Developing BIM Models of Historical Buildings
How to create 3D models of historic buildings and develop restoration projects with BIM: degradation assessment and crack mapping
Do you need to develop a 3D BIM model of a historic building? Are you working on the restoration or rehabilitation of an existing structure?
In this article, I explain how to use HBIM software to develop a complete restoration project for a historic building, from 3D modelling and degradation analysis to the definition of intervention strategies and integration with structural and MEP systems models.
I will also present a practical case study that you can use as a reference for your own projects.
Image of the 3D model
- What is HBIM
- The potentials of BIM for existing buildings
- How to develop the BIM model of historic buildings: HBIM project workflow
- A practical case with Edificius: from the point cloud to the BIM model of historic buildings
- How to model a historical building in HBIM, the degradation state, and recovery interventions
- FAQ
What is HBIM
By now we know that BIM (Building Information Modeling) originates as an operational methodology to manage the processes of:
- planning,
- design,
- construction,
- management,
- maintenance,
- demolition
of any construction through an informational model that contains all the information regarding its entire life cycle.
This approach is also applied in the field of historic buildings, taking the form of Heritage or Historical Building Information Modeling, abbreviated as HBIM.
Thanks to the development of HBIM, it is possible to create detailed models of historic buildings with intelligent parametric objects, that is, containing information about the building, its components, and all its characteristics, which can be updated, replaced, and implemented over time. In addition to geometric modeling, HBIM allows for detailed and comprehensive analyses of the current state: material survey, identification of degradation phenomena, cracking assessment, etc.
Developing a historic building BIM model: orthophoto with a surface cracks map
It is important to emphasize that HBIM is a process applied to existing buildings, whether they are monumental and of historical-artistic significance or common houses from the last century, thus greatly broadening the scope of the BIM method, as it extends its use to the creation of models of existing buildings.
So far, HBIM has not had widespread adoption in the professional field due to the lack of shared regulations and standardized workflows and, above all, to the difficulties related to modeling phases and information retrieval. In fact, modeling a historical building means taking into account elements that are not always standardizable and that cannot be referred to predefined libraries, deformations and irregularities, uncertainties about construction techniques, the presence of degradation phenomena, alterations due to the passage of time, and more.
Currently, many software programs are adapting to these needs to comprehensively manage the entire process of digitizing the existing building heritage.
Edificius, for example, has a specific environment for HBIM, with a dedicated library of objects typical of historical buildings and an editor that flexibly adapts to the specifics of each individual case:
Vault Editor– to model various types of vaults using new specific objects (barrel, ribbed barrel, lazy barrel, pavilion, polygonal base pavilion, cross vault, polygonal base cross vault, dome, lunettes/openings, horizontal section, and vertical section);Rib– to manually or automatically insert the rib in the intrados or extrados of the vault using the magic wand;Floor with wooden beams– to create and customize a wooden floor, setting the thickness of the floor, the section, the spacing, and the rotation of the beams;Degradation Area– the editor for defining the degraded surface to associate with a specific material;Fracture– the specific editor for identifying and highlighting the fractures present on a specific element of the building;Orthophoto– to associate an orthophoto with an element of the building and obtain a faithful representation of the actual state and complete material information.
Edificius HBIM – parametric objects
In this way, it is easy to overcome the difficulties related to modeling (even in the presence of strong irregularities, elaborate decorations, obsolete construction systems) and fully exploit all the advantages of HBIM:
- processing of the 3D geometric model in quick time;
- processing and management of the data model;
- use of intelligent parametric objects;
- management of documents and data;
- greater control of the project and of the investigation and analysis campaigns;
- sharing of information and the model;
- programming of maintenance interventions;
- promotion of the asset;
- creation of databases that can be updated over time;
- application of advanced technologies such as virtual or augmented reality.
Generating the 3D BIM model of a historic building allows for all the benefits of BIM in the restoration project.
Let’s see how to develop the 3D model and the restoration project of a historic building using HBIM methodology.
In summary, the main phases to follow are:
- structuring of the CDE (common data environment);
- data collection, processed materials, and historical documentation;
- management and sharing of the collected documentation on collaborative platforms;
- photographic survey and photo rectification;
- geometric survey conducted with the support of various technologies (from the more traditional ones like tapes, levels, and squares; to more advanced ones such as laser scanners, total stations, photogrammetric surveys, etc.);
- material survey;
- 3D modeling of the existing state with BIM Authoring;
- sharing the model on collaborative platforms;
- study of the functional layout of the existing state;
- analysis of degradation directly in the HBIM environment;
- stratigraphic analysis and on the construction phases of the work in the HBIM environment;
- study of the cracking framework and the ongoing kinematics;
- projecting surveys and tests to be carried out;
- identification of project interventions;
- integration with BIM software for structural and plant design;
- 3D modeling of the project;
- project verification in Real Time or virtual reality (VRi);
- automatic cost estimating from the 3D model;
- graphical processing and working drawings.
To delve deeper, I will show you a practical case developed with Edificius.
The practical example I will show you is a digitization project of a residential building from the early ‘900s.
The first operation performed on-site is the survey and acquisition of geometric data conducted through the 3D laser scanner. The result is the point cloud, which contains geometric information (their coordinates in a known reference system) and colorimetric information, as each point is associated with a relative color derived from a photo taken by the instrument during the scan.
To learn more, read also “Scan to BIM, from laser scanning to the BIM model.”
The survey data were imported into Edificius to develop the BIM model and generate the building’s geometric representation within the digital environment.
Before starting the modeling, Levels (mezzanine level, first floor, up to the roof) and subLevels with relative heights were set, and the ground with contour lines was imported directly from Google Maps using the specific functionality.
Edificius levels management
The building modeling was facilitated by the parametric objects of the HBIM environment of Edificius, which allows for the reproduction of the characteristic elements of historical architecture (vaults, wooden floors, ribs, etc.).
The external walls, windows, staircase, and all architectural details present on the façade (moldings, capitals, pilasters, etc.) were modeled.
In a BIM process, all the material useful for the project is shared and managed through the use of collaborative platforms and CDE. This way, the building data can be consulted by the entire project team and all activities are traceable to make collaboration effective and secure.
At the end of the BIM modeling, the building model was exported in the open IFC format to allow optimal integration with all professionals involved in the project. The IFC model can indeed be imported and managed by all common BIM authoring software. In this way, the structural engineer can import the BIM model and proceed with structural modeling, calculations, and checks.
In the case examined, the structural workflow included shortly:
- automatic recognition of architectural objects as structural entities in the structural calculation software;
- structural modeling;
- FEM model;
- assignment of constraints;
- definition of loads;
- structural analysis.
In parallel with the structural analysis, the material characterization and assessment of the conservation status of the decorative apparatus of the façades were developed. All of this was facilitated by importing the textured mesh obtained from the survey and leveraging the full potential of the ortofoto command, which allows for overlaying the rectified photos of the façades to be analyzed onto the 3D model. The areas affected by different degradation phenomena were identified on the orthophoto. Edificius automatically generates the legend that helps interpret the patterns associated with the various manifestations of deterioration.
Damage area analysis with Edificius
Unlike traditional workflows, HBIM technology enables the creation and continuous updating of a structured information database on the conservation status of historic buildings, along with their BIM models, resulting in a shared and evolving digital archive. By managing the project through a collaborative platform, it is possible to achieve the following benefits:
- easier consultation, sharing, and long-term management of the model
- direct exchange of information within the 3D model environment
- visualization and management of 3D files created with different software;
- creation of degradation maps useful for identifying pathologies and diagnostic analyses;
- definition of standardized intervention protocols for each restoration activity, integrated within the usBIM platform.
The case study focuses on the application of the HBIM (Heritage Building Information Modeling) methodology to the monumental complex of the Church of Madonna della Neve, part of a historic settlement dating back to the Lombard period, located in Montella (AV).
The aim is to demonstrate how digital technologies and collaborative workflows can support the documentation, conservation, and management of architectural heritage. This intervention is based on the understanding that the restoration and rehabilitation of historic buildings today require a truly multidisciplinary approach, in which restoration architects, structural engineers, survey specialists, diagnostic experts, historians, and archaeologists work in close coordination through a continuous and structured exchange of information.
HBIM management in the cloud
In this context, the HBIM methodology represents the evolution of BIM applied to existing and historical artifacts, configuring itself not only as a three-dimensional modeling tool but, above all, as an information system capable of collecting, organizing, and updating over time geometric, constructive, historical, material, and conservation data. Unlike traditional BIM, which starts from a project to arrive at the construction of the digital twin of the work, HBIM operates in the opposite manner: the process begins with the real artifact and, through surveys, investigations, and archival research, leads to the construction of a digital model “as-is,” that is, adhering to the actual and historicized state of the building, including the transformations it has undergone over time.
In the specific case of the Church of Madonna della Neve, the project was developed starting from a complex knowledge phase based on traditional geometric surveys, acquisitions via laser scanning, and photogrammetric techniques, integrated with archival documentation and analysis of the state of conservation. The operational methodology was divided into three main phases: acquisition, segmentation, and modeling. The acquisition phase involved the collection of a large amount of data from various disciplines, including metric surveys, structural analyses, deterioration surveys, and historical documentation. Subsequently, in the segmentation phase, the information was organized and semantically categorized to allow its use within the digital model. This process allowed associating not only geometric characteristics but also descriptive, diagnostic, and documentary information to the architectural elements. The final modeling phase was developed through the software Edificius, which allowed the direct import of point clouds generated from laser scanning surveys and their transformation into HBIM parametric elements.
The use of the software made it possible to faithfully reconstruct the geometry of the church through advanced snapping and sectioning tools of the point cloud. Complex architectural elements such as walls, openings, niches, historical fixtures, barrel vaults, sail vaults, ribs, domes, and longitudinal beams were modeled, with the ability to customize geometric and constructive parameters to achieve a representation consistent with the real artifact.
Loading and viewing of the HBIM model in usBIM
Particular relevance has been given to the modeling of historic vaults, achieved through dedicated parametric editors that have allowed for the definition of articulated geometries and irregular shapes typical of historic architecture. Alongside geometric modeling, the project integrated tools for conservation surveying, enabling the mapping of degradation and the cracking framework directly on the digital model. By using orthophotos obtained through photogrammetry and applied to architectural surfaces, it has been possible to trace degradation phenomena, injuries, and material alterations according to UNI-Normal classifications, distinguishing different types of deterioration related to stone, wood, and metal materials. Each degradation or injury has been defined as an informative parametric object, associated with data related to extent, severity, hypothesized causes, photographic documentation, and maintenance status.
An additional significant aspect of the case study concerns the use of the integrated collaborative platform, used as a common data-sharing environment among the various parties involved in the project. Through the platform, it was possible to archive three-dimensional models, historical photographs, archival documents, survey sheets, and results of archaeological investigations, making all the information accessible and navigable in an interactive manner. In particular, the system allowed for the direct linking of archaeological excavation campaigns conducted by Professor Rotili between the 1990s and the 2000s to the digital model, associating scientific documentation, publications, and historical references with the excavation areas.
The HBIM model has thus been transformed into a dynamic and queryable digital archive, capable of integrating historical knowledge, geometric surveying, diagnostic analysis, and conservation management in a single interoperable environment. Therefore, the case study demonstrates how HBIM can be an advanced tool for the documentation, monitoring, and enhancement of historical heritage, promoting not only a more efficient management of information and the restoration process but also new forms of cultural enjoyment, such as virtual tours and interactive consultation of digital contents.
FAQ
What is HBIM?
BIM (Building Information Modeling) originates as an operational methodology for managing the processes of programming, design, realization, management, maintenance, and demolition of a construction through an informational model that contains all the information related to its entire life cycle. This approach is also applied to historic buildings, taking the form of Heritage or Historical Building Information Modeling, briefly HBIM.
To which buildings does HBIM apply?
HBIM is a process applied to existing buildings, whether they are monumental and of historical-artistic significance or common dwellings from the last century. This approach greatly extends the scope of the BIM method, expanding its use to the creation of models of existing buildings.
What are the difficulties in BIM modeling of historic buildings?
Modeling a historic building means taking into account elements that are not always standardizable and cannot be traced back to predefined libraries, deformations and irregularities, uncertainties about construction techniques, the presence of degradation phenomena, and alterations due to the passage of time.
What are the advantages of HBIM for historic buildings?
The main advantages of HBIM are: rapid processing of the 3D geometric model, management of the data model, use of intelligent parametric objects, document management, greater control of the project and survey campaigns, sharing of information and the model, maintenance scheduling, and the creation of updatable databases over time.
What are the phases of the HBIM workflow?
The main phases of the HBIM workflow include: structuring the ACDat, document collection, photographic and geometric surveying, 3D modeling of the current state, degradation analysis, study of the cracking framework, identification of project interventions, integration with structural and plant software, and production of executive drawings.
How is the surveying of a historic building carried out for an HBIM project?
The surveying can be done using a 3D laser scanner, obtaining a point cloud containing geometric and colorimetric information useful for the accurate reconstruction of the BIM model of the historic building.
How is the BIM model of a historic building developed with Edificius?
The survey data is imported into Edificius for BIM modeling. After setting up the levels and the ground, modeling is facilitated by HBIM parametric objects that allow for the reproduction of typical elements of historic architecture, such as vaults, wooden floors, moldings, and decorations.
Why is the IFC format important in the HBIM workflow?
The open IFC format allows for the integration of the BIM model with other BIM authoring software, facilitating interdisciplinary work among architects, structural engineers, and plant engineers involved in the project.
How is the degradation analysis conducted with Edificius?
Degradation analysis is performed using textured meshes and orthophotos overlayed on the 3D model. Degraded areas are identified directly on the orthophotos, and the software automatically generates the legend associated with degradation phenomena.
What advantages does HBIM offer compared to traditional methods?
HBIM allows for the creation and ongoing update of a shared database regarding the conservation status of historic buildings, improving information management, collaboration among professionals, and planning of restoration interventions.
