BIM Content: Complete Guide to Understand, Find, and Manage BIM Content
Discover what BIM content is and how it improves reliability, efficiency, and coordination in construction projects with this comprehensive guide
In the daily work of a designer, it is easy to take for granted what appears on the screen of their PC: smart objects, parametric components, digital elements that “know” what they are and how they should behave within a model. But all this does not happen by magic. At the heart of a truly useful and functional BIM model are the so-called BIM content: structured digital content (such as doors, windows, systems, furniture) that not only describe the geometry of each element but also contain information about their technical, performance, and functional characteristics.
BIM content is essentially the digital building blocks with which an informational project is constructed. They are not simply 3D objects, but intelligent elements designed to integrate into a shared and interoperable data ecosystem. Choosing, creating, or correctly using these contents can make the difference between a coherent and coordinated project and a model that is difficult to manage, unreliable, or incomplete.
In this article, we aim to provide a clear and in-depth guide on the subject: we will explore what is really meant by BIM content, what characteristics they must have to be truly effective, and why they represent a key point for the success of any AEC project. We will also discover how BIM content is created, managed, and shared, and what benefits they can bring to the lifecycle of a construction project.
To fully leverage their potential, it is essential to have tools capable of managing them intelligently and integratively. Choose a 3D BIM building design software that natively supports parametric content, informational data, and collaborative workflows. Only then can you build truly reliable models, reduce errors during the execution phase, and optimize every stage of the project, from conception to maintenance.
What is meant by BIM content?
BIM content consists of intelligent digital objects that populate informational models. Defining them as “3D objects” would be reductive; BIM content are structured parametric entities capable of representing real building elements (such as doors, windows, walls, systems, or furniture) by integrating geometry, technical metadata, performance information, and functional behaviors.
Each BIM content contains attributes that determine its behavior within the model: it can react to dimensional changes, adapt to design constraints, communicate with other objects, or respond to specific modeling rules. This makes them fundamental tools not only for graphic representation but also for analysis, quantification, simulation, and project management.
BIM content can be divided into different types, depending on their role and level of detail:
- architectural and structural components: elements such as walls, floors, fixtures, stairs, or roofs. They often constitute the load-bearing structure of the model;
- MEP (Mechanical, Electrical, Plumbing) objects: represent mechanical, electrical, and plumbing systems, complete with functional data and connections;
- furniture and equipment families: include movable or fixed objects that enrich the space and affect the use of environments;
- complex systems and assemblies: groups of integrated components (such as curtain walls or modular systems) modeled as unique and parameterized entities;
- generic content or placeholders: used in preliminary phases to represent elements not yet defined but necessary for spatial or functional organization.
Example BIM object: window | usBIM.library
The variety of BIM content reflects the complexity of the design process and the need for consistent, updatable, and interoperable tools. For this reason, understanding the types and characteristics of BIM content is the first step towards truly effective and informed design.
Types of BIM Content
Importance of High-Quality BIM Content
The quality of BIM content directly affects the effectiveness and reliability of the entire information model. Poorly structured, overly heavy, or inconsistent content can compromise project management, slow down modeling processes, and generate errors during the execution phase.
High-quality BIM content is designed to be not only aesthetically correct and technically precise but also optimized, interoperable, and easily reusable. This means it must contain the right level of detail (LOD) for the design phase in which it is used, integrate data consistent with reference regulations, and be compatible with information exchange standards (such as IFC or COBie).
Using quality BIM content allows for:
- ensuring lightweight and high-performance models, avoiding overloads that slow down navigation or make the file unstable;
- improving coordination between disciplines (architectural, structural, mechanical), thanks to consistent and well-parameterized content;
- facilitating analyses and simulations, such as energy calculations, quantity takeoff, or regulatory checks, based on reliable data;
- minimizing errors on site and ambiguities in the execution documentation, thanks to objects that faithfully reflect the characteristics of real products;
- enabling facility management processes, allowing for the traceability of elements over time and improving post-construction management.
Investing in high-quality BIM content is therefore not a secondary detail, but a strategic choice that impacts the overall success of a project. It is what allows the transition from a simple digital model to a true integrated information environment, capable of supporting every phase of the life cycle of the work, from design to maintenance.
Best Practices for Creating and Managing BIM Content
Creating and managing BIM content effectively requires method, expertise, and a deep understanding of the digital tools used in BIM workflows. It is not enough to model a three-dimensional object: it is necessary to equip it with a coherent, structured, and context-appropriate information set.
One of the first best practices is to precisely define the level of detail (LOD) required, avoiding excessive modeling that unnecessarily burdens the file or, conversely, gaps that render it unusable. Each element should contain only the information necessary for its function and the design phase in which it is employed.
Another fundamental practice is to ensure the interoperability of the content, meaning their ability to be read, interpreted, and used by different actors and platforms within the construction process. For this reason, it is important to adopt and adhere to recognized standards, carefully choosing the BIM file formats most suitable for the project’s needs and capable of ensuring smooth, transparent, and reliable data exchange among all parties involved.
In the process of managing content, it is useful to create centralized and shared libraries, easily accessible within the project team. In this sense, having access to an advanced online library, with thousands of free BIM objects always available, represents a valuable support for completing and enriching models without having to create each component from scratch. Access to already structured and updated resources allows for maintaining consistency in models, reducing duplication of objects, and speeding up operational flows. Each BIM content should also be versioned, documented, and validated to ensure traceability and reliability over time.
Finally, it is good practice to accompany the content with descriptive metadata (category, manufacturer, article code, technical performance, reference standards) that facilitate searching, cataloging, and targeted use in different design contexts.
Following these best practices not only improves the quality of the information model but also helps create a more organized, collaborative, and efficient work environment, where BIM content becomes a strategic tool for the coordination and integrated management of the work.
If you want to discover how to create and manage a library of BIM objects or properly structure a library of IFC objects, watch the following video tutorials:
1 – Create and manage a BIM object library with usBIM.library
2 – Create and manage an IFC object library with usBIM.library
Where to find quality BIM content
Having quality BIM content is essential for developing accurate, coordinated, and up-to-date informational models. But where can these digital elements be reliably sourced? Today, there are numerous resources, both online and institutional, that allow industry professionals to access BIM content that is ready to use or easily adaptable to their project requirements.
Among the most common sources are the digital libraries provided by manufacturers of building materials and components, which offer content complete with technical data and certifications. This BIM content represents an excellent foundation for integrating real and updated objects into the model, useful in both design and execution phases.
Alongside the manufacturers’ libraries, there are specialized portals, collaborative platforms, and industry hubs that collect BIM objects classified by discipline, use, and format. These resources enable quick and targeted searches, facilitating the adoption of content that is consistent with regulatory standards and interoperable with the main modeling environments.
Finally, institutional databases and initiatives promoted by public entities and trade associations should not be overlooked, as they increasingly provide BIM catalogs structured according to national or international guidelines. Such resources represent a valid starting point to ensure quality, transparency, and consistency within the construction project.
Accessing the right BIM content means not only saving time in operational phases but also ensuring compliance with regulations, improving communication among teams, and building a solid, reliable, and truly informative digital model.
Online BIM libraries: how to use BIM content in projects
In the realm of digital design, access to updated, reliable, and consistent BIM content is a fundamental support. For this reason, online BIM libraries are playing an increasingly central role in the daily work of architects, engineers, and designers. These are specialized portals that collect thousands of ready-to-use BIM objects: parametric elements, construction components, systems, furnishings, and much more, often accompanied by technical, performance, and regulatory information.
These libraries allow you to save time in the modeling phases, while ensuring greater quality and consistency of the data entered into the model. Furthermore, they facilitate interoperability between different disciplines, as many contents are available in file formats compatible with multiple software. The adoption of content already structured according to recognized standards improves project accuracy and facilitates coordination among all involved parties.
Among the most interesting and comprehensive resources available online, you can find this BIM object library. This is a free portal, continuously updated, that provides thousands of BIM objects developed to support all phases of building design, from the initial concept to the management and maintenance of the work.
Online BIM library – interface usBIM.library
Every content is described in a detailed and structured way: parametric geometries, technical sheets, performance information, standard classifications, all within an ecosystem designed to ensure informational consistency and full interoperability. The library is perfectly integrated with ACCA’s 3D BIM design environment, but the contents can also be used in other software environments, thanks to the availability of various open and compatible formats.
This type of resource proves particularly useful not only for speeding up the modeling phase but also to ensure the quality and traceability of the data at every stage of the project. Centralized and free access to BIM objects also simplifies collaboration between designers, contractors, and suppliers, improving communication and consistency among different disciplinary models. The online BIM library thus represents a valid ally for all professionals who want to fully leverage the potential of BIM content, working with reliable, up-to-date tools that align with the modern demands of the construction industry.
For BIM content to fully express their potential, it is essential to have a working environment that ensures coherent, structured, and integrated management throughout the project’s life cycle. A 3D BIM building design software allows you to organize and make the most of parametric and informative contents, directly drawing from updated and certified online BIM libraries. This way, it is possible to improve model quality, facilitate coordination among professionals, and optimize the entire workflow. Relying on such a solution means enhancing data, optimizing processes, and increasing control over every stage of design. Try it for free for 30 days and discover how to transform your design approach in digital terms, making every phase of work more efficient, collaborative, and quality-oriented.
Read also What is BIM document management: managing documents in the BIM process
Successful Case Histories: How Manufacturers Benefit from BIM Libraries
The true value of a BIM object library is measured not only by its technical capabilities, but by the tangible results achieved by manufacturers that choose to digitize their product catalogs. By integrating 3D models with structured technical data in usBIM.library, manufacturers can turn product information into accessible, specification-ready content that can be directly incorporated into tenders, design workflows, and executive projects.
The experience of leading companies in the construction and building services sectors — including Baltur, Hoval, and Chromology Italia — demonstrates how BIM content can help bridge the gap between product manufacturers and the professionals who specify and use their products throughout the design process.
Baltur: Digitalization of heating systems and Super Low NOx burners
Baltur represents an Italian excellence active in over 60 countries, with a strong focus on technological innovation and energy sustainability. The company has been a pioneer in the development of class 4 Super Low NOx burners, as well as producing a wide range of residential solutions, heat pumps, and hybrid systems.
Baltur’s entry into usBIM.library stems from the need to allow designers and thermotechnicians to access product data independently, speeding up the selection process and eliminating the waiting times for direct consultancy.
- Autonomy for professionals – technicians can retrieve 3D objects complete with performance data and immediately insert them into their energy or plant models;
- Widespread specification – the presence of official data within the design environment encourages the thermotechnician to evaluate and include Baltur solutions from the early stages of the project;
- Continuous technical support – the strategic collaboration with ACCA technicians has ensured a flexible and timely process for loading and constantly updating digital libraries.
Hoval: From Doxa research to optimizing work for thermotechnicians (NZEB Solutions)
Hoval, a multinational group headquartered in Liechtenstein with an Italian branch in Zanica (in a certified NZEB CasaClima Gold structure), is synonymous with excellence in industrial and residential heating and air conditioning. From the range of Ultragas 2 condensation generators to patented air distribution systems like Air Injector and heat pump technologies, the company’s approach is strongly oriented towards consultancy and decarbonization.
The decision to integrate Hoval products into the usBIM.library database arises from the results of a statistical survey conducted with Doxa, which revealed that ACCA software is among the most widely used in Italian design studios.
- Simplification of workflow – today, the designer must face mechanical complexities and ongoing regulatory updates; having Hoval 3D blocks and data directly in the software eliminates downtime for research;
- Accuracy and profitability – the availability of precise and complete BIM objects allows for time-efficient modeling, improving overall efficiency and the profitability of the design studio’s activities;
- Consolidation of the network – the presence in the library strengthens the trusting partnership between the company and its extensive network of partner designers.
Chromology (Settef and Viero): Integrated packages and ETICS insulation systems
Chromology Italia, part of the international Nippon Paint group (the fourth largest player globally in the paint and construction sector), includes historical and reference brands for building envelopes such as SETEF (with over 60 years of experience in thermal insulation systems) and Viero.
In addition to producing finishing and insulation systems, the company differentiates itself primarily through training and technical know-how (via the Cromocampus center). In approaching usBIM.library, Chromology has surpassed the traditional concept of “single BIM object,” introducing a true methodological innovation for energy calculation:
- Creation of “System Packages” – instead of publishing individual products, Chromology has developed entire stratigraphies and complete systems for thermal insulation (17 insulating systems, 10 of which are certified), available for download by designers;
- Coverage of project specifications – the BIM packages include data related to thermal performance, fire safety (reaction to fire), and compatibility with complex supports (e.g., wooden structures);
- Guarding the preventive phase – considering the importance of the preventive phase (which accounts for over 50% of a construction site’s success), the presence on usBIM.library ensures Chromology direct contact with a wide array of technicians, confirmed by the positive download and view data recorded by the platform.
FAQ – BIM content
What are BIM content?
BIM content are parametric digital objects that integrate geometry and informative data. They serve to represent real elements within a BIM model and support the phases of design, construction, and management of the work.
What is the difference between CAD objects and BIM objects?
CAD objects are simple 2D or 3D geometric representations, lacking informative data. BIM objects, on the other hand, are intelligent components that include technical, performance, and functional information, becoming an active part of the informational model.
Are BIM contents always compatible with each other?
No, compatibility depends on the formats and standards adopted. To ensure interoperability among different software and actors, it is advisable to use open formats like IFC.
What does it mean to ensure interoperability of BIM content?
It means ensuring that BIM contents can be used and exchanged seamlessly among different software and professionals, thanks to the adoption of common standards and suitable formats.
Are there regulations for BIM content?
Yes, there are standards such as ISO 19650, ISO 23386/23387, etc., which define the rules for creating, using, and sharing BIM content in a standardized and interoperable way.
How important is the quality of BIM content in the life cycle of the work?
The quality of BIM content is essential to ensure design coherence, reduce errors during execution, and facilitate the management and maintenance of the work over time.
How can I find reliable BIM content for my projects?
You can access reliable BIM content through digital libraries from manufacturers, specialized platforms, and institutional databases, which offer updated objects compliant with standards.
What advantages do online BIM libraries offer?
Online BIM libraries save time in modeling, ensuring the use of always updated, standardized, and compatible contents with different design software.
What does LOD mean in BIM content?
LOD (Level of Development) indicates the level of graphic and informative detail of a BIM content. Each design phase requires a specific LOD to avoid excesses or deficiencies in information.
How can I optimize the management of BIM content in projects?
For effective management of BIM content, it is useful to adopt centralized libraries, comply with interoperability standards, and use digital tools that facilitate the organization and updating of contents throughout the project’s life cycle.
