Construction detail types and technical guidelines
Construction details are technical drawings that provide a complete graphical representation of a project specific section. Browse through examples and learn how to create them
Construction details are fundamental in the design and execution of any AEC (Architectural, Engineering, Construction) project.
They serve as an essential guide for designers, contractors and professionals in the construction industry. They ensure that every element of the construction project is executed according to the desired specifications.
Below, I provide a series of examples of construction details to browse through. And instructions on how to create them easily using a 3D building design software that you can immediately use for free for 30 days.
Edificius construction details
What are construction details
In the realm of design, construction details (or construction drawings) are detailed graphical representations that, with a high level of detail, illustrate the technical characteristics of various structure components.
They, are an integral part of the executive project documentation. And provide precise information about construction techniques and methodologies. Particularly those needed for specific parts of the building project realization. Examples would be: nodes, joints, connections, beam anchorages, masonry weaves and window frame profiles, etc.
Contractors, builders and construction workers usually use these details on-site. They ensure that every assemble or install element is correctly built. Therefore adhering to design requirements while addressing safety, functionality and aesthetic needs.
Appropriate references to construction details must be included in technical project drawings. You’ll find these references in plans, elevations, sections, 3D views and axonometric sections.
The level of detail provided by these graphic representations must ensure a comprehensive technical depiction of construction elements. Therefore to adopt construction methodologies and techniques in particular reference to geometry, dimensions, materials as well as installation is usually a key indication of a good level of construction detail.
The recommended minimum representation scale for construction details is 1:20. Although larger scale ratios can be used to graphically convey a greater amount of technical information about the element.
The most commonly used scales are:
- 1:20 → a very common scale for construction details, suitable for wall, floor, roof, foundation, and window junctions.
- 1:10 → for more detailed representations, where it is necessary to accurately depict stratigraphies, joints, connections, and fastening systems.
- 1:5 → for complex construction details or junctions requiring a high level of precision, such as connections between windows and walls, waterproofing, roofs, and structural connections.
- 1:2 → used for very minute details, such as specific junction systems, profiles, fastenings, or special components.
- 1:1 → reserved for exceptionally detailed elements, when it is necessary to represent the element at full size.
What comprises a construction drawing detail
Construction details aim to provide a descriptive representation of the technical solutions adopted in constructing a building, architectural work, or infrastructure.
They are specifically used to graphically illustrate the functionalities and characteristics of various building components.
They can be classified into the following types:
- Structural details: provide accurate information about the structural components of a building, including foundations, beams, columns, load-bearing walls. As well as the necessary connections between these elements to ensure structural stability and strength. (such as metal joints, welded or bolted connections, precast connections and cast-in-place elements, etc.);
- Foundation details: focus on the construction characteristics of foundation elements (such as slabs, piles, footings, or inverted beams), specifying for each the type, dimensions, depth, materials, reinforcements, etc.;
- Wall details: illustrate how to construct internal and external building walls, providing useful information about material layering, thermal insulation as well as openings for doors, windows and structural connections;
- Roof details: provide detailed instructions on the installation of roofing elements, including support structures, drainage, waterproofing, thermal insulation, finishes, etc.;
- Systems details: illustrate how all building systems’ elements (mechanical, electrical, plumbing, or HVAC) should be installed, positioned and connected;
- Finishing details: illustrate how internal and external finishes will be applied, describing technical specifications of wall coverings, floors, ceilings and paints;
- Landscaping details: if the project includes landscaping elements, construction details can illustrate how to construct: retaining walls, paths, gardens, water features, plantings, etc.
Below are some examples of construction details produced with Edificius building design software.
What should construction details include
To ensure a building project’s correct execution, construction detailing must contain a series of information essentials.
Their objective is to fully define the various structure elements’ construction characteristics.
Therefore, these detailed representations should include useful information about the following aspects:
- Geometry and dimensions: construction details should report the geometric characteristics and actual construction components dimensions, such as lengths, widths, heights, thicknesses, angles, inclinations, and curves;
- Materials: construction details should specify construction project materials’ quality and types. Providing information on layering, finishing grades and any special requirements;
- Structural connections: detailed drawings should show how different parts connect and interact with each other through an accurate description of structure critical points, including joints, connections and various anchorages;
- Installation guidelines: construction details should graphically describe the procedures and techniques for installing or placing each component, as well as provide adequate instructions on how to assemble various building elements. Such as walls, roofs, floors, doors, windows, and mechanical systems;
- Safety: construction details can include safety information by describing technical specifications related to elements such as emergency stairs, parapets, handrails, fire safety systems, emergency exits and other components aimed at ensuring occupant safety;
- Regulatory compliance: construction details suggest technological solutions to ensure compliance with requirements outlined by existing technical regulations;
- Energy efficiency and sustainability: technical graphical representations provide accurate information about the construction elements performance and energy quality. Therefore describing characteristics and position of thermal-acoustic insulation, ventilation systems, waterproofing elements and so on.
The information provided by the construction details
Main types of construction details
Construction details represent a fundamental part of project documentation because they translate design choices into precise technical indications, useful for the realization of the work. They can concern the structure, foundations, building envelope, roofs, systems, and finishes, defining materials, stratigraphies, connection systems, and installation methods.
The type and level of detail depend on the nature and complexity of the intervention. Below are the main categories of construction details.
Structural details
Structural details describe the load-bearing elements of the building and their respective connections, providing the necessary information for their proper realization. They can involve beams, columns, floors, load-bearing walls, bracing, and structural nodes.
These drawings generally show dimensions, materials, reinforcement, connection systems, and assembly methods, allowing an understanding of how the different elements work together to ensure the stability and safety of the construction.
Foundation details
Foundation details illustrate the connection between the building and the ground and define the methods of realization for the elements intended to transfer loads to the soil. They can include continuous, raft, isolated, or deep foundations, depending on the project’s characteristics and the ground.
In construction details, the geometry of the elements, reinforcements, substrate layers, waterproofing, drainage, and connection systems with elevation structures are usually represented.
Wall details
Wall details show the composition and assembly methods of the building’s vertical envelope. They may involve load-bearing and non-load-bearing walls, concrete walls, dry systems, and layered or ventilated facades.
Particular attention is given to the succession of layers, thermal and acoustic insulations, vapor barriers, finishes, and junctions with floors, roofs, windows, and foundations. These details are fundamental for controlling the performance of the envelope and preventing thermal bridges and infiltrations.
Roof details
Roof details define the stratigraphy and construction systems used to realize the upper part of the building. They can involve flat, sloped, walkable, or non-walkable roofs.
The details may show the load-bearing structure, insulation and waterproofing layers, roofing cover, rainwater drainage systems, and junctions with parapets, skylights, chimneys, and other protruding elements.
Floor and pavement details
Floor and pavement details illustrate the composition of horizontal elements and the relationship between structure, substrates, and finishes. For example, concrete floors, prefabricated systems, or wooden and steel structures, along with the upper functional layers, are represented.
Particular attention may be given to thermal and acoustic insulation, systems integrated into the flooring package, joints, and junctions with walls and other construction elements.
Door and window details
Door and window details define the methods of inserting fixtures within the building envelope. They generally show the relationship between the frame, counter-frame, masonry, insulation, and internal and external finishes.
These details are essential to ensure proper water and air tightness and to limit the formation of thermal bridges. They may also specify materials, dimensions, fastening systems, thresholds, sills, and methods of connection with the wall’s stratigraphy.
MEP systems details
MEP system details (Mechanical, Electrical and Plumbing) concern the mechanical, electrical, and plumbing systems of the building. They include, for example, heating and ventilation networks, electrical systems, piping for water supply and drainage, and related components.
Construction details define the route and positioning of the networks, crossings of building elements, fastening systems, and junctions between systems and structures. Proper design of these nodes allows for coordination of systems with architecture and avoids interferences during construction.
Internal finish details
Internal finish details define how the environments are completed and the junction between different materials. They can involve floors, coverings, false ceilings, walls, baseboards, decorative elements, and other architectural components.
These details allow for specifying the sequence of layers, materials, thicknesses, installation systems, and joints, ensuring aesthetic continuity and proper execution of the different elements.
External arrangements and landscaping details
Details regarding external arrangements concern the spaces surrounding the building and their relationship with the construction. They can include external pavements, sidewalks, green areas, retaining walls, fences, drainage systems, and structures for managing rainwater.
Construction details define slopes, stratigraphies, materials, drainage systems, and junctions between paved surfaces, ground, and building. This way, they contribute to ensuring the durability of external works and proper integration between the building and the surrounding space.
Creating effective construction details
Creating a complex construction detail requires precision. That’s why 3D building design software represents a crucial step in this process.
Through these software platforms, it’s possible to create detailed graphical representations based on drawings extracted from your building 3D digital model, by defining parameters such as dimensions, materials, and technical specifications. The maximum precision offered by these software tools when setting construction details results in several undeniable advantages:
- Clear communication: effective construction details allow architects, engineers, builders and other industry professionals to communicate precisely how to construct each building component. This clarity minimizes misunderstandings as well as the possibility of errors during the construction phase;
- Dimensional precision: construction detail drawings provide accurate measurements for each project section. This precision is essential, ensuring that all components are correctly manufacture and install. Thereby avoiding structural or operational issues;
- Quality control: construction details define quality standards for each project element. During the production and installation phases you can use these standards to inspect and verify building components quality levels;
- Time and cost savings: a well-documented project, with accurate drawings, tends to incur fewer delays and additional costs due to errors or communication issues. Detail technical drawings help avoid last-minute changes, optimizing construction process;
- Effective maintenance: Upon project completion, construction detail drawings serve as valuable references for potential repairs and maintenance. By analyzing these detailed representations, industry operators can easily identify parts to be replace or repair;
- Legal protection: construction details are an important part of the legal documentation associated with a construction project. These documents can help obtaining necessary permits or resolving contractual disputes.
You can immediately test the benefits listed above through a 30 days building design software free trial version. Below is a tutorial providing technical guidelines on creating construction details.
FAQ
What are construction details?
Construction details, or detail drawings, are graphic elaborations that represent with a high level of depth the technical characteristics of the various components of a structure. They are part of the executive project documentation and provide information on construction techniques and the necessary methods for executing specific parts of the building work.
What is the minimum recommended scale for construction details?
The minimum recommended representation scale for construction details is 1:20. Depending on the level of detail required, larger scales such as 1:10, 1:5, 1:2, and, for exceptionally detailed particulars, in rare cases, 1:1 may be used.
What are the main types of construction details?
The main types include structural details, foundation details, wall details, roof details, floor and pavement details, door and window details, MEP system details, interior finish details, and details of external arrangements and landscaping.
What information should construction details contain?
Construction details should comprehensively define the characteristics of building elements, including information related to geometry and dimensions, materials, structural connections, installation methodologies, safety, regulatory compliance, energy efficiency, and sustainability.
How to create effective construction details?
Creating effective construction details requires precision and can be supported by the use of 3D building design software. These tools allow for the creation of detailed graphic elaborations from the 3D digital model of the building, defining dimensions, materials, and technical specifications.
What are the advantages of construction details?
Construction details promote clear communication among professionals, improve dimensional accuracy and quality control, help reduce construction time and costs, and provide a useful reference for maintenance and potential repairs. They also constitute an important part of the legal documentation associated with the project.
