  • BIM news
  • BIM projects
  • EN
  • Menu Menu
List List Menu
  • BIM and Construction Sites
  • BIM and Building Design
  • BIM in Construction
  • BIM and Estimation
  • BIM and Energy
  • BIM and Safety
  • BIM and MEP
  • BIM and Facility Management
  • BIM and training
  • BIM and GIS
  • BIM and Infrastructure
  • BIM and technical standards
  • IFC and openBIM
  • Digital Twin
Home » BIM and Facility Management » Plumbing maintenance: efficiency and safety
Discover the importance of preventive maintenance of plumbing systems to ensure operational continuity and workplace safety
Editorial Team / 30 August 2024
Effective management of plumbing systems is essential to ensure operational continuity, worker safety, and the sustainability of industrial operations. In this article, we will explore the importance of plumbing maintenance and the different types of preventive interventions used in the industrial sector. From protecting operational continuity to reducing maintenance costs, we will discover how preventive maintenance can help optimize system performance and ensure an increasingly safe and efficient work environment.
Maintenance specialist for water systems performing checks
  • Importance of plumbing maintenance
  • Types of plumbing systems in the industrial sector
  • Plumbing Maintenance
To understand the importance of maintenance, it is necessary to delve into the main benefits of this essential practice.
Protection of operational continuity
Operational continuity is fundamental for any company, as interruptions can lead to significant economic losses and compromise productivity. Regular maintenance of plumbing systems helps prevent sudden failures, thus reducing the risk of machine downtime and interruptions in production processes. Well-maintained plumbing ensures a constant flow of water and other fluids necessary for daily operations, ensuring that production activities can proceed smoothly.
Worker safety
As in any work environment, safety is paramount. Underestimating any risk could lead to serious consequences. This is why maintenance tends to reduce malfunctions that could otherwise pose a serious safety risk, causing incidents such as flooding, pipe bursts, or exposure to hazardous substances.
Reduction of economic damages and risks to individuals
Preventive maintenance of plumbing systems not only prevents failures and interruptions but also helps reduce the costs associated with emergency repairs and structural damage. Significant breakdowns can require expensive interventions and cause damage to buildings, equipment, and goods. A regular maintenance program allows for the identification and resolution of problems before they become critical, reducing overall costs and risks.
Support for general auxiliary and specific systems
Plumbing systems do not operate in isolation but are integrated with numerous other auxiliary and specific systems necessary for production processes. These include compressed air, steam, refrigeration, and water treatment systems. Maintenance of plumbing systems is essential to ensure the proper functioning of these auxiliary systems, which in turn are crucial for many industrial applications. An efficient plumbing system supports the entire operational ecosystem, improving overall productivity and efficiency.
Plumbing systems in the industrial sector are designed to handle large volumes of water and fluids and are crucial for temperature control, pressurization, and many other industrial functions. Here are the main types of plumbing systems used in the industrial sector.
Water distribution systems
Water distribution systems are used to provide water to different sectors of an industrial plant. These systems ensure that water is available for production processes, cleaning, and other operational needs such as water supply systems including pumps, pipes, storage tanks, and water treatment systems, which include filtration, desalination, and purification processes to ensure the water is of the required quality.
Hot and cold water systems
These systems are designed to provide water at specific temperatures required for various industrial processes. The elements used in these types of systems are:
  • industrial boilers – used to heat water;
  • industrial chillers – used to cool water;
  • heat exchangers – used to transfer heat between two or more fluids.
Steam systems
Steam systems are essential for heating, sterilization, and energy generation processes. All managed through essential components used to produce steam by heating water (steam boilers), collect and recycle condensed steam (condensate systems), and transport steam to various points of use (steam distribution network).
Wastewater treatment systems
Wastewater treatment systems are designed to purify water used in production processes before it is released into the environment. As in other cases, there are several components useful for managing such a system, starting from treatment plants used to remove contaminants from wastewater, filtration systems for the removal of solid particles and other pollutants, and chemical and biological processes used to treat water and make it safe for release or reuse.
To learn more, read also: Exposed Plumbing advantages thanks to 3D Modeling!
Elements that are part of a system subject to maintenance checks
Preventive maintenance plays a crucial role in the management of plumbing systems in industrial settings, helping to ensure operational continuity, reduce maintenance costs, and prevent sudden failures. This practice can be divided into three main categories: periodic maintenance, condition-based maintenance, and predictive maintenance.
Periodic Maintenance
Periodic maintenance involves regular scheduled interventions performed at predetermined time intervals. These interventions aim to prevent wear and tear and keep plumbing systems in optimal operating conditions. Periodic maintenance activities may include:
  • Regular inspections – to identify early signs of wear, corrosion, or malfunctions;
  • Lubrication – to ensure the proper functioning of components such as valves and pumps;
  • Replacement of worn parts – replacing parts subject to deterioration or wear;
  • Alignment and tension verification – to ensure that components are correctly aligned and secured.
Periodic maintenance is essential to extend the service life of plumbing systems, reduce the risk of sudden failures, and ensure workplace safety. To delve deeper into the topic, we recommend reading the article “Periodic asset maintenance: what is it and what are the benefits“.
Condition-Based Maintenance
Condition-based maintenance is based on continuous monitoring of specific parameters to determine the health status of plumbing systems. This approach allows for intervention only when necessary, optimizing resources and reducing unplanned downtime. The main activities of condition-based maintenance include:
  • Performance monitoring – using sensors and tools to detect variations in system performance;
  • Oil analysis – to identify contaminants or signs of wear in hydraulic fluids;
  • Thermography – using thermal cameras to detect overheating or anomalies in components.
Condition-based maintenance enables timely diagnosis of potential issues and allows for more efficient planning of maintenance interventions, reducing overall costs and improving system reliability. In the article “What is condition-based maintenance and what are its advantages“, you can better understand what condition-based maintenance entails and why it is beneficial in various industrial processes.
Predictive Maintenance
Predictive maintenance represents the most advanced level of preventive maintenance, using advanced technologies to monitor systems in real-time and predict failures before they occur. This approach is based on data analysis and artificial intelligence to identify patterns and anomalies in system performance. Techniques used in predictive maintenance include:
  • Advanced sensors: using intelligent sensors to monitor critical system parameters.
  • Data analysis: applying machine learning algorithms to identify failure patterns and performance anomalies.
  • Real-time monitoring systems: implementing continuous monitoring systems to detect changes in system operating conditions.
Predictive maintenance allows for proactive failure prevention, minimizing downtime and optimizing operational efficiency of systems. Read the article “How to implement predictive maintenance: benefits, techniques and examples” to learn more about this preventive method.
usBIM.maint
usBIM.maint
Share this entry
  • Share on Facebook
  • Share on X
  • Share on WhatsApp
  • Share on LinkedIn
  • Share by Mail
Related posts
    27 July 2026
  • BIM Facility Management: The Power of BIM in Asset Management
  • 27 July 2026
  • What is a Maintenance Audit and Why It’s Important
  • 18 June 2026
  • Building Commissioning: Definition, Phases, and Key Benefits
  • 10 June 2026
  • Bridge Management System: What It Is and How It Works
Follow us on
  • Construction Sites
  • Energy
  • Estimation
  • Infrastructure
  • Safety
  • Structural Calculation
  • Technical standards
  • Training
  • BIM news
  • BIM project example
  • Digital Twin
  • IFC and openBIM
Scroll to top
