Managing BIM Data in GIS: Techniques and Best Practices
Optimize BIM data management in GIS with the right tool, maximizing both security and accessibility
The integration of BIM (Building Information Modeling) data into GIS (Geographic Information Systems) represents a significant breakthrough in the civil engineering and facility management industries. Let’s find out how this technological convergence is revolutionizing the way physical assets are managed and optimized.
The combination of BIM and GIS technologies is changing the infrastructure management landscape. Traditionally, BIM has been used to model buildings and infrastructure in detail, while GIS has excelled in managing geospatial data on a regional or global scale. The integration of these two worlds allows the creation of geospatial digital twins, overcoming size and scale limitations.
In this article, we see how all this is possible with a geospatial digital twin software, which we recommend trying to understand its enormous potential.
Integration between BIM and GIS
Intersection of local (BIM) and global (GIS) data
The integration between BIM and GIS combines the detailed and localized BIM data, such as architecture, structures, MEP (Mechanical, Electrical, Plumbing), with the global geospatial data of GIS. This integration allows contextualizing physical assets within their geographic environment, considering factors such as terrain, surrounding infrastructure, and environmental conditions.
Monitoring, analysis, and optimization
Let’s take a closer look at the peculiarities of this combination of technologies that brings countless benefits.
Real-time monitoring
Thanks to geospatial digital twins, it is possible to monitor physical assets in real-time. IoT (Internet of Things) sensors installed on buildings and infrastructure continuously collect data on operational conditions, such as temperature, humidity, vibrations, and other relevant metrics. This data is transmitted to digital models, allowing a constant and updated view of the asset’s status.
Advanced analysis
Geospatial digital twins allow for advanced analysis using simulation techniques. For example, it is possible to predict how a building will respond to natural events such as earthquakes or floods, or how transport infrastructures will handle traffic variations. These simulations help identify potential issues before they occur, improving resource planning and management.
Performance optimization
The information obtained through monitoring and analysis allows for optimizing the performance of physical assets. For example, predictive maintenance can be planned, intervening only when data indicates that a component is about to fail, thus reducing downtime and maintenance costs. Furthermore, it is possible to optimize the use of energy resources, improving overall efficiency.
Advantages of creating geospatial digital twins
Now let’s see what are the advantages of combining these two technologies.
GIS 3D Modeling with usBIM.geotwin
Informed Decision Making
With a geospatial digital twin, users have access to a vast amount of accurate and updated data, enabling decisions based on real information. This reduces uncertainty and increases confidence in strategic and operational decisions.
Operational Efficiency
By centralizing all information in a geospatial digital twin, search and data verification times are reduced. This improves operational efficiency, as all necessary information is easily accessible and integrable into decision-making processes.
Collaboration and Data Sharing
Geospatial digital twins facilitate collaboration among different disciplines and stakeholders. Architects, engineers, infrastructure managers, and other stakeholders can work together on a common platform, sharing information and coordinating their activities more effectively.
Innovation and Sustainability
The use of geospatial digital twins promotes innovation in physical asset management. For example, new technologies or management strategies can be tested in a digital environment before being applied in the real world. This approach reduces risks and promotes more sustainable and efficient solutions.
BIM Data Managed in GIS
One of the main obstacles in merging BIM data with GIS geospatial information is managing the large volume of detailed data for each construction object and the territorial scale view.
For this reason, there are geospatial digital twin software on the market that greatly facilitate the relationship between BIM data and the GIS world. All BIM information is always accessible within the GIS, allowing geospatial queries without limitations on the number and size of data. You can manage complex projects, both for specific works and for linear infrastructures such as roads, railways, bridges, and tunnels, without worrying about the amount of data to be processed.
You can access vast amounts of data, including representations of large files such as point clouds, textured meshes, and openBIM or proprietary format models. You can perform geospatial queries in the GIS and immediately view the 2D and 3D shapes of the construction BIM model, thus optimizing design decisions.
From the geospatial view, you can detail federations of architectural, structural, and plant models of buildings or infrastructures, along with IFC properties and all related data.
usBIM.geotwin supports the use of openBIM formats (IFC in all versions 2×3, 4.0, 4.3), in compliance with European standards, ensuring perpetual access to data, information sharing with all stakeholders, and activity coordination.
Here is a short video that practically summarizes all the above aspects. Finally, if you need to manage models and point clouds, you can also try a powerful geospatial digital twin software and discover its many advantages.
Read more about “GIS for infrastructure”
