BIM Consultant: roles, responsabilities and tools
BIM Consultants help construction companies to implement BIM in their workflows. Find out how this particular role supports the management of digitized processes.
Are you a company willing to implement BIM methodology in your organization and want to understand who can support you in this change? Or instead are you a professional looking for new job opportunities in the Building Information Modeling sector? In this article, we’ll find out more about what’s behind the role of a BIM Consultant. In particular, we will understand who a BIM consultant is what they do, how you become one and how this role supports the management of digitized processes.
What is a BIM Consultant?
With the introduction of BIM in the processes of design, construction and work management in the AEC sector, numerous organizations have found themselves facing the need to reformulate the workflows adopted so far. The transition to BIM can be very complex as it requires the assessment of various factors and the adoption of adequate strategies and specific BIM software necessary to meet the objectives set.
Relying on a BIM Consultant, allows the implementation of BIM methodology within the company organisation with less risks or possibility of errors. But what is a BIM Consultant?
A BIM Consultant is a specialist in the application of the BIM methodology who, thanks to their skills, can inform and provide guidance in the development of workflows based on a BIM approach.
Before analyzing what a BIM Consultant does, it is important to specify that it is a person external to the company workforce. The possibility of contacting an external consultant is particularly advantageous for companies that are starting now to approach to the world of BIM. They will benefit from the skills offered by a highly qualified figure, without however bearing the burden of hiring a person for a permanent role.
The main objective of a BIM Consultant is to contribute to the dissemination of the BIM methodology, supporting professionals, companies and businesses in carrying out different activities.
For example, the BIM Consultant carries out analyses aimed at defining strategies and standardized workflows, to be adopted for an effective implementation of BIM at the company level. But the services offered by a BIM Consultant also support:
- the design and creation of BIM models, according to the different disciplines (architectural, structural, plant engineering, etc.);
- the configuration of the Data Sharing Environment, through a collaborative BIM platform, to ensure an efficient exchange of information;
- the processing of the deliverables management, referring to the client or contractor (Information Specifications, Offer and Information Management Plan, Information Delivery Plans, etc.);
- the coordination and BIM validation procedures, to ensure the quality and reliability of the information produced;
- the management and revision of project documents;
- the choice of appropriate platforms and software packages to support the envisaged operations;
- alignment with interoperability standards;
- the management of the BIM process in all its BIM dimensions (time, costs, sustainability, facility management);
- the training of subjects involved in the management of digitised processes with specific BIM courses.
In summary, whether it is strategic help, technical support, training or process implementation, the task of the BIM Consultant is to ensure an efficient and effective application of the BIM methodology.
Discover BIM consulting services
How do I become a BIM Consultant?
If you are interested in becoming a BIM Consultant, you should know that there is no specific certification to fill this role. However, you will need to gain a lot of experience and develop the skills and abilities required.
To play the role of BIM Consultant you must be able to intervene at any level of the process, starting from the planning phase up to the management of the entire life cycle of the work. For this reason, I recommend that you immediately download the trial of a BIM software for free and start experimenting concretely with the BIM methodology.
Knowing how to provide useful indications for the planning of BIM processes means being prepared on all aspects that gravitate around the methodology itself. Appropriate training courses and professional experience gained in the field will allow you, over time, to successfully pursue a career as a BIM Consultant.
Typical Responsibilities of a BIM Consultant
The BIM Consultant is a highly specialized figure who acts as a facilitator between design, construction, and management needs, and the digital and regulatory tools necessary to meet them. Their responsibilities can be divided into six main areas:
1. Process Analysis and BIM Strategy Implementation
Assessment of the organization’s BIM maturity through internal audits or benchmarking against defined levels (e.g., ISO 19650-1).
Definition of the BIM adoption strategy at the corporate and/or project level, adapting technological, human, and regulatory resources.
Development of digital workflows and their integration into existing design and construction processes (CAD to BIM transition).
2. Drafting and Management of BIM Documentation
Production and updating of key documents such as:
- BIM Execution Plan (BEP) – operational document that guides the entire BIM workflow of the project;
- Exchange Information Requirements (EIR) – client specifications for the use of BIM;
- MIDP/TIDP – information delivery plans at the disciplinary and overall level.
3. Multidisciplinary Coordination and Management of Federated Models
Aggregation and management of 3D models from architects, structural engineers, MEP engineers, and other stakeholders.
Verification of geometric and informational consistency through clash detection techniques (interferences, duplications, overlaps).
Management of issues through collaborative platforms.
4. Quality Control of Information (Model Checking)
Control of modeling rules and naming conventions.
Validation of informational content according to the level of development (LOD/LOI/LOIN).
Execution of semantic and syntactic checks against IFC standards, with non-conformity reports and corrective suggestions.
5. Training, Technical Support, and Change Management
Provision of internal training workshops on tools, regulations, and BIM workflows.
Support for project teams in the creation and management of digital models.
Facilitation of change management to support digital transformation and BIM adoption in change-resistant environments.
6. Interoperability and Data Management for the Lifecycle of the Project
Mapping and data conversion between native and open formats (e.g., from proprietary models to IFC).
Support for the creation of Facility Management-oriented models, integrable with IoT systems.
Coordination for the construction of the Digital Twin, ensuring the transfer of “as built” data to the client.
In public projects, the BIM Consultant may also be involved in overseeing tender specifications, reviewing the informational documents of competitors, and validating the submitted models, sometimes taking on the role of BIM Validation Authority.
This figure requires cross-disciplinary skills: technical ability in modeling and data management, regulatory knowledge, communication skills, and sensitivity to project management. The BIM Consultant is not just a software expert but a professional in digital transformation in construction processes.
Essential Tools for the BIM Consultant
BIM consultants employ a variety of advanced tools to manage and optimize digital processes in the construction sector. These tools can be divided into categories, each with specific functionalities:
1. Parametric Modeling Tools (BIM software)
These tools allow the creation of intelligent three-dimensional models that integrate geometry and information. They are essential for developing architectural, structural, and MEP models, enabling precise and coordinated design.
2. Coordination and Verification Platforms
Used to aggregate models from different disciplines, these platforms facilitate clash detection and ensure consistency among the various project components. They also support issue management through standardized formats for collaboration.
3. Common Data Environments (CDE)
These centralized environments allow for the collection, management, and distribution of project information. They facilitate collaboration among multidisciplinary teams, ensuring that all stakeholders have access to the most up-to-date and relevant information.
4. Automation and Scripting Tools
Through visual or textual programming, these tools enable the automation of repetitive processes, advanced data analysis, and workflow customization. They are particularly useful for optimizing productivity and reducing manual errors.
5. Analysis and Simulation Tools
These tools allow for energy analysis, structural simulations, and performance evaluations of the building. They provide crucial information for informed design decisions and ensure the sustainability and efficiency of the project.
6. Information Management Tools
Used to structure and manage data associated with BIM models, these tools support the definition of properties, classifications, and relationships between elements. They also facilitate the export and import of data in standardized formats for interoperability.
7. Visualization and Review Tools
These allow for immersive visualization of BIM models, facilitating project understanding among all stakeholders. They also support collaborative review, allowing annotations, comments, and approvals directly on the model.
8. Building Lifecycle Management Tools
These tools extend the use of BIM beyond the construction phase, supporting the management and maintenance of the building throughout its lifecycle. They integrate operational information, maintenance scheduling, and performance monitoring.
The adoption and mastery of these tools enable BIM consultants to ensure efficient, coordinated, and informed management of projects in the construction sector, significantly contributing to the success and sustainability of the completed works.
Frequently Asked Questions about BIM Consultant
Who is a BIM Consultant and what do they do?
The BIM Consultant is a professional expert in the BIM methodology who supports companies and professionals in the adoption, implementation, and optimization of digitized processes in the AEC field. They analyze workflows, draft documentation such as the BEP and EIR, coordinate multidisciplinary 3D models, and ensure interoperability and information quality.
What are the typical responsibilities of a BIM Consultant?
Responsibilities include analyzing and strategizing BIM implementation, managing documentation, coordinating models, quality control (model checking), training stakeholders, and managing data for the entire lifecycle of the project, up to the creation of digital twins.
How does one become a BIM Consultant?
There is no single certification, but deep experience with the BIM methodology, regulatory knowledge, and cross-disciplinary skills in modeling, coordination, project management, and digital tools are necessary. Educational paths and field practice are essential.
What tools does a BIM Consultant use?
They use tools for BIM parametric modeling, coordination, data sharing environments, automation and scripting, analysis and simulation, information management, visualization and model review, and for managing the building lifecycle.
Why should a company rely on a BIM Consultant?
To ensure an effective transition to BIM, reducing risks and increasing the quality and efficiency of the project. An external consultant offers specialized expertise without requiring the immediate hiring of a new figure in the organization.
