6 good rules to create a floor plan rendering
A floor plan rendering is a rendered floor plan of a building that shows a realistic layout. Let's see how we can make it
During the development of a project, a series of rendered views has always been the most used and most effective way to present all the details proposed to customers:
- furnishing elements;
- surface lining;
- harmony between environments.
If you need to produce architectural renderings and you are still a beginner, there is no need to worry. I recommend an intuitive online 3D rendering software for free that allows you to make beautiful renderings, even if you are not an expert.
In this article, we are going to explore a particular type of rendering, the Floor Plan Rendering, analyse its peculiarities and understand how to make it.
Whatis a Floor Plan Rendering?
A floor plan rendering is a 2D or 3D graphic representation of a home layout.
It is a great solution for customers who, without specific technical knowledge, have the opportunity to understand in a simple and fast way every aspect and detail of the construction. The use of the environments is clarified and misunderstandings about the available space or navigation between the rooms are avoided.
For this reason, these floor plans show no technical information such as dimensions or measurements or characteristics of doors and windows, but they leave room for:
- colours;
- surfaces;
- textures;
- shadows;
- lighting;
- furnishing.
There are two types of rendered floor plans:
- 2D plan: plan orthogonal to the cutting plane, enriched with furniture and surface lining;
2D Floor Plan Rendering
- 3D plan: when the view is not completely orthogonal but is three-dimensional.
3D Floor Plan Rendering
Differences between a traditional floor plan and a rendered one
A building design software can create both a traditional floor plan and a rendered one; these differ in the information they provide. Let’s dive more into it.
Traditional floor plan
A technical drawing plan is a cut of the 2D orthogonal building, with a view from the top down from a height that also makes doors and windows openings visible.
It can be developed in different technical scales, depending on the level of detail to represent.
It collects a series of information that is easy for the professionals to understand:
- graphic symbols: axes, cutting lines, geodetic altitudes;
- technical notes: captions, dimensions, surfaces;
- technical details: material layers of floors or walls, direction and orientation of the openings.
Traditional floor plan rendering
Rendered floor plan
A rendered floor plan is far from the technicalities and tends to be very artistic. It allows customers to fully understand the design of all spaces.
While the traditional plan is black and white, this on the other hand is represented in color and is enriched with the most varied textures to recreate the environments in a realistic way, with furnishings, lightings and shadowings.
Floor plan rendering
Floor Plan Rendering: 6 good rules to get the best out of it
To create a good floor plan rendering you need to:
- create a good 3D model of the environment to be recreated: the more the starting model is detailed and as close as possible to reality, the more realistic the rendering will be;
- define the correct arrangement of spaces, through which the customer will perceive the correct dynamic flow of the rooms;
- choose the furnishing elements that suit the environments we want to create;
- identify the colours and chrome motifs suitable for the customer’s requests, which will have a positive or negative impact on the customer;
- better manage the parameters related to the light to be added, whether artificial or natural;
- choose materials and lining, synthetic or natural finishes, that are able to enhance the spaces created.
To conclude, we have seen that a floor plan rendering is a fundamental tool within the project, as it is a clear communication tool for customers. For this reason, it must be created properly, by paying attention to the materials choice, scenes, lights and shadows.
My advice for creating effective floor plan renderings is to choose an intuitive and professional online 3D rendering software.
What are the benefits of a floor plan rendering?
The representation of spaces through a floor plan rendering guarantees:
- an immediate view of the layout of the spaces;
- a better understanding of the dimensions and dynamics of the spaces;
- a perfect visualization of the materials and the final linings;
- faster customers ‘s decision-making processes;
- greater control of errors in the execution phase, quickly detecting any inconsistencies.
Last, but not the least, a floor plan rendering is certainly more attractive than a traditional floor plan and it is possible to attract a greater number of customers.
