An overview on building energy retrofits and their benefits
Building energy retrofits include the necessary procedures to redevelop and improve the energy efficiency of an existing building. Discover what they are and their main advantages
Energy retrofitting refers to the set of technical and design interventions aimed at improving the energy efficiency of an existing building, reducing energy consumption, operating costs, and CO₂ emissions, while simultaneously increasing living comfort and property value.
In the context of the ecological transition and European decarbonization goals, energy retrofitting represents a key strategy for the upgrading of the existing building stock, which accounts for a significant share of energy consumption and greenhouse gas emissions at the European level.
In this article, we will focus on the definition of retrofitting to clarify together its key principles, advantages, and application methods.
What is building energy retrofitting?
Building energy retrofitting refers to the set of procedures and technological and managerial strategies aimed at improving the energy efficiency of an existing building, resulting in a reduction of its energy consumption and greenhouse gas emissions.
Energy retrofitting is a comprehensive technical and design process that addresses the building as an integrated system, aiming to achieve performance levels far superior to those of a simple renovation. This is made possible through the use of innovative materials, high-efficiency systems, and renewable energy sources.
Through energy retrofitting, an outdated building can be transformed into a modern, efficient, and sustainable asset, fully aligned with European objectives for ecological transition and climate neutrality. Energy retrofitting is also a tangible expression of regenerative architecture: an approach that goes beyond reducing environmental impact to actively regenerate resources, enhance the quality of spaces, and create long-term value for both people and the environment.
Meaning and objectives of energy retrofitting
Energy retrofitting is an efficiency process that integrates architectural, system, and management aspects, adapting each intervention to the characteristics of the building, its state of preservation, the intended use, and the climatic context.
The main objectives are:
- reduction of energy consumption: decrease in the demand for energy for heating, cooling, lighting, and hot water;
- improvement of living comfort: optimal conditions of temperature, humidity, and air quality in all seasons;
- environmental sustainability: reduction of CO₂ emissions and limitation of the environmental impact of the building’s life cycle;
- economic enhancement: increase in the property’s value due to the improvement of the energy class and reduction of management costs;
- resilience and safety: greater durability and adaptability of the building to future energy and climatic needs.
The process is divided into three main phases:
- energy diagnosis, to identify inefficiencies and intervention priorities;
- design and execution, with the selection of the most effective technical solutions from an energy and economic point of view;
- post-intervention monitoring, to verify and maintain the results achieved over time.
Objectives of energy retrofitting
Why are deep energy retrofits essential for existing buildings?
The existing building stock represents one of the main challenges of the energy transition, as European buildings are responsible for around 40% of energy consumption and over one-third of greenhouse gas emissions.
Deep energy retrofits (deep retrofit) allow energy consumption to be reduced by up to 60–80% through integrated interventions on the building envelope and systems, aimed at a comprehensive and long-lasting renovation of the building.
In addition to environmental and economic benefits, these interventions significantly improve occupants’ quality of life, providing healthier, more comfortable, and safer spaces, while generating value for the entire community.
What are the advantages of building energy retrofits?
Energy retrofitting is an integrated transformation process of the existing building, focused on improving its overall performance.
This approach is not limited to individual technical interventions but acts in a coordinated manner on the envelope, systems, and energy management. The result is a lasting improvement in the efficiency, comfort, and sustainability of the building over the long term.
The benefits of energy retrofitting manifest on multiple levels, involving energy, economic, environmental, and social aspects.
These advantages produce positive effects both on the quality of life of occupants and on the overall value of the building stock.
Energy Benefits
The first tangible result of retrofitting is the reduction of consumption and the improvement of overall efficiency of the building–system. Targeted interventions on the envelope and systems allow for significant and lasting results.
The main energy benefits include:
- decrease in energy demand for heating, cooling, and hot water production;
- containment of thermal losses, thanks to better insulation and the replacement of obsolete fixtures with high-performance windows;
- optimization of the performance of air conditioning, heating, and ventilation systems;
- stability of internal comfort, with more uniform temperatures and consistent air quality throughout the year.
A retrofitted building thus becomes more efficient, comfortable, and controllable, capable of ensuring high performance with less use of primary energy.
Economic Benefits
Energy retrofitting is also a profitable investment that combines savings and property enhancement. In addition to reducing consumption and management costs, it improves the building’s competitiveness in the market.
The main economic benefits are:
- reduction of management expenses and energy bills thanks to system efficiency;
- lower maintenance costs, as new systems require less frequent and more targeted interventions;
- increase in property value and energy class, key elements in real estate valuation;
- access to incentives and tax deductions, which facilitate interventions and accelerate economic returns;
- greater stability in the long term, with less exposure to fluctuations in energy costs.
Energy efficiency thus represents a sustainable strategy from an economic perspective, capable of combining savings, comfort, and enhancement of property.
Environmental and Social Benefits
In addition to technical and economic implications, energy retrofitting generates significant environmental and social benefits. Each intervention contributes to reducing greenhouse gas emissions and the environmental impact of the building sector.
The most significant advantages include:
- reduction of CO₂ emissions and promotion of renewable energy use;
- less dependence on fossil fuels, in favor of a more sustainable energy model;
- improvement of comfort and air quality, with healthier environments and more stable thermo-hygrometric conditions;
- combating energy poverty, thanks to more efficient buildings that are cheaper to maintain;
- stimulus to the economy and employment, with new opportunities in the construction and green economy sectors.
Energy retrofitting thus becomes a strategic factor for sustainability, capable of generating concrete benefits for people, the environment, and the economy, contributing to the creation of more efficient and livable cities.
Benefits of energy retrofitting
Measures and Strategies for Energy Retrofits
The energy retrofit of a building is achieved through a series of coordinated interventions that concern the building envelope, technological systems, and energy management systems.
The choice of the most suitable measures depends on the objectives of efficiency, the level of energy performance to be achieved, and the available budget.
In general, interventions can be classified based on the structures and systems being addressed, as described below.
Energy Retrofit Interventions on the Building Envelope
The building envelope is the element that most affects energy consumption. Improving its performance means reducing thermal losses and ensuring constant comfort in all seasons.
The most common measures include:
- insulation of opaque structures (walls, roofs, and floors) in contact with the outside or with unheated spaces, through the application of high-performance insulating materials;
- replacement of windows and transparent surfaces (windows and patio doors) with more efficient models, such as low-emissivity double glazing or triple glazing with insulating gas;
- elimination of thermal bridges and adoption of solar shading to contain summer overheating.
These interventions improve the thermal response of the building, reduce environmental impact, and increase living comfort.
Updating HVAC Systems to Improve Energy Efficiency
The HVAC system (Heating, Ventilation, and Air Conditioning) includes heating, cooling, domestic hot water production, and ventilation systems.
Its upgrading is one of the most effective interventions to improve the overall energy performance of the building.
The most common strategies are:
- replacement of the heat generator with heat pumps, condensing boilers, or high-efficiency hybrid systems;
- installation of low-consumption summer air conditioning systems and controlled mechanical ventilation (CMV) with heat recovery;
- integration of automatic control systems and smart climate control to optimize energy flows and internal comfort;
- adoption of renewable sources such as solar energy, geothermal energy, or biomass, to reduce dependence on fossil fuels.
In addition to savings, an efficient HVAC system improves indoor air quality and reduces the presence of humidity, mold, and pollutants.
Integration of Smart Systems for Energy Retrofit Management
New digital technologies allow for integrated management of the entire building–system, transforming the home into a true smart home. Thanks to the Internet of Things (IoT), home automation, and smart home systems, it is possible to monitor and control energy consumption and performance in real time.
Among the most effective solutions:
- connected sensors and devices for monitoring temperature, humidity, and air quality;
- remote control of systems and devices, even through apps and voice assistants;
- energy management platforms that analyze data and optimize consumption.
The integration of smart systems makes the building more efficient, flexible, and adaptable to user needs.
Use of Renewable Energies in Energy Retrofit Projects
Renewable energy sources represent a crucial aspect of sustainable retrofitting. Their integration into buildings allows for reduced emissions, limited environmental impact, and increased energy autonomy.
The main solutions include:
- photovoltaic and solar thermal systems, for the production of electricity and domestic hot water;
- geothermal systems, which utilize the natural heat of the ground;
- biomass systems, based on renewable organic materials;
- mini-wind and storage systems to maximize self-consumption and the efficiency of the energy system.
The combined use of multiple renewable sources allows for achieving high levels of efficiency and making a concrete contribution to the ecological transition of the construction sector.
Energy retrofit measures
How to assess the level of building energy retrofits?
Before planning an energy retrofit intervention, it is essential to assess the current state of the building. Only a thorough understanding of its construction, systems, and energy characteristics allows for identifying the most effective and sustainable solutions to improve its performance.
The evaluation of the retrofit level starts from the initial energy analysis, which allows to:
- determine the current energy performance, identifying thermal losses through diagnostic tools (thermography, blower door test, simulation software, etc.);
- verify the energy class and estimate the potential improvement achievable based on different intervention scenarios;
- evaluate the technical and architectural compatibility of the proposed solutions, avoiding thermal-hygrometric problems or constraints related to balconies, fixtures, and structural connections;
- analyze the existing systems (HVAC, lighting, energy production) to identify inefficiencies and optimization margins.
A thorough analysis allows to define the most appropriate retrofit level (from light interventions to deep renovations) and to plan technical and economic strategies consistent with sustainability goals and the client’s needs.
Cost-benefit analysis of energy retrofit solutions
Once the possible improvement measures have been identified, it is essential to conduct a cost-benefit evaluation to select the most advantageous solutions from economic, energy, and environmental perspectives.
The analysis must consider:
- direct costs of interventions, including materials, labor, installations, and maintenance;
- energy benefits, i.e., the reduction of consumption for heating, cooling, ventilation, and lighting;
- environmental advantages, such as the decrease in CO₂ emissions and more efficient use of resources;
- indirect benefits, including improved living comfort, air quality, and property value.
For a complete evaluation, it is useful to simulate different intervention scenarios, comparing:
- the payback period;
- the impact on overall energy performance;
- the overall sustainability in the long term.
The goal is to identify solutions that ensure the best balance between initial investment and energy savings, ensuring technical, environmental, and economic effectiveness.
Planning and management of an energy retrofit program
An energy retrofit intervention requires careful planning and a coordinated management of all phases to ensure concrete results in terms of efficiency, comfort, and sustainability.
An effective retrofit program is based on a methodical approach articulated in several phases:
- preliminary analysis and energy diagnosis: collection of data related to the building (construction characteristics, systems, consumption) and identification of critical issues to establish intervention priorities;
- definition of objectives: clarifying the expected results, such as consumption reduction, improvement of the energy class, increase in comfort, or reduction of emissions;
- integrated design: involving multiple professionals (architects, engineers, system designers) and using BIM models and energy simulation software to evaluate different scenarios and predict future performance;
- economic planning and incentives: drafting a realistic cost plan, evaluating the cost-benefit ratio, and utilizing tax incentives to optimize the investment;
- execution and monitoring: coordinating contractors, controlling the quality of work, and verifying energy performance over time to ensure the durability of results.
Today, retrofit management is supported by digital solutions that improve control, transparency, and collaboration among the parties involved, such as:
- BIM management platforms, for managing timelines, costs, documentation, and project communications;
- IoT monitoring systems, which detect energy consumption and environmental comfort parameters in real-time;
- BIM models and Facility Management systems, which allow for integrated management of all building information throughout its life cycle, ensuring operational efficiency and management continuity.
FAQ – Energy retrofitting
What is meant by energy retrofitting?
Energy retrofitting is a renovation process that includes technical and design interventions aimed at improving the energy efficiency of an existing building, reducing consumption and emissions, and enhancing comfort and property value.
What is the difference between energy retrofitting and simple renovation?
Unlike traditional renovation, energy retrofitting involves the entire building-system and aims for superior energy performance, thanks to the integration of efficient envelopes, high-performance systems, renewable sources, and energy management systems.
Why is energy retrofitting so important today?
The existing building stock is responsible for about 40% of energy consumption and over a third of greenhouse gas emissions. Energy retrofitting is therefore a key tool for ecological transition and for achieving European decarbonization goals.
What are the main objectives of energy retrofitting?
The main objectives are the reduction of energy consumption, improvement of living comfort, decrease in CO₂ emissions, economic enhancement of the property, and increase in resilience and durability of the building over time.
What is meant by deep energy retrofitting?
Deep energy retrofitting consists of integrated interventions on the envelope and systems that allow for reducing energy consumption by up to 60–80%, ensuring a significant and lasting improvement in building performance.
What energy benefits does energy retrofitting offer?
Energy retrofitting allows for reducing the energy demand for heating, cooling, and hot water, containing thermal losses, improving system efficiency, and ensuring greater stability of internal comfort.
Is energy retrofitting also economically beneficial?
Yes, because it reduces management costs and energy bills, decreases maintenance costs, increases the property value, and allows access to incentives and tax deductions, improving the return on investment in the long term.
What environmental and social benefits does energy retrofitting generate?
Retrofit interventions contribute to the reduction of CO₂ emissions, decrease dependence on fossil fuels, improve indoor air quality, and combat energy poverty, with positive effects also on employment and the economy.
What interventions are included in the energy retrofit of the building envelope?
The most common interventions involve the insulation of walls, roofs, and floors, the replacement of fixtures with high-performance windows, and the elimination of thermal bridges, often accompanied by the adoption of solar shading.
How do HVAC systems contribute to energy retrofitting?
The upgrading of HVAC systems improves the overall energy performance of the building through the adoption of efficient generators, low-consumption air conditioning systems, controlled mechanical ventilation, and intelligent regulation and control solutions.
What is the role of renewable sources in energy retrofitting?
The integration of renewable sources such as photovoltaics, solar thermal, geothermal, biomass, and storage systems allows for reducing emissions, increasing energy autonomy, and improving the overall efficiency of the building.
How is the level of energy retrofitting of a building assessed?
The assessment starts from an initial energy analysis that allows for determining current performance, identifying major inefficiencies, verifying the energy class, and defining the most appropriate retrofit level, from light interventions to deep renovations.
Why is cost-benefit analysis important in energy retrofitting?
Cost-benefit analysis allows for comparing different design solutions by evaluating investments, energy savings, environmental benefits, and comfort, identifying interventions that ensure the best balance between initial costs and long-term effectiveness.
What are the fundamental phases for planning an energy retrofit program?
An effective program includes a preliminary analysis with energy diagnosis, definition of objectives, integrated design supported by digital tools, accurate economic planning, and a phase of execution and monitoring of performance over time.
