Electrical BIM Modeling for Designing Electrical Systems
Guide to BIM-based design of HVAC and electrical systems: calculations and Clash Detection in an integrated workflow
Within an Open BIM workflow, multidisciplinary integration becomes a continuous collaborative process based on the exchange of data in open formats through the CDE platform.
BIM modeling of electrical systems relies on an open architecture designed to improve the quality of the built environment while reducing overall project time and costs.
In this context, BIM for electrical systems goes far beyond three-dimensional representation. Parametric objects become centralized repositories of technical information, providing the data needed to power calculation engines, extract consistent quantities, and run immersive simulations.
This article explores the complete workflow, from importing the IFC model and enriching its data to regulatory sizing, Clash Detection, and Code Checking. It demonstrates how an integrated BIM approach can optimize multidisciplinary coordination, identify conflicts before construction, and minimize costly changes and variations on site.
Example UTA Edificius-MEP
- Introduction to the Open BIM ecosystem for integrated design
- Advanced 3D modeling and information enrichment in electrical BIM Modeling
- Integration between MEP modeling, specialist calculations, and regulatory checks
- Analysis of the practical case study: integrated modeling, code checking, and conflict resolution
- FAQ on Electrical System Design
Within the Open BIM workflow, multidisciplinary integration is no longer a sequence of asynchronous steps, but a continuous collaborative process in which different specialists use heterogeneous authoring tools working under common guidelines.
The management of electrical BIM Modeling design relies on an open data exchange architecture, designed to maximize the quality of the built environment and reduce time and costs.
The role of the CDE and IFC in interdisciplinary data exchange
The operational and legal pivot of this methodology is the CDE (Common Data Environment), the web platform dedicated to the management, storage, and sharing of all project data. Within the CDE, interoperability between different specialized software (architectural, structural, and plant engineering) is ensured by the adoption of the open standard format IFC (Industry Foundation Classes).
Controlled access via user credentials ensures the traceability of every operation. The IFC format enables overcoming the barriers of proprietary formats, allowing the direct visualization of models on the platform’s browser. The informational flow begins precisely with the extraction of the reference architectural model from the CDE, which constitutes the geometric and spatial basis upon which the technological project will be grafted.
From the architectural model to the MEP model: analysis of process documents and information specifications
Once the architectural IFC is downloaded from the CDE, the engineer’s activity does not begin directly in the modeling software, but rather in the validation of the informational requirements structured in the process documents (such as the information specifications). This preliminary analysis phase allows for the precise identification of the depth of the data and the required level of geometric detail for the plant assets.
In this context, the transition from the building envelope to the MEP (Mechanical, Electrical, and Plumbing) model emerges, the macro-category that unifies mechanical, electrical, and plumbing systems. The detailed study of the project documentation establishes the rules for the subsequent implementation of parametric objects in electrical BIM Modeling, ensuring that each component fully complies with the flows and standards set by the project.
The digitization applied to the plant engineering sector requires an operational approach that exceeds the logic of two-dimensional drawing in favor of data-driven modeling. Within the BIM flow for electrical systems, the construction of the geometric model occurs directly in an integrated three-dimensional environment, offering the designer the ability to section the building both horizontally and vertically to study its internal architecture or to temporarily hide specific structural parts to operate accurately in individual rooms.
model an electrical system with Edificius-MEP
Parametric Objects and MEP Libraries: Spatial Placement and Geometric Configuration of Components
Modern BIM Authoring systems provide designers with structured catalogs of intelligent and parametric objects, organized within libraries and specialized macro-categories. These databases include both power and generation components (such as transformers, meters, inverters, generators, and distribution boards) as well as terminal devices, branch elements, and systems dedicated to auxiliary plants, among which fire protection and surveillance technologies stand out.
The digital models of these components can be accessed from local user catalogs or integrated by directly drawing from web libraries and external online platforms.
The placement of elements in three-dimensional space adheres to absolute rigor of geometric logic and spatial coordination. Through the use of parametric constraints and relative positioning coordinates, the designer precisely defines the horizontal and vertical distances to the millimeter, anchoring to certain construction references, such as the edges of walls or the elevation quotients of the floor.
The native intelligence of MEP objects allows them to recognize the physical properties of the hosting entities: when inserting junction boxes on walls, for example, the object interacts with the wall stratigraphy automatically managing the embedding level and leaving only the cover plate visible externally. The modeling extends down to the granularity level of terminal components, where the modularity of the electrical boxes allows for a flexible management of individual operational outlets. The flow allows for initially configuring passive elements (such as hole cover caps), and then analytically replacing them with specific active modules, such as electric outlets, with the ability to quickly replicate these standardized combinations at other installation points or on floor-mounted towers.
This methodological approach is also central for managing hybrid and multidisciplinary components (a pillar in the electrical thermotechnical BIM design), as in the case of split air conditioning units. The workflow allows, in fact, to accurately establish the architectural anchorage point of the thermomechanical block, simultaneously defining and coordinating its related connection and power points to the electrical infrastructure.
The data beyond geometry: implementation of technical attributes, catalog sheets, and PDF attachments
The transition from three-dimensional drawing to information modeling represents the true methodological revolution in the workflows related to BIM and electrical systems. Within the BIM paradigm, the geometric element ceases to be a mere graphic representation and transforms into a centralized archive of structured information. In the authoring catalog, each parametric object natively integrates three fundamental levels of information: the geometric and dimensional definition in 3D, a rigorous set of attributes and technical data specific to the component, and the accompanying support and maintenance documentation, including freely accessible PDF attachments directly from the object’s instance.
This structured informational heritage is not a static data point, but remains permanently accessible, queryable, and updatable throughout the entire project advancement cycle. By analytically querying any node or terminal of the technological network (whether it is a communication device like a video intercom, a safety component like a smoke detector, a lighting fixture like a light point, or a sensor like a volumetric detector), the designer can instantly inspect its properties sheet.
Such granularity allows for real-time verification of the technical and performance data concerning the minimum information requirements established within the project documents and the project information specifications. From the perspective of highly integrated electrical systems design with BIM, this informational enrichment takes on strategic significance as it serves as the analytical basis for the subsequent specialist calculation and performance simulation phases.
The accurate entry of technical data into the objects is indeed the essential condition to activate the calculation engines: the definition of parameters related to loads, lengths, and installation methods enables the automatic sizing of cables and protections, while the insertion of physical and thermal properties within the panel object allows for the analytical validation of overheating checks in compliance with industry standards. The model thus configures itself as the single source of truth of the work, reducing informational asymmetries among the various disciplines involved.
BIM Validation | The verification of IFC models
The fundamental value of the information-based approach is manifested in the direct transition from the three-dimensional geometric modeling phase to the engineering sizing and regulatory check phase.
In electrical thermotechnical BIM design, the model is not just a simple static graphic trace, but constitutes the centralized database that feeds specialist calculation engines. Through the use of integrated BIM tools, the designer implements a bidirectional workflow where every geometric or analytical change is immediately reflected in the overall technical compliance of the work.
Structuring the electrical tree, single-line diagrams, and 3D panel front configuration
The transition to the calculation phase requires the logical structuring of the entire distribution network. By selecting an electrical panel within the authoring environment, the designer accesses the relevant management module to formally assign the source of electrical supply to which the subsystem is connected. From this base, the composition of the single-line diagram proceeds, logically inserting the various protection, operation, and isolation devices in sequence.
This plant hierarchy is analytically displayed through an electrical tree structure. This type of tool allows examining the overall architecture of the network and assessing the quality and consistency of the logical design even before starting the calculation algorithms.
Once the fundamental electrical part is defined, the flow allows for the configuration of the panel front, which can be generated either manually or through automatic optimization procedures. The layout of the panel front so obtained is not confined to a two-dimensional view but is automatically integrated and composed as a volumetric object in the overall 3D environment, ensuring perfect spatial coordination within the technical rooms.
Sizing algorithms and diagnostics: short-circuit currents, voltage drops, and phase balancing
To activate the cable sizing and related protection calculation processes, the digital model must be pre-populated with specific operational data: detailed information on applied loads, actual circuit lengths derived from the 3D layouts, and the specific installation methods of the conduits.
Within the general parameters of the calculation module, the engineer defines the reference variables and selects real components drawing from the manufacturers’ databases available in the system. Following the processing of the sizing algorithms, the system returns a comprehensive picture of technical diagnostics. The significant operational advantage is the direct interactivity with the three-dimensional environment: by selecting any device or circuit in the 3D model, it is possible to instantly visualize the related analytical results, such as short-circuit current values at nodes and localized voltage drop percentages.
The calculation engine also allows for executing global systemic checks, such as the comprehensive analysis of voltage drops across the entire development of the plant and phase balancing on three-phase loads, optimizing energy efficiency and the stability of the electrical network.
Overtemperature verification in electrical panels in accordance with industry standards
A crucial aspect in the validation of the model within the electrical BIM flow is the verification of the thermal safety of the distribution panels. To perform the overtemperature verification, the parametric object representing the panel must natively integrate all geometric, physical, and performance data required by the specific calculation procedures. By selecting the relevant technical standard, the designer initiates the thermal calculation algorithm to ensure that the heat dissipation generated by the internal devices is compatible with the enclosure and the environmental installation conditions. The integrated diagnostics validates the outcome of the test, allowing to verify whether the regulatory requirements are fully met. This check prevents overheating of the components and reduces the risk of failures or fires, ensuring the compliance of the executive project before its actual realization or supply on site.
BIM Model Checking
Through a series of coordinated operational steps, it is possible to analyze how the coexistence of geometric data and technical attributes allows for managing the design complexity of electrical BIM Modeling systems, anticipating in a virtual environment the issues that would traditionally manifest during the construction phase.
Geometric-functional coordination of terminal components and hybrid systems
The first part of the practical application focuses on the correct spatial and logical arrangement of the delivery points and the interconnection elements within the building’s premises. The case study highlights the precise geometric positioning on the walls of junction boxes (embedded in masonry) and socket boxes in a standardized six-module configuration, initially equipped with blanking plugs, then configured with active modules (electrical sockets) and replicated on towers positioned along the flooring. The need for multidisciplinary integration clearly emerges in the management of hybrid systems, such as split conditioning units.
The workflow demonstrates how the element, while primarily belonging to the thermotechnical sphere, inherently has an anchoring point and a connection to the electrical infrastructure. This allows for establishing a direct logical connection between the mechanical system and the power circuits of the electrical model, ensuring the consistency of overall loads.
Validation of regulatory rules (Code Checking) on special rooms and protective devices
Once the system model is completed, the presence of structured technical data allows for the execution of automated checks for compliance with regulatory and contractual requirements (Code Checking).
In the case study, two specific control filters are applied:
- check in bathrooms – the system performs an automatic check on all the socket boxes located within the restrooms, verifying that the parameter related to the degree of protection is equal to IP55. The algorithm detects a specific anomaly on a non-compliant box, visually isolating the object and exporting the error in open BCF format (BIM Collaboration Format) for its subsequent resolution on the CDE.
- check on protective devices – the second check interrogates the residual current devices included in the single-line diagram, imposing as a rule that the nominal residual current (IΔn) is less than or equal to 30 mA. The software identifies two devices not meeting the condition, allowing the technician to take them into account on the CDE to make the necessary corrective changes to the model.
Detection and resolution of geometric and spatial conflicts (Hard and Soft Clash Detection)
The spatial integration between the electrical infrastructure, structural works, and air conditioning systems is validated through collision analysis, divided into two macro-categories:
- Hard Clash (Geometric Interferences) – the automated control detects direct physical intersections between MEP system entities and architectural or structural elements. Specifically, the analysis highlights some electrical conduits that incorrectly intersect doors or reinforced concrete pillars. Each conflict is examined by the BIM Coordinator, tracked with comments on the status of advancement, and notified for path variation.
- Soft Clash (Functional and Respect Interferences) – in addition to geometric overlap, spatial respect constraints are set to ensure the installability and maintainability of the components. In the case study, it is verified that split conditioning units maintain a minimum distance of at least 50 cm from surrounding walls. The detection of air conditioners positioned below this threshold allows for correcting the geometric model before uploading the updated and federated version onto the CDE, eliminating in-progress variations.
What are the fundamentals of the Open BIM ecosystem in integrated system design?
The Open BIM ecosystem transforms multidisciplinary integration into a continuous and simultaneous collaborative process, overcoming the logic of asynchronous steps. Different designers use heterogeneous authoring software applying common guidelines and an open data exchange architecture. This approach optimizes ‘electrical BIM Modeling’, maximizing the quality of the built environment and reducing overall time and costs.
What is the role of the CDE and the IFC format in interdisciplinary data exchange?
The CDE (Common Data Environment) is the centralized web platform used to manage, store, and share project data, ensuring total traceability of operations through controlled access. Interoperability between specialized software is ensured by the open standard format IFC, which overcomes the limits of proprietary files and allows for direct visualization of models in the browser. The information flow begins by downloading the architectural IFC from the CDE, which constitutes the geometric-spatial basis for the technological project.
How does the transition from the architectural model to the MEP model occur?
After downloading the architectural IFC, the designer analyzes process documents, such as the informational specification, to identify the minimum information requirements and the required level of geometric detail. This marks the transition from the building envelope to the MEP (Mechanical, Electrical, and Plumbing) model. The study of this documentation establishes the rules for implementing parametric objects in ‘electrical BIM Modeling’, ensuring compliance with project standards.
How is advanced 3D modeling and the configuration of MEP parametric objects developed?
Modeling occurs in a data-driven integrated 3D environment, allowing for sectioning the building or applying transparencies to operate within individual spaces with precision. BIM Authoring software offers catalogs of intelligent and parametric objects (power components, terminals, or auxiliaries) that can be positioned with millimeter precision through coordinates and spatial constraints. MEP objects recognize the properties of the supporting structures (e.g., automatic recessing of boxes into walls) and manage the modularity of terminal outlets or multidisciplinary hybrid devices, coordinating their connection points and electrical loads.
What is meant by ‘data beyond geometry’ and what is the value of information enrichment?
In the BIM paradigm, the geometric element ceases to be a mere graphic representation and becomes a centralized archive that integrates 3D geometries, technical attributes, and supporting documentation (such as PDF attachments). This information repository, permanently accessible and queryable to verify compliance with project requirements, serves as an analytical basis to feed specialized calculation engines, enabling the automatic sizing of cables, protections, and electrical panels, and reducing informational asymmetries.
How does the integration between MEP modeling, specialized calculations, and the structuring of panels work?
The BIM model acts as a centralized database that feeds calculation engines through a bidirectional workflow. Selecting a panel in the authoring environment, the designer assigns the feeding, defines the network hierarchy through the single-line diagram, and analyzes the electrical tree to assess the logical consistency of the project. Finally, the panel front layout is generated and automatically integrated as a 3D volumetric object into the overall model, ensuring spatial coordination in technical rooms.
What parameters and algorithms govern electrical sizing and overheating verification in the BIM model?
Fed with technical data on loads, circuit lengths derived from 3D, and installation methods, the software executes sizing algorithms based on real catalogs and current regulations (e.g., CEI 64-8). Interactive diagnostics allow the direct visualization on the 3D model of short-circuit current values, voltage drops, and phase balancing. Additionally, by entering the physical and thermal data of the panel, overheating verification is performed to ensure thermal safety before actual installation on site.
What practical feedback emerges from the case study regarding Code Checking and Clash Detection?
The case study demonstrates how geometric and technical data allow for resolving issues in the virtual environment. Code Checking performs automated regulatory checks (e.g., checking the IP55 rating in bathrooms or the 30mA threshold on differential switches), isolating non-compliance issues and exporting them in BCF format to the CDE. Clash Detection validates spatial integration by detecting both direct physical conflicts (Hard Clash, such as pipes intersecting columns) and functional and respect tolerances (Soft Clash, such as the minimum distance of 50 cm around splits for maintenance), eliminating variations during execution.
