A Complete Guide to Convert IFC Files to DXF
How to obtain floor plans, cross-sections, elevation views and 2D technical drawings in CAD formats from the 3D model in IFC openBIM
Interoperability is crucial for the success of BIM projects, and for this reason, the conversion from IFC to DXF plays a key role in the correct communication of information during the design, execution, or maintenance processes of a construction.
Professionals in the architecture, engineering, and construction (AEC) sector face daily challenges related to collaboration between different software. This comprehensive guide explores the necessary steps to convert IFC files to DXF smoothly, analyzing reliable tools and the practical benefits that arise. You will discover how to improve workflows and ensure accuracy in your projects.
- What are IFC and DXF formats?
- Why convert IFC files to DXF?
- When to convert an IFC openBIM file to a 2D CAD format?
- Steps to convert IFC files to DXF
- Free online tools for converting IFC to DXF
- Advantages of converting IFC to DXF
- Who can benefit from using software for converting IFC to DXF?
- What is lost when converting IFC to DXF?
- FAQ on converting IFC to DXF to obtain 2D CAD drawings from BIM models
The Industry Foundation Classes (IFC) format is a fundamental standard for Building Information Modeling (BIM). Its main strength lies in interoperability: it allows different software to exchange information about building models without losing critical data. Thanks to IFC, architects, engineers, and builders can collaborate effectively using different platforms, ensuring that all essential details are maintained throughout the project lifecycle.
The Drawing Exchange Format (DXF), on the other hand, is one of the most widely used formats for CAD drawings. It allows data exchange between various CAD applications and is widely used for 2D and 3D technical representations. Converting to DXF is particularly useful for creating plans, sections, and elevations that need to be compatible with CAD software such as AutoCAD and other design tools.
In the field of design and construction, efficiency and collaboration among different professionals are essential. However, one often faces compatibility issues between formats used by BIM software and those of traditional CAD. This is where the conversion of IFC files to DXF comes into play, a strategic solution to optimize processes and promote interoperability. Here’s why this transformation is so important:
- need for interoperability: converting from IFC to DXF is essential to ensure compatibility between various CAD software. For example, an architect using BIM Authoring (Revit, ArchiCAD, Edificius, etc.) may need to share technical drawings with an engineer or a company still working with 2D CAD drawings (AutoCAD, ZWCAD, etc.). The DXF format represents the bridge between BIM and CAD platforms.
- improvement of workflows: this conversion allows you to:
- create plans, sections, and elevations directly from the 3D model;
- share detailed technical drawings with contractors and subcontractors;
- ensure that all parties involved have access to accurate and up-to-date graphic representations.
Discover how to open a DXF online with usBIM
Collaborate with those using CAD software
One of the main advantages of the IFC to DXF conversion is the compatibility with the most widely used CAD software in the market. Although BIM is becoming an established standard in the construction industry, many professionals continue to use traditional CAD tools for specific activities such as executive design, construction detailing, technical surveys, and updates of site documents.
An IFC file contains a complex data structure composed of:
- three-dimensional geometries;
- technical properties of objects;
- classifications;
- relationships between elements;
- performance and maintenance information.
Such information cannot always be read or managed correctly by conventional CAD software. By converting the model to DXF, the geometric component becomes immediately accessible to those using applications such as AutoCAD, DraftSight, BricsCAD, ZWCAD, or other compatible systems.
This approach promotes more effective multidisciplinary collaboration because:
- it eliminates the need to purchase dedicated BIM software;
- it reduces interoperability issues;
- it allows for quick exchange of technical documents;
- it enables external consultants to work directly on the drawings.
In complex projects, where architects, structural engineers, MEP engineers, and contracting companies collaborate, the availability of DXF files derived from the IFC model helps simplify the coordination among various disciplines.
Obtain floors, sections, and elevations from a BIM model
The IFC model contains the complete three-dimensional representation of the work and serves as a centralized source of geometric and technical information. Through conversion to DXF, it is possible to automatically extract two-dimensional views usable for project documentation.
The most common outputs include:
- architectural plans;
- vertical sections;
- horizontal sections;
- external elevations;
- construction details;
- executive tables.
From a technical perspective, the conversion software applies cutting planes and visualization criteria to the IFC model, generating vector representations that maintain the original coordinates of the elements.
Compared to manual redrawing, this process offers numerous advantages:
| Aspect | Extraction from IFC | Manual Drawing |
| Geometric Accuracy | Very High | Variable |
| Production Times | Reduced | High |
| Update Changes | Automatic | Manual |
| Consistency with the Model | Guaranteed | Not Always Guaranteed |
An additional benefit is the ability to quickly regenerate the tables whenever the BIM model is updated. This approach reduces the risk of documentation inconsistencies and improves revision control throughout the project’s lifecycle.
Share 2D documents with contractors, suppliers, and subcontractors
Not all parties involved in the realization of a project need access to the complete BIM model. In many cases, contractors, component suppliers, and subcontractors require only 2D graphics to perform their operational activities.
The IFC to DXF conversion allows the distribution of technical documentation in a universally recognized format, simplifying communication between design and construction.
Among the most frequently shared documents are:
- site layouts;
- dimensioned plans;
- carpentry tables;
- system diagrams;
- documents for prefabrication.
Using the DXF format offers several practical advantages:
- generally smaller file sizes compared to complete BIM models;
- greater speed of opening and consultation;
- compatibility with low-cost or free CAD systems;
- possible integration with CAM software and CNC machines.
In the prefabrication sector, for example, DXF files are frequently used to guide cutting, processing, and automated production processes of building components, directly transforming geometries from the BIM model into usable data in the workshop.
Measure, annotate, and modify drawings in CAD environment
Once converted to DXF, the content of the IFC model can be managed using typical CAD software tools. This allows users to perform control, customization, and integration operations without directly intervening on the original BIM model.
Among the most common activities are:
- dimensioning;
- technical annotations;
- labels and symbols;
- dimensional checks;
- local graphic modifications;
- preparation of tables for printing.
The vector nature of the DXF format allows for extremely accurate measurements. Users can measure:
- lengths;
- surfaces;
- distances;
- angles;
- coordinates.
Moreover, DXF supports the management of layers, blocks, dimension styles, and hatches, which are fundamental elements for organizing drawings according to corporate standards or project regulations.
From an operational standpoint, this flexibility is particularly useful when it is necessary to quickly produce customized documents for specific site needs or for requests from clients and suppliers. In such contexts, the ability to modify and annotate the DXF file directly represents a significant advantage over the exclusive use of the IFC model, which requires BIM software and specialized skills to be managed correctly.
Converting an IFC file to formats like DXF, DWG, or other CAD formats is not just about changing the format; it often involves the transformation of a 3D model into 2D plans or sections. This step is crucial for obtaining technical drawings useful especially in the realization of building and plant works.
The IFC format, being open, facilitates data exchange among all stakeholders in the construction process. Although design often occurs in a BIM environment, during execution it becomes essential to share with construction and plant companies 2D drawings in CAD format (such as DXF or DWG) to represent construction details clearly and accurately.
The real challenge is not simply converting a file but transforming a BIM model in IFC format into 2D plans, cross-sections, and elevations that highlight essential construction details for the realization of the artifact. Moreover, it is often necessary to generate 2D drawings to specify equipment, finishes, and furnishings to be included in the project.
Here are some situations where conversion can be particularly useful:
- production of technical drawings from BIM/IFC models:
- creating plans, sections, and elevations from 3D models without having to use advanced BIM software;
- exporting files in standard DXF formats for sharing and subsequent use;
- communication and presentation of the project:
- improving communication with clients, contractors, and other stakeholders through clear visual representations;
- direct measurements and model analysis:
- quick calculation of measurements of elements or surfaces from 2D drawings extracted directly from the 3D model.
- collaboration in OpenBIM processes:
- the possibility of automatically updating 2D technical drawings to be shared with different operators based on changes to the openBIM format BIM model.
Converting IFC files to DXF may seem complex, but with the right tools and an organized approach, it is a quick and simple process. By following a series of clear steps, it is possible to transform BIM data into 2D technical drawings ready to be shared or modified in CAD software. Here’s how to proceed:
- use tools compatible with openBIM: to start, open the IFC file using compatible software or an online tool like usBIM.blueprint. This tool is designed to read and interpret IFC data, allowing you to generate technical drawings effortlessly;
- create 2D views from the 3D model: with tools like usBIM.blueprint, you can:
- create plans, sections, and elevations by setting the cutting depth directly from the keyboard;
Plans, sections, and elevations from the 3D model
- hide unnecessary elements to generate clearer technical drawings;
- measure elements or surfaces directly from the 3D model.
Measuring elements from the 3D model
- export to DXF format:
once the desired drawings are generated:
- assign a name to your documents to organize them better;
- export the drawings in DXF format to ensure compatibility with third-party CAD software;
- save the files in the cloud for easy and immediate sharing.
DXF file export
To explore all the steps for converting an IFC file to DXF, watch the video below:
Among the best online tools for converting IFC files to DXF format, usBIM.blueprint stands out for its simplicity and power in generating 2D technical drawings such as plans, sections, and elevations directly from BIM models.
This software, fully integrated into the usBIM cloud platform, allows you to work on IFC models without having to install complex BIM software, making it an accessible solution for professionals and companies.
The intuitive interface makes it easy to select parts of the model to represent, choosing from custom views or advanced filters to enhance readability and presentation. Each technical drawing, dynamically linked to the 3D model, automatically updates with any changes, ensuring consistency and accuracy.
With the ability to measure elements and surfaces directly from the model and export results in standard CAD formats (DXF), usBIM.blueprint not only facilitates the creation of detailed drawings but also enhances collaboration thanks to support for OpenBIM processes.
This tool represents an ideal option for those who want to quickly transform a 3D model into high-quality technical documentation, without the need for advanced training or costly investments in proprietary software.
Converting IFC to DXF is not just a matter of technical compatibility, but an opportunity to improve the quality and efficiency of work. This process offers numerous advantages that facilitate communication among professionals and optimize workflows. Here’s why integrating this practice into your projects can make a difference:
- Improved interoperability: thanks to the DXF format, your technical drawings can be opened and modified in numerous CAD software, ensuring greater flexibility;
- Precision in technical details: conversion allows for detailed drawings, useful for:
- defining equipment and finishes;
- developing technical documentation for building or land registry practices.
- Greater efficiency: with tools like usBIM.blueprint, you can automate many stages of the process, reducing the time needed to create accurate technical documentation.
Using a dedicated software for converting IFC to DXF offers concrete benefits to various professionals in the construction sector. For architects, it represents a valuable tool for producing detailed technical representations without the need to master complex software. Engineers can leverage the precision offered by the software to analyze and share technical information among the different disciplines involved. Even construction companies find significant advantages, obtaining ready-to-use technical documentation without incurring high costs for advanced software. Clients and stakeholders, for their part, benefit from the ability to easily visualize projects, making the understanding of proposed solutions clearer. Finally, facility managers can rely on updated and accurate documentation to manage building maintenance more efficiently.
Converting IFC files to DXF is an essential practice for improving collaboration and ensuring interoperability in BIM projects. Thanks to tools like usBIM.blueprint, this process becomes simpler and more accessible, allowing AEC professionals to save time and resources. Implement these strategies in your workflow by accessing the usBIM.blueprint platform for free online and discover how to optimize the management of your projects!
Read the in-depth article: “openBIM standards“
The conversion of an IFC file to DXF inevitably results in a loss of information. This happens because the two formats were designed for different purposes: IFC is an open standard for sharing data-rich BIM models and relationships, while DXF is a format primarily oriented towards graphic representation and the exchange of geometries in a CAD environment.
During the conversion process, most geometric information is maintained, but numerous informative, semantic, and relational data typical of BIM are simplified or eliminated. For this reason, DXF should not be considered a substitute for the IFC model, but rather a graphic representation intended for consultation, modification, or distribution of technical documents.
Understanding which data are lost during the conversion process is essential for choosing the most suitable format for the project’s operational needs and to avoid issues related to information management throughout the lifecycle of the project.
BIM properties and metadata
One of the most penalized aspects in the conversion from IFC to DXF is the loss of the informative properties associated with BIM objects. In the IFC model, each building element is not only represented by its geometry but also contains a series of attributes and parameters that describe technical, performance, and management characteristics.
For example, a wall may contain information such as:
- unique identification code;
- construction stratigraphy;
- thermal transmittance;
- fire resistance;
- manufacturer and model;
- installation date;
- maintenance information.
This data is generally organized in Property Set (Pset) and associated with objects through standardized informational structures. During export to DXF, such properties are either not transferred or are retained only in a very limited form through attributes or layers, losing much of their original utility.
As a result, the resulting DXF file retains the graphic representation of elements but does not preserve the ability to query the model for advanced technical data. This severely limits the activities of analysis, computation, asset management, and facility management that characterize the BIM approach.
Materials, Textures, and Relationships Between Objects
Another category of information that is generally lost during conversion concerns materials, textures, and logical relationships between elements of the model. In the IFC format, each object can be associated with specific materials, multilayer stratigraphy, and complex construction systems that contribute to the technical definition of the work.
For example, a BIM wall can be composed of:
- internal plaster;
- load-bearing masonry;
- thermal insulation;
- external cladding.
This information is stored in the IFC model as structured data and used for energy analyses, performance checks, and quantitative computations. In DXF, however, such information is generally converted into simple geometric entities devoid of constructive meaning.
Relationships between objects are also significantly reduced. In the BIM model, there may be links between elements that describe, for example:
- belonging to a specific floor;
- structural connections;
- functional aggregations;
- spatial relationships between environments and components;
- dependencies between building and plant systems.
During conversion to DXF, these relationships are typically eliminated, as the CAD format is not designed to handle information structures of this kind. The result is a set of lines, polylines, hatches, and blocks that represent the building graphically but no longer describe its logical and informative organization.
Parametric Objects and BIM Semantics
The most significant loss likely concerns parametric objects and BIM semantics. In the IFC model, each element is defined as an intelligent entity belonging to a specific construction category, endowed with properties, behaviors, and operating rules.
For example, a window is not simply a geometry made up of lines and surfaces, but an object that the BIM software recognizes as a frame and that possesses features such as:
- parametric height and width;
- type of opening;
- energy performance;
- frame materials;
- manufacturer information;
- automatic association with the host wall.
When the model is converted to DXF, these intelligent objects are transformed into static geometric entities. A door, a window, a column, or a beam simply become lines, arcs, polylines, or blocks without parametric behavior.
BIM semantics is also lost, meaning the software’s ability to understand the nature of the represented elements. In the DXF file, there is no longer a distinction between a wall, a slab, or a plant element except through graphic conventions established by the user.
This loss of semantics prevents the automatic execution of many advanced functionalities typical of BIM, such as:
- automatic metric calculations;
- energy analyses;
- clash detection;
- regulatory checks;
- 4D and 5D simulations;
- building lifecycle management.
For this reason, when it is necessary to preserve the informational heritage of the project, the IFC file should always be maintained as the reference format, using DXF exclusively for graphical representation needs, CAD interoperability, and distribution of technical documents.
What are the IFC and DXF formats?
The IFC (Industry Foundation Classes) format is an open standard for Building Information Modeling (BIM) that allows the exchange of information between different software without data loss. The DXF (Drawing Exchange Format), on the other hand, is one of the most widely used CAD formats for representing and exchanging 2D and 3D technical drawings between different applications.
Why convert an IFC file to DXF?
Converting from IFC to DXF improves interoperability between BIM and CAD software, facilitating the sharing of technical documents with professionals using traditional CAD tools. It also allows for the generation of floor plans, sections, and elevations directly from the BIM model and to distribute updated and accurate technical documentation.
Is it possible to obtain floor plans, sections, and elevations from an IFC model?
Yes. Through the conversion of the IFC model, it is possible to automatically extract architectural floor plans, vertical and horizontal sections, elevations, construction details, and executive tables. This process ensures high geometric accuracy and consistency with the original BIM model.
When is it useful to convert an IFC model into a 2D CAD format?
The conversion is particularly useful during the execution phase of the project when it is necessary to share 2D technical documents with contractors, suppliers, subcontractors, and other stakeholders who primarily work in a CAD environment. It is also beneficial for making measurements, dimensional checks, and producing standard technical documentation.
What are the steps to convert an IFC file to DXF?
The process involves opening the IFC file with compatible software, generating 2D views such as floor plans, sections, and elevations, optionally filtering out unnecessary elements, and finally exporting the drawings in DXF format. The resulting files can be used and modified in any compatible CAD software.
What benefits does the conversion from IFC to DXF offer?
The conversion improves interoperability between BIM and CAD platforms, facilitates collaboration among professionals, reduces the time needed to produce technical documents, and enables the creation of accurate drawings ready to be annotated, dimensioned, and shared with all stakeholders involved in the project.
What is lost during the conversion from IFC to DXF?
During the conversion, geometric information is generally retained, while much of the informative BIM data is lost, such as object properties, metadata, materials, relationships between elements, parametric objects, and BIM semantics. For this reason, DXF should be considered a graphic representation of the IFC model and not a complete substitute for it.
