Dry Construction Systems
What are dry construction systems in the building world: advantages, systems, materials, and techniques
The construction sector is continuously evolving. However, significant changes, although less visible, are also influencing construction and renovation techniques, with a growing focus on sustainability and reducing construction times. A relevant example is the integration of traditional reinforced concrete construction systems with alternative methods, such as dry construction systems.
Dry construction systems: what are they?
Dry systems represent an innovative and highly efficient construction method that sharply contrasts with traditional “wet” systems based on the use of mortars, cement, and other materials that require water and drying times to ensure the structure’s solidity. Essentially, dry systems are characterized by the mechanical assembly of components using screws, bolts, metal joints, and other fastening elements, thus eliminating the use of wet binders.
Dry layered construction allows for faster construction times since work phases do not need to be interrupted to allow materials to dry. Used for both external envelopes and interiors, dry systems include the use of materials such as drywall panels, reinforced concrete slabs, and steel or wooden structures. These systems are extremely flexible and allow for a layering of elements that facilitates the integration of insulating layers, technical systems, and aesthetic finishes quickly and accurately.
Construction, especially residential, is still dominated by traditional wet techniques, where bricks are joined with mortar. However, this trend is slowly decreasing, as dry construction systems that use layered materials mounted on supporting structures made of steel or wood, or on hybrid frameworks of reinforced concrete, are increasingly spreading in many other countries.
Compared to traditional construction techniques, the dry construction system allows for the creation of structures that are more lightweight, flexible, and versatile: any type of structure can be realized, with a wide range of possibilities in creating particular shapes and the ability to make even complex modifications.
This change is motivated by various factors, among the numerous advantages offered by these methods, there is also greater environmental sustainability: dry construction reduces waste, limits environmental impact, and facilitates the recycling of materials.
For this reason, dry construction systems are often associated with green building for their ability to be disassembled and recycled in case of demolition, significantly reducing the amount of non-reusable waste.
A construction project can generally be broken down into:
- supporting structure;
- envelope and insulating systems;
- partitions.
A dry construction can be broken down in the same way, and it is possible to define more specifically all the various functions and requirements that each part must possess.
Among the main dry supporting structures, we can mention prefabricated structures, while for the envelope we can cite dry block or brick structures, and for internal partition systems, we can recall the use of gypsum panels.
Let’s see everything in detail.
Prefabricated systems
Prefabricated dry construction refers to the use of modules and panels prefabricated in a factory, which are then assembled on-site without the need for mortar or cement. Prefabricated panels can be made of cellular concrete (a lightweight and insulating material), steel, or other high-performance composites. These elements are manufactured with high precision in industrial facilities, ensuring high standards of quality and durability. Prefabricated components are assembled on-site using mechanical joining systems, without the use of mortar. They can be joined using screws, bolts, or interlocking systems.
Wood structures
Wood structures are one of the most traditional applications in dry construction, especially for building wooden houses or for creating walls and floors. The construction technology is based on the assembly of beams and wooden panels, without the use of mortar or cement. The wood used for dry construction is usually treated to improve its durability and resistance to weather conditions. Various types of wood are used, such as spruce, pine, and larch. Wood structures are assembled using mechanical connections such as screws, bolts, nails, or with interlocking systems (like stud and beam frames). In some cases, plywood or OSB (Oriented Strand Board) panels are also used for the walls.
Steel structures
Steel structures are another application of dry construction. Steel is used to create the load-bearing framework of the building, on which panels or other finishing materials are mounted. The steel used in construction is generally carbon steel or galvanized steel, treated to ensure good corrosion resistance and high durability over time. Steel beams and profiles are custom-made according to the project. The assembly of steel structures occurs through welding, screws, or bolts, creating a solid base for construction. Once the framework is assembled, cladding panels are added, which can be made of gypsum, prefabricated panels, or other materials.
These structures are used to build residential, commercial, industrial buildings, and even temporary modular structures. They are particularly appreciated for projects where it is essential to reduce construction times and minimize environmental impact.
Structure with steel beams
Dry Construction with Bricks or Blocks
Modular blocks or dry bricks are another dry construction system, where elements interlock without the need for mortar. The bricks or blocks are generally made from lightweight materials such as cellular concrete, sand, cement, or expanded clay.
Some blocks have enhanced properties, such as thermal and acoustic insulation. The blocks are simply stacked or interlocked, often without the use of mortar, thanks to mechanical interlocking systems that ensure the stability and safety of the structure.
If they lack insulation, it is possible to integrate them later with a layer of thermal insulation, which is a layer of insulating material, of varying thickness, on vertical, horizontal, or sloped surfaces, aimed at improving thermal performance, or by inserting an insulating material in the cavity between two rows of blocks in the wall, which is the empty space between two layers of blocks.
Facade Systems
To improve the energy performance of a building, action is often taken on the external envelope, particularly on the facades with so-called ventilated facades.
A typical dry ventilated envelope system is achieved with a cladding of large natural stone slabs of various types.
Thanks to its technical characteristics, ventilated stone walls indeed allow for significant advantages, insulating and protecting buildings while contributing to a significant reduction in thermal losses.
Gypsum Panels
Gypsum board is one of the most commonly used materials in dry construction for creating partition walls, ceilings, and cladding. It consists of a layer of gypsum compressed between two sheets of cardboard. Gypsum board is made from gypsum, a natural material, bonded between two sheets of paper. It can be treated with additives to improve its fire-resistant, moisture-resistant, or acoustic insulation properties. There are various types of gypsum board, including standard (used for dry environments), fire-resistant (fireproof), suitable for humid environments (like bathrooms), and sound-absorbing (to improve acoustic insulation). Gypsum panels are mounted on a metal structure (made of galvanized steel) or wood. The panels are fixed to the structure with screws or nails, creating a smooth surface ready for finishing.
Key Materials for Dry Construction for Sustainable Building
Many sustainable materials exist in nature, but the key to sustainable dry construction lies in the processes used to obtain and install them.
Sustainable dry constructions must have an impact on energy savings, pollution reduction, and the consequent improvement of the user’s quality of life and health.
To create sustainable construction, among the most common green materials used are:
- certified wood, sourced from sustainably managed forests, ensuring replanting of trees and maintenance of forest ecosystems;
- cork, obtained directly from the bark of trees;
- bamboo, an eco-friendly, strong, flexible, and renewable material;
- recycled concrete, produced from demolition debris and other construction waste;
- graphene, an ultra-lightweight and strong material, ideal for structural reinforcements and cladding;
- geopolymers, an excellent alternative to traditional cement, with a low carbon footprint;
- biocomposite materials, characterized by the presence of natural fibers and resins.
Trends and Innovations in the Dry Construction Sector
The dry construction market is experiencing steady growth, driven by sustainability demands, technological advancements, and regulatory changes.
Among the main trends is certainly the technological integration made possible by BIM software, which improves design accuracy and project management of dry works, the use of 3D printing, which allows for the rapid production of complex architectural components directly on-site, or robotics, which is generally applied for repetitive or dangerous tasks.
Also noteworthy is the use of eco-friendly materials such as recycled composites, bamboo, and low-emission solutions. Among the most interesting innovations are self-healing concrete, capable of autonomously sealing cracks, reducing maintenance costs, and electrochromic windows, equipped with glass that can become opaque or transparent based on comfort and energy-saving needs.
Building Dry: Here Are All the Advantages
Dry construction offers numerous advantages that make it an increasingly popular choice compared to traditional methods that use mortar and cement. One of the main benefits is the speed of construction. Thanks to the use of prefabricated materials and modular systems, dry construction allows for the rapid assembly of structures, reducing on-site time. This translates into a significant acceleration of the construction process, avoiding the long waiting times required for the hardening of binders like cement.
Another major advantage concerns sustainability. Dry construction has a significantly lower environmental impact compared to traditional construction. The materials used, such as wood, gypsum board, and prefabricated elements, are generally more eco-friendly. Wood, for example, is a renewable material and has a low carbon footprint. Additionally, the reduction in the use of cement contributes to lower CO₂ emissions, promoting more sustainable construction. Furthermore, many of the materials used are recyclable, further contributing to the sustainability of the construction process.
From an energy efficiency perspective, dry construction also offers good thermal and acoustic insulation capabilities. Materials such as gypsum board, wood, and thermal insulation panels are designed to reduce the energy consumption of buildings, keeping environments warmer in winter and cooler in summer. Moreover, these same materials also improve acoustic insulation, ensuring quieter and more comfortable environments.
Through the simulation of energy models, supported by energy certification software, the designer can perform analyses at different stages of the process and predict the energy needs of the building. This allows for the adoption of optimal design solutions in terms of energy savings and sustainability, which will characterize the work throughout its useful life.
The flexibility that dry construction offers is another important aspect. Modular systems and dry materials allow for great design freedom, with the possibility of easily adapting spaces and making modifications even later. This is particularly useful in renovation cases, where existing walls and structures can be quickly adapted or expanded without the use of mortar and cement. Additionally, the ability to easily modify spaces allows for optimizing the layout of environments based on the occupants’ needs.
Also from an economic perspective, dry construction presents itself as a beneficial solution. Construction costs are generally lower than traditional methods, mainly due to reduced labor costs. The speed of material installation and the reduction of labor hours required help to lower overall costs. Furthermore, the use of prefabricated materials and more efficient resource management reduce costs related to site management and waste disposal. The lightweight nature of materials used, such as gypsum board and wood, is another aspect that brings benefits. The structure is lighter than masonry, reducing the load on foundations and improving the overall stability of the building. This aspect also translates into greater safety during the construction phase, as the materials are easier to handle and less prone to risks.
There is also a cleaner and more orderly site management, with less waste and refuse production compared to traditional masonry. Prefabricated materials are precisely designed, which reduces errors during assembly and helps avoid waste. The assembly process is less invasive, producing less dust, noise, and disturbances for the surrounding environment. This also leads to a reduction in the time required for site cleanup at the end of the work.
From a durability perspective, many of the materials used in dry construction are highly resistant to weather conditions and require minimal maintenance. For example, fiber cement panels and cellular concrete blocks offer good resistance to temperature fluctuations, humidity, and mechanical damage, ensuring the longevity of the building. Additionally, some materials, such as fire-resistant gypsum board, also offer fire resistance, increasing the safety of buildings. Another significant advantage of dry construction is aesthetic customization. Materials such as gypsum board and wood offer extensive finishing possibilities, allowing spaces to be adapted to the specific aesthetic needs of the project. The ability to integrate advanced technological solutions, such as underfloor heating or photovoltaic systems, is another point in favor of dry construction, allowing for the creation of modern, efficient buildings with innovative designs.
Finally, the adaptability of dry construction is particularly advantageous in urban or renovation contexts, where construction time and visual impact are critical factors. Dry construction allows for the creation of structures that easily integrate with the existing context, without the need for invasive interventions or complex structural modifications. In summary, dry construction represents an innovative, economical, and sustainable solution to meet the modern challenges of construction, improving energy efficiency, reducing construction times, and favoring a lower environmental impact.
FAQ on Dry Construction Systems
What is meant by a dry construction system?
A dry construction system is a building technique based on the mechanical assembly of prefabricated elements — such as panels, slabs, or structures — without the use of mortars or wet binders. The components are joined with screws, bolts, or metal joints, reducing construction times and environmental impact.
What is the difference between dry construction and traditional construction?
Dry construction differs from traditional “wet” methods because it eliminates the use of cement and mortar. This allows for shorter on-site times, lighter structures, and greater design flexibility. Traditional techniques, on the other hand, require drying times and produce more processing waste.
What are the main advantages of dry construction?
The main advantages include: speed of execution, reduced labor costs, environmental sustainability, energy efficiency, and the ability to easily modify spaces over time. Additionally, the materials used (wood, gypsum board, steel) offer good thermal and acoustic insulation performance.
What materials are used in dry construction systems?
The most common materials are gypsum board, wooden or steel structures, modular blocks, prefabricated panels, and ventilated facades. From a sustainable perspective, natural or recycled materials such as cork, bamboo, geopolymers, and recycled concrete are also used.
How does the dry construction technique work?
The process consists of three main phases: creating the load-bearing structure (in steel or wood), installing the envelope and insulating systems, and finally assembling the internal partitions. All elements are assembled dry, ensuring precision, cleanliness, and speed on-site.
How sustainable is dry construction?
Dry construction is one of the most sustainable techniques: it reduces material waste, limits the use of cement, allows for the reuse of components, and promotes recycling at the end of life. Furthermore, it improves the energy efficiency of buildings through the layering of insulators and the use of natural or low-impact materials.
In what types of buildings can dry systems be applied?
Dry construction systems are used in residential, commercial, industrial, and temporary buildings. They are particularly suitable for renovations and extensions, where lightness and rapid assembly are essential to reduce time and inconvenience.
What are the latest innovations in the dry construction sector?
The main innovations involve integration with digital technologies such as BIM, 3D printing, and robotics applied to assembly. Additionally, the use of new high-performance materials — such as self-healing concrete, geopolymers, and electrochromic windows — makes dry systems even more efficient and sustainable.
