namespace":"uap\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/uap\/v2\/actions_order_and_conditions"}]}},"\/yoast\/v1\/redirects":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"origin":{"type":"string","description":"The origin to redirect","required":true},"target":{"type":"string","description":"The redirect target","required":false},"type":{"type":"integer","description":"The redirect type","required":true},"ignore_warning":{"type":"boolean","description":"Whether to ignore warnings","default":false,"required":false},"format":{"description":"O formato do redirecionamento a ser criado.","type":"string","enum":["plain","regex"],"default":"plain","required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/yoast\/v1\/redirects"}]}},"\/yoast\/v1\/redirects\/delete":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"origin":{"type":"string","description":"The origin to redirect","required":true},"target":{"type":"string","description":"The redirect target","required":false},"type":{"type":"string","description":"The redirect format","required":false},"ignore_warning":{"type":"boolean","description":"Whether to ignore warnings","default":false,"required":false},"format":{"description":"O formato do redirecionamento a ser criado.","type":"string","enum":["plain","regex"],"default":"plain","required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/yoast\/v1\/redirects\/delete"}]}},"\/yoast\/v1\/redirects\/list":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"format":{"description":"Op\u00e7\u00e3o para desativar os redirecionamentos baseados em PHP e usar o arquivo .htaccess em vez disso.","type":"string","enum":["plain","regex"],"default":"plain","required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/yoast\/v1\/redirects\/list"}]}},"\/yoast\/v1\/redirects\/update":{"namespace":"yoast\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"old_origin":{"type":"string","description":"The origin to redirect (old)","required":true},"old_target":{"type":"string","description":"The redirect target (old)","required":false},"old_type":{"type":"integer","description":"The redirect type (old)","required":true},"new_origin":{"type":"string","description":"The origin to redirect (new)","required":true},"new_target":{"type":"string","description":"The redirect target (new)","required":false},"new_type":{"type":"integer","description":"The redirect type (new)","required":true},"ignore_warning":{"type":"boolean","description":"Whether to ignore warnings","default":false,"required":false},"format":{"description":"Op\u00e7\u00e3o para desativar os redirecionamentos baseados em PHP e usar o arquivo .htaccess em vez disso.","type":"string","enum":["plain","regex"],"default":"plain","required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/yoast\/v1\/redirects\/update"}]}},"\/yoast\/v1\/redirects\/settings":{"namespace":"yoast\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":{"disable_php_redirect":{"description":"Op\u00e7\u00e3o para desativar os redirecionamentos baseados em PHP e usar o arquivo .htaccess em vez disso.","type":"string","enum":["on","off"],"required":true},"separate_file":{"description":"Se as configura\u00e7\u00f5es de redirecionamento devem ser gravadas em um arquivo separado em vez do .htaccess.","type":"string","enum":["on","off"],"required":true}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/yoast\/v1\/redirects\/settings"}]}},"\/yoast\/v1\/redirects\/undo-for-object":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"obj_id":{"type":"int","description":"The id of the post or term","required":true},"obj_type":{"type":"string","description":"The object type: post or term","required":true}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/yoast\/v1\/redirects\/undo-for-object"}]}},"\/biblus\/v1":{"namespace":"biblus\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"biblus\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/biblus\/v1"}]}},"\/biblus\/v1\/latest-posts":{"namespace":"biblus\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"tags":{"type":"string","description":"Slug di uno o pi\u00f9 tag (post_tag) separati da virgola. Vengono restituiti i post con almeno uno dei tag indicati.","required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/biblus\/v1\/latest-posts"}]}},"\/uap\/v2\/run-now\/start\/(?P<recipe_id>\\d+)":{"namespace":"uap\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"recipe_id":{"required":true}}}]},"\/real-custom-post-order\/v1\/move":{"namespace":"real-custom-post-order\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"type":{"type":"string","enum":["post"],"required":true},"sequence":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/real-custom-post-order\/v1\/move"}]}},"\/real-custom-post-order\/v1\/post\/firstTimePointer":{"namespace":"real-custom-post-order\/v1","methods":["DELETE"],"endpoints":[{"methods":["DELETE"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/real-custom-post-order\/v1\/post\/firstTimePointer"}]}},"\/regenerate-thumbnails\/v1":{"namespace":"regenerate-thumbnails\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"regenerate-thumbnails\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/regenerate-thumbnails\/v1"}]}},"\/regenerate-thumbnails\/v1\/regenerate\/(?P<id>[\\d]+)":{"namespace":"regenerate-thumbnails\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET","POST","PUT","PATCH","DELETE"],"args":{"only_regenerate_missing_thumbnails":{"description":"Criar apenas miniaturas faltando. \u00c9 mais r\u00e1pido quando ativado.","type":"boolean","default":true,"required":false},"delete_unregistered_thumbnail_files":{"description":"Excluir qualquer miniatura antiga que n\u00e3o esteja registrada agora.","type":"boolean","default":false,"required":false},"update_usages_in_posts":{"description":"Atualizar as tags da imagem em qualquer post que fa\u00e7a o uso deste anexo.","type":"boolean","default":true,"required":false},"update_usages_in_posts_post_type":{"description":"Tipos de posts a atualizar. O padr\u00e3o \u00e9 atualizar todos os tipos de posts p\u00fablicos.","type":"array","default":[],"required":false},"update_usages_in_posts_post_ids":{"description":"Atualizar IDs de posts espec\u00edficos ao inv\u00e9s de qualquer post que use este anexo.","type":"array","default":[],"required":false},"update_usages_in_posts_posts_per_loop":{"description":"Posts para processar por vez. Isso \u00e9 para controlar o uso de mem\u00f3ria e voc\u00ea provavelmente n\u00e3o precisa ajustar isso.","type":"integer","default":10,"required":false}}}]},"\/regenerate-thumbnails\/v1\/attachmentinfo\/(?P<id>[\\d]+)":{"namespace":"regenerate-thumbnails\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/regenerate-thumbnails\/v1\/featuredimages":{"namespace":"regenerate-thumbnails\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"page":{"description":"P\u00e1gina atual da cole\u00e7\u00e3o.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de itens retornados no resultado.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/regenerate-thumbnails\/v1\/featuredimages"}]}},"\/uap\/v2\/get_recipe":{"namespace":"uap\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/uap\/v2\/get_recipe"}]}},"\/uap\/v2\/create":{"namespace":"uap\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/uap\/v2\/create"}]}},"\/uap\/v2\/add":{"namespace":"uap\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/uap\/v2\/add"}]}},"\/uap\/v2\/delete":{"namespace":"uap\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/uap\/v2\/delete"}]}},"\/uap\/v2\/update":{"namespace":"uap\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/uap\/v2\/update"}]}},"\/uap\/v2\/get_options":{"namespace":"uap\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/uap\/v2\/get_options"}]}},"\/uap\/v2\/change_post_status":{"namespace":"uap\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/uap\/v2\/change_post_status"}]}},"\/uap\/v2\/change_post_recipe_type":{"namespace":"uap\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/uap\/v2\/change_post_recipe_type"}]}},"\/uap\/v2\/set_walkthrough_progress":{"namespace":"uap\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/uap\/v2\/set_walkthrough_progress"}]}},"\/uap\/v2\/change_post_title":{"namespace":"uap\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/uap\/v2\/change_post_title"}]}},"\/uap\/v2\/change_recipe_notes":{"namespace":"uap\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/uap\/v2\/change_recipe_notes"}]}},"\/uap\/v2\/recipe_completions_allowed":{"namespace":"uap\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/uap\/v2\/recipe_completions_allowed"}]}},"\/uap\/v2\/recipe_max_completions_allowed":{"namespace":"uap\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/uap\/v2\/recipe_max_completions_allowed"}]}},"\/uap\/v2\/set_recipe_terms":{"namespace":"uap\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/uap\/v2\/set_recipe_terms"}]}},"\/uap\/v2\/user-selector":{"namespace":"uap\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/uap\/v2\/user-selector"}]}},"\/uap\/v2\/trigger-options":{"namespace":"uap\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/uap\/v2\/trigger-options"}]}},"\/uap\/v2\/schedule_action":{"namespace":"uap\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/uap\/v2\/schedule_action"}]}},"\/uap\/v2\/remove_schedule":{"namespace":"uap\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/uap\/v2\/remove_schedule"}]}},"\/uap\/v2\/set_recipe_requires_user":{"namespace":"uap\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/uap\/v2\/set_recipe_requires_user"}]}},"\/uap\/v2\/actions_order":{"namespace":"uap\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/uap\/v2\/actions_order"}]}},"\/uap\/v2\/set_any_or_all_trigger_option":{"namespace":"uap\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/uap\/v2\/set_any_or_all_trigger_option"}]}},"\/uap\/v2\/duplicate_action":{"namespace":"uap\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/uap\/v2\/duplicate_action"}]}},"\/uap\/v2\/resend_api_request":{"namespace":"uap\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/uap\/v2\/resend_api_request"}]}},"\/uap\/v2\/triggers_change_logic":{"namespace":"uap\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/uap\/v2\/triggers_change_logic"}]}},"\/uap\/v2\/recipe_update_setting":{"namespace":"uap\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/uap\/v2\/recipe_update_setting"}]}},"\/wp\/v2":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp\/v2","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/wp\/v2"}]}},"\/wp\/v2\/posts":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina atual da cole\u00e7\u00e3o.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de itens retornados no resultado.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar resultados para aqueles que combinam com um texto.","type":"string","required":false},"after":{"description":"Limitar respostas a posts publicados depois de uma determinada data compat\u00edvel com o formato ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limitar respostas a posts modificados depois de uma determinada data compat\u00edvel com o formato ISO8601.","type":"string","format":"date-time","required":false},"author":{"description":"Limitar resultados a posts atribu\u00eddos a autores espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Garantir que o resultado exclui posts atribu\u00eddos a autores espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limitar respostas a posts publicados antes de uma determinada data compat\u00edvel com o formato ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limitar respostas a posts modificados antes de uma determinada data compat\u00edvel com o formato ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Garantir que o resultado exclua IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar resultados para IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Como interpretar o campo de pesquisa.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Deslocar o resultado para um n\u00famero especifico de itens.","type":"integer","required":false},"order":{"description":"Ordenar atributos de forma ascendente ou descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar cole\u00e7\u00e3o pelo atributo do post.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array de nomes de colunas para serem pesquisadas.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limitar resultados de posts definidos por um ou mais slugs espec\u00edficos.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limitar resultados de posts atribu\u00eddo por um ou mais status.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","flamingo-spam","avvia_traduzione","crea_task_resolver","any"],"type":"string"},"required":false},"tax_relation":{"description":"Limitar resultados com base no relacionamento entre m\u00faltiplas taxonomias.","type":"string","enum":["AND","OR"],"required":false},"categories":{"description":"Limitar resultados para todos os itens com termos espec\u00edficos atribu\u00eddos a taxonomia categories.","type":["object","array"],"oneOf":[{"title":"Lista de ID de termos","description":"Combinar os termos com os IDs listados.","type":"array","items":{"type":"integer"}},{"title":"Consulta da taxonomia do ID do termo","description":"Executar uma consulta avan\u00e7a de termos.","type":"object","properties":{"terms":{"description":"IDs dos termos.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Possibilidade de incluir termos descendentes nos termos limitando o conjunto de resultados.","type":"boolean","default":false},"operator":{"description":"Se os items devem ser atribu\u00eddos a todos ou a qualquer um dos termos especificados.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"categories_exclude":{"description":"Limitar resultados para todos os itens que tenham o termo espec\u00edfico atribu\u00eddo para a taxonomia categories.","type":["object","array"],"oneOf":[{"title":"Lista de ID de termos","description":"Combinar os termos com os IDs listados.","type":"array","items":{"type":"integer"}},{"title":"Consulta da taxonomia do ID do termo","description":"Executar uma consulta avan\u00e7a de termos.","type":"object","properties":{"terms":{"description":"IDs dos termos.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Possibilidade de incluir termos descendentes nos termos limitando o conjunto de resultados.","type":"boolean","default":false}},"additionalProperties":false}],"required":false},"tags":{"description":"Limitar resultados para todos os itens com termos espec\u00edficos atribu\u00eddos a taxonomia tags.","type":["object","array"],"oneOf":[{"title":"Lista de ID de termos","description":"Combinar os termos com os IDs listados.","type":"array","items":{"type":"integer"}},{"title":"Consulta da taxonomia do ID do termo","description":"Executar uma consulta avan\u00e7a de termos.","type":"object","properties":{"terms":{"description":"IDs dos termos.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Se os items devem ser atribu\u00eddos a todos ou a qualquer um dos termos especificados.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"tags_exclude":{"description":"Limitar resultados para todos os itens que tenham o termo espec\u00edfico atribu\u00eddo para a taxonomia tags.","type":["object","array"],"oneOf":[{"title":"Lista de ID de termos","description":"Combinar os termos com os IDs listados.","type":"array","items":{"type":"integer"}},{"title":"Consulta da taxonomia do ID do termo","description":"Executar uma consulta avan\u00e7a de termos.","type":"object","properties":{"terms":{"description":"IDs dos termos.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"sticky":{"description":"Limitar resultados de itens que sejam fixos.","type":"boolean","required":false},"ignore_sticky":{"description":"Se deve ou n\u00e3o ignorar os artigos fixos.","type":"boolean","default":true,"required":false},"format":{"description":"Limita conjunto de resultados a itens atribu\u00eddos a um ou mais formatos espec\u00edficos.","type":"array","uniqueItems":true,"items":{"enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"Data da publica\u00e7\u00e3o do post, no fuso hor\u00e1rio do site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Data que o post foi publicado, em GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Um identificador alfanum\u00e9rico para o post.","type":"string","required":false},"status":{"description":"Um nome de status para o post.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","avvia_traduzione","crea_task_resolver"],"required":false},"password":{"description":"Uma senha para proteger o acesso ao conte\u00fado e resumo.","type":"string","required":false},"title":{"description":"O t\u00edtulo para o post.","type":"object","properties":{"raw":{"description":"T\u00edtulo para o post, como existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo para o post em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"O conte\u00fado para o post.","type":"object","properties":{"raw":{"description":"Conte\u00fado para o post, como ele existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"Conte\u00fado HTML do post, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Vers\u00e3o do formato do conte\u00fado do bloco usado pelo post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Se o conte\u00fado \u00e9 protegido por senha.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"O ID do autor para o post.","type":"integer","required":false},"excerpt":{"description":"O resumo para o post.","type":"object","properties":{"raw":{"description":"Resumo para o post, como existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"Resumo para o post em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Se o resumo \u00e9 protegido por senha.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"O ID da imagem destacada para o post.","type":"integer","required":false},"comment_status":{"description":"Se os coment\u00e1rios no post devem ou n\u00e3o ser abertos.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Se o post pode receber chamadas ping.","type":"string","enum":["open","closed"],"required":false},"format":{"description":"O formato para o post.","type":"string","enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"required":false},"meta":{"description":"Campos meta.","type":"object","properties":{"_yoast_wpseo_focuskw":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_title":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_metadesc":{"type":"string","title":"","description":"","default":""},"_data_scadenza_evento":{"type":"string","title":"","description":"","default":""},"_evento_nome":{"type":"string","title":"","description":"","default":""},"_evento_data":{"type":"string","title":"","description":"","default":""},"_evento_luogo":{"type":"string","title":"","description":"","default":""},"_evento_cta":{"type":"string","title":"","description":"","default":""},"keyword_en":{"type":"string","title":"","description":"","default":""},"keyword_es":{"type":"string","title":"","description":"","default":""},"keyword_fr":{"type":"string","title":"","description":"","default":""},"keyword_de":{"type":"string","title":"","description":"","default":""},"keyword_ptb":{"type":"string","title":"","description":"","default":""},"_note_content":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"sticky":{"description":"Se o post deve ser tratado como fixo.","type":"boolean","required":false},"template":{"description":"O arquivo do tema usado para exibir o post.","type":"string","required":false},"categories":{"description":"Os termos atribu\u00eddos ao post na taxonomia category.","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"Os termos atribu\u00eddos ao post na taxonomia post_tag.","type":"array","items":{"type":"integer"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/wp\/v2\/posts"}]}},"\/wp\/v2\/posts\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o post.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"Substitui o tamanho padr\u00e3o do resumo.","type":"integer","required":false},"password":{"description":"A senha para o post se este for protegido por senha.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o post.","type":"integer","required":false},"date":{"description":"Data da publica\u00e7\u00e3o do post, no fuso hor\u00e1rio do site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Data que o post foi publicado, em GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Um identificador alfanum\u00e9rico para o post.","type":"string","required":false},"status":{"description":"Um nome de status para o post.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","avvia_traduzione","crea_task_resolver"],"required":false},"password":{"description":"Uma senha para proteger o acesso ao conte\u00fado e resumo.","type":"string","required":false},"title":{"description":"O t\u00edtulo para o post.","type":"object","properties":{"raw":{"description":"T\u00edtulo para o post, como existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo para o post em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"O conte\u00fado para o post.","type":"object","properties":{"raw":{"description":"Conte\u00fado para o post, como ele existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"Conte\u00fado HTML do post, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Vers\u00e3o do formato do conte\u00fado do bloco usado pelo post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Se o conte\u00fado \u00e9 protegido por senha.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"O ID do autor para o post.","type":"integer","required":false},"excerpt":{"description":"O resumo para o post.","type":"object","properties":{"raw":{"description":"Resumo para o post, como existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"Resumo para o post em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Se o resumo \u00e9 protegido por senha.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"O ID da imagem destacada para o post.","type":"integer","required":false},"comment_status":{"description":"Se os coment\u00e1rios no post devem ou n\u00e3o ser abertos.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Se o post pode receber chamadas ping.","type":"string","enum":["open","closed"],"required":false},"format":{"description":"O formato para o post.","type":"string","enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"required":false},"meta":{"description":"Campos meta.","type":"object","properties":{"_yoast_wpseo_focuskw":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_title":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_metadesc":{"type":"string","title":"","description":"","default":""},"_data_scadenza_evento":{"type":"string","title":"","description":"","default":""},"_evento_nome":{"type":"string","title":"","description":"","default":""},"_evento_data":{"type":"string","title":"","description":"","default":""},"_evento_luogo":{"type":"string","title":"","description":"","default":""},"_evento_cta":{"type":"string","title":"","description":"","default":""},"keyword_en":{"type":"string","title":"","description":"","default":""},"keyword_es":{"type":"string","title":"","description":"","default":""},"keyword_fr":{"type":"string","title":"","description":"","default":""},"keyword_de":{"type":"string","title":"","description":"","default":""},"keyword_ptb":{"type":"string","title":"","description":"","default":""},"_note_content":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"sticky":{"description":"Se o post deve ser tratado como fixo.","type":"boolean","required":false},"template":{"description":"O arquivo do tema usado para exibir o post.","type":"string","required":false},"categories":{"description":"Os termos atribu\u00eddos ao post na taxonomia category.","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"Os termos atribu\u00eddos ao post na taxonomia post_tag.","type":"array","items":{"type":"integer"},"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o post.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ignorar ou n\u00e3o o envio para a lixeira e for\u00e7ar a exclus\u00e3o.","required":false}}}]},"\/wp\/v2\/posts\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"O ID do item ascendente \u00e0 revis\u00e3o.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina atual da cole\u00e7\u00e3o.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de itens retornados no resultado.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar resultados para aqueles que combinam com um texto.","type":"string","required":false},"exclude":{"description":"Garantir que o resultado exclua IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar resultados para IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Deslocar o resultado para um n\u00famero especifico de itens.","type":"integer","required":false},"order":{"description":"Ordenar atributos de forma ascendente ou descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar cole\u00e7\u00e3o pelo atributo do objeto.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/posts\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"O ID do item ascendente \u00e0 revis\u00e3o.","type":"integer","required":false},"id":{"description":"Identificador \u00fanico da revis\u00e3o.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"O ID do item ascendente \u00e0 revis\u00e3o.","type":"integer","required":false},"id":{"description":"Identificador \u00fanico da revis\u00e3o.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Necess\u00e1rio ser verdadeiro, as revis\u00f5es n\u00e3o suportam lixeira.","required":false}}}]},"\/wp\/v2\/posts\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"O ID do item ascendente ao salvamento autom\u00e1tico.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"O ID do item ascendente ao salvamento autom\u00e1tico.","type":"integer","required":false},"date":{"description":"Data da publica\u00e7\u00e3o do post, no fuso hor\u00e1rio do site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Data que o post foi publicado, em GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Um identificador alfanum\u00e9rico para o post.","type":"string","required":false},"status":{"description":"Um nome de status para o post.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","avvia_traduzione","crea_task_resolver"],"required":false},"password":{"description":"Uma senha para proteger o acesso ao conte\u00fado e resumo.","type":"string","required":false},"title":{"description":"O t\u00edtulo para o post.","type":"object","properties":{"raw":{"description":"T\u00edtulo para o post, como existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo para o post em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"O conte\u00fado para o post.","type":"object","properties":{"raw":{"description":"Conte\u00fado para o post, como ele existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"Conte\u00fado HTML do post, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Vers\u00e3o do formato do conte\u00fado do bloco usado pelo post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Se o conte\u00fado \u00e9 protegido por senha.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"O ID do autor para o post.","type":"integer","required":false},"excerpt":{"description":"O resumo para o post.","type":"object","properties":{"raw":{"description":"Resumo para o post, como existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"Resumo para o post em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Se o resumo \u00e9 protegido por senha.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"O ID da imagem destacada para o post.","type":"integer","required":false},"comment_status":{"description":"Se os coment\u00e1rios no post devem ou n\u00e3o ser abertos.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Se o post pode receber chamadas ping.","type":"string","enum":["open","closed"],"required":false},"format":{"description":"O formato para o post.","type":"string","enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"required":false},"meta":{"description":"Campos meta.","type":"object","properties":{"_yoast_wpseo_focuskw":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_title":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_metadesc":{"type":"string","title":"","description":"","default":""},"_data_scadenza_evento":{"type":"string","title":"","description":"","default":""},"_evento_nome":{"type":"string","title":"","description":"","default":""},"_evento_data":{"type":"string","title":"","description":"","default":""},"_evento_luogo":{"type":"string","title":"","description":"","default":""},"_evento_cta":{"type":"string","title":"","description":"","default":""},"keyword_en":{"type":"string","title":"","description":"","default":""},"keyword_es":{"type":"string","title":"","description":"","default":""},"keyword_fr":{"type":"string","title":"","description":"","default":""},"keyword_de":{"type":"string","title":"","description":"","default":""},"keyword_ptb":{"type":"string","title":"","description":"","default":""},"_note_content":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"sticky":{"description":"Se o post deve ser tratado como fixo.","type":"boolean","required":false},"template":{"description":"O arquivo do tema usado para exibir o post.","type":"string","required":false},"categories":{"description":"Os termos atribu\u00eddos ao post na taxonomia category.","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"Os termos atribu\u00eddos ao post na taxonomia post_tag.","type":"array","items":{"type":"integer"},"required":false}}}]},"\/wp\/v2\/posts\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"O ID do item ascendente ao salvamento autom\u00e1tico.","type":"integer","required":false},"id":{"description":"O ID do salvamento autom\u00e1tico.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/pages":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina atual da cole\u00e7\u00e3o.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de itens retornados no resultado.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar resultados para aqueles que combinam com um texto.","type":"string","required":false},"after":{"description":"Limitar respostas a posts publicados depois de uma determinada data compat\u00edvel com o formato ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limitar respostas a posts modificados depois de uma determinada data compat\u00edvel com o formato ISO8601.","type":"string","format":"date-time","required":false},"author":{"description":"Limitar resultados a posts atribu\u00eddos a autores espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Garantir que o resultado exclui posts atribu\u00eddos a autores espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limitar respostas a posts publicados antes de uma determinada data compat\u00edvel com o formato ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limitar respostas a posts modificados antes de uma determinada data compat\u00edvel com o formato ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Garantir que o resultado exclua IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar resultados para IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"menu_order":{"description":"Limitar resultados para posts com um valor menu_order espec\u00edfico.","type":"integer","required":false},"search_semantics":{"description":"Como interpretar o campo de pesquisa.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Deslocar o resultado para um n\u00famero especifico de itens.","type":"integer","required":false},"order":{"description":"Ordenar atributos de forma ascendente ou descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar cole\u00e7\u00e3o pelo atributo do post.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"parent":{"description":"Limitar resultados para itens cujos ascendentes t\u00eam determinados IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Limitar resultados para todos os itens, exceto aqueles de um ID de ascendente em particular.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_columns":{"default":[],"description":"Array de nomes de colunas para serem pesquisadas.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limitar resultados de posts definidos por um ou mais slugs espec\u00edficos.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limitar resultados de posts atribu\u00eddo por um ou mais status.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","flamingo-spam","avvia_traduzione","crea_task_resolver","any"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"Data da publica\u00e7\u00e3o do post, no fuso hor\u00e1rio do site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Data que o post foi publicado, em GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Um identificador alfanum\u00e9rico para o post.","type":"string","required":false},"status":{"description":"Um nome de status para o post.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","avvia_traduzione","crea_task_resolver"],"required":false},"password":{"description":"Uma senha para proteger o acesso ao conte\u00fado e resumo.","type":"string","required":false},"parent":{"description":"O ID do ascendente para o post.","type":"integer","required":false},"title":{"description":"O t\u00edtulo para o post.","type":"object","properties":{"raw":{"description":"T\u00edtulo para o post, como existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo para o post em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"O conte\u00fado para o post.","type":"object","properties":{"raw":{"description":"Conte\u00fado para o post, como ele existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"Conte\u00fado HTML do post, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Vers\u00e3o do formato do conte\u00fado do bloco usado pelo post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Se o conte\u00fado \u00e9 protegido por senha.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"O ID do autor para o post.","type":"integer","required":false},"excerpt":{"description":"O resumo para o post.","type":"object","properties":{"raw":{"description":"Resumo para o post, como existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"Resumo para o post em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Se o resumo \u00e9 protegido por senha.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"O ID da imagem destacada para o post.","type":"integer","required":false},"comment_status":{"description":"Se os coment\u00e1rios no post devem ou n\u00e3o ser abertos.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Se o post pode receber chamadas ping.","type":"string","enum":["open","closed"],"required":false},"menu_order":{"description":"A ordem do post em rela\u00e7\u00e3o a outros posts.","type":"integer","required":false},"meta":{"description":"Campos meta.","type":"object","properties":{"_yoast_wpseo_focuskw":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_metadesc":{"type":"string","title":"","description":"","default":""},"_data_scadenza_evento":{"type":"string","title":"","description":"","default":""},"_evento_nome":{"type":"string","title":"","description":"","default":""},"_evento_data":{"type":"string","title":"","description":"","default":""},"_evento_luogo":{"type":"string","title":"","description":"","default":""},"_evento_cta":{"type":"string","title":"","description":"","default":""},"keyword_en":{"type":"string","title":"","description":"","default":""},"keyword_es":{"type":"string","title":"","description":"","default":""},"keyword_fr":{"type":"string","title":"","description":"","default":""},"keyword_de":{"type":"string","title":"","description":"","default":""},"keyword_ptb":{"type":"string","title":"","description":"","default":""},"_note_content":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"O arquivo do tema usado para exibir o post.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/wp\/v2\/pages"}]}},"\/wp\/v2\/pages\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o post.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"Substitui o tamanho padr\u00e3o do resumo.","type":"integer","required":false},"password":{"description":"A senha para o post se este for protegido por senha.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o post.","type":"integer","required":false},"date":{"description":"Data da publica\u00e7\u00e3o do post, no fuso hor\u00e1rio do site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Data que o post foi publicado, em GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Um identificador alfanum\u00e9rico para o post.","type":"string","required":false},"status":{"description":"Um nome de status para o post.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","avvia_traduzione","crea_task_resolver"],"required":false},"password":{"description":"Uma senha para proteger o acesso ao conte\u00fado e resumo.","type":"string","required":false},"parent":{"description":"O ID do ascendente para o post.","type":"integer","required":false},"title":{"description":"O t\u00edtulo para o post.","type":"object","properties":{"raw":{"description":"T\u00edtulo para o post, como existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo para o post em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"O conte\u00fado para o post.","type":"object","properties":{"raw":{"description":"Conte\u00fado para o post, como ele existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"Conte\u00fado HTML do post, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Vers\u00e3o do formato do conte\u00fado do bloco usado pelo post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Se o conte\u00fado \u00e9 protegido por senha.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"O ID do autor para o post.","type":"integer","required":false},"excerpt":{"description":"O resumo para o post.","type":"object","properties":{"raw":{"description":"Resumo para o post, como existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"Resumo para o post em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Se o resumo \u00e9 protegido por senha.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"O ID da imagem destacada para o post.","type":"integer","required":false},"comment_status":{"description":"Se os coment\u00e1rios no post devem ou n\u00e3o ser abertos.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Se o post pode receber chamadas ping.","type":"string","enum":["open","closed"],"required":false},"menu_order":{"description":"A ordem do post em rela\u00e7\u00e3o a outros posts.","type":"integer","required":false},"meta":{"description":"Campos meta.","type":"object","properties":{"_yoast_wpseo_focuskw":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_metadesc":{"type":"string","title":"","description":"","default":""},"_data_scadenza_evento":{"type":"string","title":"","description":"","default":""},"_evento_nome":{"type":"string","title":"","description":"","default":""},"_evento_data":{"type":"string","title":"","description":"","default":""},"_evento_luogo":{"type":"string","title":"","description":"","default":""},"_evento_cta":{"type":"string","title":"","description":"","default":""},"keyword_en":{"type":"string","title":"","description":"","default":""},"keyword_es":{"type":"string","title":"","description":"","default":""},"keyword_fr":{"type":"string","title":"","description":"","default":""},"keyword_de":{"type":"string","title":"","description":"","default":""},"keyword_ptb":{"type":"string","title":"","description":"","default":""},"_note_content":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"O arquivo do tema usado para exibir o post.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o post.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ignorar ou n\u00e3o o envio para a lixeira e for\u00e7ar a exclus\u00e3o.","required":false}}}]},"\/wp\/v2\/pages\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"O ID do item ascendente \u00e0 revis\u00e3o.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina atual da cole\u00e7\u00e3o.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de itens retornados no resultado.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar resultados para aqueles que combinam com um texto.","type":"string","required":false},"exclude":{"description":"Garantir que o resultado exclua IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar resultados para IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Deslocar o resultado para um n\u00famero especifico de itens.","type":"integer","required":false},"order":{"description":"Ordenar atributos de forma ascendente ou descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar cole\u00e7\u00e3o pelo atributo do objeto.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/pages\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"O ID do item ascendente \u00e0 revis\u00e3o.","type":"integer","required":false},"id":{"description":"Identificador \u00fanico da revis\u00e3o.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"O ID do item ascendente \u00e0 revis\u00e3o.","type":"integer","required":false},"id":{"description":"Identificador \u00fanico da revis\u00e3o.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Necess\u00e1rio ser verdadeiro, as revis\u00f5es n\u00e3o suportam lixeira.","required":false}}}]},"\/wp\/v2\/pages\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"O ID do item ascendente ao salvamento autom\u00e1tico.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"O ID do ascendente para o post.","type":"integer","required":false},"date":{"description":"Data da publica\u00e7\u00e3o do post, no fuso hor\u00e1rio do site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Data que o post foi publicado, em GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Um identificador alfanum\u00e9rico para o post.","type":"string","required":false},"status":{"description":"Um nome de status para o post.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","avvia_traduzione","crea_task_resolver"],"required":false},"password":{"description":"Uma senha para proteger o acesso ao conte\u00fado e resumo.","type":"string","required":false},"title":{"description":"O t\u00edtulo para o post.","type":"object","properties":{"raw":{"description":"T\u00edtulo para o post, como existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo para o post em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"O conte\u00fado para o post.","type":"object","properties":{"raw":{"description":"Conte\u00fado para o post, como ele existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"Conte\u00fado HTML do post, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Vers\u00e3o do formato do conte\u00fado do bloco usado pelo post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Se o conte\u00fado \u00e9 protegido por senha.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"O ID do autor para o post.","type":"integer","required":false},"excerpt":{"description":"O resumo para o post.","type":"object","properties":{"raw":{"description":"Resumo para o post, como existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"Resumo para o post em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Se o resumo \u00e9 protegido por senha.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"O ID da imagem destacada para o post.","type":"integer","required":false},"comment_status":{"description":"Se os coment\u00e1rios no post devem ou n\u00e3o ser abertos.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Se o post pode receber chamadas ping.","type":"string","enum":["open","closed"],"required":false},"menu_order":{"description":"A ordem do post em rela\u00e7\u00e3o a outros posts.","type":"integer","required":false},"meta":{"description":"Campos meta.","type":"object","properties":{"_yoast_wpseo_focuskw":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_metadesc":{"type":"string","title":"","description":"","default":""},"_data_scadenza_evento":{"type":"string","title":"","description":"","default":""},"_evento_nome":{"type":"string","title":"","description":"","default":""},"_evento_data":{"type":"string","title":"","description":"","default":""},"_evento_luogo":{"type":"string","title":"","description":"","default":""},"_evento_cta":{"type":"string","title":"","description":"","default":""},"keyword_en":{"type":"string","title":"","description":"","default":""},"keyword_es":{"type":"string","title":"","description":"","default":""},"keyword_fr":{"type":"string","title":"","description":"","default":""},"keyword_de":{"type":"string","title":"","description":"","default":""},"keyword_ptb":{"type":"string","title":"","description":"","default":""},"_note_content":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"O arquivo do tema usado para exibir o post.","type":"string","required":false}}}]},"\/wp\/v2\/pages\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"O ID do item ascendente ao salvamento autom\u00e1tico.","type":"integer","required":false},"id":{"description":"O ID do salvamento autom\u00e1tico.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/media":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina atual da cole\u00e7\u00e3o.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de itens retornados no resultado.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar resultados para aqueles que combinam com um texto.","type":"string","required":false},"after":{"description":"Limitar respostas a posts publicados depois de uma determinada data compat\u00edvel com o formato ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limitar respostas a posts modificados depois de uma determinada data compat\u00edvel com o formato ISO8601.","type":"string","format":"date-time","required":false},"author":{"description":"Limitar resultados a posts atribu\u00eddos a autores espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Garantir que o resultado exclui posts atribu\u00eddos a autores espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limitar respostas a posts publicados antes de uma determinada data compat\u00edvel com o formato ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limitar respostas a posts modificados antes de uma determinada data compat\u00edvel com o formato ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Garantir que o resultado exclua IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar resultados para IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Como interpretar o campo de pesquisa.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Deslocar o resultado para um n\u00famero especifico de itens.","type":"integer","required":false},"order":{"description":"Ordenar atributos de forma ascendente ou descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar cole\u00e7\u00e3o pelo atributo do post.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"parent":{"description":"Limitar resultados para itens cujos ascendentes t\u00eam determinados IDs.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Limitar resultados para todos os itens, exceto aqueles de um ID de ascendente em particular.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_columns":{"default":[],"description":"Array de nomes de colunas para serem pesquisadas.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limitar resultados de posts definidos por um ou mais slugs espec\u00edficos.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"inherit","description":"Limitar resultados de posts atribu\u00eddo por um ou mais status.","type":"array","items":{"enum":["inherit","private","trash"],"type":"string"},"required":false},"media_type":{"default":null,"description":"Limita resultados a anexos de um tipo de m\u00eddia em particular ou tipos de m\u00eddia.","type":"array","items":{"type":"string","enum":["image","video","audio","application","text"]},"required":false},"mime_type":{"default":null,"description":"Limita resultados a anexos de um tipo MIME em particular ou tipos MIME.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"args":{"date":{"description":"Data da publica\u00e7\u00e3o do post, no fuso hor\u00e1rio do site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Data que o post foi publicado, em GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Um identificador alfanum\u00e9rico para o post.","type":"string","required":false},"status":{"description":"Um nome de status para o post.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","avvia_traduzione","crea_task_resolver"],"required":false},"title":{"description":"O t\u00edtulo para o post.","type":"object","properties":{"raw":{"description":"T\u00edtulo para o post, como existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo para o post em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"O ID do autor para o post.","type":"integer","required":false},"featured_media":{"description":"O ID da imagem destacada para o post.","type":"integer","required":false},"comment_status":{"description":"Se os coment\u00e1rios no post devem ou n\u00e3o ser abertos.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Se o post pode receber chamadas ping.","type":"string","enum":["open","closed"],"required":false},"meta":{"description":"Campos meta.","type":"object","properties":{"_yoast_wpseo_focuskw":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_metadesc":{"type":"string","title":"","description":"","default":""},"_data_scadenza_evento":{"type":"string","title":"","description":"","default":""},"_evento_nome":{"type":"string","title":"","description":"","default":""},"_evento_data":{"type":"string","title":"","description":"","default":""},"_evento_luogo":{"type":"string","title":"","description":"","default":""},"_evento_cta":{"type":"string","title":"","description":"","default":""},"keyword_en":{"type":"string","title":"","description":"","default":""},"keyword_es":{"type":"string","title":"","description":"","default":""},"keyword_fr":{"type":"string","title":"","description":"","default":""},"keyword_de":{"type":"string","title":"","description":"","default":""},"keyword_ptb":{"type":"string","title":"","description":"","default":""},"_note_content":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"O arquivo do tema usado para exibir o post.","type":"string","required":false},"alt_text":{"description":"Texto alternativo para exibir quando o anexo n\u00e3o \u00e9 exibido.","type":"string","required":false},"caption":{"description":"A legenda do anexo.","type":"object","properties":{"raw":{"description":"Legenda para o anexo, como existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"Legenda HTML para o anexo, transformada para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"A descri\u00e7\u00e3o do anexo.","type":"object","properties":{"raw":{"description":"Descri\u00e7\u00e3o para o anexo, como existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"Descri\u00e7\u00e3o HTML para o anexo, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"post":{"description":"O ID para o post associado ao anexo.","type":"integer","required":false},"generate_sub_sizes":{"type":"boolean","default":true,"description":"Caso deva-se gerar subtamanhos de imagem.","required":false},"convert_format":{"type":"boolean","default":true,"description":"Caso deva-se converter formatos de imagem.","required":false},"url":{"type":"string","format":"uri","description":"URL de uma imagem externa para carregar diretamente na biblioteca de m\u00eddia, em vez de enviar um arquivo.","required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/wp\/v2\/media"}]}},"\/wp\/v2\/media\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identificador \u00fanico para o post.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identificador \u00fanico para o post.","type":"integer","required":false},"date":{"description":"Data da publica\u00e7\u00e3o do post, no fuso hor\u00e1rio do site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Data que o post foi publicado, em GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Um identificador alfanum\u00e9rico para o post.","type":"string","required":false},"status":{"description":"Um nome de status para o post.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","avvia_traduzione","crea_task_resolver"],"required":false},"title":{"description":"O t\u00edtulo para o post.","type":"object","properties":{"raw":{"description":"T\u00edtulo para o post, como existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo para o post em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"O ID do autor para o post.","type":"integer","required":false},"featured_media":{"description":"O ID da imagem destacada para o post.","type":"integer","required":false},"comment_status":{"description":"Se os coment\u00e1rios no post devem ou n\u00e3o ser abertos.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Se o post pode receber chamadas ping.","type":"string","enum":["open","closed"],"required":false},"meta":{"description":"Campos meta.","type":"object","properties":{"_yoast_wpseo_focuskw":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_metadesc":{"type":"string","title":"","description":"","default":""},"_data_scadenza_evento":{"type":"string","title":"","description":"","default":""},"_evento_nome":{"type":"string","title":"","description":"","default":""},"_evento_data":{"type":"string","title":"","description":"","default":""},"_evento_luogo":{"type":"string","title":"","description":"","default":""},"_evento_cta":{"type":"string","title":"","description":"","default":""},"keyword_en":{"type":"string","title":"","description":"","default":""},"keyword_es":{"type":"string","title":"","description":"","default":""},"keyword_fr":{"type":"string","title":"","description":"","default":""},"keyword_de":{"type":"string","title":"","description":"","default":""},"keyword_ptb":{"type":"string","title":"","description":"","default":""},"_note_content":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"O arquivo do tema usado para exibir o post.","type":"string","required":false},"alt_text":{"description":"Texto alternativo para exibir quando o anexo n\u00e3o \u00e9 exibido.","type":"string","required":false},"caption":{"description":"A legenda do anexo.","type":"object","properties":{"raw":{"description":"Legenda para o anexo, como existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"Legenda HTML para o anexo, transformada para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"A descri\u00e7\u00e3o do anexo.","type":"object","properties":{"raw":{"description":"Descri\u00e7\u00e3o para o anexo, como existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"Descri\u00e7\u00e3o HTML para o anexo, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"post":{"description":"O ID para o post associado ao anexo.","type":"integer","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identificador \u00fanico para o post.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ignorar ou n\u00e3o o envio para a lixeira e for\u00e7ar a exclus\u00e3o.","required":false}}}]},"\/wp\/v2\/media\/(?P<id>[\\d]+)\/post-process":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"Identificador \u00fanico para o anexo.","type":"integer","required":false},"action":{"type":"string","enum":["create-image-subsizes"],"required":true}}}]},"\/wp\/v2\/media\/(?P<id>[\\d]+)\/edit":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"src":{"description":"URL para o arquivo de imagem editado.","type":"string","format":"uri","required":true},"modifiers":{"description":"Array de edi\u00e7\u00f5es da imagem.","type":"array","minItems":1,"items":{"description":"Edi\u00e7\u00e3o de imagem.","type":"object","required":["type","args"],"oneOf":[{"title":"Virar","properties":{"type":{"description":"Tipo de giro.","type":"string","enum":["flip"]},"args":{"description":"Argumentos de invers\u00e3o.","type":"object","required":["flip"],"properties":{"flip":{"description":"Dire\u00e7\u00e3o de invers\u00e3o.","type":"object","required":["horizontal","vertical"],"properties":{"horizontal":{"description":"Se deve virar na dire\u00e7\u00e3o horizontal.","type":"boolean"},"vertical":{"description":"Se deve virar na dire\u00e7\u00e3o vertical.","type":"boolean"}}}}}}},{"title":"Rota\u00e7\u00e3o","properties":{"type":{"description":"Tipo de rota\u00e7\u00e3o.","type":"string","enum":["rotate"]},"args":{"description":"Argumentos para rota\u00e7\u00e3o.","type":"object","required":["angle"],"properties":{"angle":{"description":"\u00c2ngulo para girar no sentido hor\u00e1rio em graus..","type":"number"}}}}},{"title":"Recortar","properties":{"type":{"description":"Tipo de recorte.","type":"string","enum":["crop"]},"args":{"description":"Argumentos para recortar.","type":"object","required":["left","top","width","height"],"properties":{"left":{"description":"Posi\u00e7\u00e3o vertical da esquerda para iniciar um recorte como uma porcentagem da largura da imagem.","type":"number"},"top":{"description":"Posi\u00e7\u00e3o vertical do topo para iniciar um recorte como uma porcentagem da altura da imagem.","type":"number"},"width":{"description":"Largura para recortar como uma porcentagem da largura da imagem.","type":"number"},"height":{"description":"Altura para recortar como uma porcentagem da altura da imagem.","type":"number"}}}}}]},"required":false},"rotation":{"description":"A quantidade para girar a imagem no sentido hor\u00e1rio em graus. Obsoleto: use `modifiers` no lugar.","type":"integer","minimum":0,"exclusiveMinimum":true,"maximum":360,"exclusiveMaximum":true,"required":false},"x":{"description":"Como uma porcentagem da imagem, a posi\u00e7\u00e3o x para iniciar o recorte. Obsoleto: use `modifiers` no lugar.","type":"number","minimum":0,"maximum":100,"required":false},"y":{"description":"Como uma porcentagem da imagem, a posi\u00e7\u00e3o y para iniciar o recorte. Obsoleto: use `modifiers` no lugar.","type":"number","minimum":0,"maximum":100,"required":false},"width":{"description":"Como uma porcentagem da imagem, a largura que a imagem ser\u00e1 recortada. Obsoleto: use `modifiers` no lugar.","type":"number","minimum":0,"maximum":100,"required":false},"height":{"description":"Como uma porcentagem da imagem, a altura que a imagem ser\u00e1 recortada. Obsoleto: use `modifiers` no lugar.","type":"number","minimum":0,"maximum":100,"required":false},"caption":{"description":"A legenda do anexo.","type":"object","properties":{"raw":{"description":"Legenda para o anexo, como existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"Legenda HTML para o anexo, transformada para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"A descri\u00e7\u00e3o do anexo.","type":"object","properties":{"raw":{"description":"Descri\u00e7\u00e3o para o anexo, como existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"Descri\u00e7\u00e3o HTML para o anexo, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"title":{"description":"O t\u00edtulo para o post.","type":"object","properties":{"raw":{"description":"T\u00edtulo para o post, como existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo para o post em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"post":{"description":"O ID para o post associado ao anexo.","type":"integer","required":false},"alt_text":{"description":"Texto alternativo para exibir quando o anexo n\u00e3o \u00e9 exibido.","type":"string","required":false}}}]},"\/wp\/v2\/media\/(?P<id>[\\d]+)\/sideload":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"Identificador \u00fanico para o anexo.","type":"integer","required":false},"image_size":{"description":"Tamanho da imagem. Pode ser um \u00fanico nome de tamanho ou um array de nomes de tamanhos para registrar o mesmo arquivo em v\u00e1rios tamanhos.","type":["string","array"],"items":{"type":"string","minLength":1},"minItems":1,"minLength":1,"required":true},"convert_format":{"type":"boolean","default":true,"description":"Caso deva-se converter formatos de imagem.","required":false}}}]},"\/wp\/v2\/media\/(?P<id>[\\d]+)\/finalize":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"Identificador \u00fanico para o anexo.","type":"integer","required":false},"sub_sizes":{"description":"Array de metadados de subtamanhos coletados das respostas de sideload.","type":"array","default":[],"maxItems":100,"items":{"type":"object","properties":{"image_size":{"description":"Nome do tamanho ou um array de nomes de tamanhos quando um \u00fanico arquivo \u00e9 registrado em v\u00e1rios tamanhos com dimens\u00f5es correspondentes.","type":["string","array"],"items":{"type":"string","minLength":1},"minItems":1,"minLength":1,"required":true},"width":{"type":"integer","minimum":1},"height":{"type":"integer","minimum":1},"file":{"type":"string","minLength":1},"mime_type":{"type":"string","pattern":"^image\/.*"},"filesize":{"type":"integer","minimum":1},"original_image":{"type":"string","minLength":1}}},"required":false}}}]},"\/wp\/v2\/menu-items":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina atual da cole\u00e7\u00e3o.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de itens retornados no resultado.","type":"integer","default":100,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar resultados para aqueles que combinam com um texto.","type":"string","required":false},"after":{"description":"Limitar respostas a posts publicados depois de uma determinada data compat\u00edvel com o formato ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limitar respostas a posts modificados depois de uma determinada data compat\u00edvel com o formato ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limitar respostas a posts publicados antes de uma determinada data compat\u00edvel com o formato ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limitar respostas a posts modificados antes de uma determinada data compat\u00edvel com o formato ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Garantir que o resultado exclua IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar resultados para IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Como interpretar o campo de pesquisa.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Deslocar o resultado para um n\u00famero especifico de itens.","type":"integer","required":false},"order":{"description":"Ordenar atributos de forma ascendente ou descendente.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar cole\u00e7\u00e3o pelo atributo do objeto.","type":"string","default":"menu_order","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"search_columns":{"default":[],"description":"Array de nomes de colunas para serem pesquisadas.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limitar resultados de posts definidos por um ou mais slugs espec\u00edficos.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limitar resultados de posts atribu\u00eddo por um ou mais status.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","flamingo-spam","avvia_traduzione","crea_task_resolver","any"],"type":"string"},"required":false},"tax_relation":{"description":"Limitar resultados com base no relacionamento entre m\u00faltiplas taxonomias.","type":"string","enum":["AND","OR"],"required":false},"menus":{"description":"Limitar resultados para todos os itens com termos espec\u00edficos atribu\u00eddos a taxonomia menus.","type":["object","array"],"oneOf":[{"title":"Lista de ID de termos","description":"Combinar os termos com os IDs listados.","type":"array","items":{"type":"integer"}},{"title":"Consulta da taxonomia do ID do termo","description":"Executar uma consulta avan\u00e7a de termos.","type":"object","properties":{"terms":{"description":"IDs dos termos.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Se os items devem ser atribu\u00eddos a todos ou a qualquer um dos termos especificados.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"menus_exclude":{"description":"Limitar resultados para todos os itens que tenham o termo espec\u00edfico atribu\u00eddo para a taxonomia menus.","type":["object","array"],"oneOf":[{"title":"Lista de ID de termos","description":"Combinar os termos com os IDs listados.","type":"array","items":{"type":"integer"}},{"title":"Consulta da taxonomia do ID do termo","description":"Executar uma consulta avan\u00e7a de termos.","type":"object","properties":{"terms":{"description":"IDs dos termos.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"menu_order":{"description":"Limitar resultados para posts com um valor menu_order espec\u00edfico.","type":"integer","required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"title":{"description":"O t\u00edtulo para o objeto.","type":["string","object"],"properties":{"raw":{"description":"T\u00edtulo para o objeto, como existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo para o objeto em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"type":{"default":"custom","description":"A fam\u00edlia de objetos originalmente representados, como \"post_type\" ou \"taxonomy\".","type":"string","enum":["taxonomy","post_type","post_type_archive","custom"],"required":false},"status":{"default":"publish","description":"Um nome de status para o objeto.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","avvia_traduzione","crea_task_resolver"],"required":false},"parent":{"default":0,"description":"O ID do item ascendente ao objeto.","type":"integer","minimum":0,"required":false},"attr_title":{"description":"Texto referente ao atributo de t\u00edtulo do elemento de link deste item de menu.","type":"string","required":false},"classes":{"description":"Nomes de classe do elemento de link deste item de menu.","type":"array","items":{"type":"string"},"required":false},"description":{"description":"A descri\u00e7\u00e3o deste item de menu.","type":"string","required":false},"menu_order":{"default":1,"description":"O ID de banco de dados do nav_menu_item ascendente deste item, se houver. Caso contr\u00e1rio, \u00e9 0.","type":"integer","minimum":1,"required":false},"object":{"description":"O tipo do objeto originalmente representado, como \"category,\" \"post\" ou \"attachment\".","type":"string","required":false},"object_id":{"default":0,"description":"O ID no banco de dados do objeto original que representa este item de menu, por exemplo o ID para os posts e o term_id para as categorias.","type":"integer","minimum":0,"required":false},"target":{"description":"O atributo target (destino) de um elemento de link para este item de menu.","type":"string","enum":["_blank",""],"required":false},"url":{"description":"O URL para o qual este item de menu aponta.","type":"string","format":"uri","required":false},"xfn":{"description":"A rela\u00e7\u00e3o XFN expressa no link deste item de menu.","type":"array","items":{"type":"string"},"required":false},"menus":{"description":"Os termos atribu\u00eddos ao objeto na taxonomia nav_menu.","type":"integer","required":false},"meta":{"description":"Campos meta.","type":"object","properties":{"_yoast_wpseo_focuskw":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_metadesc":{"type":"string","title":"","description":"","default":""},"_data_scadenza_evento":{"type":"string","title":"","description":"","default":""},"_evento_nome":{"type":"string","title":"","description":"","default":""},"_evento_data":{"type":"string","title":"","description":"","default":""},"_evento_luogo":{"type":"string","title":"","description":"","default":""},"_evento_cta":{"type":"string","title":"","description":"","default":""},"keyword_en":{"type":"string","title":"","description":"","default":""},"keyword_es":{"type":"string","title":"","description":"","default":""},"keyword_fr":{"type":"string","title":"","description":"","default":""},"keyword_de":{"type":"string","title":"","description":"","default":""},"keyword_ptb":{"type":"string","title":"","description":"","default":""},"_note_content":{"type":"string","title":"","description":"","default":""}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/wp\/v2\/menu-items"}]}},"\/wp\/v2\/menu-items\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o post.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o post.","type":"integer","required":false},"title":{"description":"O t\u00edtulo para o objeto.","type":["string","object"],"properties":{"raw":{"description":"T\u00edtulo para o objeto, como existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo para o objeto em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"type":{"description":"A fam\u00edlia de objetos originalmente representados, como \"post_type\" ou \"taxonomy\".","type":"string","enum":["taxonomy","post_type","post_type_archive","custom"],"required":false},"status":{"description":"Um nome de status para o objeto.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","avvia_traduzione","crea_task_resolver"],"required":false},"parent":{"description":"O ID do item ascendente ao objeto.","type":"integer","minimum":0,"required":false},"attr_title":{"description":"Texto referente ao atributo de t\u00edtulo do elemento de link deste item de menu.","type":"string","required":false},"classes":{"description":"Nomes de classe do elemento de link deste item de menu.","type":"array","items":{"type":"string"},"required":false},"description":{"description":"A descri\u00e7\u00e3o deste item de menu.","type":"string","required":false},"menu_order":{"description":"O ID de banco de dados do nav_menu_item ascendente deste item, se houver. Caso contr\u00e1rio, \u00e9 0.","type":"integer","minimum":1,"required":false},"object":{"description":"O tipo do objeto originalmente representado, como \"category,\" \"post\" ou \"attachment\".","type":"string","required":false},"object_id":{"description":"O ID no banco de dados do objeto original que representa este item de menu, por exemplo o ID para os posts e o term_id para as categorias.","type":"integer","minimum":0,"required":false},"target":{"description":"O atributo target (destino) de um elemento de link para este item de menu.","type":"string","enum":["_blank",""],"required":false},"url":{"description":"O URL para o qual este item de menu aponta.","type":"string","format":"uri","required":false},"xfn":{"description":"A rela\u00e7\u00e3o XFN expressa no link deste item de menu.","type":"array","items":{"type":"string"},"required":false},"menus":{"description":"Os termos atribu\u00eddos ao objeto na taxonomia nav_menu.","type":"integer","required":false},"meta":{"description":"Campos meta.","type":"object","properties":{"_yoast_wpseo_focuskw":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_metadesc":{"type":"string","title":"","description":"","default":""},"_data_scadenza_evento":{"type":"string","title":"","description":"","default":""},"_evento_nome":{"type":"string","title":"","description":"","default":""},"_evento_data":{"type":"string","title":"","description":"","default":""},"_evento_luogo":{"type":"string","title":"","description":"","default":""},"_evento_cta":{"type":"string","title":"","description":"","default":""},"keyword_en":{"type":"string","title":"","description":"","default":""},"keyword_es":{"type":"string","title":"","description":"","default":""},"keyword_fr":{"type":"string","title":"","description":"","default":""},"keyword_de":{"type":"string","title":"","description":"","default":""},"keyword_ptb":{"type":"string","title":"","description":"","default":""},"_note_content":{"type":"string","title":"","description":"","default":""}},"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o post.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ignorar ou n\u00e3o o envio para a lixeira e for\u00e7ar a exclus\u00e3o.","required":false}}}]},"\/wp\/v2\/menu-items\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"O ID do item ascendente ao salvamento autom\u00e1tico.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"O ID do item ascendente ao objeto.","type":"integer","minimum":0,"required":false},"title":{"description":"O t\u00edtulo para o objeto.","type":["string","object"],"properties":{"raw":{"description":"T\u00edtulo para o objeto, como existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo para o objeto em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"type":{"description":"A fam\u00edlia de objetos originalmente representados, como \"post_type\" ou \"taxonomy\".","type":"string","enum":["taxonomy","post_type","post_type_archive","custom"],"required":false},"status":{"description":"Um nome de status para o objeto.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","avvia_traduzione","crea_task_resolver"],"required":false},"attr_title":{"description":"Texto referente ao atributo de t\u00edtulo do elemento de link deste item de menu.","type":"string","required":false},"classes":{"description":"Nomes de classe do elemento de link deste item de menu.","type":"array","items":{"type":"string"},"required":false},"description":{"description":"A descri\u00e7\u00e3o deste item de menu.","type":"string","required":false},"menu_order":{"description":"O ID de banco de dados do nav_menu_item ascendente deste item, se houver. Caso contr\u00e1rio, \u00e9 0.","type":"integer","minimum":1,"required":false},"object":{"description":"O tipo do objeto originalmente representado, como \"category,\" \"post\" ou \"attachment\".","type":"string","required":false},"object_id":{"description":"O ID no banco de dados do objeto original que representa este item de menu, por exemplo o ID para os posts e o term_id para as categorias.","type":"integer","minimum":0,"required":false},"target":{"description":"O atributo target (destino) de um elemento de link para este item de menu.","type":"string","enum":["_blank",""],"required":false},"url":{"description":"O URL para o qual este item de menu aponta.","type":"string","format":"uri","required":false},"xfn":{"description":"A rela\u00e7\u00e3o XFN expressa no link deste item de menu.","type":"array","items":{"type":"string"},"required":false},"menus":{"description":"Os termos atribu\u00eddos ao objeto na taxonomia nav_menu.","type":"integer","required":false},"meta":{"description":"Campos meta.","type":"object","properties":{"_yoast_wpseo_focuskw":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_metadesc":{"type":"string","title":"","description":"","default":""},"_data_scadenza_evento":{"type":"string","title":"","description":"","default":""},"_evento_nome":{"type":"string","title":"","description":"","default":""},"_evento_data":{"type":"string","title":"","description":"","default":""},"_evento_luogo":{"type":"string","title":"","description":"","default":""},"_evento_cta":{"type":"string","title":"","description":"","default":""},"keyword_en":{"type":"string","title":"","description":"","default":""},"keyword_es":{"type":"string","title":"","description":"","default":""},"keyword_fr":{"type":"string","title":"","description":"","default":""},"keyword_de":{"type":"string","title":"","description":"","default":""},"keyword_ptb":{"type":"string","title":"","description":"","default":""},"_note_content":{"type":"string","title":"","description":"","default":""}},"required":false}}}]},"\/wp\/v2\/menu-items\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"O ID do item ascendente ao salvamento autom\u00e1tico.","type":"integer","required":false},"id":{"description":"O ID do salvamento autom\u00e1tico.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/blocks":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina atual da cole\u00e7\u00e3o.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de itens retornados no resultado.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar resultados para aqueles que combinam com um texto.","type":"string","required":false},"after":{"description":"Limitar respostas a posts publicados depois de uma determinada data compat\u00edvel com o formato ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limitar respostas a posts modificados depois de uma determinada data compat\u00edvel com o formato ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limitar respostas a posts publicados antes de uma determinada data compat\u00edvel com o formato ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limitar respostas a posts modificados antes de uma determinada data compat\u00edvel com o formato ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Garantir que o resultado exclua IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar resultados para IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Como interpretar o campo de pesquisa.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Deslocar o resultado para um n\u00famero especifico de itens.","type":"integer","required":false},"order":{"description":"Ordenar atributos de forma ascendente ou descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar cole\u00e7\u00e3o pelo atributo do post.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array de nomes de colunas para serem pesquisadas.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limitar resultados de posts definidos por um ou mais slugs espec\u00edficos.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limitar resultados de posts atribu\u00eddo por um ou mais status.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","flamingo-spam","avvia_traduzione","crea_task_resolver","any"],"type":"string"},"required":false},"tax_relation":{"description":"Limitar resultados com base no relacionamento entre m\u00faltiplas taxonomias.","type":"string","enum":["AND","OR"],"required":false},"wp_pattern_category":{"description":"Limitar resultados para todos os itens com termos espec\u00edficos atribu\u00eddos a taxonomia wp_pattern_category.","type":["object","array"],"oneOf":[{"title":"Lista de ID de termos","description":"Combinar os termos com os IDs listados.","type":"array","items":{"type":"integer"}},{"title":"Consulta da taxonomia do ID do termo","description":"Executar uma consulta avan\u00e7a de termos.","type":"object","properties":{"terms":{"description":"IDs dos termos.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Se os items devem ser atribu\u00eddos a todos ou a qualquer um dos termos especificados.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"wp_pattern_category_exclude":{"description":"Limitar resultados para todos os itens que tenham o termo espec\u00edfico atribu\u00eddo para a taxonomia wp_pattern_category.","type":["object","array"],"oneOf":[{"title":"Lista de ID de termos","description":"Combinar os termos com os IDs listados.","type":"array","items":{"type":"integer"}},{"title":"Consulta da taxonomia do ID do termo","description":"Executar uma consulta avan\u00e7a de termos.","type":"object","properties":{"terms":{"description":"IDs dos termos.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"Data da publica\u00e7\u00e3o do post, no fuso hor\u00e1rio do site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Data que o post foi publicado, em GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Um identificador alfanum\u00e9rico para o post.","type":"string","required":false},"status":{"description":"Um nome de status para o post.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","avvia_traduzione","crea_task_resolver"],"required":false},"password":{"description":"Uma senha para proteger o acesso ao conte\u00fado e resumo.","type":"string","required":false},"title":{"description":"O t\u00edtulo para o post.","type":"object","properties":{"raw":{"description":"T\u00edtulo para o post, como existe no banco de dados.","type":"string","context":["view","edit"]}},"required":false},"content":{"description":"O conte\u00fado para o post.","type":"object","properties":{"raw":{"description":"Conte\u00fado para o post, como ele existe no banco de dados.","type":"string","context":["view","edit"]},"block_version":{"description":"Vers\u00e3o do formato do conte\u00fado do bloco usado pelo post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Se o conte\u00fado \u00e9 protegido por senha.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"O resumo para o post.","type":"object","properties":{"raw":{"description":"Resumo para o post, como existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"Resumo para o post em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Se o resumo \u00e9 protegido por senha.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"Campos meta.","type":"object","properties":{"_yoast_wpseo_focuskw":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_metadesc":{"type":"string","title":"","description":"","default":""},"_data_scadenza_evento":{"type":"string","title":"","description":"","default":""},"_evento_nome":{"type":"string","title":"","description":"","default":""},"_evento_data":{"type":"string","title":"","description":"","default":""},"_evento_luogo":{"type":"string","title":"","description":"","default":""},"_evento_cta":{"type":"string","title":"","description":"","default":""},"keyword_en":{"type":"string","title":"","description":"","default":""},"keyword_es":{"type":"string","title":"","description":"","default":""},"keyword_fr":{"type":"string","title":"","description":"","default":""},"keyword_de":{"type":"string","title":"","description":"","default":""},"keyword_ptb":{"type":"string","title":"","description":"","default":""},"_note_content":{"type":"string","title":"","description":"","default":""},"wp_pattern_sync_status":{"type":"string","title":"","description":"","default":"","enum":["partial","unsynced"]},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"O arquivo do tema usado para exibir o post.","type":"string","required":false},"wp_pattern_category":{"description":"Os termos atribu\u00eddos ao post na taxonomia wp_pattern_category.","type":"array","items":{"type":"integer"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/wp\/v2\/blocks"}]}},"\/wp\/v2\/blocks\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o post.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"Substitui o tamanho padr\u00e3o do resumo.","type":"integer","required":false},"password":{"description":"A senha para o post se este for protegido por senha.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o post.","type":"integer","required":false},"date":{"description":"Data da publica\u00e7\u00e3o do post, no fuso hor\u00e1rio do site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Data que o post foi publicado, em GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Um identificador alfanum\u00e9rico para o post.","type":"string","required":false},"status":{"description":"Um nome de status para o post.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","avvia_traduzione","crea_task_resolver"],"required":false},"password":{"description":"Uma senha para proteger o acesso ao conte\u00fado e resumo.","type":"string","required":false},"title":{"description":"O t\u00edtulo para o post.","type":"object","properties":{"raw":{"description":"T\u00edtulo para o post, como existe no banco de dados.","type":"string","context":["view","edit"]}},"required":false},"content":{"description":"O conte\u00fado para o post.","type":"object","properties":{"raw":{"description":"Conte\u00fado para o post, como ele existe no banco de dados.","type":"string","context":["view","edit"]},"block_version":{"description":"Vers\u00e3o do formato do conte\u00fado do bloco usado pelo post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Se o conte\u00fado \u00e9 protegido por senha.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"O resumo para o post.","type":"object","properties":{"raw":{"description":"Resumo para o post, como existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"Resumo para o post em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Se o resumo \u00e9 protegido por senha.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"Campos meta.","type":"object","properties":{"_yoast_wpseo_focuskw":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_metadesc":{"type":"string","title":"","description":"","default":""},"_data_scadenza_evento":{"type":"string","title":"","description":"","default":""},"_evento_nome":{"type":"string","title":"","description":"","default":""},"_evento_data":{"type":"string","title":"","description":"","default":""},"_evento_luogo":{"type":"string","title":"","description":"","default":""},"_evento_cta":{"type":"string","title":"","description":"","default":""},"keyword_en":{"type":"string","title":"","description":"","default":""},"keyword_es":{"type":"string","title":"","description":"","default":""},"keyword_fr":{"type":"string","title":"","description":"","default":""},"keyword_de":{"type":"string","title":"","description":"","default":""},"keyword_ptb":{"type":"string","title":"","description":"","default":""},"_note_content":{"type":"string","title":"","description":"","default":""},"wp_pattern_sync_status":{"type":"string","title":"","description":"","default":"","enum":["partial","unsynced"]},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"O arquivo do tema usado para exibir o post.","type":"string","required":false},"wp_pattern_category":{"description":"Os termos atribu\u00eddos ao post na taxonomia wp_pattern_category.","type":"array","items":{"type":"integer"},"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o post.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ignorar ou n\u00e3o o envio para a lixeira e for\u00e7ar a exclus\u00e3o.","required":false}}}]},"\/wp\/v2\/blocks\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"O ID do item ascendente \u00e0 revis\u00e3o.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina atual da cole\u00e7\u00e3o.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de itens retornados no resultado.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar resultados para aqueles que combinam com um texto.","type":"string","required":false},"exclude":{"description":"Garantir que o resultado exclua IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar resultados para IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Deslocar o resultado para um n\u00famero especifico de itens.","type":"integer","required":false},"order":{"description":"Ordenar atributos de forma ascendente ou descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar cole\u00e7\u00e3o pelo atributo do objeto.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/blocks\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"O ID do item ascendente \u00e0 revis\u00e3o.","type":"integer","required":false},"id":{"description":"Identificador \u00fanico da revis\u00e3o.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"O ID do item ascendente \u00e0 revis\u00e3o.","type":"integer","required":false},"id":{"description":"Identificador \u00fanico da revis\u00e3o.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Necess\u00e1rio ser verdadeiro, as revis\u00f5es n\u00e3o suportam lixeira.","required":false}}}]},"\/wp\/v2\/blocks\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"O ID do item ascendente ao salvamento autom\u00e1tico.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"O ID do item ascendente ao salvamento autom\u00e1tico.","type":"integer","required":false},"date":{"description":"Data da publica\u00e7\u00e3o do post, no fuso hor\u00e1rio do site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Data que o post foi publicado, em GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Um identificador alfanum\u00e9rico para o post.","type":"string","required":false},"status":{"description":"Um nome de status para o post.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","avvia_traduzione","crea_task_resolver"],"required":false},"password":{"description":"Uma senha para proteger o acesso ao conte\u00fado e resumo.","type":"string","required":false},"title":{"description":"O t\u00edtulo para o post.","type":"object","properties":{"raw":{"description":"T\u00edtulo para o post, como existe no banco de dados.","type":"string","context":["view","edit"]}},"required":false},"content":{"description":"O conte\u00fado para o post.","type":"object","properties":{"raw":{"description":"Conte\u00fado para o post, como ele existe no banco de dados.","type":"string","context":["view","edit"]},"block_version":{"description":"Vers\u00e3o do formato do conte\u00fado do bloco usado pelo post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Se o conte\u00fado \u00e9 protegido por senha.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"O resumo para o post.","type":"object","properties":{"raw":{"description":"Resumo para o post, como existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"Resumo para o post em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Se o resumo \u00e9 protegido por senha.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"Campos meta.","type":"object","properties":{"_yoast_wpseo_focuskw":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_metadesc":{"type":"string","title":"","description":"","default":""},"_data_scadenza_evento":{"type":"string","title":"","description":"","default":""},"_evento_nome":{"type":"string","title":"","description":"","default":""},"_evento_data":{"type":"string","title":"","description":"","default":""},"_evento_luogo":{"type":"string","title":"","description":"","default":""},"_evento_cta":{"type":"string","title":"","description":"","default":""},"keyword_en":{"type":"string","title":"","description":"","default":""},"keyword_es":{"type":"string","title":"","description":"","default":""},"keyword_fr":{"type":"string","title":"","description":"","default":""},"keyword_de":{"type":"string","title":"","description":"","default":""},"keyword_ptb":{"type":"string","title":"","description":"","default":""},"_note_content":{"type":"string","title":"","description":"","default":""},"wp_pattern_sync_status":{"type":"string","title":"","description":"","default":"","enum":["partial","unsynced"]},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"O arquivo do tema usado para exibir o post.","type":"string","required":false},"wp_pattern_category":{"description":"Os termos atribu\u00eddos ao post na taxonomia wp_pattern_category.","type":"array","items":{"type":"integer"},"required":false}}}]},"\/wp\/v2\/blocks\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"O ID do item ascendente ao salvamento autom\u00e1tico.","type":"integer","required":false},"id":{"description":"O ID do salvamento autom\u00e1tico.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/templates\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"O id de um modelo","type":"string","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina atual da cole\u00e7\u00e3o.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de itens retornados no resultado.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar resultados para aqueles que combinam com um texto.","type":"string","required":false},"exclude":{"description":"Garantir que o resultado exclua IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar resultados para IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Deslocar o resultado para um n\u00famero especifico de itens.","type":"integer","required":false},"order":{"description":"Ordenar atributos de forma ascendente ou descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar cole\u00e7\u00e3o pelo atributo do objeto.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/templates\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"O id de um modelo","type":"string","required":false},"id":{"description":"Identificador \u00fanico da revis\u00e3o.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"O id de um modelo","type":"string","required":false},"id":{"description":"Identificador \u00fanico da revis\u00e3o.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Necess\u00e1rio ser verdadeiro, as revis\u00f5es n\u00e3o suportam lixeira.","required":false}}}]},"\/wp\/v2\/templates\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"O id de um modelo","type":"string","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"id":{"description":"O id de um modelo","type":"string","required":false},"slug":{"description":"Slug \u00fanico que identifica o modelo.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"Identificador de tema para o modelo.","type":"string","required":false},"type":{"description":"Tipo do modelo.","type":"string","required":false},"content":{"description":"Conte\u00fado do modelo.","type":["object","string"],"properties":{"raw":{"description":"Conte\u00fado para o modelo, como existe no banco de dados.","type":"string","context":["view","edit"]},"block_version":{"description":"Vers\u00e3o do formato do bloco de conte\u00fado usado pelo modelo.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"T\u00edtulo do modelo.","type":["object","string"],"properties":{"raw":{"description":"T\u00edtulo para o modelo, como existe no banco de dados.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"T\u00edtulo para o modelo em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Descri\u00e7\u00e3o do modelo.","type":"string","required":false},"status":{"description":"Status do modelo.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","avvia_traduzione","crea_task_resolver"],"required":false},"author":{"description":"O ID do autor para o modelo.","type":"integer","required":false}}}]},"\/wp\/v2\/templates\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"O id de um modelo","type":"string","required":false},"id":{"description":"O ID do salvamento autom\u00e1tico.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/templates":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wp_id":{"description":"Limitar ao ID do post especificado.","type":"integer","required":false},"area":{"description":"Limitar \u00e0 \u00e1rea de parte de modelo especificada.","type":"string","required":false},"post_type":{"description":"Tipo de post para obter os modelos.","type":"string","required":false}}},{"methods":["POST"],"args":{"slug":{"description":"Slug \u00fanico que identifica o modelo.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":true},"theme":{"description":"Identificador de tema para o modelo.","type":"string","required":false},"type":{"description":"Tipo do modelo.","type":"string","required":false},"content":{"default":"","description":"Conte\u00fado do modelo.","type":["object","string"],"properties":{"raw":{"description":"Conte\u00fado para o modelo, como existe no banco de dados.","type":"string","context":["view","edit"]},"block_version":{"description":"Vers\u00e3o do formato do bloco de conte\u00fado usado pelo modelo.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"default":"","description":"T\u00edtulo do modelo.","type":["object","string"],"properties":{"raw":{"description":"T\u00edtulo para o modelo, como existe no banco de dados.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"T\u00edtulo para o modelo em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"default":"","description":"Descri\u00e7\u00e3o do modelo.","type":"string","required":false},"status":{"default":"publish","description":"Status do modelo.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","avvia_traduzione","crea_task_resolver"],"required":false},"author":{"description":"O ID do autor para o modelo.","type":"integer","required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/wp\/v2\/templates"}]}},"\/wp\/v2\/templates\/lookup":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"O slug do modelo para obter o padr\u00e3o para","type":"string","required":true},"is_custom":{"description":"Indica se um modelo \u00e9 personalizado ou faz parte da hierarquia de modelo","type":"boolean","required":false},"template_prefix":{"description":"O prefixo do modelo para o modelo criado. Isso \u00e9 usado para extrair o tipo de modelo principal, por exemplo, em `taxonomia-livros` extrai a `taxonomia`","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/wp\/v2\/templates\/lookup"}]}},"\/wp\/v2\/templates\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"O id de um modelo","type":"string","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"O id de um modelo","type":"string","required":false},"slug":{"description":"Slug \u00fanico que identifica o modelo.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"Identificador de tema para o modelo.","type":"string","required":false},"type":{"description":"Tipo do modelo.","type":"string","required":false},"content":{"description":"Conte\u00fado do modelo.","type":["object","string"],"properties":{"raw":{"description":"Conte\u00fado para o modelo, como existe no banco de dados.","type":"string","context":["view","edit"]},"block_version":{"description":"Vers\u00e3o do formato do bloco de conte\u00fado usado pelo modelo.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"T\u00edtulo do modelo.","type":["object","string"],"properties":{"raw":{"description":"T\u00edtulo para o modelo, como existe no banco de dados.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"T\u00edtulo para o modelo em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Descri\u00e7\u00e3o do modelo.","type":"string","required":false},"status":{"description":"Status do modelo.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","avvia_traduzione","crea_task_resolver"],"required":false},"author":{"description":"O ID do autor para o modelo.","type":"integer","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"O id de um modelo","type":"string","required":false},"force":{"type":"boolean","default":false,"description":"Ignorar ou n\u00e3o o envio para a lixeira e for\u00e7ar a exclus\u00e3o.","required":false}}}]},"\/wp\/v2\/template-parts\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"O id de um modelo","type":"string","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina atual da cole\u00e7\u00e3o.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de itens retornados no resultado.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar resultados para aqueles que combinam com um texto.","type":"string","required":false},"exclude":{"description":"Garantir que o resultado exclua IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar resultados para IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Deslocar o resultado para um n\u00famero especifico de itens.","type":"integer","required":false},"order":{"description":"Ordenar atributos de forma ascendente ou descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar cole\u00e7\u00e3o pelo atributo do objeto.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/template-parts\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"O id de um modelo","type":"string","required":false},"id":{"description":"Identificador \u00fanico da revis\u00e3o.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"O id de um modelo","type":"string","required":false},"id":{"description":"Identificador \u00fanico da revis\u00e3o.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Necess\u00e1rio ser verdadeiro, as revis\u00f5es n\u00e3o suportam lixeira.","required":false}}}]},"\/wp\/v2\/template-parts\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"O id de um modelo","type":"string","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"id":{"description":"O id de um modelo","type":"string","required":false},"slug":{"description":"Slug \u00fanico que identifica o modelo.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"Identificador de tema para o modelo.","type":"string","required":false},"type":{"description":"Tipo do modelo.","type":"string","required":false},"content":{"description":"Conte\u00fado do modelo.","type":["object","string"],"properties":{"raw":{"description":"Conte\u00fado para o modelo, como existe no banco de dados.","type":"string","context":["view","edit"]},"block_version":{"description":"Vers\u00e3o do formato do bloco de conte\u00fado usado pelo modelo.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"T\u00edtulo do modelo.","type":["object","string"],"properties":{"raw":{"description":"T\u00edtulo para o modelo, como existe no banco de dados.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"T\u00edtulo para o modelo em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Descri\u00e7\u00e3o do modelo.","type":"string","required":false},"status":{"description":"Status do modelo.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","avvia_traduzione","crea_task_resolver"],"required":false},"author":{"description":"O ID do autor para o modelo.","type":"integer","required":false},"area":{"description":"Onde a parte do modelo se destina a uso (cabe\u00e7alho, rodap\u00e9 etc.)","type":"string","required":false}}}]},"\/wp\/v2\/template-parts\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"O id de um modelo","type":"string","required":false},"id":{"description":"O ID do salvamento autom\u00e1tico.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/template-parts":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wp_id":{"description":"Limitar ao ID do post especificado.","type":"integer","required":false},"area":{"description":"Limitar \u00e0 \u00e1rea de parte de modelo especificada.","type":"string","required":false},"post_type":{"description":"Tipo de post para obter os modelos.","type":"string","required":false}}},{"methods":["POST"],"args":{"slug":{"description":"Slug \u00fanico que identifica o modelo.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":true},"theme":{"description":"Identificador de tema para o modelo.","type":"string","required":false},"type":{"description":"Tipo do modelo.","type":"string","required":false},"content":{"default":"","description":"Conte\u00fado do modelo.","type":["object","string"],"properties":{"raw":{"description":"Conte\u00fado para o modelo, como existe no banco de dados.","type":"string","context":["view","edit"]},"block_version":{"description":"Vers\u00e3o do formato do bloco de conte\u00fado usado pelo modelo.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"default":"","description":"T\u00edtulo do modelo.","type":["object","string"],"properties":{"raw":{"description":"T\u00edtulo para o modelo, como existe no banco de dados.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"T\u00edtulo para o modelo em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"default":"","description":"Descri\u00e7\u00e3o do modelo.","type":"string","required":false},"status":{"default":"publish","description":"Status do modelo.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","avvia_traduzione","crea_task_resolver"],"required":false},"author":{"description":"O ID do autor para o modelo.","type":"integer","required":false},"area":{"description":"Onde a parte do modelo se destina a uso (cabe\u00e7alho, rodap\u00e9 etc.)","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/wp\/v2\/template-parts"}]}},"\/wp\/v2\/template-parts\/lookup":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"O slug do modelo para obter o padr\u00e3o para","type":"string","required":true},"is_custom":{"description":"Indica se um modelo \u00e9 personalizado ou faz parte da hierarquia de modelo","type":"boolean","required":false},"template_prefix":{"description":"O prefixo do modelo para o modelo criado. Isso \u00e9 usado para extrair o tipo de modelo principal, por exemplo, em `taxonomia-livros` extrai a `taxonomia`","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/wp\/v2\/template-parts\/lookup"}]}},"\/wp\/v2\/template-parts\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"O id de um modelo","type":"string","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"O id de um modelo","type":"string","required":false},"slug":{"description":"Slug \u00fanico que identifica o modelo.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"Identificador de tema para o modelo.","type":"string","required":false},"type":{"description":"Tipo do modelo.","type":"string","required":false},"content":{"description":"Conte\u00fado do modelo.","type":["object","string"],"properties":{"raw":{"description":"Conte\u00fado para o modelo, como existe no banco de dados.","type":"string","context":["view","edit"]},"block_version":{"description":"Vers\u00e3o do formato do bloco de conte\u00fado usado pelo modelo.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"T\u00edtulo do modelo.","type":["object","string"],"properties":{"raw":{"description":"T\u00edtulo para o modelo, como existe no banco de dados.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"T\u00edtulo para o modelo em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Descri\u00e7\u00e3o do modelo.","type":"string","required":false},"status":{"description":"Status do modelo.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","avvia_traduzione","crea_task_resolver"],"required":false},"author":{"description":"O ID do autor para o modelo.","type":"integer","required":false},"area":{"description":"Onde a parte do modelo se destina a uso (cabe\u00e7alho, rodap\u00e9 etc.)","type":"string","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"O id de um modelo","type":"string","required":false},"force":{"type":"boolean","default":false,"description":"Ignorar ou n\u00e3o o envio para a lixeira e for\u00e7ar a exclus\u00e3o.","required":false}}}]},"\/wp\/v2\/global-styles\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"O ID do item ascendente \u00e0 revis\u00e3o.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina atual da cole\u00e7\u00e3o.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de itens retornados no resultado.","type":"integer","minimum":1,"maximum":100,"required":false},"offset":{"description":"Deslocar o resultado para um n\u00famero especifico de itens.","type":"integer","required":false}}}]},"\/wp\/v2\/global-styles\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"O ID ascendente da revis\u00e3o de estilos globais.","type":"integer","required":false},"id":{"description":"Identificador \u00fanico para a revis\u00e3o de estilos globais.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/global-styles\/themes\/(?P<stylesheet>[\\\/\\s%\\w\\.\\(\\)\\[\\]\\@_\\-]+)\/variations":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":false},"args":{"stylesheet":{"description":"O identificador do tema","type":"string","required":false}}}]},"\/wp\/v2\/global-styles\/themes\/(?P<stylesheet>[^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":false},"args":{"stylesheet":{"description":"O identificador do tema","type":"string","required":false}}}]},"\/wp\/v2\/global-styles\/(?P<id>[\\\/\\d+]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":false},"args":{"id":{"description":"ID da configura\u00e7\u00e3o de estilos globais.","type":"integer","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":false},"args":{"styles":{"description":"Estilos globais.","type":["object"],"required":false},"settings":{"description":"Configura\u00e7\u00f5es globais","type":["object"],"required":false},"title":{"description":"T\u00edtulo da varia\u00e7\u00e3o de estilos globais.","type":["object","string"],"properties":{"raw":{"description":"T\u00edtulo para a varia\u00e7\u00e3o de estilos globais, como no banco de dados.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"T\u00edtulo para o post em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false}}}]},"\/wp\/v2\/navigation":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina atual da cole\u00e7\u00e3o.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de itens retornados no resultado.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar resultados para aqueles que combinam com um texto.","type":"string","required":false},"after":{"description":"Limitar respostas a posts publicados depois de uma determinada data compat\u00edvel com o formato ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limitar respostas a posts modificados depois de uma determinada data compat\u00edvel com o formato ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limitar respostas a posts publicados antes de uma determinada data compat\u00edvel com o formato ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limitar respostas a posts modificados antes de uma determinada data compat\u00edvel com o formato ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Garantir que o resultado exclua IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar resultados para IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Como interpretar o campo de pesquisa.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Deslocar o resultado para um n\u00famero especifico de itens.","type":"integer","required":false},"order":{"description":"Ordenar atributos de forma ascendente ou descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar cole\u00e7\u00e3o pelo atributo do post.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array de nomes de colunas para serem pesquisadas.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limitar resultados de posts definidos por um ou mais slugs espec\u00edficos.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limitar resultados de posts atribu\u00eddo por um ou mais status.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","flamingo-spam","avvia_traduzione","crea_task_resolver","any"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"Data da publica\u00e7\u00e3o do post, no fuso hor\u00e1rio do site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Data que o post foi publicado, em GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Um identificador alfanum\u00e9rico para o post.","type":"string","required":false},"status":{"description":"Um nome de status para o post.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","avvia_traduzione","crea_task_resolver"],"required":false},"password":{"description":"Uma senha para proteger o acesso ao conte\u00fado e resumo.","type":"string","required":false},"title":{"description":"O t\u00edtulo para o post.","type":"object","properties":{"raw":{"description":"T\u00edtulo para o post, como existe no banco de dados.","type":"string","context":["edit","embed"]},"rendered":{"description":"T\u00edtulo para o post em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"O conte\u00fado para o post.","type":"object","properties":{"raw":{"description":"Conte\u00fado para o post, como ele existe no banco de dados.","type":"string","context":["edit","embed"]},"rendered":{"description":"Conte\u00fado HTML do post, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true},"block_version":{"description":"Vers\u00e3o do formato do conte\u00fado do bloco usado pelo post.","type":"integer","context":["edit","embed"],"readonly":true},"protected":{"description":"Se o conte\u00fado \u00e9 protegido por senha.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"O arquivo do tema usado para exibir o post.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/wp\/v2\/navigation"}]}},"\/wp\/v2\/navigation\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o post.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"A senha para o post se este for protegido por senha.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o post.","type":"integer","required":false},"date":{"description":"Data da publica\u00e7\u00e3o do post, no fuso hor\u00e1rio do site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Data que o post foi publicado, em GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Um identificador alfanum\u00e9rico para o post.","type":"string","required":false},"status":{"description":"Um nome de status para o post.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","avvia_traduzione","crea_task_resolver"],"required":false},"password":{"description":"Uma senha para proteger o acesso ao conte\u00fado e resumo.","type":"string","required":false},"title":{"description":"O t\u00edtulo para o post.","type":"object","properties":{"raw":{"description":"T\u00edtulo para o post, como existe no banco de dados.","type":"string","context":["edit","embed"]},"rendered":{"description":"T\u00edtulo para o post em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"O conte\u00fado para o post.","type":"object","properties":{"raw":{"description":"Conte\u00fado para o post, como ele existe no banco de dados.","type":"string","context":["edit","embed"]},"rendered":{"description":"Conte\u00fado HTML do post, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true},"block_version":{"description":"Vers\u00e3o do formato do conte\u00fado do bloco usado pelo post.","type":"integer","context":["edit","embed"],"readonly":true},"protected":{"description":"Se o conte\u00fado \u00e9 protegido por senha.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"O arquivo do tema usado para exibir o post.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o post.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ignorar ou n\u00e3o o envio para a lixeira e for\u00e7ar a exclus\u00e3o.","required":false}}}]},"\/wp\/v2\/navigation\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"O ID do item ascendente \u00e0 revis\u00e3o.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina atual da cole\u00e7\u00e3o.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de itens retornados no resultado.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar resultados para aqueles que combinam com um texto.","type":"string","required":false},"exclude":{"description":"Garantir que o resultado exclua IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar resultados para IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Deslocar o resultado para um n\u00famero especifico de itens.","type":"integer","required":false},"order":{"description":"Ordenar atributos de forma ascendente ou descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar cole\u00e7\u00e3o pelo atributo do objeto.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/navigation\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"O ID do item ascendente \u00e0 revis\u00e3o.","type":"integer","required":false},"id":{"description":"Identificador \u00fanico da revis\u00e3o.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"O ID do item ascendente \u00e0 revis\u00e3o.","type":"integer","required":false},"id":{"description":"Identificador \u00fanico da revis\u00e3o.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Necess\u00e1rio ser verdadeiro, as revis\u00f5es n\u00e3o suportam lixeira.","required":false}}}]},"\/wp\/v2\/navigation\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"O ID do item ascendente ao salvamento autom\u00e1tico.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"O ID do item ascendente ao salvamento autom\u00e1tico.","type":"integer","required":false},"date":{"description":"Data da publica\u00e7\u00e3o do post, no fuso hor\u00e1rio do site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Data que o post foi publicado, em GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Um identificador alfanum\u00e9rico para o post.","type":"string","required":false},"status":{"description":"Um nome de status para o post.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","avvia_traduzione","crea_task_resolver"],"required":false},"password":{"description":"Uma senha para proteger o acesso ao conte\u00fado e resumo.","type":"string","required":false},"title":{"description":"O t\u00edtulo para o post.","type":"object","properties":{"raw":{"description":"T\u00edtulo para o post, como existe no banco de dados.","type":"string","context":["edit","embed"]},"rendered":{"description":"T\u00edtulo para o post em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"O conte\u00fado para o post.","type":"object","properties":{"raw":{"description":"Conte\u00fado para o post, como ele existe no banco de dados.","type":"string","context":["edit","embed"]},"rendered":{"description":"Conte\u00fado HTML do post, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true},"block_version":{"description":"Vers\u00e3o do formato do conte\u00fado do bloco usado pelo post.","type":"integer","context":["edit","embed"],"readonly":true},"protected":{"description":"Se o conte\u00fado \u00e9 protegido por senha.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"O arquivo do tema usado para exibir o post.","type":"string","required":false}}}]},"\/wp\/v2\/navigation\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"O ID do item ascendente ao salvamento autom\u00e1tico.","type":"integer","required":false},"id":{"description":"O ID do salvamento autom\u00e1tico.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/font-families":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina atual da cole\u00e7\u00e3o.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de itens retornados no resultado.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"exclude":{"description":"Garantir que o resultado exclua IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar resultados para IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Como interpretar o campo de pesquisa.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Deslocar o resultado para um n\u00famero especifico de itens.","type":"integer","required":false},"order":{"description":"Ordenar atributos de forma ascendente ou descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar cole\u00e7\u00e3o pelo atributo do post.","type":"string","default":"id","enum":["id","include"],"required":false},"slug":{"description":"Limitar resultados de posts definidos por um ou mais slugs espec\u00edficos.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"args":{"theme_json_version":{"description":"Vers\u00e3o do schema do theme.json utilizado para as configura\u00e7\u00f5es de tipografia.","type":"integer","default":3,"minimum":2,"maximum":3,"required":false},"font_family_settings":{"description":"declara\u00e7\u00e3o font-family no formato para o theme.json, codificado como uma string.","type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/wp\/v2\/font-families"}]}},"\/wp\/v2\/font-families\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identificador \u00fanico para o post.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identificador \u00fanico para o post.","type":"integer","required":false},"theme_json_version":{"description":"Vers\u00e3o do schema do theme.json utilizado para as configura\u00e7\u00f5es de tipografia.","type":"integer","default":3,"minimum":2,"maximum":3,"required":false},"font_family_settings":{"description":"declara\u00e7\u00e3o font-family no formato para o theme.json, codificado como uma string.","type":"string","required":true}}},{"methods":["DELETE"],"args":{"id":{"description":"Identificador \u00fanico para o post.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ignorar ou n\u00e3o o envio para a lixeira e for\u00e7ar a exclus\u00e3o.","required":false}}}]},"\/wp\/v2\/font-families\/(?P<font_family_id>[\\d]+)\/font-faces":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"font_family_id":{"description":"O ID para a fam\u00edlia de fontes ascendente do tipo de fonte.","type":"integer","required":true},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina atual da cole\u00e7\u00e3o.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de itens retornados no resultado.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"exclude":{"description":"Garantir que o resultado exclua IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar resultados para IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Como interpretar o campo de pesquisa.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Deslocar o resultado para um n\u00famero especifico de itens.","type":"integer","required":false},"order":{"description":"Ordenar atributos de forma ascendente ou descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar cole\u00e7\u00e3o pelo atributo do post.","type":"string","default":"id","enum":["id","include"],"required":false}}},{"methods":["POST"],"args":{"font_family_id":{"description":"O ID para a fam\u00edlia de fontes ascendente do tipo de fonte.","type":"integer","required":true},"theme_json_version":{"description":"Vers\u00e3o do schema do theme.json utilizado para as configura\u00e7\u00f5es de tipografia.","type":"integer","default":3,"minimum":2,"maximum":3,"required":false},"font_face_settings":{"description":"declara\u00e7\u00e3o font-face no formato para o theme.json, codificado como uma string.","type":"string","required":true}}}]},"\/wp\/v2\/font-families\/(?P<font_family_id>[\\d]+)\/font-faces\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"font_family_id":{"description":"O ID para a fam\u00edlia de fontes ascendente do tipo de fonte.","type":"integer","required":true},"id":{"description":"Identificador \u00fanico para o tipo de fonte.","type":"integer","required":true},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"font_family_id":{"description":"O ID para a fam\u00edlia de fontes ascendente do tipo de fonte.","type":"integer","required":true},"id":{"description":"Identificador \u00fanico para o tipo de fonte.","type":"integer","required":true},"force":{"type":"boolean","default":false,"description":"Ignorar ou n\u00e3o o envio para a lixeira e for\u00e7ar a exclus\u00e3o.","required":false}}}]},"\/wp\/v2\/portfolio":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina atual da cole\u00e7\u00e3o.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de itens retornados no resultado.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar resultados para aqueles que combinam com um texto.","type":"string","required":false},"after":{"description":"Limitar respostas a posts publicados depois de uma determinada data compat\u00edvel com o formato ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limitar respostas a posts modificados depois de uma determinada data compat\u00edvel com o formato ISO8601.","type":"string","format":"date-time","required":false},"author":{"description":"Limitar resultados a posts atribu\u00eddos a autores espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Garantir que o resultado exclui posts atribu\u00eddos a autores espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limitar respostas a posts publicados antes de uma determinada data compat\u00edvel com o formato ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limitar respostas a posts modificados antes de uma determinada data compat\u00edvel com o formato ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Garantir que o resultado exclua IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar resultados para IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Como interpretar o campo de pesquisa.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Deslocar o resultado para um n\u00famero especifico de itens.","type":"integer","required":false},"order":{"description":"Ordenar atributos de forma ascendente ou descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar cole\u00e7\u00e3o pelo atributo do post.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array de nomes de colunas para serem pesquisadas.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limitar resultados de posts definidos por um ou mais slugs espec\u00edficos.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limitar resultados de posts atribu\u00eddo por um ou mais status.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","flamingo-spam","avvia_traduzione","crea_task_resolver","any"],"type":"string"},"required":false},"tax_relation":{"description":"Limitar resultados com base no relacionamento entre m\u00faltiplas taxonomias.","type":"string","enum":["AND","OR"],"required":false},"tags":{"description":"Limitar resultados para todos os itens com termos espec\u00edficos atribu\u00eddos a taxonomia tags.","type":["object","array"],"oneOf":[{"title":"Lista de ID de termos","description":"Combinar os termos com os IDs listados.","type":"array","items":{"type":"integer"}},{"title":"Consulta da taxonomia do ID do termo","description":"Executar uma consulta avan\u00e7a de termos.","type":"object","properties":{"terms":{"description":"IDs dos termos.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Se os items devem ser atribu\u00eddos a todos ou a qualquer um dos termos especificados.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"tags_exclude":{"description":"Limitar resultados para todos os itens que tenham o termo espec\u00edfico atribu\u00eddo para a taxonomia tags.","type":["object","array"],"oneOf":[{"title":"Lista de ID de termos","description":"Combinar os termos com os IDs listados.","type":"array","items":{"type":"integer"}},{"title":"Consulta da taxonomia do ID do termo","description":"Executar uma consulta avan\u00e7a de termos.","type":"object","properties":{"terms":{"description":"IDs dos termos.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"portfolio_entries":{"description":"Limitar resultados para todos os itens com termos espec\u00edficos atribu\u00eddos a taxonomia portfolio_entries.","type":["object","array"],"oneOf":[{"title":"Lista de ID de termos","description":"Combinar os termos com os IDs listados.","type":"array","items":{"type":"integer"}},{"title":"Consulta da taxonomia do ID do termo","description":"Executar uma consulta avan\u00e7a de termos.","type":"object","properties":{"terms":{"description":"IDs dos termos.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Possibilidade de incluir termos descendentes nos termos limitando o conjunto de resultados.","type":"boolean","default":false},"operator":{"description":"Se os items devem ser atribu\u00eddos a todos ou a qualquer um dos termos especificados.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"portfolio_entries_exclude":{"description":"Limitar resultados para todos os itens que tenham o termo espec\u00edfico atribu\u00eddo para a taxonomia portfolio_entries.","type":["object","array"],"oneOf":[{"title":"Lista de ID de termos","description":"Combinar os termos com os IDs listados.","type":"array","items":{"type":"integer"}},{"title":"Consulta da taxonomia do ID do termo","description":"Executar uma consulta avan\u00e7a de termos.","type":"object","properties":{"terms":{"description":"IDs dos termos.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Possibilidade de incluir termos descendentes nos termos limitando o conjunto de resultados.","type":"boolean","default":false}},"additionalProperties":false}],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"Data da publica\u00e7\u00e3o do post, no fuso hor\u00e1rio do site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Data que o post foi publicado, em GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Um identificador alfanum\u00e9rico para o post.","type":"string","required":false},"status":{"description":"Um nome de status para o post.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","avvia_traduzione","crea_task_resolver"],"required":false},"password":{"description":"Uma senha para proteger o acesso ao conte\u00fado e resumo.","type":"string","required":false},"title":{"description":"O t\u00edtulo para o post.","type":"object","properties":{"raw":{"description":"T\u00edtulo para o post, como existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo para o post em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"O conte\u00fado para o post.","type":"object","properties":{"raw":{"description":"Conte\u00fado para o post, como ele existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"Conte\u00fado HTML do post, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Vers\u00e3o do formato do conte\u00fado do bloco usado pelo post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Se o conte\u00fado \u00e9 protegido por senha.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"O ID do autor para o post.","type":"integer","required":false},"excerpt":{"description":"O resumo para o post.","type":"object","properties":{"raw":{"description":"Resumo para o post, como existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"Resumo para o post em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Se o resumo \u00e9 protegido por senha.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"O ID da imagem destacada para o post.","type":"integer","required":false},"comment_status":{"description":"Se os coment\u00e1rios no post devem ou n\u00e3o ser abertos.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Se o post pode receber chamadas ping.","type":"string","enum":["open","closed"],"required":false},"meta":{"description":"Campos meta.","type":"object","properties":{"_yoast_wpseo_focuskw":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_metadesc":{"type":"string","title":"","description":"","default":""},"_data_scadenza_evento":{"type":"string","title":"","description":"","default":""},"_evento_nome":{"type":"string","title":"","description":"","default":""},"_evento_data":{"type":"string","title":"","description":"","default":""},"_evento_luogo":{"type":"string","title":"","description":"","default":""},"_evento_cta":{"type":"string","title":"","description":"","default":""},"keyword_en":{"type":"string","title":"","description":"","default":""},"keyword_es":{"type":"string","title":"","description":"","default":""},"keyword_fr":{"type":"string","title":"","description":"","default":""},"keyword_de":{"type":"string","title":"","description":"","default":""},"keyword_ptb":{"type":"string","title":"","description":"","default":""},"_note_content":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"O arquivo do tema usado para exibir o post.","type":"string","required":false},"tags":{"description":"Os termos atribu\u00eddos ao post na taxonomia post_tag.","type":"array","items":{"type":"integer"},"required":false},"portfolio_entries":{"description":"Os termos atribu\u00eddos ao post na taxonomia portfolio_entries.","type":"array","items":{"type":"integer"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/wp\/v2\/portfolio"}]}},"\/wp\/v2\/portfolio\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o post.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"Substitui o tamanho padr\u00e3o do resumo.","type":"integer","required":false},"password":{"description":"A senha para o post se este for protegido por senha.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o post.","type":"integer","required":false},"date":{"description":"Data da publica\u00e7\u00e3o do post, no fuso hor\u00e1rio do site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Data que o post foi publicado, em GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Um identificador alfanum\u00e9rico para o post.","type":"string","required":false},"status":{"description":"Um nome de status para o post.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","avvia_traduzione","crea_task_resolver"],"required":false},"password":{"description":"Uma senha para proteger o acesso ao conte\u00fado e resumo.","type":"string","required":false},"title":{"description":"O t\u00edtulo para o post.","type":"object","properties":{"raw":{"description":"T\u00edtulo para o post, como existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo para o post em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"O conte\u00fado para o post.","type":"object","properties":{"raw":{"description":"Conte\u00fado para o post, como ele existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"Conte\u00fado HTML do post, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Vers\u00e3o do formato do conte\u00fado do bloco usado pelo post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Se o conte\u00fado \u00e9 protegido por senha.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"O ID do autor para o post.","type":"integer","required":false},"excerpt":{"description":"O resumo para o post.","type":"object","properties":{"raw":{"description":"Resumo para o post, como existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"Resumo para o post em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Se o resumo \u00e9 protegido por senha.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"O ID da imagem destacada para o post.","type":"integer","required":false},"comment_status":{"description":"Se os coment\u00e1rios no post devem ou n\u00e3o ser abertos.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Se o post pode receber chamadas ping.","type":"string","enum":["open","closed"],"required":false},"meta":{"description":"Campos meta.","type":"object","properties":{"_yoast_wpseo_focuskw":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_metadesc":{"type":"string","title":"","description":"","default":""},"_data_scadenza_evento":{"type":"string","title":"","description":"","default":""},"_evento_nome":{"type":"string","title":"","description":"","default":""},"_evento_data":{"type":"string","title":"","description":"","default":""},"_evento_luogo":{"type":"string","title":"","description":"","default":""},"_evento_cta":{"type":"string","title":"","description":"","default":""},"keyword_en":{"type":"string","title":"","description":"","default":""},"keyword_es":{"type":"string","title":"","description":"","default":""},"keyword_fr":{"type":"string","title":"","description":"","default":""},"keyword_de":{"type":"string","title":"","description":"","default":""},"keyword_ptb":{"type":"string","title":"","description":"","default":""},"_note_content":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"O arquivo do tema usado para exibir o post.","type":"string","required":false},"tags":{"description":"Os termos atribu\u00eddos ao post na taxonomia post_tag.","type":"array","items":{"type":"integer"},"required":false},"portfolio_entries":{"description":"Os termos atribu\u00eddos ao post na taxonomia portfolio_entries.","type":"array","items":{"type":"integer"},"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o post.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ignorar ou n\u00e3o o envio para a lixeira e for\u00e7ar a exclus\u00e3o.","required":false}}}]},"\/wp\/v2\/portfolio\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"O ID do item ascendente \u00e0 revis\u00e3o.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina atual da cole\u00e7\u00e3o.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de itens retornados no resultado.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar resultados para aqueles que combinam com um texto.","type":"string","required":false},"exclude":{"description":"Garantir que o resultado exclua IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar resultados para IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Deslocar o resultado para um n\u00famero especifico de itens.","type":"integer","required":false},"order":{"description":"Ordenar atributos de forma ascendente ou descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar cole\u00e7\u00e3o pelo atributo do objeto.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/portfolio\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"O ID do item ascendente \u00e0 revis\u00e3o.","type":"integer","required":false},"id":{"description":"Identificador \u00fanico da revis\u00e3o.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"O ID do item ascendente \u00e0 revis\u00e3o.","type":"integer","required":false},"id":{"description":"Identificador \u00fanico da revis\u00e3o.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Necess\u00e1rio ser verdadeiro, as revis\u00f5es n\u00e3o suportam lixeira.","required":false}}}]},"\/wp\/v2\/portfolio\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"O ID do item ascendente ao salvamento autom\u00e1tico.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"O ID do item ascendente ao salvamento autom\u00e1tico.","type":"integer","required":false},"date":{"description":"Data da publica\u00e7\u00e3o do post, no fuso hor\u00e1rio do site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Data que o post foi publicado, em GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Um identificador alfanum\u00e9rico para o post.","type":"string","required":false},"status":{"description":"Um nome de status para o post.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","avvia_traduzione","crea_task_resolver"],"required":false},"password":{"description":"Uma senha para proteger o acesso ao conte\u00fado e resumo.","type":"string","required":false},"title":{"description":"O t\u00edtulo para o post.","type":"object","properties":{"raw":{"description":"T\u00edtulo para o post, como existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo para o post em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"O conte\u00fado para o post.","type":"object","properties":{"raw":{"description":"Conte\u00fado para o post, como ele existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"Conte\u00fado HTML do post, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Vers\u00e3o do formato do conte\u00fado do bloco usado pelo post.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Se o conte\u00fado \u00e9 protegido por senha.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"O ID do autor para o post.","type":"integer","required":false},"excerpt":{"description":"O resumo para o post.","type":"object","properties":{"raw":{"description":"Resumo para o post, como existe no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"Resumo para o post em HTML, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Se o resumo \u00e9 protegido por senha.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"O ID da imagem destacada para o post.","type":"integer","required":false},"comment_status":{"description":"Se os coment\u00e1rios no post devem ou n\u00e3o ser abertos.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Se o post pode receber chamadas ping.","type":"string","enum":["open","closed"],"required":false},"meta":{"description":"Campos meta.","type":"object","properties":{"_yoast_wpseo_focuskw":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_metadesc":{"type":"string","title":"","description":"","default":""},"_data_scadenza_evento":{"type":"string","title":"","description":"","default":""},"_evento_nome":{"type":"string","title":"","description":"","default":""},"_evento_data":{"type":"string","title":"","description":"","default":""},"_evento_luogo":{"type":"string","title":"","description":"","default":""},"_evento_cta":{"type":"string","title":"","description":"","default":""},"keyword_en":{"type":"string","title":"","description":"","default":""},"keyword_es":{"type":"string","title":"","description":"","default":""},"keyword_fr":{"type":"string","title":"","description":"","default":""},"keyword_de":{"type":"string","title":"","description":"","default":""},"keyword_ptb":{"type":"string","title":"","description":"","default":""},"_note_content":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"O arquivo do tema usado para exibir o post.","type":"string","required":false},"tags":{"description":"Os termos atribu\u00eddos ao post na taxonomia post_tag.","type":"array","items":{"type":"integer"},"required":false},"portfolio_entries":{"description":"Os termos atribu\u00eddos ao post na taxonomia portfolio_entries.","type":"array","items":{"type":"integer"},"required":false}}}]},"\/wp\/v2\/portfolio\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"O ID do item ascendente ao salvamento autom\u00e1tico.","type":"integer","required":false},"id":{"description":"O ID do salvamento autom\u00e1tico.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/types":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/wp\/v2\/types"}]}},"\/wp\/v2\/types\/(?P<type>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"type":{"description":"Um identificador alfanum\u00e9rico para o tipo de post.","type":"string","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/statuses":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/wp\/v2\/statuses"}]}},"\/wp\/v2\/statuses\/(?P<status>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"status":{"description":"Um identificador alfanum\u00e9rico para o status.","type":"string","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/taxonomies":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"type":{"description":"Limitar resultados para taxonomias associadas com um tipo especifico de post.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/wp\/v2\/taxonomies"}]}},"\/wp\/v2\/taxonomies\/(?P<taxonomy>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"taxonomy":{"description":"Um identificador alfanum\u00e9rico para a taxonomia.","type":"string","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/categories":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina atual da cole\u00e7\u00e3o.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de itens retornados no resultado.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar resultados para aqueles que combinam com um texto.","type":"string","required":false},"exclude":{"description":"Garantir que o resultado exclua IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar resultados para IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"order":{"description":"Ordenar atributos de forma ascendente ou descendente.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar cole\u00e7\u00e3o por termo de atributo.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Se deseja ocultar termos n\u00e3o atribu\u00eddos a posts.","type":"boolean","default":false,"required":false},"parent":{"description":"Limitar resultados de termos atribu\u00eddos a um ascendente espec\u00edfico.","type":"integer","required":false},"post":{"description":"Limitar resultados de termos atribu\u00eddos a um post espec\u00edfico.","type":"integer","default":null,"required":false},"slug":{"description":"Limitar resultados a termos com um ou mais slugs espec\u00edficos.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"Descri\u00e7\u00e3o HTML do recurso.","type":"string","required":false},"name":{"description":"T\u00edtulo em HTML para o termo.","type":"string","required":true},"slug":{"description":"Um identificador alfanum\u00e9rico para o termo \u00fanico do seu tipo.","type":"string","required":false},"parent":{"description":"ID do termo ascendente.","type":"integer","required":false},"meta":{"description":"Campos meta.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/wp\/v2\/categories"}]}},"\/wp\/v2\/categories\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o termo.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o termo.","type":"integer","required":false},"description":{"description":"Descri\u00e7\u00e3o HTML do recurso.","type":"string","required":false},"name":{"description":"T\u00edtulo em HTML para o termo.","type":"string","required":false},"slug":{"description":"Um identificador alfanum\u00e9rico para o termo \u00fanico do seu tipo.","type":"string","required":false},"parent":{"description":"ID do termo ascendente.","type":"integer","required":false},"meta":{"description":"Campos meta.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o termo.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Necess\u00e1rio ser verdadeiro, os termos n\u00e3o suportam lixeira.","required":false}}}]},"\/wp\/v2\/tags":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina atual da cole\u00e7\u00e3o.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de itens retornados no resultado.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar resultados para aqueles que combinam com um texto.","type":"string","required":false},"exclude":{"description":"Garantir que o resultado exclua IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar resultados para IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Deslocar o resultado para um n\u00famero especifico de itens.","type":"integer","required":false},"order":{"description":"Ordenar atributos de forma ascendente ou descendente.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar cole\u00e7\u00e3o por termo de atributo.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Se deseja ocultar termos n\u00e3o atribu\u00eddos a posts.","type":"boolean","default":false,"required":false},"post":{"description":"Limitar resultados de termos atribu\u00eddos a um post espec\u00edfico.","type":"integer","default":null,"required":false},"slug":{"description":"Limitar resultados a termos com um ou mais slugs espec\u00edficos.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"Descri\u00e7\u00e3o HTML do recurso.","type":"string","required":false},"name":{"description":"T\u00edtulo em HTML para o termo.","type":"string","required":true},"slug":{"description":"Um identificador alfanum\u00e9rico para o termo \u00fanico do seu tipo.","type":"string","required":false},"meta":{"description":"Campos meta.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/wp\/v2\/tags"}]}},"\/wp\/v2\/tags\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o termo.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o termo.","type":"integer","required":false},"description":{"description":"Descri\u00e7\u00e3o HTML do recurso.","type":"string","required":false},"name":{"description":"T\u00edtulo em HTML para o termo.","type":"string","required":false},"slug":{"description":"Um identificador alfanum\u00e9rico para o termo \u00fanico do seu tipo.","type":"string","required":false},"meta":{"description":"Campos meta.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o termo.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Necess\u00e1rio ser verdadeiro, os termos n\u00e3o suportam lixeira.","required":false}}}]},"\/wp\/v2\/menus":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina atual da cole\u00e7\u00e3o.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de itens retornados no resultado.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar resultados para aqueles que combinam com um texto.","type":"string","required":false},"exclude":{"description":"Garantir que o resultado exclua IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar resultados para IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Deslocar o resultado para um n\u00famero especifico de itens.","type":"integer","required":false},"order":{"description":"Ordenar atributos de forma ascendente ou descendente.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar cole\u00e7\u00e3o por termo de atributo.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Se deseja ocultar termos n\u00e3o atribu\u00eddos a posts.","type":"boolean","default":false,"required":false},"post":{"description":"Limitar resultados de termos atribu\u00eddos a um post espec\u00edfico.","type":"integer","default":null,"required":false},"slug":{"description":"Limitar resultados a termos com um ou mais slugs espec\u00edficos.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"Descri\u00e7\u00e3o HTML do recurso.","type":"string","required":false},"name":{"description":"T\u00edtulo em HTML para o termo.","type":"string","required":true},"slug":{"description":"Um identificador alfanum\u00e9rico para o termo \u00fanico do seu tipo.","type":"string","required":false},"meta":{"description":"Campos meta.","type":"object","properties":[],"required":false},"locations":{"description":"As localiza\u00e7\u00f5es atribu\u00eddas ao menu.","type":"array","items":{"type":"string"},"required":false},"auto_add":{"description":"Se as p\u00e1ginas de n\u00edvel superior ser\u00e3o adicionadas automaticamente a este menu ou n\u00e3o.","type":"boolean","required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/wp\/v2\/menus"}]}},"\/wp\/v2\/menus\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o termo.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o termo.","type":"integer","required":false},"description":{"description":"Descri\u00e7\u00e3o HTML do recurso.","type":"string","required":false},"name":{"description":"T\u00edtulo em HTML para o termo.","type":"string","required":false},"slug":{"description":"Um identificador alfanum\u00e9rico para o termo \u00fanico do seu tipo.","type":"string","required":false},"meta":{"description":"Campos meta.","type":"object","properties":[],"required":false},"locations":{"description":"As localiza\u00e7\u00f5es atribu\u00eddas ao menu.","type":"array","items":{"type":"string"},"required":false},"auto_add":{"description":"Se as p\u00e1ginas de n\u00edvel superior ser\u00e3o adicionadas automaticamente a este menu ou n\u00e3o.","type":"boolean","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o termo.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Necess\u00e1rio ser verdadeiro, os termos n\u00e3o suportam lixeira.","required":false}}}]},"\/wp\/v2\/wp_pattern_category":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina atual da cole\u00e7\u00e3o.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de itens retornados no resultado.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar resultados para aqueles que combinam com um texto.","type":"string","required":false},"exclude":{"description":"Garantir que o resultado exclua IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar resultados para IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Deslocar o resultado para um n\u00famero especifico de itens.","type":"integer","required":false},"order":{"description":"Ordenar atributos de forma ascendente ou descendente.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar cole\u00e7\u00e3o por termo de atributo.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Se deseja ocultar termos n\u00e3o atribu\u00eddos a posts.","type":"boolean","default":false,"required":false},"post":{"description":"Limitar resultados de termos atribu\u00eddos a um post espec\u00edfico.","type":"integer","default":null,"required":false},"slug":{"description":"Limitar resultados a termos com um ou mais slugs espec\u00edficos.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"Descri\u00e7\u00e3o HTML do recurso.","type":"string","required":false},"name":{"description":"T\u00edtulo em HTML para o termo.","type":"string","required":true},"slug":{"description":"Um identificador alfanum\u00e9rico para o termo \u00fanico do seu tipo.","type":"string","required":false},"meta":{"description":"Campos meta.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/wp\/v2\/wp_pattern_category"}]}},"\/wp\/v2\/wp_pattern_category\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o termo.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o termo.","type":"integer","required":false},"description":{"description":"Descri\u00e7\u00e3o HTML do recurso.","type":"string","required":false},"name":{"description":"T\u00edtulo em HTML para o termo.","type":"string","required":false},"slug":{"description":"Um identificador alfanum\u00e9rico para o termo \u00fanico do seu tipo.","type":"string","required":false},"meta":{"description":"Campos meta.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o termo.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Necess\u00e1rio ser verdadeiro, os termos n\u00e3o suportam lixeira.","required":false}}}]},"\/wp\/v2\/portfolio_entries":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina atual da cole\u00e7\u00e3o.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de itens retornados no resultado.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar resultados para aqueles que combinam com um texto.","type":"string","required":false},"exclude":{"description":"Garantir que o resultado exclua IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar resultados para IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"order":{"description":"Ordenar atributos de forma ascendente ou descendente.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar cole\u00e7\u00e3o por termo de atributo.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Se deseja ocultar termos n\u00e3o atribu\u00eddos a posts.","type":"boolean","default":false,"required":false},"parent":{"description":"Limitar resultados de termos atribu\u00eddos a um ascendente espec\u00edfico.","type":"integer","required":false},"post":{"description":"Limitar resultados de termos atribu\u00eddos a um post espec\u00edfico.","type":"integer","default":null,"required":false},"slug":{"description":"Limitar resultados a termos com um ou mais slugs espec\u00edficos.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"Descri\u00e7\u00e3o HTML do recurso.","type":"string","required":false},"name":{"description":"T\u00edtulo em HTML para o termo.","type":"string","required":true},"slug":{"description":"Um identificador alfanum\u00e9rico para o termo \u00fanico do seu tipo.","type":"string","required":false},"parent":{"description":"ID do termo ascendente.","type":"integer","required":false},"meta":{"description":"Campos meta.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/wp\/v2\/portfolio_entries"}]}},"\/wp\/v2\/portfolio_entries\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o termo.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o termo.","type":"integer","required":false},"description":{"description":"Descri\u00e7\u00e3o HTML do recurso.","type":"string","required":false},"name":{"description":"T\u00edtulo em HTML para o termo.","type":"string","required":false},"slug":{"description":"Um identificador alfanum\u00e9rico para o termo \u00fanico do seu tipo.","type":"string","required":false},"parent":{"description":"ID do termo ascendente.","type":"integer","required":false},"meta":{"description":"Campos meta.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o termo.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Necess\u00e1rio ser verdadeiro, os termos n\u00e3o suportam lixeira.","required":false}}}]},"\/wp\/v2\/users":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina atual da cole\u00e7\u00e3o.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de itens retornados no resultado.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar resultados para aqueles que combinam com um texto.","type":"string","required":false},"exclude":{"description":"Garantir que o resultado exclua IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar resultados para IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Deslocar o resultado para um n\u00famero especifico de itens.","type":"integer","required":false},"order":{"default":"asc","description":"Ordenar atributos de forma ascendente ou descendente.","enum":["asc","desc"],"type":"string","required":false},"orderby":{"default":"name","description":"Ordenar cole\u00e7\u00e3o por atributo do usu\u00e1rio.","enum":["id","include","name","registered_date","slug","include_slugs","email","url"],"type":"string","required":false},"slug":{"description":"Limitar resultados a usu\u00e1rios com um ou mais slugs espec\u00edficos.","type":"array","items":{"type":"string"},"required":false},"roles":{"description":"Limitar resultados a usu\u00e1rios que tenham pelo menos uma dada fun\u00e7\u00e3o espec\u00edfica. Aceita lista separada por v\u00edrgulas ou uma fun\u00e7\u00e3o apenas.","type":"array","items":{"type":"string"},"required":false},"capabilities":{"description":"Limitar resultados a usu\u00e1rios que tenham pelo menos uma dada capacidade espec\u00edfica. Aceita lista separada por v\u00edrgulas ou uma capacidade apenas.","type":"array","items":{"type":"string"},"required":false},"who":{"description":"Limitar resultados a usu\u00e1rios considerados autores.","type":"string","enum":["authors"],"required":false},"has_published_posts":{"description":"Limitar resultados para usu\u00e1rios que publicaram posts.","type":["boolean","array"],"items":{"type":"string","enum":{"post":"post","page":"page","attachment":"attachment","nav_menu_item":"nav_menu_item","wp_block":"wp_block","wp_template":"wp_template","wp_template_part":"wp_template_part","wp_global_styles":"wp_global_styles","wp_navigation":"wp_navigation","wp_font_family":"wp_font_family","wp_font_face":"wp_font_face","portfolio":"portfolio"}},"required":false},"search_columns":{"default":[],"description":"Array de nomes de colunas para serem pesquisadas.","type":"array","items":{"enum":["email","name","id","username","slug"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"username":{"description":"Nome de login para o usu\u00e1rio.","type":"string","required":true},"name":{"description":"Nome de exibi\u00e7\u00e3o para o usu\u00e1rio.","type":"string","required":false},"first_name":{"description":"Nome para o usu\u00e1rio.","type":"string","required":false},"last_name":{"description":"Sobrenome para o usu\u00e1rio.","type":"string","required":false},"email":{"description":"O endere\u00e7o de e-mail para o usu\u00e1rio.","type":"string","format":"email","required":true},"url":{"description":"URL do usu\u00e1rio.","type":"string","format":"uri","required":false},"description":{"description":"Descri\u00e7\u00e3o do usu\u00e1rio.","type":"string","required":false},"locale":{"description":"Localidade para o usu\u00e1rio.","type":"string","enum":["","en_US","de_DE","en_GB","es_ES","fr_FR","it_IT","pt_BR"],"required":false},"nickname":{"description":"O apelido para o usu\u00e1rio.","type":"string","required":false},"slug":{"description":"Um identificador alfanum\u00e9rico para o usu\u00e1rio.","type":"string","required":false},"roles":{"description":"Fun\u00e7\u00f5es atribu\u00eddas ao usu\u00e1rio.","type":"array","items":{"type":"string"},"required":false},"password":{"description":"Senha para o usu\u00e1rio (nunca incluso).","type":"string","required":true},"meta":{"description":"Campos meta.","type":"object","properties":{"persisted_preferences":{"type":"object","title":"","description":"","default":[],"context":["edit"],"properties":{"_modified":{"description":"A data e o hor\u00e1rio que as prefer\u00eancias foram atualizadas.","type":"string","format":"date-time","readonly":false}},"additionalProperties":true}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/wp\/v2\/users"}]}},"\/wp\/v2\/users\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o usu\u00e1rio.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o usu\u00e1rio.","type":"integer","required":false},"username":{"description":"Nome de login para o usu\u00e1rio.","type":"string","required":false},"name":{"description":"Nome de exibi\u00e7\u00e3o para o usu\u00e1rio.","type":"string","required":false},"first_name":{"description":"Nome para o usu\u00e1rio.","type":"string","required":false},"last_name":{"description":"Sobrenome para o usu\u00e1rio.","type":"string","required":false},"email":{"description":"O endere\u00e7o de e-mail para o usu\u00e1rio.","type":"string","format":"email","required":false},"url":{"description":"URL do usu\u00e1rio.","type":"string","format":"uri","required":false},"description":{"description":"Descri\u00e7\u00e3o do usu\u00e1rio.","type":"string","required":false},"locale":{"description":"Localidade para o usu\u00e1rio.","type":"string","enum":["","en_US","de_DE","en_GB","es_ES","fr_FR","it_IT","pt_BR"],"required":false},"nickname":{"description":"O apelido para o usu\u00e1rio.","type":"string","required":false},"slug":{"description":"Um identificador alfanum\u00e9rico para o usu\u00e1rio.","type":"string","required":false},"roles":{"description":"Fun\u00e7\u00f5es atribu\u00eddas ao usu\u00e1rio.","type":"array","items":{"type":"string"},"required":false},"password":{"description":"Senha para o usu\u00e1rio (nunca incluso).","type":"string","required":false},"meta":{"description":"Campos meta.","type":"object","properties":{"persisted_preferences":{"type":"object","title":"","description":"","default":[],"context":["edit"],"properties":{"_modified":{"description":"A data e o hor\u00e1rio que as prefer\u00eancias foram atualizadas.","type":"string","format":"date-time","readonly":false}},"additionalProperties":true}},"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o usu\u00e1rio.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Necess\u00e1rio para ser verdadeiro, como usu\u00e1rios n\u00e3o suporta lixeira.","required":false},"reassign":{"type":"integer","description":"Reatribuir os posts e links do usu\u00e1rio exclu\u00eddo para este ID de usu\u00e1rio.","required":true}}}]},"\/wp\/v2\/users\/me":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"username":{"description":"Nome de login para o usu\u00e1rio.","type":"string","required":false},"name":{"description":"Nome de exibi\u00e7\u00e3o para o usu\u00e1rio.","type":"string","required":false},"first_name":{"description":"Nome para o usu\u00e1rio.","type":"string","required":false},"last_name":{"description":"Sobrenome para o usu\u00e1rio.","type":"string","required":false},"email":{"description":"O endere\u00e7o de e-mail para o usu\u00e1rio.","type":"string","format":"email","required":false},"url":{"description":"URL do usu\u00e1rio.","type":"string","format":"uri","required":false},"description":{"description":"Descri\u00e7\u00e3o do usu\u00e1rio.","type":"string","required":false},"locale":{"description":"Localidade para o usu\u00e1rio.","type":"string","enum":["","en_US","de_DE","en_GB","es_ES","fr_FR","it_IT","pt_BR"],"required":false},"nickname":{"description":"O apelido para o usu\u00e1rio.","type":"string","required":false},"slug":{"description":"Um identificador alfanum\u00e9rico para o usu\u00e1rio.","type":"string","required":false},"roles":{"description":"Fun\u00e7\u00f5es atribu\u00eddas ao usu\u00e1rio.","type":"array","items":{"type":"string"},"required":false},"password":{"description":"Senha para o usu\u00e1rio (nunca incluso).","type":"string","required":false},"meta":{"description":"Campos meta.","type":"object","properties":{"persisted_preferences":{"type":"object","title":"","description":"","default":[],"context":["edit"],"properties":{"_modified":{"description":"A data e o hor\u00e1rio que as prefer\u00eancias foram atualizadas.","type":"string","format":"date-time","readonly":false}},"additionalProperties":true}},"required":false}}},{"methods":["DELETE"],"args":{"force":{"type":"boolean","default":false,"description":"Necess\u00e1rio para ser verdadeiro, como usu\u00e1rios n\u00e3o suporta lixeira.","required":false},"reassign":{"type":"integer","description":"Reatribuir os posts e links do usu\u00e1rio exclu\u00eddo para este ID de usu\u00e1rio.","required":true}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/wp\/v2\/users\/me"}]}},"\/wp\/v2\/users\/(?P<user_id>(?:[\\d]+|me))\/application-passwords":{"namespace":"wp\/v2","methods":["GET","POST","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"app_id":{"description":"Um UUID fornecido pela aplica\u00e7\u00e3o para identific\u00e1-la de forma \u00fanica. Recomenda-se usar o UUID vers\u00e3o 5 com o URL ou namespace DNS.","type":"string","oneOf":[{"type":"string","format":"uuid"},{"type":"string","enum":[""]}],"required":false},"name":{"description":"O nome da senha da aplica\u00e7\u00e3o.","type":"string","minLength":1,"pattern":".*\\S.*","required":true}}},{"methods":["DELETE"],"args":[]}]},"\/wp\/v2\/users\/(?P<user_id>(?:[\\d]+|me))\/application-passwords\/introspect":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/users\/(?P<user_id>(?:[\\d]+|me))\/application-passwords\/(?P<uuid>[\\w\\-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"app_id":{"description":"Um UUID fornecido pela aplica\u00e7\u00e3o para identific\u00e1-la de forma \u00fanica. Recomenda-se usar o UUID vers\u00e3o 5 com o URL ou namespace DNS.","type":"string","oneOf":[{"type":"string","format":"uuid"},{"type":"string","enum":[""]}],"required":false},"name":{"description":"O nome da senha da aplica\u00e7\u00e3o.","type":"string","minLength":1,"pattern":".*\\S.*","required":false}}},{"methods":["DELETE"],"args":[]}]},"\/wp\/v2\/comments":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina atual da cole\u00e7\u00e3o.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de itens retornados no resultado.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar resultados para aqueles que combinam com um texto.","type":"string","required":false},"after":{"description":"Limitar resposta para coment\u00e1rios publicados depois de uma determinada data compat\u00edvel com a norma ISO8601.","type":"string","format":"date-time","required":false},"author":{"description":"Limitar resultados a coment\u00e1rios atribu\u00eddos a IDs de usu\u00e1rios espec\u00edficos. Requer autoriza\u00e7\u00e3o.","type":"array","items":{"type":"integer"},"required":false},"author_exclude":{"description":"Garantir que resultados excluir\u00e3o coment\u00e1rios atribu\u00eddos a IDs de usu\u00e1rios espec\u00edficos. Requer autoriza\u00e7\u00e3o.","type":"array","items":{"type":"integer"},"required":false},"author_email":{"default":null,"description":"Limitar resultado para e-mails de autores em especifico. Requer autoriza\u00e7\u00e3o.","format":"email","type":"string","required":false},"before":{"description":"Limitar resposta para coment\u00e1rios publicados antes de uma determinada data compat\u00edvel com a norma ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Garantir que o resultado exclua IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar resultados para IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Deslocar o resultado para um n\u00famero especifico de itens.","type":"integer","required":false},"order":{"description":"Ordenar atributos de forma ascendente ou descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar cole\u00e7\u00e3o pelo atributo do coment\u00e1rio.","type":"string","default":"date_gmt","enum":["date","date_gmt","id","include","post","parent","type"],"required":false},"parent":{"default":[],"description":"Limitar resultados para coment\u00e1rios cujos ascendentes t\u00eam determinados IDs.","type":"array","items":{"type":"integer"},"required":false},"parent_exclude":{"default":[],"description":"Garantir que o resultado exclui IDs de ascendentes espec\u00edficos.","type":"array","items":{"type":"integer"},"required":false},"post":{"default":[],"description":"Limitar resultados para coment\u00e1rios atribu\u00eddos para IDs espec\u00edficos de post.","type":"array","items":{"type":"integer"},"required":false},"status":{"default":"approve","description":"Limitar resultados para coment\u00e1rios atribu\u00eddos a um status espec\u00edfico. Necessita autoriza\u00e7\u00e3o.","type":"string","required":false},"type":{"default":"comment","description":"Limitar resultados para coment\u00e1rios atribu\u00eddos a um tipo espec\u00edfico. Necessita autoriza\u00e7\u00e3o.","type":"string","required":false},"password":{"description":"A senha para o post se este for protegido por senha.","type":"string","required":false}}},{"methods":["POST"],"args":{"author":{"description":"O ID do usu\u00e1rio do objeto, se o autor for um usu\u00e1rio.","type":"integer","required":false},"author_email":{"description":"Endere\u00e7o e-mail para o autor do coment\u00e1rio.","type":"string","format":"email","required":false},"author_ip":{"description":"Endere\u00e7o IP para o autor do coment\u00e1rio.","type":"string","format":"ip","required":false},"author_name":{"description":"Nome de exibi\u00e7\u00e3o para o autor do coment\u00e1rio.","type":"string","required":false},"author_url":{"description":"URL para o autor do coment\u00e1rio.","type":"string","format":"uri","required":false},"author_user_agent":{"description":"Agente de usu\u00e1rio para o autor do coment\u00e1rio.","type":"string","required":false},"content":{"description":"O conte\u00fado para o coment\u00e1rio.","type":"object","properties":{"raw":{"description":"Conte\u00fado do coment\u00e1rio, tal como est\u00e1 no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"Conte\u00fado HTML do coment\u00e1rio, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"date":{"description":"Data da publica\u00e7\u00e3o do coment\u00e1rio, no fuso hor\u00e1rio do site.","type":"string","format":"date-time","required":false},"date_gmt":{"description":"Data da publica\u00e7\u00e3o do coment\u00e1rio, em GMT.","type":"string","format":"date-time","required":false},"parent":{"default":0,"description":"O ID do item ascendente ao coment\u00e1rio.","type":"integer","required":false},"post":{"default":0,"description":"O ID para o post associado ao objeto.","type":"integer","required":false},"status":{"description":"Estado do coment\u00e1rio.","type":"string","required":false},"meta":{"description":"Campos meta.","type":"object","properties":{"_wp_note_status":{"type":"string","title":"","description":"Status de resolu\u00e7\u00e3o da nota","default":"","enum":["resolved","reopen"]}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/wp\/v2\/comments"}]}},"\/wp\/v2\/comments\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identificador \u00fanico para o coment\u00e1rio.","type":"integer","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"A senha do post ascendente ao coment\u00e1rio (se o post for protegido por senha).","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identificador \u00fanico para o coment\u00e1rio.","type":"integer","required":false},"author":{"description":"O ID do usu\u00e1rio do objeto, se o autor for um usu\u00e1rio.","type":"integer","required":false},"author_email":{"description":"Endere\u00e7o e-mail para o autor do coment\u00e1rio.","type":"string","format":"email","required":false},"author_ip":{"description":"Endere\u00e7o IP para o autor do coment\u00e1rio.","type":"string","format":"ip","required":false},"author_name":{"description":"Nome de exibi\u00e7\u00e3o para o autor do coment\u00e1rio.","type":"string","required":false},"author_url":{"description":"URL para o autor do coment\u00e1rio.","type":"string","format":"uri","required":false},"author_user_agent":{"description":"Agente de usu\u00e1rio para o autor do coment\u00e1rio.","type":"string","required":false},"content":{"description":"O conte\u00fado para o coment\u00e1rio.","type":"object","properties":{"raw":{"description":"Conte\u00fado do coment\u00e1rio, tal como est\u00e1 no banco de dados.","type":"string","context":["edit"]},"rendered":{"description":"Conte\u00fado HTML do coment\u00e1rio, transformado para exibi\u00e7\u00e3o.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"date":{"description":"Data da publica\u00e7\u00e3o do coment\u00e1rio, no fuso hor\u00e1rio do site.","type":"string","format":"date-time","required":false},"date_gmt":{"description":"Data da publica\u00e7\u00e3o do coment\u00e1rio, em GMT.","type":"string","format":"date-time","required":false},"parent":{"description":"O ID do item ascendente ao coment\u00e1rio.","type":"integer","required":false},"post":{"description":"O ID para o post associado ao objeto.","type":"integer","required":false},"status":{"description":"Estado do coment\u00e1rio.","type":"string","required":false},"meta":{"description":"Campos meta.","type":"object","properties":{"_wp_note_status":{"type":"string","title":"","description":"Status de resolu\u00e7\u00e3o da nota","default":"","enum":["resolved","reopen"]}},"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identificador \u00fanico para o coment\u00e1rio.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ignorar ou n\u00e3o o envio para a lixeira e for\u00e7ar a exclus\u00e3o.","required":false},"password":{"description":"A senha do post ascendente ao coment\u00e1rio (se o post for protegido por senha).","type":"string","required":false}}}]},"\/wp\/v2\/search":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed"],"default":"view","required":false},"page":{"description":"P\u00e1gina atual da cole\u00e7\u00e3o.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de itens retornados no resultado.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar resultados para aqueles que combinam com um texto.","type":"string","required":false},"type":{"default":"post","description":"Limite os resultados aos itens de um tipo de objeto.","type":"string","enum":["post","term","post-format"],"required":false},"subtype":{"default":"any","description":"Limite os resultados a itens de um ou mais subtipos de objeto.","type":"array","items":{"enum":["post","page","portfolio","category","post_tag","portfolio_entries","any"],"type":"string"},"required":false},"exclude":{"description":"Garantir que o resultado exclua IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar resultados para IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/wp\/v2\/search"}]}},"\/wp\/v2\/block-renderer\/(?P<name>[a-z0-9-]+\/[a-z0-9-]+)":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET","POST"],"args":{"name":{"description":"Nome registrado exclusivo para o bloco.","type":"string","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["edit"],"default":"view","required":false},"attributes":{"description":"Atributos para o bloco.","type":"object","default":[],"required":false},"post_id":{"description":"ID de contexto do post.","type":"integer","required":false}}}]},"\/wp\/v2\/block-types":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"namespace":{"description":"Namespace do bloco.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/wp\/v2\/block-types"}]}},"\/wp\/v2\/block-types\/(?P<namespace>[a-zA-Z0-9_-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"namespace":{"description":"Namespace do bloco.","type":"string","required":false}}}]},"\/wp\/v2\/block-types\/(?P<namespace>[a-zA-Z0-9_-]+)\/(?P<name>[a-zA-Z0-9_-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"name":{"description":"Nome do bloco.","type":"string","required":false},"namespace":{"description":"Namespace do bloco.","type":"string","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/settings":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":{"wordpress_api_key":{"title":"Chave de API do Akismet Antispam","description":"Chave de API para o conector Akismet Antispam.","type":"string","required":false},"title":{"title":"T\u00edtulo","description":"T\u00edtulo do site.","type":"string","required":false},"description":{"title":"Descri\u00e7\u00e3o","description":"Slogan do site.","type":"string","required":false},"timezone":{"title":"","description":"Uma cidade no mesmo fuso hor\u00e1rio que voc\u00ea.","type":"string","required":false},"date_format":{"title":"","description":"Um formato de data para todos os textos.","type":"string","required":false},"time_format":{"title":"","description":"Um formato de hora para todos os textos.","type":"string","required":false},"start_of_week":{"title":"","description":"N\u00famero do dia da semana em que a semana deve iniciar.","type":"integer","required":false},"language":{"title":"","description":"C\u00f3digo de localiza\u00e7\u00e3o do WordPress.","type":"string","required":false},"use_smilies":{"title":"","description":"Converter emoticons como :-) e :-P em gr\u00e1ficos ao exib\u00ed-los.","type":"boolean","required":false},"default_category":{"title":"","description":"Categoria padr\u00e3o para post.","type":"integer","required":false},"default_post_format":{"title":"","description":"Formato de post padr\u00e3o.","type":"string","required":false},"posts_per_page":{"title":"M\u00e1ximo de posts por p\u00e1gina","description":"As p\u00e1ginas do blog mostram no m\u00e1ximo.","type":"integer","required":false},"show_on_front":{"title":"Mostrar na frente","description":"O que exibir na p\u00e1gina inicial","type":"string","required":false},"page_on_front":{"title":"P\u00e1gina frontal","description":"O ID da p\u00e1gina que deve ser exibida na p\u00e1gina inicial","type":"integer","required":false},"page_for_posts":{"title":"","description":"O ID da p\u00e1gina que deve exibir os posts mais recentes","type":"integer","required":false},"default_ping_status":{"title":"","description":"Permitir avisos de links de outros blogs (pingbacks ou trackbacks) em novos artigos.","type":"string","enum":["open","closed"],"required":false},"default_comment_status":{"title":"Permitir coment\u00e1rios em novas publica\u00e7\u00f5es","description":"Permitir que pessoas enviem coment\u00e1rios em novos posts.","type":"string","enum":["open","closed"],"required":false},"site_logo":{"title":"Logo","description":"Logo do site.","type":"integer","required":false},"site_icon":{"title":"\u00cdcone","description":"\u00cdcone do site.","type":"integer","required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/wp\/v2\/settings"}]}},"\/wp\/v2\/themes":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"status":{"description":"Limitar resultados a temas com um ou mais status atribu\u00eddos.","type":"array","items":{"enum":["active","inactive"],"type":"string"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/wp\/v2\/themes"}]}},"\/wp\/v2\/themes\/(?P<stylesheet>[^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"stylesheet":{"description":"A folha de estilos do tema. Isso identifica exclusivamente o tema.","type":"string","required":false}}}]},"\/wp\/v2\/plugins":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"search":{"description":"Limitar resultados para aqueles que combinam com um texto.","type":"string","required":false},"status":{"description":"Limita os resultados a plugins com o status especificado.","type":"array","items":{"type":"string","enum":["inactive","active","network-active"]},"required":false}}},{"methods":["POST"],"args":{"slug":{"type":"string","description":"slug do diret\u00f3rio de plugins do WordPress.org","pattern":"[\\w\\-]+","required":true},"status":{"description":"O status de ativa\u00e7\u00e3o do plugin","type":"string","enum":["inactive","active","network-active"],"default":"inactive","required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/wp\/v2\/plugins"}]}},"\/wp\/v2\/plugins\/(?P<plugin>[^.\\\/]+(?:\\\/[^.\\\/]+)?)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"plugin":{"type":"string","pattern":"[^.\\\/]+(?:\\\/[^.\\\/]+)?","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"plugin":{"type":"string","pattern":"[^.\\\/]+(?:\\\/[^.\\\/]+)?","required":false},"status":{"description":"O status de ativa\u00e7\u00e3o do plugin","type":"string","enum":["inactive","active","network-active"],"required":false}}},{"methods":["DELETE"],"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"plugin":{"type":"string","pattern":"[^.\\\/]+(?:\\\/[^.\\\/]+)?","required":false}}}]},"\/wp\/v2\/sidebars":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/wp\/v2\/sidebars"}]}},"\/wp\/v2\/sidebars\/(?P<id>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"O ID de uma barra lateral registrada","type":"string","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"widgets":{"description":"Widgets aninhados.","type":"array","items":{"type":["object","string"]},"required":false}}}]},"\/wp\/v2\/widget-types":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/wp\/v2\/widget-types"}]}},"\/wp\/v2\/widget-types\/(?P<id>[a-zA-Z0-9_-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"O id do tipo de widget.","type":"string","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/widget-types\/(?P<id>[a-zA-Z0-9_-]+)\/encode":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"O id do tipo de widget.","type":"string","required":true},"instance":{"description":"Configura\u00e7\u00f5es da inst\u00e2ncia atual do widget.","type":"object","required":false},"form_data":{"description":"Configura\u00e7\u00f5es da inst\u00e2ncia serializados","type":"string","required":false}}}]},"\/wp\/v2\/widget-types\/(?P<id>[a-zA-Z0-9_-]+)\/render":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"O id do tipo de widget.","type":"string","required":true},"instance":{"description":"Configura\u00e7\u00f5es da inst\u00e2ncia atual do widget.","type":"object","required":false}}}]},"\/wp\/v2\/widgets":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"sidebar":{"description":"A barra lateral de onde se deseja retornar os widgets.","type":"string","required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o widget.","type":"string","required":false},"id_base":{"description":"O tipo do widget. Corresponde ao ID no endpoint widget-types.","type":"string","required":false},"sidebar":{"default":"wp_inactive_widgets","description":"A barra lateral a que o widget pertence.","type":"string","required":true},"instance":{"description":"Configura\u00e7\u00f5es da inst\u00e2ncia do widget, se suportado.","type":"object","properties":{"encoded":{"description":"Configura\u00e7\u00f5es da inst\u00e2ncia codificados em Base64.","type":"string","context":["edit"]},"hash":{"description":"Configura\u00e7\u00f5es da inst\u00e2ncia em hash criptografado.","type":"string","context":["edit"]},"raw":{"description":"Configura\u00e7\u00f5es n\u00e3o codificadas da inst\u00e2ncia, caso tenha suporte.","type":"object","context":["edit"]}},"required":false},"form_data":{"description":"Dados no formato URL-encoded do formul\u00e1rio de administra\u00e7\u00e3o do widget. Usado para atualizar um widget que n\u00e3o permite ser instanciado. Apenas escrita. ","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/wp\/v2\/widgets"}]}},"\/wp\/v2\/widgets\/(?P<id>[\\w\\-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para o widget.","type":"string","required":false},"id_base":{"description":"O tipo do widget. Corresponde ao ID no endpoint widget-types.","type":"string","required":false},"sidebar":{"description":"A barra lateral a que o widget pertence.","type":"string","required":false},"instance":{"description":"Configura\u00e7\u00f5es da inst\u00e2ncia do widget, se suportado.","type":"object","properties":{"encoded":{"description":"Configura\u00e7\u00f5es da inst\u00e2ncia codificados em Base64.","type":"string","context":["edit"]},"hash":{"description":"Configura\u00e7\u00f5es da inst\u00e2ncia em hash criptografado.","type":"string","context":["edit"]},"raw":{"description":"Configura\u00e7\u00f5es n\u00e3o codificadas da inst\u00e2ncia, caso tenha suporte.","type":"object","context":["edit"]}},"required":false},"form_data":{"description":"Dados no formato URL-encoded do formul\u00e1rio de administra\u00e7\u00e3o do widget. Usado para atualizar um widget que n\u00e3o permite ser instanciado. Apenas escrita. ","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"force":{"description":"Se deve-se for\u00e7ar a remo\u00e7\u00e3o do widget ou mov\u00ea-lo para a barra lateral inativa.","type":"boolean","required":false}}}]},"\/wp\/v2\/block-directory\/search":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view"],"default":"view","required":false},"page":{"description":"P\u00e1gina atual da cole\u00e7\u00e3o.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de itens retornados no resultado.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"term":{"description":"Limitar resultados a blocos correspondentes ao termo da pesquisa.","type":"string","minLength":1,"required":true}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/wp\/v2\/block-directory\/search"}]}},"\/wp\/v2\/pattern-directory\/patterns":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina atual da cole\u00e7\u00e3o.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de itens retornados no resultado.","type":"integer","default":100,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar resultados para aqueles que combinam com um texto.","type":"string","minLength":1,"required":false},"category":{"description":"Limitar resultados para aqueles que combinam com o ID de uma categoria.","type":"integer","minimum":1,"required":false},"keyword":{"description":"Limitar resultados para aqueles que combinam com um ID de palavra-chave.","type":"integer","minimum":1,"required":false},"slug":{"description":"Limitar os resultados para aqueles que combinam com um padr\u00e3o (slug).","type":"array","required":false},"offset":{"description":"Deslocar o resultado para um n\u00famero especifico de itens.","type":"integer","required":false},"order":{"description":"Ordenar atributos de forma ascendente ou descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar cole\u00e7\u00e3o pelo atributo do post.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","favorite_count"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/wp\/v2\/pattern-directory\/patterns"}]}},"\/wp\/v2\/block-patterns\/patterns":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/wp\/v2\/block-patterns\/patterns"}]}},"\/wp\/v2\/block-patterns\/categories":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/wp\/v2\/block-patterns\/categories"}]}},"\/wp-site-health\/v1":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp-site-health\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/wp-site-health\/v1"}]}},"\/wp-site-health\/v1\/tests\/background-updates":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/wp-site-health\/v1\/tests\/background-updates"}]}},"\/wp-site-health\/v1\/tests\/loopback-requests":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/wp-site-health\/v1\/tests\/loopback-requests"}]}},"\/wp-site-health\/v1\/tests\/https-status":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/wp-site-health\/v1\/tests\/https-status"}]}},"\/wp-site-health\/v1\/tests\/dotorg-communication":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/wp-site-health\/v1\/tests\/dotorg-communication"}]}},"\/wp-site-health\/v1\/tests\/authorization-header":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/wp-site-health\/v1\/tests\/authorization-header"}]}},"\/wp-site-health\/v1\/directory-sizes":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/wp-site-health\/v1\/directory-sizes"}]}},"\/wp-site-health\/v1\/tests\/page-cache":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/wp-site-health\/v1\/tests\/page-cache"}]}},"\/wp-block-editor\/v1":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp-block-editor\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/wp-block-editor\/v1"}]}},"\/wp-block-editor\/v1\/url-details":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"description":"O URL a ser processado.","type":"string","format":"uri","required":true}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/wp-block-editor\/v1\/url-details"}]}},"\/wp\/v2\/menu-locations":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/wp\/v2\/menu-locations"}]}},"\/wp\/v2\/menu-locations\/(?P<location>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"location":{"description":"Um identificador alfanum\u00e9rico para a localiza\u00e7\u00e3o do menu.","type":"string","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp-block-editor\/v1\/export":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/wp-block-editor\/v1\/export"}]}},"\/wp-block-editor\/v1\/navigation-fallback":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/wp-block-editor\/v1\/navigation-fallback"}]}},"\/wp\/v2\/font-collections":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina atual da cole\u00e7\u00e3o.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de itens retornados no resultado.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/wp\/v2\/font-collections"}]}},"\/wp\/v2\/font-collections\/(?P<slug>[\\\/\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp-abilities\/v1":{"namespace":"wp-abilities\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp-abilities\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/wp-abilities\/v1"}]}},"\/wp-abilities\/v1\/categories":{"namespace":"wp-abilities\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina atual da cole\u00e7\u00e3o.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de itens retornados no resultado.","type":"integer","default":50,"minimum":1,"maximum":100,"required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/wp-abilities\/v1\/categories"}]}},"\/wp-abilities\/v1\/categories\/(?P<slug>[a-z0-9]+(?:-[a-z0-9]+)*)":{"namespace":"wp-abilities\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"Identificador \u00fanico da categoria da habilidade.","type":"string","pattern":"^[a-z0-9]+(?:-[a-z0-9]+)*$","required":false}}}]},"\/wp-abilities\/v1\/abilities\/(?P<name>[a-zA-Z0-9\\-\\\/]+?)\/run":{"namespace":"wp-abilities\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET","POST","PUT","PATCH","DELETE"],"args":{"name":{"description":"Identificador \u00fanico para a habilidade.","type":"string","pattern":"^[a-zA-Z0-9\\-\\\/]+$","required":false},"input":{"description":"Par\u00e2metros da execu\u00e7\u00e3o da habilidade.","type":["integer","number","boolean","string","array","object","null"],"default":null,"required":false}}}]},"\/wp-abilities\/v1\/abilities":{"namespace":"wp-abilities\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina atual da cole\u00e7\u00e3o.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de itens retornados no resultado.","type":"integer","default":50,"minimum":1,"maximum":100,"required":false},"category":{"description":"Limita os resultados \u00e0s habilidades em uma categoria de habilidade espec\u00edfica.","type":"string","required":false},"namespace":{"description":"Limit results to abilities in a specific namespace.","type":"string","required":false},"meta":{"description":"Limit results to abilities matching all of the given meta fields.","type":"object","properties":{"annotations":{"description":"Limitar os resultados \u00e0s habilidades que correspondem \u00e0s anota\u00e7\u00f5es comportamentais informadas.","type":"object","properties":{"readonly":{"description":"Whether the ability does not modify its environment.","type":["boolean","null"]},"destructive":{"description":"Se a habilidade pode realizar atualiza\u00e7\u00f5es destrutivas em seu ambiente.","type":["boolean","null"]},"idempotent":{"description":"Se chamadas repetidas com os mesmos argumentos n\u00e3o t\u00eam efeito adicional.","type":["boolean","null"]}},"additionalProperties":true}},"additionalProperties":true,"required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/wp-abilities\/v1\/abilities"}]}},"\/wp-abilities\/v1\/abilities\/(?P<name>[a-zA-Z0-9\\-\\\/]+)":{"namespace":"wp-abilities\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"name":{"description":"Identificador \u00fanico para a habilidade.","type":"string","pattern":"^[a-zA-Z0-9\\-\\\/]+$","required":false}}}]},"\/wp\/v2\/icons":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina atual da cole\u00e7\u00e3o.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de itens retornados no resultado.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar resultados para aqueles que combinam com um texto.","type":"string","required":false},"collection":{"description":"Limita os resultados a \u00edcones pertencentes ao slug de cole\u00e7\u00e3o fornecido.","type":"string","pattern":"^[a-z0-9]([a-z0-9_-]*[a-z0-9])?$","required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/wp\/v2\/icons"}]}},"\/wp\/v2\/icons\/(?P<collection>[a-z0-9](?:[a-z0-9_-]*[a-z0-9])?)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"collection":{"description":"Limita os resultados a \u00edcones pertencentes ao slug de cole\u00e7\u00e3o fornecido.","type":"string","pattern":"^[a-z0-9]([a-z0-9_-]*[a-z0-9])?$","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina atual da cole\u00e7\u00e3o.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de itens retornados no resultado.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar resultados para aqueles que combinam com um texto.","type":"string","required":false}}}]},"\/wp\/v2\/icons\/(?P<name>[a-z0-9](?:[a-z0-9_-]*[a-z0-9])?\/[a-z0-9](?:[a-z0-9_-]*[a-z0-9])?)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"name":{"description":"Nome do \u00edcone.","type":"string","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/icon-collections":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina atual da cole\u00e7\u00e3o.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de itens retornados no resultado.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar resultados para aqueles que combinam com um texto.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/wp\/v2\/icon-collections"}]}},"\/wp\/v2\/icon-collections\/(?P<slug>[a-z0-9](?:[a-z0-9_-]*[a-z0-9])?)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"Slug da cole\u00e7\u00e3o de \u00edcones.","type":"string","required":false},"context":{"description":"Escopo sob qual a requisi\u00e7\u00e3o \u00e9 feita, determina os campos presentes na resposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/view-config":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"kind":{"description":"Tipo da entidade.","type":"string","required":true},"name":{"description":"Nome da entidade.","type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/wp\/v2\/view-config"}]}}},"site_logo":0,"site_icon":26498,"site_icon_url":"https:\/\/biblus.accasoftware.com\/ptb\/wp-content\/uploads\/sites\/5\/2023\/12\/favicon_biblus.webp","_links":{"help":[{"href":"https:\/\/developer.wordpress.org\/rest-api\/"}],"wp:featuredmedia":[{"embeddable":true,"type":"site_icon","href":"https:\/\/biblus.accasoftware.com\/ptb\/wp-json\/wp\/v2\/media\/26498"}],"curies":[{"name":"wp","href":"https:\/\/api.w.org\/{rel}","templated":true}]}}
