From BIM to BOS: Evolving Building Management Tools
The transition from BIM to BOS represents a significant turning point for the development of smart buildings. Let's discover what it means and why it is important
Have you heard of BOS?
The Building Operating System (BOS) represents the next evolution of BIM, designed to meet the demands of next-generation buildings.
Let’s explore how BOS builds on BIM to transform the construction industry.
- From BIM to BOS: what it means and why it is essential for smart buildings
- What is the BOS (Building Operating System)
- BIM and BOS: what changes and how they integrate
- The advantages of BOS in smart buildings
- How the BOS transforms the user experience of the building
- What functions can a Building Operating System manage
- BOS as a dynamic database: the connection with BIM
- The skills required in the transition from BIM to BOS
- FAQ: BOS in BIM
In the rapidly evolving landscape of construction technology, we’re witnessing a profound transition from static digital models to living, breathing architectural ecosystems. The Building Operating System (BOS) isn’t just an incremental upgrade—it’s a radical reimagining of how we conceive, interact with, and inhabit built environments.
Traditional Building Information Modeling (BIM) is an approach, primarily concerned with design documentation and project lifecycle management. In contrast, BOS represents an intelligent, interconnected framework where buildings transcend their physical constraints, becoming dynamic entities capable of learning, adapting, and responding to their inhabitants’ needs, integrating data from the information model, systems, and IoT.
The Building Operating System is a software infrastructure that acts as an intermediary layer between the physical systems of the building (systems, sensors, IoT devices) and the applications that provide services to users. It is comparable to the operating system of a computer: it does not directly execute the functions of the building, but manages interactions, data access, and service coordination.
The purpose of the BOS is to connect all the apps that govern the automated systems of a smart building (heating, alarm system, video surveillance, appliances, lights, etc.), in order to help the user keep everything under control, simply.
BIM and BOS
Smart buildings are today a new benchmark in the construction market and undoubtedly represent a rapidly growing sector. They are buildings that include automated systems and offer a range of services for owners, users, and operators. Nowadays, smart buildings are discussed in relation to office buildings, hospitals, supermarkets, museums, but it is a technology that is increasingly entering daily and domestic life as well.
The BOS transforms buildings into a true scalable digital platform that provides real added value for users.
Its innovative power is based on three things:
- visualization;
- openness;
- scalability.
Directly connected to BIM, this “operating system” for smart buildings provides a graphical and intuitive access to data.
This implies, for example, that the lighting system of a specific office, located in an extensive complex of buildings dedicated to tertiary activities, can be immediately identified and managed remotely, in real-time.
Whether it concerns infrastructures, computerized maintenance management systems, BIM, building management systems, IoT, or service applications aimed at building users, it is necessary to establish a common and shared language.
The concept of BOS aims to transform the relationship between the building and its users. Let’s take an example.
Think about how Amazon works, which has built its success by analyzing the habits and behaviors of its users to refine its offerings. Similarly, BOS improves the building based on what is highlighted by the uses of its occupants.
This learning process simplifies the correction of malfunctions detected by users and provides useful information for creating new services tailored to their needs.
This modus operandi could become a key differentiating factor in the real estate market and facilitate the development of smart buildings and smart cities.
The added value, in fact, translates into the simplification of many common actions such as managing:
- lighting;
- temperature;
- air quality;
- communication with applications external to the building;
- maintenance;
- updating applications;
- etc.
In short, BOS acts as an open and dynamic database that can be modified in real-time, linking BIM data with other data sources of the building.
Certainly, to design and create buildings equipped with self-learning services, and consequently scalable based on customized needs, it will be necessary to integrate new areas of expertise in architecture, data interpretation, management, maintenance, and cybersecurity for infrastructures. There will be an increasing need to use BIM management systems and to manage the realization and maintenance of a work in a digitized manner.
A central platform for managing smart buildings
The BOS is configured as a centralized integration platform that collects data from heterogeneous sources, normalizes it, and makes it available for management, maintenance, energy management, and user services applications. This centralization simplifies the management of the technical complexity typical of smart buildings, reducing information silos.
BOS as a communication system between apps and devices of the smart building
The BOS is a communication framework that connects applications and devices through standardized APIs. It ensures that each application can communicate with any compatible system, overcoming the traditional barriers posed by the closed protocols of building automation.
The integration between BIM and BOS represents the transition from a static information model to a dynamic digital ecosystem. While BIM is fundamental in the design and construction phases, BOS comes into play in operational management, greatly expanding the value of data and making the birth of the digital twin possible.
The role of BIM as the data repository of the digital building
BIM represents the structured archive of the building’s information heritage: geometries, components, relationships, and technical data. This database is essential for creating a semantic map that the BOS will use to navigate and interpret the building.
The BOS as the operational evolution of the BIM model
The BOS connects BIM data to the operational reality: systems, IoT, environmental sensors. Thanks to this integration, the information model becomes a living tool, constantly updated and used to automate functions and optimize performance.
Why smart buildings require a transition from BIM to BOS
Modern buildings must be able to interact with users, adapt to external conditions, and optimize consumption and comfort in real-time. This requires an operational layer that BIM is not designed to provide. The BOS fills this gap, making the building truly intelligent.
The BOS brings a series of benefits that go beyond simple automation of systems. It introduces a data-driven approach that allows the building to become a digital and scalable platform, capable of evolving over time and accommodating new services.
Real-time data visualization
The BOS offers advanced dashboards that allow monitoring of consumption, environmental parameters, and the status of systems. Real-time information supports quick decisions and energy optimization strategies.
Data openness and interoperability
Thanks to open standards and APIs, the BOS enables bidirectional communication between systems from different brands. This reduces the risk of technological lock-in and promotes the continuous evolution of the building.
Service scalability and user customization
The BOS allows for the easy addition of new services, adapting to future needs. At the same time, it accesses user data to customize lighting, comfort, bookings, and other building experience services.
The user becomes the true protagonist of the smart building. Thanks to the BOS, the building is no longer a static environment, but a system that interacts with occupants, recognizes them, and learns from their habits to offer tailored services.
From behavior analysis to the building’s self-learning
Using machine learning algorithms and real-time collected data, the BOS can adapt environmental parameters based on user behaviors and needs, improving comfort and productivity.
New services based on user data
The BOS enables functions such as space booking, indoor wayfinding, smart parking management, personalized assistance, and advanced mobile interfaces. The building becomes a true service-environment.
The BOS does not replace automation systems but coordinates them at a higher level, making them interoperable. The manageable functions are numerous and expanding, thanks to the increasing integration with IoT and cloud services.
Lighting
Intelligent management of light levels based on presence, schedules, natural brightness, and personal preferences.
Temperature and air quality
HVAC control, air quality monitoring, and automatic adjustment of environmental parameters to ensure comfort and healthiness.
Maintenance and application management
The BOS enables predictive maintenance strategies, integrating with CAFM/CMMS platforms and detecting anomalies in systems.
Integration with IoT systems and external services
Access systems, security, widespread sensors, cloud platforms, and third-party applications can be integrated seamlessly.
The synergy between BIM and BOS allows the creation of an operational digital twin, which combines static structure and dynamic data. The result is a living and constantly updated model.
BIM data as the informational basis for the BOS
The BOS uses BIM as the primary informational structure, leveraging its hierarchical and semantic organization to contextualize operational data.
Integration with sensors, IoT, and building automation systems
By linking BIM to real-time data, the BOS transforms the model into an operational tool capable of reflecting the actual state of the building.
Real-time updates and operational digital twins
The union between BIM and BOS generates a digital twin that replicates the behavior of the building, allowing for simulations, predictive maintenance, and continuous optimization.
The evolution towards smart buildings requires new professional skills that combine technical, IT, and management know-how. The professional must understand both the structure of the BIM model and the operational logic of connected systems.
Data interpretation and information management
Being able to read, correlate, and structure data is essential to properly feed the BOS and ensure informational consistency throughout the life cycle.
Cybersecurity for smart infrastructures
Cybersecurity becomes a central element: it is necessary to protect networks, devices, and data from vulnerabilities and unauthorized access.
The role of BIM management systems in BOS management
BIM management systems evolve to communicate with the BOS, control data quality, and ensure alignment between the model and the operational reality of the building.
FAQ: BOS in BIM
What is the BOS (Building Operating System)?
The BOS is a software infrastructure that connects the physical systems of the building (systems, sensors, IoT devices) to the applications that provide services to users, coordinating interactions and access to data.
What is the purpose of the BOS?
The BOS connects all the apps of the automated systems of the smart building, simplifying the control of heating, alarms, video surveillance, lights, and other devices.
How does the BOS integrate with BIM?
BIM provides the structured data repository of the building. The BOS uses this data and connects it in real-time with systems, sensors, and IoT, transforming the static model into a dynamic digital ecosystem and creating an operational digital twin.
How does it improve the user experience?
The BOS allows the building to learn from user habits and offer personalized services, such as intelligent management of lighting, temperature, air quality, and space bookings.
What functions can a BOS manage?
It manages lighting, temperature and air control, predictive maintenance, application management, integration with IoT systems and external services, coordinating systems in an interoperable manner.
What advantages does the BOS offer?
Real-time data visualization, openness and interoperability of systems, scalability of services, and customization for users. It transforms the building into an evolving digital platform, optimizing consumption, comfort, and maintenance.
What skills are needed to transition from BIM to BOS?
Technical, IT, and management skills are required, along with the ability to interpret data, ensure cybersecurity, and integrate BIM management systems with the BOS to align the digital model with operational reality.
