  • BIM news
  • BIM projects
  • EN
  • Menu Menu
List List Menu
  • BIM and Construction Sites
  • BIM and Building Design
  • BIM in Construction
  • BIM and Estimation
  • BIM and Energy
  • BIM and Safety
  • BIM and MEP
  • BIM and Facility Management
  • BIM and training
  • BIM and GIS
  • BIM and Infrastructure
  • BIM and technical standards
  • IFC and openBIM
  • Digital Twin
Home » BIM and Facility Management » What is Proactive Maintenance? Here are 3 key examples
Proactive maintenance identifies the causes of an asset's failure and tries to correct them before they become a problem. Here's what it is and 3 key examples
Editorial Team / 23 January 2023
proactive maintenance
There are many types of maintenance that a Facility Manager can refer to for efficient asset management. In this focus, however, we will mainly focus on the analysis of proactive maintenance.
Continue reading to discover some practical examples that will help you fully understand its main characteristics. In addition, if you deal with maintenance, whatever strategy you intend to use, I recommend that you try in first place a free facility management software that helps you manage the entire process and keep all the necessary maintenance operations under control.
  • What is Proactive Maintenance?
  • Types of Proactive Maintenance
  • Difference Between Proactive Maintenance and Predictive Maintenance
  • Difference Between Proactive Maintenance and Reactive Maintenance
  • 3 Key Examples of Proactive Maintenance
  • What are the advantages and disadvantages of proactive maintenance?
  • How to implement an efficient proactive maintenance strategy?
Proactive maintenance, also known as proactive maintenance, is a preventive maintenance strategy that aims to correct the underlying causes of failures, to anticipate and avoid the generation of more serious damage to assets.
In a company, there may be many causes that affect machinery efficiency.
  • Excessive extension of the lifespan of the equipment;
  • incorrect use of the equipment;
  • poor quality materials and supplies;
  • production increases;
  • errors in maintenance procedures;
  • lack of training for technicians.
This type of maintenance allows you to extend the life span of the assets and improve their performance. This is possible thanks to the continuous monitoring of the equipment, the collection and constant analysis of the data that allow the performance of maintenance efficiently only when it is really necessary.
Type flow of a proactive maintenance intervention
Flowchart proactive maintenance intervention
There are different types of proactive maintenance.
  • preventive maintenance: it is a type of maintenance whose strategy is based on a timeline and whose activities are scheduled as per due date;
  • condition-based maintenance: maintenance is planned according to the state of the equipment;
  • planned maintenance: maintenance is planned at pre-set intervals based on manufacturer guidelines and historical equipment data.
Predictive maintenance and proactive maintenance are two types of maintenance based on a preventive approach. This approach uses the monitoring of equipment condition to perform maintenance tasks before damage is generated.
The main difference between the two types is that proactive maintenance tries to identify the cause of a potential problem, while the predictive one collects useful data and information to appropriately program the interventions to be carried out.
Reactive maintenance and proactive maintenance are two completely different maintenance strategies.
Reactive maintenance is a “passive” action, after an expected failure. On the other hand, proactive maintenance acts not only to prevent equipment failure but also to improve equipment performance.
To fully understand how this maintenance strategy works, the 3 examples below will be useful:
  1. machinery lubrication: performed at regular intervals to avoid problems due to friction between the surfaces, avoiding deterioration of the motors;
  2. pipe inspection: to verify the integrity of the pipe distribution system and prevent costly interruptions due to cracks, corrosion and thinning of the ducts;
  3. application of anti-corrosion coatings on metal surfaces: to avoid immediate replacement of machine parts.
Proactive maintenance examples
The main disadvantage of proactive maintenance is the initial economic investment that is necessary to efficiently implement the strategy consisting of the development with accurate constant schedules.
Benefits include
  • reduction in the number of accidents;
  • risk reduction;
  • reduction of costs in the long term;
  • reduction of machinery downtime;
  • increased reliability of machinery;
  • increase in the operation of machinery;
  • increased availability of machinery;
  • increased longevity of machinery.
To implement an efficient proactive maintenance strategy, I recommend following these simple steps listed below:
  1. create and train a work team that manages all aspects of maintenance;
  2. start a proactive maintenance program with all the assets that need such interventions;
  3. invest in resources and technologies, try for free a facility management software to monitor, maintain and improve quality and safety in many areas of your company. Instead of programming everything manually, you can safely manage all aspects in a single central cloud-based database, which is secure and accessible to all professionals.
usbim-maint
usbim-maint
Share this entry
  • Share on Facebook
  • Share on X
  • Share on WhatsApp
  • Share on LinkedIn
  • Share by Mail
Related posts
    27 July 2026
  • BIM Facility Management: The Power of BIM in Asset Management
  • 27 July 2026
  • What is a Maintenance Audit and Why It’s Important
  • 18 June 2026
  • Building Commissioning: Definition, Phases, and Key Benefits
  • 10 June 2026
  • Bridge Management System: What It Is and How It Works
Follow us on
  • Construction Sites
  • Energy
  • Estimation
  • Infrastructure
  • Safety
  • Structural Calculation
  • Technical standards
  • Training
  • BIM news
  • BIM project example
  • Digital Twin
  • IFC and openBIM
Scroll to top
