Solar Farm: How It’s Created and How It Works
A solar farm is a large area where numerous solar panels are installed to convert solar energy into electricity
A solar farm, or photovoltaic field, is a very large area on which solar panels are installed side by side and oriented towards the sun, transforming solar energy into electricity.
The creation of a solar farm requires careful planning and a detailed analysis of the environmental and geographical conditions of the chosen location. It is also essential to consider the energy production capacity needed to meet the needs of the surrounding community.
In this regard, you can use a solar software that allows you to obtain comprehensive financial reports that take into account the construction costs of the plant, the total annual production, electricity consumption by time slots, and any incentives.
What is meant by a solar farm
A solar farm is an area dedicated to the installation of photovoltaic systems, which are systems that convert solar energy into electricity. These farms consist of a set of solar panels mounted on appropriate supports, such as ground structures or building rooftops. The energy produced can be fed into the electrical grid to supply homes, businesses, or other facilities, contributing to the supply of energy from renewable and sustainable sources.
Solar farm: main elements
A solar photovoltaic farm consists of:
- solar panels: these are flat, rectangular structures made up of modules containing photovoltaic cells that capture sunlight and convert it into electricity;
- trackers: trackers are movable supports that orient the solar panels according to the angle of the sun’s rays, thus optimizing electricity production;
- inverters: inverters are devices that convert the direct current (DC) produced by the panels into alternating current (AC), making it compatible with household utilities;
- transformer: this device increases the voltage of the electricity before it is fed into the electrical grid;
- access roads and drainage works: these infrastructures serve to control and protect the plant during rains and floods;
- cable duct: a cable that connects the photovoltaic plant to the primary substation of the grid operator.
How a solar farm works
The operation of a solar farm is identical to that of any other traditional photovoltaic system. A solar farm begins its electricity production process from the photovoltaic modules, which transform solar energy into electricity through the photovoltaic effect. These modules are primarily made of silicon, a widely available semiconductor material.
Semiconductors are materials that can conduct energy when the atoms that make them up receive enough energy to allow electrons to move freely. In the case of photovoltaic modules, the energy comes from the sun in the form of photons. When photons hit the photovoltaic cells, they provide the energy needed to free electrons from silicon, thus creating a flow of electric current.
Solar cells are made by alternating layers of doped silicon, forming a p-n junction. This junction, between boron-doped silicon (p, positive) and phosphorus-doped silicon (n, negative), generates an electric field that directs the movement of electrons. When a photon strikes this junction, it frees an electron, which can then be collected to generate electricity. Each solar cell produces a small voltage, about 0.5 – 0.6 V.
A photovoltaic module consists of many solar cells connected together. Different modules connected in series form photovoltaic strings, and many strings connected in parallel constitute the solar generator or solar farm.
The inverter is responsible for converting the direct current (DC) produced by the modules into alternating current (AC), which is usable in domestic and industrial electrical grids. Inverters can be centralized, managing large powers (from 1 to 4 MW) and collecting energy from a wide area of the solar field, or string inverters, which manage smaller powers (150-300 kW) and are positioned close to the strings to reduce losses in the cables.
After the inverter, a voltage conversion is necessary. Inverters operate at low voltage (up to 1000V in alternating current), but to manage high powers, it is necessary to increase the voltage to medium levels (from 10 to 40 kV) through a transformer.
In smaller plants (up to about 10 MW), energy is transferred directly from the transformer to the delivery substation, where it is fed into the distribution grid. In larger plants, however, the energy passes through an electrical substation, which collects the medium voltage lines and channels them to a transformer that increases the voltage to high levels (up to 120/220 kV) before feeding it into the grid.
Construction of a solar farm: the phases
We can divide the construction of a solar farm into several phases:
- obtaining permits: the first phase consists of obtaining all necessary permits, acquired through service conferences. The competent authorities issue the permits and, if necessary, impose requirements such as archaeological surveys or the presence of an archaeologist during the works;
- preliminary activities: before the actual start of the works, various preliminary activities are carried out, including:
- checking for any unexploded ordnance;
- seismic and geotechnical design tests;
- site opening: this phase involves preparing the site, including the construction of access roads and the installation of necessary offices and services for the site;
- mechanical installation: this phase is further divided into:
- driving the tracker poles;
- manual completion of the tracker installation on the poles;
- manual installation of the photovoltaic panels, paying attention to optimal orientation to avoid shadows;
- electrical installation: in this phase, the electrical installation is carried out, which includes the preparation of wiring, terminations, and electrical connections, as well as the series connection of the photovoltaic modules;
- final phase: the final phase includes electrical testing before connection to the grid, followed by energization to start energy production.
Construction of solar farm: phases
Types of solar farms
In solar farms, the systems are installed directly on the ground, with the panels elevated from the soil using special structures. Depending on the type of panels used, various types of solar farms can be identified:
- solar farms with fixed panels made of crystalline silicon: this is the first generation of solar farms. They use monocrystalline and polycrystalline solar panels, similar to those used in residential systems. These panels are arranged on the ground in multiple rows and remain fixed;
- solar farms with solar trackers and thin-film panels: thin-film silicon panels are lightweight, flexible, and resistant to temperature variations. In solar farms, their use is often combined with solar tracking technology, which allows the panels to rotate following the sun’s movement throughout the day, thus optimizing the yield and overall efficiency of the system;
- solar farms with concentrated panels: these represent the most advanced generation of solar farms, based on concentration technology. This technology concentrates sunlight on small areas of the photovoltaic panels, converting it directly into electrical energy.
What is the largest solar farm in Italy?
The largest solar farm in Italy is located in Puglia and has a capacity of 103 MW. This facility was inaugurated by the Danish company European Energy and covers an area of 1,500,000 m2, equivalent to about 200 football fields.
Other examples of solar farms in Italy include the Sticciano farm, located in the municipality of Roccastrada, province of Grosseto, which has a nominal power of 70.6 MW, and the thermodynamic solar plant Archimede, in the province of Syracuse, which produces about 5 MW of electrical power.
Solar farms around the world
According to a ranking by Energy Digital Magazine of the ten largest solar farms in the world, China and India occupy the top three positions. China is currently the world’s leading producer of solar energy.
Golmud Solar Park
According to the Electricity Market Report 2023, last year China generated 2700 billion kWh of renewable energy, covering 31.6% of national electricity consumption.
The Golmud Solar Park, with an installed capacity of 2.8 GW and 7.2 million solar panels, is the largest solar farm in the world, powering about one million homes.
In second place is the Bhadla Solar Park in the Thar Desert in India, which covers 14 thousand acres and produces 2.25 GW.
Another significant addition to the ranking is the Al Dhafra Solar Project, located 35 km from Abu Dhabi in the United Arab Emirates. This solar farm, situated in the desert over an area of more than 20 square kilometers, has a capacity of 2 GW with nearly 4 million solar panels, enough to meet the needs of about 200 thousand homes.
