Integrating Point Clouds in GIS: A New Frontier for Spatial Analysis
Discover how the integration of point cloud and GIS is revolutionizing spatial analysis with advanced applications in urban planning, engineering, and environmental management
In the rapidly evolving landscape of geospatial technologies, the integration of point clouds into GIS (Geographic Information Systems) represents a significant breakthrough. Point clouds are sets of three-dimensional data that describe the surface of an object or area through individual points with specific coordinates. These point clouds are primarily obtained through laser scanning techniques (LiDAR) or aerial photogrammetry, providing a detailed and accurate representation of the real world.
The use of specific BIS GIS software allows for the integration of GIS maps with 3D models, openBIM models, textured meshes, and point clouds, enabling the simultaneous management of a large amount of information from various disciplinary fields within a single scene.
- What is a point cloud?
- Advanced Techniques for Point Cloud Data Acquisition
- Step-by-Step Guide to Integrating Point Cloud Data with GIS Platforms
- Real-World Case Studies: Point Cloud Data Applications in GIS
- The Future of Point Cloud GIS: Trends and Innovations
- Comprehensive Resource Guide for Point Cloud GIS Professionals
Before moving on to the integration of GIS and point clouds, it is certainly useful to have a clear overview of what a point cloud is. Let’s take a look together!
Point clouds are a set of points in digital space, identified by their unique position in an X, Y, and Z coordinate system and acquired through:
- 3D laser scanning survey / LiDAR (Light Detection and Ranging) – uses laser pulses to measure precise distances from the source (usually an airplane or drone) to the ground surface. This method produces high-resolution data that can capture minute details of the terrain and structures;
- photogrammetry: involves the use of photographic images to create three-dimensional maps. Overlapping images taken from different angles are processed to extract spatial coordinates, thus generating a point cloud.
The point cloud generated in this way constitutes a very accurate representation (the accuracy will depend on the number of points acquired), useful as a starting point for creating:
- the 3D model of the surveyed object;
- the BIM model directly from the point cloud.
Point cloud
When we integrate GIS with point clouds and 3D/BIM models, this expands the scope of use of the model itself and allows us to create Geospatial Digital Twins and Smart Cities, that is, IFC/openBIM® models, BIM/3D, point clouds, textured meshes, etc., geolocated and integrated with GIS.
Other important uses that derive from the synergistic integration between openBIM and GIS are:
- precision mapping: point clouds provide high-resolution data that improve the accuracy of topographic and thematic maps. This is particularly useful for urban planning, civil engineering, and natural resource management;
- environmental monitoring: the ability to detect changes in land, vegetation, watercourses, etc., allows for monitoring soil erosion, sediment accumulation, and other environmental phenomena with unprecedented precision;
- infrastructure management: point clouds can be used to inspect and manage critical infrastructure such as bridges, roads, and electrical networks, identifying damage and degradation with high precision;
- archaeology and cultural heritage conservation: point clouds allow for the creation of detailed models of archaeological sites and monuments, facilitating documentation and digital preservation;
- asset management: for the maintenance and management of assets over time.
These are just a few examples of the multiple uses and fields of application of the integration between point clouds and GIS. Thanks to their ability to provide detailed and three-dimensional data, point clouds are becoming increasingly essential for a wide range of sectors and disciplines that require precise and in-depth spatial analysis.
If you want to learn more, read also Pointcloud to BIM to discover how to create a 3D BIM model directly from the point cloud, leveraging the automation of a point cloud to BIM software.
In the previous paragraph, we mentioned the main techniques for acquiring point clouds, which can have varying degrees of accuracy that can be predetermined during the survey setup and depend on the uses we will make of the point cloud as well as the techniques we will use for its acquisition. Let’s explore together the most advanced techniques that the dynamic world of technology offers us, in addition to the already mentioned LiDAR and photogrammetry:
- 3D scanning with structured light: based on the use of specific scanners that allow for 3D digitization of objects, reconstructing their geometry through the projection of coded light patterns. One or more cameras capture images of how the structured light deforms when projected onto the surfaces of objects. These data are transformed into 3D coordinates through triangulation algorithms. This technique is primarily applied in industrial design and reverse engineering;
- Time-of-Flight cameras: Time of Flight is an imaging technique that uses modulated light sources to illuminate the object. The position is determined by the travel time of a light pulse sent from the emitter and its return to the sensor after being reflected by an object. By using this temporal information, it is possible to accurately calculate the distance between the object and the sensor, allowing for the creation of detailed three-dimensional images. It finds extensive application especially in robotics;
- Multibeam Echo Sounder (MBES): this is a complex system composed of multiple sensors that applies the principles of acoustic reflection, scattering, and acoustic interferometry to create bathymetric data that measure depth and allow for the processing of a cartographic survey of the seabed. It is used in marine surveys and for extremely precise mapping of the seabed for geological, archaeological, or research/recovery inspections. More recently, it has also been used to monitor gas pipelines, underwater cables, and offshore wind farms.
The acquisition of point clouds, through one or the integration of multiple techniques from the previous paragraph, does not automatically reference any real-world coordinates. This means that once the point cloud is acquired, it will be our responsibility to correctly integrate the 3D/BIM models with BIM-GIS platforms.
To georeference our models, there are three methods, each of which automatically adjusts the orientation and position of the point cloud to the appropriate coordinate system without causing alterations in shape, size, or scale. Let’s explore these three methods together:
- georeferencing lidar point clouds using Ground Control Points (GCPs): Ground Control Points (GCPs) are points on the ground with known coordinates that are used to link the photogrammetric survey to real dimensions and orientation. In the operational reality of the survey, GCPs are made visible by high-contrast markers, highly recognizable objects that are appropriately fixed to the ground in points always visible from above. Through specific instrumentation (total station, GPS rod, or other surveying tools), the coordinates of the GCP identified by the marker are recorded;
- alignment of lidar point clouds to already georeferenced building models or drawings: this second method, slightly more empirical than the first, consists of aligning the not yet georeferenced point cloud to project data that are already georeferenced. In this case, it will be necessary to open the georeferenced model through our BIM-GIS software and align the new point cloud to the already oriented and positioned model using known reference points;
- registration of a point cloud to a pre-existing geolocated one: this method further simplifies the process. If there is already a georeferenced point cloud for the site, it is possible to register and georeference the new point cloud by referencing this.
Overcoming Technical Challenges in Point Cloud GIS Integration
The integration between point clouds and GIS is now possible, but this does not mean that there are no technical challenges to overcome. Let’s look at the main ones together:
- collection of precise and reliable spatial data: issues such as poor signal quality, low battery, incompatible formats, or missing attributes can arise. To overcome these challenges, careful planning of data collection is necessary, along with the use of appropriate methods and tools. For example, mobile applications that work offline and sync data when online can be used, solar chargers or backup batteries to extend battery life, standard formats and metadata to ensure data compatibility, and quality control procedures to verify and correct data errors;
- data analysis and visualization: this technical issue may manifest as low-quality maps or the use of symbols and colors that are not suitable for the map’s intended use. To bridge this gap, effective design and communication principles and practices must be employed. For example, it will be helpful to use high-resolution images or base maps, clear and consistent symbols or colors, labels or captions to explain map elements, or interactive or multimedia features to enhance the map experience;
- management and storage of territorial data: this challenge may involve loss, theft, or corruption of data, duplication or inconsistency, or data privacy management. To overcome these challenges, reliable and secure data management and storage systems and policies must be used, such as cloud storage to prevent data loss or damage, data standards or protocols to ensure data consistency or quality, or encryption or passwords to protect data privacy and security;
- static data integration: another possible limitation of the technologies currently adopted for the digitization of constructions is the static integration of data between BIM and GIS systems, which poses numerous limitations in the management of digital twins. To address this technical challenge, it is essential to refer to management platforms for geospatial digital twins that operate based on a dynamic and bidirectional integration between the openBIM® system and the GIS system.
- management and sharing of complex projects: the enormous volume of data is the biggest problem when combining the details of BIM, with all the information of each construction object, with the territorial scale view of GIS. However, this challenge can also be overcome by using the right tools that ensure all BIM information is always available to GIS for spatial queries without any limits on number and size.
We have anticipated that the integration between BIM and GIS allows for addressing design and management challenges of buildings and infrastructure in a completely avant-garde manner. To better understand what we are talking about, let’s look at some real case studies, in Italy and around the world:
- Geospatial Digital Twin for a Smart City project in Milan: the project involved three-dimensional surveying, the acquisition of point clouds of infrastructures and buildings in central Milan, including the stadium with a cloud of 2.6 million points, the processing of IFC models, and their subsequent integration with GIS maps to derive geospatial information;
- GIS Asset Management – case study of a shopping center: in this case, the openBIM IFC model of the shopping center is integrated into a geospatial context, allowing for detailed analysis of resources within the surrounding environment;
- OpenBIM and GIS in archaeology: benefits and applications to the ancient city of Pompeii: the integration between GIS, digital surveys with point clouds, and BIM models has allowed for a detailed and immersive visualization of the entire archaeological park, offering new perspectives on the conservation and study of Pompeian “domus”.
- El Jadida – Morocco: the integration between openBIM and GIS has yielded extraordinary results regarding the modeling of historical cities. As an emblematic case study, we report the digitalization of the city of El Jadida, Morocco, whose model is particularly useful for urban planning of the city.
- Barcelona: in this case, the IFC model of the Metropolitan Area of Barcelona (AMB) has been integrated with GIS platforms to optimize city management.
Geospatial digital twin – the case study Smart city in Milan
The challenges of integrating GIS and point clouds can be overcome by using the right technological tools. In fact, by working with advanced online applications, many of the stated challenges no longer pose an obstacle. With cloud tools, for example, there is no need for specialized data processing software or tools for conversion and compatibility between formats (GIS and point clouds) or desktop storage space.
For example, the technology of usBIM.geotwin allows you to insert not only openBIM 3D models in open and proprietary formats into a GIS scene but also surveys and point clouds in the most common formats currently available on the market. These models inserted into the scene interact with everything else and are not just simple mockups. In fact, it is possible to perform various actions such as taking measurements directly on models present in the scene or generating sections of 3D models in real-time to visualize the interiors of buildings and conduct detailed analyses at different scales.
The GIS map, therefore, is enriched with informative models and surveys that are also very extensive in space, such as linear infrastructures (railways, overhead lines, etc.), railway stations, tunnels, bridges, etc. Working with large-scale models remains a smooth and efficient operation with accurate and realistic visualization.
Models can always be updated and modified without the need to resort to BIM authoring, directly with online applications for editing IFC files.
The integration is complete because it allows you to visualize in a single map openBIM 3D models, surveys with textured meshes, and point clouds. Moreover, the information related on the map is not only geometric but also informative.
In summary, using usBIM.geotwin, you can:
- manage IFC/openBIM models, BIM/3D, point clouds, textured meshes, etc.;
- load complex models into a single working environment;
- geolocate models and integrate them perfectly with GIS;
- create extraordinary Geospatial Digital Twins;
- operate without limits on complexity, number, and continuous data updates.
The future of point clouds in GIS appears promising, therefore, with continuous technological advancements that reduce costs and improve accessibility. Integration with emerging technologies such as artificial intelligence and machine learning promises to further automate and enhance data analysis, paving the way for new innovative applications.
To learn more, read also: Spatial Data Analysis in GIS: Techniques, Applications, and Benefits
The professions connected to the world of GIS are numerous and constantly evolving, just as the dynamic world of technology evolves, seeing BIM interact with GIS. Those working within the GIS world and interfacing with the management of point clouds and subsequent BIM model processing know that the necessary steps to follow are:
- data collection and management: we know that in GIS, data is the essential information for processing maps and models and understanding their relationships. To best manage this phase, it will clearly be necessary to rely on appropriate surveying tools and suitable editing and management software;
- choose the right tools: when starting to work in this field, the choice of software may seem marginal, but not all software is the same, and it is necessary to pay attention to factors such as the amount of data that the BIM-GIS software can manage and the dynamic and bidirectional integration between the openBIM® system and the GIS;
- map design and visualization: map design is a more than essential step in the GIS Point Cloud world because it is through them that we transfer information that must be as accessible and understandable as possible. Therefore, a balanced choice of colors and icons will be important;
- spatial analysis techniques: spatial analysis is where the real magic happens in GIS. It allows us to discover patterns and relationships between our data through the careful design made in the previous step;
- integration of GIS with other technologies: integrating openBIM 3D models, textured meshes, and point clouds on GIS maps allows for the simultaneous management, in a single scene, of a large amount of information derived from different disciplinary fields.
As GIS professionals, the use of point clouds is more than frequent and necessary. Point clouds are used to create 3D models of landscapes, cities and buildings, ground surface, for underwater surveys, to monitor environmental changes over time such as deforestation or glacial melting, and for geospatial analyses of various types. The advantages of integrating point clouds and GIS are therefore numerous, including:
- accuracy and detail: point clouds offer an extremely detailed representation of the real world, useful for precise and in-depth analyses;
- efficiency: data collection through LiDAR and photogrammetry, or other advanced techniques, can cover large areas in relatively short times compared to traditional methods;
- integration with other GIS data: point clouds can be easily integrated with other GIS data layers, enriching spatial analyses.
In conclusion, point clouds represent a crucial component for the future of GIS systems. Their ability to provide detailed and precise data is revolutionizing the way we interpret and interact with spatial information, offering new opportunities for research, planning, and resource management.
Here is a short video of usBIM.geotwin with practical applications and case studies of point cloud and GIS management.
