AI Render from IFC File: Visualize BIM Model Without Conversions
From IFC to photorealistic render with AI: how to create professional images from a model without materials and details, quickly and OpenBIM
In the OpenBIM flow, the IFC format represents the convergence point between different disciplines, software, and skills. However, when transitioning from the informative phase to the visual communication of the project, a critical issue often arises: the photorealistic visualization of the IFC model requires complex procedures, conversions, and re-imports that slow down the process.
Today, artificial intelligence allows to overcome this limitation. Tools like usBIM.codesign AI enable the generation of AI renders directly from IFC files, even those lacking materials and graphic details, without the need for conversion to other proprietary formats. The result is a faster workflow, consistent with OpenBIM logic and oriented towards collaboration.
From drawing to design idea with usBIM.codesign AI
- The traditional rendering of IFC models: why it is an inefficient process
- The role of AI in photorealistic visualization of IFC files
- Technical workflow: from IFC to render with AI in 3 steps
- The AI Render as a Tool for Reading and Validating the BIM Model
- Integration of AI Rendering into the OpenBIM Workflow: Speed and Collaboration
- FAQ: AI Rendering and IFC Models in the OpenBIM Workflow
In the traditional process, an IFC model is generally used as an information and coordination reference, not as a basis for realistic visualization. This is because the IFC file, by nature, primarily contains geometric and semantic data, but rarely advanced information about materials, textures, lighting, or optical properties.
When opening an IFC in a viewer or authoring software, the result is often a “gray” model, with uniform surfaces lacking finishes. The geometries appear correct, but without perceptual depth. Objects do not have realistic materials, glass is not credibly transparent, and surfaces do not reflect light as in the real world.
To achieve a traditional render, it is therefore necessary to:
- import the model into rendering software;
- manually reconstruct or assign materials;
- set up lights, HDRI environment, and physical parameters;
- handle any compatibility issues or data loss.
Each step introduces potential errors, time loss, and inconsistencies compared to the original model. Furthermore, in the event of an IFC file update, the entire process often needs to be repeated. This makes traditional rendering inefficient in the dynamic context of collaborative BIM.
Artificial intelligence introduces a paradigm shift: it is no longer necessary to transform the informational model into a “rendering” model complete with materials and physical settings. It is sufficient to start from the geometry and views of the IFC model.
Through image-to-image algorithms and prompt-driven generation, AI is capable of:
- automatically recognizing architectural elements (walls, floors, windows);
- interpreting the scene in spatial terms;
- applying consistent materials and lighting conditions;
- producing multiple design variants while maintaining the original geometric structure.
With usBIM.codesign AI, the IFC model can be visualized in the cloud and transformed into an AI render without intermediate steps. Even an IFC file lacking materials, furnishings, or graphic details becomes a sufficient basis for obtaining realistic, communicative, and professional images.
AI does not replace the BIM model, but visually enhances it, preserving its geometric and semantic coherence.
The integration between IFC and AI is a very simple operational process. Let’s analyze the three fundamental steps.
Preparation and optimization of the IFC model in the viewer
The first step involves uploading the IFC file to the usBIM cloud. In this phase, materials are not modified, but the quality of the view is.
It is important to:
- verify the correct import of geometries;
- isolate any disciplines if necessary;
- set a meaningful perspective view;
- manage sections or filters to enhance spatial readability.
The goal is not to “beautify” the model, but to obtain a clear and coherent view of the scene that you want to transform into a render. AI will indeed work on the image generated by the viewer, so framing, depth, and composition are determining elements.
Using screenshots and perspective views as input for AI
Once the view is defined, it proceeds with generating a high-resolution screenshot. This image becomes the input for the AI engine.
The principle is simple yet powerful: AI uses the geometry visible in the screenshot as a base structure. It does not alter the shapes of the elements but interprets their surfaces and the environment.
Even in the absence of materials in the IFC file, the algorithm recognizes:
- vertical surfaces as plastered or clad walls;
- transparent elements such as glass;
- horizontal planes as floors;
- external context such as sky, vegetation, or urbanization.
The result is a render consistent with the OpenBIM model but enriched with materials, natural light, shadows, and realistic atmosphere.
Virtual staging with usBIM.codesign AI – Image created from a basic 3D model
Prompting and Parameters to Maintain OpenBIM Geometric Fidelity
The quality of the AI render largely depends on the prompting. In usBIM.codesign AI, it is possible to choose the desired style, materials, lighting, and environmental context directly from a list already provided by the application. It is also possible to insert a prompt to define any other suggestions and customize the result.
To maintain geometric fidelity to the IFC model, it is advisable to:
- use descriptive but not transformative prompts;
- avoid requests that alter the morphology (e.g. “add a floor”);
- specify materials consistent with the project (e.g. “exposed concrete façade”);
- define realistic lighting conditions (e.g. “afternoon natural light”).
In this way, the AI acts as a tool for visual interpretation, not as an arbitrary shape generator. The OpenBIM structure remains the primary reference, ensuring consistency between the information model and photorealistic representation.
The AI render is not just a communicative product for the client. It also becomes a technical verification tool.
Photorealistic visualization allows for the identification of:
- proportional inconsistencies;
- errors in the modeling of architectural details;
- perceptual interferences between elements;
- issues related to natural lighting.
Often, a “gray” model does not highlight problems that emerge immediately in a realistic representation. The AI, by adding materials and light, amplifies the spatial legibility of the project.
In this sense, the AI render becomes a support for the qualitative validation of the BIM model, complementing technical and regulatory checks.
One of the main advantages of the AI approach is the total consistency with the OpenBIM workflow. No conversions to proprietary formats are required, nor duplications of the model. The IFC file remains the only informative source.
Using a cloud environment, as is the case with usBIM.codesign AI, also allows for:
- immediate sharing of generated images;
- rapid iterations on design variants;
- collaboration between designers, clients, and stakeholders;
- continuous updates in case of revisions of the IFC model.
The speed of render generation enables integrating realistic visualization already in the preliminary phases, overcoming the traditional separation between technical design and visual communication.
In conclusion, the transition from IFC to render with AI represents not only a technological innovation but also a methodological evolution. It means making the BIM model immediately readable, shareable, and verifiable, without leaving the OpenBIM perimeter and without burdening the process with conversions and rework.
Artificial intelligence, integrated into tools like usBIM.codesign AI, transforms the information model into a visual experience while keeping its technical coherence intact.
Why is traditional rendering of IFC models complex?
Traditional rendering requires importing the IFC model into rendering software, manually assigning materials, lights, and physical parameters. This process is lengthy, prone to errors, and often produces unrealistic results, causing time loss and inconsistencies with the original model.
How does artificial intelligence improve the visualization of IFC models?
AI generates photorealistic renders directly from the geometry of the IFC model, automatically recognizing architectural elements and applying consistent materials and lighting. This way, it is possible to obtain realistic representations without complex steps and without altering the original geometric structure.
What are the main steps to create an AI render from an IFC file?
The main workflow involves: 1) preparing and optimizing the IFC model in the viewer, 2) generating high-resolution screenshots of the perspective views to be used as input for the AI, 3) setting prompts and parameters to maintain geometric fidelity and choosing style, materials, and lighting.
How does the AI render support the verification of the BIM model?
Photorealistic visualization allows for identifying proportional errors, incorrect architectural details, interferences between elements, and issues related to lighting, improving spatial legibility and supporting the qualitative and technical validation of the BIM model.
What advantages does the integration of AI rendering offer in the OpenBIM workflow?
The integration of AI ensures total consistency with the information model, speed in render generation, simplified collaboration between designers and stakeholders, immediate updates in case of changes to the IFC model, and the ability to iterate quickly on design variants.
How does AI enhance the visual communication of BIM projects?
In addition to technical support, the AI render allows for obtaining photorealistic images for presentations and communication with clients or stakeholders. This makes the BIM model more readable, shareable, and immediately understandable, reducing the gap between technical design and visual presentation.
