Reticular Structures: Innovation and Stability for Modern Architecture
What are reticular structures in the construction field? Everything you need to know about their structure, advantages and some famous examples
Reticular structures, in the construction field, represent one of the most advanced and flexible solutions for the design of roofs and large-scale systems. These systems are characterized by a set of beams, generally made of steel or wood, connected together to form a series of triangles, ensuring a high load-bearing capacity and an even distribution of loads. Below is a detailed technical insight into the characteristics, advantages, and applications of reticular structures.
What is meant by reticular structures?
Reticular structures or spatial reticular structures are based on 2 main aspects that interact with each other in a synergistic way: geometry and repetitiveness. Geometry, conceived as shape, represents the set of laws that govern the aggregation in space of elementary solids, combined with each other. It defines the relationships between the various elements (angles and edges) necessary to construct polyhedra, which can be more or less complex, regular or irregular, and which can be inscribed in other simpler solids or derived from intersections between them. Furthermore, it establishes the parameters necessary to identify the base solid, which is also a polyhedron, thus defining the module. Geometry is therefore the generating force of both the base module and the complex shapes that derive from it.
Repetitiveness, on the other hand, not only regulates the quantity of modules that repeat in space but also determines the rhythm and frequency, giving rise to an infinite and harmonious composition of shapes that adhere to rigorous geometric principles.
In spatial reticulations, polyhedra are not seen as three-dimensional solids but are represented through “beams” and “nodes”: the beams correspond to the edges, while the nodes correspond to the vertices. In this way, each point of intersection between the beams represents a node and vice versa. The faces of the polyhedra can be subdivided into triangular elements, formed by beams and nodes. Many polyhedra can be inscribed in others or result from their intersection. In this context, the most commonly used regular polyhedra are primarily represented.
The use of structural calculation and design software has significantly simplified the management and representation of these geometries, which become much more complex when the faces of the polyhedra are three-dimensional and further subdivided into more elementary polyhedra. The 3D drawing of a modular structure through the software is fundamental in the design of spatial reticular structures, as it allows for quick verification of the distribution and control of all the elements (beams and nodes) that make up the structure.
Who invented the reticular structure?
Spatial reticular structures originated with the first insights of August Föppl, who published his theory on spatial reticular systems in 1880, outlining the theoretical and practical foundations of these structures. His work culminated in the publication of the book Das Fachwerk in Raume in 1891, inspired also by the collapse of the Birs bridge near Munchenstein. Later, Robert Le Ricolais, a French engineer, recognized the potential of double-layer reticular structures, observing how some natural forms use similar configurations to minimize internal stresses. Among the innovators, Alexander Graham Bell experimented with models based on the tetrahedron, introducing the first beam-node connections. In the 1950s, Richard Buckminster Fuller made significant contributions with his geodesic domes, merging scientific and philosophical concepts.
Reticular structures and tensile structures
Reticular structures and tensile structures are two types of construction systems that find wide application in civil engineering and contemporary architecture due to their ability to cover large spans with efficient use of materials.
Tensile structures are based on the use of tension as the main load-bearing force. These structures utilize flexible elements such as steel cables and textile membranes that work in tension, while rigid elements, such as columns or arches, serve to anchor and support the cables. Tensile structures are characterized by high material efficiency, as the distributed tension allows for covering large surfaces with minimal use of materials. Common examples include stadium roofs, circus tents, and temporary pavilions.
Reticular structures use rigid elements such as steel or wood, while tensile structures make extensive use of flexible and lightweight materials. Reticular structures are self-supporting due to their geometry, while tensile structures rely on tension to maintain shape and stability. Tensile structures offer greater flexibility in design and a lightweight, transparent aesthetic, while reticular structures are more suitable for modular and rigid configurations.
Two or more layer and single-layer reticular structures
Spatial reticular structures can be divided into 2 categories: two or more layers and single-layer. Two or more layer spatial reticular structures are formed by grids consisting of beams and nodes, derived from the aggregation of tetrahedral base modules. The repetition of these tetrahedra in space, whether regular or irregular, generates an infinity of geometries.
Single-layer spatial reticular structures, on the other hand, consist of grids formed by beams and nodes obtained from the aggregation of triangular modules, arranged to form quadric surfaces, with the perimeter nodes externally constrained. Therefore, single-layer “open” shell structures, in which the perimeter nodes are not all externally constrained, are excluded from this category, as these define statically unstable configurations, such as single-layer vaults, barrel vaults, or unclosed single-layer domes, very low membrane shells with supports limited to corner nodes, and flat structures or those not discretized into triangles.
The type of each spatial reticular structure, whether single-layer or double-layer, depends on the subdivision into elementary modules of the desired surface, which can be either curved or flat. Therefore, the geometric and dimensional identification of the base module, the number of modules, their arrangement, and the angular variations between the elements is fundamental for the final configuration of the structure.
The regular double-layer spatial reticular structures, also known as plates, most commonly used, are divided into two main types: those derived from the aggregation of regular tetrahedra and those formed by tetrahedra interspersed with regular semi-octahedra.
Flat plates with regular tetrahedral module
These structures are characterized by spatial grids with a hexagonal shape, where the beams, all of the same length, form equilateral triangles on two parallel planes. The beams of the upper plane are connected to those of the lower plane through wall beams of the same length, so that the vertices of the triangles in the upper plane correspond to the centroids of the triangles in the lower plane, creating two staggered flat grids. The various tetrahedra are arranged so that they share one edge.
Flat plates with regular tetrahedral module with interspersed semi-octahedra
These double-layer spatial structures are characterized by the definition of flat grids whose two planes, upper and lower, are staggered squares. The nodes of the square in the upper grid correspond to the centers of the diagonals of the squares in the lower grid. The structure is generated by a series of semi-octahedra that share one edge of the base square, thus forming tetrahedra among themselves.
What advantages do reticular structures present?
Reticular structures offer numerous advantages that make them particularly appreciated in the construction field, especially for the realization of roofs and large spaces. Let’s now explore the main technical advantages of reticular structures.
High structural efficiency
Reticular structures are designed so that the beams primarily work in tension or compression, minimizing bending and shear stresses. This behavior allows for optimal utilization of the mechanical characteristics of the materials, ensuring a high load capacity with a relatively reduced use of material. The distribution of loads occurs uniformly through a network of connected elements, avoiding stress concentrations at singular points and reducing the risks of local failure.
Reduced weight
Thanks to the mesh configuration and the arrangement of the beams, reticular structures can cover large spans with a contained structural weight. This is a significant advantage as it minimizes costs related to materials and foundations, reducing the impact of the supporting structures necessary to sustain the entire construction. The reduced weight is particularly important in applications where lightness contributes to seismic safety, as seismic forces act proportionally to the mass of the structure.
Modularity and ease of assembly
Reticular structures can be made through prefabricated modules that are assembled directly on site. This modularity simplifies the construction process, as individual elements can be mass-produced and quickly assembled, reducing construction times and associated costs. Modular assembly also allows for easy expansion or modification of the structure, offering great design flexibility.
Optimal load distribution
A distinctive feature of reticular structures is their ability to distribute applied loads over a wide area of beams and nodes. This means that each element of the structure bears a limited part of the total load, allowing for a design that minimizes the use of oversized materials. Furthermore, double or triple-curvature reticular structures further improve the distribution of forces, increasing stability and the ability to withstand variable loads, such as wind and snow.
Adaptability and design flexibility
Designing with reticular structures allows for the creation of complex and lightweight shapes that can be adapted to specific architectural needs. The ability to integrate curves, angles, and three-dimensional shapes makes these structures ideal for iconic buildings such as stadiums, airports, auditoriums, and exhibition pavilions. The use of advanced modeling software allows for precise simulation of structural behavior, supporting architects and engineers in creating innovative yet functional designs.
Resistance to dynamic and seismic loads
Thanks to their lightweight configuration and ability to distribute loads, reticular structures offer good resistance to dynamic stresses, such as those induced by seismic events. The reticular mesh can dissipate forces through the various nodes and beams, preventing individual elements from becoming overloaded and, consequently, subject to failure. Additionally, the greater lightness compared to other types of roofs helps reduce inertia forces during an earthquake.
Efficiency of Materials
Reticular structures are designed to maximize the use of materials. This means that each element of the structure is utilized to operate under the most favorable conditions, with predominantly axial stresses (compression or tension). The consequence is a greater structural efficiency compared to systems that must also withstand significant bending. The optimization in the distribution of materials results in a lower environmental impact and a reduction in construction costs.
Maintenance and Durability
Reticular structures, especially those made of steel or corrosion-resistant alloys, have a long lifespan with relatively low maintenance. The use of materials treated with corrosion protection and the application of specific paints or coatings ensure good resistance to weather agents. The network arrangement of the bars also facilitates the identification and access to parts for any maintenance interventions.
Cost-Effectiveness
Although the initial design of a reticular structure may require more time and resources compared to other solutions, the overall benefits often outweigh the initial costs. The reduced structural weight leads to a decrease in loads on the foundations and thus a reduction in related costs. Modularity and prefabrication can further contribute to lowering overall expenses, making reticular structures a competitive option for large-scale projects.
Reticular Structures: Some Examples
Reticular structures have been used in numerous iconic and functional projects around the world. Here are some concrete examples that showcase the wide range of applications and the potential of reticular structures in the construction field:
Eiffel Tower, Gustave Eiffel (Paris)
The famous emblem of Paris is essentially a large reticular structure. The tower consists of a robust metal network with triangular meshes, designed to reduce the area exposed to the wind and limit the surface on which it can exert its pressure. The design was conducted with careful physical and geometric-mathematical analysis to optimize the distribution of stresses to which the structure is subjected.
Olympic Stadium in Munich (Germany)
Built for the 1972 Olympics, the Olympic Stadium in Munich is an iconic example of the use of a reticular structure. The stadium’s roof is made up of a network of cables and a transparent membrane that forms a double-curvature reticular structure, creating a light and dynamic visual effect. This structure has demonstrated how reticular designs can be employed for large roofs with innovative and functional design.
The Eden Project (United Kingdom)
The Eden Project in Cornwall is a complex of geodesic dome greenhouses, one of the most emblematic forms of reticular structure. The domes, made with a system of steel bars and hexagonal and pentagonal panels, create a controlled environment to host various plant species. This example demonstrates the effectiveness of reticular structures in constructing large enclosed spaces that are lightweight and resistant, capable of covering surfaces without internal supports.
Louvre Abu Dhabi (United Arab Emirates)
The Louvre Abu Dhabi, designed by architect Jean Nouvel, features a spectacular reticular roof made of an interweaving of steel that creates a “rain of light” effect. The reticular structure of the roof has a diameter of about 180 meters and is designed to evenly distribute loads while providing a unique aesthetic. This application shows how reticular structures can combine structural functionality with distinctive architectural elements.
Allianz Arena (Munich, Germany)
The Allianz Arena is an example of a reticular structure used in combination with lightweight facade elements. The reticular supporting structure, formed by a network of steel bars, supports an inflatable covering made of ETFE cushions (a transparent polymer). This configuration offers resistance to external loads, including wind and snow, and is designed to withstand dynamic stresses.
The Beijing National Aquatics Center (China)
Also known as the “Water Cube,” the Beijing National Aquatics Center is an example of a three-dimensional reticular structure made with a combination of steel bars that form a lattice inspired by the structure of bubbles. This innovative shape offers both aesthetic and structural functions, supporting the building’s roof and walls with a uniform load distribution. The reticular design contributes to seismic resistance and material efficiency.
O2 Arena (London, United Kingdom)
The O2 Arena is one of the largest reticular structures in the world, consisting of a geodesic dome with a reticular steel structure. The reticular roof is supported by 12 pillars, creating a vast space free of central columns. This structure is an example of how reticular designs can be used to cover large spaces while maintaining a robust and lightweight design.
Roof of Denver International Airport (USA)
The roof of Denver International Airport consists of a lightweight reticular structure with an architectural fabric covering. This design, reminiscent of the surrounding mountain peaks, uses a combination of steel bars and tension cables to create a tent-like shape. The reticular structure is designed to withstand heavy snowfall and typical winds of the region while maintaining an aesthetically pleasing configuration.
The Glass Pyramid of the Louvre Museum (Paris, France)
The Glass Pyramid of the Louvre, designed by architect Ieoh Ming Pei, is supported by a reticular structure made of steel and aluminum. Although it appears to be a simple structure, the internal lattice allows for maintaining stability and weight distribution of the glass, creating a transparent and lightweight pyramid that serves as an iconic entrance to the museum.
Terminal 5 of Heathrow Airport (United Kingdom)
Terminal 5 of Heathrow Airport uses a reticular structure for its main roof. The reticular steel beams allow for creating a large internal space without intermediate pillars, enhancing the passenger experience and optimizing load distribution. This terminal is an example of how reticular structures can be employed for transport infrastructure, ensuring stability and strength with a modern design.
