Construction management: 4 steps for an effective workflow
A construction management workflow is a process that describes the actions needed to complete a construction project. Here are 4 steps to do it effectively!
Workflows are essential to the successful completion of any project. They allow you to organize people, tools, resources and activities to effectively achieve design goals.
Lets Discover in this article which are the steps to create a truly efficient construction management workflow starting to use immediately a software solution for construction management in order to automate all your workflows making them even smarter and more productive.
- Management of the construction workflow: what does it mean?
- The tools to simplify construction workflow operations
- The role of construction workflow management in project success
- 5 Examples of Construction Management Workflows
- How to improve the construction workflow process
- 4 Steps to implement an Effective Construction Management Workflow
- The 7 best work scheduling techniques for project management strategies
- What are the advantages of a construction management workflow?
- FAQ- Construction management workflow
The expression construction workflow indicates the sequence of activities (called tasks) to be complete in order to achieve a certain objective during the process of designing and implementing a work.
These are carefully planned and coordinated sequential actions which help professionals and companies in the construction sector to standardize all processes operating more efficiently and productively.
Each construction project can include many specific workflows. Their purpose is to describe in detail what activities to undertake in order to correctly complete the phases of the construction process. Thus identifying the subjects and tools necessary for their execution.
Creating a construction workflow
A good construction management software helps project managers and construction managers to plan and organize construction projects by monitoring activities, resources, and timelines and ensuring greater control.
It supports professional activity because it allows the creation and sharing of the workflow with all various stakeholders: this translates into a direct knowledge and always real-time understanding of the project’s status, completed phases, and those yet to be completed.
A well-planned workflow ensures that the team correctly completes activities at every stage of the process, which results in a reduction in the number of errors during the development of the process and, above all, the risk of noticing them too late.
If you want to create efficient and innovative construction workflows and optimize your construction processes, try the construction management software right away. With this system, you can assign, start, track, and manage any activity related to your projects. Watch the video below to discover how to transform the issues that usually arise during the design phase into simple tasks to solve and monitor from start to completion.
Managing the workflow in construction is essential for effective project management, optimal control of expenses and timelines, collaboration, quality assurance, and risk management.
It provides a roadmap for all stakeholders and ensures that the project proceeds smoothly, achieves its objectives, and concludes successfully. This allows for a range of benefits, as:
- ensures that all operations are developed correctly: workflows provide those involved in the construction process with clear guidelines on how to perform various activities. They allow for advance planning of the operations to be carried out. All this ensures that the work is completed consistently and correctly, and that delays and errors of any kind are minimized;
- saves time and money: an efficient workflow speeds up all operations and saves valuable time to dedicate to other important aspects of the project. With the use of construction management software systems, it is also possible to schedule various activities, simplify role assignments, track progress, and resolve issues that arise during the design phase. All this translates into improved efficiency and a consequent reduction in costs;
- allows for standardization of processes: workflows have the ability to transform a mix of individual activities (that are not connected) into a perfectly organized and standardized process. They define who, when, and how the individual operations must be carried out to complete a job. This helps avoid costly delays and minimizes problems and unforeseen events;
- improves efficiency and productivity: standardized workflows minimize the need to rework steps for future projects. They also ensure that all activities are carried out within the expected timelines, significantly improving efficiency and productivity;
- reduces errors and rework: proper work planning allows for the early identification and resolution of potential problems. Well-organized workflows thus help reduce design errors and the need for costly changes during the project.
Among the construction management workflows that make it possible to greatly improve the management of a project we find, for example:
- BIM Workflow: is a workflow that involves the application of BIM (Building Information Modeling) methodology to the design processes of construction and infrastructure works. Encourages collaboration between stakeholders, supporting the creation of intelligent data. This can be used at every stage of the project lifecycle, from planning to completion;
- pre-construction: is the preliminary planning phase that serves to outline the scope of the project and to define the program for the construction team. The success of the entire project’s accuracy depends on the execution of the workflow. In fact, it provides for the definition of the budget, the identification of risks, the obtaining of permits and authorizations, the scheduling of works, the procurement of resources, and so on;
- RFIs: in the construction field, RFIs (Request for information) are formal processes in which the parties involved, such as the designer or the contractor, clarify any information gaps present in the construction documents (such as plans, drawings, specifications and agreements). RFIs are usually issued at the initial stage of the project. If the inconsistencies are addressed before the start of the works, it will be possible to avoid problems, errors and delays during the construction phase;
- change orders: Changes are quite frequent in a construction project. It may involve the introduction of additional work to those agreed in the contract or, on the contrary, the removal of a part of the scheduled work. A change order management workflow will help stakeholders deal more efficiently with design changes, seamlessly recording all changes made to the original construction contract;
- site management: site workflows are essential to optimize and standardize all repeatedly performing operations . Organizing the work in a more structured way is possible thanks to the help flowcharts. Making the different activities simpler and more understandable for all workers.
5 Essential Construction Workflows
Improving construction workflow management requires agility and adaptability to enhance internal processes
The first step is certainly the creation of a shared and common environment, a CDE where all project information can be shared and stored, accessible from anywhere.
It is important to train the team to use it effectively and define best practices for data entry and access to ensure consistency and clarity.
Moreover, with these platforms, an effective communication throughout the entire project is developed, ensuring that all stakeholders are on the same wavelength, reducing misunderstandings and errors.
Simplifying project planning then allows for the schematization of the design and construction process, clearly defining milestones and outcomes to be achieved.
Finally, it is useful to develop a real-time monitoring process that ensures you are always informed about the project’s progress, allowing for quick and informed decision-making.
Diagrams and construction workflow: how do they simplify activity monitoring?
A construction workflow diagram simplifies activity monitoring because it allows you to:
- directly visualize the activities to be performed;
- check dependencies and critical issues;
- be aware of resources and management methods;
- frame the responsibilities of the work team;
- identify expected outcomes.
Among the common project management techniques in construction that allow for the creation of a workflow diagram, we mention:
- Gantt chart;
- Critical Path Method (CPM);
- Program Evaluation and Review Technique (PERT);
- Resource-oriented planning;
- Line of Balance (LOB) planning technique;
- Q planning;
- Last Planner System (LPS).
Having good workflows allows you to break down complex projects into simpler steps. Thus allowing parties involved to successfully complete their tasks.
To build a construction management workflow that is truly effective, it is important to follow some fundamental steps:
- identify the construction’s activities: precisely listing activities is always a first step, regardless of the complexity of the project. It is necessary, then, to organize these activities according to a logical-temporal sequence. It is important not to leave anything out, laying all steps and including all actions that must be achieve before and after a main activity. Such as, for example, obtaining the approval of the interested parties or performing all the final checks required;
- find the necessary tools: the second step is to identify the necessary tools to complete each operation. It is advisable to focus on the resources that are currently unavailable (such as software, templates, files, etc.) creating an adequate procurement plan;
- assign roles and responsibilities: this is the step that involves assigning tasks to the various departments and/or subjects involved. For each role, you can define key responsibilities that fit your specific position. Each team member should be aware of their role and only be responsible for the activities that fall within their duties. Properly assigning tasks and responsibilities avoids counterproductive overlaps and ensures enormous advantages in terms of efficiency and productivity;
- improve workflow over time: Implementing a construction workflow will most likely not be perfect the first time. However, through the monitoring of appropriate performance indicators, it will be possible to test and refine all activities over time making any changes and improvements required.
To optimize the construction workflow, I recommend following these 7 key steps, which will greatly help simplify workflows to achieve successful results:
- Step 1: create a plan – it is necessary to understand the scope and boundaries of the project, planning in detail each phase to smoothly reach the final goal. It is essential to align with the client’s expectations, defining the final outcomes together.
- Step 2 – Role assignment – Clearly assigning roles and responsibilities is important to define the phases that require management or stakeholder approval;
- Step 3 – Organize preliminary meetings – Before actually starting the project, it is advisable to organize frequent meetings with stakeholders to review the plan, verify the responsibilities of the parties involved, and adopt appropriate corrective actions;
- Step 4 – Increase flexibility – it is necessary to develop an adequate capacity to address changes as they arise, turning unforeseen events into opportunities;
- Step 5 – Implement a document management system – it is advisable to implement an efficient BIM document management system that helps simplify the creation, management, updating, and sharing of all project documents, as stakeholders will need to have the appropriate documentation at the right time during the project;
- Step 6 – Improve collaboration and communication – it is essential to leverage technologies that promote collaboration and real-time data transmission, so that team members have up-to-date and reliable information;
- Step 7 – Automate management activities – using construction management software will provide you with the necessary features to simplify project management and optimize workflow progress.
You may apply workflows to any performing task in a construction project hence providing a number of benefits, such as:
- ensures carrying out all operations correctly: workflows provide the subjects involved in the construction process with clear guidelines on how to perform their different activities. They allow you to plan in advance the constructions’ operations. All this ensures that the work is completed consistently and correctly. Therefore keeping delays and errors of all kinds to a minimum;
- save time and money: a workflow that is really efficient, allows you to speed up all operations. Therefore saving and assigning valuable time to other important aspects of the project. With the use of systems software for construction management it is also possible to program the different activities. This simplifies the roles’ assignments and keeps progress’ track seamsly. Hence solving problems that arise during the course of design. All this translates into an improvement in efficiency and a consequent reduction in costs;
- allowing processes to be standards: workflows have the ability to transform a mixture of individual activities (unrelated to each other). Turning them into a perfectly organized and standardized process. They define by whom, when and how individual operations must be performed to complete a job. This avoids costly delays and reduces problems and unexpected events;
- improves efficiency and productivity: Standardizing workflows minimize the need to reshape steps for future projects. They also ensure that all activities are carried out on time, greatly improving efficiency and productivity;
- reduces errors and rework: proper work planning allows you to identify and solve potential problems in advance. Well-organized workflows therefore reduce design errors and the need for costly variants in the pipeline.
Try a construction management software right away if you want to create efficient and innovative construction workflows. It will optimize your construction processes. With this system you can assign, start, track and manage any activity that concerns your projects. The problems that usually arise during the course of the design will no longer be a problem! You can turn them into simple tasks to solve and monitor the resolution process from start to finish.
To learn more, read also: Construction Work Orders: 8 Effective Types
What is a construction workflow?
A construction workflow is the sequence of planned and coordinated activities (tasks) that must be completed to achieve a specific goal during the design and project implementation.
Why are workflows essential in construction projects?
They allow for the effective organization of people, tools, resources, and activities, ensuring that operations are carried out correctly, with fewer errors, delays, and costs.
What are the main advantages of a well-planned construction workflow?
- better control over timelines and costs;
- greater efficiency and productivity;
- reduction of errors and rework;
- standardization of processes;
- coordination among all involved parties.
What are the steps to implement an effective construction management workflow?
- identify the activities to be performed;
- acquire the necessary tools;
- assign roles and responsibilities;
- improve the workflow over time.
How can software help in managing the construction workflow?
A construction management software allows you to plan, assign, track, and manage activities in a centralized and collaborative manner. It helps share the project’s status in real-time and transform critical issues into monitorable tasks.
What techniques can I use to create a workflow diagram in construction?
- Gantt chart;
- PERT technique;
- Q planning;
- Line of Balance (LOB);
