Thermal Design: What It Is and How to Execute a Project
Discover what thermal design is, what a project includes, and what the designer does to improve the energy efficiency of the building
In summary:
thermal design is the process through which the systems intended for heating, cooling, ventilation, and hot water production of a building are analyzed, sized, and verified, aiming to ensure comfort, energy efficiency, and compliance with technical and regulatory requirements.
Thermal design applies the principles of thermodynamics, fluid dynamics, and heat transfer to the design of buildings and their related systems. The goal is to identify solutions capable of ensuring thermal comfort conditions, indoor air quality, and high energy performance.
The systems considered include, among others, heating, cooling, ventilation systems, the production of sanitary hot water, and systems powered or integrated by renewable energy sources.
To pre-evaluate the energy behavior of the building and compare different design solutions, it is also possible to use tools for dynamic energy simulation of buildings useful for creating energy models and analyzing the performance of the building and its systems.
- What is thermal design and what is it used for?
- What is a thermal design project?
- What is a thermotechnical system?
- How is a thermotechnical project developed?
- Who is the thermal designer?
- BIM and thermal design: how the workflow changes
- Importance of Tools for Thermal Design
- How to Use Energy Simulation Software
- FAQ – Thermal Design
A thermal project must simultaneously consider building characteristics, climate conditions, intended use, energy needs, type of systems, and management methods.
Thermal design therefore allows for the identification and sizing of the most suitable solutions to ensure occupant comfort and limit energy consumption, evaluating in an integrated way the building envelope and plant systems.
Application areas of thermotechnics
The application areas of thermal design are varied, but the most important ones that significantly affect the overall organization of the project are:
- environmental comfort: this relates to the design and implementation of heating, ventilation, and air conditioning systems in residential, commercial, and industrial buildings. The goal is to create indoor environments that are thermally comfortable throughout the year, regardless of external conditions;
- energy efficiency: thermal design is essential for optimizing the energy efficiency of thermal systems. This includes the adoption of technologies and design strategies aimed at reducing energy consumption and polluting emissions, such as the use of cogeneration systems, high-efficiency heat pumps, and advanced thermal insulation solutions;
- environmental sustainability: thermal design plays a crucial role in promoting environmental sustainability. This includes the adoption of low-impact technologies, such as heating and cooling systems powered by renewable sources, and the implementation of design strategies that reduce the environmental impact of thermal systems on the surrounding ecosystem.
What is thermal design and objectives
A thermal design project defines the characteristics, the sizing, and the performance of the thermal systems of a building. It starts with the analysis of the building and its energy needs to identify the most appropriate system solutions and verify their performance, consumption, and compliance with the required standards.
Therefore, the project does not only concern the selection of a generator or a terminal, but considers the interaction between the building envelope, climatic conditions, usage, systems for production, distribution, emission, regulation, and utilization of renewable sources.
What does a thermal design project contain?
Depending on the characteristics of the building and the intervention, the design may include:
- analysis of the geometric and thermo-physical characteristics of the building;
- assessment of the building envelope;
- definition of climatic conditions and usage conditions;
- calculation of heating and cooling needs;
- evaluation of the production of domestic hot water;
- analysis of ventilation needs;
- sizing of the necessary powers;
- selection and sizing of the generators;
- definition of distribution and emission systems;
- selection of control systems;
- integration of renewable energy sources;
- analysis of thermal bridges;
- verification of energy performance;
- production of drawings and the required technical documentation.
Elements of a thermal design project
The term thermotechnical system generally refers to the set of plants and systems used to ensure energy services and the thermo-hygrometric comfort of a building. From a regulatory standpoint, the reference term is “thermal system.”
A thermal system is a fixed technological system designed for winter or summer climate control of environments, with or without the production of domestic hot water, or solely for the production of domestic hot water in cases provided for by regulations. It can also be combined with ventilation systems.
Depending on the characteristics of the building and the adopted design solution, the system may include various subsystems and components, including:
- production systems, such as boilers, heat pumps, and other generators;
- distribution systems, which transfer thermal energy to environments or utilities;
- storage systems, used to store thermal energy or hot water;
- emission or utilization terminals, through which heat is given off or taken from the environments;
- regulation and control devices, necessary for managing the operation and performance of the system;
- systems for the production of domestic hot water;
- ventilation and air treatment systems, when integrated with the system;
- systems powered or integrated by renewable energy sources.
Thermal design has the task of defining and sizing these systems in relation to the characteristics of the building, energy requirements, and usage conditions, with the aim of ensuring comfort, efficiency, and correct performance of the entire building-system system.
Thermal design develops through a series of interconnected activities. The workflow may vary depending on the type of building and intervention, but generally includes the following phases.
- Analysis of the building and data collection:
the first phase consists of gathering the necessary information to correctly describe the building: geometry, orientation, envelope characteristics, intended use, occupancy profiles, climatic conditions, and characteristics of any existing systems. - Creation of the energy model:
the collected data is used to build an energy model of the building through which the envelope, thermal zones, component characteristics, and usage conditions are represented. The availability of a BIM model or CAD files can speed up this phase and reduce the need to manually re-enter information already available. - Calculation of energy needs:
the model allows for evaluating the building’s behavior and determining the needs related, for example, to:
- heating;
- cooling;
- ventilation;
- production of domestic hot water.
This information forms the basis for the subsequent sizing of the systems.
- Design and sizing of thermotechnical systems:
based on the calculated needs, the designer identifies the most appropriate system solutions and defines powers, generators, terminals, distribution, and regulation systems. In this phase, multiple design alternatives can be compared to identify the best balance between comfort, consumption, costs, and performance. - Energy and regulatory checks:
the design must also verify compliance with applicable energy requirements for the intervention and prepare, when required, the relevant technical documentation. To manage this phase of the project more easily, software for calculating energy performance can be utilized, allowing compliance checks to be carried out directly from the building’s energy model as required by current regulations. - Simulation and comparison of solutions:
through energy simulation, it is possible to analyze the building’s behavior under different conditions, compare alternative configurations, and assess how different design choices impact consumption and overall performance. With a dynamic energy simulation software for buildings, it is possible to delve deeper into this type of analysis even during the design phase.
Thermal design project workflow
The thermal designer is the professional who deals with the energy analysis of the building and the design of heating, cooling, ventilation, hot water production systems, and the integration of renewable energy sources.
The increasing focus on energy efficiency has expanded the role of this professional figure: in addition to the proper sizing of the systems, the designer must evaluate the overall behavior of the building, the interaction between the envelope and systems, the comfort of the occupants, consumption, and the environmental impact of different solutions.
What does the thermal designer do?
The thermal designer analyzes the energy behavior of the building and designs and sizes the systems necessary to ensure comfort, energy efficiency, and compliance with technical and regulatory requirements.
Among the main activities, they can:
- evaluate heating and cooling needs;
- analyze the energy behavior of the building;
- design and size the systems;
- select generators and terminals;
- evaluate ventilation and air treatment systems;
- size the systems for the production of sanitary hot water;
- integrate systems powered by renewable energy sources;
- verify energy performance;
- analyze thermal bridges and envelope characteristics;
- compare different design solutions;
- prepare the documents and the required technical documentation.
What aspects should they consider in the design?
During the design phase, the thermal designer must coordinate the evaluation of heating, cooling, ventilation, hot water production, humidity control, generators, distribution, terminals, and control systems.
The goal is to size the system to ensure adequate temperature conditions, humidity, and air quality, while avoiding oversizing and unnecessary energy consumption.
The introduction of Building Information Modeling (BIM) has represented a fundamental turning point in the energy and thermal design sector, offering new opportunities to improve the efficiency and quality of the services offered.
BIM is a working methodology that allows for the creation, management, and sharing of detailed digital information about a building or system throughout its life cycle, from conception to demolition. This integrated approach enables the optimization of the decision-making process, reduces errors and costs, and enhances collaboration among the various actors involved in the project.
There are several advantages obtained from the use of BIM within one’s workflow, for instance:
- improvement in the quality of services – thanks to BIM, it is possible to obtain a three-dimensional and integrated view of the thermal systems within the building context. This allows designers to more effectively evaluate design solutions, anticipate potential problems, and optimize system performance, ensuring a high-quality final result;
- optimization of the design and construction process – BIM facilitates collaboration among architects, engineers, and other professionals involved in the design and implementation of systems. By sharing a single digital model, it is possible to coordinate activities more efficiently, reducing design and construction times and improving communication among team members;
- reduction of errors and costs – BIM allows for the identification and resolution of any conflicts or design errors in advance, reducing the risk of costly delays and modifications during the construction phase. Moreover, the ability to simulate the operation of thermal systems within the BIM model allows for optimizing the sizing and layout of components, contributing to reducing the overall project costs;
- greater operational efficiency – once the design and construction phase is completed, the BIM model can be used to support management and maintenance activities for thermal systems. With detailed and updated information available, managers can plan preventive maintenance interventions, optimize energy consumption, and ensure the proper functioning of systems over time.
In thermal design, as in many other fields, the use of the right tools is fundamental. Therefore, it is important to understand what should be “expected” from a dynamic energy simulation software for buildings to ensure it can deliver the best possible outcome. Thus, the tool to be used must:
- create a 3D model and perform energy calculation – it must be possible to create an architectural 3D model necessary for the energy calculation starting from a CAD file in DXF or DWG format or from a BIM model in standard IFC format;
- allow configuring the model and entering data – the software should allow assigning the necessary characteristics and properties for energy simulation to each architectural element, perhaps using a vast library of BIM objects;
- integrate the calculation of thermal bridges – the ability to automatically identify all thermal bridges greatly speeds up the work and allows correcting mistakes during the design phase. However, it is important to have the option to choose which thermal bridges to evaluate in the project and manage their transmission characteristics correctly;
- perform data diagnosis and simulation – the program must check the data entered before starting the thermal simulation. This ensures that the data is correct and reduces the risk of needing to repeat the calculation;
- analyze the results – finally, detailed visualization of the calculation results must be available, both in graphical and tabular form. Additionally, it should allow for comparison of different solutions and analysis of energy performance, consumption, and costs.
Below I show you how you can use a dynamic energy simulation software for buildings.
What is a thermal project?
A thermal project is the set of analyses, calculations, and design choices used to define the characteristics and performance of a building’s systems. It includes the assessment of energy needs, the sizing of systems, and the necessary checks to ensure comfort, efficiency, and compliance with applicable requirements.
What does a thermal system include?
A thermal system can include heating, cooling, ventilation, and domestic hot water production systems, as well as generators, heat pumps, terminals, distribution networks, control systems, accumulators, and components powered by renewable energy sources.
What does a thermal designer do?
The thermal designer analyzes the energy behavior of the building, determines the needs, designs and sizes the systems, verifies the performance of various solutions, and prepares the technical documents necessary for the execution of the intervention.
Is a thermal project and a thermal system the same thing?
No. A thermal project is the collection of analysis, calculation, sizing, and technical definition activities of the solution. The thermal system, on the other hand, is the system physically realized in the building based on the project.
What is the purpose of energy simulation in thermal design?
Energy simulation allows the study of the behavior of the building and the systems, checking the effect of different design choices and comparing alternative scenarios before realization, providing the designer with useful information to optimize performance and consumption.
