Water Cooled Air Conditioner: Efficiency and Sustainability
Water cooled air conditioners: innovation and energy efficiency for sustainable climate control
In an increasingly energy-conscious world, water cooled air conditioners represent an innovative and strategic technology in the field of climate control. These systems, characterized by the use of water as the primary medium for thermal exchange, differ from traditional air conditioners in their efficiency, versatility, and reduced environmental impact. The ability to integrate these systems into residential, commercial, and industrial contexts, combined with the possibility of pairing them with renewable sources, makes them an increasingly relevant choice to address the challenges posed by the rising demand for energy and the need to reduce carbon emissions.
Water cooled air conditioner: what it is
The water cooled air conditioner is a climate control system that uses water as a cooling fluid or heat exchanger. Unlike traditional direct expansion systems, which use refrigerant gas for cooling, water cooled air conditioners can be connected to a water network or a closed water circuit, which act as a medium for heat transfer. Water technology is applied in civil and industrial contexts, where the need for energy efficiency, environmental respect, and quiet operation is essential.
Water cooled air conditioners play a primary role in meeting energy needs due to their efficiency and sustainability, especially in a global context that requires increasingly energy-conscious and environmentally friendly solutions.
How water cooled air conditioners work
The water cooled air conditioner is based on the principles of thermodynamic temperature regulation and the reverse Carnot refrigeration cycle, operating through a vapor compression cycle. The process occurs in a series of phases:
- isentropic compression: the compressor raises the pressure of the refrigerant (usually a low environmental impact synthetic HFC or HFO fluid), which is in a gaseous state, compressing it to high pressure and temperature;
- isobaric condensation: subsequently, the refrigerant gas enters the condenser, where it transfers heat to the condensation water (condensation circuit) while maintaining a constant pressure. The isobaric condition during condensation is maintained by pressure control operated through a pressure switch or an electronic valve that modulates the flow of water to the condenser;
- adiabatic expansion: the refrigerant undergoes an expansion through a throttling valve or an electronic expansion valve (EEV), lowering its pressure and temperature without heat exchange with the environment;
- isothermal evaporation: in the final step, the refrigerant enters the evaporator, where it expands and absorbs heat from the process water, reducing its temperature. This exchange occurs under isothermal and isobaric conditions until the refrigerant evaporation is complete.
Water cooled air conditioners without external units
Water cooled air conditioners without external units are an optimal choice for those seeking an efficient and discreet climate control system that takes up little space. Unlike traditional systems, these devices do not require large external installations, but only a compact internal unit that can be easily placed anywhere in the building. Water cooled air conditioners without external units operate in an extremely quiet manner, ensuring a calm and comfortable environment. These systems are also highly energy efficient, offering significant savings on consumption.
Water cooled air conditioners without external units operate on a conventional refrigeration cycle, but the condensation phase occurs entirely within the internal unit through a water/refrigerant heat exchanger. This type of exchanger allows for heat expulsion through a water circuit, in which water acts as a heat carrier and replaces air in dissipating the condensation heat.
A distinctive feature of these air conditioners is the use of a water connection for heat dispersion. The air conditioner is connected to a water source (typically the municipal water supply or a dedicated water circuit), which flows through an internal heat exchanger and, by absorbing heat from the refrigerant, heats up. The hot water is then expelled into the drainage system or sent to a recirculation system if the system is equipped with a cooling tower or a thermal power plant.
Components of a water cooled air conditioner without external units
The fundamental components of a water cooled air conditioner without external units include:
- compressor: generally of the scroll or rotary type, the compressor is integrated within the internal unit. It is designed to operate with particularly advanced vibration and noise management, as its internal placement requires effective acoustic insulation to avoid disturbances in the environments;
- water condenser: replaces the traditional air condenser with a water/refrigerant heat exchanger. This exchanger can be plate-brazed or tubular, designed to maximize thermal efficiency. The choice of exchanger also depends on the available water flow and the inlet water temperature. The water flow is regulated to maintain the condenser at the optimal temperature, ensuring that the refrigerant undergoes adequate condensation;
- water circuit: in the case of a system connected to the municipal water supply, a flow regulator controls the amount of water flowing through the heat exchanger. If a closed circuit is used, such as a cooling tower or geothermal system, the water circuit requires careful maintenance to avoid scaling or bacterial contamination issues;
- expansion valve: an electronic expansion valve (EEV) is often used to regulate the flow of refrigerant, improving the efficiency of the thermodynamic cycle and adapting to variations in thermal load;
- evaporator and air distribution unit: evaporators are designed to operate in enclosed spaces, cooling the air through the expanded low-temperature refrigerant. The cooling of the environment occurs through the evaporation of the refrigerant in the evaporator, which absorbs heat from the indoor air and cools it.
How a water cooled air conditioner without external units works
This type of air conditioner operates similarly to a traditional climate control system, with the difference that it does not require an external unit. The system consists of a network of pipes that transfer water from the cooling unit inside the building. Inside, the water passes through radiators that absorb the heat present in the air, transferring it to the water itself. This heated water then returns to the cooling system, where it is cooled again and recirculated.
The water heated by the process is then expelled or recirculated:
- direct discharge: in environments where it is possible to use municipal water, it passes once through the system and is discharged into the sewage network;
- closed circuit with cooling tower or geothermal exchanger: if continuous water use is not possible, the system can be connected to a closed circuit where the water is externally cooled and recirculated. In this case, the air conditioner requires a secondary cooling circuit, such as a cooling tower or a geothermal exchanger.
Water cooled air conditioners without external units stand out for their high efficiency, as they do not consume additional electrical energy to power an external unit. Furthermore, the absence of an external module eliminates safety and maintenance issues related to installation. These systems adapt to various types of buildings, from residential to industrial. They can also be integrated with various climate control systems, including centralized systems and underfloor heating solutions.
