Lighting Design Guide: Architectural Lighting Ideas and Solutions
The potential of lighting in interior design: how to make quick simulations to manage project results with AI
Lighting design emerges as a critical and transformative element in contemporary interior architecture. Beyond its fundamental role of ensuring optimal visibility, strategic illumination serves as a sophisticated design tool that simultaneously enhances safety, shapes spatial perception, influences psychological well-being, and accentuates architectural elements and material textures. A meticulously crafted lighting strategy can fundamentally redefine the experiential quality of a space, harmoniously integrating functional requirements with aesthetic sophistication and sensory comfort.
Modern technological advancements now enable designers to rapidly prototype and visualize lighting scenarios through cutting-edge artificial intelligence tools. These innovative AI architecture generators can transform even rudimentary hand-drawn sketches into photorealistic renderings, providing designers with unprecedented capabilities to explore and refine natural and artificial lighting conditions with remarkable precision and creative flexibility.
The three basic types of lighting in interior design
For effective design, it is essential to structure lighting considering 3 aspects.
Ambient lighting: the foundation of light in spaces
This is the general lighting, evenly distributed to ensure basic visibility. It can be achieved through ceiling fixtures, pendant lamps, or recessed spotlights, and is often complemented by reflective surfaces or light finishes to amplify light diffusion.
Functional lighting: light for specific activities
This focuses on areas where particular activities take place, such as reading, cooking, or working. It uses directed sources (e.g., table lamps, adjustable spotlights, LED strips under cabinets) and must provide more intense and localized lighting.
Accent lighting: highlighting elements and details
This serves to emphasize objects, textures, architectural details, or artworks. It uses concentrated sources and can help create suggestive lighting scenes, adding depth, prestige, and character to spaces.
The combination of these types contributes to the successful outcome of the interior design project.
How to calculate the necessary amount of light: lumens and lux
An effective lighting project starts with the correct definition of the amount of light. Lumens indicate the total amount of light emitted by a source, while lux represent the luminous intensity on a given surface (1 lux = 1 lumen/m²).
Each environment requires a minimum level of illumination: for example, 300–500 lux for offices and kitchens, 100–200 lux for living rooms, up to 700 lux for precision operational areas. Lighting calculation software allows for simulations and accurate calculations to ensure optimal results.
The reference regulation that establishes illumination values (in lux) for different environments is UNI EN 12464-1:2021 “Light and lighting – Lighting of work places – Part 1: Indoor work places.”
This standard is not mandatory but represents a voluntary technical standard recognized at the European level.
The standard defines, for each type of activity and indoor environment:
- the minimum average illumination level (Em) in lux;
- the uniformity of lighting (U0);
- the maximum glare value (UGR);
- the minimum color rendering index (CRI or Ra);
- the direction and distribution of light in some cases.
Here are some examples of typical values according to the standard, related to different functional areas:
- offices (desks, PCs) 500 lux;
- corridors 100–200 lux;
- kitchens (domestic use) 300–500 lux;
- classrooms 300–500 lux;
- meeting rooms 300 lux;
- relaxation or waiting areas 200 lux;
- stairs and landings 100 lux;
- technical laboratories 750–1000 lux.
For private residential environments, there are no mandatory values defined by law, but UNI EN 12464-1 can be used as a technical reference.
Color temperature and color rendering: choosing the right light for each environment
Color temperature, expressed in Kelvin (K), influences the perceived tone of light:
- warm light (values below 2700–3000 K) for cozy environments like living rooms and bedrooms;
- neutral light (values between 3500–4000 K) for kitchens and bathrooms;
- cool light (values above 5000–6500 K) for operational spaces or studies.
LED light temperature
The color rendering (CRI, Color Rendering Index) measures the ability of light to faithfully reproduce colors. A CRI above 80 is generally adequate for residential environments, while for museums or professional settings, values above 90 are preferred.
Practical rules for lighting arrangements in different environments
Each home environment has specific lighting needs. Here are some practical guidelines:
Living room: cozy atmospheres
Prefer a mix of diffuse ambient light and localized light points (floor or reading lamps), possibly dimmable to adjust the intensity based on the time of day and the activities to be performed.
Kitchen: functional and safe lighting
Combine ceiling lights or pendant lamps for general lighting with LED strips or direct spotlights on work surfaces. Avoid shadow areas to ensure safety and facilitate operation.
Bedroom: light for relaxation
Use warm and adjustable light. Wall sconces or bedside lamps with direct but shielded light favor reading without disturbing. The integration of indirect lights contributes to visual comfort.
Bathroom: combining functionality and aesthetics
Good general lighting is necessary, paired with front and side sources at the mirror, avoiding shadows on the face. Resistance to humidity and electrical safety (IP rating) are essential requirements.
Study and office: light for concentration
Opt for cool or neutral high-intensity light, well-distributed and without glare. Desk lamps with adjustable arms and dimmable LEDs are ideal.
Current trends in interior lighting
The latest trends in lighting within interior design include:
1. Light integrated into architecture
Recessed LED strips in false ceilings, niches, skirting boards, or floors to create light cuts that are invisible to the eye but effective in defining geometries and volumes.
Use of hidden magnetic tracks that host adjustable spotlights or linear modules for flexible and clean lighting.
LEDs dominate the market for efficiency, durability, and versatility. Integrated into smart home systems, they allow remote control, automatic intensity adjustment, and programming based on habits.
2. Bright minimalism
Ultra-thin solutions reduced to the essentials (e.g., lighting fixtures in matte black metal or satin white) that fully integrate into the space.
Elimination of traditional chandeliers in favor of linear modules or suspended tubular lamps, ideal in open spaces or contemporary kitchens. Solutions like hidden tracks, strips integrated into false ceilings, or ultra-thin recessed spotlights allow for discreet and sophisticated integration, enhancing the purity of the architectural project.
3. Lighting as a scenographic element
Incorporation of dynamic RGB lights in living rooms or corridors to create customizable light scenarios (e.g., with voice control or apps).
Use of sculptural lamps as focal points, especially in entrances or living areas, to combine art and lighting.
4. Natural and artificial light in continuity
Design that enhances natural light with large openings, technical curtains, and mirrors, integrated with artificial lights with adjustable temperature to ensure perceptual continuity throughout the day (human-centric lighting).
5. Technology, automation, and sustainability
Smart lighting systems integrated into the home automation project: automatic adjustment of intensity and color based on times, moods, or activities (e.g., “relax,” “dinner,” “work” scenes).
Presence sensors in passage areas (stairs, corridors, secondary bathrooms) for efficient consumption management. The use of sensors, timers, and optimization of natural light sources contribute to reducing environmental impact.
6. Materials and surfaces that amplify light
Strategic use of reflective materials (mirrors, glass, satin metals) or light opaque surfaces to multiply and diffuse light in small or poorly lit environments.
Walls and coverings with textured materials highlighted by grazing light or directional spotlights.
Designing lighting with artificial intelligence
Artificial intelligence today represents a strategic tool in architectural design, including the study of lighting. Thanks to solutions integrated into modern BIM environments, it is possible to generate intelligent design proposals that take into account the optimal distribution of light, both natural and artificial, from the outset.
Lighting management in interior design with AI – usBIM.codesign AI
A new approach to design with AI
Starting from a simple sketch, image of the 3D model, or photo of the current state, the designer can define characteristics of the environments, aesthetic criteria, and conditions of natural and artificial lighting, achieving automatic configurations in a few seconds.
The proposals obtained simplify the initial phases of concept and provide support for design both in terms of creativity for the designer and communication with the client. This approach allows for quick exploration of alternative solutions, improving design quality and reducing decision-making times.
AI should not be understood as a replacement for human work and ingenuity but as a useful contribution to the creative process that should be refined and developed according to the designer’s sensitivity.
To learn more, read also How to use AI in architectural design and interior design: more efficiency and creativity.
Simulating lighting in interior design: practical example
Let’s take a practical example with a tool that uses AI to create photorealistic project images. We start from a quick sketch, perhaps hand-drawn, of the space to be rendered. We trace the lines that define the spaces and the footprints of the main furniture to be inserted. Alternatively, we could also start from a digital 3D model, created with an architectural design software.
The image obtained will be the basis for creating a design proposal with AI.
The AI architecture generator allows us to choose the style we want to achieve, starting from a predefined list or by uploading a reference image to inherit its style, transferring it to the project image to be rendered.
Finally, we set the lights. We can choose between natural and artificial lighting and then select the specific type:
- Direct Sunlight (Noon);
- Diffused Light (Cloudy Day);
- Golden Hour (Sunrise/Sunset);
- Blue Hour (After Sunset);
- Moonlight and Night Scene;
- Urban Night Lighting;
- Interiors with Direct Sunlight;
- Interiors with Diffused Natural Light (Cloudy Day);
- Interiors with a Night View and Artificial Warm Lights;
- Interiors with a Night View and Cool Lighting.
In a few seconds, we can choose to regenerate the image and verify the design choices as lighting conditions change.
FAQ
1. Why is lighting so important in interior design?
Lighting is not only necessary to ensure visibility: it shapes the perception of spaces, affects people’s psychophysical well-being, and enhances colors, materials, and volumes. A well-structured project contributes to the functionality, aesthetics, and visual comfort of environments.
2. What are the three main levels of lighting to consider?
The three fundamental levels are:
- Ambient lighting, which is the general light diffused for basic visibility;
- Functional lighting, aimed at specific activities such as reading or cooking;
- Accent lighting, used to highlight architectural or decorative elements.
3. What are lumens and lux, and why are they important?
Lumens measure the total amount of light emitted by a source, while lux indicates the luminous intensity on a surface (1 lux = 1 lumen per square meter). Knowing these values is essential for designing effective and balanced lighting.
4. What is the ideal color temperature for different environments?
It depends on the function of the environment:
- Warm light (2700–3000 K) for relaxation areas such as living rooms and bedrooms;
- Neutral light (3500–4000 K) for kitchens and bathrooms;
- Cool light (5000–6500 K) for operational environments such as studios or offices.
5. What is CRI and when should it be considered?
CRI (Color Rendering Index) measures the ability of light to render colors realistically. A value above 80 is generally suitable for domestic environments; for spaces such as museums or photography studios, CRI values above 90 are preferred.
6. How should light be distributed in different areas of the home?
Each environment has specific needs:
- The living room requires a mix of diffused light and adjustable light points;
- The kitchen needs intense and well-distributed light over work surfaces;
- The bedroom prefers warm and adjustable lights;
- The bathroom requires safe and functional lights, especially around the mirror;
- The study or office requires neutral or cool lighting, without glare.
7. What are the main current trends in interior lighting?
Trends include:
- The use of LEDs and smart systems for personalized control;
- Architectural integration with discreet solutions such as LED strips or recessed spotlights;
- Energy efficiency, with presence sensors and enhancement of natural light.
8. How does artificial intelligence support lighting design?
AI allows for the rapid simulation of different lighting conditions starting from sketches, 3D models, or images. It helps generate design solutions that combine creativity and efficiency, facilitating communication with the client and optimizing decision-making times.
