BIM Content Creation: A Practical Guide for Professional Objects
Practical guide to BIM content creation: discover how to create professional, optimized, and standardized BIM objects
Despite the fact that BIM is no longer a promise for the future, but the standard of the present, many of the digital models in which engineers and architects move their projects suffer from an invisible but paralyzing problem: the quality of individual components.
Too often, 3D modeling is confused with BIM content creation. Downloading or producing a geometrically perfect object but lacking informational logic, heavy for the software, and non-standardized, is like inserting a bulky and defective engine into a luxury body. A true professional BIM object is not just a simple “three-dimensional drawing,” but a true parametric digital twin, capable of interacting with metric computations, energy analyses, and the future maintenance of the work.
Whether you are a building component manufacturer looking to digitize your catalog or a professional wanting to elevate the quality of your models, this practical guide will take you step by step through the creation of effective, lightweight BIM content ready for the challenges of openBIM to be uploaded to the online library.
The two sides of BIM
BIM content creation: what it really means
When talking about BIM content creation, there is a risk of confusing this activity with a simple session of advanced 3D modeling. In practice, creating a BIM object means bringing to life a digital twin of a real component (whether it’s a hydronic pump, a fixture, or a lighting body) capable of interacting with the entire ecosystem of the project.
We are not just drawing shapes in space; we are constructing a structured container that must respond to logic of computation, energy simulation, maintenance, and construction site management. In simple terms: if the software does not understand what that object is and how it behaves, it is not BIM. It is just a nice drawing.
From geometry to data: what you really need to build
To create a BIM object that works, it is necessary to operate on two parallel tracks that merge into a single element: geometry (the shape) and data (the information).
- Geometry – must be intelligent. There is no need to replicate every single screw or geometric bevel (overloading the project file); a parametric, flexible, and scalable geometry that can adapt to different Levels of Geometric Detail (LOG) is needed.
- Data – is the true engine of BIM. Structured information, attributes, and properties (LOI – Level of Information) such as thermal transmittance, materials, manufacturer data, maintenance cycles, and classification codes (e.g., OmniClass, Uniclass, or MasterFormat) are necessary. Thus, to “truly” construct a BIM object means finding the perfect balance between a lightweight geometric shell and a rich, standardized informational core.
Difference between “simple” and professional BIM objects
Many manufacturers and designers make the mistake of considering “valid” any file that has an extension compatible with BIM Authoring software (like .rfa or .ifc). However, there is an abyss between a “simple” object and a professional one.
| Characteristic | Simple BIM Object (Amateur) | Professional BIM Object |
| File size | Excessive. Often derived from unoptimized mechanical CAD (e.g., STEP), which slows down the overall model | Optimized and lightweight. Weighs a few kilobytes thanks to clean, native modeling |
| Parametrization | Rigid or absent. Modifying a single parameter means having to redo the block | Dynamic. The object adjusts millimetrically by changing the dimensional parameters |
| Connectors | Absent. It is an isolated block in the model | Intelligent. It has MEP connectors (hydraulic, electrical, air) that allow the calculation of flows in networks |
| Standardization | Data entered without following a precise standard, with customized and untraceable nomenclatures | Mapping of parameters according to international standards and shared guidelines |
A professional object is not just a simple “digital ornament,” but a work tool that designers will gladly use because it accelerates their calculation flow and does not “weigh down” their models.
The perfect balance for a BIM model
What data is needed to create effective BIM content
BIM content does not exist in a vacuum: to be defined as “effective”, it must integrate seamlessly into the project’s calculation and coordination workflows without generating friction. To ensure that an object becomes a resource rather than an obstacle for designers, the data structure within it must be meticulously organized according to four informational pillars.
Geometric data
Geometry in BIM is not a hyper-realistic reproduction, but a functional representation. An effective object must implement a scalable visibility logic based on levels of geometric detail (historically known as LOD, now referred to in UNI EN 17412-1 as levels of informational need).
- Maximum dimensions – useful in the early stages of space planning (space verification) and for preliminary geometric coordination.
- Anchor points and origin – the insertion axis of the object must be unique and consistent (e.g., the base for a floor-mounted machine, the back wall line for a radiator).
- Clearance Zones – virtual spaces that are invisible in rendering but can be detected by Clash Detection software. They represent the space required for door openings, maintenance, or the radius of action of a component.
Technical and performance data
This data allows the object to actively interact with specialized calculation software (structural, energy, plant). These are not just simple descriptive texts, but numerical values with precise units of measurement that the software can process.
- Thermophysical properties – thermal transmittance (U), conductivity (λ), specific heat, and emissivity for building envelope components.
- Mechanical and hydraulic data – pressure losses, operating curves, nominal flow rates, working pressures, and nominal connection diameters.
- Electrical and lighting properties – supply voltage, power consumption, phase shift (cosΦ), and integrated photometric files (e.g. IES/.LDT) for calculating luminous flows.
Information Parameters (LOI)
The Level of Information (LOI) defines the non-geometric identity card of the component. In a professional object, these parameters must be structured into logical groups (Property Set) to avoid information chaos. The fundamental parameters are divided into:
- Product Data – manufacturer, model, series, link to the official technical data sheet and commercial contacts.
- Life Cycle and Maintenance Data (Asset Management) – asset code, expected useful life, frequency of scheduled maintenance cycles, and disposal instructions (essential for BIM in phase 7D – Facility Management).
- Sustainability and LCA – information related to environmental certifications (e.g., EPD – Environmental Product Declaration), recycled material content, and carbon footprint.
Classifications and Codes
Without proper coding, a computer cannot automate extensive metric calculation processes (BIM 5D) or work scheduling (BIM 4D). The object must communicate in a universal and standardized language through the main international and national classification systems:
- IFC – the object must be mapped to the correct entity class (e.g., IfcPump for a pump, IfcBoiler for a boiler) with the corresponding Predefined Type.
- Standard Classification Systems – input of codes OmniClass, Uniclass 2015, MasterFormat or the Italian standard UNI 8290. These codes allow management software to instantly group all objects of the same type present in the model, automating the creation of estimates and specifications.
The creation of a professional BIM object does not begin and end in front of the modeling software screen. It follows an engineered process, a true workflow divided into precise phases that ensures the quality and efficiency of the final deliverable.
The four information pillars
Complete Workflow of BIM Content Creation
Phase 1 – Collection and Analysis of Source Data
Initial Strategy
Before opening Revit, Archicad, Edificius, or any other software, technical datasheets, paper catalogs, or the manufacturer’s CAD files are analyzed. In this phase, the parameter matrix (which data to include) is defined, and the limits of the geometric configuration of the object are established.
Phase 2 – Software Selection and Template Setup
Environment Setup
The native authoring environment is selected (e.g., .rfa format for Revit) always starting from clean and standardized templates. Setting the correct category (e.g., “Mechanical Equipment” or “Furnishings”) is crucial for the future behavior of the object in the project.
Phase 3 – Parametric Geometric Modeling and Connectors
Smart 3D Development
The skeleton of the object is constructed using reference planes and dimensional constraints, followed by the application of solid geometries. In this phase, MEP connectors (anchor points for pipes, cables, or ducts) are inserted, setting their directional vectors, flow rates, and electrical or hydraulic characteristics.
Phase 4 – Data Population and Parameter Mapping
Injection of Informational Code
Shared parameters and properties (LOI) defined in phase 1 are inserted. The data is associated with mathematical formulas if the object has dimensional variations (e.g., if height changes based on the model code). IFC property mapping is performed to ensure interoperability in OpenBIM.
Phase 5 – Testing, Validation, and Optimization
Quality Control (QA/QC)
It’s time for testing. The object is placed in a test project to verify that parameters change correctly, that connectors attach to networks, that 2D/3D visibility is clean, and that the file size is optimized (generally under 1 or 2 Megabytes for complex elements).
The error to avoid: Skipping Phase 5. Distributing a BIM object without testing it in a real project environment is akin to releasing software without beta testing: geometric or informational bugs will emerge at the first measurement performed by the designer, damaging the brand’s reputation.
Standards and Requirements in BIM Content Creation
In order for a BIM object to be integrated into an international workflow without creating anomalies, it is not enough for it to be well-made: it must comply with shared rules and standards. Standardization is what transforms a proprietary file into a universal resource for the construction market.
LOD: Level of Geometric Detail
The concept of LOD has undergone significant regulatory evolution. While the American approach (AIA) referred to Level of Development (LOD 100, 200, 300, 400, 500) and the Italian approach (UNI 11337) used letters (from A to G), the European and international regulation UNI EN 17412-1 introduced the concept of LOIN (Level of Information Need), which is the Level of Information Requirements.
From a purely geometric perspective, this means that the object must be modeled to show only what is needed when it is needed:
- in territorial/preliminary scale: An abstract or space-occupying representation.
- in the execution phase: Actual dimensions and exact connection points.
- in the as-built phase: The final configuration for maintenance.
A professional BIM object manages these transitions within the same file through visibility filters (Low, Medium, High), avoiding overloading the designer’s computer memory.
LOI: Level of Information
The LOI represents the non-geometric component of the information requirements. Creating effective BIM content means not exceeding either by deficiency or excess. Including too much unnecessary data (e.g., the name of the internal bolt) burdens the file and creates background noise; including too little renders the object useless for calculations.
The LOI must be structured to meet specific objectives (Project Milestones):
- data for performance calculations (e.g., acoustic insulation during design);
- data for procurement and construction (e.g., delivery times and manufacturer’s item code);
- data for asset management (e.g., COBie parameters for Facility Management).
Tailored scalability with the LOIN
Errors to Avoid in BIM Content Creation
In the world of BIM, a poorly designed object can cause more damage than a two-dimensional drawing error. If a single defective component is replicated hundreds of times within a large project model (think of the lighting fixtures in a hospital), the entire digital ecosystem risks collapse.
Recognizing and avoiding the most common errors is the first step to ensuring that your content is actually chosen and used by designers.
Too Complex and Heavy Objects
The most frequent mistake made by manufacturers venturing into BIM is the direct importation of CAD 3D models created for mechanical production (e.g., STEP, IGES, or SolidWorks files) into BIM software.
Mechanical design needs precise millimeters, threading, and every single internal curvature radius. In BIM, all of this is detrimental. A file exceeding 2-3 Megabytes (MB) is immediately discarded by BIM Coordinators.
The Consequence
An architectural or MEP model clogged with super detailed BIM objects becomes unstable, slows down loading times, and makes rendering and Clash Detection operations impossible.
The Solution
Practice what is known as “geometric simplification.” Complex curved shapes should be stylized, and internal parts that are not visible (or not useful for positioning and maintenance) should be radically removed during modeling.
Unnecessary or Redundant Parameters
On one hand, a lack of information renders the object useless; the opposite excess creates a true “intoxication” of the model. Inserting dozens of parameters related to internal industrial details, assembly screw codes, or microscopic manufacturing tolerances is entirely unnecessary for those who must design or manage the building.
Another common problem is redundancy, that is, inserting the same data under different names, such as having parameters Height, H, and Height in the same object.
The Consequence
Quantitative measurement and analysis software extract duplicate data, skewing reports, creating confusion in search filters, and disorienting designers.
The Solution
Stick to the parameters required by the information specification (EIR) and international guidelines, eliminating everything that is not necessary for the calculation, installation, quantitative measurement, or maintenance of the component.
Lack of standardization
Creating a BIM object using proprietary parameters with entirely made-up nomenclature (e.g., Thickness_Insulation_MyBrand) makes that object a deserted island unable to communicate with the rest of the project.
If the designer’s software is set to read thermal transmittance through a standardized parameter or a specific IFC code, it will never recognize a customized term invented by the content creator.
Without alignment to shared data dictionaries (such as the bSDD – buildingSMART Data Dictionary) or national guidelines, the object can never be integrated into automated calculation processes. As a result, the designer will be forced to modify it manually or, much more likely, to replace it with an object from a competitor that has complied with the standards.
Difference between a 3D model and a BIM model
FAQ on BIM Content Creation
What does BIM content creation mean in practice?
It means creating the parametric digital twin of a real component. It is not simple 3D modeling, but a structured container of geometric and informative data capable of interacting with calculation software, energy simulation, and maintenance.
What is the difference between a ‘simple’ BIM object and a professional one?
Simple objects are heavy (often derived from mechanical CAD), rigid in parameterization, and lacking standards or connectors. Professional objects are lightweight, have dynamic parameters, include MEP connectors for network calculations, and follow standardized nomenclature.
What data is needed to create effective BIM content?
Four informational pillars are needed: functional geometric data (dimensions and clearance areas), technical and performance data for specialized calculations (e.g., thermal transmittance, flow rates, powers), informational parameters (LOI) for the registry and Facility Management, and standard codes (IFC, Uniclass, OmniClass) for calculations.
What is the complete workflow of BIM content creation?
The workflow is divided into 5 phases: 1) Collection and analysis of the source data; 2) Choice of software and setting up the template; 3) Parametric geometric modeling and insertion of MEP connectors; 4) Population of data (LOI) and IFC mapping; 5) Testing, validation, and file weight optimization.
Why is it a mistake to skip the testing and validation phase (Phase 5)?
Because distributing an untested BIM object is like releasing software without beta testing: any geometric or informational bugs will emerge during design, blocking the professional’s calculations and harming the brand’s reputation.
How do the concepts of LOD and LOI evolve in BIM content creation?
The UNI EN 17412-1 standard introduces LOIN (Level of Information Need), surpassing older standards. The geometry (LOD) must be scalable through visibility filters (low, medium, high), while the informational component (LOI) must contain only the data useful for project milestones, avoiding information overload.
What are the main mistakes to avoid in BIM content creation?
1) Files that are too heavy (over 2-3 MB) derived from unsimplified mechanical CAD; 2) Unnecessary or redundant parameters that distort calculations and create confusion; 3) Lack of standardization and use of invented nomenclature, which makes the object an island incapable of interacting with automatic calculation software.
