Characteristics and famous examples of exposed concrete
Exposed concrete: characteristics, advantages, and examples of famous structures using this ancient yet modern finishing technique
Exposed concrete, also known as fair-faced concrete or exposed reinforced concrete, is a material that has gained a prominent role in contemporary architecture in recent decades. Appreciated for its aesthetic and functional properties, it is used to create visible final surfaces without the need for additional cladding or finishes.
This article analyzes in detail the characteristics, advantages, production techniques, and applications of exposed concrete.
Exposed concrete: what is it
Exposed concrete is a type of concrete that has a visible surface, often used to create architectural structures that require greater aesthetics and strength. This technique allows transferring the aesthetic impact of raw concrete typical of some significant architectural trends of the 20th century, such as brutalism, an architectural movement that has sparked widespread debates since its appearance. The term “brutalism” itself comes from the French “béton brut,” which literally means “raw concrete.” This style is characterized by the use of exposed reinforced concrete, with buildings openly displaying their structure and function, often conveying a sense of solidity and power.
More specifically, it is a special mixture of cementitious conglomerate that, once poured into formwork and after the necessary hardening time, becomes the finished surface of a reinforced concrete element, without further treatments. For this reason, it is also called architectural concrete: its texture (color and material appearance) is an integral part of the architectural design, along with the shapes and geometries of the structural elements.
Technical characteristics
A powder thixotropic product based on modified hydraulic binders and selected aggregates with a granulometric range functional to the desired decorative effects, designed for the realization of rough concrete effect skim coats or concrete slabs. Easy to apply, it allows the realization of skim coats of a certain thickness without cracking, although it is recommended to apply about 1.5-2 mm per layer.
Exposed aggregate concrete: the characteristics
Exposed concrete is a mixture of cementitious conglomerate designed to offer a pleasant and durable aesthetic appearance. Its main features include the ability to achieve surfaces with different textures and colors, depending on the formwork used and the added pigments. The finished surface can be smooth or have a specific texture, with a color that can range from the natural gray of concrete to customized shades. The “material” appearance of the surface gives buildings a distinctive and modern character. Furthermore, exposed concrete is extremely durable, resistant to weathering and wear, making it ideal for both exterior and interior applications. The ability to shape and customize exposed concrete allows for harmonious integration with the shapes and geometries of the architectural design, creating a visually impactful effect.
Exposed concrete, being exposed and highly visible, constitutes not only an aesthetic element but also an integral part of the load-bearing structure of the building. Therefore, it is essential to ensure that the structure is designed and calculated correctly to support the expected load and ensure the stability of the building over time. That’s why I recommend using a structural calculation software, perfect for modeling structures more easily, obtaining more professional results, and not falling behind in your work.
What are the advantages of exposed reinforced concrete?
The use of exposed concrete offers numerous advantages. From an aesthetic point of view, the variety of textures and colors available allows for the creation of unique and captivating surfaces, capable of enhancing any architectural project. Its versatility makes it suitable for a wide range of applications, from building facades to floors, from interior walls to decorative elements. Another advantage is the reduced maintenance: unlike other finishes, exposed concrete does not require frequent interventions such as painting or cladding. From a sustainability perspective, exposed concrete can be made with eco-friendly materials, recycled and local, contributing to reducing the environmental impact of constructions.
Production techniques
The production of exposed concrete requires a series of fundamental steps to ensure optimal aesthetic and structural results. A careful design phase is essential to define the aesthetic and functional characteristics of the concrete. The choice of concrete components, such as aggregates, cement, and pigments, significantly influences the final quality of the product. Formwork must be carefully selected to achieve the desired texture and can be made of wood, metal, or composite materials. The casting process must be carried out with precision to avoid surface defects and ensure a uniform finish. Proper curing is essential to develop the mechanical and aesthetic properties of the concrete. This balance between careful design, material selection, casting technique, and meticulous curing is essential to achieve high-quality exposed concrete.
Exposed concrete facades for exteriors
Concrete facades can be made through casting in formwork or with prefabricated elements in blocks, panels, or slabs. In more complex projects, castings are carried out on-site and treated with protective surface layers to improve finishes and reduce costs and the risk of cracking. This method allows for the creation of versatile architectural forms that harmoniously integrate into urban and natural contexts.
Despite the aesthetic and functional advantages of exposed concrete, maintenance is crucial. To repair fractures or damages, it is necessary to use restoration mortars compatible with the original material. The coloring of the mixture must be uniform to ensure color tone uniformity.
Exposed concrete for interiors
Exposed concrete is also used for interiors, not just the exterior of a building. With its raw, rough, and unfinished appearance, it has become a distinctive element in interior design, thanks to its ability to provide expressive material character to spaces. Its rough texture and various color shades give it a particular decorative effect, making it a highly sought-after choice in both commercial and residential settings.
Exposed concrete is typical of modern architecture and is experiencing a new phase of popularity. Just like in the exteriors of brutalist-style buildings, exposed concrete is gaining appeal in contemporary interiors. Despite its essential nature, this material enhances surfaces with square or sinuous geometric shapes, without the need for claddings like plaster or other materials, leaving the structural characteristics of the building exposed.
It is not only reserved for industrial or urban lofts but also finds space in refined contemporary interiors. It is a very versatile finish that, depending on the context, can create different effects. In minimalist contexts, the raw surface of concrete is maximized. When combined with noble materials, eclectic spaces of great inspiration can be achieved. A common example is porcelain stoneware tiles with a concrete effect, which perfectly reproduce the appearance of concrete and can be used on walls and floors. However, these tiles do not allow for continuous surfaces. Other examples include laminate with a concrete effect, used for furniture and countertops in bathrooms or kitchens, and PVC tiles with a concrete effect, easy to apply and suitable for various environments.
With an architectural rendering software, you can see your project in real-time thanks to 3D BIM modeling that produces extraordinary scenes of architecture, interior design, landscape design, etc.
Exposed concrete: examples of famous structures
In the last century, important works in exposed concrete were realized in Italy, such as the Palazzetto dello Sport in Rome designed by Nervi, the headquarters of the Mondadori Group in Segrate (MI) by Niemeyer, the bridge over the Basento river by Musmeci, and more recently, the MAXXI Museum in Rome designed by Zaha Hadid. In all these works, concrete played a fundamental role in enhancing the architectural project, highlighting shapes and geometries without the need for plaster, painting, or cladding with more precious materials like stones, bricks, or mosaics.
For concrete intended for exposed structures, aesthetic quality (material, texture, color) is the key element, to be associated with the structural and durability requirements that it must in any case guarantee. Achieving high-quality exposed concrete structures requires a balance between careful design, correct mix design of the cementitious conglomerate, appropriate choice of formwork, meticulous installation, and adequate curing.
