Virtual Renovation: How Digital Remodeling Works for Properties
Virtual renovation with artificial intelligence: rapid, photorealistic digital renovations integrated into BIM workflows
Thanks to 3D rendering, augmented/virtual reality, and especially artificial intelligence, it is now possible to transform floor plans, photos, and BIM models into photorealistic, customized, and immediately usable environments. Solutions like the AI architecture generators allow for faster design, improved communication with clients, and increased perceived value of properties, simplifying decision-making processes and reducing presentation times and costs.
In this article, we will analyze what Virtual renovation is, the main use cases, the differences with Virtual staging, and the technological tools that are changing the way we design, sell, and enhance properties and interiors.
Bedroom in minimalist style generated with usBIM.codesign AI
What is Virtual renovation and why is it revolutionizing the real estate sector
Virtual renovation, or virtual restructuring, is a technology that allows for the digital simulation of renovation interventions on a property. Thanks to 3D modeling software and virtual reality, it is possible to modify both interior and exterior spaces by adding or removing walls, changing floors, fixtures, coverings, and even redesigning the layout of the rooms.
For professionals in the construction sector, this innovation represents a strategic tool: it allows them to showcase the future potential of a building, enhancing dated or under-construction properties without the need for physical work.
The revolution lies in the ability to streamline sales and design processes, reduce preliminary costs, and offer clients an immersive experience that can transform a simple visit into a true journey inside the renovated property.
Real examples of Virtual renovation for houses and apartments
A typical example of virtual renovation is the transformation of a 1970s apartment with poorly functional spaces, characterized by the typical floor plan with a long central corridor leading to various rooms.
With digital simulation, the walls separating the kitchen and living room can be removed to create a modern open space, the old floor replaced with parquet, and the bathroom completely redesigned with contemporary finishes.
In its original state, the entrance opened directly onto the short side of the corridor: on the left side were the kitchen with a kitchenette, bathroom, and a bedroom, while on the opposite side were the living room, dining room, and the second bedroom. Each room was thus functionally isolated from the others, without a real connection between the spaces.
The design intervention aimed to adapt the home to the contemporary needs of an average family, restoring greater fluidity and functionality to the internal layout. The living area was completely redesigned, transforming it into a single open space that integrates the living and dining areas. The eat-in kitchen opens onto this area through a large sliding glass door, which ensures brightness and visual continuity but also allows for functional separation when needed. The corridor was minimized and turned into a space equipped with bookshelves and coat racks, thus recovering useful surface area.
The sleeping area remained separate from the living area, retaining the two original bedrooms but improving their functionality through the introduction of a walk-in closet and a master bathroom.
If you want to delve deeper into the topic of building renovation, I recommend reading the article “Guide to the apartment renovation project.”
Other common cases include:
- the redevelopment of an attic into a livable loft with exposed beams and new openings;
- the virtual addition of a veranda or extension to show how to increase the square footage of a single-family home;
- the modernization of a building’s facade, with thermal insulation, new balconies, and updated colors.
For architects and technicians, this means being able to illustrate different design hypotheses quickly, without the limitations of traditional representations, making the dialogue with clients and investors clearer and more engaging.
Kitchen with island | Render created with usBIM.codesign AI
Differences between Virtual renovation and Virtual staging
Although often confused, Virtual renovation and Virtual staging have different objectives:
- Virtual renovation – intervenes on the structural elements and finishes of a property. It allows for modifications to walls, floors, ceilings, openings, and internal distribution, showing how a space could transform after a complete renovation. It is the ideal tool for properties that need renovation or are under construction.
- Virtual staging – exclusively concerns the digital furnishing and decoration of existing spaces. It does not modify the structure of the property but virtually adds furniture, accessories, and decorations to make empty or dull rooms more inviting.
When to use Virtual renovation: use cases and advantages
Virtual renovation represents a strategic solution in various scenarios within the real estate and construction sectors. It is particularly beneficial when it is necessary to enhance an outdated property or one under construction, showcasing its potential in advance without having to undertake actual work. This approach helps overcome clients’ difficulties in visualizing the final result, reducing time and costs associated with physical renovations or temporary setups.
The main use cases include:
- properties to renovate – dated houses or apartments with obsolete finishes can be shown as already renovated, increasing buyer interest;
- empty or vacant properties – digital simulation makes them more appealing without incurring the costs of physical renovation;
- complex layouts – helps propose new internal distributions, such as open spaces or additional rooms, clearly demonstrating the potential for transformation;
- increased perceived value – a property presented with a virtual renovation appears more competitive on the market, facilitating a quicker sale or rental.
For technical professionals, the advantages translate into design flexibility, resource savings, and improved communication with clients and investors.
Virtual renovation for construction renovation projects
In the context of construction renovation, Virtual renovation becomes a powerful tool to support design and communication. Architects, engineers, and surveyors can use this technology not only to preview changes in the preliminary phases but also to leverage numerous advantages such as:
- accurate planning – allows for simulating design variations and identifying technical issues before starting the construction site, optimizing time and costs;
- client engagement – clients can experience an immersive journey through virtual tours, visualizing materials, colors, and solutions in real-time;
- multidisciplinary collaboration – sharing the project in a digital environment facilitates coordination among different stakeholders (architects, engineers, interior designers, real estate agents).
Tools and Technologies for Virtual Renovation: From Rendering to AI
Virtual renovation is based on an ecosystem of digital tools that combine photorealistic rendering, immersive reality, and artificial intelligence. 3D modeling and rendering software represent the starting point: they allow for the digital reconstruction of the property and the application of textures, materials, and lighting to achieve high-fidelity visualizations.
Alongside these tools, real-time visualization engines enable the creation of interactive navigations where the client can explore the virtual space, modify finishes, and simulate different design configurations.
Augmented reality (AR) and virtual reality (VR) technologies further expand the possibilities: with dedicated headsets or simple smartphones, it is possible to “enter” the renovated environments or overlay digital furnishings onto real spaces, making the experience immersive and engaging.
Today, however, the real leap in quality comes from artificial intelligence, which allows for the automation of much of the process and the generation of design solutions in extremely short times.
Artificial Intelligence and Automatic Generation of Virtual Environments
AI applied to virtual renovation represents a design breakthrough today: from the instant generation of virtual environments to the complete customization of design. In particular, AI architecture generators are true “co-designers,” capable of transforming sketches, photos, or 3D models into architectural concepts and photorealistic renders in record time.
The key features of these tools can be summarized as follows:
- flexible inputs – simply upload hand-drawn sketches, photographs, screenshots of BIM or 3D models (e.g., from Revit, SketchUp, Rhino, Edificius, or AutoCAD) to obtain high-quality renders in seconds;
- user-driven styles and customizations – it is possible to choose from different architectural styles (modern, industrial, classic, minimal, etc.) or upload reference images to guide the desired atmosphere. Alternatively, just type a text prompt (“minimal interior with wooden floor and large window”) to achieve the desired result;
- automatic enrichment of environments – it is possible to autonomously add elements such as furnishings, lighting, and decorations, respecting the original geometry and openings of the model. These are powerful tools for virtual staging, perfect for real estate presentations or renovated interiors;
- BIM workflow plugins – there are versions integrated directly within the main software (Revit, SketchUp, Rhino, Edificius, usBIM, etc.), allowing for the generation of photorealistic visualizations without ever leaving the design environment. One can intervene in real-time on materials, light, and architectural styles, regenerating the rendering directly in the 3D view or camera, and inserting it immediately into the project file (without losing BIM data).
Why It Is Relevant for Technical Professionals
- accessibility – the cloud-based interface and plug-in mode reduce the learning curve. You can start right away with a few clicks, even without complex rendering skills;
- high customization – changes in materials, furnishings, and lighting can be tested accurately by describing simple prompts, facilitating fast and collaborative iterative processes;
- integrated collaboration – online sharing and review functions allow teams (architects, engineers, clients) to actively and simultaneously participate in the creative process, optimizing decision-making times.
Modern house entrance ideas with usBIM.codesign AI
FAQ of Virtual renovation
What is Virtual renovation and why is it revolutionizing the real estate sector?
Virtual renovation is a technology that allows for the digital simulation of renovation interventions on a property. It enables changes to both internal and external spaces using 3D software, virtual reality, and artificial intelligence, showcasing the future potential of buildings without having to perform physical work. It represents a strategic tool for enhancing properties, reducing preliminary costs, and offering immersive experiences to clients.
What are real examples of Virtual renovation for houses and apartments?
A common example is the transformation of a 1970s apartment into a modern open space with new flooring and redesigned bathrooms. Other cases include converting an attic into a livable loft, virtually adding a veranda, or modernizing the facade of a building. These simulations allow professionals to present design proposals quickly and engagingly.
What are the differences between Virtual renovation and Virtual staging?
Virtual renovation involves structural elements and finishes, allowing for modifications to walls, floors, ceilings, and internal distribution. Virtual staging, on the other hand, pertains only to the furnishing and digital decoration of existing spaces without altering the structure. The former is ideal for properties to be renovated, while the latter is for enhancing empty or bare environments.
When is it advisable to use Virtual renovation?
It is especially beneficial for enhancing dated properties or those under construction, empty properties, or those with complex layouts. It allows for the early demonstration of the transformative potential of a building, reduces time and costs of physical renovation, and increases the perceived value of the property, making the selling or renting process quicker.
What advantages does Virtual renovation offer to technical professionals?
For architects, engineers, and surveyors, Virtual renovation enables accurate planning, identification of critical issues before the construction site, greater client engagement through virtual tours, and multidisciplinary collaboration among teams and investors. All of this optimizes time, costs, and project communication.
What tools and technologies are used in Virtual renovation?
The tools include 3D modeling and rendering software, real-time visualization engines, augmented and virtual reality, as well as artificial intelligence to generate design solutions in reduced timeframes. These technologies allow for photorealistic representations, interactive navigations, and immersive simulations for clients.
How does artificial intelligence support the automatic generation of virtual environments?
AI allows for the transformation of sketches, photos, or 3D models into photorealistic renderings in seconds. Tools like usBIM.codesign AI enable the selection of architectural styles, adding furnishings, customizing materials, and lighting through text prompts or reference images. Thanks to plugins integrated into BIM software, it is possible to regenerate visualizations in real-time, improving speed, collaboration, and accessibility of the design process.
