  • BIM news
  • BIM projects
  • EN
  • Menu Menu
List List Menu
  • BIM and Construction Sites
  • BIM and Building Design
  • BIM in Construction
  • BIM and Estimation
  • BIM and Energy
  • BIM and Safety
  • BIM and MEP
  • BIM and Facility Management
  • BIM and training
  • BIM and GIS
  • BIM and Infrastructure
  • BIM and technical standards
  • IFC and openBIM
  • Digital Twin
Home » IFC and openBIM » IFC and classification systems in the construction industry
SfB, UniClass, UniFormat, MasterFormat, OmniClass: all you need to know about IFC and construction classification systems
Editorial Team / 7 April 2026
In the world of Building Information Modeling (BIM), the structured management of information is key to ensuring consistency, interoperability, and data quality throughout the life cycle of the project. In this context, classification plays a central role: it allows for the unique organization and coding of information, promoting collaboration among different actors in the construction process and improving communication between various software and platforms.
But what exactly is a classification in BIM, and why is it so important in IFC models?
In this article, we will explore the main classification models, analyze the most widely used classification systems, and discover how they are applied in IFC models.
Finally, we will see how an IFC viewer allows you to easily create, modify, and verify classifications directly within a 3D model.
  • What is a classification in BIM and why is it fundamental in IFC models
  • Classification models: hierarchical-enumerative and analytical-synthetic
  • Most common construction classification systems and their application in IFC models
  • The ISO 12006-2 standard: general framework of BIM classification systems
  • IFC and classification: how IfcClassificationReference works
  • How to create and modify classifications in an IFC model
  • Verify and read the assigned IFC classifications
  • Download example files and software
  • FAQ on IFC classification
The term classification refers to all those activities or processes necessary for knowledge management. Processes and activities generally perform actions that fullfill order data, of whatever nature, in appropriate classifications (classes, sections, categories or species) that are associated by relationships and connections.
To be considered valid, a classification system needs to meet the following requirements:
  • stability: it needs to be applicable in any context without undergoing substantial changes;
  • flexibility: it needs to be extensible with the possibility of adding new parts.
Aristotle was the first to introduce a system of knowledge organization when he dealt with the classification of living beings, dividing them into two main groups, plants and animals, and then into subgroups. He was the first taxonomist (from the Greek taxis, arrangement and nomos, method or rule), organizing information in a hierarchical structure.
Today, generally speaking, taxonomy indicates any organization of entities or concepts organized hierarchically in a structure that resembles the shape of a tree. The most general category is represented by the root node. From the root node, through the parent categories to the child subcategories, you get to the leaf nodes that represent the objects in detail.
Primarily, objects can be grouped according to 2 organizational models:
  • hierarchical-enumerative classification;
  • analytical-synthetic classification (or faceted).
How does the hierarchical-enumerative classification work
The hierarchical-enumerative system is a more traditional classification system based on taxonomy. Through a rigid and one-dimensional hierarchical structure with strong vertical development, each element is classified under a single category. All categories are connected through an organization of subsets, as in a game of Chinese boxes.
Each classified element has a unique position in this hierarchy and can be found through a step-by-step path, which goes from the most general set of elements to the most specific ones.
Examples that belong to this type of classification can be family trees or the division of books into chapters, subchapters, paragraphs, sentences, words, letters. However, this system implies a certain rigidity and difficulty in the case of modifications and additions of new elements.
IFC and classification systems in the construction industry | Hierarchy enumeration tree
What is analytical-synthetic classification (or “faceted”)
This classification system is more elastic as it leaves the enumerative and hierarchical system in favor of a methodology consisting of flexible and open schemes with horizontal development. These schemes are more easily adaptable in case of subsequent modifications.
The object to be classified is no longer described by a single pre-eminent characteristic which represents it and which determines its location in a specific place in a data hierarchy; the object is simultaneously identified and described by several non-overlapping characteristics, called “facets” .
All this establishes an open system that can always be increased with new descriptive object characteristics.
The object described is easily identifiable by multiple search accesses provided by a single feature or by the aggregation of multiple characteristics.
Example of faceted classification
In pre-digital times, there have been different attempts to codify information and data classification systems in the construction industry. In some cases, they result closer to the hierarchical-enumerative model rather than to the “faceted” model, or they may have included both of them.
In this focus we’ll analyze some of the most known classification systems, such as:
  • SfB (Samarbetskommitten for Byggnadsfragor)
  • UniFormat;
  • MasterFormat;
  • Uniclass;
  • Omniclass.
SfB (Samarbetskommittén för Byggnadsfrågor): “table-based” structure and combinable codes
The SfB (Samarbetskommitten for Byggnadsfragor) classification plan was firstly prepared in the 1940s and was commissioned by the coordination committee for Swedish construction. Updated and further developed in the following years, this classification and coding plan for the building industry was exported to various European countries.
The SfB plan way of operating can be defined as “faceted”: practically every single part or component of the project can be broken down into 4 reading levels called “tables”.
TABLESCLASSIFICATIONCODE
Table 0 (Natural and built environment)Land use planning and building typesPair of numbers
Table 1 (Building elements)Parts of the buildingIn function and in the order of their constructionPairs of numbers in round brackets
Table 2 (Building activities)Types of workWith reference to the physical aspect of the relating materialsAlphabetic capital letter
Table 3 (Building resources)Types of materialIn relation to their natureLower case alphabetical letter + number from 1 to 9
Table 4 (Activities and requirements)Construction activity and use of resourcesCapital letter in brackets
Each characteristic, belonging to one of the 4 tables, is marked with a code.
The code assignment to each characteristic makes the identification of subjects and actions unequivocal, while the possibility of associating the tables with one another enables new combinations for data classifications that are not yet existing but possible.
A practical example of SfB classification
Let’s suppose we have a SfB code like:
52 (35) Rr1 (P)
The following information will correspond to this code:
  • 52 corresponds to Show buildings and equipment from the Table o;
  • (35) refers to False Ceilings from Table 1;
  • R indicates slabs and panels from Table 2;
  • r1 corresponds to clay, plaster, magnesium and plastic binders from Table 3;
  • (P) indicates Sound and silence from Table 4.
The code consists of numbers and letters, each of which indicates a process, equipment, material, space, etc.
Those who deal with the processing (in this case creating a false ceiling) will look for the project documents which, combined with Table 1, show code (35); an acoustics engineer will take into consideration documents in Table 4 which contain the P code, and so on.
UniFormat: classification of construction elements into groups and subgroups (A10, A1010, etc.)
UniFormat was first adopted in America in 1973 as a tool for classifying construction elements and related processes. This classification system is based on 2 elements:
  • the classification structure is hierarchical-enumerative;
  • the classified objects were chosen based on the ratio of cost incidence and frequency of use.
UniFormat classification is based on three main levels of objects:
  • level 1: collects the main groups of objects (foundations, envelope and partitions);
  • level 2: represents a breakdown of the first level into subgroups;
  • level 3: specifies the objects contained in the second level.
Below a table with some of the categories of the UniFormat classification system.
Level 1
Major Group Elements
Level 2
Group Elements
Level 3
Individual Elements
A – SubstructureA10 – FoundationsA1010 – Standard Foundations
A1020 – Special Foundations
A1030 – Stab on Grade
A20 – Basement constructionA2010 – Basement Excavation
A2020 – Basement Walls
B – Shell
B10 – Super StructureB1010 – Floor Construction
B1020 – Roof Construction
B20 – Exterior Enclosure
B2010 – Exterior Walls
B2020 – Exterior Windows
B2030 – Exterior Doors
B30 – RoofingB3010 – Roof Coverings
B3020 – Roof Openings
C – InteriorsC10 – Interior ConstructionC1010 – Partitions
Ecc. ecc.
The elements subdivision in the table, from the widest category up to the detail element, is highlighted in different colours, for example: The Substructure category is marked with a capital letter A and is specified in the two sub-categories of the Foundations and Basement construction. The Foundations subcategory is marked with the code A10. This latter one includes the individual Standard Foundations element marked with the code A1010.
As for the other classification systems, each element is associated with an alphanumeric code based on the specific level of information.
This classification system should be given credit for having enhanced the analytical efficiency of the production process.
The image below shows how to classify any entity (for example a roof) in an IFC model.
You can try to classify the elements of any 3D model yourself (IFC, DWG, SKP, etc.), using usBIM.viewer+ for free. Simply open a file, (here you can download an example file) and select the “Edit” command in the “Classification” section from the ribbon bar.
IFC and classification systems in construction
IFC and classification systems in construction | Example of UniFormat classification with usBIM.viewer+
MasterFormat: classification by divisions and sections (Division 03 – Concrete, Division 05 – Metals, etc.)
MasterFormat was published in 1963 and updated in 1974 by the North American research institutes CSI (Construction Specification Institute) and the CSC (Construction Specification Canada).
MasterFormat is currently the most widely used classification system in the construction industry in the United States of America and Canada. This classification system has a peculiar hierarchical structure that is divided into groups and subgroups which are not numbered.
On the contrary, the “divisions” associated with the subgroups are numbered. Each division, in turn, is divided into “sections” marked by a six-digit number.
Specifications Group
General Requirements Subgroup
Division 01 – General Requirements
Facility Construction Subgroup
Division 02 – Existing Conditions
Division 04 – Masonry
Division 06 – Wood, Plastics and Composites
Ecc. ecc.
Process Equipment Subgroup
Division 40 – Process Integration
Division 41 – Material Processing and Handling Equipment
Division 42 – Process Heating, Cooling, and Drying Equipment
Ecc. ecc.
IFC and classification systems in construction | Example of MasterFormat classification with usBIM.viewer+
UniClass 2015 and OmniClass: advanced systems based on faceted schema and interoperability with IFC
Among the most advanced and widely used classification systems in the BIM field, UniClass 2015 and OmniClass represent the reference models for structured and interoperable management of building information.
Both are based on a faceted schema, which allows for the description of an object or concept through a combination of independent characteristics (the “facets”), thus providing flexibility and a level of analysis impossible in purely hierarchical systems.
UniClass 2015, developed in the United Kingdom and updated to the current version, is a dynamic system based on 11 tables (Complexes, Entities, Activities, Spaces, Elements, Systems, Products, etc.) that allows for consistent classification at every level of information, from the overall project down to the individual construction components. Each element is identified by an alphanumeric code that describes its context, function, and type, facilitating data integration within IFC models and interoperability among software and disciplines. Thanks to its modular and updatable structure, UniClass 2015 is now the reference standard for the digitalization of construction processes in the UK and for the information management of BIM models.
OmniClass, on the other hand, is the North American counterpart of the British system. Derived from the ISO 12006-2 standard, it is organized into 15 tables covering the entire life cycle of a construction project (from design to management, to decommissioning) and classifies everything related to a project: entities, spaces, elements, products, materials, processes, and professional roles. The combinatorial nature of the tables allows for the creation of unique, scalable codes adaptable to any level of detail.
Both systems perfectly integrate with the IFC standard, which allows you to associate an internationally recognized classification code with each entity in the model. Through the IFC editor, you can add, modify, and read UniClass or OmniClass classifications directly within the IFC model, ensuring a common language among designers, companies, and managers.
Thanks to their open, interoperable structure compliant with international standards, UniClass 2015 and OmniClass today represent the basis for a truly collaborative approach to BIM, promoting traceability, data standardization, and efficiency throughout the life cycle of the project.
Let’s now move on to analyzing ISO 12006 which we can define as the framework of all classification systems in construction. The first version of ISO12006 was written by the International Organization for Standardization and published when international systems for the standardization of classification systems were still lacking. Revised subsequently while keeping pace with technological progress and the development of different classification systems, the purpose of ISO 12006-2 is to create structures or better tables through which to classify types, elements and relationships based on a particular specialization.
The following tables describe the entire construction process of a building, from the preliminary design phase, to construction and maintenance.
A.1 Construction entities (by form)
  • Buildings
  • Pavements/landscaping
  • Tunnels (and other underground constructions)
  • Embankments, retaining walls, dams
  • Tanks, silos, ecc.
  • Bridges, viaducts, ecc.
  • Towers, masts, superstructures
  • Pipes, ducts, cables
A.2 Construction entities (by function or user activity)
  • Hospital buildings
  • Health centre buildings
  • Footbridges
  • Airport terminal buildings
  • School buildings
  • Ecc.
A.3 Construction complexs (by function or user activity)
Fino ad arrivare ad elementi di dettaglio
A.7 Elements (by characteristic predominating function of the construction entity)
  • Floors
  • Roofs
  • Columns
  • Ecc.
A.8 Designed elements (element bytype of work)
Alle relazioni e agli attori che legano i processi costruttivi.
A.10 Management processes (by type of process)
  • Administrative management
  • Financial management
  • Marketing/sales management
  • Ecc.
A.15 Construction agents (by discipline)
  • Clients
  • Architects
  • Civil engineers
  • Ecc.
The ISO12006-2 classification methodology is that of a hierarchical structure that branches out at different levels and proceeds gradually from more general to more detailed information. However, this system still limits itself to providing basic principles, resulting an incomplete and operational classification system.
IfcClassification and IfcClassificationReference entities in the IFC schema
The IFC standard also uses data classification tools to communicate information useful in the construction process and not expressed by a standard language.
It is evident that, in many cases, it may be necessary to add information to the model, implementing the data already present expressed by the standards.
This operation involves the use of a language not encoded by the IFC standard where the vocabulary to be adopted should be agreed upon and disclosed to all interested parties (during the design, execution, maintenance and dismissal phases).
The IfcClassificationReference class is a form of “lightweight” classification that allows you to break down a building into parts (defined according to the type of classification chosen).
This classification improves model reading by adding details to its entities, while providing the possibility of selecting them in an easy manner. For example, by assigning a different classification to the single-leaf and to double- hinged windows, we could simply select them and have a more detailed picture of the information relating to “window” objects.
How to create new classifications in an IFC model?
Below we’ll show you how to do it with a practical example. Follow these steps:
  • download and install usBIM.viewer+ for free
  • click on File>Open and select the IFC file to upload
  • click Edit IFC>Edit to edit the model
  • select (manually or with the help of selection groups) the objects to which add a classification
  • click on Edit from the toolbar in the Classifications section
  • from the pop-up dialog box, choose the type of classification (Masterformat, Omniclass, Uniclass, etc.) and the associated subcategories
  • once concluded the operation, click on Confirm.
IFC classification systems
Setting up IfcClassificationReference in usBIM.viewer+
Find out more about usBIM.viewer+ and download it for free
After you have selected the entity of your interest, you can read the information you have just assigned in the Properties toolbox on the right-hand side:
  • IfcClassificationReference expresses the code that corresponds to the information that we have added
  • IfcClassification expresses the type of classification adopted.
If you receive an IFC file (generated by any software) containing object classifications, you can verify this information in the following way:
  • open the file with usBIM.viewer+
  • select an entity
  • read the following values from the properties toolbox:
    • IfcClassificationReference contains the code
    • IfcClassification contains the classification system.
Verification of entities classification with usBIM.viewer+
In the image above you could observe how the selected window has been classified with the code Ss_25_30_95_26 that refers to the UniClass 2015 system.
IFC file example
Read the in-depth article: “openBIM standards”
What is classification in BIM and why is it essential in IFC models?
The term classification refers to all activities or processes required for knowledge management, which organize data into appropriate catalogues (classes, sections, categories, or types) linked through relationships and connections. A robust classification system must be both stable and flexible, so it can be applied in any context and extended with new components. In BIM, classification is essential in IFC models because it enables the structured and unambiguous organization of information, improving communication among stakeholders in the construction process and enhancing interoperability between software platforms.
What are the main classification models used in BIM?
In general, objects can be grouped according to two main organizational models: hierarchical-enumerative classification and analytical-synthetic (or faceted) classification. The former uses a rigid, single-dimensional structure, where elements are classified under a single category in a hierarchical manner. The latter, instead, is more flexible and describes each object through multiple independent characteristics (‘facets’), making the system more adaptable and extensible.
How does hierarchical-enumerative classification work?
Hierarchical-enumerative classification is a traditional system based on a rigid hierarchical structure, in which each element belongs to a single category. Categories are linked by subset relationships, similar to a family tree or the division of a book into chapters and paragraphs. Each element has a unique position within the hierarchy and can be traced through a path from the general to the specific.
What is analytical-synthetic or faceted classification?
Analytical-synthetic classification, also known as faceted classification, is an open and flexible system that describes an object through multiple independent characteristics (the ‘facets’). Each facet represents a specific aspect of the object and can be combined with others to achieve more detailed classifications. This approach allows for easy adaptation to changes and new categories, improving search capabilities and information management.
What are the main building classification systems and how are they applied in IFC models?
The main building classification systems include SfB, UniFormat, MasterFormat, UniClass, and OmniClass. Each of these is based on different logical approaches (hierarchical-enumerative or faceted), but all can be applied to IFC models to structure data and facilitate communication among professionals. Classification codes are assigned to model objects (walls, windows, foundations, etc.), clarifying their function and enabling advanced queries and data analysis.
What is the SfB (Samarbetskommittén för Byggnadsfrågor) system?
The SfB classification system, developed in Sweden in the 1940s, is one of the earliest classification systems in the construction sector. Based on a faceted structure, it organizes project elements into four main tables: environment, building elements, construction activities, and resources. Each feature is identified by a code, facilitating its identification and association with other tables to create new classification combinations.
How does the UniFormat system work?
UniFormat is a U.S. classification system developed in 1973 that classifies building elements and related construction activities based on groups and subgroups. It uses a hierarchical-enumerative structure divided into three main levels (groups, subgroups, individual elements) and alphanumeric codes such as A10, A1010, etc. It is particularly useful for cost estimation and for organizing information within BIM projects.
What is the MasterFormat system?
MasterFormat is the most widely used classification system in North America, developed by CSI and CSC. It organizes information into numbered “divisions” (e.g., Division 03 – Concrete, Division 05 – Metals) and six-digit “sections.” It is designed to support the management and standardization of technical specifications and can be integrated with IFC models to improve communication between designers and contractors.
What is the difference between UniClass 2015 and OmniClass?
UniClass 2015, developed in the United Kingdom, and OmniClass, widely used in North America, are both based on a faceted schema that allows information to be classified through multiple independent characteristics. UniClass 2015 is structured into 11 tables (Complexes, Entities, Activities, Spaces, Elements, Systems, Products, etc.), while OmniClass includes 15 tables covering the entire building lifecycle. Both are interoperable with the IFC standard and represent a common language among designers, contractors, and facility managers.
What is the role of ISO 12006-2 in BIM classification systems?
ISO 12006-2 provides the international reference framework for classification systems in the construction industry. It establishes the conceptual foundations and tables for classifying entities, elements, and construction processes according to a hierarchical structure. Although it is not directly used as an operational standard in BIM models, it represents the foundation of modern classification systems such as UniClass and OmniClass, ensuring consistency and international compatibility.
How does classification work in IFC standards?
In IFC standards, classification is managed through the entities IfcClassification and IfcClassificationReference, which allow additional information to be assigned to model entities. These classes enable the decomposition of the building into parts according to the selected classification system, improving readability and object selection. For example, it is possible to distinguish between single-leaf and double-leaf windows to analyze data in greater detail.
How are classifications created and modified in an IFC model?
To create or modify classifications in an IFC model, tools such as usBIM.viewer+ can be used. After opening the IFC file, simply select “Edit IFC > Edit,” choose the objects to classify, and, in the “Classifications” section, click on “Edit.” Then select the classification system (e.g., MasterFormat, UniClass, OmniClass) and confirm. The assigned information will then be visible in the property toolbox as IfcClassificationReference and IfcClassification.
How can you verify and read classifications assigned to an IFC file?
To verify the classifications of an IFC file, simply open it with an IFC viewer such as usBIM.viewer+, select an entity, and check the IfcClassificationReference (assigned code) and IfcClassification (adopted classification type) fields in the property toolbox. This allows you to verify data consistency and facilitates information exchange among project stakeholders.
usbim-viewer
usbim-viewer
Share this entry
  • Share on Facebook
  • Share on X
  • Share on WhatsApp
  • Share on LinkedIn
  • Share by Mail
Related posts
    27 August 2026
  • ACCA software in South America: advancing openBIM® and Digital Twin workflows
  • 27 August 2026
  • What is ifcOWL and what are its benefits in BIM
  • 24 August 2026
  • ACCA software at BIM World Copenhagen: OpenBIM & GIS
  • 20 August 2026
  • Common Issues in IFC File Editing and How to Address Them
Follow us on
  • Construction Sites
  • Energy
  • Estimation
  • Infrastructure
  • Safety
  • Structural Calculation
  • Technical standards
  • Training
  • BIM news
  • BIM project example
  • Digital Twin
  • IFC and openBIM
Scroll to top
