Essential guide to electrical rewiring: safety, compliance, and efficiency
Discover reasons, phases, and practical advice for electrical rewiring, improving safety, compliance, and energy efficiency
Electrical rewiring is a vital process in building renovation and maintenance, ensuring not only compliance with current regulations but also enhancing safety and energy efficiency. Whether you’re undertaking a complete overhaul or just partial updates, understanding the main aspects of rewiring can help you make informed decisions about your project. In this guide, we’ll delve into the key reasons for rewiring an electrical system, the steps involved, and go through some practical advice for achieving optimal results.
Why Rewire an Electrical System?
Rewiring an electrical system is a construction intervention that involves the complete or partial replacement of existing system components with new elements, in order to ensure safety, system efficiency, and system updating in compliance with products currently available on the market and with current regulations in force.
Partial demolitions will be necessary, removal of some existing components, creation of traces to create new ducts for electrical cables, installation of new corrugated conduits, junction boxes, fruits, and fruit holders, etc., laying of new electrical conductors, and restoration of finishes (plaster, painting, coatings, etc.).
Ultimately, it is a rather invasive intervention, especially if an under-track system is chosen.
If you are facing the renovation project of a property, and you are considering whether to also rewire the electrical system, this focus can support you in understanding when and why it is necessary to plan for this type of intervention.
Reasons to opt for electrical rewiring include:
- safety – one of the main reasons for rewiring an electrical system is to improve safety. Outdated systems can pose significant risks, such as short circuits, overheating, and, in the worst cases, fires. More current materials and technologies offer greater guarantees against these risks;
- compliance with regulations – electrical regulations change over time to adapt to new technologies and ensure higher safety levels. An old system may no longer comply with current standards governing the installation of electrical systems in residential buildings;
- energy efficiency – modern systems are designed to be more energy-efficient. The use of devices such as LED bulbs, low-consumption appliances, and energy management systems can significantly reduce electricity consumption.
Is it Possible to Rewire Only Some Parts of the System?
You have certainly found yourself talking to the client during the evaluation of the works to be carried out, and this question has been asked with the aim of reducing costs. Well, the answer is yes, it is possible to rewire only some parts of the electrical system without redoing everything. However, there are some conditions and limitations to consider, such as the condition of the system, its compliance with regulations, safety, and the feasibility of the intervention.
If the system is old and does not meet safety standards, it is often more cost-effective to rewire the entire system to ensure safety and system efficiency, avoiding the need for deeper intervention a few years later.
If the system is in good condition and complies with regulations, it is possible to rewire only the parts that require maintenance, such as replacing cables or light points. In addition, the existing system can also be expanded by adding new light points.
Rewiring only some parts of the system may be more cost-effective than redoing everything, but it may require more time and appropriate project evaluations and careful planning to avoid interruptions in the electrical service and minimize inconveniences for residents.
In summary, rewiring only some parts of the electrical system can be a more economical and a less invasive solution, but it requires careful evaluation of the system’s conditions and the regulations to be complied with.
When is Electrical Rewiring Necessary?
Usually, it is recommended to rewire the electrical system every 30 years. However, in case of malfunctions, such as continuous sudden voltage drops, a meter that jumps too often, a burnt smell from outlets, sparks coming out of outlets, it is advisable to intervene even if the system is not that old, especially if there are safety hazards.
These signs may indicate that the electrical system is old or does not meet safety standards, requiring a complete rewiring to ensure the safety and efficiency of the system.
What are the costs to consider for electrical rewiring?
The costs for rewiring an electrical system can vary based on various factors, such as:
- type of system: whether it is surface-mounted or recessed, standard, basic, or home automation;
- complexity level of the system: if the system requires advanced technologies or modifications to the existing conditions, the cost can increase significantly;
- regulations and necessary approvals: the cost may increase if special approvals or demolition and reconstruction works (partition walls, false ceilings, etc.) are required.
In general, it is important to provide a detailed metric calculation of all the works to obtain an accurate estimate of the cost of electrical rewiring.
For further information, also read:
When to opt for a ceiling electrical system
Surface-mounted electrical system: solutions and advantages
Electrical rewiring: the phases
The first phase involves a detailed evaluation of the existing system. A qualified technician will examine the system to identify any issues and determine the extent of the necessary works. This includes the analysis of cables, outlets, switches, and the electrical panel.
Once the evaluation is completed, the design of the new system is carried out. This phase involves creating a detailed plan specifying the position of cables, outlets, switches, and other components. It is essential to consider the specific needs of the building and its occupants. When designing an electrical system, it is advisable to use a MEP design software. Especially when rewiring an existing system, following a BIM design methodology can be useful to avoid conflicts between existing and new elements and design errors. In fact, integrating the electrical system model into the 3D model already complete with structural, architectural, and MEP elements limits the possibility of errors on-site and helps to have a comprehensive overview of the work to be done. Moreover, creating a BIM model representing the digital twin of the real building is an important starting point for managing system maintenance and even its future decommissioning.
The installation phase is the most operational part of rewiring. It includes removing the old system and installing the new one according to the executive design. During this phase, it is important to strictly follow safety regulations to prevent accidents.
After the installation, the system must be tested to verify that it functions correctly and complies with all regulations. This phase includes continuity, insulation, and differential protection tests. At the end of the tests, a compliance certification is issued, attesting that the system is safe and compliant.
Rewiring an electrical system is a complex operation that requires specific skills. It is essential to rely on qualified and certified professionals to ensure quality work. Careful planning is essential to avoid unforeseen events and delays. Also, when designing the new system, consider possible future expansions. Provide spaces and provisions for adding new devices or installing home automation systems.
