Truss Beams: Types, Benefits, and Applications
Truss beams are structural elements made up of a set of rods subjected exclusively to axial stress. Discover how to design them
Truss beams represent one of the most effective and versatile structural elements in civil engineering and architecture. Composed of a set of rods arranged in a network configuration, these beams are designed to be subjected exclusively to axial stress, thus ensuring unmatched lightness and strength. These characteristics make them ideal for a wide range of applications, from bridges to industrial buildings, to large roofs.
In this article, we will explore what truss beams are, when it is appropriate to use them, and how to design them correctly. We will discover the basic principles that govern their operation, the different types available, and the advantages they offer compared to other structural solutions.
To effectively improve your approach to designing not only truss beams but any other component of your structures, rely on the capabilities of a structural calculation software. This BIM-based solution with an integrated FEM solver will provide you with the support you need to quickly create your structural models and perform advanced analyses in record time with extremely reliable results. Take advantage of a thirty-day free trial to explore all the features of this system and discover the advantages and design criteria of truss beams.
What are truss beams?
Truss beams are structural elements made up of a set of rods connected to each other to create a network configuration. This configuration allows for optimal force distribution throughout the structure, making it particularly efficient for supporting heavy loads and spanning large distances without the need for intermediate supports.
The rods that make up a truss beam can be made from various materials, including steel and wood, and are arranged in such a way as to form triangles, a geometric configuration that offers maximum stability and strength.
From a static point of view, it is assumed that the connection nodes between the rods of a truss beam are of the “hinge” type and that the loads consist of concentrated forces applied at the nodes themselves. This configuration implies that the rods are subjected exclusively to normal stress, thus eliminating shear and moment stresses within the various components.
Howe Truss | EdiLus
What advantages do truss beams offer?
Truss beams represent a highly versatile and advantageous structural solution in numerous fields of engineering. Compared to traditional solid section beams, they offer a series of significant benefits:
- structural lightness: the truss configuration allows for a significantly lighter structure with the same load-bearing capacity. This feature becomes crucial in applications where the weight of the structure is a determining factor, such as in structures subjected to seismic loads;
- efficiency in material use: the triangular arrangement of the members that make up the truss beam allows for better distribution of stresses, enabling more efficient use of the material employed. This results in slimmer cross-sections and reduced material consumption;
- versatility of use: truss beams can be designed and manufactured to meet the needs of a wide range of applications, from large-span roofs to bridges, from residential buildings to industrial and commercial structures. Their geometry can be easily adapted to the specific requirements of the project;
- prefabrication and simplified assembly: truss beams can be prefabricated in the factory, ensuring superior quality control and reducing construction time on site. Their assembly is quick and straightforward;
- maintainability: truss beams are easily inspectable and allow for quick identification and resolution of any structural issues.
Applications of truss beams
Thanks to their structural efficiency and high versatility, truss beams find application in various fields of engineering and architecture. They are primarily used to create:
- large-span roofs in industrial buildings, sports facilities, hangars, open spaces, or other structures where it is necessary to cover large areas without intermediate supports;
- decking for bridges and viaducts where high strength and lightness are required to overcome natural or artificial obstacles, such as rivers, valleys, roads, etc.;
- residential and commercial buildings where it is necessary to contain the overall weight of the structure to improve resistance to seismic stresses;
- temporary and modular structures that can ensure high speed of assembly and disassembly.
What are the components of a truss beam?
Truss beams consist of a series of elements that work together to form a strong and lightweight structure. These components can be classified as follows:
- chords: these are the elements that form the backbone of the beam and distribute loads along the length of the element. They are divided into:
- upper chord: a set of horizontal members located at the top of the beam. These elements are primarily subjected to compression;
- lower chord: a set of horizontal members located at the bottom of the beam. These elements are primarily subjected to tension;
- web members: they help maintain the distance between the upper and lower chords, ensuring that the structure remains stable and rigid. They work to counteract vertical and tangential stresses, keeping the configuration of the beam unchanged. The web members are further divided into the following elements:
- verticals: vertical members that connect the upper chord to the lower chord. The verticals must absorb the tangential stresses that arise with the bending of the chords;
- diagonals: inclined members that connect the chords. The diagonals primarily work to absorb tension and compression forces and contribute to maintaining the stability and rigidity of the structure;
- joints: these are the connection points between the members. The joints are crucial for transferring forces between the members and must be designed to withstand high stresses without causing structural weaknesses.
Components of truss beam
How does a truss beam work?
The resistant mechanism of the truss beam is based on the ability of its components to work synergistically to absorb and distribute forces through the members, which are subjected exclusively to tensile or compressive stresses.
The wall members, depending on the stresses they are subjected to, can be divided into:
- struts: members subjected to compression;
- ties: members subjected to tension.
These elements are connected at the nodes, which represent the points where forces are transmitted from one member to another. Thanks to the triangular arrangement of the members, the truss beam is able to distribute forces efficiently, minimizing the risk of deformations. This operating principle allows the truss beam to span large distances with a reduced amount of material compared to a solid beam.
Types of truss beams
Truss beams are mainly distinguished by their geometry and the type of stresses to which their members are subjected. Here is a list of the main types of truss beams with a brief description of their characteristics and behavior (assuming they are subjected to gravitational loads):
- Warren truss: also known as Neville truss, this type is distinguished by its simplicity and structural efficiency. The geometric configuration of this element does not include vertical members, but only diagonals arranged to form isosceles or equilateral triangles. The upper chord is compressed, the lower chord is in tension, while the consecutive diagonals experience alternating compressive and tensile stresses. Specifically, the diagonals descending towards the midspan of the beam are in tension, while those ascending towards the midspan are compressed;
- Howe truss: the geometry of this element is characterized by the presence of vertical members and diagonals ascending towards the midspan of the beam. The former are subjected to tension, while the latter are all subjected to compression. The upper chord is compressed, while the lower chord is in tension;
- Mohnié truss: this type is similar to the previous one as it consists of vertical members and diagonal members that, however, are arranged with a descending trend towards the midspan of the beam. The stresses in the wall members are, therefore, inverted compared to the Howe truss, with diagonals subjected to tension and vertical members subjected to compression. The upper and lower chords are, instead, subjected to compression and tension, respectively;
- Pratt truss: can be considered as a combination of the Howe and Mohnié trusses. It consists of vertical members and diagonal members that alternately take on an ascending and descending configuration. As in all schemes, the upper chord is subjected to compression, while the lower chord is subjected to tension. The diagonals descending towards the midspan of the element are in tension, unlike the ascending ones which are compressed. Regarding the vertical members, the even ones are subjected to compression, while the odd ones are unloaded;
- Nielsen truss: this type differs from the previous ones as the upper chord takes on a parabolic configuration. Vertical members are absent, therefore, the wall members consist exclusively of diagonally arranged elements subjected to tension. The curvilinear upper chord is subjected to a nearly constant compressive stress, while the lower chord is in tension;
- Inverted parabolic truss: unlike the Nielsen truss, this type is characterized by the presence of a straight upper chord and a parabolic lower chord, subjected respectively to constant tensile and compressive stresses. The wall members consist of compressed vertical members and tensioned diagonals;
- Double diagonal truss: it is a hyperstatic system that involves the positioning of two diagonals, one ascending and one descending, between two consecutive vertical members. It is used in cases where a reversal of loads can occur, as happens with wind or seismic action. This configuration allows for better handling of the sign reversals of the stresses, with diagonals that can be in tension or compression depending on the loading conditions.
Types of truss beams and their stresses
How to design a truss beam?
Designing a truss beam involves a series of steps that include structural analysis and determining the stresses in the various components. Below are the main steps for the correct design of a truss beam:
- define the geometry of the beam: start by determining the configuration of the truss beam you intend to design, clearly indicating the arrangement of the nodes and the bars. This step will be the basis for the subsequent analysis;
- identify loads and constraints: proceed with a load analysis to accurately assess the actions applied to the beam. Also, define the boundary conditions that may influence the equilibrium of the structure;
- analyze the stresses: determine the magnitude of the stresses in the bars using the method of equilibrium at the nodes or the method of sections. The first involves applying the equations of static equilibrium (sum of forces and moments = 0) to each node of the structure to derive the axial forces in the elements. The second, on the other hand, involves “cutting” the beam along a section that intersects no more than three non-converging bars at the same node. The equations of static equilibrium are then applied to the cut section to determine the magnitude of the stresses;
- dimensioning the beam: based on the stresses obtained, size the components of the truss beam to meet the strength and stability checks, considering the main limit states (ultimate strength, allowable deformations);
- final checks: ensure that the stresses in the various components do not exceed the allowable stresses of the chosen material. Subsequently, check the overall stability of the structure, paying particular attention to possible buckling phenomena (compression instability). Ensure that the beam is designed to avoid such issues, using appropriate checks and safety factors, which you can find within the Eurocodes for structural design.
The design of a truss beam can be extremely complex if done manually. To simplify and improve this process, we recommend using an advanced structural calculation software. Thanks to the integration of BIM technology and FEM analysis, this tool will facilitate the modeling of your structures and allow you to perform precise and reliable structural analyses that will help you evaluate the behavior of each component under different load conditions. Take advantage of a thirty-day free trial to discover all the features of this software and optimize your design work.
