Masonry Lintels: Types, Dimensions, and Design Considerations
Everything you need to know about the masonry lintel: structure, materials, types, dimensions, and design
The masonry lintel is one of the most commonly used structural elements in both traditional and modern architecture, employed to support the load above openings such as doors and windows. Its role is crucial in ensuring the stability and safety of buildings, especially those constructed with load-bearing masonry. Despite the prevalence of new materials and construction techniques, the masonry lintel remains a key component, valued for its physical qualities, ease of processing, and cost-effectiveness.
Masonry lintels: what are they?
A lintel is a horizontal beam placed above an opening, such as a door or window, to distribute the load above and allow for the creation of an opening without compromising the integrity of the load-bearing structure. Masonry lintels are made with masonry blocks, which can be individual bricks or more commonly prefabricated elements, such as reinforced or unreinforced masonry “beams.” The main characteristics include:
- compressive strength: masonry is known for its high compressive strength, making it suitable for bearing vertical loads from upper floors;
- durability: masonry lintels are resistant over time, provided they are protected from adverse weather conditions (for example, through plastering or waterproofing treatments);
- economy: masonry is a widely available material, allowing for the construction of lintels at low costs.
You can create projects that include masonry lintels with the building design software: you not only take care of the design but can also easily manage the entire architectural aspect, focusing on the overall drawing and identifying the most interesting details.
Masonry lintel Edificius
Types of masonry lintels
Masonry lintels are mainly distinguished by two factors: the type of masonry used and the presence or absence of reinforcement.
Unreinforced masonry lintels are those constructed using bricks or masonry blocks without any type of steel reinforcement. They are suitable for openings of small dimensions or for low-load buildings. The most common form is a simple assembly of bricks arranged horizontally, which distribute the load directly onto the underlying masonry.
Reinforced masonry lintels are equipped with a steel structure (reinforcement) integrated into the central part, to increase the load-bearing capacity of the system. This type is necessary when supporting greater loads or when designing larger openings, such as for doors and windows in taller buildings or with specific static requirements.
The reinforcement can be positioned continuously along the entire length of the lintel, using steel bars or metal grids, to ensure greater resistance to tension and bending. In many modern constructions, masonry lintels are manufactured as prefabricated elements. These elements usually consist of reinforced masonry beams or prefabricated masonry blocks, often equipped with grooves for housing reinforcement bars. Prefabricated elements offer numerous advantages, including speed of construction and reduction of installation errors.
Masonry lintels: dimensions
The dimensions of a masonry lintel depend on several factors, including the type of load the lintel must support, the length of the opening to be covered, the quality of the material, and the presence or absence of reinforcement. The standard dimensions of a masonry lintel are variable, but there are general guidelines that can be followed for design.
Length of the lintel
The length of the lintel generally corresponds to the width of the opening it must cover (for example, the width of a door or window). Common openings in residential buildings have widths that vary from:
- 80 cm to 120 cm for internal doors or small windows;
- 140 cm to 200 cm for external doors or medium-sized windows;
- over 200 cm for very large openings, such as glass walls or garage doors, which require more robust or reinforced lintels.
The lintel must therefore be at least equal to the width of the opening, but it is usually designed with a slight excess to ensure adequate load distribution.
Height (thickness) of the lintel
The height or thickness of the lintel depends on the type of material used and the loads it must bear. In general, the height of the masonry lintel ranges between:
- 15 cm to 30 cm for small openings or when using good quality bricks with light loads;
- 30 cm to 50 cm for wider openings or for buildings with higher loads, where the load-bearing capacity of the lintel must be greater.
In the case of reinforced lintels, the reinforcement can reduce the need for greater thickness, but the central part of the masonry lintel will still remain solid and resistant.
Masonry lintels with a base
Masonry lintels with a base are a type of lintel particularly used in construction, which involves the use of a base (or “foundation”) to improve load distribution and provide greater resistance to the lintel itself. This type of lintel is very common in traditional and historical buildings, but it is also applied in modern constructions, thanks to its ability to combine strength and versatility.
It consists of a load-bearing structure in masonry, which can be made of bricks or blocks, and a base (platform) placed under the upper plane of the lintel. This base serves to evenly distribute the loads above the opening and to prevent the lintel from deforming under stress. In the case of masonry lintels with a base, the term “base” refers to an additional element, usually in the form of a slab or plane, which is laid above the load-bearing masonry and below the main part of the lintel.
Function of the masonry base
The masonry base performs several structural and practical functions, including:
- load distribution: the base helps to evenly distribute the loads above the lintel across its entire surface, reducing the risk of stress concentration at specific points;
- increased stability: adding a masonry base to a lintel improves the stability of the structure, especially in the presence of significant loads. This element provides a wider and more uniform support plane for the bricks or blocks of the lintel;
- bending resistance: the presence of a base reinforces the lintel against bending stresses, which occur when the lintel is subjected to vertical and horizontal loads;
- aesthetics: in some situations, the masonry base can also have an aesthetic function, as it can contribute to providing visual continuity to the underlying masonry, with a more homogeneous and uniform appearance.
Designing a masonry lintel
The design of a masonry lintel must take into account several structural and geometric factors. The main variables to consider are:
- vertical load: the lintel must be designed to support the weight above it. The design must ensure that the chosen material, in combination with the geometry of the lintel, can bear such loads without excessive deformation;
- dimensioning and length of the opening: the length of the opening to be covered is one of the main parameters influencing the design of the lintel. The lintel must be long enough to cover the opening without compromising structural stability. For wider openings, the lintel must be more robust, or the use of reinforced lintels can be considered;
- bending resistance: during the design phase, it is essential to ensure that the lintel can withstand the bending stresses resulting from the applied load. This is particularly important for longer or unreinforced lintels, which may have a greater tendency to deform under load;
- material and quality of the masonry: the quality of the masonry is fundamental in the design. The material must be chosen based on the strength class of the brick (for example, bricks of class 15 or 25, depending on the loads to be supported). It is important that the masonry is free from defects and has good adhesion to the mortar, to avoid premature degradation phenomena.
