Edit Objects in Renders with AI: Methods and Applications
Discover how to edit objects in renders with AI and the techniques for adding and removing for professional editing
Until recently, even the smallest change to a rendered image—such as replacing a piece of furniture or removing a minor detail—meant going back to the 3D model and running long, resource-intensive rendering sessions once again.
Today, the emergence of Generative Artificial Intelligence has radically transformed this workflow. New AI-powered tools are now able to manipulate pixels with a semantic understanding of space, allowing designers to interact with rendered scenes intelligently rather than simply retouching images. Objects can be added, removed, or modified while automatically preserving lighting, shadows, materials, and perspective—often in a matter of seconds.
In this article, we explore how AI is redefining architectural image editing. We examine techniques for adding, removing, and replacing elements with precision, how to maintain visual consistency across scenes, and how these innovations can be integrated into professional workflows to significantly reduce time and costs without compromising aesthetic quality.
- Editing objects in a render with AI: methods and applications
- The Role of AI in Editing Architectural Renders
- Removing Objects from a Render with AI
- Adding Objects in a Render with AI
- Visual Consistency as a Requirement for Editing with AI
- Edit Objects in Renders with AI in the Visualization Workflow
- Limits and Challenges of AI Object Editing
- FAQ on Editing Objects in Renders with AI
The architectural visualization sector is experiencing an unprecedented revolution. Until recently, modifying a single element within a photorealistic image required hours of work, having to return to the modeling software, change the asset, reset the lights, and launch a new rendering. Today, thanks to the integration of Generative Artificial Intelligence, this workflow has become immediate, fluid, and incredibly precise.
Why intervene on the objects of a render without regenerating it
In the traditional workflow of an architect or interior designer, rendering is often considered the endpoint, a “costly” process in terms of computation time and hardware resources. However, the review phase with the client inevitably involves requests for small but significant changes: changing the color of a sofa, replacing a wood essence, or inserting a different piece of furniture.
Intervening directly on the objects via AI, without regenerating the entire scene, offers fundamental strategic advantages:
- reduction of post-production times – there is no longer a need to wait for the rendering engine’s computation times. The modification occurs in seconds through various techniques;
- preservation of visual consistency – regenerating a render from scratch can sometimes lead to unintended micro-variations in global lighting or digital noise. AI allows isolating the intervention only to the area of interest, keeping the rest of the work intact;
- real-time creative flexibility – during a meeting with the client, it is possible to test different variants of furniture or finishes instantly, transforming the render from a static image to a dynamic decision-making tool;
- hardware efficiency – processing a targeted modification through artificial intelligence algorithms requires less computing power than a full rendering session, allowing operation even on not overly powerful workstations.
This evolution does not replace the designer’s talent but frees them from repetitive tasks, allowing them to focus on design and client relationships, thanks especially to AI software dedicated to architecture.
The introduction of artificial intelligence in the field of architectural visualization has marked the transition from manual (pixel-based) editing to semantic editing. While traditional photo editing software requires manual adjustments to lights and shadows to integrate a new object, AI “understands” the depth, materials, and light sources present in the original image.
From Image Processing to Spatial Understanding
The role of AI is not limited to the simple overlay of elements. Thanks to models trained on billions of architectural images, artificial intelligence is capable of performing complex tasks:
- material recognition – AI identifies whether a surface is reflective (like glass) or opaque (like concrete), adapting the refraction of the newly inserted object coherently;
- ambient light management – if we insert a lamp in a night render, AI does not just draw the object, but simulates how the light should hit the surrounding surfaces;
- perspective consistency – one of the crucial roles is maintaining the vanishing points. AI interprets the perspective of the existing render and deforms the new object so that it fits perfectly into the three-dimensional space, eliminating the “collage” effect.
Inpainting and Outpainting Techniques
In render editing, AI primarily operates through two methodologies:
- inpainting – allows selecting a specific area of the render (for example, an old table) and asking AI to replace it with a modern model. The algorithm reconstructs the missing pixels of the background “behind” the new object, ensuring visual cleanliness;
- outpainting – useful when wanting to extend the framing of an already existing render, adding portions of the environment that were not originally calculated, while maintaining the same architectural style.
The integration of these technologies into BIM (Building Information Modeling) processes allows for a direct link between the design idea and its visual representation, drastically reducing the gap between draft and photorealistic reality.
While adding new elements enriches the project, strategic removal is what makes it flawless. Artificial intelligence has transformed this operation into an instant and intelligent process.
When is it Necessary to Remove Objects from an Image
In the AEC sector, the reasons for eliminating elements from an already produced render are multiple and often related to the strategic communication of the project:
- visual decluttering – often, during the review phase, it becomes apparent that too many furnishings or too much vegetation distract the eye from the main focus: the architecture;
- modeling errors or clipping – an object intersecting a wall or an asset “floating” a few millimeters off the ground can be modified with AI faster than reopening the source file;
- adapting to different markets – a render intended for a European client might require the removal of decorative elements more suited to an Asian or American market, allowing for a rapid “localization” of the project;
- privacy and urban context – in photo insertions, it may be necessary to remove car license plates, degraded road signs, or disturbing elements present in the real context captured for the background.
Principles of AI Removal Functionality
Unlike traditional deletion, removal via AI does not simply eliminate pixels but performs a contextual reconstruction operation.
The process is based on generative infilling algorithms that follow these logical steps:
- contour analysis – AI studies the pixels adjacent to the selected area to identify textures, patterns, and vanishing points;
- depth estimation – the system understands what is “behind” the object to be removed. If we eliminate a chair placed in front of a wall with wainscoting, AI reconstructs the wood pattern and the shadows projected on the wall itself;
- texture synthesis – through neural networks, the software generates new pixels that blend chromatically and stylistically with the rest of the image, eliminating those unsightly halos typical of manual photo editing;
- lighting consistency – the algorithm recalculates how ambient light should hit the newly freed area, ensuring that no “ghost shadows” of the removed object remain.
Inserting new elements into a static image represents one of the most challenging tasks for AI applied to architecture. It is not just about “sticking” an object, but making it coexist with the physical laws of the pre-existing scene.
Inserting New Objects into the Existing Context
Adding an element (like a plant, a new light fixture, or a human figure) requires AI to analyze three critical factors to ensure realism:
- interaction with shadows (Ambient Occlusion) – AI automatically generates the “contact shadows” where the object rests on the floor or touches a wall. Without these micro-shadows, the object would appear to float;
- reflections and specularity – if we add a metal vase on a marble table already rendered, artificial intelligence can simulate the reflection of the vase on the surface of the table and, conversely, project the colors of the environment onto the vase itself;
- depth of field (Bokeh) – if the original render has selective focus (background blur), AI will apply the same degree of blur to the new object based on its virtual position in the depth of the scene.
Visual Verification and Comparison of Alternatives
One of the most underrated advantages of AI in rendering is the ability to perform instant A/B testing. Instead of deciding in advance which chair model or type of upholstery to use, the designer can generate different variants in a matter of seconds.
This approach transforms the render into an interactive workspace:
- dimensional validation – visually check if the footprint of a new piece of furniture saturates the space too much;
- study of color contrast – test how different colors of an object interact with the overall color palette of the room;
- client engagement – showing the client multiple “finished” options allows for closing the decision-making cycle much faster, reducing the risk of second thoughts during construction.
When modifying an existing render, the main risk is breaking the visual balance. An added or modified object that does not respect the physical properties of light or the grain of the original image will immediately appear “alien” to the human eye. Advanced AI solves this problem through strict control of three fundamental parameters.
Light Balancing and Color Temperature
Every render has its own “light soul,” defined by the color temperature (expressed in Kelvin) and the direction of the main light sources. The AI analyzes the whites and shadows of the scene to ensure that the new object is illuminated exactly like the rest of the environment. If the original render has a warm sunset light, the modified object will never show cold reflections from daylight, maintaining perfect color harmony.
Grain and Digital Noise Matching
Renders are never perfectly “smooth”; they always have a subtle grain due to the sampling process of the rendering engine. One of the most common mistakes in manual editing is inserting an object that is too sharp into a slightly grainy scene. Modern artificial intelligence performs noise matching: it analyzes the frequency of the digital noise of the base render and applies it uniformly to the modified or added object, making the edges indistinguishable from the context.
Material Integration and Global Reflections
Visual consistency also involves managing materials. If we change the color of an armchair placed near a window, the AI must be able to:
- maintain the texture of the original fabric;
- preserve the specular reflections of the light coming in from the window;
- simulate how the new color “bounces” off nearby surfaces, like a light floor that might take on a slight hue from the new furniture.
Achieving this level of realism without dedicated tools would require hours of manual calibration. With an AI architecture generator, however, this process is automated: the algorithm takes care of preserving visual consistency while you focus on the aesthetic and functional choices of the project. It is the ultimate tool for those seeking perfection in detail without compromising productivity.
The integration of artificial intelligence does not erase the traditional workflow but enhances it at its most critical points. Incorporating the ability to edit objects with AI into the architectural visualization process means transitioning from a linear model (Modeling -> Rendering -> Post-production) to an iterative and dynamic model.
Optimization of Review Phases
The typical AI-enhanced workflow consists of three key moments:
- base rendering – a high-quality image is produced that defines volumes, spaces, and main lights;
- spot review (AI Editing) – instead of reopening the CAD/BIM file for every minor change requested by the client, you intervene directly on the render. This phase allows testing dozens of variants of furniture, materials, or decorations in a fraction of the usual time;
- finalization – once the “flying” changes made with AI are approved, the designer can decide whether to consolidate them into the final BIM model or directly deliver the edited image, given the extremely high quality achieved.
Reduction of “Time-to-Market”
For an architecture firm, time is the most valuable resource. Using AI to edit objects drastically reduces the so-called “bottleneck” of rendering. This approach allows you to:
- manage multiple projects simultaneously, delegating micro-editing tasks to the AI;
- improve communication with the client, who can see their ideas come to life almost instantly during the presentation meeting;
- lower operational costs, reducing hardware wear and energy consumption related to the long calculation times of traditional rendering engines.
Despite the incredible evolution of diffusion models, editing renders with artificial intelligence still presents technical challenges. Understanding these limits is essential for the designer who wants to maintain total control over the quality of their output.
Visual Hallucinations and Geometric Distortions
The most well-known limit of generative AI is the so-called “hallucination.” In some cases, the algorithm may generate objects that, while aesthetically coherent, have structural errors:
- impossible geometries – a chair with three legs or a table that partially merges with the floor;
- material inconsistencies – a fabric that suddenly takes on the texture of metal in particularly dense shadow areas;
- loss of technical details – the AI may overly simplify complex elements like handles, hinges, or switches, making them less defined compared to the rest of the 3D calculated render.
Brand Management and Specific Model Handling
AI excels at creating “generic” objects (e.g., “a blue velvet sofa”). However, if the project requires the insertion of a specific model from a design brand (with precise proportions and stitching), pure AI editing may not be sufficiently faithful. In this case, the AI’s intervention must be guided by very precise image references or sketches to avoid the furniture appearing similar but not identical to what is specified in the specifications.
The Resolution Factor and “Blur”
When intervening on high-resolution renders (4K or higher), some Inpainting techniques may generate areas that are slightly less sharp than the original file. This happens because AI models often work at fixed resolutions and must scale the output. This is where the skill of the professional and the quality of the software used come into play: advanced tools perform contextual upscaling to match the pixel density of the modified area with that of the rest of the image.
Why intervene on objects in a render without regenerating it?
Intervening directly on objects via AI offers fundamental strategic advantages: reducing post-production times, preserving visual consistency, real-time creative flexibility, and hardware efficiency, allowing operation even on not overly powerful workstations.
What is the role of AI in architectural render editing?
The introduction of artificial intelligence has marked the transition from manual (pixel-based) editing to semantic editing. AI ‘understands’ the depth, materials, and light sources present in the original image, ensuring material recognition, ambient light management, and perspective consistency.
What do Inpainting and Outpainting techniques consist of?
Inpainting allows you to select a specific area of the render and ask the AI to replace it with a new model, reconstructing the missing background pixels. Outpainting is useful when you want to extend the framing of an existing render, adding portions of the environment while maintaining the same architectural style.
When is it necessary to remove objects from an image?
The reasons are multiple: visual decluttering to avoid distracting from the main focus, correcting modeling errors or clipping, adapting to different markets (project localization), and the need for privacy or cleanliness in the urban context in photo insertions.
What are the principles of AI removal operation?
The process is based on generative infilling algorithms that follow four steps: contour analysis, depth estimation (what is ‘behind’ the object), texture synthesis through neural networks, and recalculating lighting consistency to ensure that no ‘ghost shadows’ remain.
What factors are critical for inserting new objects into the existing context?
To ensure realism, the AI analyzes three factors: interaction with shadows (Ambient Occlusion) to prevent the object from floating, reflections and specularity on surrounding surfaces, and depth of field (Bokeh) to apply the same degree of blur as the original render.
How is visual consistency ensured as a requirement of AI editing?
AI mitigates the risk of imbalance through strict control of three parameters: light balancing and color temperature, grain and digital noise matching, and material integration with global reflections.
What are the limits and challenges of AI object editing?
Challenges include visual hallucinations (impossible geometries or distortions), difficulty in brand management for specific design models, and possible discrepancies in resolution (blur effect) when intervening on high-resolution renders.
