How to Use Texture in Interior Design: A Guide for Designers
From the sensoriality of materials to the use of AI: a guide on how to use texture in interior design for unique and characterful spaces
In interior design, texture is one of the least obvious yet most decisive tools for shaping, depth, and character in a space. It is not just an aesthetic matter: good management of textures can influence the perception of space, living comfort, and even the behavior of light and sound. For professionals involved in interior design, understanding the different types of texture and knowing how to integrate them coherently is essential for achieving high-quality, functional, and engaging results.
In this comprehensive guide, aimed at designers, we explore what texture is in interior design, how to use it strategically, and what innovative tools – such as artificial intelligence – can simplify and enhance the creative process.
- What is texture in interior design
- Types of texture and their applications
- Techniques for Integrating Texture in Spaces
- Customize Spaces with Artificial Intelligence: Experiment with Different Textures and Styles in Real Time
- Practical tips for using texture in interior design
- Common mistakes to avoid when using textures
- Frequently asked questions about texture in interior design
To properly address the topic of texture in interior design, it is essential to clarify what this term means and how it manifests in materials and spaces. Understanding the difference between visually perceived textures and tactile ones is the first step in designing coherent, welcoming, and functional environments.
Visual texture vs tactile texture
Visual texture is what is perceived with the eye. It can be created by patterns, colors, designs, or graphic simulations that give depth and three-dimensionality even to completely smooth surfaces.
Tactile texture is what is perceivable to the touch, and it is related to the actual materiality of the materials. It can be smooth, rough, soft, grainy, and adds an additional sensory dimension to the environment.
Texture interior design | Image created with usBIM.codesign AI
Why texture is fundamental in design
Texture is not just a decorative element. It is a true design tool that helps create rhythm, contrast, and identity. Additionally, it influences practical aspects such as light perception, the acoustics of spaces, and the definition of functional areas.
Once the importance of texture is understood, it is necessary to know the main categories and understand in which situations and ways each can be applied. Below, we analyze natural, artificial, and decorative textures.
Natural textures
Natural textures derive from authentic and unprocessed materials such as wood, stone, linen, or leather. Their strength lies in the imperfection and the sense of authenticity they convey, making the environment warmer and more human.
Natural textures interior design | Image created with usBIM.codesign AI
Artificial Textures
Artificial Textures are generated from industrial materials, mechanical processes, or synthetic composites. They allow for sophisticated visual effects, durability over time, and greater resistance to stress, stains, and wear.
Decorative and Visual Textures
Decorative and Visual Textures are often used on flat surfaces or through graphic treatments. They are applied through wallpapers, decorative panels, special paints, or printed coatings to provide dynamism and visual variety without altering the actual material surface.
Integrating texture into an interior design project requires a clear strategy. There are established techniques that allow for effective integration, enhancing materials and surfaces. Let’s explore some of them.
Layering Materials
Layering involves the overlapping or adjacent use of materials with different textures. This technique adds visual depth and creates complex material narratives that enrich the identity of the space.
Read also How to use materials for modern interior design.
Surface Contrasts
The Contrast between surfaces – for example, between matte and glossy, rough and smooth – allows for the creation of visual focal points and defines functional areas. It is a useful technique for generating rhythm and guiding the eye through the environment.
Furniture and Accessories with Texture
Not all textures need to be architectural. Very often, furniture, fabrics, lamps, or paintings can introduce significant textures, completing the sensory palette of the environment and increasing personalization.
Digital innovation has introduced new tools for designers. Thanks to artificial intelligence, it is now possible to simulate the application of different textures in an environment in real time, with a surprising level of realism and rapid response times.
Read the article How to use AI in architectural design and interior design: boosting efficiency and creativity.
Texture interior design | Rendered image with usBIM.codesign AI
AI architecture generator free for 7 days.
What is an AI generator for interior design
An AI generator like usBIM.codesign AI allows you to create, visualize, and modify interior environments by realistically simulating materials, furnishings, and textures. Starting from a project image, even if it’s not very detailed, the tool generates coherent visual proposals, offering the designer immediate inspiration and new stylistic solutions.
usBIM.codesign.AI allows you to:
- apply different textures to walls, floors, ceilings;
- simulate coverings and upholstery on sofas, seats, curtains;
- visualize the overall effect of the environment in real-time;
- save proposals for mood boards or client presentations.
The main advantages of using AI are:
- speed in testing many options,
- inspiration through innovative proposals,
- high graphic realism for professional presentations,
- customization of the result according to design briefs.
Read also Guide to lighting for interior design: ideas, principles, and solutions with AI.
Integrating texture correctly requires sensitivity and method. In this section, we propose some practical guidelines to enhance every space without risking inconsistencies or design errors.
Consistency with the style of the environment
Every texture must interact with the overall style of the project. Minimalism, industrial style, classic, or rustic: each language has its own material codes and the right textures to choose from to maintain overall harmony.
Evaluate maintenance and functionality
The choice of textures should not compromise functionality. Some rough materials can trap dust, while others may degrade in humid or busy environments. It is essential to also consider long-term maintenance.
Accessible and budget-friendly ideas
Textures can also be introduced in low-budget projects. There are economical yet effective solutions such as vinyl coverings, shaped MDF panels, textiles with material prints, and high-visual-impact adhesive finishes.
Incorrect use of texture can compromise the effectiveness of the project. In this section, we highlight some frequent mistakes to avoid.
- Visual overload
Using too many textures in a single environment creates confusion and distracts the user. It is preferable to focus on one or two dominant materials to accompany with other more neutral elements. - Inconsistency between materials and styles
The disorderly use of textures belonging to different styles can compromise the identity of the space. Consistency should guide every material choice. - Ignoring light and spatial perception
The chosen textures affect light reflection and the volumetric perception of the environment. Dark or overly pronounced textures can make a space feel smaller and gloomier.
What is texture in an interior project?
Texture is the visual or tactile aspect of a surface. In an interior project, it is used to give depth, rhythm, and identity to the space, also influencing light perception and the comfort of the environment.
What is the difference between visual texture and tactile texture?
Visual texture is perceivable by sight and is often achieved with graphic patterns, while tactile texture is felt by touch and is related to the materiality of materials, such as the roughness of a stone or the softness of a fabric.
How can I use texture without compromising the coherence of the project?
It is important to choose textures that are consistent with the overall style of the environment, limit the number of dominant materials, and use targeted contrasts to highlight focal points or functional areas.
Are there digital tools to test textures before implementation?
Yes, AI-based solutions like usBIM.codesign AI allow you to visualize in real-time how spaces change based on the textures applied to surfaces, furnishings, and textiles.
Do textures influence the acoustics and light of a space?
Absolutely. Soft or porous materials improve sound absorption, while reflective or textured surfaces can modify light diffusion, making the environment feel warmer or more technical.
