Change Management in Construction: Process, Causes, Best Practices
Change management in construction is a useful process for managing sudden changes in the construction timeline. Here’s why it’s important and how to implement it.
The need to introduce sudden changes in a construction project can create problems in terms of time and cost. To address this issue, change management becomes essential. Implementing good practices of “change management” in the construction sector can be truly beneficial for quickly acquiring new strategies necessary to ensure the project’s success. I recommend that you try a construction management software right away to manage all activities of the change management process and continue reading this article to understand how you can develop an effective strategy.
Workflow reorganization following design
- What is Change Management in Construction?
- Common Causes of Variances in Construction Projects
- Types of Variations in Construction Projects
- Why is change management important in construction?
- The process of managing changes in construction projects
- How to Document Change Management in Construction Projects
- How to effectively implement change management in construction?
- FAQ on change management
Change Management in construction (also known as site variant management) is the structured set of processes, methodologies, and tools aimed at identifying, evaluating, approving, and monitoring any changes from the original planning of a construction or infrastructure project.
In the architecture, engineering, and construction (AEC) industry, a project rarely follows the defined path identically as it was during the initial design phase. Environmental variables, geological surprises, alterations in client requirements, or fluctuations in material prices make variation an almost inevitable element in the project lifecycle.
Implementing a proper Change Management process in the construction sector does not merely mean reacting to unforeseen events but proactively managing them to limit the impact on three fundamental parameters (the so-called constraint triangle):
- costs – prevent extra costs induced by rework or penalties;
- time – avoid delays in the delivery of the site and in the work schedule;
- quality – ensure that changes comply with performance standards and current regulations.
With the advent of BIM methodology and the digitalization of construction sites, Change Management has evolved from a bureaucratic and paper-based approach to a management system based on shared informational models. This allows simulating the impact of a variation in real time and tracking every decision, ensuring maximum transparency among the client, project management, and the executing company.
What constitutes a variation in a construction project?
In the context of a construction site, a variation (or Change Order) is defined as any formal alteration compared to the approved project baseline, which modifies the initial contract, the executive drawings, the technical specifications, or the implementation timelines.
To fully understand the scope of Change Management in construction, it is essential to identify the elements that concretely constitute a variation:
- changes to the specifications and scope of work – addition or removal of work items, changes in finishes, or variations in material choices compared to what was agreed upon in the original offer;
- design errors or omissions – discrepancies between graphic documents and structural/system calculations, or defects discovered during the coordination and clash detection phase in the BIM model;
- unexpected site or soil conditions – inadequate geological findings, presence of unreported groundwater from preliminary investigations, or interference with existing utilities;
- regulatory and authorization adjustments – safety requirements or urban-environmental constraints introduced by competent authorities during the execution of work;
- rescheduling of the work schedule – requests for acceleration of site phases or delays resulting from problems in the supply chain that require reprogramming of activities.
In the absence of a strict Change Management protocol, each of these scenarios risks turning into a formal dispute (claim), causing operational blockages and legal disputes. On the contrary, integrating Change Management into the digital workflow allows for the approval of variations with a clear understanding of their economic and temporal impacts, safeguarding all parties involved.
In the field of engineering and construction, site variances never occur by chance: they are the result of complex dynamics that develop throughout the entire lifecycle of the project. Understanding the root causes is the first step in establishing an effective Change Management process in construction.
The main causes that necessitate introducing a modification during the works can be divided into internal and external circumstances to the project team:
- inconsistencies and errors in the initial design – uncoordinated drawings, interferences between disciplinary models (structural, architectural, and plant engineering) or incomplete technical specifications require immediate corrections during the execution phase;
- unexpected site and soil conditions – discrepancies between preliminary geological/geotechnical investigations and the reality of the construction site (e.g., unforeseen rock, high water tables, or the presence of unmapped utilities);
- modification requests from the client – new functional needs, variations in layout, or aesthetic revisions proposed by the client once work has already begun;
- issues in the supply chain – unavailability or discontinuation of specific materials, delays in the delivery of prefabricated components, or sudden increases in raw material prices;
- force majeure and exceptional weather events – adverse weather conditions that compromise the technical feasibility of the work or damage partially completed structures;
- new regulatory or authorization constraints – changes to the legislative framework, local building regulations, or safety requirements that arise during construction;
The adoption of advanced methodologies such as BIM and 4D/5D modeling drastically reduces the emergence of internal causes, but Change Management in construction remains essential for managing all unforeseen events with promptness and transparency.
Collaborative approach to the change management process
To apply proper governance of changes, the Change Management process in construction classifies variations based on their origin, the subject of the intervention, and their impact on the contract. Below, we analyze the main categories encountered on construction sites.
Design Variations
Design variations arise from modifications to technical documents, working drawings, or BIM informational models. They may be generated by the need to correct calculation errors, resolve geometric clashes that emerged late, or adjust the project to the actual dimensions detected on site. In a BIM environment, a design variation involves the revision of parametric objects and the updating of the information progress status of the model.
Scope and Area Variations
Scope and area variations occur when the works included in the original contractual agreement are significantly added, removed, or modified. A typical example is the expansion of the buildable area or the inclusion of new building functionalities at the client’s request. This type of variation has a direct and cascading impact on both the timelines and the final budget of the work.
Schedule Variations
Schedule variations concern the rescheduling of the execution time of individual phases of the site or the final delivery date. They may consist of:
- extensions (Extension of Time – EOT) – granted to the contractor for delays caused by force majeure or work suspensions ordered by the project management;
- acceleration plans – modifications to the work program aimed at recovering accumulated delays by increasing resources and work shifts on the site.
Cost Variations
Cost variations affect the economic component of the contract without necessarily altering the physical works. This category includes changes due to the revision of material prices, the adjustment of exchange rates for foreign supplies, or the application of reserves and extra costs due to work stoppages not attributable to the contractor.
Technical and Construction Method Variations
Technical variations occur when the execution technology or construction methodology is modified to carry out the same work. This happens, for example, when choosing to replace a cast-in-place structure with prefabricated elements to accelerate timelines or when adopting a different soil containment system due to poor soil bearing capacity.
Contractual Variations
Contractual variations involve changes to the terms and conditions of the agreement between the client and the contractor, regardless of the purely physical aspect of the work. This includes the revision of payment terms, changes to performance bonds, redefinition of penalties for delays, or modification of the service levels required during testing.
Emergency Variations
Emergency variations constitute a special category activated in extraordinary situations of immediate danger to public safety, worker security on site, or the safeguarding of the integrity of the work. In these cases, the Change Management protocol in construction provides that corrective work is carried out immediately, deferring the accounting formalization and signing of the Change Order to a later time.
In the construction sector, change management is very important because it prevents:
- delays;
- cost increases;
- customer dissatisfaction;
- disturbances in project objectives;
- legal blocks;
- low-quality work.
To avoid disputes (claims), sudden cost escalations, and uncontrolled delays, Change Management in construction requires a clear, traceable, and standardized workflow. Every single modification must follow a specific procedure before it becomes an operational instruction on site. In a digital environment, this flow is managed within the Common Data Environment (CDE), ensuring transparency and traceability for all actors in the supply chain.
Identify the proposed change
The flow is activated as soon as a need or opportunity for a change arises. The need can be identified by the executing company during field tracking, by the project management during control, or by the client for new functional requirements.
Document the change request
The informal request is transformed into an official document called Change Request (CR) or Change Variation Request. The document specifies the reason for the request, the construction site elements involved, the relevant graphical documents, and a brief description of the intervention.
Assess the necessity of the change
The project manager and the project director conduct a preliminary review to determine whether the change is indeed necessary (e.g., safety constraints, regulatory inconsistencies, or design defects) or optional. If the request lacks technical or contractual basis, it is rejected without committing further resources.
Analyze impacts on scope, costs, and timelines
The effect of the change on the three key parameters of the project is quantified:
- scope – how quantities and specifications of the work change;
- costs – preparation of the supplementary budget estimate (variation pre-bill);
- time – impact analysis on the general schedule (CPM) using 4D/5D BIM modeling to check whether the change alters the project’s critical path.
Evaluate risks and benefits
Before the final approval, a cost-benefit analysis and a risk analysis are conducted. The operational or performance advantages generated by the change are weighed against the risks associated with its execution (e.g., possible site halt, overlap of workers, or availability of materials).
Approve or reject the change
Based on the analyses produced, the RUP/Project Manager or the Client issues the final verdict. In the case of a positive outcome, the Change Order (or Submitted Act/Change Variation Report) is formalized and signed, officially modifying the contractual terms.
Update project documents and plans
Following approval, immediate updates to the project documents are made: BIM informational models, executive graphic tables, special contract specifications, economic plan, and work schedule.
Communicate the change to stakeholders
The approved change is officially notified to all interested parties: site manager, subcontractors, suppliers, testers, and authorizing bodies. In the BIM workflow, this step coincides with the publication of new versions of the objects in the Approved/Published state of the CDE.
Implement the approved change
The change becomes fully operational. The company initiates the modified work on site according to the new specifications, and the project management supervises the execution to verify technical compliance.
Monitor and close the change
During and by the end of the intervention, it is checked that the actual costs and timelines remain within the limits established in the change order. Once the work is completed, the change is included in the final accounting and in the as-built documentation of the project.
Documentary rigor is the backbone of an effective Change Management system in construction. In the absence of traceability, a variation risks quickly turning into disputes, stalled works, or uncontrollable cost overruns.
In the era of digital transition in the AECO industry, documentation no longer consists merely of the accumulation of signed paper forms. It is an integrated information ecosystem that relies on the CDE and ensures that every change is validated, justified, and accessible in real-time to all stakeholders in the supply chain.
To ensure maximum contractual and executive protection, documentation for a variation must be structured in six key components.
Variation Request Forms
The variation request form is the formal act that officially initiates the change management flow.
This standardized document summarizes the key elements of the variation:
- subject and traceability ID – unique identifier of the request for tracking in the CDE;
- origin of the request – specifies whether the proposal comes from the client, the executing company, or the Works Management;
- technical or contractual justification – detailed description of the problem (e.g., unforeseen interference, regulatory change, performance optimization);
- brief description of the intervention – summary of the additional or corrective works to be carried out.
Revised Drawings and BIM Models
A variation cannot be executed on-site based on simple verbal instructions. Change Management in construction requires the timely updating of technical and executive documents.
- Revision of 2D drawings – the graphic drawings are recreated, usually applying the so-called revision clouds that highlight the area subject to change and updating the revision block with the indication of the new index (e.g., Rev. A –> Rev. B);
- Update of BIM Models (Informative Models) – in BIM workflows, modified parametric objects are updated directly in the disciplinary model. Through the BCF (BIM Collaboration Format), changes are reported and coordinated among different disciplines (architectural, structural, systems) to perform a new clash detection before installation.
Updated Technical Specifications and Cost Estimating
Every physical variation has a direct impact on site accounting and executive prescriptions.
- integrative cost estimating (variation pre-quote) – accounting document that quantifies the new volumes or different quantities of work. If the variation introduces works not foreseen in the original contract, the formulation and approval of the related New Unit Prices (NPU) shall be proceeded;
- technical specifications – updating the technical data sheets for the materials, required performances, and operational installation methods to ensure compliance of the final work.
Cost and Timeline Impact Report
Before proceeding with the final approval of a Change Order, the decision-maker must have an accurate forecasting analysis based on data:
- economic impact report – comparative framework illustrating the variation of the overall project budget, highlighting financial coverages (e.g., use of contingency reserve or allowances);
- impact analysis on the timeline (4D BIM) – temporal simulation aimed at determining whether the variation affects the activities of the critical path (Critical Path Method – CPM). Any days of extension to be granted (Extension of Time – EOT) or necessary acceleration plans to maintain the delivery date unchanged are established.
Approval Log and Traceability
The Change Log (or Variations Register) is the centralized record that tracks the status of each request from the moment of its opening to the final closure.
The recorded data includes:
- Date of submission, evaluation, and decision.
- Names of signatories and roles of responsibility (client, project manager, site manager, contractor).
- Priority score and operational status (Under evaluation, Approved, Rejected, Under execution, Closed).
In workflows managed in an CDE environment, this log is automatically generated providing an unalterable audit trail, essential for preventing or resolving potential legal disputes or contractor claims.
As-Built Documentation (Final State)
The change management process in construction does not conclude with the simple execution of the variation on-site, but with its correct archiving for final accounting.
As-Built (or As-Constructed) documentation represents the faithful snapshot of what has actually been constructed:
- As-Built graphic outputs and BIM modeling – definitive alignment of the 3D informative model and graphic tables to the reality of the site;
- works folder and testing documents – updating of operation and maintenance manuals, certifications of new materials, and conformity declarations necessary for the subsequent phase of Facility Management (6D/7D BIM).
To effectively implement change management in the construction sector, it is necessary to adopt a well-structured strategy that involves the use of a construction management software. We recommend trying this tool for free right away, which offers numerous benefits, including:
- centralization of information: this allows all team members to have immediate access to the most up-to-date information and reduces the risk of misunderstandings or errors due to a lack of correct information;
- traceability of changes: keeping track of all changes made to the project, including information such as responsible parties and modification dates, allows for effective management of any issues that may arise during the construction process;
- better collaboration among team members: clear and timely communication reduces delays and improves task management.
What is Change Management in construction?
It is the structured set of processes, methodologies, and tools to identify, assess, approve, and monitor any changes compared to the original planning of a project. It serves to govern variations proactively to limit impacts on costs (avoiding extra costs or penalties), timelines (avoiding delays in the schedule), and quality (complying with standards and regulations). Thanks to BIM and digitization, it relies on shared information models to simulate impacts in real time and ensure transparency among all stakeholders.
A variation (or Change Order) is any formal alteration from the approved baseline that modifies the contract, working drawings, technical specifications, or timelines. It consists of: changes to the specifications and scope of work, design errors or omissions (discrepancies or interferences identified in clash detection), unforeseen site or ground conditions (water tables, rock, or underground utilities), regulatory and permit adjustments, and rescheduling (accelerations or delays in the supply chain).
What are common causes of variations in construction projects?
Variations arise from internal and external causes:
- inconsistencies and errors in the initial design;
- unforeseen site and soil conditions;
- change requests from the client;
- issues in the supply chain (unavailability of materials or price increases);
- force majeure events or exceptional weather;
- new regulatory or permitting constraints.
What are the types of variations in construction projects?
They are divided into:
- Design variations (changes to documents or BIM models due to errors or interferences);
- Scope and extent variations (significant changes to contractual work);
- Schedule variations (EOT extensions or acceleration plans);
- Cost variations (price revisions or extra costs without physical changes);
- Technical and construction method variations (change in technology or execution methodology);
- Contractual variations (changes to clauses, payments, or penalties);
- Urgent variations (immediate interventions for danger or safety purposes, formalized later).
It is essential because it prevents delays, cost increases, client dissatisfaction, disruptions to project objectives, legal blocks, and low-quality work.
What is the process for managing variations in construction projects?
The workflow, managed in the CDE, includes 10 phases:
- Identify the proposed variation;
- Document the request via Change Request (CR);
- Evaluate the necessity of the variation;
- Analyze the impacts on scope, costs, and timelines (BIM 4D/5D);
- Assess risks and benefits;
- Approve or reject via Change Order;
- Update documents and project plans;
- Communicate the variation to stakeholders;
- Implement the variation on site;
- Monitor and close the variation by including it in the as-built.
How to document change management in construction projects?
Documentation is based on rigorous documentation in CDE through 6 components:
- Change request forms (CR);
- Revised graphic documents (with revision clouds) and BIM models (updated via BCF);
- Technical specifications and integrated metric estimates (with NPU);
- Impact reports on costs and timelines (BIM 4D/5D and CPM);
- Approval log and traceability (Change Log/audit trail);
- Final As-Built documentation (aligned 3D models, manuals, and tests for Facility Management).
It requires the adoption of construction management software, which allows you to: centralize information (ensuring access to updated data and reducing errors), track each modification (with responsible parties and dates to manage issues), and improve collaboration among team members, reducing delays.
