4 tips for using Agile construction
Agile construction is a cyclical, iterative and collaborative approach that you can manage construction projects with. Learn what it is and how to use this approach
In the past few years, project management with the “agile” approach has become very popular in many sectors since it has been very effective in the construction industry.
A specific construction management software , that I recommend you try immediately , turns out to be very useful to apply this method .With the help of these tools you will be able to break down the construction project into smaller phases optimizing its overall organization. Find out how in this article!
- What is Agile Construction?
- How the “Agile” methodology in the construction sector is transforming project delivery
- Agile Construction and Renovation: a Flexible Approach to Renovation
- Tools and Techniques for Agile Management of Construction Projects
- Agile in the Construction Sector: Benefits for Contractors and Clients
- How to Effectively Implement the Agile Approach in Construction
- FAQ – Agile Construction
Agile construction is a project management approach that has its origins in software development, but also adapts well to the changing needs of the construction industry; it is based on the continuous collaboration between stakeholders to improve and iterate a project at every stage.
The basic idea of the Agile approach is based on the strategic division of any large project into smaller, manageable tasks. In particular, these activities are broken down according to priorities, providing higher quality results and optimizing the workflow.
features of the agile methodology
The key principles of the Agile approach in construction
The application of the Agile approach in construction is based on some key principles that guide the entire project management process. These are not mere technical adjustments, but true methodological pillars that transform the way to plan, coordinate, and execute a project:
- division and adaptation: projects are broken down into small and measurable activities, reorganizable based on the client’s needs or unforeseen site issues;
- continuous feedback: each phase is accompanied by frequent reviews that allow for corrections, anticipating problems and responding to changes;
- cross-collaboration: technical, client, and operational teams work in close synergy, overcoming silos and rigid roles;
- visualization of work: through tools like Kanban boards or collaborative planning, the entire production flow is transparent and shared;
- focus on real value: each activity is planned and evaluated based on the concrete value it brings to the final project, avoiding unnecessary or ineffective activities.
Read also Lean Construction: 6 Key Principles and Benefits in AECO.
The Agile approach is applicable in any constructive project, because it does not prescribe strict rules on how the work is to be performed. Therefore it collects practical advice to change the work environment and improve the mentality and objectives of the team.
In fact, it contrasts with the traditional waterfall project management method. This method is characterized by a short planning and verification process before the start of the realization,that is difficult to modify once the construction begins.
The use of Agile management allows you to have greater transparency in the team work/client relationship. It also encourages collaborative work and allows you to develop the project more quickly. This approach has a strong impact precisely in the initial planning, design and in general pre-construction phases. It is in these phases that with sketches, drawings and models it is possible to collect feedback from the client. By doing so, changes in the executive phases will be minimized and we can achieve well-defined results immediately.
flow of the agile approach in the construction industry
Agile vs traditional
Understanding the differences between the Agile methodology in the construction sector and the traditional project management approach, often referred to as the waterfall model, helps to consciously choose the most suitable method based on the type of project, operational context, and degree of complexity.
The traditional model follows a sequential logic: each phase of the project (design, procurement, construction, delivery) must be completed before the next one begins. The entire plan is generally defined in the initial phase, with complete documentation and well-defined roles.
In the Agile model, the project is divided into small functional blocks (sprints), each completed, validated, and adapted based on continuous feedback. The focus is not only on adhering to the initial plan but on the progressive creation of value, with a team actively involved in all phases.
Moreover, compared to the traditional construction process, Agile management is also applied in the execution phase, focusing on creating an iterative approach, where teams break down their projects and continuously deliver small pieces, maintaining flexibility for the remaining work. The key objective is to continuously release small results to obtain constant feedback.
This way, it is possible to easily adapt future actions based on feedback and, if necessary, apply small modifications to what has been delivered, instead of executing extensive rework.
| Characteristic | Traditional Method | Agile Method |
| Planning | Completely ex ante | Iterative and continuous |
| Adaptability to changes | Poor | High |
| Client involvement | Initial and final | Constant and active |
| Communication between teams | Vertical and structured | Cross-functional and continuous |
| Partial deliverability | Only at the end of the project | Progressive, sprint by sprint |
| Quality control | Final verification | Continuous control |
| Risk of rework | High | Continuous control |
| Technologies and digital tools | Optional | Strongly recommended |
Agile or traditional: which approach to adopt and when
Choosing between an Agile approach and a traditional one depends on multiple factors, including the nature of the project, the level of uncertainty, the involvement required from the client, and the available organizational structure. The following table provides a practical overview to guide the choice based on the most common operational conditions.
| Choose Agile if… | Choose Traditional if… |
| The project is complex and evolving | The project is standard, well-defined, and stable |
| The client wants to be involved throughout the cycle | The client provides input only at the beginning and at delivery |
| You want to experiment with new technologies or processes | You prefer to follow established and contractual procedures |
| You can work with multidisciplinary and flexible teams | You have very structured roles and separate responsibilities |
Agile management is particularly suitable for all those complex projects, subject to frequent changes where collaboration is essential for the successful outcome of the project itself.
Among the various projects, certainly those of renovation are almost always subject to changes during the execution phase because in most cases it is difficult to have an in-depth knowledge of the current state: how many times does it happen that, for example, the systems have not been implemented as expected from the project documents?
The first step must always be a good level of planning and preliminary design, not forgetting safety, compliance, and quality control. From this essential foundation, collaboration and adaptability prove to be very useful: the development of faster and simpler work phases allows for adaptation to the changing needs of the client and the difficulties encountered on site.
The decomposition of work into simple cycles allows for better management of unforeseen events, preventing them from altering too large cycles, creating delays and cost increases. Furthermore, after each phase, it is useful to conduct an analysis with the clients, discussing any problems encountered and analyzing what could proceed more smoothly in the next phase.
Agile management of construction projects is based on a set of non-specific rules and practices aimed at modifying the work environment and the team’s objectives, instilling the right mindset in the team itself.
Among the tools and techniques of Agile construction, there are certainly:
- construction roadmap: the work team creates work activities that have well-defined characteristics and requirements. The definition of the sequence of execution of activities takes place based on the needs of the clients, in their presence, and allows for the creation of the roadmap itself;
- project sequencing plans: the project is divided into multiple work areas, measurable, usable, and segmentable pieces. They are deferred based on the phases; in fact, each phase will have separate sequencing plans, with separate areas, but any modification to one of the plans will entail an update to all the others;
- sprint planning: it is a process that involves all teams, as it represents the moment to discuss, divide, and sequence all work activities, in order to optimize the construction process and bring greater benefits to the client.
The use of Agile in the construction sector brings numerous advantages to the workflow, both for contractors and clients.
Among the benefits, we note:
- greater collaboration between parties: Agile allows for gathering feedback from clients and contractors, helping to ensure that everyone is on the same wavelength and minimizing the risk of interruptions during construction;
- greater communication: the methodology encourages transparency and continuous communication between parties;
- reduction of project delays due to rework: being more adaptable to changes, Agile management allows for better time management;
- provides value to the actual project: greater attention to feedback and the constant pursuit of improving the process allows for obtaining a higher quality final product;
- improves team performance: with better collaboration and sharing;
- improves management and organization of unforeseen events: through the use of constant reports on activities and processes;
- constant monitoring of processes: with greater transparency and control, intervening immediately in case of problems;
- implementation of new software technologies: capable of optimizing and simplifying construction processes at every stage.
Moving from theory to practical application of Agile in construction requires the adoption of appropriate tools and a change in management mindset. The Agile method works when supported by structured processes and digital tools capable of ensuring traceability, collaboration, and continuous adaptation.
The best way to successfully implement Agile in the construction sector is to rely on a construction management software. These digital tools allow for transforming the construction site into a transparent, monitorable, and highly collaborative operational environment. In particular, usBIM.resolver allows for:
- detection and recording of problems and non-conformities, assigning them to the direct responsible parties and tracking activities in real-time until resolution;
- storing all documentation in the cloud, accessible anywhere and with any device;
- effective communication through integrated chat with the entire team;
- annotating information directly on 2D drawings or BIM models, precisely geolocating non-conformities;
- using photos taken on-site to visually document the evolution of the construction site;
- managing workflows with a classic Kanban board or grid system, updating the status of activities (“draft,” “to do,” “in progress,” “completed,” “closed”;
- customizing activity cards with colors, tags, priorities, and deadlines, obtaining a clear view of progress and responsibilities.
These features ensure full control over the project, allowing real-time monitoring of progress, identifying bottlenecks, and intervening promptly on operational inefficiencies. To truly understand how these features can support an Agile approach on construction sites, watch the video below: a practical look at how to digitize workflow management, improve collaboration, and respond quickly to critical issues.
4 practical tips for adopting Agile in construction
To start off on the right foot in adopting the Agile approach, it is helpful to follow some fundamental best practices:
- collaborate constantly with the operational team and clients, creating a continuous and two-way communication flow;
- communicate immediately any doubts or obstacles, avoiding the accumulation of problems that could slow down processes;
- develop mental and operational flexibility, getting used to revising plans, workloads, and priorities based on emerging needs;
- leverage technology; try a construction management software to eliminate manual processes, increase productivity, and improve the quality of work on site.
What is Agile construction?
Agile construction is a project management method for building projects based on iterative cycles, constant collaboration, and continuous feedback. It draws inspiration from the principles of Agile software development and Lean thinking, applying them to the construction context to improve efficiency, flexibility, and quality.
How does Agile differ from the traditional approach?
Unlike the traditional waterfall model, which involves fixed and sequential planning, Agile breaks the project into functional blocks (sprints), facilitates continuous adaptation, and actively involves the client at every stage, even during execution.
In which phases of construction is the Agile approach most useful?
Agile is particularly effective in the early phases (design, pre-construction), where feedback can be gathered through models and drawings, but it is also applicable in the execution phase, thanks to the breakdown of work into agile and adaptable tasks.
Is the Agile approach suitable for renovations as well?
Yes, the Agile approach is ideal for renovation projects, which are often subject to unforeseen events. The breakdown of work into simple and flexible phases allows for quick adaptation to new needs or unexpected conditions.
What digital tools support Agile management in construction?
Construction management software, such as those equipped with Kanban boards, task tracking systems, annotations on BIM models, cloud management of documentation, and real-time communication, are essential for effectively applying Agile on construction sites.
What advantages does Agile construction bring to contractors and clients?
The Agile approach fosters greater collaboration between parties, reduces delays due to rework, improves final quality, optimizes the management of unforeseen events, and makes the process more transparent, monitorable, and responsive.
