Lean Maintenance, What is it and when to implement it
Lean Maintenance is a strategy that aims to reduce waste and inefficiencies in the management of physical resources. Find out how to implement it!
Lean logic has been applied since long time in the production sector to streamline all processes and reduce waste without, however, sacrificing the quality of the final product. What you may not know is that the success of Lean Production is based on the implementation of strategies dedicated to keep tools and plants in a state of maximum efficiency.
The objective of this article is, in fact, to make you discover all the advantages and potential of the so-called Lean Maintenance. It involves the application of “lean” principles and methods to the management and maintenance of the company assets. Lean Maintenance represents an essential prerequisite to ensure the success of each organization.
Before showing you how to implement this maintenance strategy, I recommend you try a Facility Management software, a very powerful and easy to use tool. Through a series of integrated functions and centralized information management it helps you to achieve the objectives of Lean Maintenance with maximum efficiency and simplicity.
What is the Lean Maintenance
Lean Maintenance, is an approach to managing a company’s physical resources and capital goods. It aims to eliminate unnecessary activities from day-to-day operations by reducing time waste and improving the overall efficiency and productivity of the organization.
Although this strategy is often referred as a subset of Lean Production, exactly the opposite is true. In fact, in order to be successful in lean production, it is first of all necessary to apply the “lean” principles to the management and maintenance processes of industrial plants and machinery.
In the “lean” logic, waste refers to the excessive use of resources (such as time, labor, energy, etc.) that does not add any value to the final product or service. With particular reference to the maintenance sector, inefficiencies and waste are due to:
- reducing unplanned downtime;
- excessive maintenance;
- automated creation of work orders;
- mismanagement of inventory;
- the unnecessary accumulation of stocks and spare parts;
- to the extra costs for the repair of defects and the correction of maintenance errors.
The implementation of Lean Maintenance allows you to avoid these problems at the origin. In fact, it allows the identification and elimination of actions that cause a waste of the internal resources of the organization. This is obtained by improving inefficient processes and optimizing the management of work orders.
Lean Maintenance qualified technician at work
What are the 5 Principles of Lean Maintenance?
Lean maintenance practices are based on the application of five essential principles, illustrated below:
- Total Productive Maintenance (TPM), it optimize the effectiveness and reliability of production equipment, through the involvement in the maintenance processes of all the subjects operating at different levels of the production system (operators, technicians, executives, etc.). The aim of this strategy is to minimize fails, leaks, breakdowns and other incidents;
- Reliability Centered Maintenance (RCM),is a process that ensures that maintenance activities are performed efficiently, economically, reliably, and safely. The RCM approach is used to monitor physical resources in their current operating conditions in order to predict maintenance requirements;
- 5S process: it is a methodology that involves the systematic implementation of five activities for the workplace management that allow to improve the overall efficiency of the plant. The “S” refers specifically to five Japanese words that literally mean:
- Seiri (Separate), identify and remove everything that is not necessary from the work environment;
- Seiton (Reorder), arrange in an orderly and accessible way all the tools;
- Seinso (deep Clean), clean and inspect the workplace and any machinery frequently;
- Seiketsu (Standardize): establish schedules and procedures to repeat the first three activities “S”;
- Shitsuke (Support): continue to support the process of improvement through the establishment of behavioral habits;
- Just in Time (JIT) is a concept that refer to inventory activities. Companies use this methodology to reduce waste during the production process by receiving goods in stock only when necessary. In lean maintenance, operators plan repairs as accurately as possible so that the various interventions are carried out only when due (neither too early nor too late) and that spare parts are made available at the exact time they need to be used;
- Waste elimination: the lean maintenance procedures are based on the elimination of all those phases of the process that do not add any value to the final product, and that can be classified into seven different types of waste:
- overproduction;
- excessive downtime;
- unnecessary storage;
- reworkings;
- presence of defective parts;
- non-optimized transport;
- unnecessary movements.
The principles of Lean Maintenance
What are the advantages of lean maintenance
The implementation of Lean Maintenance allows you to obtain numerous advantages, including:
- minimizing maintenance costs, both direct (required for labour and resources) and indirect (due to unplanned downtime);
- the elimination of waste, especially the use of JIT logic avoids keeping expensive stocks longer than necessary;
- reducing inefficient activities, with practices that allow you to eliminate or modify processes that take too long to complete;
- the reduction of emergencies, the use of a proactive approach allows to solve any problems before they turn into failures;
- continuous involvement of employees, in fact, appropriate training processes aim to train operators to act decisively when problems arise.
The sectors that benefit the most from Lean Maintenance
The industries that gain the most from Lean Maintenance are those that heavily rely on equipment availability, operational efficiency, and cost reduction. The main sectors include:
- Manufacturing – reduces downtime, improves equipment reliability, and minimizes waste in production lines.
- Automotive – increases production efficiency, reduces maintenance costs, and optimizes spare parts management.
- Aerospace and Defense – ensures high reliability, safety, and compliance with strict maintenance regulations.
- Energy and Utilities – improves asset management, reduces unexpected failures, and increases operational efficiency.
- Oil and Gas – strengthens predictive maintenance strategies, reduces risks, and minimizes downtime in critical operations.
- Healthcare and Pharmaceuticals – ensures the reliability of medical equipment, reduces operational costs, and improves regulatory compliance.
- Food and Beverages – maintains production efficiency, reduces waste, and ensures compliance with hygiene standards.
- Logistics and Transportation – improves fleet management, reduces failures, and optimizes maintenance scheduling.
- Construction and Heavy Machinery – extends the lifespan of machinery, reduces costly repairs, and improves project completion times.
How to Implement Lean Maintenance
Generally speaking, the implementation of Lean Maintenance implies moving away from traditional resource allocation schemes. It is carried out by assigning a proactive role to the maintenance department, so that it can participate in the improvement of production processes.
The implementation process usually begins with a maintenance audit that aims to identify the department’s strengths and weaknesses. Based on the results obtained in this first phase, the following fundamental steps are:
- definition of standardized practices aimed at extending the service life of equipment and spare parts;
- strengthening and developing these practices improve response capacity and reduce the frequency of interventions;
- experimenting with planned preventive strategies to find the right balance of services that prevent emergencies without overloading equipment;
- assign routine maintenance operations to the production department to allow the maintenance team to devote itself to the most serious problems;
- search for more efficient alternatives in the choice of equipment for repairs and cleaning of machinery and workplace;
- improvement of inventory and inventory management methods.
To apply the lean approach to maintenance processes it is essential to use a CMMS (Computerized Maintenance Management System) software as it is the only tool able to support the steps described above.
Since not all CMMS systems are equally effective in the development of lean maintenance, it is important to choose solutions that meet certain criteria and are therefore:
- easy to use, to help facility managers in carrying out the different activities;
- cloud-based, to enable use from any mobile device;
- able to offer simplified and standardized processes for work order and inventory management;
- able to provide reports and historical data on maintenance operations.
You should rely on the potential of a Facility Management software and start experimenting with the advantages of Lean Maintenance right away. With the help of this tool you can manage your activities from a single centralized platform and in the cloud. It will also provide you with the support you’ll need to make your maintenance processes even more streamlined and efficient.
What technologies support the implementation of Lean Maintenance?
The implementation of Lean Maintenance is supported by various advanced technologies that enhance efficiency, reduce waste, and optimize resource management. Here are the main ones:
- CMMS (Computerized Maintenance Management System) – software that helps manage work orders, inventory, and maintenance scheduling in a centralized and digital manner.
- IoT (Internet of Things) – smart sensors applied to machinery to monitor operational conditions in real-time and prevent failures.
- Predictive Maintenance (PdM) – use of AI and machine learning to analyze operational data and predict when equipment might fail.
- Digital Twin – creation of a digital model of machinery and plants to simulate scenarios, test maintenance strategies, and optimize performance.
- Big Data & Analytics – collection and analysis of historical and real-time data to identify inefficiencies, improve planning, and reduce costs.
- Mobile Maintenance – applications on tablets and smartphones that allow technicians to access data, update interventions, and report issues directly in the field.
- Augmented Reality (AR) and Virtual Reality (VR) – technologies that support staff training and remote assistance in maintenance processes.
- 3D Printing – allows for the rapid production of spare parts, reducing wait times and inventory costs.
- Automation and Robotics – automatic systems for autonomous maintenance of equipment, reducing human involvement in repetitive or dangerous tasks.
- Cloud Computing – enables access to maintenance data anywhere and facilitates integration between different business systems.
The integration of these technologies allows companies to optimize maintenance processes, reduce costs, and improve plant reliability.
FAQ
What is Lean Maintenance?
Lean Maintenance, or lean maintenance, is an approach to managing the physical resources and instrumental assets of a company aimed at eliminating unnecessary activities, reducing waste, and improving overall efficiency and productivity.
What are the 5 principles of Lean Maintenance?
The 5 fundamental principles of Lean Maintenance are:
- Total Productive Maintenance (TPM).
- Reliability Centered Maintenance (RCM).
- 5S Process (Seiri, Seiton, Seinso, Seiketsu, Shitsuke).
- Just in Time (JIT).
- Elimination of waste.
What are the benefits of implementing Lean Maintenance?
The main benefits of Lean Maintenance include reduced maintenance costs, elimination of waste, decreased inefficient activities, reduced emergencies, and greater employee engagement.
How to implement Lean Maintenance?
Implementing Lean Maintenance begins with a maintenance audit and continues with the definition of standardized practices, the development of preventive strategies, involving the production department in routine maintenance, and optimizing inventory management. A CMMS software is essential to support these processes.
What sectors benefit the most from Lean Maintenance?
The sectors that benefit the most from this approach are as follows:
- manufacturing;
- automotive;
- aerospace and defense;
- energy and utilities;
- oil and gas;
- healthcare and pharmaceuticals;
- food and beverages;
- logistics and transportation;
- construction and heavy machinery.
What waste does Lean Maintenance eliminate?
Lean Maintenance helps eliminate seven main types of waste: overproduction, excessive waiting times, unnecessary storage, rework, defective parts, unoptimized transportation, and unnecessary movements.
- CMMS (Computerized Maintenance Management System);
- IoT (Internet of Things);
- predictive maintenance (Predictive Maintenance, PdM);
- Digital Twin;
- Big Data & Analytics;
- mobile maintenance;
- augmented reality (AR) and virtual reality (VR);
- 3D printing;
- automation and robotics;
- Cloud Computing.
