  • BIM news
  • BIM projects
  • EN
  • Menu Menu
List List Menu
  • BIM and Construction Sites
  • BIM and Building Design
  • BIM in Construction
  • BIM and Estimation
  • BIM and Energy
  • BIM and Safety
  • BIM and MEP
  • BIM and Facility Management
  • BIM and training
  • BIM and GIS
  • BIM and Infrastructure
  • BIM and technical standards
  • IFC and openBIM
  • Digital Twin
Home » BIM and Building Design » Gable Roof Guide: Advantages and Disadvantages, Types and Guidelines
The gable roof represents a type of roof covering that goes beyond mere protection from the elements. Let's examine its distinctive characteristics, analyzing its evolution over time and how to create it with BIM software.
Editorial Team / 1 December 2025
The roof slab is an essential component for a building, impacting safety and comfort: it separates the structure from the outside and protects it from external weather conditions, in addition to being a structurally important element.
Among the various types of roof slabs, we find sloped roofs, which are those made up of inclined surfaces that facilitate the drainage of rainwater.
When we think of sloped roofs and, in general, the primordial concept of a home, the gable roof certainly comes to mind: in this article, we will explore everything you need to know about the gable roof, from the definition of this architectural element to the advantages that distinguish it.
Finally, you will be able to watch a video that shows you how to easily and thoroughly create a roof with an architectural design software.
Gable roof of a modern building
  • What is a gable roof?
  • Historical evolution of gable roofs
  • Characteristics of a gable roof
  • Gable roof: advantages and disadvantages
  • Other types of sloped roofs: geometric configurations
  • Gable roof vs two-slope roof: differences and combination
  • Two-slope roof vs shed roof: differences and combination
The gable roof represents the archetype of architectural closure. Two slopes converge at the top along the ridge line, defining a triangular portion of wall called the gable. The facade that is created is indeed referred to as “gable” or “double slope,” referring to the delineation of the two slopes of the roof itself.
This section provides a detailed view of the geometries involved, originating the gable roof from the summation of two opposing regular lean-tos. The gable becomes a key architectural element, often clad differently to give it greater aesthetic impact.
In this video, you can see how to design a roof with a 3D architectural design software.
The historical evolution of gable roofs has traced a fascinating path, leading to significant advantages both from a formal and technological standpoint. Let’s explore the progress from the simple covering shape of the “cabin” to modern roofs, highlighting the significant transformations and the reasons behind such changes.
The first coverings, essentially cabins, were initially made with plant elements and later evolved with the introduction of clay artifacts. Originally resting on the ground, these roofs primarily served as shelter from the weather. However, technological evolution and changing social needs transformed these cabins into roofs supported by walls, paving the way for new architectural possibilities.
Modern gable roofs are characterized by remarkable flexibility and customization options. Chimneys, dormers, skylights, vents, and inspection hatches can be integrated without compromising the strength and function of the roof. The choice of materials, ranging from traditional bricks, tiles, or shingles to panels, sheets, or other finishes, offers a wide range of aesthetic and functional options.
A key section in the design of gable roofs concerns ventilation. The sloped and linear shape of the slopes facilitates the rapid drainage of rainwater and promotes ventilation, leveraging the chimney effect of the interstitial air. This not only contributes to the proper functioning of the roof but also represents a crucial aspect for its long-term maintenance.
Gable roofs, when used in building contexts, must comply with current construction and performance regulations. Micro-ventilation emerges as a fundamental requirement, representing an added value for the proper functioning and long-term preservation of the roof. A properly ventilated roof must incorporate intake and exhaust sections for air, ensuring regular circulation and preventing stagnation that could compromise thermal performance.
Contrary to the outdated idea, the gable roof is anything but old-fashioned. Contemporary architectures, especially in northern countries, embrace the use of reinterpreted gable roofs in terms of materials and sizes. These roofs not only respect the original functional shape but reinterpret its allegorical meaning, finding space not only in residential buildings but also in museums, industries, and iconic buildings.
The gable roof is distinguished by its classic two-slope shape, with a uniform slope ranging from 15% to 50%. This structure is anchored to the masonry of the building, taking on the traditional shape of a “house.”
The slopes typically rest on the longer side of the building, outlining the facades and contributing to the volume of the attic. This section provides a detailed description of the main characteristics of this type of roof, emphasizing its traditional shape and uniform slope.
Another fundamental aspect in the characteristics of the composition of a gable roof is provided by the stratigraphy. This is the set of different elements, each designed with a specific purpose. Before examining these components in detail, it is essential to understand the calculation techniques used in this design phase.
Calculation techniques for roof precision
To accurately determine the thickness of the roof, various calculation techniques based on the thermal and hygrometric analysis of the building are employed. These methodologies consider factors such as the thermal conductivity of insulating materials, local climatic conditions, and the energy needs of the building.
The application of such techniques allows for an accurate assessment of the amount of thermal insulation necessary to ensure adequate internal comfort. This is particularly crucial in regions with extreme climates, where a well-insulated roof helps maintain comfortable internal temperatures and reduce energy consumption.
Flat Roof - Stratigraphy
Flat Roof – Material Layers
Typical components of roof material layers
Now let’s examine the key components of a gable roof material layer:
  1. covering layer: this visible outer layer, made of materials such as tiles, metal sheets, or bituminous coverings, has the primary function of protecting the building from weather agents;
  2. insulating layer: responsible for thermal insulation, this layer helps maintain a comfortable temperature inside the building. The choice of insulating material and its thickness is crucial for thermal regulation;
  3. support layer: provides structural support to the roof, generally made of beams or panels in wood, reinforced concrete, or steel, depending on the structural needs of the building;
  4. membrane or waterproofing layer: prevents water infiltration and protects the underlying layers. It is made with bituminous membranes, synthetic membranes, or similar materials;
  5. ventilation layer: promotes proper air circulation under the roof, preventing the formation of condensation and rot. Effective airflow helps maintain the health of the roof;
  6. finishing layer: the innermost level, often made of cladding panels or drywall, has an aesthetic function and contributes to the internal appearance of the roof.
The synergistic combination of these layers, carefully designed and calculated, creates a gable roof that not only offers protection from weather agents but also contributes to thermal comfort and energy efficiency of the building.
The gable roof is a very common roof covering because it has various advantages:
  • limited budget, it is an easy roof to build, so the overall cost of construction and installation will be lower than other construction options;
  • effective drainage, with the steep slopes of the surfaces, the gable roof facilitates the drainage of water and snow, aids ventilation, thus avoiding humidity problems;
  • limitation of thermal dispersion, resulting in reduced heating costs;
  • excellent solution for the installation of solar and thermal solar panels, the slope of the surfaces indeed allows the panels to capture more solar energy;
  • creation of an attic, utilizing the space between the ceiling of the top floor and the roof itself.
However, there are also some disadvantages related to this type of construction:
  • strongly subject to wind action, especially if the overhang of the surfaces from the eaves line is greater. The wind can exert considerable pressure causing detachments of the roof or even collapse;
  • a solid supporting structure is necessary, due to the risk of significant damage caused by the wind. Therefore, it is necessary to properly structure the covering, using effective materials and structurally verifying its stability;
  • subject to more frequent maintenance and repairs, due to damage caused by weather conditions.
In addition to the gable type, roof coverings have various geometric configurations, each with unique characteristics. Let’s carefully examine the main types.
Single slope or shed roof
Shed roofs, within the solutions of sloped roofs, are characterized by the drainage of water along a single surface. This configuration, with a single slope resting on walls of different heights, represents the basic matrix of all sloped roofs. This section illustrates the simple shape and the complex summation of sheds, laying the groundwork for understanding more intricate types.
Asymmetrical gable roof
The asymmetrical gable roof, that is, with slopes of different inclinations, offers a unique perspective. The slopes converge at the top along the ridge, but do not have the same size, one of the two has an asymmetrical overhang on one side creating an iconic image of architectural closure.
This means that each side of the roof has a different length and sometimes also has a different slope, and their edges form an irregular angle. This section delves into the geometry of this type of roof, and thanks to the greater length of one side of the roof, extra space is created underneath, allowing for additional setup.
Asymmetrical roofs drain snow and rainwater more quickly than other roofs, precisely because of their shape, the slope is indeed greater, especially on the long side. Moreover, the greater length of one side means that snow or rainwater is distributed over a larger surface, which reduces the likelihood of dangerous accumulations.
Regular pavilion roof
The regular pavilion roof represents an option where water drainage occurs on all sides of the rectangular base. The section emphasizes the presence of a eaves line along the entire perimeter, and the visible slopes that conclude each facade of the building. It also explores the projection in plan of the inclined ridge line and its relationship with the length of the eaves.
Irregular pavilion roof
The irregular pavilion roof also allows water drainage on all sides of the polygonal base. This section focuses on the intersections between the slopes, giving rise to valleys or ridges. It highlights the differences between regular and irregular roofs, with particular attention to planimetric geometry and volumetric configurations.
Pyramid Gable Roof
The pyramid roof is the simplest pavilion roof, it develops on a square base, thus on a square building plan and consists of four equal slopes, in size and inclination, that converge at a single point at the top.
Flying gable roof
A flying gable roof, known as “flying gable roof”, is a common two-slope roof where their overhang at the ridge level is greater than that of the eaves line. It is typically used in chalets or rustic houses that may be subject to heavy snow loads.
Mansard roof
It is a French design and is more difficult to construct than the two-slope roof. It actually has two slopes within one, on each side. The lower part of the roof slope is steeper so that the roof pitch barely begins. This allows for more space inside and in most cases creates additional space.
Barn roof
The barn roof is similar to the mansard roof, as it is a two-sided roof with two slopes on each side, where the lower slope is steeper than the upper one, but it features vertical gables at the other two ends. It is most often seen in 18th-century North American colonial houses.
Dutch gable roof
The Dutch gable roof or Dutch pavilion roof is essentially a combination of a pavilion roof and a gable roof. It is indeed a four-sided pavilion roof with a small gable on top. Dutch gable roofs are slightly more expensive to build due to the extra beams involved in the structure, but they certainly create an interesting design.
Patio with gable roof
A gable roof can be an excellent technical solution for covering a patio or a veranda. The sloped roof of a veranda, patio, or covered carport allows for increased usable space in a home while providing a maximum sense of openness. Compared to a flat roof, a patio with a sloped covering allows for better drainage of rainwater, without compromising the integrity of the covering itself.
Flat roofs and terrace coverings
Flat roofs or terrace coverings are a common choice in Mediterranean countries, characterized by limited rainfall and little snow presence. However, the construction of a quality flat roof requires specific attention to detailed works that allow for proper drainage of water towards predetermined points, ensuring waterproofing and insulation. A careful implementation of such works can significantly reduce the costs associated with these roofs compared to sloped ones.
Finally, we recommend reading the in-depth article “How to design a roof” for more information on the different roofing systems.
Roof design architecture
Roof components
The gable roof is a sturdier structure compared to the two-slope roof, making it more suitable for areas with strong winds or heavy snow and requiring fewer diagonal reinforcements. However, the sturdier structure compared to the two-slope roof also translates into higher costs, both in terms of design and construction.
The structure appears more aesthetically elegant and pleasing thanks to the eaves that surround the perimeter of the entire roof in a linear and uniform manner.
The hip roof, on the other hand, although it is subject to damage in overly windy areas, is more easy to build, provides better ventilation, and offers more attic space compared to a gable roof.
The two types of roofing can be combined to create numerous design solutions, such as the pyramid roof or the combined roof, which incorporates more design into a single structure.
The shed roofs originate from the use of a series of unidirectional sloped planes that extend from one end to the other of the structure. They represent an ideal architectural solution to favor the entry of natural light in large spaces: the entry of light is made possible by the distance between the transparent elements, which must be a maximum of two and a half times the height of the space.
Although the shed roof originates from the sloped roof, it is much more functional: in its design, factors such as solar angle and lighting conditions throughout the day are considered, as it is used to maximize the entry of light into the underlying spaces and is especially used for large structures such as warehouses.
Share this entry
  • Share on Facebook
  • Share on X
  • Share on WhatsApp
  • Share on LinkedIn
  • Share by Mail
Related posts
    18 August 2026
  • Building a house on a sloped terrain: architectural considerations and design strategies
  • 18 August 2026
  • How to view a Revit file online
  • 18 August 2026
  • Trouble Ticketing Meaning, Applications, Software
  • 17 August 2026
  • LGSx: An Innovative Format for 3D Data Management and Sharing
Follow us on
  • Construction Sites
  • Energy
  • Estimation
  • Infrastructure
  • Safety
  • Structural Calculation
  • Technical standards
  • Training
  • BIM news
  • BIM project example
  • Digital Twin
  • IFC and openBIM
Scroll to top
